  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 77.1k Aufrufe 56 Beobachtet
    @ritter
    Un jetzt?
    iob diag
    Ritter
    #81
    @thomas-braun ```
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: NUC
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.12.41+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: Intel corporation
      Hardware Model: NUC6i3SYB
    Firmware Version: SYSKLi35.86A.0070.2019.0401.1729
       Firmware Date: Mon 2019-04-01
        Firmware Age: 6y 4month 2w 2d
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:33:31 up  2:16,  2 users,  load average: 1.39, 1.65, 1.36
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-08-16 17:33:31 CEST
               Universal time: Sat 2025-08-16 15:33:31 UTC
                     RTC time: Sat 2025-08-16 15:33:31
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    christian
    HOME=/home/christian
    GROUPS=christian adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             33G        837M         31G        4.3M        2.1G         32G
    Swap:           1.0G          0B        1.0G
    Total:           34G        837M         32G
    Active iob-Instances:   1
            31993 M total memory
              798 M used memory
              290 M active memory
             1208 M inactive memory
            29686 M free memory
              329 M buffer memory
             1641 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 17:33:31 up  2:16,  2 users,  load average: 1.28, 1.62, 1.35
    Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.9 us,  3.8 sy,  0.0 ni, 94.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  31993.3 total,  29686.8 free,    798.2 used,   1970.8 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.  31195.1 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs   16G     0   16G   0% /dev
    tmpfs          tmpfs     3.2G  808K  3.2G   1% /run
    /dev/sda1      ext4      468G   62G  382G  14% /
    tmpfs          tmpfs      16G     0   16G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs      16G  3.1M   16G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
    [Sat Aug 16 15:17:16 2025] EXT4-fs (sda1): mounted filesystem 96448ee6-f182-4f61-a44e-5eb0f63f92f9 ro with ordered data mode. Quota mode: none.
    [Sat Aug 16 15:17:17 2025] EXT4-fs (sda1): re-mounted 96448ee6-f182-4f61-a44e-5eb0f63f92f9 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.2G    /var/
    1.5G    /var/log/journal/08006622a09d4dd5b7dc7c548ff96709
    1.5G    /var/log
    566M    /var/cache
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    8.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    308M    /opt/iobroker/iobroker-data/backup-objects
    287M    /opt/iobroker/iobroker-data/files/vis
    278M    /opt/iobroker/iobroker-data/files/vis/widgets
    49M     /opt/iobroker/iobroker-data/files/0_userdata.0/cam9.mp4
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.18.0
    /usr/bin/node           v22.18.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    NUC                 NUC (version: 7.0.7, hostname: NUC           , alive, uptime: 8018)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     9.0.11
    nodejs modules from github:     8
    +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
    +-- iobroker.pirate-weather@0.1.4 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#f70e2e8f1968bfe65afabf792ca73253a19f8321)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.signifylights@1.0.0 (git+ssh://git@github.com/disaster123/ioBroker.signifylights.git#bb475662d63f1e39993c2b4e9fb395c29dcd1adc)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
    +-- iobroker.xsense@0.0.12 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#cae2e07ac3d59527f701426739ed0cf14afdd0de)
    +-- iobroker.yr@5.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.yr.git#dec7b7f69b3968a43a390e2b2a60391c2dca6b23)
    Adapter State
      system.adapter.accuweather.0            : accuweather           : NUC                                      -  enabled
      system.adapter.admin.0                  : admin                 : NUC                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : NUC                                      - disabled
      system.adapter.backitup.0               : backitup              : NUC                                      -  enabled
      system.adapter.chromecast.0             : chromecast            : NUC                                      -  enabled
      system.adapter.daswetter.0              : daswetter             : NUC                                      -  enabled
      system.adapter.device-reminder.0        : device-reminder       : NUC                                      -  enabled
      system.adapter.device-watcher.0         : device-watcher        : NUC                                      -  enabled
      system.adapter.devices.0                : devices               : NUC                                      - disabled
      system.adapter.discovery.0              : discovery             : NUC                                      -  enabled
      system.adapter.drops-weather.0          : drops-weather         : NUC                                      - disabled
      system.adapter.dwd.0                    : dwd                   : NUC                                      -  enabled
      system.adapter.echarts.0                : echarts               : NUC                                      -  enabled
      system.adapter.email.0                  : email                 : NUC                                      -  enabled
      system.adapter.email.1                  : email                 : NUC                                      -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: NUC                                      -  enabled
      system.adapter.enigma2.0                : enigma2               : NUC                                      -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUC                                      -  enabled
      system.adapter.feiertage.0              : feiertage             : NUC                                      -  enabled
      system.adapter.flot.0                   : flot                  : NUC                                      - disabled
      system.adapter.fullcalendar.0           : fullcalendar          : NUC                                      -  enabled
      system.adapter.habpanel.0               : habpanel              : NUC                                      - disabled
      system.adapter.hass.0                   : hass                  : NUC                                      -  enabled, port: 8123
      system.adapter.heizoel.0                : heizoel               : NUC                                      -  enabled
      system.adapter.history.0                : history               : NUC                                      -  enabled
      system.adapter.hm-rega.0                : hm-rega               : NUC                                      -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : NUC                                      -  enabled, port: 3000
      system.adapter.hm-rpc.1                 : hm-rpc                : NUC                                      -  enabled, port: 4000
      system.adapter.hm-rpc.2                 : hm-rpc                : NUC                                      -  enabled, port: 5000
      system.adapter.hm-rpc.3                 : hm-rpc                : NUC                                      -  enabled, port: 5500
      system.adapter.homeconnect.0            : homeconnect           : NUC                                      -  enabled
      system.adapter.ical.0                   : ical                  : NUC                                      -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUC                                      - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: NUC                                      -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUC                                      - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : NUC                                      -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : NUC                                      - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : NUC                                      - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : NUC                                      - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUC                                      - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUC                                      - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUC                                      - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : NUC                                      -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUC                                      - disabled
