  4. Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem
40 Beiträge 9 Kommentatoren 5.3k Aufrufe 8 Beobachtet
  • D Dschones
    Script v.2024-12-09 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7l+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     16:56:37 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-01-11 16:56:38 CET
               Universal time: Sat 2025-01-11 15:56:38 UTC
                     RTC time: Sat 2025-01-11 15:56:38
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.9G        1.1G        1.8G        0.0K        982M        2.6G
    Swap:            99M          0B         99M
    Total:          4.0G        1.1G        1.9G
    Active iob-Instances:   18
             3887 M total memory
             1106 M used memory
              464 M active memory
             1500 M inactive memory
             1799 M free memory
              113 M buffer memory
              868 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 16:56:38 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
    Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  3.0 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3887.9 total,   1799.4 free,   1105.6 used,    982.9 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2641.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       58G  7.2G   49G  13% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     778M  876K  777M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    3.3G    /var/
    1.9G    /var/log
    1.8G    /var/log/journal/834f3657738944fca3e7840589ae9346
    755M    /var/cache
    Archived and active journals take up 1.7G in the file system.
    /opt/iobroker/backups:
    402M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    198M    /opt/iobroker/iobroker-data/
    132M    /opt/iobroker/iobroker-data/files
    49M     /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
    6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
    /dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEHP-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-pi         iobroker-pi (version: 7.0.6, hostname: iobroker-pi   , alive, uptime: 673253)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.1.5
    javascript:     6.0.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-pi                              -  enabled
      system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
    + system.adapter.fronius.0                : fronius               : iobroker-pi                              -  enabled
      system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.hm-rega.1                : hm-rega               : iobroker-pi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker-pi                              - disabled
    + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
    + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
      system.adapter.sayit.0                  : sayit                 : iobroker-pi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartmeter.0             : smartmeter            : iobroker-pi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
    + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.velux.0                  : velux                 : iobroker-pi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
      system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.1.5  [Updatable]
    Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
    Adapter    "daswetter"    : 3.2.2    , installed 3.1.3  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.0.5  [Updatable]
    Adapter    "fronius"      : 2.1.1    , installed 2.0.2  [Updatable]
    Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
    Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
    Adapter    "javascript"   : 8.8.3    , installed 6.0.3  [Updatable]
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "modbus"       : 6.3.2    , installed 5.0.11 [Updatable]
    Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
    Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
    Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
    Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "velux"        : 0.0.8    , installed 0.0.7  [Updatable]
    Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
    Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.13 [Updatable]
    Objects and States
    Objects:        9605
    States:         8668
    W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
    E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.50:18701    0.0.0.0:*               LISTEN      1001       1161594    6723/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1264871    20308/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1160161    6800/io.shelly.0
    tcp        0      0 192.168.178.50:2010     0.0.0.0:*               LISTEN      1001       1159103    6518/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16436      968/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158040    6374/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158045    6374/iobroker.js-co
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14656      1013/dnsmasq
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1160707    6397/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1161918    7217/io.terminal.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16438      968/sshd: /usr/sbin
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14655      1013/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14652      1013/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12249      808/dhclient
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11089      406/avahi-daemon: r
    udp        0      0 0.0.0.0:38251           0.0.0.0:*                           108        11091      406/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11090      406/avahi-daemon: r
    udp6       0      0 :::35121                :::*                                108        11092      406/avahi-daemon: r
    2025-01-11 16:13:12.167  - info: host.iobroker-pi instance system.adapter.velux.0 in version "0.0.7" started with pid 31891
    2025-01-11 16:13:14.688  - info: velux.0 (31891) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.velux, node: v20.18.1, js-controller: 7.0.6
    2025-01-11 16:13:14.999  - error: velux.0 (31891) null
    2025-01-11 16:13:15.004  - error: velux.0 (31891) Login was not successful
    2025-01-11 16:15:54.022  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 32127
    2025-01-11 16:15:56.927  - info: daswetter.0 (32127) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
    2025-01-11 16:16:11.263  - info: daswetter.0 (32127) still wrong data structure from server received! repaired...
    2025-01-11 16:16:15.476  - info: daswetter.0 (32127) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-01-11 16:16:15.997  - info: daswetter.0 (32127) cleaned everything up...
    2025-01-11 16:16:16.015  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 32127 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-11 16:30:54.025  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 899
    2025-01-11 16:30:56.939  - info: daswetter.0 (899) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
    2025-01-11 16:31:11.118  - info: daswetter.0 (899) still wrong data structure from server received! repaired...
    2025-01-11 16:31:15.240  - info: daswetter.0 (899) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-01-11 16:31:15.755  - info: daswetter.0 (899) cleaned everything up...
