  4. js-controller 6.0.x jetzt für alle User im STABLE!
    apollon77A
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 95.6k Aufrufe 45 Beobachtet
    @faz3rs-adventures
    Gib mal die Langfassung von
    iob diag
    zum Besten.
    fAz3rs adventuresF
    fAz3rs adventuresF
    fAz3rs adventures
    #82
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     00:02:36 up 81 days,  5:39,  3 users,  load average: 1.51, 2.09, 2.41
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-08-03 00:02:37 CEST
               Universal time: Fri 2024-08-02 22:02:37 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        2.4G        746M         35M        4.7G        5.3G
    Swap:            99M          0B         99M
    Total:          7.9G        2.4G        846M
    Active iob-Instances:   27
             7812 M total memory
             2396 M used memory
             2627 M active memory
             3853 M inactive memory
              746 M free memory
              376 M buffer memory
             4293 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 00:02:37 up 81 days,  5:39,  3 users,  load average: 1.51, 2.09, 2.41
    Tasks: 219 total,   2 running, 217 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 27.0 us,  4.1 sy,  0.0 ni, 68.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7812.3 total,    746.0 free,   2396.6 used,   4669.8 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5258.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       30G   20G  8.7G  70% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   53M  203M  21% /boot
    tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
    [Mon May 13 18:23:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.                              macaddr=DC:A6:32:CB:CB:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb8f5eed-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ign                              ore-serial-consoles
    [Mon May 13 18:23:18 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon May 13 18:23:18 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon May 13 18:23:21 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [Fri Aug  2 23:29:26 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm kworker/u8:3: bg 166: bad block bitmap checksum
    [Fri Aug  2 23:29:26 2024] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 700736 at logical offset 0 with max blocks 135 with error 74
    [Fri Aug  2 23:29:26 2024] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
    [Fri Aug  2 23:29:29 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm kworker/u8:3: bg 165: bad block bitmap checksum
    [Fri Aug  2 23:29:29 2024] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 700840 at logical offset 0 with max blocks 175 with error 74
    [Fri Aug  2 23:29:29 2024] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
    [Sat Aug  3 00:01:27 2024] EXT4-fs error (device mmcblk0p2): ext4_validate_block_bitmap:390: comm logrotate: bg 164: bad block bitmap checksum
    [Sat Aug  3 00:01:27 2024] EXT4-fs error (device mmcblk0p2) in ext4_mb_clear_bb:6077: Filesystem failed CRC
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE          OPTIONS
    /                            /dev/mmcblk0p2 ext4            rw,noatime
    |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=3735680k,nr_inodes=933920,mode=755
    | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
    | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc           proc            rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
    | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
    |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.1G    /var/
    2.4G    /var/cache
    2.3G    /var/cache/apt/archives
    2.3G    /var/cache/apt
    1.5G    /var/log/journal/a9d90c753d4c4e98916aa8f9a3f582f2
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    126M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    951M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/serial/by-path/platform-fd500000.pcie-pci-0000
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     3
    +-- iobroker.bring@1.8.4 (git+ssh://git@github.com/foxriver76/ioBroker.bring.git#85ba3e11a521d5660aa3018d12e7e083f181ad8b)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.todoist2@0.9.1 (git+ssh://git@github.com/rde-master/ioBroker.todoist2.git#531241af9356c641158a3cb63e3bd45a1d11a8d8)
    Adapter State
      system.adapter.acme.0                   : acme                  : raspberrypi                              - disabled, port: 8092, bind: 192.168.178.60
      system.adapter.adguard.0                : adguard               : raspberrypi                              - disabled
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
    + system.adapter.bring.1                  : bring                 : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.iwg-vpn.0                : iwg-vpn               : raspberrypi                              - disabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 8000
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 192.168.178.60
    + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
    + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled
    + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.residents.0              : residents             : raspberrypi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.synochat.0               : synochat              : raspberrypi                              - disabled
      system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5001
      system.adapter.tapo.0                   : tapo                  : raspberrypi                              - disabled
      system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
      system.adapter.todoist2.0               : todoist2              : raspberrypi                              - disabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.welcome.0                : welcome               : raspberrypi                              - disabled, port: 80, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      system.adapter.wiobrowser.0             : wiobrowser            : raspberrypi                              - disabled, port: 5000
