  4. {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.
    6.3k
90 Beiträge 8 Kommentatoren 7.6k Aufrufe 5 Beobachtet
    @esp8266
    Ich hab jetzt mein System auf nodejs@18 gedrückt, maxcul installiert, dann nodejs@20 installiert und maxcul hat sich automatisch selber neugebaut. Es kamen zwar zunächst Meldungen wie
    2024-07-27 22:07:04.394  - info: maxcul.0 (21557) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.16.0, js-controller: 6.0.9
    2024-07-27 22:07:04.974  - error: maxcul.0 (21557) uncaught exception: Could not locate the bindings file. Tried:
     → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/compiled/20.16.0/linux/arm64/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
     → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v115-linux-arm64/bindings.node
    2024-07-27 22:07:04.980  - error: maxcul.0 (21557) Error: Could not locate the bindings file. Tried:
        at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
        at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        at Module._compile (node:internal/modules/cjs/loader:1358:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        at Module.load (node:internal/modules/cjs/loader:1208:32)
        at Module._load (node:internal/modules/cjs/loader:1024:12)
        at Module.require (node:internal/modules/cjs/loader:1233:19)
        at require (node:internal/modules/helpers:179:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.maxcul/node_modules/serialport/lib/index.js:2:17)
    2024-07-27 22:07:04.984  - error: maxcul.0 (21557) Could not locate the bindings file. Tried:
    2024-07-27 22:07:04.998  - info: maxcul.0 (21557) terminating
    2024-07-27 22:07:05.001  - warn: maxcul.0 (21557) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-07-27 22:07:05.504  - info: maxcul.0 (21557) terminating
    2024-07-27 22:07:05.706  - error: host.chet Caught by controller[0]: Cannot load serialport module
    2024-07-27 22:07:05.709  - error: host.chet instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-07-27 22:07:41.498  - info: maxcul.0 (21900) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.16.0, js-controller: 6.0.9
    2024-07-27 22:07:41.982  - info: maxcul.0 (21900) using serial device /dev/ttyS0@38400
    2024-07-27 22:07:42.018  - info: maxcul.0 (21900) serialPort /dev/ttyS0 is open!
    2024-07-27 22:08:12.031  - info: maxcul.0 (21900) Timeout on CUL connect, cul is available but not responding
    2024-07-27 22:09:21.327  - warn: maxcul.0 (21900) Module serialport is not available
    2024-07-27 22:10:31.444  - error: host.chet iobroker npm-rebuild: Rebuilding native modules failed
    rein, da einfach ein paar Minuten abwarten, am Ende kommt dann aber:
    2024-07-27 22:14:19.035  - info: maxcul.0 (22993) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.16.0, js-controller: 6.0.9
    2024-07-27 22:14:19.321  - info: maxcul.0 (22993) using serial device /dev/ttyS0@38400
    2024-07-27 22:14:19.336  - info: maxcul.0 (22993) serialPort /dev/ttyS0 is open!
    2024-07-27 22:14:26.978  - info: maxcul.0 (22993) List of port: [{"manufacturer":"Silicon Labs","serialNumber":"00_12_4B_00_23_93_2C_A8","pnpId":"usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"path":"/dev/ttyS0"}]
    2024-07-27 22:14:49.340  - info: maxcul.0 (22993) Timeout on CUL connect, cul is available but not responding
    2024-07-27 22:15:33.136  - info: maxcul.0 (22993) List of port: [{"manufacturer":"Silicon Labs","serialNumber":"00_12_4B_00_23_93_2C_A8","pnpId":"usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"path":"/dev/ttyS0"}]
    und die Instanz startet.
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    @thomas-braun , Hmh, wie kann ich bei einer neu Installation umgehen, dass die Datenpunkte gelöscht werden?
    • ESP8266E ESP8266
      @esp8266
      Werden sie nicht.
      mcm1957M ESP8266E 2 Antworten Letzte Antwort
        @esp8266
        Werden sie nicht.
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @thomas-braun said in Maxcul Adapter veraltet, bitte aktualisieren.:
        @esp8266
        Werden sie nicht.
        Ähmm - bei der Installation nicht. Aber bei der DEinstallation. Oder versteh ich da was falsch?
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M mcm1957
          @esp8266
          Werden sie nicht.
