  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • wendy2702W wendy2702
    Dann jetzt mal
    iob diag
    Davon dann auch die Langfassung Ausgabe mal zeigen
    Greenhorn
    @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:47:29 up 32 min,  1 user,  load average: 0.31, 0.55, 0.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-25 19:47:30 GMT
               Universal time: Sun 2024-02-25 19:47:30 UTC
                     RTC time: n/a
                    Time zone: Europe/London (GMT, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    simon
    /home/simon
    simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.8G        955M        1.0M        1.0G        2.2G
    Swap:            99M          0B         99M
    Total:          3.9G        1.8G        1.1G
             3794 M total memory
             1830 M used memory
             1700 M active memory
              921 M inactive memory
              955 M free memory
               75 M buffer memory
              932 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.7G   24G  17% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G	/var/
    859M	/var/log
    841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
    302M	/var/cache
    Archived and active journals take up 840.1M in the file system.
    /opt/iobroker/backups:
    55M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    463M	/opt/iobroker/iobroker-data/
    135M	/opt/iobroker/iobroker-data/files
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    40M	/opt/iobroker/iobroker-data/backup-objects
    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    285M	/opt/iobroker/iobroker-data/objects.jsonl
    7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
    4.6M	/opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v12.22.12
    /usr/bin/node 		v12.22.12
    /home/iobroker/.diag.sh: line 279: npm: command not found
    /home/iobroker/.diag.sh: line 280: npx: command not found
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 290: npm: command not found
    /home/iobroker/.diag.sh: line 291: npx: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.12~dfsg-1~deb11u4
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
     *** 12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    /home/iobroker/.diag.sh: line 360: npm: command not found
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.8.0
    javascript: 	7.1.4
    /home/iobroker/.diag.sh: line 375: npm: command not found
    Adapters from github: 	0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
    + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
    + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
    Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
    Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
    Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
    Objects and States
    Objects: 	3908
    States: 	3264
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14428      512/influxd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28796      4257/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13142      553/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27223      4238/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28486      4238/iobroker.js-co
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        14037      512/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27330      4313/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13153      553/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        14178      692/grafana
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12258      400/avahi-daemon: r
    udp        0      0 0.0.0.0:42522           0.0.0.0:*                           108        12260      400/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      691/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12259      400/avahi-daemon: r
    udp6       0      0 :::57185                :::*                                108        12261      400/avahi-daemon: r
    2024-02-25 19:41:36.839  - info: iqontrol.0 (4359) Creating Popup States...
    2024-02-25 19:41:37.570  - info: iqontrol.0 (4359) Creating Widget States...
    2024-02-25 19:41:37.571  - info: iqontrol.0 (4359) Lists deactivated.
    2024-02-25 19:41:37.572  - info: iqontrol.0 (4359) Deleting unused Objects...
    2024-02-25 19:41:37.574  - info: iqontrol.0 (4359) Subscribing to states...
    2024-02-25 19:41:37.575  - info: iqontrol.0 (4359) iQontrol ready.
    2024-02-25 19:41:43.883  - info: hmip.0 (4272) ws connection opened
    2024-02-25 19:41:44.152  - info: hmip.0 (4272) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"14":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":14,"groupIndex":7,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}},"15":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":15,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_PRIMARY_ACTION_CHANNEL","groups":[],"channelRole":null,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"16":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
    2024-02-25 19:41:54.684  - info: hmip.0 (4272) hmip adapter connected and ready
    Copy text starting here:
    			v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/London (GMT, +0000)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	3
    Pending iob updates: 	14
    Nodejs-Installation: 	/usr/bin/nodejs 	v12.22.12
    /home/iobroker/.diag.sh: line 488: npm: command not found
    /home/iobroker/.diag.sh: line 489: npx: command not found
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs  and npm
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        1.9G        909M        1.0M        998M        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.9G        1.0G
    Active iob-Instances: 	9
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.8.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		3908
    States: 		3264
    Size of iob-Database:
    4.2M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
    • G Offline
      Greenhorn
      Musste zwischendrin etwas ausschneiden, weil der Eintrag sonst zu lang geworden wäre...