    2025-01-11 16:31:15.772  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 899 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-11 16:45:54.020  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 3933
    2025-01-11 16:45:56.966  - info: daswetter.0 (3933) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
    2025-01-11 16:46:11.024  - info: daswetter.0 (3933) still wrong data structure from server received! repaired...
    2025-01-11 16:46:15.423  - info: daswetter.0 (3933) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-01-11 16:46:15.941  - info: daswetter.0 (3933) cleaned everything up...
    2025-01-11 16:46:15.958  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 3933 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-11 16:51:25.964  - info: admin.0 (6397) Request actual repository...
    2025-01-11 16:51:26.593  - info: host.iobroker-pi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2025-01-11 16:51:31.666  - info: admin.0 (6397) Repository received successfully.
    Meister MopperM Offline
    Meister Mopper
    @dschones
    Ich würde die vielen Adapter-Upgrades durchführen, eine backitup-Sicherung durchführen und diese extern sichern. Anschließend würde ich das System mit dem aktuellen Debian 12.9 neu aufsetzen (wie oben beschrieben).
    Alles andere ist vermeidbare Mehrarbeit.
    Danach kann man das Zigbee-Problem angehen.
    Proxmox und HA ...
      @dschones
      Dschones
      @meister-mopper
      die Updates der Adapter habe ich durchgeführt, das Upgrade auf die neuste Debin-Version scheue ich aktuell weil ich noch nicht weis ob und wie ich das system wieder soaufgesetzt bekommne. Da ist auch u.a. eine Homematic - Version drauf mit der ich meine Heuzung steuere, wäre doof wenn das nun im Winter nicht mehr klappt.
      gibt es keine andere Möglichkeit ?
      • D Dschones
        @meister-mopper
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @dschones sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
        Du kannst den Hinweis erst einmal ignorieren - ich gehe eher nicht davon aus das die Probleme mit dem Sonoff an der OS Version hängen. eher ist denkbar das der Stick / die firmware defekt ist.
        Insbesondere wenn USB Verlängerung etc. nichts gebracht haben.
        Also Firmware neu flashen, neu versuchen.
        Bevor die Diskussion los geht: Hier geht es mir nicht darum ob es sinnvoll ist das System zu aktualisieren, sondern ob das relevant für den beschriebenen Fehler ist. Das ist es sicher nicht. Ich habe die längste Zeit ein solches System selber betrieben - es funktioniert.
        A.
        B D 2 Antworten Letzte Antwort
        • AsgothianA Asgothian
          A.
          bommel
          schrieb am zuletzt editiert von bommel
          Das gleiche Chaos hatte ich auch neulich...
          Letztendlich: iobroker runter (war strubbelich..) , neu drauf, vorher den Sonoff USB-Dongle mit der 7-er Firmware versehen
          Unnu? Alles löppt wie Pavoo.
          Firmware flashen via Web (https://darkxst.github.io/silabs-firmware-builder/) ging super, nachdem ich temporär die Rechte für ttyACM0 frei gesetzt hatte.
          Die Geräte waren nach 20 min. neu angelernt, so groß ist meine Hütte nicht.
          Gruß, Bommel
          • B bommel
            Gruß, Bommel
            @bommel sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
            Du hättest besser den user in die passende Gruppe gepackt.
            Nachschauen wie die Rechte da vom Treiber/Kernel vergeben werden, ist aber i.d.R. entweder dialup oder plugdevices
            B 1 Antwort Letzte Antwort
            • D Dschones
              @asgothian said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
              Die Einstellungen im Adapter sind die folgenden - ich haeb auch schon andere PAN ID's versucht , aber das Problem blieb das gleich
              Das ist auch nicht verwunderlich. Dem Adapter gelingt es nicht mit der Firmware auf dem Stick zu reden. Mögliche Ursachen:
              • Störungen durch USB3 (in welchem Port steckt der Zigbee-Stick ? In einem der USB3 oder einem der USB2, mit oder ohne USB Verlängerung
              ohne USB-Verlängerung , ich habe auch schon andere USB-Ports versucht - gleiches Ergebnis
              pi@iobroker-pi:~ $ ls -la /dev/serial/by-id/
              total 0
              drwxr-xr-x 2 root root 80 Jan  2 22:17 .
              drwxr-xr-x 4 root root 80 Jan  2 22:17 ..
              lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEH                                                    P-if00-port0 -> ../../ttyUSB0
              lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                                                    us_902fb787e3e7ed119668d7770b2af5ab-if00-port0 -> ../../ttyUSB1
              • Defekte Firmware auf dem Stick - da wäre dann neu Flaschen angesagt
              ok, das habe ich noch nicht in Betracht zu gezogen, das ding ist ja "frisch"
              hast du da ne gute Anleitung ?