    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.yahka.1                  : yahka                 : raspberrypi                              - disabled
    + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "acme"         : 0.1.2    , installed 0.1.2
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "openknx"      : 0.9.0    , installed 0.9.0
    Adapter    "residents"    : 0.1.1    , installed 0.1.1
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "synochat"     : 1.3.1    , installed 1.3.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 3.3.2    , installed 3.3.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "welcome"      : 0.3.0    , installed 0.3.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
    Objects and States
    Objects:        6774
    States:         5215
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:45989           0.0.0.0:*               LISTEN      1001       55153121   29571/io.yahka.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15381      580/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55151380   29218/node-red
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       55149882   29112/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55149877   29112/iobroker.js-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          55154847   30024/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15383      580/sshd: /usr/sbin
    tcp6       0      0 :::4369                 :::*                    LISTEN      0          14541      1/systemd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          55154846   30024/cupsd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55152105   29537/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       55151228   29130/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       55152999   29556/io.ws.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       55150427   29499/io.lovelace.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16409      475/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          55156844   30028/cups-browsed
    udp        0      0 0.0.0.0:41644           0.0.0.0:*                           1001       55151762   29277/io.openknx.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       55152225   29593/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12255      370/avahi-daemon: r
    udp        0      0 0.0.0.0:35438           0.0.0.0:*                           108        12257      370/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12256      370/avahi-daemon: r
    udp6       0      0 :::36482                :::*                                108        12258      370/avahi-daemon: r
    2024-08-03 00:00:00.080  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 29931
    2024-08-03 00:00:03.501  - info: dwd.0 (29931) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.16.0, js-controller: 5.0.19
    2024-08-03 00:00:04.123  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 29947
    2024-08-03 00:00:05.493  - info: dwd.0 (29931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-08-03 00:00:06.041  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-08-03 00:00:08.090  - info: ical.0 (29947) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.16.0, js-controller: 5.0.19
    2024-08-03 00:00:09.385  - info: ical.0 (29947) processing URL: Gmail Privat https://calendar.google.com/calendar/ical/liersch52%40gmail.com/private-30a9b22ce901d314b7678a6a5cecd14f/basic.ics
    2024-08-03 00:00:31.904  - info: ical.0 (29947) processing URL: Gmail Geschäft https://calendar.google.com/calendar/ical/timo.liersch%40roche.com/private-1093527edc409a6928e6c06171fa8233/basic.ics
    2024-08-03 00:00:51.143  - info: ical.0 (29947) Set events.2.Geschäft to true
    2024-08-03 00:00:52.421  - info: ical.0 (29947) Set events.0.today.Geschäft to false
    2024-08-03 00:00:52.432  - info: ical.0 (29947) Set events.0.now.Geschäft to false
    2024-08-03 00:00:52.444  - info: ical.0 (29947) Set events.7.Geschäft to false
    2024-08-03 00:00:57.512  - info: ical.0 (29947) Terminated (NO_ERROR): Without reason
    2024-08-03 00:00:58.106  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    Press any key for a summary
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    Skript v.2024-05-22
    *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
    Docker          : false
    Kernel          : aarch64
    Userland        : 32 bit
    CPU threads: 4
    Current issues:
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    pi
    HOME=/home/pi
    iobroker
    HOME=/home/iobroker
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Swap:            99M          0B         99M
    ^Cb diag has finished.l here for C&P =============instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)r/ical/timo.liersch%40roche.com/private-1093527edc409a6928e6c06171fa8233/basic.ics:1.0-port0n
    pi@raspberrypi:~ $
    • fAz3rs adventuresF fAz3rs adventures
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
               2396 M used memory
                746 M free memory
                376 M buffer memory
               4293 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      4.1G    /var/
      2.4G    /var/cache
      2.3G    /var/cache/apt
      USB-Devices by-id:
      HINT:
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.22
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6774
      States:         5215
      Pending Updates: 0
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
      pi@raspberrypi:~ $
      Thomas BraunT
      Thomas BraunT
      #83
      @faz3rs-adventures sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
      Bring das beizeiten per NEUINSTALLATION auf Version 12 'Bookworm'.
      Dann auch gleich in der 64Bit-Version.
