  4. iobroker exit 25 bei Adapter-Update
    6.1k
113 Beiträge 8 Kommentatoren 19.1k Aufrufe 7 Beobachtet
  • Siggi0904S Siggi0904
    @thomas-braun yeah, das hat geholfen. Javascript ist wieder da.
    Da hat sich wohl jemand verschluckt.
    #81
    @siggi0904
    Zeig mal das Gesamtkunstwerk...
    iob diag
    in der Langfassung.
    Siggi0904S 1 Antwort Letzte Antwort
      @siggi0904
      iob diag
      in der Langfassung.
      Siggi0904S Offline
      Siggi0904S Offline
      Siggi0904
      #82
      @thomas-braun sollst du bekommen:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-18-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:21:58 up 34 min,  2 users,  load average: 0.18, 0.30, 0.43
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Wed 2024-04-03 21:21:58 CEST
                 Universal time: Wed 2024-04-03 19:21:58 UTC
                       RTC time: Wed 2024-04-03 19:21:58
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      mario
      /home/mario
      mario adm sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        2.8G        607M        499K        960M        1.3G
      Swap:           4.3G         59M        4.2G
      Total:          8.4G        2.9G        4.8G
               3915 M total memory
               2664 M used memory
                480 M active memory
               2539 M inactive memory
                579 M free memory
                 91 M buffer memory
                824 M swap cache
               4092 M total swap
                 56 M used swap
               4036 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  552K  392M   1% /run
      /dev/sda1      ext4       45G  9.7G   34G  23% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1001
      [Wed Apr  3 20:47:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Apr  3 20:47:28 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems \(real ones only\):
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      3.7G    /var/
      3.5G    /var/log
      3.4G    /var/log/journal/06882d2afcc64e848dd2d19ddcda7ca8
      192M    /var/lib
      Archived and active journals take up 3.3G in the file system.
      /opt/iobroker/backups:
      1.4M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      435M    /opt/iobroker/iobroker-data/
      253M    /opt/iobroker/iobroker-data/files
      121M    /opt/iobroker/iobroker-data/backup-objects
      58M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      9.7M    /opt/iobroker/iobroker-data/states.jsonl
      9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2139836-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.1
      /usr/bin/node           v18.20.1
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.1-1nodesource1
        Candidate: 18.20.1-1nodesource1
        Version table:
       *** 18.20.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
              500 https://deb.debian.org/debian-security bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
      npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
      npm ERR! A complete log of this run can be found in: /home/mario/.npm/_logs/2024-04-03T19_22_04_172Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "deconz"       : 1.4.0    , installed 1.4.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "mihome-vacuum": 4.1.1    , installed 4.2.0
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
      Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Objects and States
      Objects:        11202
      States:         9365
      Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
      Hit:2 https://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       16341      443/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       16349      443/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15846      475/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13256      1/init
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16050      437/deCONZ
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16294      437/deCONZ
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16268      770/exim4
      tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1000       16918      908/io.hm-rpc.1
      tcp        0      0 192.168.178.64:2010     0.0.0.0:*               LISTEN      1000       16864      893/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18353      1026/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15863      475/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13262      1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16269      770/exim4
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       19722      1191/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       16491      797/io.admin.0
      udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1000       18887      1057/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15766      430/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       19228      1107/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       19979      1243/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16330      437/deCONZ
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15482      405/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13259      1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       19325      1139/io.mihome-vacu
      udp        0      0 0.0.0.0:59854           0.0.0.0:*                           107        15768      430/avahi-daemon: r
      udp        0      0 0.0.0.0:47686           0.0.0.0:*                           1000       41292      2805/io.javascript.
      udp6       0      0 :::5353                 :::*                                107        15767      430/avahi-daemon: r
      udp6       0      0 :::38572                :::*                                107        15769      430/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1000       19981      1243/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       19980      1243/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          13265      1/init
      2024-04-03 21:10:00.036  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2901
      2024-04-03 21:10:02.750  - info: dwd.0 (2901) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
      2024-04-03 21:10:05.230  - info: dwd.0 (2901) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-03 21:10:05.756  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-04-03 21:13:35.422  - info: admin.0 (797) ==> Connected system.user.admin from ::ffff:192.168.178.41
      2024-04-03 21:15:00.038  - info: javascript.0 (2805) script.js.Skripte.Wohnung.VerbrauchTasmota: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
      2024-04-03 21:15:00.100  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3532
      2024-04-03 21:15:00.109  - info: javascript.0 (2805) script.js.Skripte.Wohnung.VerbrauchShelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
      2024-04-03 21:15:00.150  - info: javascript.0 (2805) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
      2024-04-03 21:15:02.595  - info: dwd.0 (3532) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
      2024-04-03 21:15:04.109  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 3548
      2024-04-03 21:15:05.029  - info: dwd.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-03 21:15:05.673  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-04-03 21:15:08.349  - info: daswetter.0 (3548) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.1, js-controller: 5.0.19
      2024-04-03 21:15:14.554  - info: daswetter.0 (3548) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-04-03 21:15:15.073  - info: daswetter.0 (3548) cleaned everything up...
