  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • G Greenhorn
    @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:47:29 up 32 min,  1 user,  load average: 0.31, 0.55, 0.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-25 19:47:30 GMT
               Universal time: Sun 2024-02-25 19:47:30 UTC
                     RTC time: n/a
                    Time zone: Europe/London (GMT, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    simon
    /home/simon
    simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.8G        955M        1.0M        1.0G        2.2G
    Swap:            99M          0B         99M
    Total:          3.9G        1.8G        1.1G
             3794 M total memory
             1830 M used memory
             1700 M active memory
              921 M inactive memory
              955 M free memory
               75 M buffer memory
              932 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.7G   24G  17% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G	/var/
    859M	/var/log
    841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
    302M	/var/cache
    Archived and active journals take up 840.1M in the file system.
    /opt/iobroker/backups:
    55M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    463M	/opt/iobroker/iobroker-data/
    135M	/opt/iobroker/iobroker-data/files
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    40M	/opt/iobroker/iobroker-data/backup-objects
    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    285M	/opt/iobroker/iobroker-data/objects.jsonl
    7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
    4.6M	/opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v12.22.12
    /usr/bin/node 		v12.22.12
    /home/iobroker/.diag.sh: line 279: npm: command not found
    /home/iobroker/.diag.sh: line 280: npx: command not found
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 290: npm: command not found
    /home/iobroker/.diag.sh: line 291: npx: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.12~dfsg-1~deb11u4
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
     *** 12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    /home/iobroker/.diag.sh: line 360: npm: command not found
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.8.0
    javascript: 	7.1.4
    /home/iobroker/.diag.sh: line 375: npm: command not found
    Adapters from github: 	0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
    + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
    + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
    Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
    Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
    Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
    Objects and States
    Objects: 	3908
    States: 	3264
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14428      512/influxd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28796      4257/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13142      553/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27223      4238/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28486      4238/iobroker.js-co
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        14037      512/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27330      4313/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13153      553/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        14178      692/grafana
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12258      400/avahi-daemon: r
    udp        0      0 0.0.0.0:42522           0.0.0.0:*                           108        12260      400/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      691/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12259      400/avahi-daemon: r
    udp6       0      0 :::57185                :::*                                108        12261      400/avahi-daemon: r
    2024-02-25 19:41:36.839  - info: iqontrol.0 (4359) Creating Popup States...
    2024-02-25 19:41:37.570  - info: iqontrol.0 (4359) Creating Widget States...
    2024-02-25 19:41:37.571  - info: iqontrol.0 (4359) Lists deactivated.
    2024-02-25 19:41:37.572  - info: iqontrol.0 (4359) Deleting unused Objects...
    2024-02-25 19:41:37.574  - info: iqontrol.0 (4359) Subscribing to states...
    2024-02-25 19:41:37.575  - info: iqontrol.0 (4359) iQontrol ready.
    2024-02-25 19:41:43.883  - info: hmip.0 (4272) ws connection opened
    2024-02-25 19:41:44.152  - info: hmip.0 (4272) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"14":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":14,"groupIndex":7,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}},"15":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":15,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_PRIMARY_ACTION_CHANNEL","groups":[],"channelRole":null,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"16":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
    2024-02-25 19:41:54.684  - info: hmip.0 (4272) hmip adapter connected and ready
    Copy text starting here:
    			v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/London (GMT, +0000)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	3
    Pending iob updates: 	14
    Nodejs-Installation: 	/usr/bin/nodejs 	v12.22.12
    /home/iobroker/.diag.sh: line 488: npm: command not found
    /home/iobroker/.diag.sh: line 489: npx: command not found
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs  and npm
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        1.9G        909M        1.0M        998M        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.9G        1.0G
    Active iob-Instances: 	9
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.8.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		3908
    States: 		3264
    Size of iob-Database:
    4.2M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
    Stell das richtig ein. Geht in
    sudo raspi-config
    Dann
    sudo rm /etc/apt/sources.list.d/influ*
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive_compat.key
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Dann
    iob update
    iob upgrade all -y
    iob stop
    iob upgrade self
    iob restart
    G 2 Antworten Letzte Antwort
    • G Offline
      Greenhorn
      OK, grad mal noch neues iob.diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
       20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
      CPU threads: 4
      Current issues:
                     Local time: Sun 2024-02-25 20:05:04 GMT
                 Universal time: Sun 2024-02-25 20:05:04 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      simon
      /home/simon
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
      Swap:            99M          0B         99M
      Total:          3.9G        1.7G        840M
               3794 M total memory
               1680 M used memory
               1813 M active memory
                990 M inactive memory
                740 M free memory
                124 M buffer memory
               1247 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  4.9G   23G  18% /
      /var:
      1.5G	/var/
      859M	/var/log
      356M	/var/cache
      505M	/opt/iobroker/iobroker-data/
      325M	/opt/iobroker/iobroker-data/objects.jsonl
      5.1M	/opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /usr/bin/nodejs 	v18.19.1
      /usr/bin/node 		v18.19.1
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.8.0
      javascript: 	7.1.4
      Adapter State
      + instance is alive
      Objects and States
      wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
      • G Greenhorn
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        simon
        /home/simon
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                 1680 M used memory
                  740 M free memory
                  124 M buffer memory
                 1247 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.5G	/var/
        859M	/var/log
        356M	/var/cache
        USB-Devices by-id:
        /usr/bin/npm 		10.2.4
        /usr/bin/npx 		10.2.4
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.8.0
        javascript: 	7.1.4
        Adapter State
        + instance is alive
        Objects and States
        wendy2702W Offline
        wendy2702W Offline
        @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
        • G Greenhorn
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          simon
          /home/simon
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3794 M total memory
                   1680 M used memory
                    740 M free memory
                    124 M buffer memory
                   1247 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.5G	/var/
          859M	/var/log
          356M	/var/cache
          USB-Devices by-id:
          /usr/bin/npm 		10.2.4
          /usr/bin/npx 		10.2.4
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.8.0
          javascript: 	7.1.4
          Adapter State
          + instance is alive
          Objects and States
          • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
          • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
          Die liegen nauf dem gleichen Port.
