  4. vedirect keine Verbindung bei rasp 4
24 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    mere13
    Hallo
    nachdem vedirect von DrotmotiX am rasp 3b problemlos lief zusammen mit dem USB Kabel von victroenic (Bluesolar MPTT 100/50) bin ich auf rasp 4 umgestiegen und hab alles genauso installiert. iobroker und Adapter. Leider keine Verbindung zum USB. Hat jemand eine Idee, woran das liegt? Ein paar Details:
    Get error "Issue handling serial port connection : {}" and no connection to USB. power supply is no problem, because active usb hub. also tried without hub. same result. MPTT Bluesolar 100/50, ve.direct USB
    settings are /dev/ttyUSB0 , both times on 0sec
    is there an issue with rasp 4? any idea?
    These are my usb devices:
    usb-devices
    T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
    D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
    P: Vendor=1d6b ProdID=0002 Rev=06.06
    S: Manufacturer=Linux 6.6.20+rpt-rpi-v8 xhci-hcd
    S: Product=xHCI Host Controller
    S: SerialNumber=0000:01:00.0
    C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
    I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
    E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
    T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
    D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
    P: Vendor=2109 ProdID=3431 Rev=04.21
    S: Product=USB2.0 Hub
    C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
    E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
    T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 3 Spd=480 MxCh= 4
    D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
    P: Vendor=05e3 ProdID=0610 Rev=92.24
    S: Manufacturer=GenesysLogic
    I: If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
    T: Bus=01 Lev=03 Prnt=03 Port=03 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
    D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
    P: Vendor=0403 ProdID=6015 Rev=10.00
    S: Manufacturer=VictronEnergy BV
    S: Product=VE Direct cable
    S: SerialNumber=VE6WATIJ
    C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=90mA
    I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
    E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
    D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
    P: Vendor=1d6b ProdID=0003 Rev=06.06
    Versions:
    Adapter version: recent
    JS-Controller version: 5.0.19
    Node version: 18.20.2
    Operating system: rasp OS 64 bit
    • M mere13
      Hallo
      usb-devices
      Versions:
      @mere13 sagte in vedirect keine Verbindung bei rasp 4:
      incl. des identischen USB Ports?
      wie sieht die config aus?
      was ergibt bei dir
      pi@tinkerboard:~$ ls /dev/serial/by-id/
      usb-FTDI_FT232R_USB_UART_A10NBMVW-if00-port0
      usb-FTDI_FT232R_USB_UART_AB0OH9QR-if00-port0
      usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01066523-if00-port0
      pi@tinkerboard:~$
      • M mere13
        Hallo
        usb-devices
        Versions:
        Setz da den Link aus /dev/serial/by-id rein, nicht die Gerätedatei direkt.
          mere13
          @thomas-braun marcel@rasp:~ $ ls /dev/serial/by-id
          usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
          und was soll ich jetzt einsetzen?
          • M mere13
            genau das
            /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
            so wie hier
              mere13
              leider nicht besser
              Bildschirmfoto 2024-04-14 um 10.37.40.png Bildschirmfoto 2024-04-14 um 10.37.53.png
              Thomas BraunT M 2 Antworten Letzte Antwort
              • M mere13
                leider nicht besser
                @mere13
                Zeig mal die Langfassung von
                iob diag
                • M mere13
                  leider nicht besser
                  mere13
                  @mere13 iobdiagsummary.txt
                  • M mere13
                    @mere13
                    Das ist nicht die Langfassung sondern die Zusammenfassung.
                      @mere13
                      mere13
                      @thomas-braun sorry.
                      iobdiag.txt
                      • M mere13
                        iobdiag.txt
                        iobdiag.txt
                        bitte in code-tags gesetzt posten
                          iobdiag.txt
                          mere13
                          @homoran verstehe ich leider nicht. wie bekomme ich die code-tags? Hab alles per copy-paste übertragen. So?
