  4. Tester für Zigbee Adapter 2.0.x gesucht
    5.2k
zigbee 2.0.1
529 Beiträge 51 Kommentatoren 134.6k Aufrufe 41 Beobachtet
  • P pk68
    @ro75 Danke für deine Mühe.
    @Asgothian
    Neu angelernt habe ich die Taster nicht, nur den Lichtsensor. Ich hatte den Adapter neu gestartet und die Tasten dabei betätigt. Das war wohl falsch.
    Beim Rekonfig passieren folgende Dinge: drückt man keine Taste gibt es nach ein paar Sekunden einen Timeout.
    Configuration timed out 0x588e81fffe1fc390 TRADFRI remote control. The device did not repond in time to the configuration request. Another attempt will be made when the device is awake.
    Drückt man eine Taste bricht der Vorgang sofort mit einem Fehler ab.
    0x588e81fffe1fc390 TRADFRI remote control Failed to configure. --> Device 0x588e81fffe1fc390 has no output cluster genScenes
    Hier das ganze Log im Debugmode:
    2025-04-21 14:27:55.864 - info: zigbee.0 (59969) Configuring 0x588e81fffe1fc390 E1524/E1810
    2025-04-21 14:27:58.355 - warn: zigbee.0 (59969) DeviceConfigure:0x588e81fffe1fc390 TRADFRI remote control Failed to configure. --> Device 0x588e81fffe1fc390 has no output cluster genScenes
    2025-04-21 14:28:39.844 - info: zigbee.0 (59969) debug devices set to ["588e81fffe1fc390"]
    2025-04-21 14:28:57.552 - warn: zigbee.0 (59969) ELEVATED:I01 (b54e) Zigbee Event of Type commandToggle from device 0x588e81fffe1fc390, incoming event: {"type":"commandToggle","data":{},"linkquality":28,"groupID":901,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":53,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    2025-04-21 14:28:57.560 - warn: zigbee.0 (59969) ELEVATED:I01 (b54e) message received '{"linkquality":28}' from device 588e81fffe1fc390 type 'E1524/E1810'
    2025-04-21 14:28:57.561 - warn: zigbee.0 (59969) ELEVATED:I02 (b54e) value generated '28' from device 588e81fffe1fc390 for 'Link quality'
    2025-04-21 14:28:57.563 - warn: zigbee.0 (59969) ELEVATED:I01 (b54e) message received '{"action":"toggle"}' from device 588e81fffe1fc390 type 'E1524/E1810'
    2025-04-21 14:28:57.563 - warn: zigbee.0 (59969) ELEVATED:I02 (b54e) value generated '"toggle"' from device 588e81fffe1fc390 for 'Triggered action (e.g. a button click)'
    2025-04-21 14:28:57.564 - warn: zigbee.0 (59969) ELEVATED:I02 (b54e) value generated 'true' from device 588e81fffe1fc390 for 'toggle'
    2025-04-21 14:28:59.007 - info: zigbee.0 (59969) Configuring 0x588e81fffe1fc390 E1524/E1810
    2025-04-21 14:28:59.498 - warn: zigbee.0 (59969) ELEVATED:I01 (bcea) Zigbee Event of Type commandToggle from device 0x588e81fffe1fc390, incoming event: {"type":"commandToggle","data":{},"linkquality":28,"groupID":901,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":54,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    2025-04-21 14:28:59.503 - warn: zigbee.0 (59969) ELEVATED:I01 (bcea) message received '{"linkquality":28}' from device 588e81fffe1fc390 type 'E1524/E1810'
    2025-04-21 14:28:59.504 - warn: zigbee.0 (59969) ELEVATED:I02 (bcea) value generated '28' from device 588e81fffe1fc390 for 'Link quality'
    2025-04-21 14:28:59.506 - warn: zigbee.0 (59969) ELEVATED:I01 (bcea) message received '{"action":"toggle"}' from device 588e81fffe1fc390 type 'E1524/E1810'
    2025-04-21 14:28:59.507 - warn: zigbee.0 (59969) ELEVATED:I02 (bcea) value generated '"toggle"' from device 588e81fffe1fc390 for 'Triggered action (e.g. a button click)'
    2025-04-21 14:28:59.508 - warn: zigbee.0 (59969) ELEVATED:I02 (bcea) value generated 'true' from device 588e81fffe1fc390 for 'toggle'
    2025-04-21 14:28:59.680 - warn: zigbee.0 (59969) DeviceConfigure:0x588e81fffe1fc390 TRADFRI remote control Failed to configure. --> Device 0x588e81fffe1fc390 has no output cluster genScenes
