  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 77.1k Aufrufe 56 Beobachtet
  • Eduard77E Eduard77
    Vielen Dank für tolle Beschreibung.
    Ich habe jetzt mein System aktualisiert.
    iob diag sieht so aus:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: DebianIO
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.8-2-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     16:40:11 up 10 min,  0 users,  load average: 0.87, 0.91, 1.05
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-08-15 16:40:12 CEST
               Universal time: Fri 2025-08-15 14:40:12 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    edi77
    HOME=/home/edi77
    GROUPS=edi77 sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/edi77
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.6G        2.1G        5.5G        118K        907M        6.5G
    Swap:           1.1G          0B        1.1G
    Total:          9.7G        2.1G        6.6G
    Active iob-Instances:   33
             8192 M total memory
             2035 M used memory
             2089 M active memory
              640 M inactive memory
             5290 M free memory
                0 M buffer memory
              865 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    top - 16:40:12 up 10 min,  0 users,  load average: 0.87, 0.91, 1.05
    Tasks:  58 total,   1 running,  57 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   5289.1 free,   2037.2 used,    865.6 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   6154.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--104--disk--0 ext4       40G   19G   19G  51% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.6G     0  7.6G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /tmp
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--104--disk--0 ext4   rw,relatime,stripe=16
    /var:
    950M    /var/
    495M    /var/log
    494M    /var/log/journal/07999bdde13e4bb78b0c943aad8ee95b
    292M    /var/cache
    Archived and active journals take up 97.1M in the file system.
    /opt/iobroker/backups:
    3.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    6.9G    /opt/iobroker/iobroker-data/
    5.9G    /opt/iobroker/iobroker-data/history
    860M    /opt/iobroker/iobroker-data/files
    228M    /opt/iobroker/iobroker-data/files/vis-2
    129M    /opt/iobroker/iobroker-data/files/vis
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.4
    /usr/bin/node           v20.19.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.4-1nodesource1
      Candidate: 20.19.4-1nodesource1
      Version table:
     *** 20.19.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.19.3-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    DebianIO            DebianIO (version: 7.0.6, hostname: DebianIO      , alive, uptime: 620)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     1
    +-- iobroker.zigbee@3.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#ae472aefab7fbb3c70b56d3c477662e265e52f03)
    Adapter State
    + system.adapter.admin.0                  : admin                 : DebianIO                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : DebianIO                                 -  enabled
    + system.adapter.backitup.1               : backitup              : DebianIO                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : DebianIO                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : DebianIO                                 -  enabled
      system.adapter.devices.0                : devices               : DebianIO                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : DebianIO                                 -  enabled, port: 8899
      system.adapter.discovery.0              : discovery             : DebianIO                                 - disabled
    + system.adapter.echarts.0                : echarts               : DebianIO                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : DebianIO                                 -  enabled
    + system.adapter.history.0                : history               : DebianIO                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : DebianIO                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : DebianIO                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : DebianIO                                 - disabled
    + system.adapter.iot.0                    : iot                   : DebianIO                                 -  enabled
    + system.adapter.javascript.0             : javascript            : DebianIO                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : DebianIO                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : DebianIO                                 -  enabled, port: 54321
    + system.adapter.onvif.0                  : onvif                 : DebianIO                                 -  enabled, port: 8000
    + system.adapter.ping.0                   : ping                  : DebianIO                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : DebianIO                                 -  enabled, port: 8006
    + system.adapter.reolink.0                : reolink               : DebianIO                                 -  enabled
      system.adapter.scenes.0                 : scenes                : DebianIO                                 - disabled
    + system.adapter.shelly.0                 : shelly                : DebianIO                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : DebianIO                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : DebianIO                                 -  enabled
      system.adapter.socketio.0               : socketio              : DebianIO                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : DebianIO                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : DebianIO                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : DebianIO                                 -  enabled
    + system.adapter.telegram.0               : telegram              : DebianIO                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : DebianIO                                 - disabled
