  4. npm Error bei mihome-vacuum Adapter Installation
33 Beiträge 7 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • WintermuteW Wintermute
    Ich habe gerade das Update auf die 4.2.0 und habe das Problem, dass die Installation offenbar sauber durchläuft, der Adapter aber nicht mehr startet ("Verbunden mit Gerät oder Dienst" ist grün, der Rest rot)
    iob update und iob upgrade hab ich probiert, keine Resultate:
    C:\ioBroker>iob update
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "deconz"       : 1.4.0    , installed 1.4.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.1  [Updatable]
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    C:\ioBroker>iob upgrade
    This upgrade of "vis" will introduce the following changes:
    -> 1.5.4:
    added the new binding operation for getting property of JSON or object
    Checked the initialization of the `local_` variables
    fixed subscribeOidAtRuntime
    Added dynamic web manifest
    Optimization for basic-view in widget8
    Changed binding regex to accept umlauts
    Corrected first installation of vis
    Would you like to upgrade vis from @1.5.1 to @1.5.4 now? [(y)es, (n)o]: n
    No upgrade of "vis" desired.
    Vis habe ich aus Gründen nicht aktualisiert, weil ansonsten einige ältere Tablets nicht mehr klarkommen.
    Ein "Iob fix" bringt:
    Need to install the following packages:
      @iobroker/fix@5.0.0
    Ok to proceed? (y) y
    "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
    npm notice
    npm notice New major version of npm available! 9.5.0 -> 10.5.2
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.2
    npm notice Run npm install -g npm@10.5.2 to update!
    npm notice
    Hat das Eine mit dem Anderen zu tun?
    @wintermute
    bei Windows bin ich raus..
    WintermuteW 1 Antwort Letzte Antwort
    • P pusemuckel
      ich habe das gleiche Problem seit dem Update auf die neue Version
      host.iobroker
      	2024-04-19 16:31:31.427	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2024-04-19 16:31:31.426	error	Caught by controller[1]: Node.js v20.12.2
      host.iobroker
      	2024-04-19 16:31:31.426	error	Caught by controller[0]: }
      host.iobroker
      	2024-04-19 16:31:31.425	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
      host.iobroker
      	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
      host.iobroker
      	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
      host.iobroker
      	2024-04-19 16:31:31.424	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.iobroker
      	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      host.iobroker
      	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
      host.iobroker
      	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
      host.iobroker
      	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
      host.iobroker
      	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
      host.iobroker
      	2024-04-19 16:31:31.418	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
      host.iobroker
      	2024-04-19 16:31:31.418	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
      host.iobroker
      	2024-04-19 16:31:31.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
      host.iobroker
      	2024-04-19 16:31:31.417	error	Caught by controller[0]: ^
      host.iobroker
      	2024-04-19 16:31:31.417	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
      host.iobroker
      	2024-04-19 16:31:31.416	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
      Hat jemand eine Idee wo man schauen muss um das zu korrigieren ?
      Danke!
      @pusemuckel
      ist nicht der gleiche Fehler, wie der TE hat, aber irgendein script scheint filename falsch deklariert zu haben.. sofern ich den Fehler richtig verstehe.. ist ja nur n Auschschnitt vom Ende des Fehlers.. man muesste da halt mal wissen:
      welches System?
      welche Version?
      Logfile von Begin an, wenn der Adapter startet...
      Dann natuerlich noch die Grundsaetzlichen infos aus iob diag.
      P 1 Antwort Letzte Antwort
        @pusemuckel
        welches System?
        welche Version?
        pusemuckel
        @ilovegym
        Danke für Deine Rückmeldung!
