  4. X-Sense Adapter
    6.8k
X-Sense Adapter
177 Beiträge 22 Kommentatoren 21.7k Aufrufe 26 Beobachtet
  • I Ice_age_77
    @arteck: Ich bekomme den Adapter leider nicht zum laufen. Könntest Du bitte nochmal drüber schauen wo es bei meinem System hakt?
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Raspbian GNU/Linux 11 (bullseye)
       Static hostname: RaspberryPi4B
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     14:42:51 up 9 days, 12:25,  2 users,  load average: 2.20, 1.44, 1.17
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-12-19 14:42:51 CET
               Universal time: Fri 2025-12-19 13:42:51 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            7.8G        3.1G        224M        1.0M        4.5G        4.6G
    Swap:            99M          0B         99M
    Total:          7.9G        3.1G        324M
    Active iob-Instances:   41
             7811 M total memory
             3131 M used memory
             5023 M active memory
             2114 M inactive memory
              224 M free memory
              216 M buffer memory
             4239 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 14:42:51 up 9 days, 12:25,  2 users,  load average: 2.20, 1.44, 1.17
    Tasks: 236 total,   2 running, 234 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6.9 us,  6.9 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7811.3 total,    224.2 free,   3131.1 used,   4456.0 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4557.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      458G   39G  396G   9% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Wed Dec 10 02:16:54 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:C4:82:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4a22189-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Dec 10 02:16:56 2025] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Wed Dec 10 02:16:56 2025] EXT4-fs (sda2): write access will be enabled during recovery
    [Wed Dec 10 02:16:58 2025] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Wed Dec 10 02:16:58 2025] EXT4-fs (sda2): 6 orphan inodes deleted
    [Wed Dec 10 02:16:58 2025] EXT4-fs (sda2): recovery complete
    [Wed Dec 10 02:16:58 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Dec 10 02:16:58 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Dec 10 02:17:00 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime,stripe=8191
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.7G    /var/
    1.9G    /var/log
    1.8G    /var/log/journal/2ffba3cdeb49409eb30d3df1267d3cf0
    634M    /var/cache
    Archived and active journals take up 1.7G in the file system.
    /opt/iobroker/backups:
    1.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18G     /opt/iobroker/iobroker-data/history
    393M    /opt/iobroker/iobroker-data/files
    114M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/vis-2
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    31M     /opt/iobroker/iobroker-data/states.jsonl
    13M     /opt/iobroker/iobroker-data/history/20250215/history.mqtt.0.iot.smartmeter.sensor.2.obis.1-0~1.8.0.255.value.json
    13M     /opt/iobroker/iobroker-data/history/20241222/history.mqtt.0.iot.smartmeter.sensor.1.obis.1-0~16.7.0.255.value.json
    12M     /opt/iobroker/iobroker-data/history/20251218/history.mqtt.0.iot.smartmeter.sensor.2.obis.1-0~1.8.0.255.value.json
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_WiMOD_iM871A-usb_0275947E-if00-port0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.15.0
    /usr/bin/node           v22.15.0
    /usr/bin/npm            10.9.2
    /usr/bin/npx            10.9.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 22.15.0-1nodesource1
      Candidate: 22.15.0-1nodesource1
      Version table:
     *** 22.15.0-1nodesource1 600
            500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u7 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v22.15.0) is vulnerable to the following CVEs:
    CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
    Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    RaspberryPi4B       RaspberryPi4B (version: 7.1.0, hostname: RaspberryPi4B , alive, uptime: 612260)
    Core adapters versions
    js-controller:  7.1.0
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
      system.adapter.adb.0                    : adb                   : RaspberryPi4B                            - disabled
    + system.adapter.admin.0                  : admin                 : RaspberryPi4B                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : RaspberryPi4B                            -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : RaspberryPi4B                            -  enabled
    + system.adapter.backitup.0               : backitup              : RaspberryPi4B                            -  enabled
    + system.adapter.bluelink.0               : bluelink              : RaspberryPi4B                            -  enabled
    + system.adapter.cloud.0                  : cloud                 : RaspberryPi4B                            -  enabled
      system.adapter.daswetter.0              : daswetter             : RaspberryPi4B                            -  enabled
      system.adapter.device-reminder.0        : device-reminder       : RaspberryPi4B                            - disabled
    + system.adapter.discovery.0              : discovery             : RaspberryPi4B                            -  enabled