      • G Greenhorn
        iob diag
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        simon
        /home/simon
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                 1830 M used memory
                  955 M free memory
                   75 M buffer memory
                  932 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.4G	/var/
        859M	/var/log
        302M	/var/cache
        USB-Devices by-id:
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.8.0
        javascript: 	7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	3908
        States: 	3264
        Pending Updates: 3
        			v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Kernel: 		aarch64
        Userland: 		arm64
        User-ID: 		1000
        X-Server: 		false
        Please check
        MEMORY:
        Swap:            99M          0B         99M
        			admin 			6.8.0
        Objects type: jsonl
        States  type: jsonl
        Objects: 		3908
        States: 		3264
        wendy2702W Offline
        wendy2702W Offline
        @greenhorn
        Jetzt
        iob nodejs-update
        Dauert wahrscheinlich was länger.
        G 1 Antwort Letzte Antwort
          @greenhorn
          Jetzt
          iob nodejs-update
          Greenhorn
          iob nodejs-update
          ioBroker nodejs updater 2023-10-13
          No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
          Your current setup is:
          /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
          /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
          /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
          /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
          We found these nodejs versions available for installation:
          nodejs:
          Version table:
          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
          Press <y> to continue or any other key to quit
          Fixing your nodejs setup
          *** Deleting ***
          rm: cannot remove '': No such file or directory
          *** Deleting ***
          Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
          You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
          Update der Installation läuft gerade noch...
          • G Offline
            Greenhorn
            *** Deleting ***
            *** Deleting ***
            Trying to update your installation now. Please be patient.
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://apt.grafana.com stable InRelease
            Get:6 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
            Err:6 https://repos.influxdata.com/debian bullseye InRelease
            Reading package lists... Done
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Get:5 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
            Hit:6 https://apt.grafana.com stable InRelease
            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
            Err:5 https://repos.influxdata.com/debian bullseye InRelease
            Installing the recommended nodejs version now!
            Exact recommended version unknown, installing a fallback!
            (Reading database ... 55472 files and directories currently installed.)
            Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
            dpkg: libnode72:arm64: dependency problems, but removing anyway as you requested:
            nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
            Removing libnode72:arm64 (12.22.12~dfsg-1~deb11u4) ...
            (Reading database ... 55284 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
            Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
            Setting up nodejs (18.0.0-1nodesource1) ...
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
            Processing triggers for man-db (2.9.4-2) ...
            Updating fallback to latest nodejs v18 release
            Preconfiguring packages ...
            (Reading database ... 60946 files and directories currently installed.)
            Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
            Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
            Setting up tar (1.34+dfsg-1+deb11u1) ...
            Preparing to unpack .../tzdata_2024a-0+deb11u1_all.deb ...
            Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u11) ...
            Preparing to unpack .../distro-info-data_0.51+deb11u5_all.deb ...
            Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
            Preparing to unpack .../nodejs_18.19.1-1nodesource1_arm64.deb ...
            Detected old npm client, removing...
            Unpacking nodejs (18.19.1-1nodesource1) over (18.0.0-1nodesource1) ...
            Setting up distro-info-data (0.51+deb11u5) ...
            Setting up nodejs (18.19.1-1nodesource1) ...
            Setting up tzdata (2024a-0+deb11u1) ...
            Current default time zone: 'Europe/London'
            Local time is now: Sun Feb 25 20:02:26 GMT 2024.
            Universal Time is now: Sun Feb 25 20:02:26 UTC 2024.
            Run 'dpkg-reconfigure tzdata' if you wish to change it.
            Processing triggers for mailcap (3.69) ...
            v18.19.1 has been installed! You are using the latest version now!
            Installing the recommended nodejs version!
            We tried our best to update or fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
            Please refresh or restart your browser in a few moments.