            sudo raspi-config
            Dann
            sudo apt update
            sudo reboot
            Dann
            iob update
            iob upgrade all -y
            iob stop
            iob upgrade self
            iob restart
            Greenhorn
            @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
            iob upgrade all -y
            Läuft noch...melde mich wenn fertig.
              sudo raspi-config
              Dann
              sudo apt update
              sudo reboot
              Dann
              iob update
              iob upgrade all -y
              iob stop
              iob upgrade self
              iob restart
              Greenhorn
              iob restart
              Alles einwandfrei durchgelaufen bis auf:
              simon@iobroker:~ $ iob upgrade self
              No connection to databases possible ...
              • G Greenhorn
                iob restart
                @greenhorn
                iob restart
                iob diag
                G 1 Antwort Letzte Antwort
                  @greenhorn
                  iob restart
                  iob diag
                  Greenhorn
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                  CPU threads: 4
                  Current issues:
                                 Local time: Sun 2024-02-25 21:25:58 CET
                             Universal time: Sun 2024-02-25 20:25:58 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  simon
                  /home/simon
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.6G        1.0G
                           3794 M total memory
                           1639 M used memory
                            913 M inactive memory
                            905 M free memory
                             42 M buffer memory
                           1206 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G  5.3G   23G  19% /
                  [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /var:
                  1.5G	/var/
                  859M	/var/log
                  356M	/var/cache
                  657M	/opt/iobroker/iobroker-data/
                  163M	/opt/iobroker/iobroker-data/files
                  57M	/opt/iobroker/iobroker-data/files/javascript.admin
                  38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                  447M	/opt/iobroker/iobroker-data/objects.jsonl
                  22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                  8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                  7.0M	/opt/iobroker/iobroker-data/states.jsonl
                  7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                  USB-Devices by-id:
                  /usr/bin/npm 		10.2.4
                  /usr/bin/npx 		10.2.4
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.13.16
                  javascript: 	7.8.0
                  Adapter State
                  + instance is alive
                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                  Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                  Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                  bjects and States
                  Objects: 	3913
                  States: 	3266
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:5 https://apt.grafana.com stable InRelease
                  Hit:6 https://repos.influxdata.com/debian stable InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                  tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                  tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                  udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                  udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                  2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                  2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                  2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                  2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                  2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                  2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                  2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                  2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                  2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                  iob diag has finished.