    + system.adapter.echarts.0                : echarts               : RaspberryPi4B                            -  enabled
    + system.adapter.eusec.0                  : eusec                 : RaspberryPi4B                            -  enabled
      system.adapter.flot.0                   : flot                  : RaspberryPi4B                            - disabled
    + system.adapter.followthesun.0           : followthesun          : RaspberryPi4B                            -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi4B                            -  enabled
    + system.adapter.harmony.0                : harmony               : RaspberryPi4B                            -  enabled
    + system.adapter.history.0                : history               : RaspberryPi4B                            -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : RaspberryPi4B                            -  enabled
    + system.adapter.hue.0                    : hue                   : RaspberryPi4B                            -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : RaspberryPi4B                            -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : RaspberryPi4B                            -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : RaspberryPi4B                            - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RaspberryPi4B                            - disabled
    + system.adapter.info.0                   : info                  : RaspberryPi4B                            -  enabled
      system.adapter.intex.0                  : intex                 : RaspberryPi4B                            - disabled, port: 8990
    + system.adapter.iot.0                    : iot                   : RaspberryPi4B                            -  enabled
    + system.adapter.javascript.0             : javascript            : RaspberryPi4B                            -  enabled
    + system.adapter.knx.0                    : knx                   : RaspberryPi4B                            -  enabled, bind: 192.168.178.11
      system.adapter.modbus.0                 : modbus                : RaspberryPi4B                            - disabled
    + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi4B                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : RaspberryPi4B                            -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : RaspberryPi4B                            -  enabled
      system.adapter.nuki.0                   : nuki                  : RaspberryPi4B                            - disabled
      system.adapter.openknx.0                : openknx               : RaspberryPi4B                            - disabled
    + system.adapter.rpi2.0                   : rpi2                  : RaspberryPi4B                            -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : RaspberryPi4B                            -  enabled, port: 45555, bind: 0.0.0.0
      system.adapter.scheduler.0              : scheduler             : RaspberryPi4B                            - disabled
      system.adapter.schoolfree.0             : schoolfree            : RaspberryPi4B                            -  enabled
    + system.adapter.shelly.0                 : shelly                : RaspberryPi4B                            -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : RaspberryPi4B                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartcontrol.0           : smartcontrol          : RaspberryPi4B                            -  enabled
    + system.adapter.smartthings.0            : smartthings           : RaspberryPi4B                            -  enabled
    + system.adapter.solarlog.0               : solarlog              : RaspberryPi4B                            -  enabled, port: 80
    + system.adapter.sourceanalytix.0         : sourceanalytix        : RaspberryPi4B                            -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : RaspberryPi4B                            -  enabled
      system.adapter.telegram.0               : telegram              : RaspberryPi4B                            - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.time-switch.0            : time-switch           : RaspberryPi4B                            - disabled
    + system.adapter.trashschedule.0          : trashschedule         : RaspberryPi4B                            -  enabled
    + system.adapter.tuya.0                   : tuya                  : RaspberryPi4B                            -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : RaspberryPi4B                            -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : RaspberryPi4B                            -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : RaspberryPi4B                            -  enabled
      system.adapter.vis-history.0            : vis-history           : RaspberryPi4B                            - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : RaspberryPi4B                            -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : RaspberryPi4B                            -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RaspberryPi4B                            - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : RaspberryPi4B                            - disabled