            simon@iobroker:~ $
            • G Greenhorn
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              simon
              /home/simon
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3794 M total memory
                       1830 M used memory
                        955 M free memory
                         75 M buffer memory
                        932 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              1.4G	/var/
              859M	/var/log
              302M	/var/cache
              USB-Devices by-id:
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.8.0
              javascript: 	7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	3908
              States: 	3264
              Pending Updates: 3
              			v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Kernel: 		aarch64
              Userland: 		arm64
              User-ID: 		1000
              X-Server: 		false
              Please check
              MEMORY:
              Swap:            99M          0B         99M
              			admin 			6.8.0
              Objects type: jsonl
              States  type: jsonl
              Objects: 		3908
              States: 		3264
              @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
              Stell das richtig ein. Geht in
              sudo raspi-config
              Dann
              sudo rm /etc/apt/sources.list.d/influ*
              wget -q https://repos.influxdata.com/influxdata-archive_compat.key
              echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
              echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
              rm influxdata-archive_compat.key
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Dann
              iob update
              iob upgrade all -y
              iob stop
              iob upgrade self
              iob restart
              G 2 Antworten Letzte Antwort
              • G Offline
                Greenhorn
                OK, grad mal noch neues iob.diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
                CPU threads: 4
                Current issues:
                               Local time: Sun 2024-02-25 20:05:04 GMT
                           Universal time: Sun 2024-02-25 20:05:04 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                simon
                /home/simon
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
                Swap:            99M          0B         99M
                Total:          3.9G        1.7G        840M
                         3794 M total memory
                         1680 M used memory
                         1813 M active memory
                          990 M inactive memory
                          740 M free memory
                          124 M buffer memory
                         1247 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       29G  4.9G   23G  18% /
                /var:
                1.5G	/var/
                859M	/var/log
                356M	/var/cache
                505M	/opt/iobroker/iobroker-data/
                325M	/opt/iobroker/iobroker-data/objects.jsonl
                5.1M	/opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/nodejs 	v18.19.1
                /usr/bin/node 		v18.19.1
                /usr/bin/npm 		10.2.4
                /usr/bin/npx 		10.2.4
                /usr/bin/corepack 	0.22.0
                nodejs:
                  Installed: 18.19.1-1nodesource1
                  Version table:
                 *** 18.19.1-1nodesource1 1001
                     18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		6.8.0
                javascript: 	7.1.4
                Adapter State
                + instance is alive
                Objects and States
                • G Greenhorn
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  simon
                  /home/simon
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           3794 M total memory
                           1680 M used memory
                            740 M free memory
                            124 M buffer memory
                           1247 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.5G	/var/
                  859M	/var/log
                  356M	/var/cache
                  USB-Devices by-id:
                  /usr/bin/npm 		10.2.4
                  /usr/bin/npx 		10.2.4
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.8.0
                  javascript: 	7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  wendy2702W Offline
                  wendy2702W Offline
                  @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
                  • G Greenhorn
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    simon
                    /home/simon
                    X-Server: 	false
                    Desktop:
                    Terminal: 	tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             3794 M total memory
                             1680 M used memory
                              740 M free memory
                              124 M buffer memory
                             1247 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.5G	/var/
                    859M	/var/log
                    356M	/var/cache
                    USB-Devices by-id:
                    /usr/bin/npm 		10.2.4
                    /usr/bin/npx 		10.2.4
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.8.0
                    javascript: 	7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
                    • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
                    Die liegen nauf dem gleichen Port.
                      sudo raspi-config
                      Dann
                      sudo apt update
                      sudo reboot
                      Dann
                      iob update
                      iob upgrade all -y
                      iob stop
                      iob upgrade self
                      iob restart
                      Greenhorn
                      @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
                      iob upgrade all -y
                      Läuft noch...melde mich wenn fertig.
                        sudo raspi-config
                        Dann
                        sudo apt update
                        sudo reboot
                        Dann
                        iob update
                        iob upgrade all -y
                        iob stop
                        iob upgrade self
                        iob restart
                        Greenhorn
                        iob restart
                        Alles einwandfrei durchgelaufen bis auf:
                        simon@iobroker:~ $ iob upgrade self
                        No connection to databases possible ...
