  4. Vis2 Adapter macht Probleme.
22 Beiträge 5 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    TimoWald
    Hallo, was ist das für eine Fehlermeldung? Was kann ich da machen?
    2024-11-03 11:32:53.538 - debug: homeconnect.0 (151169) Set event state
    2024-11-03 11:33:41.833 - info: host.iobroker "system.adapter.vis-2.0" enabled
    2024-11-03 11:33:42.628 - error: host.iobroker startInstance vis-2.0: cannot find start file!
    2024-11-03 11:33:45.359 - info: solax.0 (1115) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    2024-11-03 11:33:52.985 - debug: homeconnect.0 (151169) event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14VG93-68A40E9041F2\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"level\":\"hint\",\"timestamp\":1730630032,\"unit\":\"%\",\"uri\":\"/api/homeappliances/SIEMENS-WM14VG93-68A40E9041F2/programs/active/options/BSH.Common.Option.ProgramProgress\",\"value\":12}]}","lastEventId":"SIEMENS-WM14VG93-68A40E9041F2","origin":"https://api.home-connect.com"}
    2024-11-03 11:33:52.985 - debug: homeconnect.0 (151169) SIEMENS-WM14VG93-68A40E9041F2.programs.active.options.BSH_Common_Option_ProgramProgress:12
    2024-11-03 11:33:52.986 - debug: homeconnect.0 (151169) Set event state
    2024-11-03 11:33:53.531 - debug: homeconnect.0 (151169) event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14VG93-68A40E9041F2\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.RemainingProgramTime\",\"level\":\"hint\",\"timestamp\":1730630033,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/SIEMENS-WM14VG93-68A40E9041F2/programs/active/options/BSH.Common.Option.RemainingProgramTime\",\"value\":2520}]}","lastEventId":"SIEMENS-WM14VG93-68A40E9041F2","origin":"https://api.home-connect.com"}
    2024-11-03 11:33:53.532 - debug: homeconnect.0 (151169) SIEMENS-WM14VG93-68A40E9041F2.programs.active.options.BSH_Common_Option_RemainingProgramTime:2520
    2024-11-03 11:33:53.533 - debug: homeconnect.0 (151169) Set event state
    • T TimoWald
      sigi234S Online
      sigi234S Online
      sigi234
      @timowald
      Adapter Grün? WEB Adapter installiert und konfiguriert?
      Immer Daten sichern!
      • sigi234S sigi234
        @timowald
        TimoWald
        @sigi234 Adapter wird nicht grün.
        • T TimoWald
          sigi234S Online
          sigi234S Online
          sigi234
          @timowald
          Haken bei Reine Web-Sockets verwenden mal raus
          • sigi234S sigi234
            @timowald
            TimoWald
            @sigi234 Wird auch nicht grün.
            Er meckert wegen Start File.
            • T TimoWald
              sigi234S Online
              sigi234S Online
              sigi234
              @timowald
              Wie installiert, welche Version ?
              Browser Cache mal komplett geleert?
              VIS-2 Upload mal gemacht?
              • sigi234S sigi234
                @timowald
                TimoWald
                @sigi234 Version ist noch die v2.9.44. Bekomme keine andere drauf. Cache wurde schon geleert. Was ist mit Vis2 Uload gemeint?
                • T TimoWald
                  HomoranH Offline
                  HomoranH Offline
                  @timowald sagte in Vis2 Adapter macht Probleme.:
                  warum nicht?
                  erfüllst du irgendwelche Voraussetzungen nicht?
                    warum nicht?
                    TimoWald
                    schrieb am zuletzt editiert von TimoWald
                    @homoran Wie soll ich sie am besten installieren? Mit Github URL, NMP, etc?
                    An dieser stelle bleibt er stundenlang stehen.
                    • T TimoWald
                      @timowald
                      Das ist vis1.
                      Was sagt die Konsole?
                      iob update
                      iob upgrade
                      Oder vielleicht gleich mal die Langfassung von
                      iob diag
                        @timowald
                        Das ist vis1.
