  4. js-controller 6.0.x jetzt für alle User im STABLE!
    1.0k
    6.1k
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 88.2k Aufrufe 45 Beobachtet
  • C Offline
    Chris777
    #61
    host.iOBrocker
    	2024-08-02 18:55:41.112	error	iobroker host.iOBrocker Cannot install iobroker.backitup@latest: 1
    host.iOBrocker
    	2024-08-02 18:55:41.111	error	iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-08-02T16_55_34_985Z-debug-0.log
    Habe Version
    Plattform: docker (official image - v9.1.2)
    RAM: 11.5 GB
    Node.js: v18.20.4(20.16.0)
    NPM: 10.8.2
    • XBiTX Online
      XBiTX Online
      XBiT
      #62
      Nach dem update auf den js-controller 6.0.9 bekomme ich folgende Fehler im log zu so fast jeden Adapter:
      host.IoBroker
      2024-08-02 20:33:23.911	info	Restart adapter system.adapter.vis-inventwo.0 because enabled
      host.IoBroker
      2024-08-02 20:33:23.910	error	instance system.adapter.vis-inventwo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: Node.js v18.20.4
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis-inventwo/main.js:14:33)
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: ^
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: class visInventwo extends utils.Adapter {
      host.IoBroker
      2024-08-02 20:33:23.910	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.vis-inventwo/main.js:14
      host.IoBroker
      2024-08-02 20:33:23.725	info	instance system.adapter.upnp.0 in version "1.0.21" started with pid 8475
      host.IoBroker
      2024-08-02 20:33:23.709	info	Restart adapter system.adapter.sourceanalytix.0 because enabled
      host.IoBroker
      2024-08-02 20:33:23.709	error	instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: Node.js v18.20.4
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31:36)
      host.IoBroker
      2024-08-02 20:33:23.709	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
      host.IoBroker
      2024-08-02 20:33:23.708	error	Caught by controller[0]: ^
      host.IoBroker
      2024-08-02 20:33:23.708	error	Caught by controller[0]: class Sourceanalytix extends utils.Adapter {
      host.IoBroker
      2024-08-02 20:33:23.706	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31
      host.IoBroker
      2024-08-02 20:33:23.018	info	instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 8468
      host.IoBroker
      2024-08-02 20:33:22.942	info	instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: DrozmotiX/ioBroker.sourceanalytix#c9b9e18e1694e45ce88e21e868e38e565aad6910) started with pid 8461
      host.IoBroker
      2024-08-02 20:33:22.149	info	Restart adapter system.adapter.upnp.0 because enabled
      iob diag sagt:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: IoBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-23-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:39:02 up 23 min,  3 users,  load average: 3.61, 2.84, 2.11
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Fri 2024-08-02 20:39:02 CEST
                 Universal time: Fri 2024-08-02 18:39:02 UTC
                       RTC time: Fri 2024-08-02 18:39:02
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      stephan
      HOME=/home/stephan
      GROUPS=stephan cdrom floppy sudo audio dip video plugdev netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        4.8G         11G        524K        1.0G         11G
      Swap:           6.4G          0B        6.4G
      Total:           23G        4.8G         17G
      Active iob-Instances:   45
              15992 M total memory
               4618 M used memory
                478 M active memory
               4274 M inactive memory
              10743 M free memory
                161 M buffer memory
                799 M swap cache
               6140 M total swap
                  0 M used swap
               6140 M free swap
      top - 20:39:02 up 23 min,  3 users,  load average: 3.61, 2.84, 2.11
      Tasks: 161 total,   4 running, 157 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15992.7 total,  10742.4 free,   4619.5 used,    960.9 buff/cache
      MiB Swap:   6141.0 total,   6141.0 free,      0.0 used.  11373.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  520K  1.6G   1% /run
      /dev/sda1      ext4       34G   13G   19G  42% /
      tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Fri Aug  2 20:15:45 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Aug  2 20:15:45 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE      FSTYPE      OPTIONS
      /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
      |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12580
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=8169164k,nr_inodes=2042291,mode=755,inode64
      | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
      | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
      | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
      `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=1637652k,mode=755,inode64
        |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
        |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=1637648k,nr_inodes=409412,mode=700,uid=1000,gid=1000,inode64
        `-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
      /var:
      1.1G    /var/
      468M    /var/log
      450M    /var/log/journal/81661bec9382417183506b6886357c63
      409M    /var/cache
      Archived and active journals take up 41.3M in the file system.