      system.adapter.iot.0                    : iot                   : NUC                                      -  enabled
      system.adapter.javascript.0             : javascript            : NUC                                      -  enabled
      system.adapter.klipper-moonraker.0      : klipper-moonraker     : NUC                                      - disabled
      system.adapter.linux-control.0          : linux-control         : NUC                                      -  enabled
      system.adapter.material.0               : material              : NUC                                      - disabled
      system.adapter.matter.0                 : matter                : NUC                                      -  enabled
      system.adapter.meross.0                 : meross                : NUC                                      - disabled
      system.adapter.meteoalarm.0             : meteoalarm            : NUC                                      -  enabled
      system.adapter.mobile.0                 : mobile                : NUC                                      - disabled
      system.adapter.mqtt.0                   : mqtt                  : NUC                                      -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : NUC                                      -  enabled
      system.adapter.node-red.0               : node-red              : NUC                                      - disabled, port: 1880, bind: 0.0.0.0
      system.adapter.odl.0                    : odl                   : NUC                                      -  enabled
      system.adapter.onkyo.0                  : onkyo                 : NUC                                      -  enabled
      system.adapter.onvif.0                  : onvif                 : NUC                                      -  enabled, port: 8000
      system.adapter.opendtu.0                : opendtu               : NUC                                      -  enabled
      system.adapter.openweathermap.0         : openweathermap        : NUC                                      -  enabled
      system.adapter.parser.0                 : parser                : NUC                                      -  enabled
      system.adapter.ping.0                   : ping                  : NUC                                      -  enabled
      system.adapter.pirate-weather.0         : pirate-weather        : NUC                                      - disabled
      system.adapter.places.0                 : places                : NUC                                      -  enabled
      system.adapter.pollenflug.0             : pollenflug            : NUC                                      -  enabled
      system.adapter.pushover.0               : pushover              : NUC                                      -  enabled
      system.adapter.reolink.0                : reolink               : NUC                                      -  enabled
      system.adapter.rickshaw.0               : rickshaw              : NUC                                      - disabled
      system.adapter.sainlogic.0              : sainlogic             : NUC                                      -  enabled, port: 45000, bind: 0.0.0.0
      system.adapter.samsung.0                : samsung               : NUC                                      -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : NUC                                      -  enabled, port: 8002
      system.adapter.sayit.0                  : sayit                 : NUC                                      -  enabled
      system.adapter.sayit.7                  : sayit                 : NUC                                      -  enabled
      system.adapter.scenes.0                 : scenes                : NUC                                      -  enabled
      system.adapter.scheduler.0              : scheduler             : NUC                                      -  enabled
      system.adapter.signifylights.0          : signifylights         : NUC                                      -  enabled
      system.adapter.simple-api.0             : simple-api            : NUC                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : NUC                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : NUC                                      -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.statistics.0             : statistics            : NUC                                      -  enabled
      system.adapter.synology.0               : synology              : NUC                                      -  enabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : NUC                                      -  enabled
      system.adapter.telegram.0               : telegram              : NUC                                      -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : NUC                                      -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : NUC                                      -  enabled
      system.adapter.text2command.1           : text2command          : NUC                                      -  enabled
      system.adapter.time-switch.0            : time-switch           : NUC                                      -  enabled
      system.adapter.tr-064.0                 : tr-064                : NUC                                      -  enabled
      system.adapter.trashschedule.0          : trashschedule         : NUC                                      -  enabled
      system.adapter.tuya.0                   : tuya                  : NUC                                      -  enabled
      system.adapter.vesync.0                 : vesync                : NUC                                      -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: NUC                                      -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : NUC                                      - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : NUC                                      - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: NUC                                      -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: NUC                                      - disabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: NUC                                      -  enabled
      system.adapter.vis-2.0                  : vis-2                 : NUC                                      -  enabled
      system.adapter.vis-bars.0               : vis-bars              : NUC                                      - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUC                                      - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUC                                      - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUC                                      - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUC                                      -  enabled
      system.adapter.vis-history.0            : vis-history           : NUC                                      - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUC                                      - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : NUC                                      - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : NUC                                      -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUC                                      - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : NUC                                      - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : NUC                                      - disabled