      2024-04-03 21:15:15.086  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-04-03 21:16:13.897  - info: javascript.0 (2805) Stop script script.js.Skripte.Außen.CarportLichtMorgensEin
      2024-04-03 21:16:13.921  - info: javascript.0 (2805) Start javascript script.js.Skripte.Außen.CarportLichtMorgensEin
      2024-04-03 21:16:13.936  - info: javascript.0 (2805) script.js.Skripte.Außen.CarportLichtMorgensEin: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
      2024-04-03 21:16:33.064  - info: admin.0 (797) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
      2024-04-03 21:20:00.019  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3775
      2024-04-03 21:20:02.273  - info: dwd.0 (3775) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
      2024-04-03 21:20:04.491  - info: dwd.0 (3775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-03 21:20:05.019  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Der xmlbuilder Error sieht so aus:
      mario@iobroker:/opt/iobroker$ npm ls xmlbuilder
      iobroker.inst@2.0.3 /opt/iobroker
      ├─┬ iobroker.hm-rega@4.0.0
      │ └─┬ xml2js@0.6.2
      │   └── xmlbuilder@11.0.1
      ├─┬ iobroker.hm-rpc@1.16.0
      │ └─┬ homematic-xmlrpc@1.0.2
      │   └── xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      ├─┬ iobroker.shelly@6.8.0
      │ └── xmlbuilder@15.1.1
      └─┬ iobroker.tr-064@4.2.18
        └─┬ xml2js@0.4.23
      Das ist aber auch noch im aktuellen Code so alt.
      Da gibt es evtl. schon eine Klärung.
      Ansonsten nochmal großes Danke.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 2
                      NTP service: active
                  RTC in local TZ: no
        mario
        /home/mario
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           4.3G         59M        4.2G
                 3915 M total memory
                 2664 M used memory
                  480 M active memory
                  579 M free memory
                   91 M buffer memory
                  824 M swap cache
                 4092 M total swap
                   56 M used swap
                 4036 M free swap
        *** FILESYSTEM ***
        /var:
        3.7G    /var/
        3.5G    /var/log
        192M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11202
        States:         9365
        Pending Updates: 0
        │ └─┬ xml2js@0.6.2
          └─┬ xml2js@0.4.23
        #83
        @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
        iob update
        iob upgrade hm-rpc@1.16.0
        Denn eigentlich will der "homematic-xmlrpc": "^1.0.2" haben und nicht den alten Kram.
        Edit: Falsch geschaut...
          iob update
          Siggi0904S Offline
          Siggi0904S Offline
          Siggi0904
          #84
          @thomas-braun ne, der will die alte Version. Steht in der https://github.com/ioBroker/ioBroker.hm-rpc/blob/master/package-lock.json ab Zeile 3761.
          Beim Fritzox-Adapter tr-061 ist das auch so alt.
            #85
            @siggi0904
            Das muss geändert werden. Der Verweis geht ins Leere.
            Siggi0904S mcm1957M 2 Antworten Letzte Antwort
              @siggi0904
              Siggi0904S Offline
              Siggi0904S Offline
              Siggi0904
              #86
              @thomas-braun Jo, liegt schon per Feature Request im Repo.
                @siggi0904
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #87
                Wieso geht der Verweis ins Leere?
                Ich kann https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5 einwandfrei downloaden.
                Abgesehen davon dass wir keine Kontrolle übder diese sub sub Abhängigkeit haben...
                Das müsste in homematic-xmlrpc geändert werden. Nur das ist auch schon ewig in der Geriatrie ...
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • mcm1957M mcm1957
                  #88
                  @mcm57
                  Weil der invalid ist:
                    @mcm57
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #89
                    Ja aber WARUM ist der invalid?
                    Wobei es eigentlich egal ist - der Adapter lebt von homematic-xmlrpc und da ist 1.0.2 die neueste Version un die verlangt xmlbuilder@0.4.2.