                        iob update
                        iob upgrade
                        iob diag
                        TimoWald
                        @thomas-braun iob diag sagt folgendes:
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer-container
                                   Chassis: container
                            Virtualization: lxc
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.8.12-1-pve
                              Architecture: x86-64
                        OS is similar to:
                        model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
                        Docker          : false
                        Virtualization  : lxc
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         12:47:33 up 18 days, 18:57,  2 users,  load average: 0.76, 1.37, 2.90
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                        *** TIME AND TIMEZONES ***
                                       Local time: Sun 2024-11-03 12:47:33 CET
                                   Universal time: Sun 2024-11-03 11:47:33 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        wald
                        HOME=/home/wald
                        GROUPS=wald sudo
                        js-controller is not running
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                        *** MEMORY ***
                        Mem:            7.8G        454M        3.6G        0.0K        3.8G        7.3G
                        Swap:           7.0G        8.0M        7.0G
                        Total:           14G        463M         10G
                        Active iob-Instances:   1
                                 7778 M total memory
                                  454 M used memory
                                   84 M active memory
                                 3687 M inactive memory
                                 3569 M free memory
                                    0 M buffer memory
                                 3754 M swap cache
                                 7039 M total swap
                                    8 M used swap
                                 7031 M free swap
                        top - 12:47:33 up 18 days, 18:57,  2 users,  load average: 0.76, 1.37, 2.90
                        Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  1.5 us,  3.1 sy,  0.0 ni, 95.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   7778.1 total,   3568.8 free,    454.6 used,   3754.8 buff/cache
                        MiB Swap:   7040.0 total,   7031.3 free,      8.7 used.   7323.5 avail Mem
                        *** FAILED SERVICES ***
                          UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                        * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                        * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                        * iobroker.service              loaded failed failed ioBroker Server
                        * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                        4 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        dmesg: read kernel buffer failed: Operation not permitted
                        No critical errors detected
                        *** FILESYSTEM ***
                        /dev/loop3     ext4       32G   18G   13G  58% /
                        none           tmpfs     492K  4.0K  488K   1% /dev
                        udev           devtmpfs  3.8G     0  3.8G   0% /dev/tty
                        tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
                        tmpfs          tmpfs     1.6G  116K  1.6G   1% /run
                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                        tmpfs          tmpfs     778M     0  778M   0% /run/user/1005
                        Show mounted filesystems:
                        TARGET SOURCE     FSTYPE OPTIONS
                        /      /dev/loop3 ext4   rw,relatime
                        /var:
                        1.6G    /var/
                        1.2G    /var/log/journal/e42f0ac6b105431aa6e42fb59b1f8fbf
                        1.2G    /var/log
                        348M    /var/cache
                        Archived and active journals take up 24.0M in the file system.
                        /opt/iobroker/backups:
                        128M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        2.2G    /opt/iobroker/iobroker-data/
                        1.6G    /opt/iobroker/iobroker-data/files
                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                        30M     /opt/iobroker/iobroker-data/objects.jsonl
                        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2272728-if00
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.17.0
                        /usr/bin/node           v20.17.0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.3
                        nodejs:
                          Installed: 20.17.0-1nodesource1
                          Candidate: 20.18.0-1nodesource1
                          Version table:
                             20.18.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                         *** 20.17.0-1nodesource1 1001
                                100 /var/lib/dpkg/status
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u5 500
                                500 http://security.debian.org bullseye-security/main amd64 Packages
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        iobroker is not running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1622837)
                        Core adapters versions
                        js-controller:  6.0.11
                        admin:          7.1.5
                        javascript:     8.8.3
                        nodejs modules from github:     13
                        +-- iobroker.bydhvs@1.5.1 (git+ssh://git@github.com/christianh17/ioBroker.bydhvs.git#55d06a849a015b35995e8e3fdc3c35f57fdd9c0d)
                        +-- iobroker.energiefluss-erweitert@0.5.1-alpha.10 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#3a8c53f95ee9a763bf454b74ea986d8eb5991a65)
                        +-- iobroker.fronius@2.1.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fronius.git#392e182ba42b3255cdd84c657c00e7fd8a9c4814)
                        +-- iobroker.icons-ultimate-png@1.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-ultimate-png.git#519f1a7d31416157f8297b6e5b33745a3989a122)
                        +-- iobroker.luxtronik2@0.5.2 (git+ssh://git@github.com/boellner/ioBroker.luxtronik2.git#dc0b80246a75506d7419bc2f6e6fe1b0d34338ef)
                        +-- iobroker.pvforecast@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.pvforecast.git#3ef9743f113e0c4a53a7f1841748131e5b1d66a3)
                        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                        +-- iobroker.vis-2@ (git+ssh://git@github.com/ioBroker/ioBroker.vis-2.git#cabeca3a63207dc71df3504865eccfcef2f22097)
                        +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
                        +-- iobroker.vis-materialdesign@0.5.86 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#cf7fc5b85debcda156a3ec7feb761cff217fa855)
                        +-- iobroker.vis@1.5.6 (git+ssh://git@github.com/iobroker/ioBroker.vis.git#8518f7fbadf76519b3c6bceb5a34e298b9257c0a)
                        +-- iobroker.wiobrowser@2.0.2 (git+ssh://git@github.com/Bettman66/ioBroker.wiobrowser.git#1ce25f0107ab18ad95b5851d4bd96efd4172469d)
                        +-- iobroker.worx@3.1.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.worx.git#4511551fdae7eaa6084c884ad1c2aaa67cef80d2)
                        Adapter State
                          system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled, compact disabled
                          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
                          system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
                          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
                          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled, compact disabled
                          system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled, compact disabled
