  4. js-controller 6.0.x jetzt für alle User im STABLE!
    1.0k
    6.1k
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 88.2k Aufrufe 45 Beobachtet
  • fAz3rs adventuresF fAz3rs adventures
    Es passiert nichts weiter
    Es kommt eine neue eingabe Zeile in der ich Iobroker wieder starten könnte
    #81
    @faz3rs-adventures
    Gib mal die Langfassung von
    iob diag
    zum Besten.
    fAz3rs adventuresF 1 Antwort Letzte Antwort
      @faz3rs-adventures
      iob diag
      zum Besten.
      fAz3rs adventuresF Offline
      fAz3rs adventures
      #82
      ======== Start marking the full check here =========
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       00:02:36 up 81 days,  5:39,  3 users,  load average: 1.51, 2.09, 2.41
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-08-03 00:02:37 CEST
                 Universal time: Fri 2024-08-02 22:02:37 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        2.4G        746M         35M        4.7G        5.3G
      Swap:            99M          0B         99M
      Total:          7.9G        2.4G        846M
      Active iob-Instances:   27
               7812 M total memory
               2396 M used memory
               2627 M active memory
               3853 M inactive memory
                746 M free memory
                376 M buffer memory
               4293 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 00:02:37 up 81 days,  5:39,  3 users,  load average: 1.51, 2.09, 2.41
      Tasks: 219 total,   2 running, 217 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 27.0 us,  4.1 sy,  0.0 ni, 68.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7812.3 total,    746.0 free,   2396.6 used,   4669.8 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5258.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       30G   20G  8.7G  70% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/mmcblk0p1 vfat      255M   53M  203M  21% /boot
      tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
      [Mon May 13 18:23:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.                              macaddr=DC:A6:32:CB:CB:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb8f5eed-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ign                              ore-serial-consoles
      [Mon May 13 18:23:18 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon May 13 18:23:18 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon May 13 18:23:21 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      [Fri Aug  2 23:29:26 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm kworker/u8:3: bg 166: bad block bitmap checksum
      [Fri Aug  2 23:29:26 2024] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 700736 at logical offset 0 with max blocks 135 with error 74
      [Fri Aug  2 23:29:26 2024] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
      [Fri Aug  2 23:29:29 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm kworker/u8:3: bg 165: bad block bitmap checksum
      [Fri Aug  2 23:29:29 2024] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 700840 at logical offset 0 with max blocks 175 with error 74
      [Fri Aug  2 23:29:29 2024] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
      [Sat Aug  3 00:01:27 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm logrotate: bg 164: bad block bitmap checksum
      [Sat Aug  3 00:01:27 2024] EXT4-fs error (device mmcblk0p2) in ext4_mb_clear_bb:6077: Filesystem failed CRC
      Show mounted filesystems:
      TARGET                       SOURCE         FSTYPE          OPTIONS
      /                            /dev/mmcblk0p2 ext4            rw,noatime
      |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=3735680k,nr_inodes=933920,mode=755
      | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
      | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc           proc            rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
      | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
      |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      4.1G    /var/
      2.4G    /var/cache
      2.3G    /var/cache/apt/archives
      2.3G    /var/cache/apt
      1.5G    /var/log/journal/a9d90c753d4c4e98916aa8f9a3f582f2
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      126M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      951M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/serial/by-path/platform-fd500000.pcie-pci-0000
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     3
      +-- iobroker.bring@1.8.4 (git+ssh://git@github.com/foxriver76/ioBroker.bring.git#85ba3e11a521d5660aa3018d12e7e083f181ad8b)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.todoist2@0.9.1 (git+ssh://git@github.com/rde-master/ioBroker.todoist2.git#531241af9356c641158a3cb63e3bd45a1d11a8d8)
      Adapter State
        system.adapter.acme.0                   : acme                  : raspberrypi                              - disabled, port: 8092, bind: 192.168.178.60
        system.adapter.adguard.0                : adguard               : raspberrypi                              - disabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.bring.1                  : bring                 : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.iwg-vpn.0                : iwg-vpn               : raspberrypi                              - disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 8000