                    Und bei mir läßt sich der Adapter problemlos installieren:
                    pi@pi4:~ $ iob add iobroker.hm-rpc
                    NPM version: 10.2.4
                    Installing iobroker.hm-rpc@1.16.0... (System call)
                    added 12 packages in 17s
                    154 packages are looking for funding
                      run `npm fund` for details
                    host.pi4 install adapter hm-rpc
                    upload [281] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                    upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                    upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                    upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/204_hmip-drdi3_thumb.png icons/204_hmip-drdi3_thumb.png image/png
                    upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/43_hm-cc-vd_thumb.png icons/43_hm-cc-vd_thumb.png image/png
                    upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/52_hm-sec-sd-team_thumb.png icons/52_hm-sec-sd-team_thumb.png image/png
                    upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/5_hm-lc-sw2-fm_thumb.png icons/5_hm-lc-sw2-fm_thumb.png image/png
                    upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/6_hm-lc-bl1-sm_thumb.png icons/6_hm-lc-bl1-sm_thumb.png image/png
                    upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/80_hm-sen-mdir-o_thumb.png icons/80_hm-sen-mdir-o_thumb.png image/png
                    upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/88_hm-lc-sw4-ba-pcb_thumb.png icons/88_hm-lc-sw4-ba-pcb_thumb.png image/png
                    upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/9_hm-ws550-us_thumb.png icons/9_hm-ws550-us_thumb.png image/png
                    upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/OM55_DimmerSwitch_thumb.png icons/OM55_DimmerSwitch_thumb.png image/png
                    upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                    upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                    upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                    upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                    upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                    upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                    upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                    upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                    upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                    upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                    upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                    upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                    upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                    upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                    upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                    upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                    upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                    upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
                    upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
                    upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                    upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                    host.pi4 object _design/hm-rpc created/updated
                    host.pi4 object system.adapter.hm-rpc created/updated
                    host.pi4 create instance hm-rpc
                    host.pi4 object system.adapter.hm-rpc.0.alive created
                    host.pi4 object system.adapter.hm-rpc.0.connected created
                    host.pi4 object system.adapter.hm-rpc.0.compactMode created
                    host.pi4 object system.adapter.hm-rpc.0.cpu created
                    host.pi4 object system.adapter.hm-rpc.0.cputime created
                    host.pi4 object system.adapter.hm-rpc.0.memHeapUsed created
                    host.pi4 object system.adapter.hm-rpc.0.memHeapTotal created
                    host.pi4 object system.adapter.hm-rpc.0.memRss created
                    host.pi4 object system.adapter.hm-rpc.0.uptime created
                    host.pi4 object system.adapter.hm-rpc.0.inputCount created
                    host.pi4 object system.adapter.hm-rpc.0.outputCount created
                    host.pi4 object system.adapter.hm-rpc.0.eventLoopLag created
                    host.pi4 object system.adapter.hm-rpc.0.sigKill created
                    host.pi4 object system.adapter.hm-rpc.0.logLevel created
                    host.pi4 object hm-rpc.0.updated created
                    host.pi4 object hm-rpc.0.info created
                    host.pi4 object hm-rpc.0.info.connection created
                    host.pi4 Set default value of hm-rpc.0.info.connection: false
                    host.pi4 object system.adapter.hm-rpc.0 created
                    pi@pi4:/opt/iobroker $ npm ls xmlbuilder
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├─┬ iobroker.shelly@6.6.1
                    │ ├─┬ xml2js@0.6.2
                    │ │ └── xmlbuilder@11.0.1
                    ├─┬ iobroker.systeminfo@1.1.0
                    │ └─┬ xml2js@0.6.2
                      └─┬ xml2js@0.4.23
                    OK node v18.19.1
                    Check mal ob du https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5 vom ioBroker hist aus erreichen kannst. NIcht dass da new Firewall o.ä. Zugriffe auf Github blocket. Alles schon dagewesen...
                    • mcm1957M mcm1957
                      NPM version: 10.2.4
                      │ ├─┬ xml2js@0.6.2
                      │ └─┬ xml2js@0.6.2
                        └─┬ xml2js@0.4.23
                      OK node v18.19.1
                      #90
                      @mcm57 sagte in iobroker exit 25 bei Adapter-Update:
                      Keine Ahnung. Ich sowas schon mal bei Adaptern aus dem github. Die werden dann auch als invalid angezeigt.
                      Wenn dann irgendeiner der Adapter nochmal reingezogen wird sind auch die anderen Verweise wieder valide.
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #91
                        OK - na dann halt nochmal instzallieren.
                        Im ioBroker Adapter seh ich wenig Chancen da was zu machen. Außer jemand hat Zeit und Lust den Basiscode (externe lib) zu froken, zu aktualisisern und zu testen - oder neu zu schreiben. Aber mal sehen.
                          ich bekomme seit dem heutigen Update auf node-js Version 18.20.0 folgenden Fehler,
                          wenn ich versuche Adapter zu aktualisieren.
                          Was kann ich tun?
                          2024-03-29 19:09:10.732 - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T18_03_29_073Z-debug-0.log
                          2024-03-29 19:09:10.735 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.cloud@5.0.1: 127
                          2024-03-29 19:09:11.756 - info: host.iobroker iobroker exit 25
                          Danke im Voraus.