      system.adapter.vis-material.0           : vis-material          : RaspberryPi4B                            - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : RaspberryPi4B                            - disabled
      system.adapter.vis-metro.0              : vis-metro             : RaspberryPi4B                            - disabled
      system.adapter.vis-players.0            : vis-players           : RaspberryPi4B                            - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : RaspberryPi4B                            - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : RaspberryPi4B                            -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : RaspberryPi4B                            - disabled
      system.adapter.vis-weather.0            : vis-weather           : RaspberryPi4B                            -  enabled
      system.adapter.vis.0                    : vis                   : RaspberryPi4B                            -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : RaspberryPi4B                            -  enabled
    + system.adapter.web.0                    : web                   : RaspberryPi4B                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : RaspberryPi4B                            -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : RaspberryPi4B                            -  enabled
    + system.adapter.wireless-mbus.0          : wireless-mbus         : RaspberryPi4B                            -  enabled
    + system.adapter.ws.0                     : ws                    : RaspberryPi4B                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.xsense.0                 : xsense                : RaspberryPi4B                            - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 7.7.22   , installed 7.7.19 [Updatable]
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.13   , installed 3.3.11 [Updatable]
    Adapter    "bluelink"     : 3.1.23   , installed 3.1.23
    Adapter    "cloud"        : 5.1.2    , installed 5.1.2
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "echarts"      : 2.0.10   , installed 2.0.10
    Adapter    "eusec"        : 2.0.3    , installed 2.0.3
    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "harmony"      : 2.0.3    , installed 2.0.3
    Adapter    "homeconnect"  : 1.5.2    , installed 1.5.1  [Updatable]
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "intex"        : 0.1.7    , installed 0.1.7
    Adapter    "iot"          : 5.0.11   , installed 5.0.7  [Updatable]
    Adapter    "javascript"   : 9.0.17   , installed 9.0.11 [Updatable]
    Controller "js-controller": 7.1.0    , installed 7.1.0
    Adapter    "knx"          : 2.0.33   , installed 2.0.33
    Adapter    "modbus"       : 7.0.6    , installed 7.0.6
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "openknx"      : 0.9.0    , installed 0.9.0
    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
    Adapter    "sainlogic"    : 1.0.14   , installed 0.12.1 [Updatable]
    Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
    Adapter    "schoolfree"   : 1.1.13   , installed 1.1.13
    Adapter    "shelly"       : 10.5.0   , installed 10.4.1 [Updatable]
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "smartthings"  : 0.2.2    , installed 0.2.2
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "solarlog"     : 2.4.0    , installed 2.4.0
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 1.5.6  , installed 1.5.3  [Updatable]
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 5.1.0    , installed 5.0.0  [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.0.3  [Updatable]
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Adapter    "xsense"       : 0.2.1    , installed 0.2.1
    Objects and States
    Objects:        35185
    States:         31366
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 12
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      116        15898      590/redis-server 12
    tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1000       138254641  23934/nc
    tcp        0      0 0.0.0.0:45555           0.0.0.0:*               LISTEN      1001       30616993   15177/io.sainlogic.
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13965      614/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          126222218  6893/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30605327   13794/iobroker.js-c
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       30604130   13986/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       30609677   14006/io.shelly.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      116        15899      590/redis-server 12
    tcp6       0      0 :::3333                 :::*                    LISTEN      1001       30610677   14436/io.fullybrows
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30617080   15157/io.simple-api
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       30615662   14706/io.web.1
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       30612331   14656/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30615541   14600/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30605438   13825/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       30605559   13836/io.admin.1
    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       30612488   14766/go2rtc
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       30612487   14766/go2rtc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          126222217  6893/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13967      614/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       30609092   14448/io.harmony.0
