  4. {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.
    2.8k
    4.9k
    4.1k
61 Beiträge 8 Kommentatoren 6.1k Aufrufe 6 Beobachtet
  • ESP8266E ESP8266
    ok, wird gemacht.
    ```bash
    Script v.2026-06-06
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.18.34+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 224 days ago (on 2025-12-04).
    Systemuptime and Load:
     13:10:33 up 49 min,  1 user,  load average: 1.10, 0.77, 0.76
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-07-17 13:10:33 CEST
               Universal time: Fri 2026-07-17 11:10:33 UTC
                     RTC time: Fri 2026-07-17 11:10:33
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c        spi render input iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            8.3G        5.5G        1.8G         12M        1.1G        2.8G
    Swap:           2.1G          0B        2.1G
    Total:           10G        5.5G        4.0G
    Active iob-Instances:   48
             7954 M total memory
             5274 M used memory
             5109 M active memory
              759 M inactive memory
             1729 M free memory
              131 M buffer memory
              913 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 13:10:33 up 49 min,  1 user,  load average: 1.10, 0.77, 0.76
    Tasks: 223 total,   4 running, 219 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 35.9 us,  5.1 sy,  0.0 ni, 59.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7954.9 total,   1727.4 free,   5275.8 used,   1045.3 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2679.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G  9.5M  1.6G   1% /run
    /dev/nvme0n1p2 ext4      117G   13G  100G  12% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
    tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
    /dev/nvme0n1p1 vfat      510M   67M  444M  14% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@tty        AMA10.service
    tmpfs          tmpfs     796M  8.0K  796M   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Fri Jul 17 12:21:10 2026] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
    [Fri Jul 17 12:21:10 2026] EXT4-fs (nvme0n1p2): mounted filesystem 21724cc6-e5a3        -48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Fri Jul 17 12:21:11 2026] EXT4-fs (nvme0n1p2): re-mounted 21724cc6-e5a3-48a1-86        43-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.6G    /var/
    316M    /var/cache
    309M    /var/cache/apt
    195M    /var/lib
    177M    /var/cache/apt/archives
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    173M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.3G    /opt/iobroker/iobroker-data/
    1.7G    /opt/iobroker/iobroker-data/history
    372M    /opt/iobroker/iobroker-data/files
    191M    /opt/iobroker/iobroker-data/backup-objects
    54M     /opt/iobroker/iobroker-data/files/vis
    35M     /opt/iobroker/iobroker-data/objects.jsonl
    16M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CBBsEY85.js
    13M     /opt/iobroker/iobroker-data/states.jsonl
    7.7M    /opt/iobroker/iobroker-data/files/vis.0/Haus/vis-views.json
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.j        s
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.0
    Extended Pan ID:
    00124b00216afd7c
    Pan ID:
    6756
    Channel:
    23
    Network Key:
    01030507090b0d0f00020406080a0c0d
    ": "6fd6534fc2e53bb02ba76945df6c
    ": "600b28de3f2cd7fb113122c3b62f
    ": "854478164e1ab48ca300092c4407
    ": "d70cbc25c0863f7fa636b6384985
    ": "8457efbb9777b870c026d5b18afe
    ": "0642eef2c43ee1071bcbedd4804f
    ": "e2c33d1d17e6895de1e5796c2dec
    ": "74406fb23dc41d0c303155b8204d
    ": "d566dfc20ba76ae3ef6cc24b0881
    ": "f616f533935aac207f15d377e260
    ": "02c2c80e2af2f6e808df410d0cb6
    ": "05c90797d23635c006ef43e6e83c
    ": "75091d2c4407b18f534d6c164e1a
    ": "f30263d480c41535ee8b60f2c4b5
    ": "6ff764c56db7aa0ce6f442811c8d
    ": "100e54000db385d21a13dd032bf7
    ": "58a63c98788590bc5b8078e9428f
    ": "074681ebb1b05c082102f0d1bbad
    ": "b768233ef40d82678d623eb7f72b
    ": "71df46c3b62ba85b00e54cde3f28
    ": "aec70320d5dd58cdb34e000691ac
    ": "fe300797d23635c0fd1643e6e83c
    ": "152b6b38d283e164160d2f49e889
    ": "f3a23c98788590bcf08478e9428f