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 192.168.178.60
      + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
      + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled
      + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.residents.0              : residents             : raspberrypi                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.synochat.0               : synochat              : raspberrypi                              - disabled
        system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5001
        system.adapter.tapo.0                   : tapo                  : raspberrypi                              - disabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
        system.adapter.todoist2.0               : todoist2              : raspberrypi                              - disabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.welcome.0                : welcome               : raspberrypi                              - disabled, port: 80, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
        system.adapter.wiobrowser.0             : wiobrowser            : raspberrypi                              - disabled, port: 5000
      + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.yahka.1                  : yahka                 : raspberrypi                              - disabled
      + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "acme"         : 0.1.2    , installed 0.1.2
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "openknx"      : 0.9.0    , installed 0.9.0
      Adapter    "residents"    : 0.1.1    , installed 0.1.1
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "synochat"     : 1.3.1    , installed 1.3.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "welcome"      : 0.3.0    , installed 0.3.0
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        6774
      States:         5215
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:45989           0.0.0.0:*               LISTEN      1001       55153121   29571/io.yahka.2
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15381      580/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55151380   29218/node-red
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       55149882   29112/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55149877   29112/iobroker.js-c
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          55154847   30024/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15383      580/sshd: /usr/sbin
      tcp6       0      0 :::4369                 :::*                    LISTEN      0          14541      1/systemd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          55154846   30024/cupsd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55152105   29537/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       55151228   29130/io.admin.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       55152999   29556/io.ws.0
      tcp6       0      0 :::8091                 :::*                    LISTEN      1001       55150427   29499/io.lovelace.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16409      475/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          55156844   30028/cups-browsed
      udp        0      0 0.0.0.0:41644           0.0.0.0:*                           1001       55151762   29277/io.openknx.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       55152225   29593/io.esphome.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12255      370/avahi-daemon: r
      udp        0      0 0.0.0.0:35438           0.0.0.0:*                           108        12257      370/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12256      370/avahi-daemon: r
      udp6       0      0 :::36482                :::*                                108        12258      370/avahi-daemon: r
      2024-08-03 00:00:00.080  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 29931
      2024-08-03 00:00:03.501  - info: dwd.0 (29931) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.16.0, js-controller: 5.0.19
      2024-08-03 00:00:04.123  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 29947
      2024-08-03 00:00:05.493  - info: dwd.0 (29931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-03 00:00:06.041  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-08-03 00:00:08.090  - info: ical.0 (29947) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.16.0, js-controller: 5.0.19
      2024-08-03 00:00:09.385  - info: ical.0 (29947) processing URL: Gmail Privat https://calendar.google.com/calendar/ical/liersch52%40gmail.com/private-30a9b22ce901d314b7678a6a5cecd14f/basic.ics
      2024-08-03 00:00:31.904  - info: ical.0 (29947) processing URL: Gmail Geschäft https://calendar.google.com/calendar/ical/timo.liersch%40roche.com/private-1093527edc409a6928e6c06171fa8233/basic.ics
      2024-08-03 00:00:51.143  - info: ical.0 (29947) Set events.2.Geschäft to true
      2024-08-03 00:00:52.421  - info: ical.0 (29947) Set events.0.today.Geschäft to false
      2024-08-03 00:00:52.432  - info: ical.0 (29947) Set events.0.now.Geschäft to false
      2024-08-03 00:00:52.444  - info: ical.0 (29947) Set events.7.Geschäft to false
      2024-08-03 00:00:57.512  - info: ical.0 (29947) Terminated (NO_ERROR): Without reason
      2024-08-03 00:00:58.106  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      iob diag has finished.