    + system.adapter.tr-064.0                 : tr-064                : DebianIO                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : DebianIO                                 -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: DebianIO                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : DebianIO                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : DebianIO                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: DebianIO                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: DebianIO                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : DebianIO                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : DebianIO                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : DebianIO                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : DebianIO                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : DebianIO                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : DebianIO                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : DebianIO                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : DebianIO                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : DebianIO                                 - disabled
      system.adapter.vis.0                    : vis                   : DebianIO                                 -  enabled
    + system.adapter.web.0                    : web                   : DebianIO                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : DebianIO                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : DebianIO                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : DebianIO                                 -  enabled, port: tcp://192.168.178.12:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 2.0.5    , installed 3.0.1
    Objects and States
    Objects:        10632
    States:         9133
    W: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3843699    174/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3844511    174/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          3844328    323/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3838891    1/init
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       3845540    565/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3845693    610/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3840845    1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3838893    1/init
    tcp6       0      0 :::8095                 :::*                    LISTEN      1001       3854689    898/io.onvif.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       3848811    736/io.simple-api.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       3849058    787/io.ws.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       3849216    832/io.web.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3845929    691/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3844625    336/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          3844329    323/master
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       3848400    625/io.mihome-vacuu
    udp        0      0 0.0.0.0:37750           0.0.0.0:*                           1001       3845073    550/io.snmp.0
    udp        0      0 192.168.178.5:5353      0.0.0.0:*                           1001       3845643    595/io.tr-064.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3845595    580/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3845596    580/io.tuya.0
    udp        0      0 0.0.0.0:7885            0.0.0.0:*                           1001       3845381    520/io.mihome-vacuu
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3838892    1/init
    udp6       0      0 :::111                  :::*                                0          3838894    1/init
    <soap:Envelope   >
            <soap:Header>
                    <wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action>
                    <wsa:MessageID>urn:uuid:e1da5585-4fa1-4a38-91e6-f77b38e0d9bd</wsa:MessageID>
                    <wsa:RelatesTo>urn:uuid:ef96d4fd-5ccf-0624-fd92-b1d24ad84bb4</wsa:RelatesTo>
                    <wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To>
                    <wsd:AppSequence InstanceId="2614047292" MessageNumber="1"/>
            </soap:Header>
            <soap:Body>
                    <wsd:ProbeMatches/>
            </soap:Body>
    </soap:Envelope>
    2025-08-15 16:32:11.175  - error: onvif.0 (898) undefined
    2025-08-15 16:32:15.851  - error: onvif.0 (898) Error during discovery: TypeError: Cannot read properties of undefined (reading 'endpointReference'),TypeError: Cannot read properties of undefined (reading 'endpointReference')
    2025-08-15 16:32:15.851  - info: onvif.0 (898) Finished onvif discovery
    2025-08-15 16:32:15.852  - info: onvif.0 (898) Starting snapshot server
    2025-08-15 16:32:32.676  - info: tuya.0 (580) bf8736ec46b647a352ueah: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.174:6668
    2025-08-15 16:32:34.721  - info: sonoff.0 (565) Client [Stromzaehler] connected with secret 1755268354720_9744
    2025-08-15 16:32:34.881  - info: sonoff.0 (565) Client [Nous-3] connected with secret 1755268354880_1452
    2025-08-15 16:32:35.239  - info: sonoff.0 (565) Client [Nous-2] connected with secret 1755268355239_5967
    2025-08-15 16:32:35.374  - info: sonoff.0 (565) Client [Nous-1_Gefrierschrank] connected with secret 1755268355373_6833
    2025-08-15 16:32:59.748  - info: tuya.0 (580) bf4401a6fe27d67a7e1uuq: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.163:6668
    2025-08-15 16:33:01.924  - info: tuya.0 (580) bfb7a39438c5cbac04novg: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.161:6668
    2025-08-15 16:33:03.012  - info: tuya.0 (580) bf302f3b8d8e768522cdj2: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.167:6668
    iob diag has finished.
    Da wird ein Fehler angezeigt und ich habe keine Ahnung was ich da machen soll.
    danke nochmal für die Hilfe
    #41
    @eduard77 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
    Da darf der user nicht die Kernelringpuffer-Meldungen des Hosts sehen. Ist bei LXCs erstmal halt so.
    Eduard77E 1 Antwort Letzte Antwort
      Eduard77E Online
      Eduard77E Online
      Eduard77
      #42
      Okay alles klar. Danke.
        #43
        @eduard77
        Die anderen Dinge (adm-Gruppe, graphical target, nodejs usw) kannst du aber angehen.
          @eduard77
          Eduard77E Online
          Eduard77E Online
          Eduard77
          #44
          das Nodejs update möchte ich noch wegen Echarts Adapter nicht machen.