    2025-04-21 14:29:00.301 - warn: zigbee.0 (59969) ELEVATED:I01 (c00c) Zigbee Event of Type commandToggle from device 0x588e81fffe1fc390, incoming event: {"type":"commandToggle","data":{},"linkquality":31,"groupID":901,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":55,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    2025-04-21 14:29:00.310 - warn: zigbee.0 (59969) ELEVATED:I01 (c00c) message received '{"linkquality":31}' from device 588e81fffe1fc390 type 'E1524/E1810'
    2025-04-21 14:29:00.311 - warn: zigbee.0 (59969) ELEVATED:I02 (c00c) value generated '31' from device 588e81fffe1fc390 for 'Link quality'
    2025-04-21 14:29:00.313 - warn: zigbee.0 (59969) ELEVATED:I01 (c00c) message received '{"action":"toggle"}' from device 588e81fffe1fc390 type 'E1524/E1810'
    2025-04-21 14:29:00.313 - warn: zigbee.0 (59969) ELEVATED:I02 (c00c) value generated '"toggle"' from device 588e81fffe1fc390 for 'Triggered action (e.g. a button click)'
    2025-04-21 14:29:00.314 - warn: zigbee.0 (59969) ELEVATED:I02 (c00c) value generated 'true' from device 588e81fffe1fc390 for 'toggle'
    2025-04-21 14:29:07.509 - info: zigbee.0 (59969) Configuring 0x588e81fffe1fc390 E1524/E1810
    2025-04-21 14:29:17.518 - info: zigbee.0 (59969) Timeout trying to configure 0x588e81fffe1fc390 E1524/E1810 (starting CoM).
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #361
    @pk68 die debug Meldungen bringen nichts. Bitte die Info-Seite für das Gerät posten.
    A.
    P 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      pk68
      #362
      @asgothian
      Wie schon erwähnt, scheint der Sensor wieder zu funktionieren. Die Helligkeitswerte kommen wieder rein. Was fehlt ist noch der Batteriestatus. Aber das dauert bestimmt noch etwas. Hier die Info-Seite:
      DuffyD 1 Antwort Letzte Antwort
      • AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #363
        @pk68 es ging um die Ikea Fernbedienung, nicht den Sensor
        DuffyD P 2 Antworten Letzte Antwort
        • P pk68
          @asgothian
          DuffyD Offline
          DuffyD Offline
          Duffy
          #364
          @pk68
          Also bei mir erscheint der Batteriezustand. Nur zur Info.
          Viele Grüße Duffy
          Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
          Node.js: v22.23.1
          NPM: 10.9.4
          js-controller 7.1.2
          Linux: Trixie
            DuffyD Offline
            DuffyD Offline
            Duffy
            #365
            @asgothian
            Hallo asgothian,
            Auch ihn habe mich nun durchgerungen die 2.0.5 zu installieren. „Durchgerungen“ nur deshalb weil ich, wenn es nicht funktioniert hätte ziemlich auf dem Schlauch gestanden wäre. Aber es hat problemlos geklappt, einige orangenen Einträge korrigiert und alle Geräte funktionieren wieder.
            Vielen Dank für eure tolle Arbeit!!
            Jetzt habe ich aber noch 2 Punkte.
            1. ich habe einen Aquara Erschütterungsmelder in meinem Klodeckel. Hier bekomme ich seit dem Update immer folgende Warnung.
            Ich verwende die Punkte nicht und würde die Warnung gerne unterdrücken. Geht das irgendwie?
            1. seit dem Update ist der Adapter recht mitteilungsbedürftig das kennne ich so von der Version 1.x.x nicht in dem Maße. Kleines Beispiel:
            Kann ich das irgendwie etwas reduzieren?
            Viele Grüße Duffy
            Node.js: v22.23.1
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
            • DuffyD Duffy
              @asgothian
              Hallo asgothian,
              Viele Grüße Duffy
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #366
              @duffy Zu 1: da lässt sich aktuell nichts machen - die Definition des Converters ist nicht korrekt, daher die Meldungen. In der 3.0 wir es dafür eine Lösung geben
              Zu 2: Du musst schauen das du das betroffene Gerät für eine Konfiguration wach hältst (den pairing Knopf alle paar sekunden kurz drücken). Sobald er erfolgreich konfiguriert wurde sind die Meldungen weg.
              A.
                A.