        			v.2023-10-10
        model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.2
        Installation: 		Docker
        Kernel: 		x86_64
        Userland: 		amd64
        Timezone: 		Etc/UTC
        User-ID: 		0
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
        			/usr/bin/node 		v20.12.2
        			/usr/bin/npm 		10.5.0
        			/usr/bin/npx 		10.5.0
        			/usr/bin/corepack 	0.25.2
        Recommended versions are nodejs 18.20.2 and npm 10.5.0
        MEMORY:
        Mem:             12G        6.7G        822M        188M        5.4G        5.7G
        Swap:           9.6G         60M        9.5G
        Total:           21G        6.8G         10G
        Active iob-Instances: 	26
        Active repo(s): stable
        ioBroker Core: 		js-controller 		5.0.19
        			admin 			6.13.16
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: redis
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects: 		15173
        States: 		11749
        Size of iob-Database:
        16M	/opt/iobroker/iobroker-data/objects.jsonl
        13M	/opt/iobroker/iobroker-data/objects.json.migrated
        13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        3.5M	/opt/iobroker/iobroker-data/states.json.bak
        Adapter Log:
        host.iobroker
        	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
        host.iobroker
        	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
        host.iobroker
        	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
        host.iobroker
        	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
        host.iobroker
        	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
        host.iobroker
        	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
        host.iobroker
        	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.iobroker
        	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        host.iobroker
        	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
        host.iobroker
        	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
        host.iobroker
        	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
        host.iobroker
        	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
        host.iobroker
        	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
        host.iobroker
        	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
        host.iobroker
        	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
        host.iobroker
        	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
        host.iobroker
        	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
        host.iobroker
        	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
        host.iobroker
        	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
        Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
        ? mcm1957M 2 Antworten Letzte Antwort
        • P pusemuckel
          @ilovegym
          			v.2023-10-10
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v9.1.2
          Kernel: 		x86_64
          Userland: 		amd64
          Timezone: 		Etc/UTC
          User-ID: 		0
          X-Server: 		false
          			/usr/bin/npm 		10.5.0
          			/usr/bin/npx 		10.5.0
          MEMORY:
          Swap:           9.6G         60M        9.5G
          Total:           21G        6.8G         10G
          			admin 			6.13.16
          Objects type: jsonl
          States  type: redis
          Objects: 		15173
          States: 		11749
          Adapter Log:
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          @pusemuckel
          mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
          In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
          sudo docker exec -tiu username containername /bin/bash
          bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
          sudo docker exec -tiu iobroker iobroker /bin/bash
          danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
          Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
          edit:
          das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
          iob logs --watch
            @pusemuckel
            edit:
            iob logs --watch
            pusemuckel
            @ilovegym said in npm Error bei mihome-vacuum Adapter Installation:
            Das hatte ich schon gemacht, leider auch ohne Erfolg. Ich konnte es mit
            npm install iobroker/adapter-core
            korrigieren, danach lässt sich der Adapter wieder starten!
            Schönes Wochenende!
              @wintermute
              WintermuteW Offline
              WintermuteW Offline
              Wintermute
              @ilovegym ...und ich bei Linux 😀
              Alle Reparaturversuche sind fehlgeschlagen - Einspielen des Updates von letzter Nacht hat meinem Iobroker und meinem Staubsauger aber wieder auf die Beine geholfen. Das Update auf die 4.2.0 werde ich dann mal besser auslassen...
              Iobroker als Windows-VM auf einem Supermicro-Server
                Läuft.
                  Läuft.
                  WintermuteW Offline
                  WintermuteW Offline
                  Wintermute
                  @thomas-braun sagte in npm Error bei mihome-vacuum Adapter Installation:
                  Läuft.
                  Auf einem Windows-System? Hast Du irgendwelche Verrenkungen gemacht, damit der Adapter läuft?
                    Läuft.
                    @wintermute
                    Läuft natürlich auf einem Betriebssystem.
                    Gerade nochmal durchgestartet:
                    2024-04-19 18:46:09.700  - info: mihome-vacuum.0 (1232) Got terminate signal TERMINATE_YOURSELF
                    2024-04-19 18:46:09.727  - error: mihome-vacuum.0 (1232) Socket Close
                    2024-04-19 18:46:09.731  - info: mihome-vacuum.0 (1232) terminating
                    2024-04-19 18:46:09.734  - info: mihome-vacuum.0 (1232) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-04-19 18:46:10.221  - info: mihome-vacuum.0 (1232) terminating
                    2024-04-19 18:46:15.796  - info: mihome-vacuum.0 (680497) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v21.7.3, js-controller: 5.0.19
                    2024-04-19 18:46:15.867  - info: mihome-vacuum.0 (680497) IOT enabled, create state
                    2024-04-19 18:46:16.017  - info: mihome-vacuum.0 (680497) select standard vacuum protocol....
                    2024-04-19 18:46:16.494  - info: mihome-vacuum.0 (680497) create state for carpet_mode
                    2024-04-19 18:46:16.649  - info: mihome-vacuum.0 (680497) settest next timer: not available
                    Kein Ding, kommt sofort wieder hoch.
                    -1
                      @wintermute
                      WintermuteW Offline
                      WintermuteW Offline
                      Wintermute
                      @wintermute
                      Da bin ich mir sicher, dass es auf einem Betriebssystem läuft ;-)
                      Aber läuft es auch auf Meinem Betriebssystem?
                        @wintermute
                        @wintermute
                        Natürlich nicht.
                        • P pusemuckel
                          @ilovegym
                          			v.2023-10-10
                          Kernel          : x86_64
                          Userland        : amd64
                          Docker          : v9.1.2
                          Kernel: 		x86_64
                          Userland: 		amd64
                          Timezone: 		Etc/UTC
                          User-ID: 		0
                          X-Server: 		false
                          			/usr/bin/npm 		10.5.0
                          			/usr/bin/npx 		10.5.0
                          MEMORY:
                          Swap:           9.6G         60M        9.5G
                          Total:           21G        6.8G         10G
                          			admin 			6.13.16
                          Objects type: jsonl
                          States  type: redis
                          Objects: 		15173
                          States: 		11749
                          Adapter Log:
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @pusemuckel
                          @wintermute
                          Siehe https://forum.iobroker.net/topic/74221/häufung-von-update-problemen/3
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          • mcm1957M mcm1957
                            @pusemuckel
                            @wintermute
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            Weiter gehts hier https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
