  3. Marktplatz
  4. cod.m ZigBee Coordinator (PoE/non-PoE) - made in Germany
    6.3k
Geplant Angeheftet Gesperrt Verschoben Marktplatz
cc2652p7zigbee-adapterzigbee-coordinatorzigbee2mqtt
308 Beiträge 36 Kommentatoren 75.0k Aufrufe 47 Beobachtet
  • FredFF FredF
    @Asgothian @pmayer Hier der Log
    2025-12-19 19:07:21.284 - warn: zigbee.0 (106550) Network parameters in Config : panID=6754 channel=11 extendedPanID=d7b8aa1c004b1200
    2025-12-19 19:07:21.285 - warn: zigbee.0 (106550) Network parameters on Coordinator: panID=65534 channel=0 extendedPanID=d7b8aa1c004b1200
    2025-12-19 19:07:21.306 - error: zigbee.0 (106550) Starting zigbee-herdsman problem : network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms
    at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:68:23)
    at ZnpAdapterManager.beginCommissioning (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:362:31)
    at processTicksAndRejections (node:internal/process/task_queues:105:5)
    at ZnpAdapterManager.start (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:90:21)
    at ZStackAdapter.start (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:155:16)
    at Controller.start (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at ZigbeeController.start (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:220:28)
    at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:451:28))
    2025-12-19 19:07:21.306 - error: zigbee.0 (106550) Failed to start Zigbee: no message given
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #221
    @FredF was du versuchen kannst:
    • antenne des Koordinators (ggf. sogar den ganzen cod.m in Alufolie einwickeln. Sicherstellen das er keines deiner Geräte erreichen kann.
    • Netzwerk starten. (Ohne gültiges NVBackup) Hoffen das es durch geht
    • Netzwerk anhalten.
    • nvBackup vom letzten Lauf vor dem Versuch mit HA widerherstellen
    • Netzwerk starten - hoffen das es durch geht
    • Wenn es durch geht, netzwerk anhalten, Alufolie von der Antenne nehmen, Netzwerk wieder starten.
    Dann sollte es wieder laufen.
    A.
    FredFF 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      FredFF Offline
      FredFF Offline
      FredF
      Most Active Forum Testing
      #222
      @Asgothian Danke
      Nach Punkt 2 Netzwerk starten wird der Adapter grün, schon mal gut.
      Allerdings keine Geräte mehr, ok.
      Wo bekomme ich das nvBackup vor dem HA Versuch her?
      • FredFF FredF
        @Asgothian Danke
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #223
        @FredF sagte in cod.m ZigBee Coordinator (PoE/non-PoE) - made in Germany:
        Na ja - ich war davon ausgegangen das du die Datei vor dem Löschen gesichert hast.
        Hast du nicht ? - dann nicht gut.
        Was du versuchen kannst:
        der Adapter sichert die Dateien in einem internen Backup - jeweils beim erfolgreichen Start. Auf die kannst du mittels dieses Buttons in der Konfiguration der Version 3.3.0 zugreifen (Screenshot 2025-12-19 at 20.19.34.png
        Da im Dateinamen des Backups der Zeitpunkt der Entstehung drin steht kannst du also das letzte backup vor deinem HA debakel versuchen zurück zu spielen.
        Hast du nicht Adapter 3.3.0 - dann musst du da manuell ran - die Dateien liegen im gleichen Verzeichnis wie die shepherd.db. Es sind .tgz dateien. via tar -xzf <dateiname> kannst du die in dem verzeichnis auspacken wo du den Befehl absetzt (linux/macos only - keine Ahnung wie das bei windows ist)
        A.
        Nachtrag:
        Was hast du denn alles gelöscht als es nicht ging ?
        A.
          A.
          Nachtrag:
          A.
          FredFF Offline
          FredFF Offline
          FredF
          schrieb am zuletzt editiert von FredF
          #224
          @Asgothian
          Läuft wieder.
          Nachdem der Adapter Grün geworden ist und alle Geräte weg waren, habe ich ein Restore vom letzten Backup vor dem HA Fehler gemacht.