          Bei Graphical Target habe ich aus deinem Werkzeugkasten folgendes ausgeführt.
          edi77@DebianIO:~$ systemctl get-default
          multi-user.target
          edi77@DebianIO:~$ sudo systemctl set-default multi-user.target
          edi77@DebianIO:~$
          iob diag liefert jetzt das hier:
          Display-Manager:
          Desktop:
          Session:                tty
          Was soll ich machen?
            multi-user.target
            edi77@DebianIO:~$
            Display-Manager:
            Desktop:
            Session:                tty
            CodierknechtC Offline
            Codierknecht
            #45
            Nix! Ist doch alles tacko.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • CodierknechtC Codierknecht
              Eduard77E Online
              Eduard77E Online
              Eduard77
              #46
              @codierknecht
              Ich habe jetzt festgestellt dass Ping Adapter bei mir nicht mehr funktioniert.
              Deinstallation und neu Installation hat nichts gebracht.
              Hat jemand das auch?
              Mein Debug Log.
              ping.0 2025-08-15 20:44:34.149	debug	Ping result for 192.168.178.15: false in -ms (Tried 0/1 times)
              ping.0 2025-08-15 20:44:34.147	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:34.144	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.15
              ping.0 2025-08-15 20:44:34.144	debug	Pinging offline 192.168.178.15
              ping.0 2025-08-15 20:44:34.093	debug	Ping result for 192.168.178.14: false in -ms (Tried 1/1 times)
              ping.0 2025-08-15 20:44:34.092	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:34.088	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.14
              ping.0 2025-08-15 20:44:34.087	debug	Ping result for 192.168.178.14: false in -ms (Tried 0/1 times)
              ping.0 2025-08-15 20:44:34.086	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:34.081	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.14
              ping.0 2025-08-15 20:44:34.081	debug	Pinging offline 192.168.178.14
              ping.0 2025-08-15 20:44:34.028	debug	Ping result for 192.168.178.24: false in -ms (Tried 1/1 times)
              ping.0 2025-08-15 20:44:34.027	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:34.024	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.24
              ping.0 2025-08-15 20:44:34.023	debug	Ping result for 192.168.178.24: false in -ms (Tried 0/1 times)
              ping.0 2025-08-15 20:44:34.021	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:34.018	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.24
              ping.0 2025-08-15 20:44:34.017	debug	Pinging offline 192.168.178.24
              ping.0 2025-08-15 20:44:03.965	debug	Ping result for 192.168.178.15: false in -ms (Tried 1/1 times)
              ping.0 2025-08-15 20:44:03.964	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:03.961	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.15
              ping.0 2025-08-15 20:44:03.960	debug	Ping result for 192.168.178.15: false in -ms (Tried 0/1 times)
              ping.0 2025-08-15 20:44:03.959	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:03.955	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.15
              ping.0 2025-08-15 20:44:03.954	debug	Pinging offline 192.168.178.15
              ping.0 2025-08-15 20:44:03.903	debug	Ping result for 192.168.178.14: false in -ms (Tried 1/1 times)
              ping.0 2025-08-15 20:44:03.902	debug	STDERR: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:03.901	debug	STDERR: /bin/ping:
              ping.0 2025-08-15 20:44:03.896	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.14
              ping.0 2025-08-15 20:44:03.895	debug	Ping result for 192.168.178.14: false in -ms (Tried 0/1 times)
              ping.0 2025-08-15 20:44:03.894	debug	STDERR: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:03.893	debug	STDERR: /bin/ping:
              ping.0 2025-08-15 20:44:03.888	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.14
              ping.0 2025-08-15 20:44:03.887	debug	Pinging offline 192.168.178.14
              ping.0 2025-08-15 20:44:03.830	debug	Ping result for 192.168.178.24: false in -ms (Tried 1/1 times)
              ping.0 2025-08-15 20:44:03.829	debug	STDERR: /bin/ping: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:03.822	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.24
              ping.0 2025-08-15 20:44:03.822	debug	Ping result for 192.168.178.24: false in -ms (Tried 0/1 times)
              ping.0 2025-08-15 20:44:03.820	debug	STDERR: socktype: SOCK_RAW/bin/ping: socket: Operation not permitted/bin/ping: => missing cap_net_raw+p capability or setuid?
