  4. Test Adapter Schedule-Switcher
98 Beiträge 14 Kommentatoren 17.4k Aufrufe 19 Beobachtet
  • L Lucky_ESA
    @negalein In der Instanz Settings kann man nur neu Objekte hinzufügen aber nicht editieren. Ging bei der alten aber auch nicht. Das mit dem ? muss ich mal schauen.
    Edit: Bitte auch den Adapter aktiv lassen und nicht deaktivieren.
    Edit2: Eigentlich müsste es bei dir so aussehen:
    Gruß//Lucky
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @lucky_esa
    gerade im Log gesehn
    schedule-switcher.0 2024-10-22 23:20:48.181	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:20:24.832	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:05:12.162	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:04:46.200	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:04:45.331	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:04:36.762	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:04:33.994	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:04:31.427	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:02:48.254	error	Message service change-view-dataId not initialized
    schedule-switcher.0 2024-10-22 23:01:02.050	error	Cannot find view "system"
    schedule-switcher.0 2024-10-22 23:01:02.050	error	Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:3513:19) at async Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:3554:37)
    schedule-switcher.0 2024-10-22 23:01:02.049	error	unhandled promise rejection: Cannot find view "system"
    schedule-switcher.0 2024-10-22 23:01:02.049	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    schedule-switcher.0 2024-10-22 23:01:02.048	error	Cannot find view "system" for search "state" : Connection is closed.
    ° Fixer ---> iob fix
    L 1 Antwort Letzte Antwort
    • NegaleinN Negalein
      @lucky_esa
      L Online
      L Online
      Lucky_ESA
      @negalein Vielen Dank. change-view-dataId hatte ich vergessen. Habe es gerade auf GIT geladen.
      Welchen admin und js-contoller nutzt du und mit welchem System bist du unterwegs?
      Gruß//Lucky
        @lucky_esa sagte in Test Adapter Schedule-Switcher:
        hatte ich nur ganz kurz in der Anfangsphase. Schon zu lange aus. ;)
        Ah ok. Ich will zB 5 Geräte steuern, leg ich mir Objekte im Adapter an, schmeiß 5 Widgets in VIS und stell erst dort das zu steuernde Gerät, usw. ein?
        sowieso
        Nö, hab ja den Adapter gestartet.
        So, Widget läuft. :)
        • warum ist hier alles in Englisch? ioB ist auf Deutsch.
        • bei + für condition tut sich nichts. Oder kommen die Bedingungen nicht bei jedem Trigger?
        • kann der Name vom State (hier hue.0.Wohnzimmer.level) ausgebledet werden?
        L Online
        L Online
        Lucky_ESA
        @negalein
        sowieso
        Das darf so nicht aussehen. Wie sieht es jetzt aus?
        Kannst du in deinem Browser in die Console schauen?
        Die Bedingunegn müssen in den Einstellung vom Widget erst angelegt werden (wenn man diese benötigt)
        In den Einstellungen vom Widget unter Anzeigen des geschaltenen States
        Gruß//Lucky
        • L Lucky_ESA
          Gruß//Lucky
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Fehler ist weg.
          Admin: 7.2.6
          JS-Controller: 6.0.11
          System Ubuntu 22.04
          • L Lucky_ESA
            @negalein
            sowieso
            Gruß//Lucky
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            10.0.1.202-1729664198362.log
            Ah, ok.
            gefunden :)
            steht bei mir als showID
            • L Lucky_ESA
              @negalein
              bis wann schätzt du, gibt es die 0.0.2?
              jetzt 😀
              @sigi234 Habe diese hinzugefügt aber funktioniert noch nicht so wie ich will (siehe Anleitung - Instanz Einstellung und Beispiel Historie)
              Puh, das war aber jetzt viel Arbeit....
              EDIT:
              Achja, wer den Adapter installiert hatte muss in den Instanz Einstellungen die Anzahl der Objekte kurz hinzufügen und speichern.
              Für die Historie müssen die Trigger einmal gelöscht werden und dann wieder neu anlegen.
              Gruß//Lucky
              sigi234S Online
              sigi234S Online
              sigi234
              @lucky_esa
              Hallo, soll ich den Adapter deinstallieren oder drüber?
              Immer Daten sichern!
              • sigi234S sigi234
                @lucky_esa
                L Online
                L Online
                Lucky_ESA
                @sigi234 sagte in Test Adapter Schedule-Switcher:
                @lucky_esa
                drüber. Du musst dann nur die Trigger editieren oder neu anlegen. Nicht das Widget...
                In der Instanz Einstellung die Anzahl anlegen (+ Zeichen) wie viele Objekte du unter onoff hast.
                • L Lucky_ESA
                  @lucky_esa
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  Da kann ich nichts ändern steht schon da?
                  • sigi234S sigi234
                    L Online
                    L Online
                    Lucky_ESA
                    @sigi234 Es wäre besser beide zu löschen und dann neu anzulegen.
                    @Negalein Auf GIT funktioniert nun auch Translate bei VIS1.
                    Habe nun bei mir im Live System aktualisiert. Es waren dann alle 21 States weg. Musste die 21 neu anlegen und dann den Backup.json neu unter Objekte importiert.