      /opt/iobroker/backups:
      879M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      48M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/states.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.4
      /usr/bin/node           v18.20.4
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.4-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
       *** 18.20.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.3-1nodesource1 1001
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     11
      +-- iobroker.deyeidc@0.0.14 (git+ssh://git@github.com/raschy/ioBroker.deyeidc.git#1e9919216a6173e4089dff844edb4abb35eb2366)
      +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
      +-- iobroker.fullybrowser@3.0.12 (git+ssh://git@github.com/arteck/ioBroker.fullybrowser.git#e962587ed6e25b749b28c8537318c39f2c0deefe)
      +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#91ce6d3d470cba4011b7861103c4bfffa32dffbe)
      +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
      +-- iobroker.mercedesme@0.1.6 (git+ssh://git@github.com/TA2k/iobroker.mercedesme.git#b58e9673d5c28e358830fd45d231dd97ab425219)
      +-- iobroker.omada@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#8fb0331b97155bd4fae67c940d98c57b2ea34be2)
      +-- iobroker.sayit@3.0.5 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#581f2fb99f33c2b8b0a628d91be14967788ac120)
      +-- iobroker.sourceanalytix@0.4.12-2 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#c9b9e18e1694e45ce88e21e868e38e565aad6910)
      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.zendure-solarflow@1.7.0 (git+ssh://git@github.com/nograx/ioBroker.zendure-solarflow.git#f2c56c734ba9176aa75b36391c868a3c0fe33a60)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : IoBroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : IoBroker                                 -  enabled
      + system.adapter.deyeidc.0                : deyeidc               : IoBroker                                 -  enabled, port: 8899
      + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoBroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : IoBroker                                 -  enabled
      + system.adapter.enigma2.1                : enigma2               : IoBroker                                 -  enabled
      + system.adapter.enigma2.2                : enigma2               : IoBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
      + system.adapter.followthesun.0           : followthesun          : IoBroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
        system.adapter.google-sharedlocations.0 : google-sharedlocations: IoBroker                                 -  enabled
      + system.adapter.govee-app.0              : govee-app             : IoBroker                                 -  enabled
      + system.adapter.govee-local.0            : govee-local           : IoBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : IoBroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
      + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
        system.adapter.logparser.0              : logparser             : IoBroker                                 - disabled
      + system.adapter.lovelace.0               : lovelace              : IoBroker                                 -  enabled, port: 8091, bind: 192.168.1.251, run as: admin
        system.adapter.meater.0                 : meater                : IoBroker                                 - disabled
      + system.adapter.mercedesme.0             : mercedesme            : IoBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
      + system.adapter.omada.0                  : omada                 : IoBroker                                 -  enabled, port: 8043
      + system.adapter.onvif.0                  : onvif                 : IoBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
        system.adapter.roborock.0               : roborock              : IoBroker                                 - disabled
      + system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
      + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 2023, bind: 0.0.0.0
        system.adapter.sia.0                    : sia                   : IoBroker                                 -  enabled, port: 50001, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
      + system.adapter.sony-bravia.0            : sony-bravia           : IoBroker                                 -  enabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled, port: 3306
      + system.adapter.synochat.0               : synochat              : IoBroker                                 -  enabled
      + system.adapter.synology.0               : synology              : IoBroker                                 -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.2               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
        system.adapter.upnp.0                   : upnp                  : IoBroker                                 -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : IoBroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zendure-solarflow.0      : zendure-solarflow     : IoBroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "meater"       : 1.1.1    , installed 1.1.1
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "roborock"     : 0.6.4    , installed 0.6.4
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "sia"          : 1.0.4    , installed 1.0.4
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "synochat"     : 1.3.1    , installed 1.3.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "zendure-solarflow": 1.6.7, installed 1.7.0