                DuffyD Offline
                DuffyD Offline
                Duffy
                schrieb am zuletzt editiert von Duffy
                #367
                @asgothian
                Danke schön, das werde ich versuchen.
                Edit: toller Tip jetzt kommen nicht mehr so viele Meldungen.
                Liebe Grüsse Duffy
                Node.js: v22.23.1
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
                  pk68
                  #368
                  @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                  Sorry, hier die richtige Info:
                  • DuffyD Duffy
                    @pk68
                    Viele Grüße Duffy
                    pk68
                    #369
                    @duffy
                    Danke. Der Batteriezustand wird sicher selten übertragen. Ändert sich sehr langsam. Werde mal einen Tag abwarten. Der Helligkeitswert wird ja übertragen. Der ist wichtig.
                      @pedder007 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                      Ich hatte das gerade mal über die 'Binding' Funktion im Adapter probiert (mit einer TRADFRI remote control und einem SA-003-Zigbee Switch, bzw einem A1Z Plug), hat aber nicht geklappt. Da werden in der Auswahl jeweils auch nicht alle Datenpunkte, bzw. auch lange nicht alle Devices, angezeigt.
                      Das könnte ein Bedienfehler gewesen sein. Binding ist genau die Lösung für das Problem. Allerdings geht Binding aktuell nur wenn bestimmte Cluster im Zigbee unterstützt werden. Man kann zwar über den Experten-Modus auch andere Bindings erstellen, das erfordert aber maximales Expertenwissen. Da das nicht 'mal eben' End-Nutzerfreundlich in einen Dialog giessbar.
                      Zeig doch mal das Log von dem Zeitraum wo du das Binding versucht hast.
                      A.
                      Pedder007P Offline
                      Pedder007P Offline
                      Pedder007
                      schrieb am zuletzt editiert von Pedder007
                      #370
                      Bitteschön :-) :
                      Failed to bind cluster 'genOnOff' from '0xccccccfffee0be2f' to '0x00124b001d4413e2' (Error: Bind 0xccccccfffee0be2f/1 genOnOff from '0x00124b001d4413e2/1' failed (AREQ - ZDO - bindRsp after 10000ms))
                      Mehr kam da nicht.
                      Das war der Versuch die beiden zu koppeln:
                      Pedder
                      All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                      Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                      Under construction: Smart-WoMo auf Raspi4
                      • Pedder007P Pedder007
                        Bitteschön :-) :
                        Mehr kam da nicht.
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #371
                        @pedder007 Wie gesagt.. User error. Wenn die Fernbedienung schläft kann sie nicht gebunden werden. Wiederhol das ganze mal, halt dabei aber die Fernbedienung wach :)
                        A.
                        Pedder007P 1 Antwort Letzte Antwort
                          A.
                          Pedder007P Offline
                          Pedder007P Offline
                          Pedder007
                          #372
                          wenn die Fernbedienung schläft kann sie nicht gebunden werden.
                          A-haaa, jap das wars, Binding klappt, wenn man den Button während des Binding-Vorganges 1-2x drückt.
                          Allerdings schaltet dann danach dennoch nichts.
                          Ich hatte es auch mit anderen Quell- und Ziel-Endpunkten probiert, ging aber auch nicht.
                          Was übersehe ich da noch?
                          Achso, im Log stand nun noch das:
                          Object of state "zigbee.0.info.bind_ccccccfffee0be2f_1_6_00124b001d4413e2_1_5" is missing the required property "common.type"
                          Pedder
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #373
                            @pedder007 Das Problem dabei ist wie die Geräte das Binding erwarten, und was sie daraus machen. Das ist lange nicht untersucht worden.
                            Auch ist die Frage was du 'binden' wolltest - eigentlich sollte das binding von onOff zu onOff das ein/ausschalten ermöglichen - sicher ist das aber leider nicht. Um die Helligkeit zu steuern brauchst du ein weiteres binding mit den gleichen Geräten.
                            Zusätzlich kann es sein das der Haken beim Entkoppeln auch bei deiner Fernbedienung notwendig ist - das weiss ich aber nicht.
                            Die Fehlermeldung liegt daran das das ganze System mit den Bindings lange nicht angefasst wurde und damit nicht an die Änderungen im JS Controller angepasst wurde. Das muss überarbeitet werden - ist aber aktuell erst einmal zurück gestellt. Das ganze Thema Binding ist schwierig.
                            A.