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       30612483   14766/go2rtc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15186      427/avahi-daemon: r
    udp        0      0 0.0.0.0:54549           0.0.0.0:*                           1001       30611707   14495/io.eusec.0
    udp        0      0 192.168.178.11:50485    0.0.0.0:*                           1001       45465777   13936/io.knx.0
    udp        0      0 0.0.0.0:54819           0.0.0.0:*                           1001       39083033   14495/io.eusec.0
    udp        0      0 192.168.178.11:58959    0.0.0.0:*                           1001       59038221   13936/io.knx.0
    udp        0      0 192.168.178.11:46741    0.0.0.0:*                           1001       47574964   13936/io.knx.0
    udp        0      0 0.0.0.0:55261           0.0.0.0:*                           1001       38554050   14495/io.eusec.0
    udp        0      0 192.168.178.11:51168    0.0.0.0:*                           1001       104739020  13936/io.knx.0
    udp        0      0 192.168.178.11:51655    0.0.0.0:*                           1001       116633728  13936/io.knx.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       30609125   14140/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       30609126   14140/io.tuya.0
    udp        0      0 192.168.178.11:35675    0.0.0.0:*                           1001       69500755   13936/io.knx.0
    udp        0      0 192.168.178.11:40450    0.0.0.0:*                           1001       91779757   13936/io.knx.0
    udp        0      0 0.0.0.0:40498           0.0.0.0:*                           108        15188      427/avahi-daemon: r
    udp        0      0 0.0.0.0:48736           0.0.0.0:*                           1001       30611699   14495/io.eusec.0
    udp        0      0 192.168.178.11:44671    0.0.0.0:*                           1001       69500228   13936/io.knx.0
    udp        0      0 192.168.178.11:36506    0.0.0.0:*                           1001       30620618   13936/io.knx.0
    udp        0      0 0.0.0.0:36888           0.0.0.0:*                           1001       56720176   14495/io.eusec.0
    udp        0      0 192.168.178.11:41004    0.0.0.0:*                           1001       48531624   13936/io.knx.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16398      494/dhcpcd
    udp        0      0 192.168.178.11:53441    0.0.0.0:*                           1001       37989066   13936/io.knx.0
    udp        0      0 0.0.0.0:53742           0.0.0.0:*                           1001       101385616  14495/io.eusec.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       30609093   14448/io.harmony.0
    udp        0      0 0.0.0.0:58055           0.0.0.0:*                           1001       30612503   14495/io.eusec.0
    udp6       0      0 :::5353                 :::*                                108        15187      427/avahi-daemon: r
    udp6       0      0 :::8555                 :::*                                1001       30612489   14766/go2rtc
    udp6       0      0 :::53611                :::*                                108        15189      427/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16418      494/dhcpcd
    2025-12-19 14:44:28.225  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.c8d778ef4ad8.rps:{"val":11.904761904761905,"ack":true,"ts":1766151868223,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151868223}
    2025-12-19 14:44:28.267  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.606d3c24581d.alive:{"val":true,"ack":true,"ts":1766151868265,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1765422805285}
    2025-12-19 14:44:28.269  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.606d3c24581d.time:{"val":0.00094,"ack":true,"ts":1766151868266,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151868266}
    2025-12-19 14:44:28.291  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.606d3c24581d.rps:{"val":1000,"ack":true,"ts":1766151868289,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151840789}
    2025-12-19 14:44:28.292  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.e0286d8cb318.alive:{"val":true,"ack":true,"ts":1766151868289,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1765712710449}
    2025-12-19 14:44:28.292  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.e0286d8cb318.time:{"val":0.000242,"ack":true,"ts":1766151868289,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151868289}
    2025-12-19 14:44:28.292  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.e0286d8cb318.rps:{"val":1000,"ack":true,"ts":1766151868289,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151061100}
    2025-12-19 14:44:28.293  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.e45f01c482c6.alive:{"val":true,"ack":true,"ts":1766151868289,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766020974642}
    2025-12-19 14:44:28.293  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.e45f01c482c6.time:{"val":0.00007199999999999999,"ack":true,"ts":1766151868290,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151868290}
    2025-12-19 14:44:28.293  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.e45f01c482c6.rps:{"val":1000,"ack":true,"ts":1766151868290,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766147427492}