                          system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled, compact disabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
                          system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
                          system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
                          system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
                          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                          system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
                          system.adapter.fronius-solarweb.1       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
                          system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled, compact disabled
                          system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
                          system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
                          system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled, compact disabled
                          system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
                          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled, compact disabled
                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                          system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
                          system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
                          system.adapter.iot.1                    : iot                   : iobroker                                 -  enabled, compact disabled
                          system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
                          system.adapter.knx.0                    : knx                   : iobroker                                 - disabled, compact disabled, bind: 192.168.9.254
                          system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled, compact disabled
                          system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 -  enabled, compact disabled, port: 8214
                          system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled, compact disabled
                          system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled, compact disabled
                          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                          system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
                          system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1888, bind: 0.0.0.0
                          system.adapter.mqtt.3                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                          system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, compact disabled, port: 1880, bind: 192.168.9.254
                          system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled, compact disabled
                          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled, compact disabled
                          system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled, compact disabled
                          system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
                          system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled, compact disabled
                          system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
                          system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled, compact enabled (group 1)
                          system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled, compact disabled
                          system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                          system.adapter.shelly.1                 : shelly                : iobroker                                 - disabled, compact disabled, port: 1887, bind: 0.0.0.0
                          system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled, compact disabled
                          system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                          system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
                          system.adapter.synology.0               : synology              : iobroker                                 -  enabled, compact disabled, port: 5000
                          system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
                          system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled, compact disabled
                          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                          system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
                          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
                          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled, compact disabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
                          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
                          system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
                          system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
                          system.adapter.windows-control.0        : windows-control       : iobroker                                 - disabled, compact disabled
                          system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, compact disabled, port: 2208
                          system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled, compact disabled
                          system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled, compact disabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                        Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
                        Adapter    "bydhvs"       : 1.5.0    , installed 1.5.1
                        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.10
                        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
                        Adapter    "gira-iot"     : 0.5.0    , installed 0.5.0
                        Adapter    "hass"         : 1.4.0    , installed 1.4.0
                        Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                        Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                        Adapter    "ical"         : 1.15.0   , installed 1.15.0
                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                        Adapter    "iot"          : 3.3.0    , installed 3.3.0
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Controller "js-controller": 6.0.11   , installed 6.0.11
                        Adapter    "knx"          : 2.0.28   , installed 2.0.28
                        Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
                        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                        Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                        Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
                        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                        Adapter    "pvforecast"   : 3.0.0    , installed 4.0.0
                        Adapter    "roborock"     : 0.6.16   , installed 0.6.16
                        Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                        Adapter    "solax"        : 0.9.12   , installed 0.9.12
                        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                        Adapter    "synology"     : 3.1.0    , installed 3.1.0
                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                        Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
                        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
                        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                        Adapter    "windows-control": 0.1.5  , installed 0.1.5
                        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                        Adapter    "worx"         : 3.1.0    , installed 3.1.0
                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                        Objects and States
                        Objects:        34385
                        States:         27991