              • falsche Auswahl der Firmware im Adapter. Welchen Sonoff Dongle hast du genau ?
              Hier:
              A.
              p.s. All dies ist unabhängig von der alten Software auf dem PI4. Ein Update macht sicher Sinn, hat aber mit diesem Problem wenig bis nichts zu tun.
              Das sehe ich ähnlich - Freunde von mir haben den Stick ebenfalls (auf noch viel älteren System) problemlos am laufen
              CodierknechtC Offline
              Codierknecht
              Schönen Gruß an die Freunde. Auch die sollten sich zeitnah um Systemupdates kümmern.
              "never change a running system" funktioniert nicht.
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
                bommel
                @thomas-braun said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                Hatte gelesen, daß dialup diejenige sei, in der war ich.
                Dann wars wahrscheinlich plugdevices...
                • B bommel
                  Schau es halt nach...
                  ls -l /dev/ttyACM0
                  Und so ganz grundsätzlich verwendet man die Gerätedateien auch nicht direkt sonder nur über die Links 'by-id' beispielsweise.
                    A.
                    Dschones
                    @asgothian
                    Nur um euch auf dem laufenden zu halten: Der Sonoff Sitck hat (nach vielen Rückschlägen (bootloader wollte nicht)) eine neue Firmware, aber das Problem ist 1:1 das gleiche. Es gibt keine erkennbare Veränderung.
                    Mir reichts nun etwas und auf den aktuellen Stick (ZBDongle-P) habe ich keine Lust mehr- daher habe ich mir einen neuen(ZBDongle-E) bestellt- der kommt anfang kommender woche. Dann versuche ich es erneut.
                    Ggf. Mache ich vorab auch gleich prophylaktisch die neue Firmware drauf.
                    • D Dschones
                      @asgothian
                      Dschones
                      Update: Es schaut nicht gut aus
                      Neuer Stick ist gekauft , mit neuster Firmeware geflashed und das Problem ist das nahezu das gleiche ...
                      Hier der Log:
                      2025-01-21 21:21:15.638 - info: host.iobroker-pi "system.adapter.zigbee.0" disabled
                      2025-01-21 21:21:15.639 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2025-01-21 21:21:15.645 - info: zigbee.0 (9841) Got terminate signal TERMINATE_YOURSELF
                      2025-01-21 21:21:15.648 - info: zigbee.0 (9841) cleaned everything up...
                      2025-01-21 21:21:15.651 - info: zigbee.0 (9841) Zigbee: disabling joining new devices.
                      2025-01-21 21:21:15.659 - info: zigbee.0 (9841) terminating
                      2025-01-21 21:21:15.661 - info: zigbee.0 (9841) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-01-21 21:21:15.692 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 send kill signal
                      2025-01-21 21:21:16.148 - info: zigbee.0 (9841) terminating
                      2025-01-21 21:21:16.249 - info: host.iobroker-pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-01-21 21:21:21.092 - info: host.iobroker-pi "system.adapter.zigbee.0" enabled
                      2025-01-21 21:21:21.812 - info: host.iobroker-pi instance system.adapter.zigbee.0 in version "1.10.14" started with pid 12553
                      2025-01-21 21:21:27.109 - info: zigbee.0 (12553) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                      2025-01-21 21:21:27.206 - info: zigbee.0 (12553) delete old Backup files. keep only last 10
                      2025-01-21 21:21:27.209 - info: zigbee.0 (12553) Starting Zigbee npm ...
                      2025-01-21 21:21:27.547 - info: zigbee.0 (12553) Installed Version: iobroker.zigbee@1.10.14
                      2025-01-21 21:21:48.223 - error: zigbee.0 (12553) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2025-01-21 21:21:48.224 - error: zigbee.0 (12553) Failed to start Zigbee
                      2025-01-21 21:21:48.224 - error: zigbee.0 (12553) Error herdsman start
                      2025-01-21 21:21:58.228 - info: zigbee.0 (12553) Try to reconnect. 1 attempts left
                      2025-01-21 21:21:58.229 - info: zigbee.0 (12553) Starting Zigbee npm ...
                      2025-01-21 21:21:58.243 - info: zigbee.0 (12553) Installed Version: iobroker.zigbee@1.10.14
                      2025-01-21 21:21:58.410 - error: zigbee.0 (12553) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                      2025-01-21 21:21:58.411 - error: zigbee.0 (12553) Failed to start Zigbee
                      2025-01-21 21:21:58.412 - error: zigbee.0 (12553) Error herdsman start
                      was nun ?