      system.adapter.vis-map.0                : vis-map               : NUC                                      - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : NUC                                      - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : NUC                                      - disabled
      system.adapter.vis-material.0           : vis-material          : NUC                                      - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : NUC                                      - disabled
      system.adapter.vis-metro.0              : vis-metro             : NUC                                      - disabled
      system.adapter.vis-players.0            : vis-players           : NUC                                      - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : NUC                                      -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : NUC                                      - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUC                                      - disabled
      system.adapter.vis-weather.0            : vis-weather           : NUC                                      - disabled
      system.adapter.vis.0                    : vis                   : NUC                                      -  enabled
      system.adapter.weather-warnings.0       : weather-warnings      : NUC                                      -  enabled
      system.adapter.web.0                    : web                   : NUC                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.windows-control.0        : windows-control       : NUC                                      -  enabled
      system.adapter.wled.0                   : wled                  : NUC                                      -  enabled
      system.adapter.xsense.0                 : xsense                : NUC                                      -  enabled
      system.adapter.yamaha.0                 : yamaha                : NUC                                      -  enabled
      system.adapter.yr.0                     : yr                    : NUC                                      -  enabled
      system.adapter.zendure-solarflow.0      : zendure-solarflow     : NUC                                      -  enabled
      system.adapter.zigbee.0                 : zigbee                : NUC                                      -  enabled, port: tcp://192.168.1.49:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name          │ url        │ auto upgrade │
    │ 0       │ 'online'      │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
    │ 1       │ 'fast-online' │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
    │ 2       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
    │ 3       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.6  , installed 2.12.6
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "drops-weather": 1.2.7    , installed 1.2.7
    Adapter    "echarts"      : 2.0.6    , installed 2.0.6
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss-erweitert": 0.7.8, installed 0.7.8
    Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
    Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 3.6.0    , installed 3.6.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "matter"       : 0.5.2    , installed 0.5.2
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "nina"         : 0.0.26   , installed 0.0.26
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "odl"          : 5.0.0    , installed 5.0.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "parser"       : 2.3.1    , installed 2.3.1
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "places"       : 1.3.0    , installed 1.3.0
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "sainlogic"    : 0.12.1   , installed 0.12.1
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "scenes"       : 4.0.3    , installed 4.0.3
    Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
    Adapter    "signifylights": 1.0.0    , installed 1.0.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "statistics"   : 4.0.0    , installed 4.0.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 4.0.1    , installed 4.0.1
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vesync"       : 0.0.9    , installed 0.0.9
    Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
    Adapter    "vis-2-widgets-inventwo": 0.3.5, installed 0.3.5
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-weather-and-heating": 1.1.1, installed 1.1.1
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zendure-solarflow": 2.0.1, installed 2.0.1
    Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
    Objects and States
    Objects:        51148
    States:         38799
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://security.debian.org/debian-security trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          854        935/exim4
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5832       766/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          855        935/exim4
    tcp6       0      0 :::8555                 :::*                    LISTEN      1000       9071       1751/go2rtc_linux_a
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       9067       1751/go2rtc_linux_a
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5834       766/sshd: /usr/sbin
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       10692      1751/go2rtc_linux_a
    udp        0      0 192.168.1.31:8555       0.0.0.0:*                           1000       9075       1751/go2rtc_linux_a
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          816        626/dhclient
    udp6       0      0 2003:c5:8f45:2500::8555 :::*                                1000       9077       1751/go2rtc_linux_a
    udp6       0      0 fd8f:79ab:5076:0:b:8555 :::*                                1000       9076       1751/go2rtc_linux_a
    2025-08-16 17:31:16.378  - warn: host.NUC instance system.adapter.statistics.0 terminated due to SIGKILL
    2025-08-16 17:31:16.378  - info: host.NUC instance system.adapter.statistics.0 terminated with code null ()
    2025-08-16 17:31:16.470  - warn: host.NUC instance system.adapter.tankerkoenig.0 terminated due to SIGKILL
    2025-08-16 17:31:16.470  - info: host.NUC instance system.adapter.tankerkoenig.0 terminated with code null ()
    2025-08-16 17:31:16.471  - warn: host.NUC instance system.adapter.text2command.1 terminated due to SIGKILL
    2025-08-16 17:31:16.471  - info: host.NUC instance system.adapter.text2command.1 terminated with code null ()
    2025-08-16 17:31:16.491  - warn: host.NUC instance system.adapter.time-switch.0 terminated due to SIGKILL
    2025-08-16 17:31:16.491  - info: host.NUC instance system.adapter.time-switch.0 terminated with code null ()
    2025-08-16 17:31:16.511  - warn: host.NUC instance system.adapter.vis-2.0 terminated due to SIGKILL
    2025-08-16 17:31:16.511  - info: host.NUC instance system.adapter.vis-2.0 terminated with code null ()
    2025-08-16 17:31:16.548  - warn: host.NUC instance system.adapter.windows-control.0 terminated due to SIGKILL
    2025-08-16 17:31:16.548  - info: host.NUC instance system.adapter.windows-control.0 terminated with code null ()
    2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated due to SIGKILL
    2025-08-16 17:31:16.588  - info: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated with code null ()
    2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.vesync.0 terminated due to SIGKILL
    2025-08-16 17:31:16.603  - info: host.NUC instance system.adapter.vesync.0 terminated with code null ()
    2025-08-16 17:31:17.187  - info: host.NUC instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
    2025-08-16 17:31:17.208  - info: host.NUC instance system.adapter.vis-inventwo.0 terminated while should be started once
    2025-08-16 17:31:17.237  - warn: host.NUC instance system.adapter.tuya.0 terminated due to SIGKILL
    2025-08-16 17:31:17.238  - info: host.NUC instance system.adapter.tuya.0 terminated with code null ()
    2025-08-16 17:31:17.258  - info: host.NUC instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.matter.0 terminated with code 0 (NO_ERROR)
    2025-08-16 17:31:17.307  - info: host.NUC All instances are stopped.