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port        Status
    zigbee.0        ...a86_USB_Serial-if00-port0        ...a86_USB_Serial-if00-port0        ✓ Matching
                                                        ..._UART_A50285BI-if00-port0        ✗ Not matching
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.23.1
    /usr/bin/node           v22.23.1
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.1-1nodesource1
      Candidate: 22.23.1-1nodesource1
      Version table:
     *** 22.23.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Pac        kages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, u        ptime: 2959)
    Core adapters versions
    js-controller:  7.2.2
    admin:          7.9.13
    javascript:     9.3.1
    nodejs modules from github:     3
    +-- iobroker.apsystems-ecu@0.2.10 (git+ssh://git@github.com/npeter/ioBroker.apsy        stems-ecu.git#548da10e3e534154e71dcdfa060190a62172ed66)
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi        -ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    +-- iobroker.maxcul@2.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.maxcul.git        #ed1931ce941d94d6a9a4f2b8d507318e9c861e14)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker        -  enabled, compact disabled, port: 8081, bind: 0.0        .0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker        -  enabled, compact disabled
    + system.adapter.apsystems-ecu.0          : apsystems-ecu         : iobroker        -  enabled, compact disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker        -  enabled, compact disabled
    + system.adapter.awtrix-light.1           : awtrix-light          : iobroker        -  enabled, compact disabled
    + system.adapter.backitup.0               : backitup              : iobroker        -  enabled, compact disabled
    + system.adapter.backitup.1               : backitup              : iobroker        -  enabled, compact disabled
    + system.adapter.bambulab.0               : bambulab              : iobroker        -  enabled, compact disabled, port: 8883
    + system.adapter.broadlink2.0             : broadlink2            : iobroker        -  enabled
    + system.adapter.bshb.0                   : bshb                  : iobroker        -  enabled, compact disabled
    + system.adapter.daswetter.0              : daswetter             : iobroker        -  enabled, compact disabled
    + system.adapter.denon.0                  : denon                 : iobroker        -  enabled, compact disabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker        -  enabled, compact disabled
    + system.adapter.discovery.0              : discovery             : iobroker        -  enabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : iobroker        -  enabled, compact enabled (group 1)
    + system.adapter.echarts.0                : echarts               : iobroker        -  enabled, compact disabled
    + system.adapter.enigma2.0                : enigma2               : iobroker        -  enabled, compact disabled
    + system.adapter.fakeroku.0               : fakeroku              : iobroker        -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker        -  enabled, compact disabled
    + system.adapter.frontier_silicon.0       : frontier_silicon      : iobroker        -  enabled, compact disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker        -  enabled, compact enabled (group 1)
    + system.adapter.g-homa.0                 : g-homa                : iobroker        -  enabled, compact disabled
    + system.adapter.harmony.0                : harmony               : iobroker        -  enabled
    + system.adapter.heizoel.0                : heizoel               : iobroker        -  enabled, compact disabled
    + system.adapter.history.0                : history               : iobroker        -  enabled, compact disabled
      system.adapter.ical.0                   : ical                  : iobroker        -  enabled, compact disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker        -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker        -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker        -  enabled, compact disabled