                      • D Dschones
                        Hier der Log:
                        was nun ?
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        was nun ?
                        • Hast du die Einstellungen angepasst (EZSP firmware statt TI firmware ?)
                        • hast du shepherd.db und nvbackup.json beseitigt ?
                        A.
                          was nun ?
                          A.
                          Dschones
                          was nun ?
                          A.
                          Sorry für die späte Antwort - war beruflich länger weg
                          Neuer Stick ist da - Firmeware ist geflashed
                          --> Zigbee (EZSP) 7.4.5.0 build 0
                          shepherd.db und nvbackup.json sind nicht "beseitigt" , da es bei mir immer heißt "existiert nicht"
                          pi@iobroker-pi:~ $ rm opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                          rm: cannot remove 'opt/iobroker/iobroker-data/zigbee_0/nvbackup.json': No such file or directory
                          ansonsten ist das Problem 1:1 das gleiche wie immer ... der Log sieht noch 1:1 aus wie oben
                          • D Dschones
                            was nun ?
                            A.
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            Bist du 100% sicher das die Meldung die gleiche ist ? Insbesondere das diese Meldung kommt:
                            Wenn ja, dann passt etwas nicht mit dem USB Port bzw. den Treibern. Hast du versucht einen anderen Port zu wählen ?
                            Also sind sie beseitigt - es gibt keine. Das war der Ziel-Zustand.
                            Aktuell muss ich dich wahrscheinlich 2 bis 3 Tage vertrösten, dann kann ich Dir eine aktualisierte Version des Adapters zum Testen anbieten - für den Fall das es Probleme zwischen Herdsman und Stick gibt. Die ist aber aktuell noch in Arbeit.
                            A.
                              A.
                              Dschones
                              schrieb am zuletzt editiert von Dschones
                              @asgothian
                              alos ich habe alle 4 Ports durchprobiert - das ergebis war das gleiche
                              zigbee.0
                              	2025-02-23 12:46:12.986	error	Error herdsman start
                              zigbee.0
                              	2025-02-23 12:46:12.985	error	Failed to start Zigbee
                              zigbee.0
                              	2025-02-23 12:46:12.984	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                              zigbee.0
                              	2025-02-23 12:46:12.837	info	Installed Version: iobroker.zigbee@1.10.14
                              zigbee.0
                              	2025-02-23 12:46:12.823	info	Starting Zigbee npm ...
                              zigbee.0
                              	2025-02-23 12:46:12.822	info	Try to reconnect. 1 attempts left
                              zigbee.0
                              	2025-02-23 12:46:02.819	error	Error herdsman start
                              zigbee.0
                              	2025-02-23 12:46:02.818	error	Failed to start Zigbee
                              zigbee.0
                              	2025-02-23 12:46:02.817	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                              zigbee.0
                              	2025-02-23 12:45:42.254	info	Installed Version: iobroker.zigbee@1.10.14
                              zigbee.0
                              	2025-02-23 12:45:41.875	info	Starting Zigbee npm ...
                              zigbee.0
                              	2025-02-23 12:45:41.873	info	delete old Backup files. keep only last 10
                              zigbee.0
                              	2025-02-23 12:45:41.746	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
                              zigbee.0
                              	2025-02-23 12:45:31.660	info	terminating
                              zigbee.0
                              	2025-02-23 12:45:31.171	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zigbee.0
                              	2025-02-23 12:45:31.169	info	terminating
                              zigbee.0
                              	2025-02-23 12:45:31.162	info	Zigbee: disabling joining new devices.
                              zigbee.0
                              	2025-02-23 12:45:31.158	info	cleaned everything up...
                              zigbee.0
                              	2025-02-23 12:45:31.156	info	Got terminate signal TERMINATE_YOURSELF
                              zigbee.0
                              	2025-02-23 12:45:21.917	info	Installed Version: iobroker.zigbee@1.10.14
                              zigbee.0
                              	2025-02-23 12:45:21.529	info	Starting Zigbee npm ...
                              zigbee.0
                              	2025-02-23 12:45:21.527	info	delete old Backup files. keep only last 10
                              zigbee.0
                              	2025-02-23 12:45:21.388	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
                              zigbee.0
                              	2025-02-23 12:45:21.267	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"3c357f1f8439ef1193585df454516304","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_3c357f1f8439ef1193585df454516304-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"}]
                              zigbee.0
                              	2025-02-23 12:45:10.886	info	terminating
                              zigbee.0
                              	2025-02-23 12:45:10.394	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zigbee.0
                              	2025-02-23 12:45:10.393	info	terminating
                              was genau ist denn dieses Herdsman ? ich finde dazu im Netz nix wirklich detailiertes
                              • D Dschones
                                @asgothian
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                der Zigbee-Herdsman ist die Bibliothek die für die Kommunikation mit der Firmware auf dem Stick verantwortlich ist. Die Fehlermeldung deutet darauf hin das keine Kommunikation zur Firmware aufgebaut werden kann.