    2025-08-16 17:31:17.375  - info: host.NUC terminated
    iob diag has finished.
    christian@NUC:~$
    • R Ritter
      @thomas-braun ```
      Script v.2025-08-09
      *** BASE SYSTEM ***
               Chassis: desktop 🖥️
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      christian
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           34G        837M         32G
                798 M used memory
                290 M active memory
              29686 M free memory
                329 M buffer memory
               1641 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      2.2G    /var/
      1.5G    /var/log
      566M    /var/cache
      USB-Devices by-id:
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        51148
      States:         38799
      Pending Updates: 0
      christian@NUC:~$
      Thomas BraunT Offline
      #82
      @ritter
      Funktioniert also wieder.
      R 1 Antwort Letzte Antwort
        @ritter
        Ritter
        #83
        @thomas-braun Ja, es funktioniert jetzt. Vielen herzlichen Dank für deine Hilfe und Geduld und die super Anleitung für das upgrade.
        • CodierknechtC Offline
          Codierknecht
          #84
          Prinzipiell hat das Upgrade dank @Thomas-Braun's detaillierter Anleitung problemlos funktioniert.
          Zuerst vor dem offiziellen Release auf der Testkiste und dann - nachdem das einwandfrei geklappt hat - gestern auf dem Produktivsystem.
          Allerdings lief heute Morgen das MySQL-Backup nicht mehr durch:
          2025-08-16 02:40:25.969 - error: backitup.0 (483) [iobroker/mysql] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
          2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker/mysql] mysqldump: Got error: 2026: "TLS/SSL error: SSL is required, but the server does not support it" when trying to connect
          2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
          Der DB-Server läuft - genau wie der ioBroker - als LXC unter Proxmox. Das wurde gleichzeitig mit dem Upgrade des ioBroker auf PVE 9.0.5 gehoben.
          An den LXC's selbst wurde nix weiter geändert.
          Die Historisierung über den SQL-Adapter funktioniert ja auch weiterhin problemlos.
          @simatec Was muss ich jetzt hier unternehmen? SSL brauche ich innerhalb meines lokalen Netzes nicht. Kann man dem Backup beibringen, die Option --skip-ssl zu verwenden?
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #85
            @codierknecht
            Die Frage ist, warum MySQL bei dir überhaupt SSL verlangt.
            Normalerweise muss man das für den Server oder für den User Extra konfigurieren.
            Schau mal in der Konfiguration einmal hier.
            [mysqld]
            require_secure_transport = ON
            Oder in der Datenbank selbst
            SELECT user, host, ssl_type
            FROM mysql.user;
            Meine Adapter und Widgets
            Links im Profil
              @eduard77 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
              Ich habe jetzt festgestellt dass Ping Adapter bei mir nicht mehr funktioniert.
              Versuch mal ping neu zu installieren:
              sudo apt-get install iputils-ping --reinstall
              Eduard77E Online
              Eduard77E Online
              Eduard77
              #86
              @dr-bakterius sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
              Tut mir leid, dass ich erst jetzt antworte.
              Ich habe jetzt versucht nochmals mit deinem Code zu machen.
              Hat wieder nichts gebracht.
              edi77@DebianIO:~$ sudo apt-get install iputils-ping --reinstall
              [sudo] password for edi77:
              Reading package lists... Done
              Building dependency tree... Done
              The following packages were automatically installed and are no longer required:
                g++-12 libassuan0 libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57 libc-ares2 libcares2 libcodec2-1.0 libdav1d6 libdrm-nouveau2
                libdrm-radeon1 libepoxy0 libflac12 libgirepository-1.0-1 libglapi-mesa libjsoncpp25 libjxl0.7 libllvm15 libmbedcrypto7 libmfx1 libnl-3-200
                libnl-genl-3-200 libnsl-dev libplacebo208 libpostproc56 libpthread-stubs0-dev librav1e0 librhash0 libssh-gcrypt-4 libstdc++-12-dev libsvtav1enc1
                libswresample4 libswscale6 libtheora0 libtirpc-dev libvpx7 libx265-199 libxcb-dri2-0 node-busboy node-cjs-module-lexer node-undici node-xtend
                x11proto-core-dev
              Use 'sudo apt autoremove' to remove them.
              0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
              Need to get 51.2 kB of archives.
