  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • G Greenhorn
    OK, grad mal noch neues iob.diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-25 20:05:04 GMT
               Universal time: Sun 2024-02-25 20:05:04 UTC
                     RTC time: n/a
                    Time zone: Europe/London (GMT, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    simon
    /home/simon
    simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.7G        840M
             3794 M total memory
             1680 M used memory
             1813 M active memory
              990 M inactive memory
              740 M free memory
              124 M buffer memory
             1247 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.9G   23G  18% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G	/var/
    859M	/var/log
    841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
    356M	/var/cache
    Archived and active journals take up 840.1M in the file system.
    /opt/iobroker/backups:
    55M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    505M	/opt/iobroker/iobroker-data/
    135M	/opt/iobroker/iobroker-data/files
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    40M	/opt/iobroker/iobroker-data/backup-objects
    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    325M	/opt/iobroker/iobroker-data/objects.jsonl
    7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
    5.1M	/opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.1
    /usr/bin/node 		v18.19.1
    /usr/bin/npm 		10.2.4
    /usr/bin/npx 		10.2.4
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.8.0
    javascript: 	7.1.4
    Adapters from github: 	0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
    + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
    + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
    Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
    Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
    Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
    Objects and States
    wendy2702W Offline
    wendy2702W Offline
    @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
    • G Greenhorn
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      simon
      /home/simon
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
               1680 M used memory
                740 M free memory
                124 M buffer memory
               1247 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.5G	/var/
      859M	/var/log
      356M	/var/cache
      USB-Devices by-id:
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.8.0
      javascript: 	7.1.4
      Adapter State
      + instance is alive
      Objects and States
      @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
      • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
      • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
      Die liegen nauf dem gleichen Port.
        Stell das richtig ein. Geht in
        sudo raspi-config
        Dann
        sudo rm /etc/apt/sources.list.d/influ*
        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        rm influxdata-archive_compat.key
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Dann
        iob update
        iob upgrade all -y
        iob stop
        iob upgrade self
        iob restart
        Greenhorn
        @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
        iob upgrade all -y
        Läuft noch...melde mich wenn fertig.
          sudo raspi-config
          Dann
          sudo apt update
          sudo reboot
          Dann
          iob update
          iob upgrade all -y
          iob stop
          iob upgrade self
          iob restart
          Greenhorn
          iob restart
          Alles einwandfrei durchgelaufen bis auf:
          simon@iobroker:~ $ iob upgrade self
          No connection to databases possible ...
          • G Greenhorn
            iob restart
            @greenhorn
            iob restart
            iob diag
            G 1 Antwort Letzte Antwort
              @greenhorn
              iob restart
              iob diag
              Greenhorn
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
              CPU threads: 4
              Current issues:
                             Local time: Sun 2024-02-25 21:25:58 CET
                         Universal time: Sun 2024-02-25 20:25:58 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              simon
              /home/simon
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
              Swap:            99M          0B         99M
              Total:          3.9G        1.6G        1.0G
                       3794 M total memory
                       1639 M used memory
                        913 M inactive memory
                        905 M free memory
                         42 M buffer memory
                       1206 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       29G  5.3G   23G  19% /
              [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              /var:
              1.5G	/var/
              859M	/var/log
              356M	/var/cache
              657M	/opt/iobroker/iobroker-data/
              163M	/opt/iobroker/iobroker-data/files
              57M	/opt/iobroker/iobroker-data/files/javascript.admin
              38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              447M	/opt/iobroker/iobroker-data/objects.jsonl
              22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
              8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
              7.0M	/opt/iobroker/iobroker-data/states.jsonl
              7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
              USB-Devices by-id:
              /usr/bin/npm 		10.2.4
              /usr/bin/npx 		10.2.4
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.13.16
              javascript: 	7.8.0
              Adapter State
              + instance is alive
              Adapter    "admin"        : 6.13.16  , installed 6.13.16
              Adapter    "backitup"     : 2.10.11  , installed 2.10.11
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Adapter    "hmip"         : 1.21.0   , installed 1.21.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "web"          : 6.2.3    , installed 6.2.3
              Adapter    "ws"           : 2.5.10   , installed 2.5.10
              Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
              bjects and States
              Objects: 	3913
              States: 	3266
              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:5 https://apt.grafana.com stable InRelease
              Hit:6 https://repos.influxdata.com/debian stable InRelease
              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
              tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
              tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
              udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
              udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
              2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
              2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
              2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
              2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
              2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
              2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
              l":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
              2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
              2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
              2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
              iob diag has finished.
