  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 247.9k Aufrufe 78 Beobachtet
  • E Online
    E Online
    eve11
    schrieb am zuletzt editiert von eve11
    #231
    Hallo zusammen, nach update auf die aktuellste Version 3.2.3 hatte ich auf einmal folgendes Problem.
    (Bin aber wieder auf 3.2.2 zurück, Problem bestand aber weiterhin)
    worx.0
    2025-06-14 15:53:28.245	error	"429 TOO MANY REQUESTS"
    worx.0
    2025-06-14 15:53:28.244	error	AxiosError: Request failed with status code 429
    worx.0
    2025-06-14 15:53:28.027	info	Start login
    worx.0
    2025-06-14 15:53:28.027	debug	Session value: 0
    worx.0
    2025-06-14 15:53:27.980	info	Login to worx
    worx.0
    2025-06-14 15:53:27.979	info	Changed timeout for edgecut to 5000
    worx.0
    2025-06-14 15:53:27.978	info	Use new aws-iot-device-sdk-v2.
    worx.0
    2025-06-14 15:53:27.855	debug	Server have not been changed!
    worx.0
    2025-06-14 15:53:27.854	debug	User and password have not been changed!
    worx.0
    2025-06-14 15:53:27.829	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.3
    worx.0
    2025-06-14 15:53:27.643	debug	Plugin sentry Initialize Plugin (enabled=true)
    worx.0
    2025-06-14 15:53:27.607	debug	States connected to redis: 127.0.0.1:9000
    worx.0
    2025-06-14 15:53:27.525	debug	States create User PubSub Client
    worx.0
    2025-06-14 15:53:27.524	debug	States create System PubSub Client
    worx.0
    2025-06-14 15:53:27.502	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    worx.0
    2025-06-14 15:53:27.465	debug	Objects connected to redis: 127.0.0.1:9001
    worx.0
    2025-06-14 15:53:27.460	debug	Objects client initialize lua scripts
    worx.0
    2025-06-14 15:53:27.388	debug	Objects create User PubSub Client
    worx.0
    2025-06-14 15:53:27.387	debug	Objects create System PubSub Client
    worx.0
    2025-06-14 15:53:27.387	debug	Objects client ready ... initialize now
    worx.0
    2025-06-14 15:53:27.352	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Auch in der App bekomme ich diese Meldung:
    Das interessante an der ganzen Sache ist, dass ich den Mäher gar nicht im Einsatz hatte. Weder über Iobroker noch über die App.
    Nach gut 24 Stunden kann ich die App wieder benutzen, aber sobald ich den Adapter starte bekomme ich wieder dieselbe Meldung. Das dementsprechende Blockly für die Vis habe deaktiviert.
    An den Einstellungen im Adapter habe ich nichts verändert.
    Vielen Dank für etwaige Rückmeldungen.
    Heiko
    L 1 Antwort Letzte Antwort
    • E eve11
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      Heiko
      L Online
      L Online
      Lucky_ESA
      #232
      @eve11 Du musst den Adapter auf debug stellen damit mal mehr sieht. Hast du jetzt auch eine Sperre mit der Version 3.2.2?
      E 1 Antwort Letzte Antwort
      • L Lucky_ESA
        E Online
        E Online
        eve11
        #233
        @lucky_esa
        Ja, ich habe jetzt die Sperre auch auf 3.2.2.
        Der Adapter steht schon auf Debug.
        Vielen Dank
        Zeit
        debug
        Nachricht
        worx.0
        2025-06-14 16:50:08.316	error	"429 TOO MANY REQUESTS"
        worx.0
        2025-06-14 16:50:08.315	error	AxiosError: Request failed with status code 429
        worx.0
        2025-06-14 16:50:08.080	info	Start login
        worx.0
        2025-06-14 16:50:08.079	debug	Session value: 0
        worx.0
        2025-06-14 16:50:08.028	info	Login to worx
        worx.0
        2025-06-14 16:50:08.027	info	Changed timeout for edgecut to 5000
        worx.0
        2025-06-14 16:50:08.027	info	Use new aws-iot-device-sdk-v2.
        worx.0
        2025-06-14 16:50:07.977	debug	Server have not been changed!
        worx.0
        2025-06-14 16:50:07.977	debug	User and password have not been changed!