              After this operation, 0 B of additional disk space will be used.
              Get:1 http://deb.debian.org/debian trixie/main amd64 iputils-ping amd64 3:20240905-3 [51.2 kB]
              Fetched 51.2 kB in 0s (612 kB/s)
              (Reading database ... 48784 files and directories currently installed.)
              Preparing to unpack .../iputils-ping_3%3a20240905-3_amd64.deb ...
              Unpacking iputils-ping (3:20240905-3) over (3:20240905-3) ...
              Setting up iputils-ping (3:20240905-3) ...
              Processing triggers for man-db (2.13.1-1) ...
              edi77@DebianIO:~$
              • OliverIOO OliverIO
                @codierknecht
                [mysqld]
                FROM mysql.user;
                Codierknecht
                #87
                @oliverio sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                Falsche Richtung. Nicht der "Server" verlangt SSL, sondern das Backup und mysqldump.
                Der Server bietet gar kein SSL an - daran stört sich mysqldump und damit das Backup. Aber erst seit dem Update.
                Edit
                Die mysqldump.cnf sieht wie folgt aus:
                [mysqldump]
                quick
                quote-names
                max_allowed_packet      = 16M
                  Edit
                  [mysqldump]
                  quick
                  quote-names
                  Codierknecht
                  #88
                  @codierknecht sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                  Ich hab's hinbekommen :-D
                  Die config muss (auf der ioBroker-Seite) so aussehen:
                  [mysqldump]
                  quick
                  quote-names
                  ssl = 0
                  Siggi0904S 1 Antwort Letzte Antwort
                  • C Offline
                    cbrocker
                    #89
                    @thomas-braun sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                    Ähnliches macht man mit veralteten und lokal erzeugten Pakten nach Möglichkeit.
                    apt list '~o'
                    sudo apt purge '~o'
                    sudo apt --purge autoremove
                    sudo apt autoclean
                    Hallo, das Upgrade auf Trixie lief astrein durch.
                    Wenn ich das apt list '~o' eingebe, kommt bei mir u.a.:
                    grafana-enterprise/now 12.1.1 amd64  [Installiert,lokal]
                    Das möchte ich natürlich behalten.
                    Kann ich das aus --purge autoremove ausschließen oder
                    die o.g. Befehle einfach überspringen?
                    Ist ja nichts, was man unbedingt machen müsste?
                    Grüße
                    Christoph
                    Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
                    • C cbrocker
                      apt list '~o'
                      sudo apt purge '~o'
                      sudo apt autoclean
                      Grüße
                      Christoph
                      #90
                      @cbrocker sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                      Nein, du möchtest eher auf das Paket grafana umsteigen
                      Und du möchtest schauen, warum das als lokal installiert angezeigt wird.
                      grafana-Repository nicht aktiv?
                      C 1 Antwort Letzte Antwort
                        cbrocker
                        #91
                        Grafana aktualisiere ich immer manuell mit
                        wget https://dl.grafana.com/grafana-enterprise/release/12.1.1/grafana-enterprise_12.1.1_16903967602_linux_amd64.deb
                        sudo dpkg -i grafana-enterprise_12.1.1_16903967602_linux_amd64.deb
                        habe das nicht in der Repository.
                        Was ist der Unterschied zwischen grafana und grafana-enterprise?
                        • C cbrocker
                          #92
                          Solltest du aber machen und die Finger von manuellen Installationen lassen.
                          Das löst dir nämlich auch Abhängigkeiten auf und du wirst auch über neue Releases informiert.
                          grafana-enterprise ist das kommerzielle Angebot für Unternehmen:
                          Grafana Enterprise:
                          Commercial offering: Requires a paid license after the trial period.
                          C D 2 Antworten Letzte Antwort
                            Grafana Enterprise:
                            cbrocker
                            #93
                            klar, über Repo ist es auch bequemer.
                            Ich nutze die Enterprise schon seit 2-3 Jahren,
                            die eingeschränkte Version ist free:
                            The Enterprise Edition is the default and recommended edition. It includes all the features of the OSS Edition, can be used for free and can be upgraded to the full Enterprise feature set, including support for Enterprise plugins.
                            ok, danke für die Hinweise.
                            Werde ich in die Repo einbauen.
                              Grafana Enterprise:
                              Dieter_P
                              #94
                              Danke hat für ein debian 12.11 auf einem Firebat T8 Pro ohne jeglichen Hürden so funktioniert und läuft.
                              • MatzebhvM Offline
                                MatzebhvM Offline
                                Matzebhv
                                #95
                                Hier auch erledigt.
                                root@iOBroker:/home/iobroker# lsb_release -a
                                No LSB modules are available.
                                Distributor ID: Debian
                                Description: Debian GNU/Linux 13 (trixie)
                                Release: 13
                                Codename: trixie
                                L 1 Antwort Letzte Antwort
                                • MatzebhvM Matzebhv
                                  Hier auch erledigt.
                                  Release: 13
                                  Codename: trixie
                                  lessthanmore
                                  #96
                                  @matzebhv said in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                  root@
                                  Na lass das mal nicht @Thomas-Braun sehen :-D
                                  • L lessthanmore
                                    root@
                                    #97
                                    @lessthanmore sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                    Hab ich schon heute Vormittag gesehen...