      system.adapter.iqontrol.0               : iqontrol              : iobroker        - disabled, compact disabled
    + system.adapter.javascript.0             : javascript            : iobroker        -  enabled, compact disabled
    + system.adapter.kodi.0                   : kodi                  : iobroker        -  enabled, compact enabled (group 1), port: 9090
    + system.adapter.lgtv.0                   : lgtv                  : iobroker        -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker        -  enabled, compact disabled
    + system.adapter.matter.0                 : matter                : iobroker        -  enabled
    + system.adapter.maxcul.0                 : maxcul                : iobroker        -  enabled, compact enabled (group 1)
    + system.adapter.mqtt.0                   : mqtt                  : iobroker        -  enabled, compact disabled, port: 1884, bind: 192        .168.62.15
    + system.adapter.mqtt.1                   : mqtt                  : iobroker        -  enabled, compact disabled, port: 1888, bind: 0.0        .0.0
    + system.adapter.nut.0                    : nut                   : iobroker        -  enabled, compact disabled
      system.adapter.octoprint.0              : octoprint             : iobroker        - disabled, compact disabled
      system.adapter.parcel.0                 : parcel                : iobroker        - disabled, compact disabled
    + system.adapter.ping.0                   : ping                  : iobroker        -  enabled, compact disabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker        -  enabled, compact disabled
    + system.adapter.scenes.0                 : scenes                : iobroker        -  enabled, compact disabled
    + system.adapter.shelly.0                 : shelly                : iobroker        -  enabled, compact disabled, port: 1884, bind: 192        .168.62.15
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker        - disabled, compact disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker        -  enabled, compact disabled, port: 1883, bind: 192        .168.62.15
    + system.adapter.telegram.0               : telegram              : iobroker        -  enabled, compact disabled, port: 8443, bind: 0.0        .0.0
    + system.adapter.text2command.0           : text2command          : iobroker        -  enabled, compact disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker        -  enabled, compact disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker        -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker        -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker        -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker        -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker        -  enabled, compact disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker        -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker        -  enabled, compact disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker        -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker        -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker        -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker        -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker        -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker        -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker        -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker        -  enabled
      system.adapter.vis.0                    : vis                   : iobroker        -  enabled, compact disabled
      system.adapter.vw-connect.0             : vw-connect            : iobroker        - disabled, compact disabled
    + system.adapter.web.0                    : web                   : iobroker        -  enabled, compact disabled, port: 8082, bind: 0.0        .0.0, run as: admin
    + system.adapter.withings.0               : withings              : iobroker        -  enabled, compact disabled
      system.adapter.wled.0                   : wled                  : iobroker        - disabled, compact disabled