      Schalt den Desktop aus.
      sudo systemctl set-default multi-user.target
      Das Dateisystem der SD-Karte ist hin.
      fAz3rs adventuresF 1 Antwort Letzte Antwort
        fAz3rs adventuresF
        fAz3rs adventuresF
        fAz3rs adventures
        #84
        Das heißt eine neue SD Karte rein, mit V 12 neu Installieren und dann mein letztes Backup von IOB aufspielen?
          Thomas BraunT
          Thomas BraunT
          #85
          So kann man das machen. Vorausgesetzt, in dem Backup sind nicht bereits korrupte Dateien enthalten.
            fAz3rs adventuresF
            fAz3rs adventuresF
            fAz3rs adventures
            #86
            Das klingt garnich so gut.
            Ich mache zwar regelmäßig Backups aber ob das da nich auch schon fehler hat weiß ich nicht
            Dh im Worstcase müsste ich alles neu programmieren
            Noch eine Frage.
            Was hat es mit dem Display server auf sich?
            Also am RPI hab ich keinen Bildschirm
              Noch eine Frage.
              Thomas BraunT
              Thomas BraunT
              #87
              Eben...
              Du hast aber da einen Desktop laufen (und einen Druckerserver usw.), der für gar nix gut ist.
              Daher kannst du das ja bei der Neuinstallation gleich alles weg lassen.
                Eben...
                fAz3rs adventuresF
                fAz3rs adventuresF
                fAz3rs adventures
                #88
                Okay Vielen Dank für die Hilfe.
                Dann werd ich die Tage eine neue SD Karte organisieren und alles neu Aufsetzen.
                Hoffe das klappt💪
                  Hoffe das klappt💪
                  Thomas BraunT
                  Thomas BraunT
                  #89
                  @faz3rs-adventures
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    @faz3rs-adventures
                    fAz3rs adventuresF
                    fAz3rs adventuresF
                    fAz3rs adventures
                    #90
                    Sau stark Danke👍
                    • Joerg SchumacherJ
                      Joerg SchumacherJ
                      Joerg Schumacher
                      schrieb am zuletzt editiert von Joerg Schumacher
                      #91
                      Hallo @all!
                      Ich habe da ein Problem beim upgrade der 6.0.7 auf die 6.0.9
                      Kann mir jemand helfen?
                      Ich komme da nicht mehr weiter.
                      Danke schonmal.
                      pi@01-schumsmarthome:/opt/iobroker $ iob upgrade self
                      Update js-controller from @6.0.7 to @6.0.9
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.8.2
                      Installing iobroker.js-controller@6.0.9... (System call)
                      npm error code 6
                      npm error path /opt/iobroker/node_modules/iobroker.js-controller
                      npm error command failed
                      npm error command sh -c node iobroker.js setup first
                      npm error Uncaught Rejection: TypeError: callback is not a function
                      npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/@iobroker/plugin-base/lib/PluginBas                      e.js:310:17
                      npm error This error originated either by throwing inside of an async function without a catch block, or by rejecti                      ng a promise which was not handled with .catch(). The promise rejected with the reason:
                      npm error TypeError: callback is not a function
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_09_05_083Z-debug-0.lo                      g
                      host.01-schumsmarthome Cannot install iobroker.js-controller@6.0.9: 6
                      Mod-Edit: Code bitte in Code-Tags </> setzen!
                      surfer09S 1 Antwort Letzte Antwort
                      • Joerg SchumacherJ Joerg Schumacher
                        Hallo @all!
                        Danke schonmal.
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 10.8.2
                        npm error code 6
                        surfer09S
                        surfer09S
                        surfer09
                        #92
                        Guten Morgen zusammen,
                        unter Windows 11 / Windows 10 hat bei mir auch alles funktioniert.
                        Gruß surfer ;-)
                        • stony2kS
                          stony2kS
                          stony2k
                          schrieb am zuletzt editiert von stony2k
                          #93
                          Da ich im Github des Admin Adapter und auch hier nichts dazu finde: Muss ich, um alle Updates aus dem Stable-Repo zu bekommen den Schalter auf None oder Patch stellen?
                          • stony2kS stony2k
                            Thomas BraunT
                            Thomas BraunT
                            #94
                            @stony2k
                            Edit: Unklare Beschreibung. Unten steht es besser erklärt.
