  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • G Greenhorn
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-25 21:25:58 CET
               Universal time: Sun 2024-02-25 20:25:58 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    simon
    /home/simon
    simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.6G        1.0G
             3794 M total memory
             1639 M used memory
             1813 M active memory
              913 M inactive memory
              905 M free memory
               42 M buffer memory
             1206 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  5.3G   23G  19% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G	/var/
    859M	/var/log
    841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
    356M	/var/cache
    Archived and active journals take up 840.1M in the file system.
    /opt/iobroker/backups:
    55M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    657M	/opt/iobroker/iobroker-data/
    163M	/opt/iobroker/iobroker-data/files
    57M	/opt/iobroker/iobroker-data/files/javascript.admin
    40M	/opt/iobroker/iobroker-data/backup-objects
    38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    447M	/opt/iobroker/iobroker-data/objects.jsonl
    22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    7.0M	/opt/iobroker/iobroker-data/states.jsonl
    7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.1
    /usr/bin/node 		v18.19.1
    /usr/bin/npm 		10.2.4
    /usr/bin/npx 		10.2.4
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.13.16
    javascript: 	7.8.0
    Adapters from github: 	0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
    + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
    + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hmip"         : 1.21.0   , installed 1.21.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
    bjects and States
    Objects: 	3913
    States: 	3266
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
    udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
    udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
    2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
    2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
    2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
    2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
    2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
    2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
    l":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
    2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
    2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
    2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
    iob diag has finished.
    Copy text starting here:
    			v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	0
    Pending iob updates: 	1
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
    			/usr/bin/npm 		10.2.4
    			/usr/bin/npx 		10.2.4
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
    Swap:            99M          0B         99M
    Total:          3.9G        1.8G        757M
    Active iob-Instances: 	9
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		3913
    States: 		3266
    Size of iob-Database:
    7.2M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    simon@iobroker:~ $
    #61
    @greenhorn
    iob stop
    iob upgrade self
    iob start
    G 1 Antwort Letzte Antwort
      @greenhorn
      iob stop
      iob upgrade self
      iob start
      Greenhorn
      #62
      @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
      iob start
      simon@iobroker:~ $ iob stop
      simon@iobroker:~ $ iob upgrade self
      No connection to databases possible ...
      simon@iobroker:~ $ iob start
      simon@iobroker:~ $
      • G Greenhorn
        iob start
        simon@iobroker:~ $
        #63
        @greenhorn
        Kein Wunder. Die ist ja auch RIESIG:
        Versuch mal ein
        iob stop
        iob fix
        iob upgade self
          @greenhorn
          Versuch mal ein
          iob stop
          iob fix
          iob upgade self
          Greenhorn
          #64
          Update js-controller from @4.0.24 to @5.0.19
          Stopped Objects DB
          Stopped States DB
          NPM version: 10.2.4
          Installing iobroker.js-controller@5.0.19... (System call)
          added 2 packages, removed 12 packages, and changed 29 packages in 1m
          136 packages are looking for funding
            run `npm fund` for details
          simon@iobroker:~ $
          • G Greenhorn
            Stopped Objects DB
            Stopped States DB
            NPM version: 10.2.4
            simon@iobroker:~ $
            #65
            @greenhorn
            Dann sollte es das nun gewesen sein.
            • G Offline
              Greenhorn
              #66
              Kann den iobroker aber leider immer noch nicht wieder aufrufen :-(
              • G Greenhorn
                #67
                @greenhorn
                iob diag
                • wendy2702W Offline
                  wendy2702W Offline
                  wendy2702
                  #68
                  Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
                    @greenhorn
                    iob diag
                    Greenhorn
                    #69
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
                    CPU threads: 4
                    Current issues:
                                   Local time: Sun 2024-02-25 21:51:48 CET
                               Universal time: Sun 2024-02-25 20:51:48 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    simon
                    /home/simon
                    X-Server: 	false
                    Desktop:
                    Terminal: 	tty
                    *** MEMORY ***
                    Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
                    Swap:            99M          0B         99M
                    Total:          3.9G        2.1G        594M
                             3794 M total memory
                             2118 M used memory
                             2335 M active memory
                              732 M inactive memory
                              494 M free memory
                               84 M buffer memory
                             1097 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       29G  5.0G   23G  19% /
                    /var:
                    1.5G	/var/
                    859M	/var/log
                    356M	/var/cache
                    318M	/opt/iobroker/iobroker-data/
                    115M	/opt/iobroker/iobroker-data/objects.jsonl
                    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                    USB-Devices by-id:
                    /usr/bin/npm 		10.2.4
                    /usr/bin/npx 		10.2.4
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    js-controller: 	5.0.19
                    admin: 		6.13.16
                    javascript: 	7.8.0
                    Adapter State
                    + instance is alive
                    Controller "js-controller": 5.0.19   , installed 5.0.19
                    Objects and States
                    Objects: 	3913
                    States: 	3266
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
                    2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
                    2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
                    2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
                    2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
                    2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
                    2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
                    v.2023-10-10
                    Icon name: computer
                    Architecture: arm64
                    Kernel: aarch64
                    Userland: arm64
                    User-ID: 1000
                    X-Server: false
                    Pending iob updates: 0
                    /usr/bin/npm 10.2.4
                    /usr/bin/npx 10.2.4
                    MEMORY:
                    total used free shared buff/cache available
                    Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
                    Swap: 99M 0B 99M
                    Total: 3.9G 1.7G 994M
                    ioBroker Core: js-controller 5.0.19
                    admin 6.13.16
                    Objects type: jsonl
                    States type: jsonl
                    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects: 3913
                    States: 3266
                    116M /opt/iobroker/iobroker-data/objects.jsonl
                    1.3M /opt/iobroker/iobroker-data/states.jsonl
                    simon@iobroker:~ $
                    • wendy2702W wendy2702
                      HomoranH Offline
                      HomoranH Offline
                      #70
                      @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                      so ist es!