                    History sollte nun funktionieren und bei Astro Trigger wird die Schaltzeit im Trigger angezeigt. Das funktioniert aber nicht zuverlässig.
                    Gruß//Lucky
                    • L Lucky_ESA
                      Gruß//Lucky
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      Danke, nun ist alles in deutsch.
                      Musste ihn zuerst löschen und dann wieder neu.
                      PS:
                      das funktioniert bei mir nicht. Muss ihn immer über benutzerdefiniert laden.
                      Bei Git scheint er auch danach nicht auf.
                      Adapter zum ersten Mal von GIT laden:
                      Danach Updates von GIT laden:
                        PS:
                        L Online
                        L Online
                        Lucky_ESA
                        @negalein Es ist eigentlich egal aber der Adapter sollte bei GIT zu sehen sein.
                        Komisch...aber egal.. Bei VIS1 muss ich nach dem Update unter Adapter bei VIS neu downloaden, sonst werden Änderungen nicht übernommen (bei dev-server).
                        Gruß//Lucky
                        • L Lucky_ESA
                          Gruß//Lucky
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Ahh, da kann ich lange nach Schedule suchen. 😂
                          Ok, ich hab nur beim Schedule-Switcher den Upload gemacht.
                            L Online
                            L Online
                            Lucky_ESA
                            @negalein
                            So sollte es auch eigentlich sein. Warum das nicht ohne download auf meinen dev-server funktioniert entzieht sich meine Kenntnis. Man muss auch nicht alles wissen.
                            Gruß//Lucky
                            • BananaJoeB Offline
                              BananaJoeB Offline
                              BananaJoe
                              Zwischenfrage:
                              Kann ich den Schedule-Switcher parallel zum time-Switcher installieren?
                              Mir geht es darum ob die beiden sich gegenseitig stören,
                              übernommen werden muss nichts / wird idealerweise nichts.
                              Ich würde dann parallel arbeiten und alles Stück für Stück umstellen
                              • BananaJoeB BananaJoe
                                Zwischenfrage:
                                L Online
                                L Online
                                Lucky_ESA
                                @bananajoe sagte in Test Adapter Schedule-Switcher:
                                Zwischenfrage:
                                Wenn du parallel aufbaust verwendest du ja die selben Zeiten. Bedeutet du Triggerst dann States doppelt womit kein Adapter umgehen kann. Wenn du andere States verwendest, ist das kein Problem.
                                Gruß//Lucky
                                • L Lucky_ESA
                                  Zwischenfrage:
                                  Gruß//Lucky
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  Zwischenfrage:
                                  Gruß//Lucky
                                  naja, ich wollte das schon bei deinen Adapter neu einrichten und dann auf dem bisherigen deaktivieren ...
                                    Zwischenfrage:
                                    Gruß//Lucky
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    @bananajoe
                                    Das wäre kein Problem
                                    • M Online
                                      M Online
                                      mane444
                                      schrieb am zuletzt editiert von mane444
                                      Bin gerade am testen und auch froh das ich auf VIS2 umsteigen kann.
                                      Mir ist aber folgendes aufgefallen.
                                      Ich habe in den Instanz Einstellungen für 8 Schaltpläne erzeugt, danach in der Vis2 das erste Widget hineingezogen und parametriert. Soweit klappt das alles super.
                                      Da ich nun etwas faul bin, wollte ich in der Vis2 Seite das Widget kopieren und dann die Schaltplandaten händisch ändern.
                                      Beim Ändern der ID kommen im log folgende Fehlermeldungen:
                                      schedule-switcher.0
                                      2024-10-29 19:33:34.515	error	Could not handle message:
                                      schedule-switcher.0
                                      2024-10-29 19:33:34.515	error	TypeError: Cannot set properties of undefined (setting 'vis-2.0') at MessageService.updateViews (/opt/iobroker/node_modules/iobroker.schedule-switcher/build/services/MessageService.js:199:35) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async MessageService.handleMessage (/opt/iobroker/node_modules/iobroker.schedule-switcher/build/services/MessageService.js:54:7) at async ScheduleSwitcher.setSendTo (/opt/iobroker/node_modules/iobroker.schedule-switcher/build/main.js:735:9)
                                      schedule-switcher.0
                                      2024-10-29 19:33:34.514	error	Requested getState schedule-switcher.0.onoff..views returned null/undefined!
                                      Die Instanz vom schedule-switcher bleibt grün, aber man kann in der VIS2 keine Änderungen mehr pflegen. Erst nach einem Neustart von der Instanz vom schedule-switcher läuft wieder alles wie es soll.
                                      Vielleicht lässt sich das ja irgendwie abfangen.
                                        darkaragon
                                        Moin,
                                        ich wollte nur kurz Danke sagen, dass es mit dem Adapter in Zukunft weiter geht. Ich benutze ihn für etliche Schaltvorgänge und die Rolladen.
                                        Hätte einen riesen Stress wenn er weg wäre.
                                        • M mane444
                                          schedule-switcher.0
                                          schedule-switcher.0
                                          schedule-switcher.0
                                          L Online
                                          L Online
                                          Lucky_ESA
                                          schrieb am zuletzt editiert von Lucky_ESA
                                          @mane444 Danke für diese Info. Werde es mir anschauen.
                                          Ist mit 0.0.3 gefixt