    2025-12-19 14:44:28.298  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.0cc5743470e7.alive:{"val":true,"ack":true,"ts":1766151868297,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1765712713183}
    2025-12-19 14:44:28.299  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.0cc5743470e7.time:{"val":0.00019600000000000002,"ack":true,"ts":1766151868297,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151868297}
    2025-12-19 14:44:28.338  - silly: javascript.0 (13844) States user redis pmessage io.*/io.net-tools.0.0cc5743470e7.rps:{"val":1000,"ack":true,"ts":1766151868337,"q":0,"from":"system.adapter.net-tools.0","user":"system.user.admin","lc":1766151774660}
    2025-12-19 14:44:28.349  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.alive:{"val":true,"ack":true,"ts":1766151868345,"q":0,"from":"system.adapter.backitup.0","lc":1765539621009}
    2025-12-19 14:44:28.350  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.connected:{"val":true,"ack":true,"ts":1766151868345,"q":0,"from":"system.adapter.backitup.0","lc":1765539621009}
    2025-12-19 14:44:28.351  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.memRss:{"val":126.79,"ack":true,"ts":1766151868346,"q":0,"from":"system.adapter.backitup.0","lc":1766118642076}
    2025-12-19 14:44:28.353  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.memHeapTotal:{"val":34.35,"ack":true,"ts":1766151868346,"q":0,"from":"system.adapter.backitup.0","lc":1766148058195}
    2025-12-19 14:44:28.353  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.memHeapUsed:{"val":29.69,"ack":true,"ts":1766151868346,"q":0,"from":"system.adapter.backitup.0","lc":1766151868346}
    2025-12-19 14:44:28.355  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.eventLoopLag:{"val":2,"ack":true,"ts":1766151868347,"q":0,"from":"system.adapter.backitup.0","lc":1766151793345}
    2025-12-19 14:44:28.355  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.uptime:{"val":612301,"ack":true,"ts":1766151868347,"q":0,"from":"system.adapter.backitup.0","lc":1766151868347}
    2025-12-19 14:44:28.357  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.inputCount:{"val":0,"ack":true,"ts":1766151868347,"q":0,"from":"system.adapter.backitup.0","lc":1766123967271}
    2025-12-19 14:44:28.357  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.outputCount:{"val":11,"ack":true,"ts":1766151868347,"q":0,"from":"system.adapter.backitup.0","lc":1766093501092}
    2025-12-19 14:44:28.360  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.cpu:{"val":0.07,"ack":true,"ts":1766151868358,"q":0,"from":"system.adapter.backitup.0","lc":1766151823346}
    2025-12-19 14:44:28.364  - silly: javascript.0 (13844) States user redis pmessage io.*/io.system.adapter.backitup.0.cputime:{"val":384.53,"ack":true,"ts":1766151868359,"q":0,"from":"system.adapter.backitup.0","lc":1766151868359}
    2025-12-19 14:44:28.513  - silly: javascript.0 (13844) States user redis pmessage io.*/io.tuya.0.bff93c8458f6e40bd0r3js.105:{"val":19,"ack":true,"ts":1766151868512,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1766151868512}
    ilovegymI Offline
    ilovegymI Offline
    ilovegym
    #121
    @Ice_age_77
    erstmal dein Uraltes System neu Aufsetzen, also iobroker Backup machen, dann am besten ne neue SD Karte und mit Debian Trixie Lite ohne Desktop installieren, iobroker wieder drauf und das Backup restoren.
    Dann kann man weiter sehen..
    I 1 Antwort Letzte Antwort
    • I Ice_age_77
      Script v.2025-08-09
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
               3131 M used memory
                224 M free memory
                216 M buffer memory
               4239 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      1.9G    /var/log
      634M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Hosts:
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        35185
      States:         31366
      Pending Updates: 12
      arteckA Offline
      arteckA Offline
      arteck
      #122
      @Ice_age_77 sagte in X-Sense Adapter:
      erstmal was @ilovegym geschrieben hat
      dann
      LOG vom adapter
      • I Ice_age_77
        Script v.2025-08-09
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7811 M total memory
                 3131 M used memory
                  224 M free memory
                  216 M buffer memory
                 4239 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        2.7G    /var/
        1.9G    /var/log
        634M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.2
        /usr/bin/npx            10.9.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Hosts:
        admin:          7.7.19
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        35185
        States:         31366
        Pending Updates: 12
        #123
        System von Grund auf neu aufsetzen. In der 64Bit-Lite-Version auf einem neuen Datenträger.
        Und log nicht auf silly:
        silly: javascript.0
        • ilovegymI ilovegym
          @Ice_age_77
          I Offline
          I Offline
          Ice_age_77
          #124
          @ilovegym OK Danke werde ich tun. Eine Frage habe ich zum Backup. Reicht es aus bzw. ist es der richtige weg das Backup über Backitup Adapter zu sichern und auch wieder zu restoren. Werden dort alle Einstellungen etc. mit rübergenommen? Ich habe als Speichermedium eine SSD am RPI, die kann ich dann zur Installation wieder verwenden oder ?