      Objects and States
      Objects:        39665
      States:         34253
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:2023            0.0.0.0:*               LISTEN      1001       50826      6428/io.shelly.1
      tcp        0      0 192.168.1.251:42001     0.0.0.0:*               LISTEN      1001       49127      6181/io.hm-rpc.0
      tcp        0      0 192.168.1.251:42010     0.0.0.0:*               LISTEN      1001       49781      6210/io.hm-rpc.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14944      470/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          580        1/init
      tcp        0      0 192.168.1.251:8701      0.0.0.0:*               LISTEN      1001       49844      6240/io.hm-rpc.3
      tcp        0      0 192.168.1.251:49292     0.0.0.0:*               LISTEN      1001       49815      6225/io.hm-rpc.2
      tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          841        454/node
      tcp        0      0 192.168.1.251:8091      0.0.0.0:*               LISTEN      1001       52164      6930/io.lovelace.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50203      5950/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48035      5950/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14946      470/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14335      1/init
      tcp6       0      0 :::3500                 :::*                    LISTEN      0          843        454/node
      tcp6       0      0 :::3501                 :::*                    LISTEN      1001       49964      6328/io.sonos.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       56808      7478/io.fullybrowse
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       54993      7174/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50231      5968/io.admin.0
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       55243      7295/io.onvif.0
      udp        0      0 192.168.1.251:5353      0.0.0.0:*                           1001       50102      6375/io.tr-064.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          581        1/init
      udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       58098      7557/io.govee-local
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       52279      6270/io.mihome-vacu
      udp6       0      0 :::111                  :::*                                0          12022      1/init
      2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
      2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]: Node.js v18.20.4
      2024-08-02 20:39:33.951  - error: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-08-02 20:39:33.951  - info: host.IoBroker Restart adapter system.adapter.sourceanalytix.0 because enabled
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.upnp/main.js:88
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     adapter = new utils.Adapter(options);
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:               ^
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: TypeError: utils.Adapter is not a constructor
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at startAdapter (/opt/iobroker/node_modules/iobroker.upnp/main.js:88:15)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.upnp/main.js:1931:5)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
      2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: Node.js v18.20.4
      2024-08-02 20:39:34.096  - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-08-02 20:39:34.096  - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
      2024-08-02 20:39:35.857  - info: host.IoBroker instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: DrozmotiX/ioBroker.sourceanalytix#c9b9e18e1694e45ce88e21e868e38e565aad6910) started with pid 12932
      2024-08-02 20:39:35.916  - info: host.IoBroker instance system.adapter.upnp.0 in version "1.0.21" started with pid 12939
      kann mir da wer helfen?
      mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
      • XBiTX XBiT
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        iob diag sagt:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        stephan
        HOME=/home/stephan
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           6.4G          0B        6.4G
        Total:           23G        4.8G         17G
                 4618 M used memory
                  478 M active memory
                10743 M free memory
                  161 M buffer memory
                  799 M swap cache
                 6140 M total swap
                    0 M used swap
                 6140 M free swap
        *** FILESYSTEM ***
        /var:
        1.1G    /var/
        468M    /var/log
        409M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.0.22
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        39665
        States:         34253
        Pending Updates: 0
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #63
        @xbit said in js-controller 6.0.x jetzt für alle User im STABLE!:
        instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: ...
        Dieser GitHub Stand wird wohl veraltet sein. Von Github Installationen wir generell abgeraten. Kontaktiere den Dev bzw. installiere eine neuere Version.
        Hast du nur 2 Adapter?
        Ich seh nur sourceanaytix und vis-inventwo. Wobei vis-inventwo ein veraltetes adapter-core benutzt; dieses Problem sollte aber seit Wochen behoben sein. Bei Github Installationen kann es divereste Gründe geben dass diese nicht funktionieren - hier bitte mit dem Dev Kontaktaufnehmen wenn er die Github Installation empfohlen hat oder selbst suchen ...