    + system.adapter.ws.0                     : ws                    : iobroker        -  enabled, compact disabled, port: 8084, bind: 0.0        .0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker        -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker        -  enabled, compact disabled, port: /dev/serial/by-        id/usb-1a86_USB_Serial-if00-port0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                     │        auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │        false        │
    │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │        false        │
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                  │ name                 │ version        │ upgrade policy │
    │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '7.9.13        '  │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'             │ 'alexa2'             │ '3.28.3        '  │ 'none'         │
    │ 2       │ 'system.adapter.apsystems-ecu'      │ 'apsystems-ecu'      │ '0.2.10        '  │ 'none'         │
    │ 3       │ 'system.adapter.awtrix-light'       │ 'awtrix-light'       │ '3.0.0'        │ 'none'         │
    │ 4       │ 'system.adapter.backitup'           │ 'backitup'           │ '3.3.17        '  │ 'none'         │
    │ 5       │ 'system.adapter.bambulab'           │ 'bambulab'           │ '0.4.3'        │ 'none'         │
    │ 6       │ 'system.adapter.broadlink2'         │ 'broadlink2'         │ '2.3.0'        │ 'none'         │
    │ 7       │ 'system.adapter.bshb'               │ 'bshb'               │ '0.6.3'        │ 'none'         │
    │ 8       │ 'system.adapter.daswetter'          │ 'daswetter'          │ '4.5.9'        │ 'none'         │
    │ 9       │ 'system.adapter.denon'              │ 'denon'              │ '1.15.1        2' │ 'none'         │
    │ 10      │ 'system.adapter.device-reminder'    │ 'device-reminder'    │ '3.1.2'        │ 'none'         │
    │ 11      │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.1'        │ 'none'         │
    │ 12      │ 'system.adapter.dwd'                │ 'dwd'                │ '2.8.5'        │ 'none'         │
    │ 13      │ 'system.adapter.echarts'            │ 'echarts'            │ '4.0.0'        │ 'none'         │
    │ 14      │ 'system.adapter.enigma2'            │ 'enigma2'            │ '2.3.0'        │ 'none'         │
    │ 15      │ 'system.adapter.fakeroku'           │ 'fakeroku'           │ '0.4.0'        │ 'none'         │
    │ 16      │ 'system.adapter.feiertage'          │ 'feiertage'          │ '1.4.0'        │ 'none'         │
    │ 17      │ 'system.adapter.frontier_silicon'   │ 'frontier_silicon'   │ '0.5.1'        │ 'none'         │
    │ 18      │ 'system.adapter.fullybrowser'       │ 'fullybrowser'       │ '3.1.5'        │ 'none'         │
    │ 19      │ 'system.adapter.g-homa'             │ 'g-homa'             │ '0.5.3'        │ 'none'         │
    │ 20      │ 'system.adapter.harmony'            │ 'harmony'            │ '2.1.0'        │ 'none'         │
    │ 21      │ 'system.adapter.heizoel'            │ 'heizoel'            │ '1.0.3'        │ 'none'         │
    │ 22      │ 'system.adapter.history'            │ 'history'            │ '4.0.0'        │ 'none'         │
    │ 23      │ 'system.adapter.ical'               │ 'ical'               │ '1.20.1        '  │ 'none'         │
    │ 24      │ 'system.adapter.icons-mfd-png'      │ 'icons-mfd-png'      │ '1.2.1'        │ 'none'         │
    │ 25      │ 'system.adapter.icons-ultimate-png' │ 'icons-ultimate-png' │ '1.0.1'        │ 'none'         │
    │ 26      │ 'system.adapter.iot'                │ 'iot'                │ '6.1.3'        │ 'none'         │
    │ 27      │ 'system.adapter.iqontrol'           │ 'iqontrol'           │ '3.0.0'        │ 'none'         │
    │ 28      │ 'system.adapter.javascript'         │ 'javascript'         │ '9.3.1'        │ 'none'         │
    │ 29      │ 'system.adapter.kodi'               │ 'kodi'               │ '3.1.0'        │ 'none'         │
    │ 30      │ 'system.adapter.lgtv'               │ 'lgtv'               │ '2.7.4'        │ 'none'         │
    │ 31      │ 'system.adapter.logparser'          │ 'logparser'          │ '2.5.0'        │ 'none'         │
    │ 32      │ 'system.adapter.matter'             │ 'matter'             │ '1.2.1'        │ 'none'         │
    │ 33      │ 'system.adapter.maxcul'             │ 'maxcul'             │ '2.0.0'        │ 'none'         │