          • I Ice_age_77
            #125
            @Ice_age_77
            Das ist der Zweck des Backups...
            Die SSD würde ich aber mal unter die Lupe nehmen.
            Wenn die inodes vergisst schaut das nicht gut aus. Du fährst das System ja immer sauber herunter und ziehst nicht einfach den Stecker...
            • SlimsteveS Offline
              SlimsteveS Offline
              Slimsteve
              #126
              hi und schönes neues erstmal. hab auch das system neu aufsetzen müssen wie oben beschrieben adapter läuft, krieg aber die melder nicht. hab des neues python welches ich im adapter nicht auswählen kann. liegt es evtl daran?
              Merlin123M 1 Antwort Letzte Antwort
              • SlimsteveS Slimsteve
                Merlin123M Offline
                Merlin123M Offline
                Merlin123
                #127
                @Slimsteve kann sein. Installier doch die Version, die unterstützt wird.
                Beta-Tester
                SlimsteveS 1 Antwort Letzte Antwort
                  danieldownload
                  #128
                  ich versuche grade den Adapter mit meinen Thermometern zu Laufen zu bekommen. Das funktioniert grundlegend, jedoch bekomme ich nur aktuelle Daten, wenn ich in der IPhone App die Daten abfrage und aktualisiere. Wenn ich das nicht mache, bekomme ich nur immer den selben Wert in iobroker rein. Separater Login wird verwendet.
                  Woran liegt das?
                  Grüße,
                  Daniel
                  arteckA protreeP 2 Antworten Letzte Antwort
                  • Merlin123M Merlin123
                    SlimsteveS Offline
                    SlimsteveS Offline
                    Slimsteve
                    schrieb am zuletzt editiert von Slimsteve
                    #129
                    @Merlin123
                    i bin a iobroker newbie. ist downgrad so einfach machbar? dann tu ich das natürlich sofort. google hat mir da ned wirklich so helfen können das ich mir des zu trau 🙈
                    hab gerade erfahren das ich am besten eine zweite python version installieren, wie kann ich dann dem adapter erklären das er diese python version nutzt. bzw muss ich python erklären er soll diesen adapter nutzen?
                    wäre mega wenn mir jemand da helfen könnte
                    danke euch vielmals
                    • D danieldownload
                      Woran liegt das?
                      Grüße,
                      Daniel
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #130
                      @danieldownload sagte in X-Sense Adapter:
                      Woran liegt das?
                      kein plan.. schick mir mal ein zusatz login so dass ich den verwenden kann..
                      muss ich mir mal anschauen was da läuft
                      @Slimsteve sagte in X-Sense Adapter:
                      was willst du da downgraden.. der adapter installiert sich inzwischen intern eine python Version.. da ist keine zusätzlich installierte nicht nötig..
                      welche Melder werden den nicht angezeigt ? es hat nix mit der python version zu tun
                        SlimsteveS Offline
                        Slimsteve
                        #131
                        hab die sd11-mr
                        wenn ich daheim bin kriegst ne log. danke dir schonmal im voraus
                        • arteckA arteck
                          Woran liegt das?
                          SlimsteveS Offline
                          SlimsteveS Offline
                          Slimsteve
                          #132
                          @arteck
                          hab im adapter debug angeklickt und es kamen fehler aber er läuft alle melder sind da
                          danke für den adapter
                          • patricknitschP Online
                            patricknitsch
                            #133
                            Guten Morgen,
                            ich habe den Adapter mit Basisstation und sechs Rauchmeldern getestet. Verbindung steht, alles wird richtig ausgelesen und die Testfunktion klappt ebenfalls.
                            Danke für den Adapter!
                            Systeme:
                            • Proxmox 1 mit ioBroker, HomeAssistant, piHole
                            • Proxmox 2 mit SOLECTRUS, Mosquitto, piHole und Frigate
                            • RPi4 mit Octoprint
                            Eigene Adapter: grohe-smarthome, solectrus-influxdb, schlueter-thermostat
                              Ritter
                              #134
                              die Basissation SBS50 lässt sich jetzt auch lokal über MQTT verbinden mit neuer Firmware und APP.