          @mcm1957
          Man muss den Adapter ja nicht deinstallieren, einfach nur rebuilden lassen. Funktioniert wie oben gestestet automatisch. Man muss nur abwarten.
            @esp8266
            Werden sie nicht.
            ESP8266E Offline
            ESP8266E Offline
            ESP8266
            @thomas-braun , erklär mal. Ich lösche den Adapter und die Daten bleiben.
            Ich nehme mal an, löschen unter den Instanzen, richtig. Dann sollten die Datenpunkte erhalten werden. Ich frage nur zur Sicherheit. Zur Not kann ich dann auch ein Restore noch einspielen.
            Aber dann bleibt der Adapter so wie er ist.
            • ESP8266E ESP8266
              @esp8266
              Was soll ich denn da erklären?
              Update nodejs und warte einfach ab.
              • ESP8266E Offline
                ESP8266E Offline
                ESP8266
                schrieb am zuletzt editiert von ESP8266
                @thomas-braun , so sieht es seit 12:44 aus
                logparser.0
                	1689	2024-07-28 12:44:58.899	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.logparser, node: v20.16.0, js-controller: 6.0.9
                host.iobroker
                		2024-07-28 12:44:56.014	warn	Do not restart adapter system.adapter.maxcul.0 because restart loop detected
                host.iobroker
                		2024-07-28 12:44:56.013	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                		2024-07-28 12:44:56.012	error	Caught by controller[0]: Cannot load serialport module
                maxcul.0
                	1636	2024-07-28 12:44:55.262	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                maxcul.0
                	1636	2024-07-28 12:44:55.247	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                maxcul.0
                	1636	2024-07-28 12:44:55.244	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                maxcul.0
                	1636	2024-07-28 12:44:55.238	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                und es hat sich nichts weiter getan.
                Das war schon der 2. Versuch.
                Der erste sah so aus:
                host.iobroker
                		2024-07-28 12:23:55.288	warn	Do not restart adapter system.adapter.maxcul.0 because restart loop detected
                host.iobroker
                		2024-07-28 12:23:55.288	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                		2024-07-28 12:23:55.287	error	Caught by controller[0]: Cannot load serialport module
                maxcul.0
                	289114	2024-07-28 12:23:54.644	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                maxcul.0
                	289114	2024-07-28 12:23:54.635	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                maxcul.0
                	289114	2024-07-28 12:23:54.633	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                maxcul.0
                	289114	2024-07-28 12:23:54.629	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                host.iobroker
                		2024-07-28 12:23:20.908	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                		2024-07-28 12:23:20.903	error	Caught by controller[0]: Cannot load serialport module
                maxcul.0
                	289047	2024-07-28 12:23:20.236	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                maxcul.0
                	289047	2024-07-28 12:23:20.224	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                maxcul.0
                	289047	2024-07-28 12:23:20.222	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                maxcul.0
                	289047	2024-07-28 12:23:20.217	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                host.iobroker
                		2024-07-28 12:22:43.996	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                		2024-07-28 12:22:43.989	error	Caught by controller[0]: Cannot load serialport module
                maxcul.0
                	288903	2024-07-28 12:22:43.133	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                maxcul.0
                	288903	2024-07-28 12:22:43.105	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                maxcul.0
                	288903	2024-07-28 12:22:43.098	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                maxcul.0
                	288903	2024-07-28 12:22:43.087	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                • ESP8266E ESP8266
                  logparser.0
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  host.iobroker
                  host.iobroker
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  host.iobroker
                  host.iobroker
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  maxcul.0
                  @esp8266 sagte in Maxcul Adapter veraltet, bitte aktualisieren.:
                  Dann knall den nochmal rein:
                  iob upgrade maxcul@1.3.1 --debug
                  Der Rebuild schaut dann auf meiner Kiste so aus:
                  echad@chet:~ $ iob upgrade iobroker.maxcul@1.3.1 --debug
                  Would you like to reinstall version 1.3.1 of maxcul now? [(y)es, (n)o]: y
                  Update maxcul from @1.3.1 to @1.3.1
                  Uninstall npm packet "iobroker.maxcul" for a clean re-installation
                  removed 41 packages in 8s
                  191 packages are looking for funding
                    run `npm fund` for details
                  NPM version: 10.8.2
                  Installing iobroker.maxcul@1.3.1... (System call)
                  > @serialport/bindings@9.2.8 install
                  > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                  prebuild-install warn install No prebuilt binaries found (target=22.5.1 runtime=node arch=arm64 libc= platform=linux)
                  gyp info it worked if it ends with ok
                  gyp info using node-gyp@10.1.0
                  gyp info using node@22.5.1 | linux | arm64
                  gyp info find Python using Python version 3.12.4 found at "/usr/bin/python3"
                  gyp info spawn /usr/bin/python3