    │ 34      │ 'system.adapter.mcp'                │ 'mcp'                │ '1.0.11        '  │ 'none'         │
    │ 35      │ 'system.adapter.mqtt'               │ 'mqtt'               │ '7.1.1'        │ 'none'         │
    │ 36      │ 'system.adapter.nut'                │ 'nut'                │ '1.7.0'        │ 'none'         │
    │ 37      │ 'system.adapter.octoprint'          │ 'octoprint'          │ '7.0.0'        │ 'none'         │
    │ 38      │ 'system.adapter.parcel'             │ 'parcel'             │ '0.3.2'        │ 'none'         │
    │ 39      │ 'system.adapter.ping'               │ 'ping'               │ '2.2.4'        │ 'none'         │
    │ 40      │ 'system.adapter.rpi2'               │ 'rpi2'               │ '3.0.2'        │ 'none'         │
    │ 41      │ 'system.adapter.scenes'             │ 'scenes'             │ '4.0.4'        │ 'none'         │
    │ 42      │ 'system.adapter.shelly'             │ 'shelly'             │ '11.0.0        '  │ 'none'         │
    │ 43      │ 'system.adapter.shuttercontrol'     │ 'shuttercontrol'     │ '2.0.12        '  │ 'none'         │
    │ 44      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '3.0.7'        │ 'none'         │
    │ 45      │ 'system.adapter.socketio'           │ 'socketio'           │ '8.0.1'        │ 'none'         │
    │ 46      │ 'system.adapter.sonoff'             │ 'sonoff'             │ '3.3.0'        │ 'none'         │
    │ 47      │ 'system.adapter.telegram'           │ 'telegram'           │ '4.1.0'        │ 'none'         │
    │ 48      │ 'system.adapter.text2command'       │ 'text2command'       │ '4.0.0'        │ 'none'         │
    │ 49      │ 'system.adapter.trashschedule'      │ 'trashschedule'      │ '5.3.0'        │ 'none'         │
    │ 50      │ 'system.adapter.tuya'               │ 'tuya'               │ '3.17.0        '  │ 'none'         │
    │ 51      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'        │ 'none'         │
    │ 52      │ 'system.adapter.vis-bars'           │ 'vis-bars'           │ '0.1.4'        │ 'none'         │
    │ 53      │ 'system.adapter.vis-canvas-gauges'  │ 'vis-canvas-gauges'  │ '1.0.1'        │ 'none'         │
    │ 54      │ 'system.adapter.vis-fancyswitch'    │ 'vis-fancyswitch'    │ '1.1.0'        │ 'none'         │
    │ 55      │ 'system.adapter.vis-google-fonts'   │ 'vis-google-fonts'   │ '1.0.4'        │ 'none'         │
    │ 56      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'        │ 'none'         │
    │ 57      │ 'system.adapter.vis-icontwo'        │ 'vis-icontwo'        │ '2.11.6        '  │ 'none'         │
    │ 58      │ 'system.adapter.vis-inventwo'       │ 'vis-inventwo'       │ '4.1.1'        │ 'none'         │
    │ 59      │ 'system.adapter.vis-jqui-mfd'       │ 'vis-jqui-mfd'       │ '1.1.3'        │ 'none'         │
    │ 60      │ 'system.adapter.vis-justgage'       │ 'vis-justgage'       │ '2.1.7'        │ 'none'         │
    │ 61      │ 'system.adapter.vis-keyboard'       │ 'vis-keyboard'       │ '0.0.3'        │ 'none'         │
    │ 62      │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9'        │ 'none'         │
    │ 63      │ 'system.adapter.vis-players'        │ 'vis-players'        │ '0.1.6'        │ 'none'         │
    │ 64      │ 'system.adapter.vis-rgraph'         │ 'vis-rgraph'         │ '0.0.2'        │ 'none'         │
    │ 65      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'        │ 'none'         │
    │ 66      │ 'system.adapter.vw-connect'         │ 'vw-connect'         │ '0.9.6'        │ 'none'         │
    │ 67      │ 'system.adapter.web'                │ 'web'                │ '9.0.0'        │ 'none'         │
    │ 68      │ 'system.adapter.withings'           │ 'withings'           │ '0.0.16        '  │ 'none'         │
    │ 69      │ 'system.adapter.wled'               │ 'wled'               │ '0.9.2'        │ 'none'         │
    │ 70      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'        │ 'none'         │
    │ 71      │ 'system.adapter.yahka'              │ 'yahka'              │ '1.1.6'        │ 'none'         │
    │ 72      │ 'system.adapter.zigbee'             │ 'zigbee'             │ '3.4.11        '  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: beta