        worx.0
        2025-06-14 16:50:07.905	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.3
        worx.0
        2025-06-14 16:50:07.691	debug	Plugin sentry Initialize Plugin (enabled=true)
        worx.0
        2025-06-14 16:50:07.656	debug	States connected to redis: 127.0.0.1:9000
        worx.0
        2025-06-14 16:50:07.570	debug	States create User PubSub Client
        worx.0
        2025-06-14 16:50:07.569	debug	States create System PubSub Client
        worx.0
        2025-06-14 16:50:07.546	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        worx.0
        2025-06-14 16:50:07.502	debug	Objects connected to redis: 127.0.0.1:9001
        worx.0
        2025-06-14 16:50:07.499	debug	Objects client initialize lua scripts
        worx.0
        2025-06-14 16:50:07.435	debug	Objects create User PubSub Client
        worx.0
        2025-06-14 16:50:07.434	debug	Objects create System PubSub Client
        worx.0
        2025-06-14 16:50:07.434	debug	Objects client ready ... initialize now
        worx.0
        2025-06-14 16:50:07.401	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        • E eve11
          @lucky_esa
          Vielen Dank
          Zeit
          debug
          Nachricht
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          worx.0
          L Online
          L Online
          Lucky_ESA
          #234
          @eve11
          Vermutlich ist die APP jetzt auch gesperrt, oder?
          Was steht denn unter:
          worx.0.xxx.mower.last_command
          worx.0.loginInfo
          Du bist ja gesperrt und daher kann nichts mehr zu Cloud gesendet werden. Es wäre besser ein debug Log wenn du wieder entsperrt bist.
          Gruß//Lucky
          • L Lucky_ESA
            @eve11
            worx.0.loginInfo
            Gruß//Lucky
            E Online
            E Online
            eve11
            #235
            @lucky_esa
            Ja, die App ist auch gesperrt. Ich werde jetzt Mal 24 Stunden abwarten und dann wieder berichten. Vielen Dank
            • N Offline
              N Offline
              NewPaint2
              #236
              Scheinbar macht es die Runde mit den Sperrungen, ist bei mir auch seit gestern, obwohl ich auf 60 Min stehe und nur übers IPhone die App nutze... tolle Idee des Hersteller Geräte zu verkaufen die IOT-fähig sind und dann die Zugänge zu limitieren. Das war doch mal Verkaufsargument bei Worx.
              • L Lucky_ESA
                @leiniac Kannst du bitte mal von GIT laden?
                LeiniAC
                #237
                @lucky_esa Heute Morgen war die 3.2.4 verfügbar und die scheint den Fehler ausgebügelt zu haben. Nach dem Update startet der Adapter und beide Fehlermeldungen tauchen nicht mehr auf. Die Ojekte sind auch alle da.
                • N NewPaint2
                  L Online
                  L Online
                  Lucky_ESA
                  #238
                  @newpaint2 sagte in Adapter Worx Landroid v3.x.x:
                  Worx ist sehr kundenfreundlich und stellt uns Entwickler eine sehr gute API zur Verfügung was andere Anbieter nicht machen. Die Limitierung ist sehr hoch und daher eigentlich schwer zu erreichen. Wenn ihr in diese Sperrung kommt, dann sind es immer fehlerhafte Scripte oder ich habe einen unbekannten Fehler im Adapter. Also, bitte nach der Entsperrung den Adapter auf debug stellen und bei einer Sperrung, mir euer Log zur Verfügung stellen.
                  Befehle werden allerdings komuliert: APP Papa + APP Mama + APP Tochter + iobroker Instanz 0 + iobroker Instanz 1 usw...
                  Da kann es schnell zu einer Sperrung kommen.
                  Es gibt 2 Verbindungen - 1. Verbindung API: Hier kann der Intervall in den Einstellungen gesetzt werden. Dieser Intervall holte sich alle Daten von der API. Bsp. ihr ändert in der APP den Namen vom Mäher, dann kommt diese Änderung bei euch an, wenn der Intervall seine Zeit erreicht hat. Mit Aktualisierung der Daten nach der Token-Aktualisierung wird auch alle 60 Minuten die Daten geholt...Das kann ich eigentlich mal entfernen es sei denn, man stellt den Intervall auf 1440 und setzt dann den Haken.