              Copy text starting here:
              			v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Installation: 		native
              Kernel: 		aarch64
              Userland: 		arm64
              Timezone: 		Europe/Berlin (CET, +0100)
              User-ID: 		1000
              X-Server: 		false
              Pending OS-Updates: 	0
              Pending iob updates: 	1
              Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
              			/usr/bin/npm 		10.2.4
              			/usr/bin/npx 		10.2.4
              Recommended versions are nodejs  and npm
              MEMORY:
              Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
              Swap:            99M          0B         99M
              Total:          3.9G        1.8G        757M
              Active iob-Instances: 	9
              ioBroker Core: 		js-controller 		4.0.24
              			admin 			6.13.16
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              Objects: 		3913
              States: 		3266
              Size of iob-Database:
              7.2M	/opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
              simon@iobroker:~ $
              • G Greenhorn
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                simon
                /home/simon
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3794 M total memory
                         1639 M used memory
                          905 M free memory
                           42 M buffer memory
                         1206 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.5G	/var/
                859M	/var/log
                356M	/var/cache
                USB-Devices by-id:
                /usr/bin/npm 		10.2.4
                /usr/bin/npx 		10.2.4
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		6.13.16
                javascript: 	7.8.0
                Adapter State
                + instance is alive
                bjects and States
                Objects: 	3913
                States: 	3266
                Pending Updates: 0
                			v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                Kernel: 		aarch64
                Userland: 		arm64
                User-ID: 		1000
                X-Server: 		false
                			/usr/bin/npm 		10.2.4
                			/usr/bin/npx 		10.2.4
                MEMORY:
                Swap:            99M          0B         99M
                			admin 			6.13.16
                Objects type: jsonl
                States  type: jsonl
                Objects: 		3913
                States: 		3266
                simon@iobroker:~ $
                @greenhorn
                iob stop
                iob upgrade self
                iob start
                  @greenhorn
                  iob stop
                  iob upgrade self
                  iob start
                  Greenhorn
                  iob start
                  simon@iobroker:~ $ iob stop
                  simon@iobroker:~ $ iob start
                  simon@iobroker:~ $
                  • G Greenhorn
                    iob start
                    simon@iobroker:~ $
                    @greenhorn
                    Kein Wunder. Die ist ja auch RIESIG:
                    Versuch mal ein
                    iob stop
                    iob fix
                    iob upgade self
                      @greenhorn
                      Versuch mal ein
                      iob stop
                      iob fix
                      iob upgade self
                      Greenhorn
                      Update js-controller from @4.0.24 to @5.0.19
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.2.4
                      Installing iobroker.js-controller@5.0.19... (System call)
                      added 2 packages, removed 12 packages, and changed 29 packages in 1m
                      136 packages are looking for funding
                        run `npm fund` for details
                      simon@iobroker:~ $
                      • G Greenhorn
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 10.2.4
                        simon@iobroker:~ $
                        @greenhorn
                        Dann sollte es das nun gewesen sein.
                        • G Offline
                          Greenhorn
                          #66
                          Kann den iobroker aber leider immer noch nicht wieder aufrufen :-(
                          • G Greenhorn
                            #67
                            @greenhorn
                            iob diag
                            • wendy2702W Offline
                              wendy2702W Offline
                              #68
                              Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
                                @greenhorn
                                iob diag
                                Greenhorn
                                #69
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
                                CPU threads: 4
                                Current issues:
                                               Local time: Sun 2024-02-25 21:51:48 CET
                                           Universal time: Sun 2024-02-25 20:51:48 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                simon
                                /home/simon
                                X-Server: 	false
                                Desktop:
                                Terminal: 	tty
                                *** MEMORY ***
                                Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
                                Swap:            99M          0B         99M
                                Total:          3.9G        2.1G        594M
                                         3794 M total memory
                                         2118 M used memory
                                         2335 M active memory
                                          732 M inactive memory
                                          494 M free memory
                                           84 M buffer memory
                                         1097 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       29G  5.0G   23G  19% /
                                /var:
                                1.5G	/var/
                                859M	/var/log
                                356M	/var/cache
                                318M	/opt/iobroker/iobroker-data/
                                115M	/opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm 		10.2.4
                                /usr/bin/npx 		10.2.4
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                js-controller: 	5.0.19
                                admin: 		6.13.16
                                javascript: 	7.8.0
                                Adapter State
                                + instance is alive
                                Controller "js-controller": 5.0.19   , installed 5.0.19
                                Objects and States
                                Objects: 	3913
                                States: 	3266
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
                                2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
                                2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
                                2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
                                2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
                                2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
                                2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
                                v.2023-10-10
                                Icon name: computer
                                Architecture: arm64
                                Kernel: aarch64
                                Userland: arm64
                                User-ID: 1000
                                X-Server: false
                                Pending iob updates: 0
                                /usr/bin/npm 10.2.4
                                /usr/bin/npx 10.2.4
                                MEMORY:
                                total used free shared buff/cache available
                                Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
                                Swap: 99M 0B 99M
                                Total: 3.9G 1.7G 994M
                                ioBroker Core: js-controller 5.0.19
                                admin 6.13.16
                                Objects type: jsonl
                                States type: jsonl
                                • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects: 3913
                                States: 3266
                                116M /opt/iobroker/iobroker-data/objects.jsonl
                                1.3M /opt/iobroker/iobroker-data/states.jsonl
                                simon@iobroker:~ $
                                • wendy2702W wendy2702
                                  HomoranH Offline
                                  HomoranH Offline
                                  #70
                                  @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                  so ist es!
                                  @Greenhorn
                                  iob start admin
                                    so ist es!
                                    @Greenhorn
                                    iob start admin
                                    Greenhorn
                                    #71
                                    Ja, stimmt.
                                    kann den ioBroker aber immer noch nicht öffnen...
                                    wendy2702W HomoranH 2 Antworten Letzte Antwort
                                    • G Greenhorn
                                      Ja, stimmt.
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      #72
                                      @greenhorn zeige uns ein/Ausgabe des Befehls
                                      Mach mal so
                                      iob start admin.0
                                      • G Greenhorn
                                        Ja, stimmt.
                                        HomoranH Offline
                                        HomoranH Offline
                                        #73
                                        @greenhorn ist der admin jetzt aktiv?
                                        wenn nein, was hindert ihn daran? =was steht im log?
                                        • G Offline
                                          Greenhorn
                                          #74
                                          @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
                                          iob start admin.0
                                          👍🙏😀 Es geht wieder, ich fass´es nicht !
                                          Ihr seid die Besten !!! Allerherzlichsten Dank !!!