          Deine Antwort kam parallel.
          Vielen Dank für deine Hilfe.
          • FredFF Offline
            FredFF Offline
            FredF
            #225
            @pmayer
            Was mich noch wundert ist, dass das löschen des NVRAMs über die Konsole "anscheinend" nicht funktioniert hat.
            Oder unterliege ich einem Irrtum?
            pmayerP 2 Antworten Letzte Antwort
            • AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #226
              Na ja - wenn der Adapter ein nvram backup hat, und erkennt das im nvram nix drin steht, dann schiebt er das da rein - deswegen dauert bei sowas der erste start auch etwas länger.
              • FredFF FredF
                @pmayer
                pmayerP Offline
                pmayerP Offline
                pmayer
                #227
                @FredF Die Config.json liegt im Dateisystem. Der kleinste Block ist 8kb - das passt so.
                NVRAM ist im CC2652P7. Das hat nichts mit dem Dateisystem des Coordinators (ESP32) zu tun,
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #228
                  hat sich erledigt
                  • MartinPM Offline
                    MartinPM Offline
                    MartinP
                    #229
                    Zur Frage der Antennenqualität auf beiden Seiten einer Strecke zwischen Koordinator und Endgerät und die Auswirkungen noch eine Anmerkung: Die bessere Qualität der Antenne wirkt sich, wenn man sich an die Regularien hält eher auf der Empfangsseite des Koordinators aus. Da sorgt der Antennengewinn dafür, dass über die Antennenbuchse ein stärkeres Signal vom Endgerät hereinkommt.
                    In Senderichtung muss der Koordinator an seiner Antennenbuchse die HF Leistung entsprechend dem Antennengewinn abschwächen, um nicht eine EIRP (Äquivalent Rundstrahlerleistung) zu erreichen, die über dem Erlaubten liegt.
                    Aber auch da gilt, wo kein Kläger, da kein Richter.
                    Es ist noch niemand wegen Frixtender Antennen an der Fritzbox, oder einer Stummelantenne an seiner ESP32 CAM belangt worden.
                    • FredFF FredF
                      @pmayer
                      pmayerP Offline
                      pmayerP Offline
                      pmayer
                      #230
                      @FredF Anscheinend hab ich da gestern zu schnell geantwortet.
                      Eventuell ist das ein Bug, dass der Status des NVRAM nach dem leeren nicht korrekt ausgelesen wird.
                      Ich hab mal ein Ticket aufgemacht.
                      • D4vED Offline
                        D4vED Offline
                        D4vE
                        schrieb am zuletzt editiert von D4vE
                        #231
                        frage hab heute das update auf 2.1 oder so was gemacht seitem geht hier nix mehr das gerät geht an aus an aus :8 was mach ich jetzt?
                        Iobroker Installation date 2021-08-16
                        Platform: linux init system: Docker
                        cod.m Zigbee Coordinator: CZC v1.0
                        arteckA pmayerP 2 Antworten Letzte Antwort
                        • D4vED D4vE
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #232
                          @D4vE sagte in cod.m ZigBee Coordinator (PoE/non-PoE) - made in Germany:
                          oder so was gemacht
                          liegt bwestimt wam Wetter oder sowas
                          im ernst... wenn du schon mal ein Problem hast dann beschribe es so genau wie möglich..
                          meinst du wir haben nix anderes zu tun als sich mit "oder sowas" zu beschäftigen..
                          • D4vED D4vE
                            pmayerP Offline
                            pmayerP Offline
                            pmayer
                            schrieb am zuletzt editiert von pmayer
                            #233
                            @D4vE Wir sind bei uns bei version 2.1. Was hast du wie geupdatet?