                                    teletapiT 1 Antwort Letzte Antwort
                                      teletapiT Online
                                      teletapiT Online
                                      teletapi
                                      schrieb am zuletzt editiert von teletapi
                                      #98
                                      Ich hab das hier gepostet weil ich vermute das die Meldung jetzt kam nachdem ich das Update vor ein paar Tagen auf "Trixie" bzw das Nodejs update auf die 22.18 gemacht hatte. Falls das damit nix zu tun hat dann einfach löschen oder wenns woanders hion passen würde verschieben
                                      Gerade eben wollte ich per sudo apt update nachschauen ob es neue Updates gibt da kam folgende Meldung
                                      Was wäre denn da jetzt zu tun.
                                      pi@Raspberrypi5:~ $ sudo apt update
                                      OK:1 http://deb.debian.org/debian trixie InRelease
                                      OK:2 http://deb.debian.org/debian-security trixie-security InRelease
                                      OK:3 http://archive.raspberrypi.com/debian trixie InRelease
                                      OK:4 http://deb.debian.org/debian trixie-updates InRelease
                                      OK:5 https://repos.influxdata.com/debian stable InRelease
                                      Holen:6 https://apt.grafana.com stable InRelease [7.661 B]
                                      Fehl:6 https://apt.grafana.com stable InRelease
                                        Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on B53AE77BADB630A683046005963FA27710458545 is bad:            The primary key is not live   because: Expired on 2025-08-23T16:33:45Z
                                      OK:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                                      Alle Pakete sind aktuell.
                                      Warnung: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. OpenPGP-Signaturüberprüfung fehlgeschlagen: https://apt.grafana.com stable InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on B53AE77BADB630A683046005963FA27710458545 is bad:            The primary key is not live   because: Expired on 2025-08-23T16:33:45Z
                                      Warnung: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                      Warnung: Fehlschlag beim Holen von https://apt.grafana.com/dists/stable/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on B53AE77BADB630A683046005963FA27710458545 is bad:            The primary key is not live   because: Expired on 2025-08-23T16:33:45Z
                                      Warnung: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                      Anbei noch ein aktuelles iob diag
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                       Static hostname: Raspberrypi5
                                             Icon name: computer
                                                Kernel: Linux 6.12.34+rpt-rpi-2712
                                          Architecture: arm64
                                      OS is similar to:
                                      Model           : Raspberry Pi 5 Model B Rev 1.0
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       01:39:28 up 2 days, 12:08,  1 user,  load average: 0.33, 0.22, 0.25
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                                     Local time: Mon 2025-08-25 01:39:28 CEST
                                                 Universal time: Sun 2025-08-24 23:39:28 UTC
                                                       RTC time: Sun 2025-08-24 23:39:28
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      SUDO_HOME=/home/pi
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Mem:            8.5G        4.4G        1.0G         18M        3.3G        4.1G
                                      Swap:           209M        207M        1.9M
                                      Total:          8.7G        4.6G        1.0G
                                      Active iob-Instances:   33
                                               8063 M total memory
                                               4154 M used memory
                                               3785 M active memory
                                               2753 M inactive memory
                                                965 M free memory
                                                141 M buffer memory
                                               2999 M swap cache
                                                199 M total swap
                                                198 M used swap
                                                  1 M free swap
                                      top - 01:39:28 up 2 days, 12:08,  1 user,  load average: 0.33, 0.22, 0.25
                                      Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us,  2.4 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   8063.1 total,    962.7 free,   4155.5 used,   3142.9 buff/cache
                                      MiB Swap:    200.0 total,      1.8 free,    198.2 used.   3907.5 avail Mem
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                      tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
                                      /dev/sda2      ext4       59G   23G   33G  41% /
                                      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                      tmpfs          tmpfs     4.0G   11M  4.0G   1% /tmp
                                      /dev/sda1      vfat      510M   73M  438M  15% /boot/firmware
                                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                                      tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
                                      [Fri Aug 22 13:31:20 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                      [Fri Aug 22 13:31:25 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
                                      [Fri Aug 22 13:31:26 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
                                      /                /dev/sda2 ext4   rw,noatime
                                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      3.1G    /var/
                                      1.3G    /var/log/journal/02a43974e4004c17afbe02a71ed8236e
                                      1.3G    /var/log
                                      1.3G    /var/lib
                                      Archived and active journals take up 1.2G in the file system.
