  4. iobroker exit 25 bei Adapter-Update
    1.0k
    6.1k
113 Beiträge 8 Kommentatoren 19.1k Aufrufe 7 Beobachtet
    @siggi0904
    iob update
    iob upgrade hm-rpc@1.16.0
    iob upgrade all
    Siggi0904S Offline
    Siggi0904S Offline
    Siggi0904
    @thomas-braun sagte in iobroker exit 25 bei Adapter-Update:
    hm, misst. Bleibt auch so erhalten, der Fehler.
    mario@iobroker:/opt/iobroker$ iob update
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "deconz"       : 1.4.0    , installed 1.4.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "ical"         : 1.14.3   , installed 1.13.3 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.11   , installed 2.5.10 [Updatable]
    mario@iobroker:/opt/iobroker$ iob upgrade hm-rpc@1.16.0
    Would you like to reinstall version 1.16.0 of hm-rpc now? [(y)es, (n)o]: y
    Update hm-rpc from @1.16.0 to @1.16.0
    NPM version: 10.5.0
    Installing iobroker.hm-rpc@1.16.0... (System call)
    npm ERR! code 127
    npm ERR! path /opt/iobroker/node_modules/zlib
    npm ERR! command failed
    npm ERR! command sh -c node-waf clean || true; node-waf configure build
    npm ERR! sh: 1: node-waf: not found
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_31_44_159Z-debug-0.log
    host.iobroker Cannot install iobroker.hm-rpc@1.16.0: 127
    • Siggi0904S Siggi0904
      NPM version: 10.5.0
      npm ERR! code 127
      @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
      zlib
      npm ls zlib
      Siggi0904S 1 Antwort Letzte Antwort
        zlib
        npm ls zlib
        Siggi0904S Offline
        Siggi0904S Offline
        Siggi0904
        mario@iobroker:/opt/iobroker$ npm ls zlib
        iobroker.inst@2.0.3 /opt/iobroker
        └─┬ iobroker.mihome-vacuum@4.1.1
          └── zlib@1.0.5
            └── zlib@1.0.5
          @siggi0904
          npm prune
          npm ls
          Siggi0904S 3 Antworten Letzte Antwort
            @siggi0904
            npm prune
            npm ls
            Siggi0904S Offline
            Siggi0904S Offline
            Siggi0904
              └── zlib@1.0.5
            mario@iobroker:/opt/iobroker$ npm prune
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
            npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
            npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN deprecated @azure/msal-node@1.18.4: A newer major version of this library is available. Please upgrade to the latest available version.
            npm ERR! code 127
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_48_34_023Z-debug-0.log
              @siggi0904
              npm prune
              npm ls
              Siggi0904S Offline
              Siggi0904S Offline
              Siggi0904
              ├── @types/caseless@0.12.5 extraneous
              ├── @types/request@2.48.12 extraneous
              ├── @types/tough-cookie@4.0.5 extraneous
              ├── coffeescript@2.7.0 extraneous
              ├── colors@1.4.0
              ├── fs-extra@7.0.1
              ├── iobroker.admin@6.13.16
              ├── iobroker.alarm@3.6.0
              ├── iobroker.alexa-timer-vis@0.3.0
              ├── iobroker.alexa2@3.26.4
              ├── iobroker.awtrix-light@0.16.0
              ├── iobroker.backitup@2.10.11
              ├── iobroker.cloud@4.4.1
              ├── iobroker.daswetter@3.1.13
              ├── iobroker.deconz@1.4.0
              ├── iobroker.discovery@4.4.0
              ├── iobroker.dwd@2.8.5
              ├── iobroker.email@1.2.2
              ├── iobroker.feiertage@1.1.4
              ├── iobroker.flot@1.12.0
              ├── iobroker.heatingcontrol@2.12.5
              ├── iobroker.hm-rega@4.0.0
              ├── iobroker.hm-rpc@1.16.0
              ├── iobroker.ical@1.13.3
              ├── iobroker.icons-mfd-svg@1.2.0
              ├── iobroker.iot@2.0.11
              ├── iobroker.javascript@7.8.0
              ├── iobroker.js-controller@5.0.19
              ├── iobroker.mihome-vacuum@4.1.1
              ├── iobroker.openweathermap@1.0.4
              ├── iobroker.ping@1.6.2
              ├── iobroker.scenes@2.3.9
              ├── iobroker.shelly@6.8.0
              ├── iobroker.simple-api@2.7.2
              ├── iobroker.socketio@6.6.0
              ├── iobroker.sonoff@3.0.3
              ├── iobroker.sql@2.2.0
              ├── iobroker.tankerkoenig@3.3.7
              ├── iobroker.tr-064@4.2.18
              ├── iobroker.trashschedule@3.2.0
              ├── iobroker.vis@1.5.4
              ├── iobroker.web@6.2.3
              ├── iobroker.ws@2.5.10
              ├── iobroker@2.0.3
              ├── jsonata@2.0.4 extraneous
              ├── node-inspect@2.0.0 extraneous
              ├── picocolors@1.0.0 extraneous
              ├── semver@5.7.2
              ├── typescript@5.3.3 extraneous
              ├── virtual-tsc@0.6.2 extraneous
              ├── wake_on_lan@1.0.0 extraneous
              └── yargs@7.1.2
                @siggi0904
                npm prune
                npm ls
                Siggi0904S Offline
                Siggi0904S Offline
                Siggi0904
                In der Datei /opt/iobroker/node_modules/zlib/configure steht node-waf configure
                Also ist zlib schuld?