              ping.0 2025-08-15 20:44:03.819	debug	STDERR: /bin/ping:
              ping.0 2025-08-15 20:44:03.813	debug	System command: /bin/ping -n -w 2 -c 1 192.168.178.24
              ping.0 2025-08-15 20:44:03.812	debug	Pinging offline 192.168.178.24
              ping.0 2025-08-15 20:44:03.811	debug	Start tasks of objects update
              ping.0 2025-08-15 20:44:03.809	debug	Prepare tasks of objects update
              ping.0 2025-08-15 20:44:03.687	debug	Get existing objects
              ping.0 2025-08-15 20:44:03.686	debug	Host=DebianIO
              ping.0 2025-08-15 20:44:03.685	debug	Prepare objects
              ping.0 2025-08-15 20:44:03.669	info	starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v20.19.4, js-controller: 7.0.6
              ping.0 2025-08-15 20:44:03.220	debug	Plugin sentry Initialize Plugin (enabled=true)
              ping.0 2025-08-15 20:44:03.161	debug	States connected to redis: 127.0.0.1:9000
              ping.0 2025-08-15 20:44:03.099	debug	States create User PubSub Client
              ping.0 2025-08-15 20:44:03.098	debug	States create System PubSub Client
              Kann es was mit admin rechten liegen?
              Thomas BraunT teletapiT Dr. BakteriusD 3 Antworten Letzte Antwort
                @codierknecht
                Mein Debug Log.
                #47
                @eduard77
                An der Stelle wurde etwas umgestellt, die Rechte an ping werden mit Debian 13 anders vergeben.
                Steht aber in der Readme drin. Hab ich glaube ich oben verlinkt.
                Edith: Kann auch sein, dass da beim Adapter etwas angepasst werden muss. Mach am besten ein Issue dort auf.
                  @eduard77
                  Eduard77E Online
                  Eduard77E Online
                  Eduard77
                  #48
                  Hab ich gemacht, aber ich bin mir nicht sicher ob alles richtig gemacht. Ist meine erste Issue gewesen.
                  https://github.com/ioBroker/ioBroker.ping/issues/240
                    @codierknecht
                    Mein Debug Log.
                    teletapiT Online
                    teletapiT Online
                    teletapi
                    schrieb am zuletzt editiert von teletapi
                    #49
                    @eduard77 also ich hab die tage auch auf Trixie umgestellt und ebenfalls das Nodejs update gemacht und der Ping Adapter funktioniert
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                     Static hostname: Raspberrypi5
                           Icon name: computer
                              Kernel: Linux 6.12.34+rpt-rpi-2712
                        Architecture: arm64
                    OS is similar to:
                    Model           : Raspberry Pi 5 Model B Rev 1.0
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                     21:52:35 up 3 days,  7:32,  1 user,  load average: 0.32, 0.47, 0.44
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                                   Local time: Fri 2025-08-15 21:52:35 CEST
                               Universal time: Fri 2025-08-15 19:52:35 UTC
                                     RTC time: Fri 2025-08-15 19:52:35
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    SUDO_HOME=/home/pi
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:            8.5G        4.7G        1.5G         25M        2.4G        3.7G
                    Swap:           209M        201M        7.8M
                    Total:          8.7G        4.9G        1.5G
                             8063 M total memory
                             4515 M used memory
                             4012 M active memory
                             2075 M inactive memory
                             1397 M free memory
                              124 M buffer memory
                             2136 M swap cache
                              199 M total swap
                              192 M used swap
                                7 M free swap
                    top - 21:52:35 up 3 days,  7:32,  1 user,  load average: 0.38, 0.48, 0.45
                    Tasks: 242 total,   1 running, 241 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 50.0 us,  4.3 sy,  0.0 ni, 45.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   8063.1 total,   1406.3 free,   4506.7 used,   2261.5 buff/cache
                    MiB Swap:    200.0 total,      7.5 free,    192.5 used.   3556.4 avail Mem
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    udev           devtmpfs  3.9G     0  3.9G   0% /dev
                    tmpfs          tmpfs     1.6G   24M  1.6G   2% /run
                    /dev/sda2      ext4       59G   20G   36G  37% /
                    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                    tmpfs          tmpfs     4.0G   11M  4.0G   1% /tmp
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                    /dev/sda1      vfat      510M   73M  438M  15% /boot/firmware
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                    tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
                    [Tue Aug 12 14:20:16 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                    [Tue Aug 12 14:20:21 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
                    [Tue Aug 12 14:20:22 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
                    /                /dev/sda2 ext4   rw,noatime
                    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    3.1G    /var/
                    1.4G    /var/lib
                    1.3G    /var/log/journal/02a43974e4004c17afbe02a71ed8236e
                    1.3G    /var/log
                    Archived and active journals take up 1.2G in the file system.