      Press any key for a summary
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
      ^Cb diag has finished.l here for C&P =============instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)r/ical/timo.liersch%40roche.com/private-1093527edc409a6928e6c06171fa8233/basic.ics:1.0-port0n
      pi@raspberrypi:~ $
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7812 M total memory
                 2396 M used memory
                  746 M free memory
                  376 M buffer memory
                 4293 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        4.1G    /var/
        2.4G    /var/cache
        2.3G    /var/cache/apt
        USB-Devices by-id:
        HINT:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.0.22
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6774
        States:         5215
        Pending Updates: 0
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
        pi@raspberrypi:~ $
        #83
        @faz3rs-adventures sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
        Bring das beizeiten per NEUINSTALLATION auf Version 12 'Bookworm'.
        Dann auch gleich in der 64Bit-Version.
        Schalt den Desktop aus.
        sudo systemctl set-default multi-user.target
        Das Dateisystem der SD-Karte ist hin.
          fAz3rs adventures
          #84
          Das heißt eine neue SD Karte rein, mit V 12 neu Installieren und dann mein letztes Backup von IOB aufspielen?
            #85
            So kann man das machen. Vorausgesetzt, in dem Backup sind nicht bereits korrupte Dateien enthalten.
              fAz3rs adventures
              #86
              Das klingt garnich so gut.
              Ich mache zwar regelmäßig Backups aber ob das da nich auch schon fehler hat weiß ich nicht
              Dh im Worstcase müsste ich alles neu programmieren
              Noch eine Frage.
              Was hat es mit dem Display server auf sich?
              Also am RPI hab ich keinen Bildschirm
                Noch eine Frage.
                #87
                Eben...
                Du hast aber da einen Desktop laufen (und einen Druckerserver usw.), der für gar nix gut ist.
                Daher kannst du das ja bei der Neuinstallation gleich alles weg lassen.
                  Eben...
                  fAz3rs adventures
                  #88
                  Okay Vielen Dank für die Hilfe.
                  Dann werd ich die Tage eine neue SD Karte organisieren und alles neu Aufsetzen.
                  Hoffe das klappt💪
                    Hoffe das klappt💪
                    #89
                    @faz3rs-adventures
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      @faz3rs-adventures
                      fAz3rs adventures
                      #90
                      Sau stark Danke👍
                      • Joerg SchumacherJ Offline
                        Joerg Schumacher
                        schrieb am zuletzt editiert von Joerg Schumacher
                        #91
                        Hallo @all!
                        Ich habe da ein Problem beim upgrade der 6.0.7 auf die 6.0.9
                        Kann mir jemand helfen?
                        Ich komme da nicht mehr weiter.
                        Danke schonmal.
                        pi@01-schumsmarthome:/opt/iobroker $ iob upgrade self
                        Update js-controller from @6.0.7 to @6.0.9
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 10.8.2
                        Installing iobroker.js-controller@6.0.9... (System call)
                        npm error code 6
                        npm error path /opt/iobroker/node_modules/iobroker.js-controller
                        npm error command failed
                        npm error command sh -c node iobroker.js setup first
                        npm error Uncaught Rejection: TypeError: callback is not a function
                        npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/@iobroker/plugin-base/lib/PluginBas                      e.js:310:17
                        npm error This error originated either by throwing inside of an async function without a catch block, or by rejecti                      ng a promise which was not handled with .catch(). The promise rejected with the reason:
                        npm error TypeError: callback is not a function
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_09_05_083Z-debug-0.lo                      g
                        host.01-schumsmarthome Cannot install iobroker.js-controller@6.0.9: 6
                        Mod-Edit: Code bitte in Code-Tags </> setzen!
                        surfer09S 1 Antwort Letzte Antwort
                        • Joerg SchumacherJ Joerg Schumacher
                          Hallo @all!
                          Danke schonmal.
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 10.8.2
                          npm error code 6
                          surfer09S Offline
                          surfer09S Offline
                          surfer09
                          #92
                          Guten Morgen zusammen,
                          unter Windows 11 / Windows 10 hat bei mir auch alles funktioniert.
                          Gruß surfer ;-)
                          • stony2kS Offline
                            stony2kS Offline
                            stony2k
                            schrieb am zuletzt editiert von stony2k
                            #93
                            Da ich im Github des Admin Adapter und auch hier nichts dazu finde: Muss ich, um alle Updates aus dem Stable-Repo zu bekommen den Schalter auf None oder Patch stellen?