                  			v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		arm64
                  Timezone: 		Europe/Berlin (CET, +0100)
                  User-ID: 		1000
                  X-Server: 		false
                  Pending OS-Updates: 	0
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                  			/usr/bin/npm 		10.2.4
                  			/usr/bin/npx 		10.2.4
                  MEMORY:
                  Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.8G        757M
                  			admin 			6.13.16
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		3913
                  States: 		3266
                  7.2M	/opt/iobroker/iobroker-data/states.jsonl
                  simon@iobroker:~ $
                  • G Greenhorn
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    simon
                    /home/simon
                    X-Server: 	false
                    Desktop:
                    Terminal: 	tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             3794 M total memory
                             1639 M used memory
                              905 M free memory
                               42 M buffer memory
                             1206 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.5G	/var/
                    859M	/var/log
                    356M	/var/cache
                    USB-Devices by-id:
                    /usr/bin/npm 		10.2.4
                    /usr/bin/npx 		10.2.4
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.13.16
                    javascript: 	7.8.0
                    Adapter State
                    + instance is alive
                    bjects and States
                    Objects: 	3913
                    States: 	3266
                    Pending Updates: 0
                    			v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                    Kernel: 		aarch64
                    Userland: 		arm64
                    User-ID: 		1000
                    X-Server: 		false
                    			/usr/bin/npm 		10.2.4
                    			/usr/bin/npx 		10.2.4
                    MEMORY:
                    Swap:            99M          0B         99M
                    			admin 			6.13.16
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		3913
                    States: 		3266
                    simon@iobroker:~ $
                    @greenhorn
                    iob stop
                    iob upgrade self
                    iob start
                      @greenhorn
                      iob stop
                      iob upgrade self
                      iob start
                      Greenhorn
                      iob start
                      simon@iobroker:~ $ iob stop
                      simon@iobroker:~ $ iob start
                      simon@iobroker:~ $
                      • G Greenhorn
                        iob start
                        simon@iobroker:~ $
                        @greenhorn
                        Kein Wunder. Die ist ja auch RIESIG:
                        Versuch mal ein
                        iob stop
                        iob fix
                        iob upgade self
                          @greenhorn
                          Versuch mal ein
                          iob stop
                          iob fix
                          iob upgade self
                          Greenhorn
                          Update js-controller from @4.0.24 to @5.0.19
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 10.2.4
                          Installing iobroker.js-controller@5.0.19... (System call)
                          added 2 packages, removed 12 packages, and changed 29 packages in 1m
                          136 packages are looking for funding
                            run `npm fund` for details
                          simon@iobroker:~ $
                          • G Greenhorn
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 10.2.4
                            simon@iobroker:~ $
                            @greenhorn
                            Dann sollte es das nun gewesen sein.
                            • G Offline
                              Greenhorn
                              #66
                              Kann den iobroker aber leider immer noch nicht wieder aufrufen :-(
                              • G Greenhorn
                                #67
                                @greenhorn
                                iob diag
                                • wendy2702W Offline
                                  wendy2702W Offline
                                  #68
                                  Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
                                    @greenhorn
                                    iob diag
                                    Greenhorn
                                    #69
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Sun 2024-02-25 21:51:48 CET
                                               Universal time: Sun 2024-02-25 20:51:48 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    simon
                                    /home/simon
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                    Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        2.1G        594M
                                             3794 M total memory
                                             2118 M used memory
                                             2335 M active memory
                                              732 M inactive memory
                                              494 M free memory
                                               84 M buffer memory
                                             1097 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  5.0G   23G  19% /
                                    /var:
                                    1.5G	/var/
                                    859M	/var/log
                                    356M	/var/cache
                                    318M	/opt/iobroker/iobroker-data/
                                    115M	/opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm 		10.2.4
                                    /usr/bin/npx 		10.2.4
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    js-controller: 	5.0.19
                                    admin: 		6.13.16
                                    javascript: 	7.8.0
                                    Adapter State
                                    + instance is alive
                                    Controller "js-controller": 5.0.19   , installed 5.0.19
                                    Objects and States
                                    Objects: 	3913
                                    States: 	3266
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
                                    2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
                                    2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
                                    2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
                                    2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
                                    2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
                                    2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
                                    v.2023-10-10
                                    Icon name: computer
                                    Architecture: arm64
                                    Kernel: aarch64
                                    Userland: arm64
                                    User-ID: 1000
                                    X-Server: false
                                    Pending iob updates: 0
                                    /usr/bin/npm 10.2.4
                                    /usr/bin/npx 10.2.4
                                    MEMORY:
                                    total used free shared buff/cache available
                                    Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
                                    Swap: 99M 0B 99M
                                    Total: 3.9G 1.7G 994M
                                    ioBroker Core: js-controller 5.0.19
                                    admin 6.13.16
                                    Objects type: jsonl
                                    States type: jsonl
                                    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    Objects: 3913
                                    States: 3266
                                    116M /opt/iobroker/iobroker-data/objects.jsonl
                                    1.3M /opt/iobroker/iobroker-data/states.jsonl
                                    simon@iobroker:~ $
                                    • wendy2702W wendy2702
                                      HomoranH Offline
                                      HomoranH Offline
                                      #70
                                      @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                      so ist es!
                                      @Greenhorn
                                      iob start admin
                                        so ist es!
                                        @Greenhorn
                                        iob start admin
                                        Greenhorn
                                        #71
                                        Ja, stimmt.
                                        kann den ioBroker aber immer noch nicht öffnen...
                                        wendy2702W HomoranH 2 Antworten Letzte Antwort
                                        • G Greenhorn
                                          Ja, stimmt.
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          #72
                                          @greenhorn zeige uns ein/Ausgabe des Befehls
                                          Mach mal so
                                          iob start admin.0