                    1.9G    /opt/iobroker/backups/
                    529M    /opt/iobroker/iobroker-data/
                    160M    /opt/iobroker/iobroker-data/files
                    122M    /opt/iobroker/iobroker-data/backup-objects
                    72M     /opt/iobroker/iobroker-data/node-red
                    71M     /opt/iobroker/iobroker-data/node-red/node_modules
                    42M     /opt/iobroker/iobroker-data/objects.jsonl
                    26M     /opt/iobroker/iobroker-data/states.jsonl
                    8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
                    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                    6.2M    /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/nodejs         v22.18.0
                    /usr/bin/node           v22.18.0
                    /usr/bin/npm            10.9.3
                    /usr/bin/npx            10.9.3
                    /usr/bin/corepack       0.33.0
                    nodejs:
                      Installed: 22.18.0-1nodesource1
                      Candidate: 22.18.0-1nodesource1
                      Version table:
                     *** 22.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         20.19.2+dfsg-1 500
                            500 http://deb.debian.org/debian trixie/main arm64 Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    Raspberrypi5        Raspberrypi5 (version: 7.0.7, hostname: Raspberrypi5  , alive, uptime: 286333)
                    js-controller:  7.0.7
                    admin:          7.7.2
                    javascript:     9.0.11
                    nodejs modules from github:     4
                    +-- iobroker.influxdb@4.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.influxdb.git#234de8d73a8e1b48aabce21d9133eb8a13af2956)
                    +-- iobroker.jarvis@3.2.0-rc.17 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#65370bd2ad4617722447bcff04ba4dc6429bed9b)
                    +-- iobroker.nspanel-lovelace-ui@0.2.4 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#0a997895460f24da9797ea6d3a74bfdeba28f75a)
                    +-- iobroker.syrconnectapp@1.0.3 (git+ssh://git@github.com/TA2k/ioBroker.syrconnectapp.git#188d6182f6a83ba14edf51d368e01b44b94dc0c2)
                    Adapter State
                      system.adapter.accuweather.0            : accuweather           : Raspberrypi5                             - disabled
                    + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
                    + system.adapter.alpha-ess.0              : alpha-ess             : Raspberrypi5                             -  enabled
                    + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
                    + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
                      system.adapter.devices.0                : devices               : Raspberrypi5                             -  enabled
                    + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
                      system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Raspberrypi5                             - disabled
                    + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: Raspberrypi5                             -  enabled
                      system.adapter.energiefluss-erweitert.3 : energiefluss-erweitert: Raspberrypi5                             - disabled
                    + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
                    + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
                      system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             - disabled, port: 12001
                    + system.adapter.homeconnect.0            : homeconnect           : Raspberrypi5                             -  enabled
                    + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 80
                      system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
                      system.adapter.ical.1                   : ical                  : Raspberrypi5                             -  enabled
                    + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : Raspberrypi5                             -  enabled
                    + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
                    + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
                    + system.adapter.matter.0                 : matter                : Raspberrypi5                             -  enabled
                    + system.adapter.modbus.0                 : modbus                : Raspberrypi5                             -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
                    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : Raspberrypi5                             -  enabled
                    + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : Raspberrypi5                             -  enabled
                    + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
                    + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
                    + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                    + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
                      system.adapter.syrconnectapp.0          : syrconnectapp         : Raspberrypi5                             - disabled
                    + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
                    + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    Active repo(s): beta
                    Used repository: beta
                    Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                    Adapter    "admin"        : 7.7.2    , installed 7.7.2
                    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                    Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
                    Adapter    "devices"      : 1.2.8    , installed 1.2.8
                    Adapter    "energiefluss-erweitert": 0.7.8, installed 0.7.8
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                    Adapter    "hue"          : 3.16.2   , installed 3.16.2
                    Adapter    "ical"         : 1.16.2   , installed 1.16.2
                    Adapter    "influxdb"     : 4.0.2    , installed 4.0.3
                    Adapter    "iot"          : 3.6.0    , installed 3.6.0
                    Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.17
                    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "matter"       : 0.5.2    , installed 0.5.2
                    Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                    Adapter    "net-tools"    : 1.2.0    , installed 1.2.0
                    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                    Adapter    "ping"         : 1.7.9    , installed 1.7.9
                    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "web"          : 7.0.9    , installed 7.0.9
                    Adapter    "ws"           : 3.0.19   , installed 3.0.19
                    Objects and States
                    Objects:        14957
                    States:         14940
                    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
                    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                    Hit:4 https://apt.grafana.com stable InRelease
                    Hit:5 http://deb.debian.org/debian trixie-updates InRelease
                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9586       1197/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9591       1197/iobroker.js-co
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          9496       1161/exim4
                    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       9140       1474/io.hm-rpc.0
                    tcp        0      0 192.168.178.82:18702    0.0.0.0:*               LISTEN      1001       12692      1766/io.hm-rpc.1
                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       11866      1705/io.sonoff.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        5821       882/mosquitto
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8475       847/sshd: /usr/sbin
                    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       14378      1939/io.simple-api.
