  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 248.0k Aufrufe 78 Beobachtet
  • GarganoG Gargano
    Seit letzter Woche wird mein Account für 24h gesperrt ,wenn ich den Adapter starte. Auch die App geht dann nicht mehr.
    Ich hatte den Adapter auf 3.2.4 upgedatet . Seitdem der Fehler auch mit älteren Versionen .
    Hat noch jemand das Problem ?
    Hier der Log :
    worx.0
    2025-06-15 18:32:29.748	info	terminating
    worx.0
    2025-06-15 18:32:29.246	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    worx.0
    2025-06-15 18:32:29.244	debug	Plugin sentry destroyed
    worx.0
    2025-06-15 18:32:29.243	info	terminating
    worx.0
    2025-06-15 18:32:29.241	info	Got terminate signal TERMINATE_YOURSELF
    worx.0
    2025-06-15 18:29:59.662	info	Start check devices object!
    worx.0
    2025-06-15 18:29:59.662	debug	Start refreshTokenInterval!
    worx.0
    2025-06-15 18:29:59.661	warn	No mower found to start mqtt
    worx.0
    2025-06-15 18:29:59.660	info	Start MQTT connection
    worx.0
    2025-06-15 18:29:59.641	error	"429 TOO MANY REQUESTS"
    worx.0
    2025-06-15 18:29:59.641	error	AxiosError: Request failed with status code 429
    worx.0
    2025-06-15 18:29:59.485	error	"429 TOO MANY REQUESTS"
    worx.0
    2025-06-15 18:29:59.485	error	AxiosError: Request failed with status code 429
    worx.0
    2025-06-15 18:29:59.315	info	Start login
    worx.0
    2025-06-15 18:29:59.314	debug	Session value: 0
    worx.0
    2025-06-15 18:29:59.312	error	"429 TOO MANY REQUESTS"
    worx.0
    2025-06-15 18:29:59.312	error	AxiosError: Request failed with status code 429
    worx.0
    2025-06-15 18:29:58.977	debug	Refresh token
    worx.0
    2025-06-15 18:29:58.976	debug	Use old session for refresh token!
    worx.0
    2025-06-15 18:29:58.976	debug	Old session {"token_type":"Bearer","expires_in":3600,"access_token":yyyyy
    worx.0
    2025-06-15 18:29:58.967	info	Login to worx
    worx.0
    2025-06-15 18:29:58.965	info	Changed timeout for edgecut to 5000
    worx.0
    2025-06-15 18:29:58.961	info	Use new aws-iot-device-sdk-v2.
    worx.0
    2025-06-15 18:29:58.773	debug	Server have not been changed!
    worx.0
    2025-06-15 18:29:58.770	debug	User and password have not been changed!
    worx.0
    2025-06-15 18:29:58.671	info	starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.worx, node: v20.18.3, js-controller: 7.0.7
    worx.0
    2025-06-15 18:29:58.476	debug	Plugin sentry Initialize Plugin (enabled=true)
    worx.0
    2025-06-15 18:29:58.456	debug	States connected to redis: xxxx
    worx.0
    2025-06-15 18:29:58.452	debug	States create User PubSub Client
    worx.0
    2025-06-15 18:29:58.452	debug	States create System PubSub Client
    worx.0
    2025-06-15 18:29:58.449	debug	Redis States: Use Redis connection: xxxxx
    worx.0
    2025-06-15 18:29:58.442	debug	Objects connected to redis: xxxxx
    worx.0
    2025-06-15 18:29:58.439	debug	Objects client initialize lua scripts
    worx.0
    2025-06-15 18:29:58.380	debug	Objects create User PubSub Client
    worx.0
    2025-06-15 18:29:58.380	debug	Objects create System PubSub Client
    worx.0
    2025-06-15 18:29:58.379	debug	Objects client ready ... initialize now
    worx.0
    2025-06-15 18:29:58.367	debug	Redis Objects: Use Redis connection
    haselchenH Offline
    haselchenH Offline
    haselchen
    #241
    @gargano
    Guck bitte hier und machen da auch weiter....
    https://forum.iobroker.net/topic/74380/adapter-worx-landroid-v3-x-x/239
    • haselchenH haselchen
      @gargano
      HomoranH Offline
      HomoranH Offline
      #242
      @haselchen Danke!
      7ch hab's zusammengeführt
        @haselchen Danke!
        GarganoG Offline
        GarganoG Offline
        Gargano
        #243
        @homoran Danke fürs Zusammenführen. Ich habs leider nicht gefunden.
        • GarganoG Gargano
          Hier der Log :
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          eve11
          schrieb am zuletzt editiert von eve11
          #244
          @gargano
          Bei mir das selbe Problem.
          Ich warte jetzt bis morgen und probiere es noch einmal.
          Nach 24 Stunden kann ich die App wieder starten, aber sobald ich den Adapter starte kommt die Fehlermeldung und die App geht nicht mehr. Alle Blockly Scripts habe ich deaktiviert.
          Berichte dann morgen wieder.
          L 1 Antwort Letzte Antwort
          • E eve11
            @gargano
            Lucky_ESA
            #245
            @eve11 sagte in Adapter Worx Landroid v3.x.x:
            @gargano
            Wenn das wirklich so ist dann bitte erst in der Instanz Einstellungen den roten Button drücken. Schau dann zur Sicherheit nach, ob das State worx.0.loginInfo wirklich leer ist.
