  4. iobroker exit 25 bei Adapter-Update
    1.0k
    6.1k
113 Beiträge 8 Kommentatoren 19.1k Aufrufe 7 Beobachtet
  • Siggi0904S Siggi0904
    @Thomas-Braun irgendwie zerlege ich mir hier gerade mein IOBroker.
    Im Guthub wurde mit geschrieben, dass ich das zlib anheben soll.
    Habs in der package.json angepasst.
    Nun ist IOBroker komplett nicht mehr erreichbar.
    login as: mario
    mario@192.168.178.64's password:
    Linux iobroker 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Fri Mar 29 20:47:18 2024 from 192.168.178.41
    mario@iobroker:~$ nano /opt/iobroker/node_modules/io
    iobroker/                 iobroker.flot/            iobroker.simple-api/
    iobroker.admin/           iobroker.heatingcontrol/  iobroker.socketio/
    iobroker.alarm/           iobroker.hm-rega/         iobroker.sonoff/
    iobroker.alexa2/          iobroker.hm-rpc/          iobroker.sql/
    iobroker.alexa-timer-vis/ iobroker.ical/            iobroker.tankerkoenig/
    iobroker.awtrix-light/    iobroker.icons-mfd-svg/   iobroker.tr-064/
    iobroker.backitup/        iobroker.iot/             iobroker.trashschedule/
    iobroker.cloud/           iobroker.javascript/      iobroker.type-detector/
    iobroker.daswetter/       iobroker.js-controller/   iobroker.vis/
    iobroker.deconz/          iobroker.mihome-vacuum/   iobroker.web/
    iobroker.discovery/       iobroker.openweathermap/  iobroker.ws/
    iobroker.dwd/             iobroker.ping/            ioredis/
    iobroker.email/           iobroker.scenes/
    iobroker.feiertage/       iobroker.shelly/
    mario@iobroker:~$ ls /opt/iobroker/node_modules/iobroker.mihome-vacuum/
    admin  io-package.json  lib  LICENSE  main.js  package.json  README.md
    mario@iobroker:~$ nano /opt/iobroker/node_modules/iobroker.mihome-vacuum/package.json
    mario@iobroker:~$ iob upgrade mihome-vacuum@4.1.1
    Would you like to reinstall version 4.1.1 of mihome-vacuum now? [(y)es, (n)o]: y
    Update mihome-vacuum from @4.1.1 to @4.1.1
    NPM version: 10.5.0
    Installing iobroker.mihome-vacuum@4.1.1... (System call)
    npm ERR! code 127
    npm ERR! path /opt/iobroker/node_modules/zlib
    npm ERR! command failed
    npm ERR! command sh -c node-waf clean || true; node-waf configure build
    npm ERR! sh: 1: node-waf: not found
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-31T12_32_38_352Z-debug-0.log
    host.iobroker Cannot install iobroker.mihome-vacuum@4.1.1: 127
    mario@iobroker:~$ npm ls zlib
    /home/mario
    └── (empty)
    node:internal/modules/cjs/loader:1143
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
        at Module._load (node:internal/modules/cjs/loader:981:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.20.0
    mario@iobroker:~$
    mcm1957M Online
    mcm1957M Online
    mcm1957
    #41
    @siggi0904
    Wie ich schon im issue geschrieben habe ist
    • das Editieren der package.json keine tolle idee da bei der Installation das package.json des Paketsbund hiffentlich kuchtcdes Zielsystems verwendet wird
    • beim Ändern v package.json auch packaga-lock.json anzupassen ist.
    • ein Sprung vvzlib 1.x.x auf 3.x.x ohne check des Changelogs sehr mutigbust. Major Releases veinhaltennmeust knkompatible änderungen und sa muss ev der Adapter angepasst werden..