                  2. MQTT Verbindung: Diese ist eine dauerhafte Verbindung die alle 60 Minuten kurz abbricht um den neuen Token anzuwenden. Über diese Verbindung versendet der Adapter eure Befehle. Wenn hier jede Minute was versendet wird, dann werdet ihr gesperrt. Warum sollte man auch so viele Befehle senden?????? Eigentlich kommt hier alle 10 Minuten automatisch ein Update der Daten vom Mäher. Bei wichtige Änderungen kommen sofort Daten.
                  Wenn ich jetzt die API von Worx mit anderen vergleiche, dann ist Worx auf Platz 1.
                  Gruß//Lucky
                  • L Lucky_ESA
                    Gruß//Lucky
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #239
                    @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                    weils geht .. das ist das Problem.. :-)
                    @NewPaint2 es liegt meisten an dem Nutzer.. und der Konfiguration.. ergo.. check die nochmal.. und nicht nur dich . sondern auch das iphone deiner Frau.. oder oder.. bedenke ALLE Verbindungen werden gezählt. auch die vom Testsystem ..
                    N 1 Antwort Letzte Antwort
                    • GarganoG Offline
                      GarganoG Offline
                      Gargano
                      #240
                      Seit letzter Woche wird mein Account für 24h gesperrt ,wenn ich den Adapter starte. Auch die App geht dann nicht mehr.
                      Ich hatte den Adapter auf 3.2.4 upgedatet . Seitdem der Fehler auch mit älteren Versionen .
                      Hat noch jemand das Problem ?
                      Hier der Log :
                      worx.0
                      2025-06-15 18:32:29.748	info	terminating
                      worx.0
                      2025-06-15 18:32:29.246	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      worx.0
                      2025-06-15 18:32:29.244	debug	Plugin sentry destroyed
                      worx.0
                      2025-06-15 18:32:29.243	info	terminating
                      worx.0
                      2025-06-15 18:32:29.241	info	Got terminate signal TERMINATE_YOURSELF
                      worx.0
                      2025-06-15 18:29:59.662	info	Start check devices object!
                      worx.0
                      2025-06-15 18:29:59.662	debug	Start refreshTokenInterval!
                      worx.0
                      2025-06-15 18:29:59.661	warn	No mower found to start mqtt
                      worx.0
                      2025-06-15 18:29:59.660	info	Start MQTT connection
                      worx.0
                      2025-06-15 18:29:59.641	error	"429 TOO MANY REQUESTS"
                      worx.0
                      2025-06-15 18:29:59.641	error	AxiosError: Request failed with status code 429
                      worx.0
                      2025-06-15 18:29:59.485	error	"429 TOO MANY REQUESTS"
                      worx.0
                      2025-06-15 18:29:59.485	error	AxiosError: Request failed with status code 429
                      worx.0
                      2025-06-15 18:29:59.315	info	Start login
                      worx.0
                      2025-06-15 18:29:59.314	debug	Session value: 0
                      worx.0
                      2025-06-15 18:29:59.312	error	"429 TOO MANY REQUESTS"
                      worx.0
                      2025-06-15 18:29:59.312	error	AxiosError: Request failed with status code 429
                      worx.0
                      2025-06-15 18:29:58.977	debug	Refresh token
                      worx.0
                      2025-06-15 18:29:58.976	debug	Use old session for refresh token!
                      worx.0
                      2025-06-15 18:29:58.976	debug	Old session {"token_type":"Bearer","expires_in":3600,"access_token":yyyyy
                      worx.0
                      2025-06-15 18:29:58.967	info	Login to worx
                      worx.0
                      2025-06-15 18:29:58.965	info	Changed timeout for edgecut to 5000
                      worx.0
                      2025-06-15 18:29:58.961	info	Use new aws-iot-device-sdk-v2.
                      worx.0
                      2025-06-15 18:29:58.773	debug	Server have not been changed!
                      worx.0
                      2025-06-15 18:29:58.770	debug	User and password have not been changed!