                  node-waf configure
                  Möglich. Auf meinem System schaut es so aus:
                  echad@chet:/opt/iobroker $ grep -r node-waf
                  node_modules/reinterval/.npmignore:# node-waf configuration
                  node_modules/bindings/bindings.js:      // node-waf and gyp_addon (a.k.a node-gyp)
                  node_modules/bindings/bindings.js:      // Legacy from node-waf, node <= 0.4.x
                  node_modules/zlib/configure:node-waf configure
                  node_modules/zlib/Makefile:     node-waf build
                  node_modules/zlib/Makefile:     node-waf clean
                  Ich habe aber keine Fehler, wenn npm loslegt.
                    node-waf configure
                    Siggi0904S Offline
                    Siggi0904S Offline
                    Siggi0904
                    @thomas-braun in den Releases zu node-js 18.20 ist aber auch viel zlib Zeug dabei.
                    https://nodejs.org/en/blog/release/v18.20.0
                    Bei mir auch so:
                    mario@iobroker:/opt/iobroker$ grep -r node-waf
                    log/iobroker.2024-03-29.log:2024-03-29 18:56:47.899  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T17_50_31_979Z-debug-0.log
                    log/iobroker.2024-03-29.log:2024-03-29 19:09:10.732  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T18_03_29_073Z-debug-0.log
                    log/iobroker.2024-03-29.log:2024-03-29 20:25:32.516  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_19_31_663Z-debug-0.log
                    log/iobroker.2024-03-29.log:2024-03-29 20:58:12.865  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_52_59_224Z-debug-0.log
                    node_modules/node-rest-client/readme.md:**NOTE:** _Since version 0.8.0 node does not contain node-waf anymore. The node-zlib package which node-rest-client make use of, depends on node-waf.Fortunately since version 0.8.0 zlib is a core dependency of node, so since version 1.0 of node-rest-client the explicit dependency to "zlib" has been removed from package.json. therefore if you are using a version below 0.8.0 of node please use a versión below 1.0.0 of "node-rest-client". _
                      @siggi0904
                      Kommt aus dem Modul:
                      https://github.com/kkaefer/DEPRECATED-node-zlib
                      Das ist aber wie gesagt seit Jahren überholt.
                        @siggi0904
                        Siggi0904S Offline
                        Siggi0904S Offline
                        Siggi0904
                        schrieb am zuletzt editiert von Siggi0904
                        @thomas-braun ja.
                        Deine Reihenfolge in der grep Ausgabe ist aber anders.
                        das npmignore kommt bei mir am Ende, bei dir als erstes.
                        Kann man die Verwendung irgendwie deaktivieren, dass das sauber durchläuft?
                          @thomas-braun ja.
                          Der mihome-vacuum schleppt wohl zlib an. Keine Ahnung, ob man die Dependency dort herausnehmen kann/soll/muss.
                            Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            @thomas-braun wenn iobroker mich die deinstallation machen lassen würde, könnte ich den adapter auch testweise deinstallieren.
                            da hat einer einfach gyp nachinstalliert.
                            https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/904
                            Tja, wie nun weiter?
                            Ich habe beim mihome-adapter mal ein issue aufgemacht.
                            https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/940
                              Da ging es aber auch um canvas. Und die Aktion da global irgendwas reinzuknüppeln war bestimmt auch nicht die eleganteste.
                                Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                @thomas-braun Hallo Thomas, gibt es Ideen was ich noch machen könnte?
                                Ich steh irgendwie auf dem Schlauch.
                                Wie könnte man die Abhängigkeit aufheben?
                                Dank dir.
                                  Dank dir.