                  gyp info spawn args [
                  gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                  gyp info spawn args 'binding.gyp',
                  gyp info spawn args '-f',
                  gyp info spawn args 'make',
                  gyp info spawn args '-I',
                  gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
                  gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                  gyp info spawn args '/home/iobroker/.cache/node-gyp/22.5.1/include/node/common.gypi',
                  gyp info spawn args '-Dlibrary=shared_library',
                  gyp info spawn args '-Dvisibility=default',
                  gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.5.1',
                  gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                  gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.5.1/<(target_arch)/node.lib',
                  gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
                  gyp info spawn args '-Dnode_engine=v8',
                  gyp info spawn args '--depth=.',
                  gyp info spawn args '--no-parallel',
                  gyp info spawn args '--generator-output',
                  gyp info spawn args 'build',
                  gyp info spawn args '-Goutput_dir=.'
                  gyp info spawn args ]
                  gyp info spawn make
                  gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                  make: Entering directory '/opt/iobroker/node_modules/@serialport/bindings/build'
                    CXX(target) Release/obj.target/bindings/src/serialport.o
                  In file included from /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-array-buffer.h:12,
                                   from /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8.h:24,
                                   from /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:73,
                                   from ../../../nan/nan.h:62,
                                   from ../src/./serialport.h:13,
                                   from ../src/serialport.cpp:1:
                  /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-local-handle.h:401:30: warning: template-id not allowed for constructor in C++20 [-Wtemplate-id-cdtor]
                    401 |   V8_INLINE explicit Local<T>(const LocalBase<T>& other)
                  /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-local-handle.h:401:30: note: remove the ‘< >’
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                  ../src/serialport.cpp: At global scope:
                  ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                    433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                  ../src/serialport.cpp:433:28: note: remove parentheses
                  ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                    452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                  ../src/serialport.cpp:452:30: note: remove parentheses
                  /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:1232:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                   1232 |       (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:1266:3: note: in expansion of macro ‘NODE_MODULE_X’
                   1266 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                    486 | NODE_MODULE(serialport, init);
                    CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                   from ../src/serialport.h:13,
                                   from ../src/serialport_unix.cpp:2:
                  ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                  ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                    179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                  ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                  ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                     89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                    CXX(target) Release/obj.target/bindings/src/poller.o
                                   from ../src/poller.cpp:1:
                    CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                    SOLINK_MODULE(target) Release/obj.target/bindings.node
                    COPY Release/bindings.node
                  make: Leaving directory '/opt/iobroker/node_modules/@serialport/bindings/build'
                  gyp info ok
                  added 41 packages in 40s
                  204 packages are looking for funding
                  upload [3] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/index.html index.html text/html
                  upload [2] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/index_m.html index_m.html text/html
                  upload [1] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/maxcul.png maxcul.png image/png
                  upload [0] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/words.js words.js application/javascript
                  echad@chet:~ $
                  ESP8266E mcm1957M 2 Antworten Letzte Antwort
                    NPM version: 10.8.2
                    gyp info spawn make
                    gyp info ok
                    echad@chet:~ $
                    ESP8266E Offline
                    ESP8266E Offline
                    ESP8266
                    @thomas-braun , super das hat gepasst.👍
                    Wenn ich euch nicht hätte 😊
                    G 1 Antwort Letzte Antwort
                      NPM version: 10.8.2
                      gyp info spawn make
                      gyp info ok
                      echad@chet:~ $
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      Achtung:
                      Der REinstall funktioniert erst richtig mit js-controller 6++. Erst ab 6.x.x wird zuerst ein implizites npm deinstall ausgeführt und dann ein npm i.
                      Der 5er macht nur ein npm i - und npm optimiert alles weg wenn die Version schon installiert ist. Beim 5er sollte es helfen zuerst eine version downzugraden und dann wieder upzugraden. Da tut npm dann was.