                            • J
                              J
                              Jack01
                              #95
                              Moin alle zusammen,
                              Update lief ohne Probleme durch. Zuerst alle Adapter aktualisiert, dann Node.Js hochgezogen und dann über den Update Button das Update durchgefürt. Läuft auf einem Fujitsu Primo unter Proxmox als LXC.
                              Danke an die Entwickler.
                              Hans-Jürgen
                              Proxmox LXC
                              Node.js: V22.22.2
                              NPM: 10.9.7
                              JS-controller: 7.0.7
                                @stony2k
                                mcm1957M
                                mcm1957M
                                mcm1957
                                #96
                                @thomas-braun said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                @stony2k
                                None = Keine Updates
                                Patch = Jede Version wird angeboten (x.y.Z)
                                Minor = Nur neue Minor-Versionen werden angeboten (zweite Stelle in der Versionsnummer x.Y.z)
                                Major = Nur große Versionssprünge werden angeboten (X.y.z)
                                Da es hier um den automatischen Updates geht sollte es wohl heißen:
                                Patch = Nur neue Patch-Versionen werden installiert (x.y.Z)
                                Minor = Nur neue Minor- und Patch-Versionen werden installiert (zweite oder dritte Stelle in der Versionsnummer x.Y.Z)
                                Major = Alle neuen Versionen werden installiert., auch Major Spünge (X.y.z)
                                @Thomas-Braun
                                Kannst du das ggF noch mal reviewen - du schreibts oben in etwa das Gegenteil :-) ?
                                Wenn es nicht klar ist, sollte es @foxriver76 klärend erläutern.
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                foxriver76F Thomas BraunT 2 Antworten Letzte Antwort
                                • mcm1957M mcm1957
                                  @stony2k
                                  @Thomas-Braun
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  schrieb am zuletzt editiert von foxriver76
                                  #97
                                  @mcm1957 An der Stelle nochmal der Aufruf, dass man major auto Updates auf Produktivsystemen unbedingt meiden sollte, da so automatisch Änderungen rein kommen die euer System potentiell lahm legen, da Änderungen nötig sein könnten. Wenn man das wählt sollte der Admin auch eine Warnung anzeigen.
                                  Und ja die Erklärung von @mcm1957 stimmt.
                                  Videotutorials & mehr
                                  stony2kS 1 Antwort Letzte Antwort
                                  • foxriver76F foxriver76
                                    stony2kS
                                    stony2kS
                                    stony2k
                                    #98
                                    @foxriver76 Danke. Also noch klar ausgedrückt: Die Einstellung auf Major bedeutet, man bekommt alle Updates, auch wenn nur die Patchversion angehoben wurde? Mich verwirrt das gerade etwas :D
                                    Wenn ich vorher einfach auf Update gedrückt habe, dann wurde der Adapter ja aktualisiert. Manchmal kam eine Warnung, dass etwass geändert wurde und man vor dem Update dieses und jenes beachten muss. Das würde ich weiterhin gerne auch manuell machen. Also ist Minor die "sichere" Einstellung? Und bei allen anderen Updates bekomme ich weiterhin die Update Benachrichtigung?
                                    • stony2kS stony2k
                                      mcm1957M
                                      mcm1957M
                                      mcm1957
                                      #99
                                      @stony2k said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                      Ja.
                                      Bei Einstellung Major werden ALLE Updates automatisch installiert. Diese Einstellung ist aber nur selten sinnvoll und auf produktiven System m.E. NIE sinnvoll da major Updates inkompatible Änderungen beinhalten (können) und der Admin ja vor der Installation solcher Updates prüfen sollte was er anpassen muss
                                      • mcm1957M mcm1957
                                        @stony2k
                                        @Thomas-Braun
                                        Thomas BraunT
                                        Thomas BraunT
                                        #100
                                        @mcm1957 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                        Öh, nein? Wenn sich Y ändert, dann auch immer Z gleich mit.
                                          @lamo1966 werden die Datenpunkte gelistet, wenn du history auswählst
                                          L
                                          L
                                          lamo1966
                                          schrieb am zuletzt editiert von lamo1966
                                          #101
                                          @crunchip said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                          ich weiß nicht wo ich das nachsehen soll, bzw. wo dein snapshot her ist?
                                          Wie erwartet kommen heute keine Daten mehr in dem oben geposteten Chart an
                                          83.9k