                          Z Offline
                          Z Offline
                          ZeroQool
                          #92
                          @siggi0904
                          Ich habe seit kurzem das gleiche Problem. Ich bekomme 5 Adapter Updates angezeigt und bei jedem kommt die gleiche Fehlermeldung.
                          $ iobroker upgrade socketio@6.6.1
                          Update socketio from @6.6.0 to @6.6.1
                          host.iobroker Adapter "system.adapter.socketio.0" is stopped.
                          NPM version: 10.5.0
                          Installing iobroker.socketio@6.6.1... (System call)
                          npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-06T09_30_24_064Z-debug-0.loghost.iobroker Cannot install iobroker.socketio@6.6.1: 127
                          ERROR: Process exited with code 25
                          iob nodejs-update
                          Habe ich bereits gemacht. Keine Veränderung. Da muss doch allgemein etwas passiert sein.
                          • Z ZeroQool
                            @siggi0904
                            NPM version: 10.5.0
                            iob nodejs-update
                            Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            #93
                            @zeroqool hast du denn den mihome-vacuum Adapter installiert?
                            Der war, ich hoffe es, bei mir das Problem.
                            Wenn du davon die Beta installierst, oder auf die stable 4.2.0 wartest behebt es das zlib Problem.
                            Denn dann dürfte grep -r node-waf kein zlib mehr anzeigen.
                            Ansonsten zeig mal, was bei npm ls zlib rauskommt.
                            Z 2 Antworten Letzte Antwort
                            • Z Offline
                              Z Offline
                              ZeroQool
                              #94
                              @siggi0904 Glaube habe ein allg. Problem. Es läßt sich kein Adapter mehr installieren, die gleiche Fehlermeldung wie beim Update. Habe letztens alles mit iob nodejs-update aktualisiert. Sieht auch von den Versionen sauber aus.
                                Z Offline
                                Z Offline
                                ZeroQool
                                #95
                                @siggi0904 said in iobroker exit 25 bei Adapter-Update:
                                npm ls zlib
                                root@iobroker:/opt/iobroker# npm ls zlib
                                iobroker.inst@2.0.2 /opt/iobroker
                                -- iobroker.mihome-vacuum@4.1.1 -- zlib@1.0.5
                                  Z Offline
                                  Z Offline
                                  ZeroQool
                                  #96
                                  grep -r node-waf
                                  ist ein riesen Log aber mit Fehler:
                                  • Z ZeroQool
                                    npm ls zlib
                                    #97
                                    @zeroqool sagte in iobroker exit 25 bei Adapter-Update:
                                    NICHT als root herum hampeln. Und schon gar nicht im Verzeichnis von iobroker mit npm...
                                    Logs auch nicht als Screenshot sonder als Text in CodeTags.
                                    Als USER!
                                    iob stop
                                    iob fix
                                    iob update
                                    Z 1 Antwort Letzte Antwort
                                      Als USER!
                                      iob stop
                                      iob fix
                                      iob update
                                      Z Offline
                                      Z Offline
                                      ZeroQool
                                      schrieb am zuletzt editiert von ZeroQool
                                      #98
                                      @thomas-braun OK, aber muss zugeben, dass ich den Proxmox Container seit mehreren Jahren so laufen habe.
                                      iob stop && iob update && iob fix && iob upgrade self && iob start
                                      Habe ich auch schon ausgeführt. aber keine Verbesserung. hatte vorher node 14 oder so u nun 18.20.1
                                      • Z ZeroQool
                                        #99
                                        Das heißt ja nix. Nur das du es dann halt seit Jahren falsch machst.
                                        Habe ich auch schon ausgeführt. aber keine Verbesserung. hatte vorher node 14 oder so u nun 16
                                        Zeigen. Und aktuell ist nodejs@18...
                                        Zeig am besten mal den ganzen Quark...
                                        iob stop
                                        iob fix
                                        iob diag
                                          iob stop
                                          iob fix
                                          iob diag
                                          Z Offline
                                          Z Offline
                                          ZeroQool
                                          #100
                                          @thomas-braun said in iobroker exit 25 bei Adapter-Update:
                                          library: loaded
                                          Library version=2024-01-04
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2024-01-04
                                          Installing prerequisites (1/5)
                                          Hit:1 http://ftp.debian.org/debian bookworm InRelease
                                          Hit:2 http://security.debian.org bookworm-security InRelease
                                          Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
                                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Reading package lists... Done
                                          Checking ioBroker user and directory permissions (2/5)
                                          Created /etc/sudoers.d/iobroker
                                          Check and cleanup npm temporary directories (3/5)
                                          Done.
                                          Database maintenance (4/5)
                                          Checking for uncompressed JSONL databases... This might take a while!
                                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                          Compressed 2 JSONL files. Done
                                          Checking autostart (5/5)
                                          Enabling autostart...
                                          Autostart enabled!
                                          This script must not be run as root!
                                          Please use your standard user!