            Gruß//Lucky
            E 1 Antwort Letzte Antwort
            • L Lucky_ESA
              @gargano
              Gruß//Lucky
              eve11
              #246
              @lucky_esa
              Wenn ich den Button "Sitzungsdaten löschen" betätige wird an diesem State nichts verändert.
              Sollte ich mal den ganzen Adapter deinstallieren und wieder installieren ?
              • E eve11
                @lucky_esa
                GarganoG Offline
                GarganoG Offline
                Gargano
                #247
                @eve11 Hab gerade neu installiert, muss trotzdem die 24 Stunden abwarten, da er keine Daten holen kann.
                • GarganoG Gargano
                  eve11
                  #248
                  @gargano
                  Ich denke bevor die 24 Stunden nicht abgelaufen sind, wird eine Adapter Neuinstallation nichts bringen
                  • E eve11
                    @gargano
                    Lucky_ESA
                    #249
                    @gargano
                    Das ist korrekt.
                    • arteckA arteck
                      @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                      Warum sollte man auch so viele Befehle senden??????
                      weils geht .. das ist das Problem.. :-)
                      @NewPaint2 es liegt meisten an dem Nutzer.. und der Konfiguration.. ergo.. check die nochmal.. und nicht nur dich . sondern auch das iphone deiner Frau.. oder oder.. bedenke ALLE Verbindungen werden gezählt. auch die vom Testsystem ..
                      N Offline
                      N Offline
                      NewPaint2
                      #250
                      @arteck Nein, das war auch mein erster Gedanke. Habs nur auf meinem Telefon als App und nur eine Instanz im IOB laufen. Ich warte mal ob sich was ändert wenn die Sperrung aufgehoben ist. Scripte zum Abrufen über Worx habe ich nicht am Laufen, ich nutze nur die States für 2 Sonoff NSPanels. Das sollte aber eigentlich nicht neue Daten abfordern. Wie gesagt ich warte mal die Sperrung ab, bis jetzt läuft er ja trotz Sperrung über meinen Rasen.
                      • N NewPaint2
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #251
                        @newpaint2 sagte in Adapter Worx Landroid v3.x.x:
                        warum sollte er nicht laufen.. es geht ja nur um den Zugriff auf die Server..
                        • EvilElsE Offline
                          EvilElsE Offline
                          EvilEls
                          #252
                          Selbes 429 Problem be mir mit v3.2.4
                          Ich glaube aber nicht, dass es am Adapter liegt.
                          Habe Adapter und App ~48h nicht benutzt. Roboter aus.
                          Dann habe ich über App den Mähplan und Rasen geändert um API Zugriffe zu provozieren. Schon beim dritten Versuch die Mähzeiten zu verändern wurde ich geblockt.
                          Kein Adapter an zu der Zeit.
                          GarganoG haselchenH E 3 Antworten Letzte Antwort
                          • EvilElsE EvilEls
                            GarganoG Offline
                            GarganoG Offline
                            Gargano
                            #253
                            @evilels Hat jemand schon beim Worx Service nachgefragt, ob die etwas geändert haben ?
                            • GarganoG Gargano
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #254
                              @gargano
                              Was sollte das bringen ?
                              Bei mir läuft alles tutti.
                              2 mal die App in Benutzung plus Blockly Skript.
                              Guckt mal bei euch wie @Lucky_ESA schon schrieb, ob da nicht zu viele Abfragen, wo auch immer, bei euch sind.
                              Oder einfach mal die App oder das Skript 2 Tage unbenutzt lassen.
                              • EvilElsE EvilEls
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                #255
                                @evilels
                                Das hat ja nix mit dem Adapter zu tun.
                                Ein App Problem solltest Du mit dem Support klären.
                                • EvilElsE EvilEls
                                  eve11
                                  #256
                                  @evilels
                                  Ich konnte dies nun auch nachvollziehen. Ich habe alles bezgl. Worx im IoBroker deaktiviert. Nach 48 Stunden habe ich jetzt die App nur für 1 Minute geöffnet. Nach 2 x aktualisieren in der App bin ich wieder geblockt.
                                  Komisch ist es aber schon, dass dies genau dann aufgetreten ist, nachdem ich von 3.2.2 auf 3.2.3 ein Update installiert habe.
                                  • E Offline
                                    eve11
                                    #257
                                    Kennt jemand die Mail Adresse vom Worx App support ?
                                    Vielen Dank
                                    Hat sich erledigt:
                                    app-support@positecgroup.com
                                    • E Offline
                                      eve11
                                      #258
                                      Ich habe jetzt mal versucht mich auf der Homepage von Worx anzumelden.
                                      Auf der Arbeit konnte ich mich anmelden nachdem ich von der App geblockt wurde.
                                      Zuhause bekomme ich auch die selbe Fehlermeldung.
                                      Ich habe es versucht auf unterschiedlichen Computern als auch Browser. Immer die selbe Meldung. Ich musste aber nie
                                      meine Anmeldedaten eingeben. Wieso muss ich nirgends im Browser auf der Worx Homepage meine Daten eingeben ?
                                      Wird dies irgendwie von Google synchronisiert ?
                                      Dr. BakteriusD L 2 Antworten Letzte Antwort
                                      • E eve11
                                        Dr. BakteriusD Offline
                                        Dr. Bakterius
                                        #259
                                        @eve11 Möglicherweise ist die IP auf einer Art Sperrliste?
                                        EvilElsE 1 Antwort Letzte Antwort
                                        • E eve11
                                          Lucky_ESA
                                          #260
                                          @eve11 Hast du den Support mal angeschrieben?
                                          Gruß//Lucky