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • XBiTX XBiT
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          host.IoBroker
          iob diag sagt:
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 8
                        NTP service: active
                    RTC in local TZ: no
          stephan
          HOME=/home/stephan
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           6.4G          0B        6.4G
          Total:           23G        4.8G         17G
                   4618 M used memory
                    478 M active memory
                  10743 M free memory
                    161 M buffer memory
                    799 M swap cache
                   6140 M total swap
                      0 M used swap
                   6140 M free swap
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          468M    /var/log
          409M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.0.22
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        39665
          States:         34253
          Pending Updates: 0
          #64
          @xbit
          iob nodejs-update 20
          XBiTX 1 Antwort Letzte Antwort
            @xbit
            XBiTX Online
            XBiTX Online
            XBiT
            schrieb am zuletzt editiert von XBiT
            #65
            Danke mache ich gerade..
            @mcm1957
            die Adapter die es betrifft sind: (fast alle war sehr übertrieben sorry)
            google-sharelocation
            Sia09
            UPNP
            Sourceanalytix
            bei den oberen 2 gibt es kein update werde ich mal nachfragen... Sourceanalytix mache ich gleich ein update
            Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
            • XBiTX XBiT
              @mcm1957
              Sia09
              UPNP
              Sourceanalytix
              #66
              @xbit
              Das solltest du auf ein Maß zurückstutzen, das du auch noch überblicken kannst:
                @xbit
                XBiTX Online
                XBiTX Online
                XBiT
                #67
                @thomas-braun & @mcm1957
                Vielen Dank es läuft soweit wieder alles.
                Die anderen Adapter (UPNP,SIA09 etc.) gehen nun auch wieder warum auch immer ist mir leider erst nach dem update von Sourceanalytix aufgefallen habe aber nur dieses update gemacht und das nodejs update auf V20
                • XBiTX XBiT
                  #68
                  @xbit
                  Du solltest das Vehikel dennoch möglichst konsistent halten und sowenig github-Zeuch wie möglich verwenden.
                  • XBiTX XBiT
                    @mcm1957
                    Sia09
                    UPNP
                    Sourceanalytix
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #69
                    Nehme an du meinst google-sharedlocation
                    Ich kann diesen Adapter nicht in den ioBroker rpositories finden. Er scheint auch schon lange nicht mehr gewartet worden zu sein. Prinzipiell ist es immer ein Risiko Adapter zu verwenden die nicht im Repository gelistet sind da diese weder den minimalen Review durchlaufen haben noch bei div. Checks wie z.B. einem Update des js-controllers beachtet werden können.
                    Sia09
                    Den Adapter find ich nicht. meinst du https://github.com/schmupu/ioBroker.sia
                    Der scheint eher dahin zu dämmern. Erstell bitte ggF im Adapterverzeichnis ein Issue und mention mich. Der Adaptercode ist dort total veraltet. Eine Codeanpassung könnte hier notwendig sein.
                    UPNP
                    Hier rate ich dir den dev zu kontaktieren bzw. ein Issue beim Adapter anzulegen. Da wurden erst letzte Woche Anpassungen vorgenommen die anscheinend noch nicht auf npm verfügbar sind. Repo: (https://github.com/Jey-Cee/ioBroker.upnp)
                    Sourceanalytix
                    Hier aktualisisere mal auf die aktuelle LATEST version. Falls diese nicht funktioniert erstell ein Issue im Adapter Repo.
                    • XBiTX XBiT
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #70
                      OK, dann feier mal schön :-)
                      An sich sollte der js-controller implizit versuchen veraltete Adapter zu aktualisiseren. Scheinbar hat das bei deinem Upgrade nicht gleich gezogen.
                      Trotzdem sei dir bewußt dass wenn du Aapter verwendest die nicht im repository gelistet sind du ein erhöhtes Risiko hast, dass diese ausfallen bzw. dass niemand sich der Sache annehmen kann / wird.
                      • mcm1957M mcm1957
                        XBiTX Online
                        XBiTX Online
                        XBiT
                        #71
                        @mcm1957
                        der google-sharedlocations Adapter wurde zuletzt von @Garfonso betreut welcher auch die Lovelace UI betreut warum die nicht ins rpositorie kommen oder sind kann ich nicht sagen bin ja nur Anwender :-)
                        der SIA Adapter ist wirklich schon 5 Jahre alt versuche mal ein Issu auf Git zu machen aber was soll ich da schreiben er läuft ja jetzt wieder?