                          ======== Start marking the full check here =========
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                           Static hostname: rasp
                                 Icon name: computer
                                    Kernel: Linux 6.6.20+rpt-rpi-v8
                              Architecture: arm64
                          Model		: Raspberry Pi 4 Model B Rev 1.5
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : arm64
                          Systemuptime and Load:
                           11:15:46 up 1 day,  1:06,  3 users,  load average: 0.14, 0.26, 0.34
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Sun 2024-04-14 11:15:47 CEST
                                     Universal time: Sun 2024-04-14 09:15:47 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          marcel
                          /home/marcel
                          marcel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server: 	false
                          Desktop:
                          Terminal: 	tty
                          Boot Target: 	graphical.target
                          *** MEMORY ***
                          Mem:            8.2G        1.2G        5.7G        1.4M        1.4G        6.9G
                          Swap:           104M          0B        104M
                          Total:          8.3G        1.2G        5.8G
                                   7810 M total memory
                                   1184 M used memory
                                   1421 M active memory
                                    775 M inactive memory
                                   5445 M free memory
                                    122 M buffer memory
                                   1181 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          lifetime oom required: 0 Mbytes
                          total time in oom handler: 0 ms
                          max time spent in oom handler: 0 ms
                          *** FAILED SERVICES ***
                            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                          * lightdm.service loaded failed failed Light Display Manager
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          udev           devtmpfs  3.6G     0  3.6G   0% /dev
                          tmpfs          tmpfs     782M  1.3M  780M   1% /run
                          /dev/mmcblk0p2 ext4       58G  6.4G   48G  12% /
                          tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
                          tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                          /dev/mmcblk0p1 vfat      510M   82M  429M  17% /boot/firmware
                          tmpfs          tmpfs     782M   28K  781M   1% /run/user/1000
                          [Sat Apr 13 10:09:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B1:D2:3A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8a167c7b-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                          [Sat Apr 13 10:09:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
                          [Sat Apr 13 10:09:09 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
                          Show mounted filesystems \(real ones only\):
                          TARGET           SOURCE         FSTYPE OPTIONS
                          /                /dev/mmcblk0p2 ext4   rw,noatime
                          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          870M	/var/
                          341M	/var/cache
                          334M	/var/cache/apt
                          322M	/var/lib
                          221M	/var/cache/apt/archives
                          Archived and active journals take up 104.0M in the file system.
                          /opt/iobroker/backups:
                          2.9M	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          62M	/opt/iobroker/iobroker-data/
                          31M	/opt/iobroker/iobroker-data/backup-objects
                          19M	/opt/iobroker/iobroker-data/files
                          13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                          8.8M	/opt/iobroker/iobroker-data/objects.jsonl
                          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                          4.6M	/opt/iobroker/iobroker-data/states.jsonl
                          2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                          2.6M	/opt/iobroker/iobroker-data/files/ble.admin/build/index.js.map
                          USB-Devices by-id:
                          USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs 	v18.20.2
                          /usr/bin/node 		v18.20.2
                          /usr/bin/npm 		10.5.0
                          /usr/bin/npx 		10.5.0
                          /usr/bin/corepack 	0.25.2
                          nodejs:
                            Installed: 18.20.2-1nodesource1
                            Candidate: 18.20.2-1nodesource1
                            Version table:
                           *** 18.20.2-1nodesource1 600
                                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                  100 /var/lib/dpkg/status
                               18.20.1-1nodesource1 600
                               18.20.0-1nodesource1 600
                               18.19.1-1nodesource1 600
                               18.19.0+dfsg-6~deb12u1 500
                               18.19.0-1nodesource1 600
                               18.18.2-1nodesource1 600
                               18.18.1-1nodesource1 600
                               18.18.0-1nodesource1 600
                               18.17.1-1nodesource1 600
                               18.17.0-1nodesource1 600
                               18.16.1-1nodesource1 600
                               18.16.0-1nodesource1 600
                               18.15.0-1nodesource1 600
                               18.14.2-1nodesource1 600
                               18.14.1-1nodesource1 600
                               18.14.0-1nodesource1 600
                               18.13.0+dfsg1-1 500
                               18.13.0-1nodesource1 600
                               18.12.0-1nodesource1 600
                               18.11.0-1nodesource1 600
                               18.10.0-1nodesource1 600
                               18.9.1-1nodesource1 600
                               18.9.0-1nodesource1 600
                               18.8.0-1nodesource1 600
                               18.7.0-1nodesource1 600
                               18.6.0-1nodesource1 600
                               18.5.0-1nodesource1 600
                               18.4.0-1nodesource1 600
                               18.3.0-1nodesource1 600