                                Da das prinzipiell geht (sonst wäre das Forum voll mit Beschwerden das der Zigbee-Adapter nicht geht) muss etwas auf Deinem System nicht OK sein.
                                Relevant dafür ist diese Meldung:
                                Alles weitere, auch das mit dem unable to lock port sind Folgefehler die aus dieser einen Meldung resultieren.
                                Wenn ich den Thread richtig zusammenfasse:
                                • du hast einen anderen Stick probiert - gleiche Meldung
                                • du hast andere Firmware probiert - gleiche Meldung
                                • du hast das OS aktualisiert - gleiche Meldung
                                Bleibt ggf. noch ein hardware-Defekt im USB Bereich ? Hast du die Möglichkeit auf einem anderen Rechner zum testen einen ioBroker zu installieren und zu schauen ob der Zigbee-Adapter da startet ? Ansonsten gehen mir leider die Ideen aus.
                                A.
                                  A.
                                  Dschones
                                  @asgothian
                                  einer der USB-Port war (irgendwann habe ich den weg, damit es nicht ggf. daran liegen könnte) mit einem enocean gateway verbunden, dieser hat bisher auch immer hervorragend funktioniert .
                                  welche möglichkeiten gibt es die USB-Port zu testen?
                                  • D Dschones
                                    @asgothian
                                    Dschones
                                    Update:
                                    ich habe nun damit ich möglichst viele Fehlerquellen ausschließe mir kurzerhand nen nietnagelneuen RaspberryPi 5 (4GB) zugelegt und darauf auch die neueste Version des Betriebssystems draufgespielt.
                                    dazu gab es einen neuen Sonoff Zigbee Stick welchen ich auch passend der Anleitungen geflasht habe.
                                    und .... das Problem ist immer noch da . Da ich nun Hardware oder Betriebssystem-Probleme ausgeschlossen habe --> woran könnte es noch liegen ?
                                    hier der Log:
                                    2025-03-15 13:59:25.966 - info: zigbee.0 (1564) terminating
                                    2025-03-15 13:59:26.000 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2025-03-15 13:59:29.166 - info: host.raspberrypi instance system.adapter.zigbee.0 in version "1.10.14" started with pid 1682
                                    2025-03-15 13:59:30.683 - info: zigbee.0 (1682) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                                    2025-03-15 13:59:30.717 - info: zigbee.0 (1682) delete old Backup files. keep only last 10
                                    2025-03-15 13:59:30.718 - info: zigbee.0 (1682) Starting Zigbee npm ...
                                    2025-03-15 13:59:30.839 - info: zigbee.0 (1682) Installed Version: iobroker.zigbee@1.10.14
                                    2025-03-15 13:59:51.069 - error: zigbee.0 (1682) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                    2025-03-15 13:59:51.070 - error: zigbee.0 (1682) Failed to start Zigbee
                                    2025-03-15 13:59:51.070 - error: zigbee.0 (1682) Error herdsman start
                                    2025-03-15 14:00:01.071 - info: zigbee.0 (1682) Try to reconnect. 1 attempts left
                                    2025-03-15 14:00:01.072 - info: zigbee.0 (1682) Starting Zigbee npm ...
                                    2025-03-15 14:00:01.079 - info: zigbee.0 (1682) Installed Version: iobroker.zigbee@1.10.14
                                    2025-03-15 14:00:01.161 - error: zigbee.0 (1682) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                    2025-03-15 14:00:01.162 - error: zigbee.0 (1682) Failed to start Zigbee
                                    2025-03-15 14:00:01.162 - error: zigbee.0 (1682) Error herdsman start
                                    Hier die Adaptereinstellungen
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      wie währe es wenn du den Adapter richtig einstellst
                                      für EZSP
                                      Thomas BraunT D 2 Antworten Letzte Antwort
                                      • arteckA arteck
                                        für EZSP
                                        @Dschones
                                        Im Zuge dessen könnte man auch die Geräte-Datei auf den 'by-id'-Link umstellen.
                                        • arteckA arteck
                                          für EZSP
                                          Dschones
                                          @arteck
                                          Kaum macht man es richtig, schon klappt es ...
                                          DANKE! Vielen Dank !