                                      3.3G    /opt/iobroker/backups/
                                      501M    /opt/iobroker/iobroker-data/
                                      160M    /opt/iobroker/iobroker-data/files
                                      109M    /opt/iobroker/iobroker-data/backup-objects
                                      72M     /opt/iobroker/iobroker-data/node-red
                                      71M     /opt/iobroker/iobroker-data/node-red/node_modules
                                      13M     /opt/iobroker/iobroker-data/states.jsonl
                                      8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
                                      8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                                      6.2M    /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.9.3
                                      /usr/bin/npx            10.9.3
                                      nodejs:
                                        Version table:
                                              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                           20.19.2+dfsg-1 500
                                              500 http://deb.debian.org/debian trixie/main arm64 Packages
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      Raspberrypi5        Raspberrypi5 (version: 7.0.7, hostname: Raspberrypi5  , alive, uptime: 216475)
                                      admin:          7.7.2
                                      javascript:     9.0.11
                                      nodejs modules from github:     5
                                      +-- iobroker.influxdb@4.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.influxdb.git#28ac2b78843928094d8a6fea3a43a45cde1cc19d)
                                      +-- iobroker.jarvis@3.2.0-rc.17 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#65370bd2ad4617722447bcff04ba4dc6429bed9b)
                                      +-- iobroker.nspanel-lovelace-ui@0.2.4 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#dcbe5f9e78b9f2b992650058cd43c45843b6ddff)
                                      +-- iobroker.pirate-weather@0.2.0 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#5afe302853331ec86024d6aa8b3f1aefd85f7c03)
                                      +-- iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#c87e9539d89bac8f4d19b266679bcb78ed554f1d)
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
                                        system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
                                      + system.adapter.alpha-ess.0              : alpha-ess             : Raspberrypi5                             -  enabled
                                      + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
                                        system.adapter.devices.0                : devices               : Raspberrypi5                             -  enabled
                                      + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
                                        system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Raspberrypi5                             - disabled
                                      + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: Raspberrypi5                             -  enabled
                                        system.adapter.energiefluss-erweitert.3 : energiefluss-erweitert: Raspberrypi5                             - disabled
                                      + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
                                      + system.adapter.homeconnect.0            : homeconnect           : Raspberrypi5                             -  enabled
                                      + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 80
                                        system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
                                        system.adapter.ical.1                   : ical                  : Raspberrypi5                             -  enabled
                                      + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
                                        system.adapter.iot.0                    : iot                   : Raspberrypi5                             - disabled
                                      + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
                                      + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
                                      + system.adapter.matter.0                 : matter                : Raspberrypi5                             -  enabled
                                      + system.adapter.modbus.0                 : modbus                : Raspberrypi5                             -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
                                      + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : Raspberrypi5                             -  enabled
                                      + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
                                        system.adapter.openweathermap.0         : openweathermap        : Raspberrypi5                             -  enabled
                                      + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
                                      + system.adapter.pirate-weather.0         : pirate-weather        : Raspberrypi5                             -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
                                      + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                                      + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
                                      + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                      Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
                                      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                                      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                                      Adapter    "hue"          : 3.16.2   , installed 3.16.2
                                      Adapter    "influxdb"     : 4.0.2    , installed 4.0.3
                                      Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.17
                                      Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                                      Adapter    "net-tools"    : 1.2.0    , installed 1.2.0
                                      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                                      Objects and States
                                      Objects:        14508
                                      States:         14163
                                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://apt.grafana.com stable InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on B53AE77BADB630A683046005963FA27710458545 is bad:            The primary key is not live   because: Expired on 2025-08-23T16:33:45Z
                                      W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on B53AE77BADB630A683046005963FA27710458545 is bad:            The primary key is not live   because: Expired on 2025-08-23T16:33:45Z
                                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                                      Hit:1 http://deb.debian.org/debian trixie InRelease
                                      Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
                                      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                                      Get:5 https://apt.grafana.com stable InRelease [7661 B]
                                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                                      Err:5 https://apt.grafana.com stable InRelease
                                      Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                                      Pending Updates: 0
                                      tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       10438      1488/io.hm-rpc.0
                                      tcp        0      0 192.168.178.82:18702    0.0.0.0:*               LISTEN      1001       12321      1505/io.hm-rpc.1
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        7481       861/mosquitto
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       226331     16034/io.sonoff.0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8253       834/sshd: /usr/sbin
                                      tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       15114      2308/io.simple-api.