                      @Greenhorn
                      iob start admin
                        so ist es!
                        @Greenhorn
                        iob start admin
                        Greenhorn
                        #71
                        Ja, stimmt.
                        kann den ioBroker aber immer noch nicht öffnen...
                        wendy2702W HomoranH 2 Antworten Letzte Antwort
                        • G Greenhorn
                          Ja, stimmt.
                          wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          #72
                          @greenhorn zeige uns ein/Ausgabe des Befehls
                          Mach mal so
                          iob start admin.0
                          • G Greenhorn
                            Ja, stimmt.
                            HomoranH Offline
                            HomoranH Offline
                            #73
                            @greenhorn ist der admin jetzt aktiv?
                            wenn nein, was hindert ihn daran? =was steht im log?
                            • G Offline
                              Greenhorn
                              #74
                              @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
                              iob start admin.0
                              👍🙏😀 Es geht wieder, ich fass´es nicht !
                              Ihr seid die Besten !!! Allerherzlichsten Dank !!!
                              • G Offline
                                Greenhorn
                                #75
                                Gleich ab morgen werde ich mich mit dem Thema Backup beschäftigen...
                                Mann oh Mann, was ein Schock 😬 Ich bin soo froh dass das wieder geht.
                                Nochmal allerherzlichsten Dank an euch 👍
                                • G Greenhorn
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  wendy2702
                                  #76
                                  @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                  Tippe schnell in die Konsole
                                  iob backup
                                  Dann hast du wenigsten schonmal eins
                                    iob backup
                                    Greenhorn
                                    #77
                                    @wendy2702
                                    Das habe ich gestern leider nicht mehr gemacht, hatte es nicht mehr gesehen.
                                    Heute morgen habe ich festgestellt, dass einige Instanzen nicht aktiv waren. Habe sie dann nacheinander aktiviert, mit dem Ergebnis, dass der Raspi so rödelt, dass er keinen Befehl mehr annimmt. Diesmal lasse ich ihn aber laufen bis ich heute nachmittag nachhause komme. Vielleicht hat er sich bis dahin beruhigt…
                                    • G Greenhorn
                                      @wendy2702
                                      CodierknechtC Offline
                                      Codierknecht
                                      #78
                                      @greenhorn
                                      Weiß Du noch welche?
                                      Mir scheint auch die objects.json etwas groß.
                                      Ich habe z.B. fast doppelt so viele Objekte, die Datei ist aber nur 1/4 so groß.
                                      @Thomas-Braun
                                      Kann man im diag-Script an die Liste der aktiven Instanzen auch deren Speicherverbrauch prömpeln?
                                      Mir fällt immer wieder auf, dass die Anwender häufig Probleme mit dem RAM haben.
                                      Wäre doch praktisch, wenn man in der Ausgabe auch gleich sehen könnte, wo die "dicken Hunde" stecken.
                                      Zumindest was die ioBroker-Instanzen betrifft.
                                      HmIP|ZigBee|Tasmota|Unifi
                                      Zabbix Certified Specialist
                                      Thomas BraunT G 2 Antworten Letzte Antwort
                                      • CodierknechtC Codierknecht
                                        @greenhorn
                                        @Thomas-Braun
                                        #79
                                        @codierknecht sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                        In einer Beta-Version ist ein Snapshot von 'top' drin.
                                        Das ganze ist aber halt nur ein Snapshot und damit nur bedingt Aussage kräftig.
                                          @greenhorn
                                          @Thomas-Braun
                                          Greenhorn
                                          #80
                                          @codierknecht
                                          Nicht genau, aber ca. die Hälfte war nicht aktiv. U.a. die Influx, die habe ich aber vorsichtshalber gar nicht aktiviert, weil ich die am meisten in Verdacht hatte, alles zu blockieren…