                            Du kannst im Notfall den Coordinator mit dem Webflasher neu flashen: https://docs.codm.de/zigbee/coordinator/web-installer/
                            D4vED 1 Antwort Letzte Antwort
                            • pmayerP pmayer
                              D4vED Offline
                              D4vED Offline
                              D4vE
                              #234
                              @pmayer grüß dich mein freund. also guck sobald ich hab die neuste ver. gehe. geht das teil an und aus das UI ist für 10 sek errreichbar danach geht nix mehr. man muss schnell sein sobald das UI ererichbar ist musste ich werkseinstellung machen. somit konnte ich die 2.04 drauf spielen und es geht wieder hab das paar mal probiert. es geht nur mit ver. 2.03 / 2.04 sobald 2.1 drauf ist gehen die lichten nur an aus an aus. und das gerät ist nicht mehr erreichbar.
                              • pmayerP Offline
                                pmayerP Offline
                                pmayer
                                #235
                                Krass! Ok - du kannst mit dem Web-Flasher auch die älteren Versionen installieren. Das geht auch wenn da gar keine Firmware drauf ist. So als Backup....
                                Ich habe keine Idee warum V2.1 bei dir das macht. Haben wir bisher noch nicht gehabt.
                                • pmayerP pmayer
                                  D4vED Offline
                                  D4vED Offline
                                  D4vE
                                  #236
                                  @pmayer ja alles gut kann ja mal passieren ich warte einfach auf eine neue ver. und teste es dann nochmal. danke dir
                                  • FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    schrieb am zuletzt editiert von Fabio
                                    #237
                                    @pmayer @asgothian Hallo ich weiß eigentlich gar nicht wo ich das posten sollte.
                                    Zum Problem, ich habe drei Coordinator mit Version 2.1
                                    ZigBee Adapter mit Version 3.3.0 am laufen, seit ca. 2 Wochen sind auf einmal die Coordinatoren über die Weboberfläche nicht mehr erreichbar. Ping kommt an. Beim ersten mal dachte ich an einen IP Konflikt, habe aber in meinen Netzwerk nichts dazu gefunden. Nach Netzteil ziehen kommen sie zurück und machen ihren Job. Die Coordinatoren befinden sich im LAN, Wlan ist auch abgeschaltet.
                                    Da es jetzt alle drei betrifft und ich das Problem vorher noch nicht hatte, meine Frage was könnte das sein? Anbei ein Log.
                                    igbee.2
                                    2025-12-28 21:46:23.597	info	0x7cb03eaa00ae0410 (addr 49651): AC0363900NJ - OSRAM Smart+ mini gardenpole RGBW (Router)
                                    zigbee.2
                                    2025-12-28 21:46:23.572	info	Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20250321 (2-1.2.7.1)
                                    zigbee.2
                                    2025-12-28 21:46:18.778	info	Starting Zigbee-Herdsman
                                    zigbee.2
                                    2025-12-28 21:46:18.778	info	configured transmit power :
                                    zigbee.2
                                    2025-12-28 21:46:18.778	info	Installed Version: iobroker.zigbee@3.3.0 (Converters 25.84.0 Herdsman 7.0.4)
                                    zigbee.2
                                    2025-12-28 21:46:18.776	info	Starting Adapter npm ...
                                    zigbee.2
                                    2025-12-28 21:46:18.775	info	Try to reconnect.
                                    admin.0
                                    2025-12-28 21:38:49.418	info	==> Connected system.user.admin from ::ffff:192.168.2.63
                                    zigbee.2
                                    2025-12-28 21:38:07.293	error	Failed to start Zigbee: no message given
                                    zigbee.2
                                    2025-12-28 21:38:07.293	error	Starting zigbee-herdsman problem : Error while opening socket
                                    zigbee.2
                                    2025-12-28 21:38:07.246	info	Unable to obtain herdsman settings
                                    zigbee.2
                                    2025-12-28 21:37:52.796	info	Starting Zigbee-Herdsman
                                    zigbee.2
                                    2025-12-28 21:37:52.796	info	configured transmit power :
                                    zigbee.2
                                    2025-12-28 21:37:52.795	info	Installed Version: iobroker.zigbee@3.3.0 (Converters 25.84.0 Herdsman 7.0.4)
                                    zigbee.2
                                    2025-12-28 21:37:52.788	info	Starting Adapter npm ...