                              • R Ritter
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #135
                                @Ritter ja ABER...
                                man muss die APP Version 1.34 haben UND die Bridge SBS50....
                                es kommen nicht alle Informationen rüber..
                                somit sehr gut für alarmierung aber man kann kein Test durchführen..
                                also ich habe eine hybride Version gebaut.. die Grundinformationen werden wie bis jetzt per python geholt..
                                die relevanten Informationen per MQTT..
                                somit kann man das Abfragintervall höher setzen1354acd9-cda6-4431-93d4-8442f2b48815-grafik.png
                                da ich nur RWM's hier habe und CO Melder weiss ich nicht was kommt bei Wasser oder Magnetsensoren...
                                WICHTIG
                                  Ritter
                                  #136
                                  Das mit der hybriden Version ist super, danke. Die Wassermelder werden über MQTT nicht angezeigt, die Rauchmelder XS01-M gehen.
                                  • Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #137
                                    Kann mir mal jemand nen Hinweis zu MQTT geben?
                                    Ich habe schon nen MQTT Server in io broker laufen.
                                    Ist der Port im XSense der auf iobroker Seite? Dann müsste ich mir da nen freien Suchen.
                                    Muss ich in der App was ändern?
                                    Ach ja.. Im Changelog auf Git ist glaub ich ein Zahlendreher:
                                    0.2.4 (2026-01-24)
                                    (arteck) add MQTT communication to Bridge. Xsense app Version > 1.43 is necessary
                                    Soll da nicht 1.34 stehen?
                                    Beta-Tester
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #138
                                      wenn du einen MQTT Server laufen hast .. dann musst du nur in der xsense app den angeben incl. port.. dann meldet die Bridge die sache dahin
                                      im adapter gibst du genau das was du in der app eingegeben hast und wählst externer MQTT
                                      und ja zahlendreher..thx
                                      • R Ritter
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #139
                                        @Ritter sagte in X-Sense Adapter:
                                        stell den adapter auf debug
                                        und poste mal
                                        du musst aber dann in die app gehen und den mqtt mal ausschalten...10 sek warten dann wieder einschalten.. erst dann werden infos gepostet..
                                        ist komisch gelöst..
                                        R 1 Antwort Letzte Antwort
                                        • arteckA arteck
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          #140
                                          @arteck ist das normal?
                                          mqtt.0
                                          2026-01-24 20:21:31.238	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000010.SBS50152966C8_00000010_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:28.971	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_0000000F.SBS50152966C8_0000000F_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:26.663	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_0000000E.SBS50152966C8_0000000E_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:24.418	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_0000000D.SBS50152966C8_0000000D_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:22.109	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_0000000C.SBS50152966C8_0000000C_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:19.807	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_0000000B.SBS50152966C8_0000000B_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:17.578	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_0000000A.SBS50152966C8_0000000A_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:15.347	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000009.SBS50152966C8_00000009_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:13.109	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000008.SBS50152966C8_00000008_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:10.868	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000007.SBS50152966C8_00000007_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:08.642	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000006.SBS50152966C8_00000006_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:06.387	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000005.SBS50152966C8_00000005_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:04.117	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000004.SBS50152966C8_00000004_battery.state...
                                          mqtt.0
                                          2026-01-24 20:21:01.888	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000003.SBS50152966C8_00000003_battery.state...
                                          mqtt.0
                                          2026-01-24 20:20:59.625	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000002.SBS50152966C8_00000002_battery.state...
                                          mqtt.0
                                          2026-01-24 20:20:57.378	warn	Client [SBS50152966C8] Topic name is too long: mqtt.0.homeassistant.binary_sensor.SBS50152966C8_00000001.SBS50152966C8_00000001_battery.state...
                                          Wie sehe ich, ob der Adapter sauber läuft? Er zeigt in der Instanz mal Hybridmodus an.
                                          Sehe ich da irgendwo im Adapter bzw. seinen Datenpunkten was mehr oder "nur" unter dem mqtt Server?
                                          Beta-Tester