                        Sourceanalytix von @Dutchman betreut aber soll ja komplett neu gemacht werden so meine letzte Info...
                        • L Offline
                          lamo1966
                          schrieb am zuletzt editiert von lamo1966
                          #72
                          ich hab gerade den JS Controller von5.019 auf 6.09 upgedatet.
                          Zufällig stell ich gerade fest, dass in meinen Modbus Objekten hinten das Zahnrad nicht mehr aktiv ist. (
                          Ganz rechts)
                          b4fe00a5-5428-498a-a78c-a669165c0dff-image.png Sorry, kann es nicht besser beschreiben
                          Beispiel
                          Ich erzeuge seit Tagen ein EChart mit den Spannungs-Werten der PV-Strings. Dazu hab ich die Werte in die Histroy geschrieben.
                          Unter dem Chart sind die History-Einträge schön zu sehen, die es jetzt nicht mehr gibt
                          Ich hoffe dass es zufällig ein anderer Fehler ist, aber ich hab nichts anderes gemacht. Nein stimmt nicht, die Admin Instanz hab ich auch noch upgedatet.
                          • L lamo1966
                            Ganz rechts)
                            Beispiel
                            crunchipC Offline
                            crunchipC Offline
                            #73
                            @lamo1966 werden die Datenpunkte gelistet, wenn du history auswählst
                            L 2 Antworten Letzte Antwort
                            • foxriver76F foxriver76
                              Hallo ioBroker-Community,
                              Ab heute wird der js-controller v6 im stable Repository verfügbar sein.
                              Vorab Danke an alle fleißigen Alpha und Beta Tester.
                              Node.js Versions-Anforderungen
                              In diesem Release entfällt Node.js 14.x und 16.x. Die unterstützten Node.js Versionen sind: 18.x, 20.x und voraussichtlich 22.x. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 20.x angehoben.
                              Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
                              Informationen zur Version
                              In dieser Version wurde die Umstellung des Quellcodes auf TypeScript nochmal vorangetrieben (5.X 76%, mit 6.X 90% der Codebase), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können.
                              Ebenfalls läuft der Controller nun komplett als ESM Modul, was uns technisch alle Möglichkeiten offen hält und auch Adapter nun komplett als ESM Module laufen können und somit keine Einschränkungen mehr haben falls Dependencies nur für ESM verfügbar sind.
                              Weiterhin sind auch einige neue Features unter anderem die Möglichkeit des automatisierten Adapter-Upgrades (Admin Funktionalität wird zeitnah implementiert), Informationen über das System Management (neue Pakete, restart nötig, ...) sowie das Management von geblockten Adapter-Versionen hinzugefügt.
                              Auch wenn mit dieser Version keine neuen relevanten Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
                              Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                              Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
                              Darüber hinaus ist der js-controller 6.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der Version 5.x ist problemlos möglich.
                              Ansonsten empfehlen wir ein schrittweises Update auf die 6.0 (3.3.x -> 4.0 -> 5.0).
                              Installation
                              VOR der Installation
                              Wie bei jedem Upgrade dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
                              Eine alte 5.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Letzter Stable Stand ist die 5.0.19)
                              Nötige Adapter-Aktualisierungen
                              Am besten VOR dem js-controller Update alle verfügbaren Adapter-Updates (vorallem den javascript Adapter) prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 5.0 oder höher hinweisen.
                              Mit den stable Versionen der jeweiligen Adapter sollten keine Probleme auftreten, falls doch bitte hier melden.
                              Achtung: MASTER/SLAVE-Systeme Reihenfolgen beachten!
                              Bei einem Multi-Host-System, welches auf js-controller 5.0.x läuft, ist es beim Update auf Version 6.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                              Bei Updates von Master/Slave-Systemen mit js-controller 4.x oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
                              Windows
                              Es wird empfohlen einmalig bei bestehenden Installationen den fixer auszuführen und falls noch vorhanden die iobroker.bat zu löschen.