    Adapter    "admin"        : 7.9.13   , installed 7.9.13
    Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "bshb"         : 0.6.3    , installed 0.6.3
    Adapter    "daswetter"    : 4.5.9    , installed 4.5.9
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 5.0.1    , installed 5.0.1
    Adapter    "echarts"      : 4.0.0    , installed 4.0.0
    Adapter    "enigma2"      : 2.3.0    , installed 2.3.0
    Adapter    "fakeroku"     : 0.4.0    , installed 0.4.0
    Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
    Adapter    "frontier_silicon": 0.5.1 , installed 0.5.1
    Adapter    "fullybrowser" : 3.1.5    , installed 3.1.5
    Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
    Adapter    "harmony"      : 2.1.0    , installed 2.1.0
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 6.1.3    , installed 6.1.3
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.3.1    , installed 9.3.1
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "lgtv"         : 2.7.4    , installed 2.7.4
    Adapter    "logparser"    : 2.5.0    , installed 2.5.0
    Adapter    "matter"       : 1.2.1    , installed 1.2.1
    Adapter    "maxcul"       : 1.3.1    , installed 2.0.0
    Adapter    "mcp"          : 1.0.11   , installed 1.0.11
    Adapter    "mqtt"         : 7.1.1    , installed 7.1.1
    Adapter    "nut"          : 1.7.0    , installed 1.7.0
    Adapter    "octoprint"    : 7.0.0    , installed 7.0.0
    Adapter    "parcel"       : 0.3.2    , installed 0.3.2
    Adapter    "ping"         : 2.2.4    , installed 2.2.4
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "shelly"       : 11.0.0   , installed 11.0.0
    Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
    Adapter    "socketio"     : 8.0.1    , installed 8.0.1
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "trashschedule": 5.3.0    , installed 5.3.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
    Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vw-connect"   : 0.9.6    , installed 0.9.6
    Adapter    "web"          : 9.0.0    , installed 9.0.0
    Adapter    "withings"     : 0.0.16   , installed 0.0.16
    Adapter    "wled"         : 0.9.2    , installed 0.9.2
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "yahka"        : 1.1.6    , installed 1.1.6
    Adapter    "zigbee"       : 3.4.11   , installed 3.4.11
    Objects and States
    Objects:        28431
    States:         24486
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
    udp   UNCONN 0      0            0.0.0.0:57813       0.0.0.0:*    users:(("io.ma        tter.0",pid=2144,fd=38))
    udp   UNCONN 0      0            0.0.0.0:61991       0.0.0.0:*    users:(("io.ha        rmony.0",pid=2086,fd=30))
    udp   UNCONN 0      0          127.0.0.1:978         0.0.0.0:*    users:(("rpc.s        tatd",pid=1226,fd=5))
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("io.ma        tter.0",pid=2144,fd=41))
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("io.ma        tter.0",pid=2144,fd=35))
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("io.ya        hka.0",pid=1773,fd=30))
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("io.ya        hka.0",pid=1773,fd=29))
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi        -daemon",pid=717,fd=12))
    udp   UNCONN 0      0            0.0.0.0:coap        0.0.0.0:*    users:(("io.sh        elly.0",pid=1698,fd=38))
    udp   UNCONN 0      0            0.0.0.0:1900        0.0.0.0:*    users:(("io.fa        keroku.0",pid=1420,fd=32))
    udp   UNCONN 0      0            0.0.0.0:6666        0.0.0.0:*    users:(("io.tu        ya.0",pid=1737,fd=48))
    udp   UNCONN 0      0            0.0.0.0:6667        0.0.0.0:*    users:(("io.tu        ya.0",pid=1737,fd=49))
    udp   UNCONN 0      0            0.0.0.0:60007       0.0.0.0:*    users:(("io.br        oadlink2.0",pid=1356,fd=31))
    udp   UNCONN 0      0            0.0.0.0:15001       0.0.0.0:*    users:(("io.br        oadlink2.0",pid=1356,fd=30))
    udp   UNCONN 0      0            0.0.0.0:43989       0.0.0.0:*    users:(("io.br        oadlink2.0",pid=1356,fd=32))
    udp   UNCONN 0      0            0.0.0.0:56809       0.0.0.0:*    users:(("rpc.s        tatd",pid=1226,fd=8))
    udp   UNCONN 0      0            0.0.0.0:53161       0.0.0.0:*    users:(("avahi        -daemon",pid=717,fd=14))
    udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbi        nd",pid=691,fd=5),("systemd",pid=1,fd=145))
    udp   UNCONN 0      0                  *:57813             *:*    users:(("io.ma        tter.0",pid=2144,fd=37))
    udp   UNCONN 0      0                  *:mdns              *:*    users:(("io.ma        tter.0",pid=2144,fd=42))
    udp   UNCONN 0      0                  *:mdns              *:*    users:(("io.ma        tter.0",pid=2144,fd=36))
    udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi        -daemon",pid=717,fd=13))
    udp   UNCONN 0      0                  *:55102             *:*    users:(("avahi        -daemon",pid=717,fd=15))
    udp   UNCONN 0      0                  *:43440             *:*    users:(("rpc.s        tatd",pid=1226,fd=10))
    udp   UNCONN 0      0                  *:sunrpc            *:*    users:(("rpcbi        nd",pid=691,fd=7),("systemd",pid=1,fd=147))
    tcp   LISTEN 0      511          0.0.0.0:33117       0.0.0.0:*    users:(("io.ya        hka.0",pid=1773,fd=37))
    tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbi        nd",pid=691,fd=4),("systemd",pid=1,fd=144))
    tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd"        ,pid=955,fd=6))
    tcp   LISTEN 0      511    192.168.62.15:1883        0.0.0.0:*    users:(("io.so        noff.0",pid=6862,fd=34))
    tcp   LISTEN 0      511    192.168.62.15:1884        0.0.0.0:*    users:(("io.mq        tt.0",pid=1553,fd=35))
    tcp   LISTEN 0      511    192.168.62.15:1885        0.0.0.0:*    users:(("io.mq        tt.0",pid=1553,fd=36))
    tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobro        ker.js-con",pid=934,fd=23))
    tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobro        ker.js-con",pid=934,fd=29))
    tcp   LISTEN 0      4096         0.0.0.0:55285       0.0.0.0:*    users:(("rpc.s        tatd",pid=1226,fd=9))
    tcp   LISTEN 0      511    192.168.62.15:9094        0.0.0.0:*    users:(("io.fa        keroku.0",pid=1420,fd=31))
    tcp   LISTEN 0      511    192.168.62.15:9093        0.0.0.0:*    users:(("io.fa        keroku.0",pid=1420,fd=30))
    tcp   LISTEN 0      511                *:57813             *:*    users:(("io.ma        tter.0",pid=2144,fd=39))
    tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbi        nd",pid=691,fd=6),("systemd",pid=1,fd=146))
    tcp   LISTEN 0      32                 *:ftp               *:*    users:(("vsftp        d",pid=946,fd=3))
    tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd"        ,pid=955,fd=7))
    tcp   LISTEN 0      511                *:50001             *:*    users:(("io.g-        homa.0",pid=2008,fd=30))
    tcp   LISTEN 0      511                *:61991             *:*    users:(("io.ha        rmony.0",pid=2086,fd=29))
    tcp   LISTEN 0      4096            [::]:42299          [::]:*    users:(("rpc.s        tatd",pid=1226,fd=11))
    tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.ad        min.0",pid=979,fd=39))
    tcp   LISTEN 0      511                *:8082              *:*    users:(("io.we        b.0",pid=2225,fd=35))
    tcp   LISTEN 0      511                *:8084              *:*    users:(("io.ws        .0",pid=2267,fd=34))
    2026-07-17 12:22:04.751  - info: bshb.0 (1372) Start detecting climate schedules        ...
    2026-07-17 12:22:04.888  - info: bshb.0 (1372) Detecting climate schedules finis        hed
    2026-07-17 12:22:04.888  - info: bshb.0 (1372) Start detecting backup informatio        n...
    2026-07-17 12:22:05.044  - info: bshb.0 (1372) Detecting backup information fini        shed
    2026-07-17 12:22:05.044  - info: bshb.0 (1372) Subscribe to ioBroker states
    2026-07-17 12:22:05.046  - info: bshb.0 (1372) Listen to changes
    2026-07-17 12:22:07.096  - info: fakeroku.0 (1420) starting. Version 0.4.0 in /o        pt/iobroker/node_modules/iobroker.fakeroku, node: v22.23.1, js-controller: 7.2.2
    2026-07-17 12:22:15.125  - info: frontier_silicon.0 (1452) starting. Version 0.5        .1 in /opt/iobroker/node_modules/iobroker.frontier_silicon, node: v22.23.1, js-c        ontroller: 7.2.2
    2026-07-17 12:22:15.377  - info: frontier_silicon.0 (1452) Trying to create sess        ion with frname @ 192.168.62.60 ...