                                    zigbee.2
                                    2025-12-28 21:37:52.788	info	Autostart Zigbee subsystem
                                    zigbee.2
                                    2025-12-28 21:37:52.787	info	delete old Backup files. keep only last 10
                                    zigbee.2
                                    2025-12-28 21:37:52.767	info	Adapter ready - starting subsystems. Adapter is running in info mode.
                                    zigbee.2
                                    2025-12-28 21:37:52.761	info	init localConfig
                                    zigbee.2
                                    2025-12-28 21:37:52.753	info	starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.21.0, js-controller: 7.0.7
                                    host.nuc
                                    2025-12-28 21:37:51.956	info	instance system.adapter.zigbee.2 in version "3.3.0" started with pid 20348
                                    host.nuc
                                    2025-12-28 21:37:21.663	info	Restart adapter system.adapter.zigbee.2 because enabled
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	instance system.adapter.zigbee.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:105:5)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:473:47)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at ZStackAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1032:49)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at AdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:58:48)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at AdapterBackup.getAdapterVersion (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:437:48)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at Znp.requestWithReply (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:228:34)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:244:19)
                                    host.nuc
                                    2025-12-28 21:37:21.663	error	Caught by controller[2]: Error: Cannot request when znp has not been initialized yet
                                    host.nuc
                                    2025-12-28 21:37:21.662	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                    zigbee.2
                                    2025-12-28 21:37:21.564	info	Saved local configuration data
                                    zigbee.2
                                    2025-12-28 21:37:21.065	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    zigbee.2
                                    2025-12-28 21:37:21.064	info	terminating
                                    zigbee.2
                                    2025-12-28 21:37:21.064	info	cleanup successful
                                    zigbee.2
                                    2025-12-28 21:37:21.064	info	zigbecontroller stopped successfully - ZH was not running
                                    zigbee.2
                                    2025-12-28 21:37:21.062	info	cleaning everything up
                                    zigbee.2
                                    2025-12-28 21:37:21.062	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
                                    zigbee.2
                                    2025-12-28 21:37:21.050	error	Cannot request when znp has not been initialized yet
                                    zigbee.2
                                    2025-12-28 21:37:21.050	error	Error: Cannot request when znp has not been initialized yet at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:244:19) at Znp.requestWithReply (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:228:34) at AdapterBackup.getAdapterVersion (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:437:48) at AdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:58:48) at ZStackAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1032:49) at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:473:47) at processTicksAndRejections (node:internal/process/task_queues:105:5)
                                    zigbee.2
                                    2025-12-28 21:37:21.035	error	unhandled promise rejection: Cannot request when znp has not been initialized yet
                                    zigbee.2
                                    2025-12-28 21:37:21.035	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    zigbee.2
                                    2025-12-28 21:34:32.288	info	Failed to ping 0x7cb03eaa00ae0410 Gardenpole Mini RGBW OSRAM for {"failed":1,"reported":0} attempts
                                    zigbee.2
                                    2025-12-28 21:34:30.058	info	Failed to ping 0xa4c138a40c8b5793 TS0004 for {"failed":1,"reported":0} attempts
                                    zigbee.2
                                    2025-12-28 21:34:23.755	error	Adapter disconnected, stopping
                                    Herzliche Grüße und eine gute Nacht aus Köln
                                    Fabio
                                    Iobroker:
                                    • Matter over Thread Hilfe
                                    • pmayerP Offline
                                      pmayerP Offline
                                      pmayer
                                      #238
                                      Sorry. Ich hab da gerade keine Idee...
                                        BigChris
                                        #239
                                        Für mich klingt das enorm nach Netzwerkproblemen, nicht nach den Koordinatoren.
                                        • FabioF Fabio
                                          igbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          admin.0
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          host.nuc
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          zigbee.2
                                          Fabio
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #240
                                          @Fabio da sind wir ja Nachbarn.. komme aus Oberhausen
                                          steigen die 3 immer zur gleichen Zeit aus ?? was hast du zu hause an Geräten.. Fritte und was noch ?? managed switch ?