                      • mcm1957M mcm1957
                        Achtung:
                        @mcm1957
                        Hatte mich schon gewundert.
                        war mir nämlich neu. Aber ich rebuilde auch nicht sooooo oft meine Adapter.
                          @mcm1957
                          ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          Nun ist die "beta" Repository bei mir komplett Aktuell....
                            @mcm1957
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @mcm1957
                            Bei Tests hat sich gezeigt, dass npm zu viel optimiert. Ein REinstall hat daher nicht wirklich das gebracht was man erwartet - nämlich dass der Stand installiert wird der im Package drinnen ist. Hat man (- ja soll man nicht-) eine Datei des Adapters verändert dann hat ein Reinstall nicht wie erwartet den Stand wiederhergestellt der im Package drinnen ist sondern (im allgeminen) nichts gemacht... js-controller 6 macht daher bei reinstall nun zuerst ein (npm only) deinstall gefolgt von einem npm install. Npm only deinstall soll heißen, dass nur das npm package deinstalliert wird nicht aber der normale Deinstall Ablauf durchgeführt wird. Kurz - Einstellungen, States, ... bleiben alle erhalten.
                            • ESP8266E ESP8266
                              guergen
                              schrieb am zuletzt editiert von guergen
                              @esp8266 Hast Du jetzt mit Node 20 den Maxcul 1.3.1 laufen, sehe ich das richtig?
                              Also erst den Node auf 20 und dann den Befehl von thomas?
                                @esp8266 sagte in Test Adapter Awtrix-Light (Awtrix 3):
                                Ausser deinen Belehrungen wüsste ich nichts.
                                Wahrscheinlich reicht erstmal ein einfaches Update der Dependencies (aktuell ist serialport 12.x). Das Problem ist wohl, dass die Schnittmenge an Entwicklern und Nutzern von den (abgekündigten?) MAX!-Geräten sehr gering sein wird. Ich kann z.B. schlecht "ins Blaue entwickeln" und einfach eine neue Version freigeben, weil ich nix testen kann.
                                @Homoran würdest Du die Offtopic-Diskussion zu MAX! hier bitte abtrennen?
                                guergen
                                @haus-automatisierung Zum Testen hätt ich dir was geben können, den Cul hast Du ja noch, nen Fensterkontakt ist schnell abgebaut ;-)
                                Leider zu spät gesehen, aber es scheint ja zu funktionieren...
                                haus-automatisierungH ESP8266E 2 Antworten Letzte Antwort
                                • G guergen
                                  haus-automatisierungH Offline
                                  @guergen Klar, irgendwie bekommt man das hin. Ich mache nur aktuell schon super viel an Adaptern, welche ich selbst nicht nutze (nur um die am leben zu halten). Mir fehlt die Zeit an allen Ecken und Enden weiter zu machen.
                                  Und wir sprechen ja von einem recht selten genutzten Adapter. Die Dankbarkeit wird sich in Grenzen halten und die Produkte und Protokolle sind ja eh schon abgekündigt.
                                  📚 Meine Dokumentation
                                  ESP8266E 1 Antwort Letzte Antwort
                                  • G guergen
                                    ESP8266E Offline
                                    ESP8266E Offline
                                    ESP8266
                                    @guergen , ich betreibe Maxcul im Cube modus und brauche den Adapter trotzdem. Der cul liegt in der Schublade.
                                    Aber schau mal dort, wie ich das gelöst habe... https://forum.iobroker.net/topic/61650/usb-port-to-ip-oder-maxcube-mit-maxcul-adapter-via-lan?_=1723539547532
                                    Das läuft schon über ein Jahr bei mir.
                                      ESP8266E Offline
                                      ESP8266E Offline
                                      ESP8266
                                      @haus-automatisierung sagte in {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.:
                                      Der beste Beweis, das wir in einer Wegwerfgesellschaft leben.
                                      • ESP8266E ESP8266
                                        @esp8266 sagte in {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.:
                                        Was man dann unterstützt, wenn man auf proprietäre Produkte und Protokolle einzelner Hersteller setzt.
                                        • ESP8266E ESP8266
                                          guergen
                                          @esp8266 Hast mich nicht verstanden....
                                          Du hast es jetzt so gelöst?:
                                          Node 20 auf den Rechner und dann den Befehl von Thomas.
                                          Sind die Fehler:
                                          jetzt weg?