    Deinstallier mihome mal. Ich bezweifle dass der Adapter bzw zlib die primäre Fehlerursache ist. Es sind mit Sicherheit auchcschon zug andere User auf node 18. Wenn das Problem ohne mihome weg ist dann ibstalluer den Adapter neu. Und dann schau na bal was der Statzs ist.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    Siggi0904S 1 Antwort Letzte Antwort
    • mcm1957M mcm1957
      @siggi0904
      Siggi0904S Offline
      Siggi0904S Offline
      Siggi0904
      #42
      @mcm57 wie geschrieben geht aktuell garnichts mehr.
      • Siggi0904S Offline
        Siggi0904S Offline
        Siggi0904
        #43
        So, ich habe nun mein Proxmox-Backup von vor der Hochrüstung von node-js wieder eingespielt.
        Zum Glück hatte ich das entsprechend des Tutorials von @haus-automatisierung alles so eingerichtet,
        dass das zurückrollen des Backups leicht ging.
        Nur musste ich alle Arbeiten, die ich die Woche über gemacht hatte, wiederholen.
        Zum aktuellen Stand:
        Ich habe alle Addons aktuell, mihome-vacuum adapter ist installiert und node-js steht bei Version 18.19.1.
        Ich müsste nun node-js hochrüsten.
        Aber wie?
          Aber wie?
          #44
          @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
          iob nodejs-update
            iob nodejs-update
            Siggi0904S Offline
            Siggi0904S Offline
            Siggi0904
            #45
            @thomas-braun ohne Angabe einer Version?
            Ein Update via apt nicht machen? Denn dort wird es ja auch gelistet.
            Sollte ich vorher den mihome-vacuum Adapter deinstallieren?
            Kann man vorher noch irgendwas checken?
            Thomas BraunT haus-automatisierungH 2 Antworten Letzte Antwort
              #46
              Ohne Angabe einer Version wird die empfohlene Version installiert. Heute also die 18.20.0.
                haus-automatisierungH Offline
                #47
                @siggi0904 Ohne Version = aktuell empfohlene Version wird installiert (nodejs 18).
                Ansonsten läuft das natürlich über apt, aber der Befehl kontrolliert die aktuelle nodejs Installation und zieht sie ggf gerade. Es werden die entsprechenden apt Repositories angelegt und dann daraus installiert.
                Am Ende ist ein Bash-Script, welches einfach nur viel Arbeit abnimmt und apt richtig konfiguriert
                📚 Meine Dokumentation
                  Siggi0904S Offline
                  Siggi0904
                  #48
                  Tja, den Adapter mihome-vacuum vorher deinstallieren?
                  Ich lass erst einmal ein Backup laufen.
                    samsungfreak
                    #49
                    Hallo.
                    ich habe genau das gleiche Problem wie @Siggi0904. Allerdings ist es mir aufgefallen, als ich den mihome-vacuum adapter installieren wollte. Updates von allen anderen Adaptern die bereits installiert sind laufen ohne Probleme durch.
                      Siggi0904S Offline
                      Siggi0904
                      #50
                      Neue Adapter-Version vom mihome-vacuum ist auf dem Weg. Es wird der nodejs eigene zlib verwendet. Hoffentlich hilft es.
                      Ich lasse mein System nun erst einmal mit der node-js 18.19 Version, bis die neue Adapter-Version da ist. Leider bleiben dann auch einige andere Updates hängen, aber halb so wild.
                      Wär cool, wenn es das Thema löst.
                        #51
                        @siggi0904
                        Also bei mir ist das zlib-Modul nun rausgeflogen:
                        echad@chet:/opt/iobroker $ grep -r node-waf
                        node_modules/reinterval/.npmignore:# node-waf configuration
                        node_modules/bindings/bindings.js:      // node-waf and gyp_addon (a.k.a node-gyp)
                        node_modules/bindings/bindings.js:      // Legacy from node-waf, node <= 0.4.x
                          @siggi0904
                          Siggi0904S Offline
                          Siggi0904S Offline
                          Siggi0904
                          #52
                          @thomas-braun hast du dir die neue Version aus dem npm gezogen?