                               18.2.0-1nodesource1 600
                               18.1.0-1nodesource1 600
                               18.0.0-1nodesource1 600
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller: 	5.0.19
                          admin: 		6.13.16
                          javascript: 	"javascript" not found
                          Adapters from github: 	1
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : rasp                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : rasp                                     -  enabled
                          + system.adapter.ble.0                    : ble                   : rasp                                     -  enabled
                          + system.adapter.discovery.0              : discovery             : rasp                                     -  enabled
                          + system.adapter.influxdb.0               : influxdb              : rasp                                     -  enabled, port: 8086
                          + system.adapter.mqtt.0                   : mqtt                  : rasp                                     -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.mystrom.0                : mystrom               : rasp                                     -  enabled
                          + system.adapter.vedirect.0               : vedirect              : rasp                                     -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 6.13.16  , installed 6.13.16
                          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                          Adapter    "ble"          : 0.14.0   , installed 0.14.0
                          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                          Controller "js-controller": 5.0.19   , installed 5.0.19
                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                          Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
                          Objects and States
                          Objects: 	385
                          States: 	287
                          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          Hit:6 https://apt.grafana.com stable InRelease
                          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2106529    42615/cupsd
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       42475      11730/io.mqtt.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8479       1072/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8472       1072/iobroker.js-co
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9234       778/sshd: /usr/sbin
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        6022       896/influxd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7635       1122/io.admin.0
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2106528    42615/cupsd
                          tcp6       0      0 :::3000                 :::*                    LISTEN      113        6061       1071/grafana
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          9236       778/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1857       626/dhcpcd: [networ
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2107407    42643/cups-browsed
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7074       570/avahi-daemon: r
                          udp        0      0 0.0.0.0:38954           0.0.0.0:*                           104        7076       570/avahi-daemon: r
                          udp6       0      0 :::36418                :::*                                104        7077       570/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          1859       626/dhcpcd: [networ
                          udp6       0      0 :::5353                 :::*                                104        7075       570/avahi-daemon: r
                          2024-04-14 10:37:15.420  - debug: vedirect.0 (70677) Objects client ready ... initialize now
                          2024-04-14 10:37:15.423  - debug: vedirect.0 (70677) Objects create System PubSub Client
                          2024-04-14 10:37:15.425  - debug: vedirect.0 (70677) Objects create User PubSub Client
                          2024-04-14 10:37:15.461  - debug: vedirect.0 (70677) Objects client initialize lua scripts
                          2024-04-14 10:37:15.470  - debug: vedirect.0 (70677) Objects connected to redis: 127.0.0.1:9001
                          2024-04-14 10:37:15.488  - debug: vedirect.0 (70677) Redis States: Use Redis connection: 127.0.0.1:9000
                          2024-04-14 10:37:15.496  - debug: vedirect.0 (70677) States create System PubSub Client
                          2024-04-14 10:37:15.497  - debug: vedirect.0 (70677) States create User PubSub Client
                          2024-04-14 10:37:15.511  - debug: vedirect.0 (70677) States connected to redis: 127.0.0.1:9000
                          2024-04-14 10:37:15.541  - debug: vedirect.0 (70677) Plugin sentry Initialize Plugin (enabled=true)
                          2024-04-14 10:37:15.965  - info: vedirect.0 (70677) starting. Version 0.3.3 (non-npm: DrozmotiX/ioBroker.vedirect#8435302add9dc410535180c6c0d5ebbaef2eeb1e) in /opt/iobroker/node_modules/iobroker.vedirect, node: v18.20.2, js-controller: 5.0.19
                          2024-04-14 10:37:15.987  - info: vedirect.0 (70677) Starting VE.Direct with Protocol Version 3.33 and configurable expiring state capability
                          2024-04-14 10:37:15.998  - error: vedirect.0 (70677) Issue handling serial port connection : {}
                          2024-04-14 10:37:45.453  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                          2024-04-14 10:37:55.638  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201
                          2024-04-14 10:39:42.298  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                          2024-04-14 10:40:09.177  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
                          2024-04-14 10:43:51.983  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                          2024-04-14 10:44:41.987  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                          2024-04-14 10:57:05.970  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                          2024-04-14 11:01:56.002  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                          2024-04-14 11:06:49.715  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                          2024-04-14 11:08:09.723  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                          2024-04-14 11:10:09.427  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
                          2024-04-14 11:14:58.222  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                          iob diag has finished.