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7926       878/influxd
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       11068      1958/io.socketio.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13092      1994/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7992       1242/io.admin.0
                    tcp6       0      0 :::3000                 :::*                    LISTEN      107        3469336    236768/grafana
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          9497       1161/exim4
                    tcp6       0      0 :::1883                 :::*                    LISTEN      106        5822       882/mosquitto
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          8477       847/sshd: /usr/sbin
                    tcp6       0      0 :::8400                 :::*                    LISTEN      1001       12278      1917/io.jarvis.0
                    udp        0      0 0.0.0.0:41857           0.0.0.0:*                           104        7557       662/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       7633901    2095/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       7633885    2095/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13930      2095/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13922      2095/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7555       662/avahi-daemon: r
                    udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1001       13939      2095/io.matter.0
                    udp        0      0 0.0.0.0:51454           0.0.0.0:*                           1001       15376      2095/io.matter.0
                    udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          7907       743/NetworkManager
                    udp6       0      0 fe80::38be:beb2:fe6:546 :::*                                0          6783       743/NetworkManager
                    udp6       0      0 :::5353                 :::*                                1001       7633902    2095/io.matter.0
                    udp6       0      0 :::5353                 :::*                                1001       7633886    2095/io.matter.0
                    udp6       0      0 :::5353                 :::*                                1001       13933      2095/io.matter.0
                    udp6       0      0 :::5353                 :::*                                1001       13925      2095/io.matter.0
                    udp6       0      0 :::5353                 :::*                                104        7556       662/avahi-daemon: r
                    udp6       0      0 :::5541                 :::*                                1001       13938      2095/io.matter.0
                    udp6       0      0 :::46829                :::*                                104        7558       662/avahi-daemon: r
                    udp6       0      0 :::51454                :::*                                1001       15375      2095/io.matter.0
                    2025-08-15 21:52:55.037  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                    2025-08-15 21:52:57.005  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:52:57.047  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:52:57.048  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:53:00.010  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:00.011  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:00.014  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:00.018  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:00.018  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:53:00.019  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:53:00.020  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:53:00.022  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_9BE738.cmnd.CustomSend[SmartHome/NSPanel_9BE738/cmnd/CustomSend]
                    2025-08-15 21:53:00.037  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                    2025-08-15 21:53:00.040  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                    2025-08-15 21:53:00.049  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-4x20-59.cmnd.DisplayText[Displays/Tasmota-4x20-59/cmnd/DisplayText]
                    2025-08-15 21:53:00.052  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssd1309-186.cmnd.DisplayText[Displays/Tasmota-ssd1309-186/cmnd/DisplayText]
                    2025-08-15 21:53:00.103  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:00.105  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:00.107  - info: mqtt.0 (73128) send2Server mqtt.0.SmartHome.NSPanel_C60BC4.cmnd.CustomSend[SmartHome/NSPanel_C60BC4/cmnd/CustomSend]
                    2025-08-15 21:53:05.005  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                    2025-08-15 21:53:05.010  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                    2025-08-15 21:53:10.013  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssh1106-21.cmnd.DisplayText[Displays/Tasmota-ssh1106-21/cmnd/DisplayText]
                    2025-08-15 21:53:10.016  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssd1309-176.cmnd.DisplayText[Displays/Tasmota-ssd1309-176/cmnd/DisplayText]
                    2025-08-15 21:53:10.058  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-ssd1309-186.cmnd.DisplayText[Displays/Tasmota-ssd1309-186/cmnd/DisplayText]
                    2025-08-15 21:53:10.062  - info: mqtt.0 (73128) send2Server mqtt.0.Displays.Tasmota-4x20-59.cmnd.DisplayText[Displays/Tasmota-4x20-59/cmnd/DisplayText]