                          Wär cool, wenn es so das Problem beheben würde.
                          Dann hoffe ich, dass die stable zeitnah kommt.
                          Dann kann ich mein System wieder aktuell ziehen.
                          Danke für die Info.
                          mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                            Danke für die Info.
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #53
                            @siggi0904
                            Da du ein System bei dem du via Container scheinbar recht rasch zurücksteigen kannst, wärs durchaus sinnvoll die latest Release zu testen, Ich bezweifle, dass sonst viele User gibt die dein Problem haben.
                            Du kannst natürlich auch gerne auf die Stable warten und dann testen ob die Release dein Problem behebt - ist aber erst in ca 2 bis 3 Wochen zu erwarten wenn sich bis dahin keine neuen Fehler zeigen.
                              Danke für die Info.
                              #54
                              @siggi0904
                              Lag im Beta-Repo.
                              • mcm1957M mcm1957
                                @siggi0904
                                Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                #55
                                @mcm57 Hi, naja ist eine VM unter Proxmox.
                                Ich muss dann halt das Backup wieder zurückrollen.
                                Kann immer nur hoffen, dass die Backups sauber laufen.
                                Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                  #56
                                  @siggi0904
                                  Angel dir den einen Adapter doch aus dem Beta-Repo/npm.
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #57
                                    @siggi0904
                                    Na ja
                                    Variante 1: mit der neuen Version gehts - alles gut
                                    Varainate 2: Mit der neuen Version gehts nicht. Dann musst du eh auf deinem System suchen was da faul ist. Da der Adapter nunmehr zlib in der Uraltversion nicht mehr includiert, kann es daran nicht liegen.
                                    Das einzige was du mit zuwarten gewinnen kannst ist die Frage ob allenfalls die Uralt-zlib und nodes zlib doch irgendwo nicht 100% kompatibel sind und dass diese Problem wer anderer entdeckt ...
                                    • mcm1957M mcm1957
                                      @siggi0904
                                      Na ja
                                      Siggi0904S Offline
                                      Siggi0904S Offline
                                      Siggi0904
                                      #58
                                      @mcm57 ja, genau die Angst habe ich bei Variante 2.
                                      Der Aufwand wär dann halt sehr hoch.
                                      @thomas-braun sagte in iobroker exit 25 bei Adapter-Update:
                                      @siggi0904
                                      Wie komm ich denn nur für den Adapter an die Beta-Version?
                                      Alles andere soll ja stable bleiben.
                                        @siggi0904
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #59
                                        @siggi0904
                                        Kann deine Angst verstehen. Aber wenn Variante 2 zutrifft wird das wohl primär nicht im Adapter lösbar sein, Sorry.
                                        Zum Latest Repo kommst du
                                        • In der Kopfzeile den Schraubenschlüssel nehmen und in den Base Settings auf Repositories gehen:
                                        • Dort BETA als aktiv markieren,
                                        • Auf der Adapterseite oben auf "Nach Updates suchen" Klicken (Button mit rundem Pfeil)
                                        • Jetzt solltes du alle möglichen Adapetrupdates sehen.; beim mihome-vacuum die neue Release
                                        • NUR Beim mihomevacuum die neue Release zum Updaten anklicken
                                        • Anschließend wieder STABLE als aktiv auswählen (in der Repository maske)
                                        Thomas BraunT J 2 Antworten Letzte Antwort
                                        • mcm1957M mcm1957
                                          @siggi0904
                                          #60
                                          Alternativ: In den Experten-Optionen über 'die Katze' und dann den Reiter npm wählen.
                                          Ich würde evtl. zuvor noch den npm-cache löschen, sonst hält sich npm unter Umständen an dem alten Kram fest.
                                          sudo -H -u iobroker npm cache clean --force