                        • G Greenhorn
                          iob restart
                          @greenhorn
                          iob restart
                          iob diag
                            @greenhorn
                            iob restart
                            iob diag
                            Greenhorn
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2024-02-25 21:25:58 CET
                                       Universal time: Sun 2024-02-25 20:25:58 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            simon
                            /home/simon
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.6G        1.0G
                                     3794 M total memory
                                     1639 M used memory
                                      913 M inactive memory
                                      905 M free memory
                                       42 M buffer memory
                                     1206 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G  5.3G   23G  19% /
                            [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            /var:
                            1.5G	/var/
                            859M	/var/log
                            356M	/var/cache
                            657M	/opt/iobroker/iobroker-data/
                            163M	/opt/iobroker/iobroker-data/files
                            57M	/opt/iobroker/iobroker-data/files/javascript.admin
                            38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                            447M	/opt/iobroker/iobroker-data/objects.jsonl
                            22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                            8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                            7.0M	/opt/iobroker/iobroker-data/states.jsonl
                            7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                            USB-Devices by-id:
                            /usr/bin/npm 		10.2.4
                            /usr/bin/npx 		10.2.4
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.13.16
                            javascript: 	7.8.0
                            Adapter State
                            + instance is alive
                            Adapter    "admin"        : 6.13.16  , installed 6.13.16
                            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                            Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                            Adapter    "web"          : 6.2.3    , installed 6.2.3
                            Adapter    "ws"           : 2.5.10   , installed 2.5.10
                            Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                            bjects and States
                            Objects: 	3913
                            States: 	3266
                            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:6 https://repos.influxdata.com/debian stable InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                            tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                            tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                            udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                            udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                            udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                            2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                            2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                            2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                            2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                            2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                            2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                            2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                            2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                            2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                            iob diag has finished.
                            			v.2023-10-10
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel: 		aarch64
                            Userland: 		arm64
                            Timezone: 		Europe/Berlin (CET, +0100)
                            User-ID: 		1000
                            X-Server: 		false
                            Pending OS-Updates: 	0
                            Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                            			/usr/bin/npm 		10.2.4
                            			/usr/bin/npx 		10.2.4
                            MEMORY:
                            Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.8G        757M
                            			admin 			6.13.16
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		3913
                            States: 		3266
                            7.2M	/opt/iobroker/iobroker-data/states.jsonl
                            simon@iobroker:~ $
                            • G Greenhorn
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              simon
                              /home/simon
                              X-Server: 	false
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                       1639 M used memory
                                        905 M free memory
                                         42 M buffer memory
                                       1206 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              1.5G	/var/
                              859M	/var/log
                              356M	/var/cache
                              USB-Devices by-id:
                              /usr/bin/npm 		10.2.4
                              /usr/bin/npx 		10.2.4
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin: 		6.13.16
                              javascript: 	7.8.0
                              Adapter State
                              + instance is alive
                              bjects and States
                              Objects: 	3913
                              States: 	3266
                              Pending Updates: 0
                              			v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel: 		aarch64
                              Userland: 		arm64
                              User-ID: 		1000
                              X-Server: 		false
                              			/usr/bin/npm 		10.2.4
                              			/usr/bin/npx 		10.2.4
                              MEMORY:
                              Swap:            99M          0B         99M
                              			admin 			6.13.16
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		3913
                              States: 		3266
                              simon@iobroker:~ $
                              @greenhorn
                              iob stop
                              iob upgrade self
                              iob start
                                @greenhorn
                                iob stop
                                iob upgrade self
                                iob start
                                Greenhorn
                                iob start
                                simon@iobroker:~ $ iob stop
                                simon@iobroker:~ $ iob start
                                simon@iobroker:~ $
                                • G Greenhorn
                                  iob start
                                  simon@iobroker:~ $
                                  @greenhorn
                                  Kein Wunder. Die ist ja auch RIESIG:
                                  Versuch mal ein
                                  iob stop
                                  iob fix
                                  iob upgade self
                                    @greenhorn
                                    Versuch mal ein
                                    iob stop
                                    iob fix
                                    iob upgade self
                                    Greenhorn
                                    Update js-controller from @4.0.24 to @5.0.19
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 10.2.4
                                    Installing iobroker.js-controller@5.0.19... (System call)
                                    added 2 packages, removed 12 packages, and changed 29 packages in 1m
                                    136 packages are looking for funding
                                      run `npm fund` for details
                                    simon@iobroker:~ $
                                    • G Greenhorn
                                      Stopped Objects DB
                                      Stopped States DB
                                      NPM version: 10.2.4
                                      simon@iobroker:~ $
                                      @greenhorn
                                      Dann sollte es das nun gewesen sein.
                                      • G Offline
                                        Greenhorn
                                        #66
                                        Kann den iobroker aber leider immer noch nicht wieder aufrufen :-(
                                        • G Greenhorn
                                          #67
                                          @greenhorn
                                          iob diag