    2026-07-17 12:22:15.503  - info: frontier_silicon.0 (1452) Session 753887667 wit        h Device frname @ 192.168.62.60 created
    2026-07-17 12:22:31.900  - info: logparser.0 (1536) starting. Version 2.5.0 in /        opt/iobroker/node_modules/iobroker.logparser, node: v22.23.1, js-controller: 7.2        .2
    2026-07-17 12:22:51.913  - info: ping.0 (1604) starting. Version 2.2.4 in /opt/i        obroker/node_modules/iobroker.ping, node: v22.23.1, js-controller: 7.2.2
    2026-07-17 12:22:55.115  - info: rpi2.0 (1625) starting. Version 3.0.2 in /opt/i        obroker/node_modules/iobroker.rpi2, node: v22.23.1, js-controller: 7.2.2
    2026-07-17 12:22:55.446  - info: rpi2.0 (1625) GPIO ports are not configured
    2026-07-17 12:23:30.895  - error: tuya.0 (1737) Login for MQTT failed: TypeError        : Cannot destructure property 'access_token' of 'res.result' as it is undefined.
    2026-07-17 12:23:35.327  - error: bambulab.0 (1872) Connection issue occurred: E        rror: connect EHOSTUNREACH 192.168.62.74:8883 - printer may be powered off or un        reachable
    2026-07-17 12:23:44.014  - info: discovery.0 (1927) starting. Version 5.0.1 in /        opt/iobroker/node_modules/iobroker.discovery, node: v22.23.1, js-controller: 7.2        .2
    2026-07-17 12:23:51.334  - info: echarts.0 (1964) starting. Version 4.0.0 in /op        t/iobroker/node_modules/iobroker.echarts, node: v22.23.1, js-controller: 7.2.2
    2026-07-17 12:24:20.653  - info: text2command.0 (2152) starting. Version 4.0.0 i        n /opt/iobroker/node_modules/iobroker.text2command, node: v22.23.1, js-controlle        r: 7.2.2
    2026-07-17 12:24:28.350  - info: vis-google-fonts.0 (2197) starting. Version 1.0        .4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v22.23.1, js-c        ontroller: 7.2.2
    2026-07-17 12:24:29.091  - info: vis-google-fonts.0 (2197) Terminated (NO_ERROR)        : Without reason
    2026-07-17 12:24:34.694  - info: vis.0 (2213) starting. Version 1.5.6 in /opt/io        broker/node_modules/iobroker.vis, node: v22.23.1, js-controller: 7.2.2
    2026-07-17 12:24:36.127  - info: vis.0 (2213) Terminated (NO_ERROR): Without rea        son
    2026-07-17 12:24:44.269  - info: ws.0 (2267) starting. Version 4.1.0 in /opt/iob        roker/node_modules/iobroker.ws, node: v22.23.1, js-controller: 7.2.2
    2026-07-17 12:24:44.295  - info: ws.0 (2267) socket.io server listening on port        8084
    Hier das full diag:
    full diag.txt
    Ich sehe nichts, ausser einer kleine Warnung der USB Zuweisung. Die brauche ich eh nicht. Wie oben geschrieben läuft der Adapter nach zigmal rebooten. Das ist aber für mich keine Lösung. Gern schicke ich nochmal ein diag wenn der Fehler wieder auftritt.
    Danke erstmal.
    schrieb zuletzt editiert von
    #61
    @ESP8266 sagte:
    Das spricht für mich nach genau dem Verhalten, wenn Gerätedateien doppelt/falsch vergeben werden.