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7690       1187/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7697       1187/iobroker.js-co
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7638       1145/exim4
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7639       1145/exim4
                                      tcp6       0      0 :::1883                 :::*                    LISTEN      106        7482       861/mosquitto
                                      tcp6       0      0 :::8400                 :::*                    LISTEN      1001       3524004    268297/io.jarvis.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          8255       834/sshd: /usr/sbin
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10004      1229/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16426      2401/io.web.0
                                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       15866      2367/io.socketio.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        8478       853/influxd
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      107        9965       1186/grafana
                                      udp        0      0 0.0.0.0:48124           0.0.0.0:*                           1001       15796      2192/io.matter.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14081      2192/io.matter.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14073      2192/io.matter.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1797       648/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1001       14090      2192/io.matter.0
                                      udp        0      0 0.0.0.0:58952           0.0.0.0:*                           104        1799       648/avahi-daemon: r
                                      udp6       0      0 :::48124                :::*                                1001       15795      2192/io.matter.0
                                      udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          9894       735/NetworkManager
                                      udp6       0      0 fe80::38be:beb2:fe6:546 :::*                                0          8329       735/NetworkManager
                                      udp6       0      0 :::5353                 :::*                                1001       14084      2192/io.matter.0
                                      udp6       0      0 :::5353                 :::*                                1001       14076      2192/io.matter.0
                                      udp6       0      0 :::5353                 :::*                                104        1798       648/avahi-daemon: r
                                      udp6       0      0 :::5541                 :::*                                1001       14089      2192/io.matter.0
                                      udp6       0      0 :::34804                :::*                                104        1800       648/avahi-daemon: r
                                      2025-08-25 01:39:40.006  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                                      2025-08-25 01:39:40.009  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                                      2025-08-25 01:39:40.014  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-186.cmnd.DisplayText[Displays/Tasmota-ssd1309-186/cmnd/DisplayText]
                                      2025-08-25 01:39:40.016  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-4x20-59.cmnd.DisplayText[Displays/Tasmota-4x20-59/cmnd/DisplayText]
                                      2025-08-25 01:39:45.004  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                                      2025-08-25 01:39:45.009  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                                      2025-08-25 01:39:50.003  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                                      2025-08-25 01:39:50.006  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                                      2025-08-25 01:39:50.058  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-4x20-59.cmnd.DisplayText[Displays/Tasmota-4x20-59/cmnd/DisplayText]
                                      2025-08-25 01:39:50.100  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-186.cmnd.DisplayText[Displays/Tasmota-ssd1309-186/cmnd/DisplayText]
                                      2025-08-25 01:39:53.009  - info: mqtt.0 (1612) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                                      2025-08-25 01:39:53.052  - info: mqtt.0 (1612) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                                      2025-08-25 01:39:53.053  - info: mqtt.0 (1612) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                                      2025-08-25 01:39:55.003  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                                      2025-08-25 01:39:55.047  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                                      2025-08-25 01:40:00.004  - info: mqtt.0 (1612) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                                      2025-08-25 01:40:00.010  - info: mqtt.0 (1612) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                                      2025-08-25 01:40:00.019  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                                      2025-08-25 01:40:00.026  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                                      2025-08-25 01:40:00.031  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-186.cmnd.DisplayText[Displays/Tasmota-ssd1309-186/cmnd/DisplayText]
                                      2025-08-25 01:40:00.035  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-4x20-59.cmnd.DisplayText[Displays/Tasmota-4x20-59/cmnd/DisplayText]
                                      2025-08-25 01:40:05.005  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                                      2025-08-25 01:40:05.010  - info: mqtt.0 (1612) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                                      Ich hab jetzt mal Chat GPT gefragt und hier wurde mir folgendes angeboten was ich auch durchgeführt habe. ich hatte mir im Vorfeld eine Sicherungskopie meiner Festplatte gemacht so das ich jederzeit auf das vorran gegangene System wieder zurück kann wenn was schief läuft. Scheint aber zu funktionieren. Fehler ist zumindest weg.
                                      1. Alte Datei/Keyreferenzen löschen
                                      Falls du noch eine alte Repository-Datei hast, die auf den abgelaufenen Key verweist, am besten löschen:
                                      sudo rm /etc/apt/sources.list.d/grafana.list
                                      2. Neuen Key herunterladen und sicher ablegen
                                      sudo mkdir -p /usr/share/keyrings
                                      sudo wget -q -O /usr/share/keyrings/grafana.gpg https://apt.grafana.com/gpg.key
                                      3. Repository mit neuem Key einrichten
                                      echo "deb [signed-by=/usr/share/keyrings/grafana.gpg] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                                      4. Update durchführen
                                      sudo apt update
                                      Ich hoffe das das so in Ordnung ist.
                                      Nach einem weiteren iob diag hatte ich wieder eine Meldung
                                      Die aber dann durch einen iob fix und einen reboot wieder verschwunden ist.
                                      • teletapiT teletapi
                                        ```bash
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                        Current issues:
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        iobroker
                                        HOME=/home/iobroker
                                        SUDO_HOME=/home/pi
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                                 8063 M total memory
                                                 4154 M used memory
                                                  965 M free memory
                                                  141 M buffer memory
                                                 2999 M swap cache
                                                  199 M total swap
                                                  198 M used swap
                                                    1 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        3.1G    /var/
                                        1.3G    /var/log
                                        1.3G    /var/lib
                                        USB-Devices by-id:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.9.3
                                        /usr/bin/npx            10.9.3
                                        nodejs:
                                          Version table:
                                             20.19.2+dfsg-1 500
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.7.2
                                        javascript:     9.0.11
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        14508
                                        States:         14163
                                        Pending Updates: 0
                                        sudo apt update
                                        #99
                                        @teletapi sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                        Der Schlüssel muss erneuert werden, deiner ist am 23. August abgelaufen. Ich mache das immer danach:
                                        https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                        Hier werden andere Verzeichnisse als bei SchrottJiPiehTieh verwendet. Kann man sich drüber streiten, was richtiger/besser ist, die aktuelle Vorgabe seitens Debian ist aber /etc/apt/keyrings/
                                          teletapiT Online
                                          teletapiT Online
                                          teletapi
                                          #100
                                          @thomas-braun kann ich das so lassen oder sollte ich das ändern damit das für die Zukunft evtl. besser ist.?