                              Hierzu werden folgende Befehle genutzt:
                              del iobroker.bat
                              iob fix
                              Anschließend vorzugsweise das Upgrade mit dem Installer durchführen siehe https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
                              Alternativ im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
                              Linux
                              Entweder den GUI installationsprozess im Admin nutzen oder
                              • ioBroker stoppen (iobroker stop)
                              • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                              • cd /opt/iobroker
                              • Das Update erfolgt via iob upgrade self
                              • ioBroker starten (iobroker start)
                              Bei Fehlern:
                              Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                              Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels iob upgrade self versuchen. Bitte berichtet solche Fälle hier im Thread.
                              NACH der Installation
                              Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                              Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                              Was hat sich geändert, was besonders ansehen/beachten?
                              Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                              • generell siehe Changelog, speziell auch für die Features
                              • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript und ESM Umstellungen haben sehr viel Code angefasst.
                              Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                              Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                              6.0.1 Release Kiera
                              Breaking changes
                              • Support for Node.js 16 is dropped!
                              • Binary states have been removed
                              • Let's encrypt has been removed
                              Features
                              • (foxriver76) Added possibility to automatically upgrade adapters (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#automatic-adapter-upgrade)
                              • (foxriver76) if updates for OS packages are available a notification is generated (Linux only)
                              • (foxriver76) the controller creates a notification if free disk space is critical (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#disk-space-warnings)
                              • (foxriver76) allow to ignore specific adapter versions (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#ignoring-specific-adapter-version)
                              • (foxriver76) if an adapter is blocklisted and thus stopped the controller now generates a notification
                              • (foxriver76) allow to configure redis tls during setup custom
                              Optimizations and fixes
                              • (foxriver76) we now send SIGKILL instead of SIGTERM if adapter does not stop in normal time to prevent ghost processes
                              • (foxriver76) prevent crash case if an invalid pattern is scanned in the database
                              • (foxriver76) we now log the pid if a adapter process is stopped
                              • (foxriver76/Apollon77) fixed crash case on file rotation
                              • (foxriver76) optimized error messages and help text for cli commands url and install
                              • (foxriver76) if users want to install non existing adapters we now hint to the url command instead of recommending the use of npm
                              • (foxriver76) when interacting with aliases we no longer check permissions of the alias and the original object, we now only check the alias
                              • (foxriver76) host object is now already created during setup first run, allowing eg to disable sentry globally before first start of ioBroker
                              • (foxriver76) if the user sets a custom title for instances this is now preserved during upload
                              • (foxriver76) on reinstallation of adapters we uninstall the package manually first to ensure a correct reinstall
                              • (foxriver76) fixed problem on multihost discover
                              • (foxriver76) if getState is called on a non existing or non linked alias we return null like for all other non existing states
                              • (foxriver76) optimize alias subscribe performance for non-redis dbs
                              • (foxriver76/bluefox/Apollon77) updated dependencies
                              • (foxriver76/bluefox/Apollon77) minor fixes and stability improvements
                              Developer relevant DEPRECATIONS/WARNINGS
                              • (foxriver76) adapters need to specify adapter-core version 3.1.4 or higher or allow an upgrade to this version by specifying e.g. ^3.x.x
                              • (foxriver76) it is now validated that obj.native is of type Record<string, unknown>
                              • (foxriver76) Let's encrypt has been removed (@iobroker/webeserver should be used instead)
                              • (foxriver76) deprecated delete/createState/channel/device methods
                              • (foxriver76) deprecated ioPack common.license which is replaced by the new object common.licenseInfo
                              • (foxriver76) ioPack mode subscribe has been removed as you can achieve the same with mode once and setting system.adapter.xy.alive state (also removed common.wakeup and common.subscribe because of this)
                              Developer relevant new features
                              • (foxriver76) js-controller (and thus the whole ioBroker) is now running as an ESM module internally while staying a 100 % backward compatible to adapters written in cjs
                              • (foxriver76) adapters can now be written as ESM modules having full support (including compact mode)
                              • (foxriver76) we provide all exports as ESM and as CJS to allow adapter developers to choose what to use
                              • (foxriver76) added convenient methods to manage node modules (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#managing-node-modules)
                              • (foxriver76) allow to specify reason and exit code on adapter.stop
                              • (foxriver76) if you blocklist a version in your io-package.json the controller won't start it anymore and will generate a notification
                              • (foxriver76) for adapters of type schedule and connectionType set to cloud the schedule will be automatically delayed by up to 60 seconds randomly per user if the CRON does not contain a seconds argument, this is to prevent DDoS attacks
                              Developer relevant optimizations and fixes
                              • (foxriver76) fixed crash case if an malformed object was defined in ioPack instanceObjects
                              • (foxriver76) if getState is called on a non-existing or non-linked alias we return null like for all other non-existing states
                              • (foxriver76/bluefox) multiple improvements on type level
                              Wir wünschen allen viel Spaß mit dem neuen Controller!