                        Hit:1 http://security.debian.org bullseye-security InRelease
                        Hit:2 http://ftp.debian.org/debian bullseye InRelease
                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 20
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        17344      110/systemd-resolve
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14077      1/init
                        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        17338      110/systemd-resolve
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18446      295/master
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          14079      1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14198      1/init
                        tcp6       0      0 :::5355                 :::*                    LISTEN      104        17341      110/systemd-resolve
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18447      295/master
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        17343      110/systemd-resolve
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14078      1/init
                        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        17337      110/systemd-resolve
                        udp6       0      0 :::111                  :::*                                0          14080      1/init
                        udp6       0      0 :::5355                 :::*                                104        17340      110/systemd-resolve
                        2024-11-03 12:38:03.521  - warn: host.iobroker instance system.adapter.backitup.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.521  - info: host.iobroker instance system.adapter.backitup.0 terminated with code null ()
                        2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.modbus.1 terminated due to SIGKILL
                        2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.modbus.1 terminated with code null ()
                        2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.hass.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.hass.0 terminated with code null ()
                        2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.pvforecast.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.pvforecast.0 terminated with code null ()
                        2024-11-03 12:38:03.619  - warn: host.iobroker instance system.adapter.homeconnect.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.619  - info: host.iobroker instance system.adapter.homeconnect.0 terminated with code null ()
                        2024-11-03 12:38:03.620  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.620  - info: host.iobroker instance system.adapter.iot.0 terminated with code null ()
                        2024-11-03 12:38:03.676  - warn: host.iobroker instance system.adapter.iot.1 terminated due to SIGKILL
                        2024-11-03 12:38:03.676  - info: host.iobroker instance system.adapter.iot.1 terminated with code null ()
                        2024-11-03 12:38:03.676  - warn: host.iobroker instance system.adapter.openknx.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.676  - info: host.iobroker instance system.adapter.openknx.0 terminated with code null ()
                        2024-11-03 12:38:03.709  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGKILL
                        2024-11-03 12:38:03.709  - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                        2024-11-03 12:38:03.709  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
                        2024-11-03 12:38:03.749  - info: host.iobroker.compactgroup1 terminated
                        2024-11-03 12:38:03.959  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                        2024-11-03 12:38:03.959  - info: host.iobroker instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
                        2024-11-03 12:38:05.051  - info: host.iobroker compactgroup controller 1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-11-03 12:38:05.170  - info: host.iobroker All instances are stopped.
                        2024-11-03 12:38:05.369  - info: host.iobroker terminated
                        iob diag has finished.
                        Press any key for a summary
                        • T TimoWald
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          wald
                          HOME=/home/wald
                          GROUPS=wald sudo
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Total:           14G        463M         10G
                                   7778 M total memory
                                    454 M used memory
                                     84 M active memory
                                   3569 M free memory
                                      0 M buffer memory
                                   3754 M swap cache
                                   7039 M total swap
                                      8 M used swap
                                   7031 M free swap
                          *** FILESYSTEM ***
                          /var:
                          1.6G    /var/
                          1.2G    /var/log
                          348M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        34385
                          States:         27991
                          Pending Updates: 20
                          Beizeiten den Container mit Bookkworm / Debian 12 betreiben. Bullseye ist tot.
                          Setz den User 'wald' in die Gruppe 'adm' und 'iobroker' rein.
                          sudo usermod -a -G adm,iobroker wald
                          exit
                          Warum nicht?
                          Warum hantierst du da mit einer Alpha-Version von vis-2 herum?
                          Gleiche gilt für vis1:
                          Pending Updates: 20
                          System auf Stand bringen.
                          iob stop
                          sudo apt update && sudo apt full-upgrade
                          Dann Container neustarten und die stabilen Versionen von vis2 und vis1 installieren.
                            exit
                            Warum nicht?
                            Pending Updates: 20
                            iob stop
                            TimoWald
                            @thomas-braun said in Vis2 Adapter macht Probleme.:
                            Wie kann ich diesen Updaten? Und wie installiere ich die stabilen Versionen von Vis2?
                            Thomas BraunT OliverIOO 3 Antworten Letzte Antwort
                            • T TimoWald
                              Muss dir einer der Container-Kapitäne sagen.
                              • T TimoWald
                                iob update
                                iob upgrade vis@1.5.6
                                iob upgrade vis-2@2.9.64
                                  iob update
                                  TimoWald
                                  Mit diesen Befehlen ist der VIS2 schonmal grün und aktuell.
                                  Jetzt mus ich nur noch rausbekommen wie ich den Container Update.
                                  • T TimoWald
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    Wie kann ich diesen updaten?
                                    Indem du ein aktuelleres Image auswählst:
                                    https://hub.docker.com/layers/buanet/iobroker/v10.0.0/images/sha256-8261681190598bcaf5483779b1093e8d8a1a64be0d9e73c5df51287cea66b364?context=explore
                                    Meine Adapter und Widgets
                                    Links im Profil
                                    • OliverIOO OliverIO
                                      TimoWald
                                      @oliverio Sorry hier bin ich überfragt. Wo wähle ich das aus. Mein IOB läuft auf Proxmox.
                                      • T TimoWald
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        @timowald
                                        Als Docker Container oder als LXC Container oder als vm ?
                                        Links im Profil
                                          @timowald
                                          TimoWald
                                          @oliverio LXC