                            • stony2kS stony2k
                              #94
                              @stony2k
                              Edit: Unklare Beschreibung. Unten steht es besser erklärt.
                              • J Offline
                                Jack01
                                #95
                                Moin alle zusammen,
                                Update lief ohne Probleme durch. Zuerst alle Adapter aktualisiert, dann Node.Js hochgezogen und dann über den Update Button das Update durchgefürt. Läuft auf einem Fujitsu Primo unter Proxmox als LXC.
                                Danke an die Entwickler.
                                Hans-Jürgen
                                Proxmox LXC
                                Node.js: V22.22.2
                                NPM: 10.9.7
                                JS-controller: 7.0.7
                                  @stony2k
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #96
                                  @thomas-braun said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                  @stony2k
                                  None = Keine Updates
                                  Patch = Jede Version wird angeboten (x.y.Z)
                                  Minor = Nur neue Minor-Versionen werden angeboten (zweite Stelle in der Versionsnummer x.Y.z)
                                  Major = Nur große Versionssprünge werden angeboten (X.y.z)
                                  Da es hier um den automatischen Updates geht sollte es wohl heißen:
                                  Patch = Nur neue Patch-Versionen werden installiert (x.y.Z)
                                  Minor = Nur neue Minor- und Patch-Versionen werden installiert (zweite oder dritte Stelle in der Versionsnummer x.Y.Z)
                                  Major = Alle neuen Versionen werden installiert., auch Major Spünge (X.y.z)
                                  @Thomas-Braun
                                  Kannst du das ggF noch mal reviewen - du schreibts oben in etwa das Gegenteil :-) ?
                                  Wenn es nicht klar ist, sollte es @foxriver76 klärend erläutern.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  foxriver76F Thomas BraunT 2 Antworten Letzte Antwort
                                  • mcm1957M mcm1957
                                    @stony2k
                                    @Thomas-Braun
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    schrieb am zuletzt editiert von foxriver76
                                    #97
                                    @mcm1957 An der Stelle nochmal der Aufruf, dass man major auto Updates auf Produktivsystemen unbedingt meiden sollte, da so automatisch Änderungen rein kommen die euer System potentiell lahm legen, da Änderungen nötig sein könnten. Wenn man das wählt sollte der Admin auch eine Warnung anzeigen.
                                    Und ja die Erklärung von @mcm1957 stimmt.
                                    Videotutorials & mehr
                                    stony2kS 1 Antwort Letzte Antwort
                                    • foxriver76F foxriver76
                                      stony2kS Offline
                                      stony2kS Offline
                                      stony2k
                                      #98
                                      @foxriver76 Danke. Also noch klar ausgedrückt: Die Einstellung auf Major bedeutet, man bekommt alle Updates, auch wenn nur die Patchversion angehoben wurde? Mich verwirrt das gerade etwas :D
                                      Wenn ich vorher einfach auf Update gedrückt habe, dann wurde der Adapter ja aktualisiert. Manchmal kam eine Warnung, dass etwass geändert wurde und man vor dem Update dieses und jenes beachten muss. Das würde ich weiterhin gerne auch manuell machen. Also ist Minor die "sichere" Einstellung? Und bei allen anderen Updates bekomme ich weiterhin die Update Benachrichtigung?
                                      • stony2kS stony2k
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #99
                                        @stony2k said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                        Ja.
                                        Bei Einstellung Major werden ALLE Updates automatisch installiert. Diese Einstellung ist aber nur selten sinnvoll und auf produktiven System m.E. NIE sinnvoll da major Updates inkompatible Änderungen beinhalten (können) und der Admin ja vor der Installation solcher Updates prüfen sollte was er anpassen muss
                                        • mcm1957M mcm1957
                                          @stony2k
                                          @Thomas-Braun
                                          #100
                                          @mcm1957 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                          Öh, nein? Wenn sich Y ändert, dann auch immer Z gleich mit.