                              Moritz
                              fAz3rs adventuresF Offline
                              fAz3rs adventures
                              #74
                              @foxriver76
                              Servus,
                              Ich wollte meinen IoBroker wieder auf neuesten Stand bringen und scheitere aber an dem js-controller Update.
                              Node.js und NPM updaten klappt, ebenso wie alle Adapter Updates.
                              Liegt auch alles (aus meiner Sicht) korrekt ab
                              nodejs liegt in /usr/bin
                              node liegt in /usr/bin
                              npm liegt in /usr/bin
                              führe ich das Update über die iob Oberfläche in Hosts aus bekomme ich folgende Rückmeldung:
                              36 verbose stack     at callLimit (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:35:69)
                              537 verbose pkgid iobroker.js-controller@6.0.9
                              538 error code 1
                              539 error path /opt/iobroker/node_modules/iobroker.js-controller
                              540 error command failed
                              541 error command sh -c node iobroker.js setup first
                              542 error file:///opt/iobroker/node_modules/axios/lib/helpers/parseHeaders.js:1
                              542 error   },
                              542 error   ^
                              542 error
                              542 error SyntaxError: Unexpected token '}'
                              542 error     at ModuleLoader.moduleStrategy (node:internal/modules/esm/translators:169:18)
                              542 error     at callTranslator (node:internal/modules/esm/loader:272:14)
                              542 error     at ModuleLoader.moduleProvider (node:internal/modules/esm/loader:278:30)
                              542 error
                              542 error Node.js v20.16.0
                              543 silly unfinished npm timer reify 1722633029717
                              544 silly unfinished npm timer reify:build 1722633047822
                              545 silly unfinished npm timer build 1722633047827
                              546 silly unfinished npm timer build:deps 1722633047827
                              547 silly unfinished npm timer build:run:install 1722633049025
                              548 silly unfinished npm timer build:run:install:node_modules/iobroker.js-controller 1722633049025
                              549 verbose cwd /opt/iobroker
                              550 verbose os Linux 6.1.21-v8+
                              551 verbose node v20.16.0
                              552 verbose npm  v10.8.1
                              553 verbose exit 1
                              554 verbose code 1
                              Auch über
                              iobroker stop
                              iobroker update
                              iobroker fix bzw ( - curl -sLf https://iobroker.net/install.sh | bash -)
                              iobroker upgrade self
                              iobroker start
                              erfolglos
                              Dann habe ich es über npm install iobroker.js-controller@6.0.9 versucht mit folgendem Ergebnis
                              1236 error code EACCES
                              1237 error syscall open
                              1238 error path /home/pi/package.json
                              1239 error errno -13
                              1240 error Error: EACCES: permission denied, open '/home/pi/package.json'
                              1240 error     at async open (node:internal/fs/promises:639:25)
                              1240 error     at async writeFile (node:internal/fs/promises:1219:14)
                              1240 error     at async PackageJson.save (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:255:14)
                              1240 error     at async [saveIdealTree] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1512:9)
                              1240 error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:148:5)
                              1240 error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
                              1240 error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
                              1240 error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
                              1240 error   errno: -13,
                              1240 error   code: 'EACCES',
                              1240 error   syscall: 'open',
                              1240 error   path: '/home/pi/package.json'
                              1240 error }
                              1241 error
                              1241 error The operation was rejected by your operating system.
                              1241 error It is likely you do not have the permissions to access this file as the current user
                              1241 error
                              1241 error If you believe this might be a permissions issue, please double-check the
                              1241 error permissions of the file and its containing directories, or try running
                              1241 error the command again as root/Administrator.