                      worx.0
                      2025-06-15 18:29:58.671	info	starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.worx, node: v20.18.3, js-controller: 7.0.7
                      worx.0
                      2025-06-15 18:29:58.476	debug	Plugin sentry Initialize Plugin (enabled=true)
                      worx.0
                      2025-06-15 18:29:58.456	debug	States connected to redis: xxxx
                      worx.0
                      2025-06-15 18:29:58.452	debug	States create User PubSub Client
                      worx.0
                      2025-06-15 18:29:58.452	debug	States create System PubSub Client
                      worx.0
                      2025-06-15 18:29:58.449	debug	Redis States: Use Redis connection: xxxxx
                      worx.0
                      2025-06-15 18:29:58.442	debug	Objects connected to redis: xxxxx
                      worx.0
                      2025-06-15 18:29:58.439	debug	Objects client initialize lua scripts
                      worx.0
                      2025-06-15 18:29:58.380	debug	Objects create User PubSub Client
                      worx.0
                      2025-06-15 18:29:58.380	debug	Objects create System PubSub Client
                      worx.0
                      2025-06-15 18:29:58.379	debug	Objects client ready ... initialize now
                      worx.0
                      2025-06-15 18:29:58.367	debug	Redis Objects: Use Redis connection
                      haselchenH E 2 Antworten Letzte Antwort
                      • GarganoG Gargano
                        Hier der Log :
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        worx.0
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #241
                        @gargano
                        Guck bitte hier und machen da auch weiter....
                        https://forum.iobroker.net/topic/74380/adapter-worx-landroid-v3-x-x/239
                        • haselchenH haselchen
                          @gargano
                          #242
                          @haselchen Danke!
                          7ch hab's zusammengeführt
                          GarganoG 1 Antwort Letzte Antwort
                            @haselchen Danke!
                            GarganoG Offline
                            GarganoG Offline
                            Gargano
                            #243
                            @homoran Danke fürs Zusammenführen. Ich habs leider nicht gefunden.
                            • GarganoG Gargano
                              Hier der Log :
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              worx.0
                              E Online
                              E Online
                              eve11
                              #244
                              @gargano
                              Bei mir das selbe Problem.
                              Ich warte jetzt bis morgen und probiere es noch einmal.
                              Nach 24 Stunden kann ich die App wieder starten, aber sobald ich den Adapter starte kommt die Fehlermeldung und die App geht nicht mehr. Alle Blockly Scripts habe ich deaktiviert.
                              Berichte dann morgen wieder.
                              • E eve11
                                @gargano
                                L Online
                                L Online
                                Lucky_ESA
                                #245
                                @eve11 sagte in Adapter Worx Landroid v3.x.x:
                                @gargano
                                Wenn das wirklich so ist dann bitte erst in der Instanz Einstellungen den roten Button drücken. Schau dann zur Sicherheit nach, ob das State worx.0.loginInfo wirklich leer ist.
                                Gruß//Lucky
                                • L Lucky_ESA
                                  @gargano
                                  Gruß//Lucky
                                  E Online
                                  E Online
                                  eve11
                                  #246
                                  @lucky_esa
                                  Wenn ich den Button "Sitzungsdaten löschen" betätige wird an diesem State nichts verändert.
                                  Sollte ich mal den ganzen Adapter deinstallieren und wieder installieren ?
                                  • E eve11
                                    @lucky_esa
                                    GarganoG Offline
                                    GarganoG Offline
                                    Gargano
                                    #247
                                    @eve11 Hab gerade neu installiert, muss trotzdem die 24 Stunden abwarten, da er keine Daten holen kann.
                                    • GarganoG Gargano
                                      E Online
                                      E Online
                                      eve11
                                      #248
                                      @gargano
                                      Ich denke bevor die 24 Stunden nicht abgelaufen sind, wird eine Adapter Neuinstallation nichts bringen
                                      • E eve11
                                        @gargano
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #249
                                        @gargano
                                        Das ist korrekt.
                                        • arteckA arteck
                                          N Offline
                                          N Offline
                                          NewPaint2
                                          #250
                                          @arteck Nein, das war auch mein erster Gedanke. Habs nur auf meinem Telefon als App und nur eine Instanz im IOB laufen. Ich warte mal ob sich was ändert wenn die Sperrung aufgehoben ist. Scripte zum Abrufen über Worx habe ich nicht am Laufen, ich nutze nur die States für 2 Sonoff NSPanels. Das sollte aber eigentlich nicht neue Daten abfordern. Wie gesagt ich warte mal die Sperrung ab, bis jetzt läuft er ja trotz Sperrung über meinen Rasen.