                    • teletapiT teletapi
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/pi
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                               8063 M total memory
                               4515 M used memory
                               1397 M free memory
                                124 M buffer memory
                               2136 M swap cache
                                199 M total swap
                                192 M used swap
                                  7 M free swap
                      *** FILESYSTEM ***
                      /var:
                      3.1G    /var/
                      1.4G    /var/lib
                      1.3G    /var/log
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.3
                      /usr/bin/npx            10.9.3
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.2
                      javascript:     9.0.11
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        14957
                      States:         14940
                      Pending Updates: 0
                      #50
                      @teletapi sagte: auf Trixie umgestellt und ebenfalls das Nodejs update gemacht und der Ping Adapter funktioniert
                      Bei mir auch.
                        Bei mir auch.
                        Eduard77E Online
                        Eduard77E Online
                        Eduard77
                        #51
                        @paul53 @teletapi
                        Wahrscheinlich der Unterschied ist, das bei mir IoBroker in einem LXC Container unter Proxmox 9 (Trixie) läuft.
                          @codierknecht
                          Mein Debug Log.
                          Dr. BakteriusD Offline
                          Dr. Bakterius
                          #52
                          Versuch mal ping neu zu installieren:
                          sudo apt-get install iputils-ping --reinstall
                            Ritter
                            #53
                            dank der sehr guten Anleitung bin ich jetzt auch auf Version 13 hoffe ich. Ein Problem hab ich noch, iob diag geht nicht, war aber vor dem uprade schon.
                            christian@NUC:~$ cat /etc/debian_version
                            13.0
                            christian@NUC:~$ iob diag
                            /usr/bin/iob: Zeile 21: /home/iobroker/iob_diag.log: Keine Berechtigung
                            christian@NUC:~$
                            • Thomas BraunT Online
                              #54
                              @ritter sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                              Keine Berechtigung
                              ls -l /home/iobroker/
                              sagt?
                              R 1 Antwort Letzte Antwort
                                Keine Berechtigung
                                sagt?
                                Ritter
                                #55
                                @thomas-braun sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                christian@NUC:~$ ls -l /home/iobroker/
                                insgesamt 48
                                -rw-r--r-- 1 iobroker iobroker 48483  3. Nov 2024  iob_diag.log
                                • R Ritter
                                  insgesamt 48
                                  #56
                                  @ritter
                                  sudo chmod g+x /home/iobroker/
                                  Dann dürften auch Kommandos wie 'iob diag' oder 'iob nodejs-update' funktionieren.
                                    @ritter
                                    Ritter
                                    #57
                                    kommt gleicher Fehler, bei iob diag. Aber nodejs-update konnte ich ausführen und ist jetzt auf 22
                                    • R Ritter
                                      #58
                                      @ritter
                                      id
                                      ls -l /home
                                      sagt?
                                        @ritter
                                        id
                                        ls -l /home
                                        sagt?
                                        Ritter
                                        #59
                                        christian@NUC:~$ id
                                        ls -l /home
                                        uid=1000(christian) gid=1000(christian) Gruppen=1000(christian),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),106(netdev),1001(iobroker)
                                        insgesamt 8
                                        drwx------ 6 christian christian 4096 16. Aug 12:58 christian
                                        drwxr-xr-x 5 iobroker  iobroker  4096 29. Jul 00:29 iobroker
                                        christian@NUC:~$
                                        • R Ritter
                                          christian@NUC:~$ id
                                          ls -l /home
                                          insgesamt 8
                                          christian@NUC:~$
                                          #60
                                          @ritter
                                          sudo -u iobroker touch /home/iobroker/iob_diag.log