                              1242 silly unfinished npm timer reify 1722634042338
                              1243 silly unfinished npm timer reify:save 1722634104770
                              1244 verbose cwd /home/pi
                              1245 verbose os Linux 6.1.21-v8+
                              1246 verbose node v20.16.0
                              1247 verbose npm  v10.8.1
                              Das ist wohl ein anderer Pfad der entweder korrekt oder falsch ist (jaaa es ist nur gefährliches Halbwissen am start.. ich lerne beim tun)
                              Kann mir jemand für dumme sagen was mein Fehler ist?
                              Grüßle Timo
                              • fAz3rs adventuresF fAz3rs adventures
                                @foxriver76
                                Servus,
                                538 error code 1
                                542 error   },
                                542 error   ^
                                542 error
                                542 error
                                553 verbose exit 1
                                554 verbose code 1
                                Auch über
                                iobroker stop
                                iobroker update
                                iobroker start
                                erfolglos
                                1240 error }
                                1241 error
                                1241 error
                                Grüßle Timo
                                #75
                                @faz3rs-adventures sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                Du stehst für solche Aktionen via npm im falschen Verzeichnis.
                                Versuch es erstmal so:
                                iob update
                                iob stop
                                iob upgrade all -y
                                iob upgrade self
                                iob start
                                fAz3rs adventuresF 1 Antwort Letzte Antwort
                                  iob update
                                  iob stop
                                  iob upgrade all -y
                                  iob upgrade self
                                  iob start
                                  fAz3rs adventures
                                  #76
                                  Moinmoin
                                  danke schonmal für die Antwort
                                  nach dem
                                  iob upgrade all -y
                                  kommt All adapters are up to date
                                  beim
                                  iob upgrade self
                                  passiert folgendes
                                  Update js-controller from @5.0.19 to @6.0.9
                                  Stopped Objects DB
                                  Stopped States DB
                                  NPM version: 10.8.1
                                  Installing iobroker.js-controller@6.0.9... (System call)
                                  es läuft jedoch nicht fertig durch
                                    Moinmoin
                                    nach dem
                                    iob upgrade all -y
                                    beim
                                    iob upgrade self
                                    passiert folgendes
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 10.8.1
                                    #77
                                    @faz3rs-adventures
                                    Bitte immer vollständige Ein- wie Ausgabezeilen posten.
                                    Damit man sowas wie 'falsches Verzeichnis' auch sieht.
                                    Keine Screenshots!
                                      @faz3rs-adventures
                                      Keine Screenshots!
                                      fAz3rs adventures
                                      #78
                                      pi@raspberrypi:~ $ iob update
                                      Adapter    "acme"         : 0.1.2    , installed 0.1.2
                                      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                      Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "email"        : 1.3.1    , installed 1.3.1
                                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                      Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
                                      Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
                                      Adapter    "material"     : 1.3.1    , installed 1.3.1
                                      Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
                                      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                                      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                      Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                      Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                                      Adapter    "residents"    : 0.1.1    , installed 0.1.1
                                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "welcome"      : 0.3.0    , installed 0.3.0
                                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                                      pi@raspberrypi:~ $ iob stop
                                      pi@raspberrypi:~ $ iob upgrade all -y
                                      pi@raspberrypi:~ $ iob upgrade self
                                      Stopped Objects DB
                                      Stopped States DB
                                      NPM version: 10.8.1
                                      pi@raspberrypi:~ $
                                      das steht in der console
                                        Moinmoin
                                        nach dem
                                        iob upgrade all -y
                                        beim
                                        iob upgrade self
                                        passiert folgendes
                                        Stopped Objects DB
                                        Stopped States DB
                                        NPM version: 10.8.1
                                        #79
                                        @faz3rs-adventures
                                        Sondern?
                                          @faz3rs-adventures
                                          Sondern?
                                          fAz3rs adventures
                                          #80
                                          Es passiert nichts weiter
                                          Es kommt eine neue eingabe Zeile in der ich Iobroker wieder starten könnte
                                          Thomas BraunT E 2 Antworten Letzte Antwort