                            • Pedder007P Offline
                              Pedder007P Offline
                              Pedder007
                              #374
                              @asgothian Ok, danke Dir, verstanden - denke ich ;-)
                              Also: Es sollte ja nur onOff schalten, das würde mir da reichen, bzw. dieser Empfänger kann ohnehin nur onOff.
                              Wenn ich den Hinweis in dem Binding-Fenster bzgl. Haken-setzen richtig verstehe, dann würde das allerdings dazu führen, dass der Button ja nicht mehr am Koordinator hängt.
                              Das würde für mich aber keinen Sinn machen, da ich die Funktion ja immer benötige. Ich hätte das Binding als Fallback gesehen, wie gesagt bei Server/ioBroker-Ausfall.
                              Das hier verwendete Setup ist auch nur ein Trivial-Beispiel, um das Ganze besser zu verstehen. Eigentlich geht es mir am Ende darum Osram-Switche und Aqara Opples direkt mit Rolladenaktoren zukoppeln. Ich befürchte aber, dass das dann alles nicht so ganz einfach ist :-)
                              Da ich diese Aktoren allerdings sukzessive ohnehin gegen andere Schalter austausche (geht wegen der Kabel-Verlegung nur Step-by-Step) ist das auch nicht ganz so tragisch.
                              Pedder
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #375
                                Probier es aus - es kann gehen, muss aber nicht. Die Ikea Fernbedienungen sind durchaus speziell (insbesondere die Runden)
                                A.
                                  A.
                                  Pedder007P Offline
                                  Pedder007P Offline
                                  Pedder007
                                  #376
                                  Oki-doki, dann teste ich mal ein paar andere Gerätchen.
                                  Es bleibt einfach immer spannend bei dem ganzen Zeugs ... ;-)
                                  Danke Dir!
                                  Pedder
                                    Danke Dir!
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #377
                                    @pedder007 Ich würde mich freuen wenn Du uns auf dem Laufenden hältst. Welche Geräte / welche Fernbedienung / welche Erfolge.
                                    A.
                                      A.
                                      Pedder007P Offline
                                      Pedder007P Offline
                                      Pedder007
                                      #378
                                      Mache ich sobald ich etwas ausprobiert habe ✌
                                      Pedder
                                        @pk68 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                        @asgothian
                                        Ich habe das wie oben beschrieben durchgeführt, allerdings ohne Verbesserung. Die Schalter bleiben als "configured: false" markiert. Drückt man erstmalig eine Taste, kommt eine Warnung:
                                        2025-04-21 13:37:10.520 - info: zigbee.0 (59969) Configure on Message for 0x588e81fffe1fc6e8
                                        2025-04-21 13:37:10.521 - info: zigbee.0 (59969) Configuring 0x588e81fffe1fc6e8 E1524/E1810
                                        2025-04-21 13:37:11.631 - warn: zigbee.0 (59969) DeviceConfigure:0x588e81fffe1fc6e8 TRADFRI remote control Failed to configure. --> Device 0x588e81fffe1fc6e8 has no output cluster genScenes
                                        Den Lichtsensor habe ich erneut angelernt und dabei immer wieder den Taster betätigt. Außer das die Meldung "Successfully interviewed" zweimal kam, hat sich nichts geändert. Keine Werte in den Datenpunkten.
                                        Von neu anlernen war nirgends die Rede. Neu konfigurieren ist nötig, kann über die Gerätekachel angestoßen werden. Dabei den Sensor wach halten.
                                        Für die E1524/E1810: zeig mal das Info-Display des Gerätes
                                        A.
                                        pk68
                                        #379
                                        @asgothian
                                        Da es bei mir noch nicht ganz rund läuft, könnte es an meinen Coordinator liegen? Ich nutze einen CC2538 + CC2592 PA Zigbee Stick vor knapp 5 Jahren hier im Forum gekauft. Hier noch ein paar Infos dazu:
                                        type: zStack30x
                                        version: 2-2.2.7.2.
                                        revision: 20201010
                                        channel: 25
                                        • P pk68
                                          @asgothian
                                          type: zStack30x
                                          version: 2-2.2.7.2.
                                          revision: 20201010
                                          channel: 25
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #380
                                          @pk68 Nein - deine Fernbedienung scheint nicht OK - sie meldet nicht die für die FB üblichen Cluster - das ist Ursache der Fehlermeldung. Ich empfehle Dir ein Firmware-Update für die FB durchführen.
                                          A.
                                          Nachtrag: so sollten sie aussehen.
                                          P AlexAtHomeA 2 Antworten Letzte Antwort