                                  @siggi0904
                                  Das müsste im Modul eingetragen werden. Vielleicht kann sich @mcm57 das mal anschauen. Nach meinem Dafürhalten könnte die Abhängigkeit da raus. Aber ich hab keine Ahnung vom Paketbau.
                                    @siggi0904
                                    Siggi0904S Offline
                                    Siggi0904S Offline
                                    Siggi0904
                                    @thomas-braun dann hoffe ich, dass @mcm57 mir da recht kurzfristig helfen kann.
                                    Ich habe auch schwer die Vermutung, dass ich den Adapter mihome-vacuum auch nicht einfach deinstallieren kann. Ich werde da wohl auch in den Fehler rennen.
                                    Da bin ich irgendwie gefangen und brauch Hilfe bei der Reparatur.
                                    Natürlich auch gern per PN und Teamviewer oder ähnliches.
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      @siggi0904
                                      Sorry damit du nicht umsonst wartest.
                                      Aber vor Di werd ich mur kaum was ansehen können.
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      • mcm1957M mcm1957
                                        @siggi0904
                                        Siggi0904S Offline
                                        Siggi0904S Offline
                                        Siggi0904
                                        @mcm57 Kein Thema, dann warte ich. Läuft ja alles, nur updates gehen nicht.
                                        • Siggi0904S Offline
                                          Siggi0904S Offline
                                          Siggi0904
                                          @Thomas-Braun irgendwie zerlege ich mir hier gerade mein IOBroker.
                                          Im Guthub wurde mit geschrieben, dass ich das zlib anheben soll.
                                          Habs in der package.json angepasst.
                                          Nun ist IOBroker komplett nicht mehr erreichbar.
                                          login as: mario
                                          mario@192.168.178.64's password:
                                          Linux iobroker 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
                                          The programs included with the Debian GNU/Linux system are free software;
                                          the exact distribution terms for each program are described in the
                                          individual files in /usr/share/doc/*/copyright.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                          permitted by applicable law.
                                          Last login: Fri Mar 29 20:47:18 2024 from 192.168.178.41
                                          mario@iobroker:~$ nano /opt/iobroker/node_modules/io
                                          iobroker/                 iobroker.flot/            iobroker.simple-api/
                                          iobroker.admin/           iobroker.heatingcontrol/  iobroker.socketio/
                                          iobroker.alarm/           iobroker.hm-rega/         iobroker.sonoff/
                                          iobroker.alexa2/          iobroker.hm-rpc/          iobroker.sql/
                                          iobroker.alexa-timer-vis/ iobroker.ical/            iobroker.tankerkoenig/
                                          iobroker.awtrix-light/    iobroker.icons-mfd-svg/   iobroker.tr-064/
                                          iobroker.backitup/        iobroker.iot/             iobroker.trashschedule/
                                          iobroker.cloud/           iobroker.javascript/      iobroker.type-detector/
                                          iobroker.daswetter/       iobroker.js-controller/   iobroker.vis/
                                          iobroker.deconz/          iobroker.mihome-vacuum/   iobroker.web/
                                          iobroker.discovery/       iobroker.openweathermap/  iobroker.ws/
                                          iobroker.dwd/             iobroker.ping/            ioredis/
                                          iobroker.email/           iobroker.scenes/
                                          iobroker.feiertage/       iobroker.shelly/
                                          mario@iobroker:~$ ls /opt/iobroker/node_modules/iobroker.mihome-vacuum/
                                          admin  io-package.json  lib  LICENSE  main.js  package.json  README.md
                                          mario@iobroker:~$ nano /opt/iobroker/node_modules/iobroker.mihome-vacuum/package.json
                                          mario@iobroker:~$ iob upgrade mihome-vacuum@4.1.1
                                          Would you like to reinstall version 4.1.1 of mihome-vacuum now? [(y)es, (n)o]: y
                                          Update mihome-vacuum from @4.1.1 to @4.1.1
                                          NPM version: 10.5.0
                                          Installing iobroker.mihome-vacuum@4.1.1... (System call)
                                          npm ERR! code 127
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-31T12_32_38_352Z-debug-0.log
                                          host.iobroker Cannot install iobroker.mihome-vacuum@4.1.1: 127
                                          mario@iobroker:~$ npm ls zlib
                                          /home/mario
                                          └── (empty)
                                          node:internal/modules/cjs/loader:1143
                                            throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                              at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                              at Module._load (node:internal/modules/cjs/loader:981:27)
                                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                              at node:internal/main/run_main_module:28:49 {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: []
                                          Node.js v18.20.0
                                          mario@iobroker:~$