                          Press any key for a summary
                          • M mere13
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            marcel
                            /home/marcel
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:           104M          0B        104M
                                     7810 M total memory
                                     1184 M used memory
                                     5445 M free memory
                                      122 M buffer memory
                                     1181 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            870M	/var/
                            341M	/var/cache
                            334M	/var/cache/apt
                            322M	/var/lib
                            USB-Devices by-id:
                            /usr/bin/npm 		10.5.0
                            /usr/bin/npx 		10.5.0
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.13.16
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	385
                            States: 	287
                            Pending Updates: 0
                            da steht er.
                            in deinem Screenshot leider nicht zu lesen.
                            Aber da sind anscheinend Leerzeichen verwendet und der abschließende Slash fehlt
                            • M mere13
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              marcel
                              /home/marcel
                              X-Server: 	false
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Swap:           104M          0B        104M
                                       7810 M total memory
                                       1184 M used memory
                                       5445 M free memory
                                        122 M buffer memory
                                       1181 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              870M	/var/
                              341M	/var/cache
                              334M	/var/cache/apt
                              322M	/var/lib
                              USB-Devices by-id:
                              /usr/bin/npm 		10.5.0
                              /usr/bin/npx 		10.5.0
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin: 		6.13.16
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects: 	385
                              States: 	287
                              Pending Updates: 0
                              Setz das auf
                              sudo systemctl set-default multi-user.target
                              Nach einem Neustart:
                              ls -la /dev/serial/by-id
                                mere13
                                @thomas-braun said in vedirect keine Verbindung bei rasp 4:
                                Bekomme das:
                                total 0
                                drwxr-xr-x 2 root root 60 Apr 14 12:29 .
                                drwxr-xr-x 4 root root 80 Apr 14 12:29 ..
                                lrwxrwxrwx 1 root root 13 Apr 14 12:29 usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0 -> ../../ttyUSB0
                                und im Adapter ist das eingetragen, keine Leerzeichen
                                /dev/serial/by-id usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
                                DJMarc75D HomoranH 2 Antworten Letzte Antwort
                                • M mere13
                                  Bekomme das:
                                  total 0
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  keine Leerzeichen
                                  doch, zwischen id und usb
                                  Lehrling seit 1975 !!!
                                  • DJMarc75D DJMarc75
                                    keine Leerzeichen
                                    mere13
                                    @djmarc75 ok. sorry, war blind. habs jetzt korrigiert und mit / ersetzt. Was meintest Du mit abschließendem Slash? Jetzt steht das da, aber leider noch keine Verbindung:
                                    • M mere13
                                      @mere13
                                      Es muss exakt das eingetragen werden:
                                      Rechte sind vorhanden?
                                      ls -la /dev/ttyUSB0
                                      sudo -u iobroker groups
                                        mere13
                                        mit copy-paste übertragen. leider nix.
                                        marcel@rasp:~ $ ls -la /dev/ttyUSB0
                                        crw-rw----+ 1 root plugdev 188, 0 Apr 14 12:29 /dev/ttyUSB0
                                        iobroker tty dialout audio video bluetooth gpio i2c
                                        • M mere13
                                          leider nix.
                                          Wie nix? Da sind doch die Ausgaben. Würde man besser sehen, wenn du freundlicherweise für solche Ausgaben aus der Konsole die CodeTags verwenden würdest.
                                          Der user 'iobroker' ist nicht in der Gruppe 'plugdev' drin. Deswegen darf der mit dem Gerät nix anfangen.
                                          Setz den da rein:
                                          sudo usermod -a -G plugdev iobroker
                                          iob stop
                                          sudo reboot
                                          Sollte danach funktionieren.
