  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • wendy2702W wendy2702
    @greenhorn
    Du hast ein log vom fix Befehl gepostet.
    Da steht am Ende drin das Iob noch läuft und zuerst gestoppt werden soll.
    Hast du das gelesen und gemacht?
    Das mit dem NodeJS was du gepostet hast, ist das was vollständiges?
    Greenhorn
    @wendy2702 Sorry, ich komme da leider nicht ganz mit. Wie kann ich das mit dem NodeJS vollständig erhalten?
      @greenhorn
      Greenhorn
      @wendy2702
      simon@iobroker:~ $ iob stop
      simon@iobroker:~ $ iob fix
      library: loaded
      Library version=2024-01-04
      Welcome to the ioBroker installation fixer!
      Script version: 2024-01-04
      You might need to enter your password a couple of times.
      Installing prerequisites (1/5)
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:7 https://apt.grafana.com stable InRelease
      Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Reading package lists... Done
      W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      Checking ioBroker user and directory permissions (2/5)
      Check and cleanup npm temporary directories (3/5)
      Done.
      Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      usage: sudo -h | -K | -k | -V
      usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
      usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
      usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>]
      usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
      main: line 14: [: -lt: unary operator expected
      sudo: npm: command not found
      Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
      Your installation was fixed successfully
      Run iobroker start to start ioBroker again!
      simon@iobroker:~ $ iobroker start
      simon@iobroker:~ $
      • wendy2702W Offline
        wendy2702W Offline
        Diese Reihenfolge
        iob stop
        iob fix
        Dann die komplette Ausgabe davon hier als Text posten.
        Dann schauen wir mal weiter
        Edit: ht sich überschnitten mit deinem post
          wendy2702W Offline
          Dann jetzt mal
          iob diag
          Davon dann auch die Langfassung Ausgabe mal zeigen
          G 1 Antwort Letzte Antwort
            Dann jetzt mal
            iob diag
            Greenhorn
            @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
            iob diag
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model		: Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             19:47:29 up 32 min,  1 user,  load average: 0.31, 0.55, 0.47
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sun 2024-02-25 19:47:30 GMT
                       Universal time: Sun 2024-02-25 19:47:30 UTC
                             RTC time: n/a
                            Time zone: Europe/London (GMT, +0000)
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            simon
            /home/simon
            simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            Boot Target: 	multi-user.target
            *** MEMORY ***
            Mem:            3.8G        1.8G        955M        1.0M        1.0G        2.2G
            Swap:            99M          0B         99M
            Total:          3.9G        1.8G        1.1G
                     3794 M total memory
                     1830 M used memory
                     1700 M active memory
                      921 M inactive memory
                      955 M free memory
                       75 M buffer memory
                      932 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G  4.7G   24G  17% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.4G	/var/
            859M	/var/log
            841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
            302M	/var/cache
            Archived and active journals take up 840.1M in the file system.
            /opt/iobroker/backups:
            55M	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            463M	/opt/iobroker/iobroker-data/
            135M	/opt/iobroker/iobroker-data/files
            52M	/opt/iobroker/iobroker-data/files/javascript.admin
            40M	/opt/iobroker/iobroker-data/backup-objects
            34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
            285M	/opt/iobroker/iobroker-data/objects.jsonl
            7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
            6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
            4.6M	/opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
            USB-Devices by-id:
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /usr/bin/nodejs 	v12.22.12
            /usr/bin/node 		v12.22.12
            /home/iobroker/.diag.sh: line 279: npm: command not found
            /home/iobroker/.diag.sh: line 280: npx: command not found
            /home/iobroker/.diag.sh: line 281: corepack: command not found
            /home/iobroker/.diag.sh: line 290: npm: command not found
            /home/iobroker/.diag.sh: line 291: npx: command not found
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 12.22.12~dfsg-1~deb11u4
              Candidate: 18.19.1-1nodesource1
              Version table:
                 18.19.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                 18.19.0-1nodesource1 500
                 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
             *** 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            /home/iobroker/.diag.sh: line 360: npm: command not found
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller: 	4.0.24
            admin: 		6.8.0
            javascript: 	7.1.4
            /home/iobroker/.diag.sh: line 375: npm: command not found
            Adapters from github: 	0
            Adapter State
              system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
              system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
            + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
              system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
              system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
            + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
            + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
              system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
              system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
              system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
            Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
            Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
            Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
            Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
            Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
            Adapter    "link"         : 0.5.12   , installed 0.5.12
            Adapter    "midea"        : 0.0.7    , installed 0.0.7
            Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
            Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
            Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
            Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "vis"          : 1.5.4    , installed 1.5.4
            Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
            Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
            Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
            Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
            Objects and States
            Objects: 	3908
            States: 	3264
            Pending Updates: 3
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14428      512/influxd
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28796      4257/io.sonoff.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13142      553/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27223      4238/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28486      4238/iobroker.js-co
            tcp6       0      0 :::8086                 :::*                    LISTEN      110        14037      512/influxd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27330      4313/io.web.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13153      553/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      111        14178      692/grafana
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12258      400/avahi-daemon: r
            udp        0      0 0.0.0.0:42522           0.0.0.0:*                           108        12260      400/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      691/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        12259      400/avahi-daemon: r
            udp6       0      0 :::57185                :::*                                108        12261      400/avahi-daemon: r
            2024-02-25 19:41:36.839  - info: iqontrol.0 (4359) Creating Popup States...
            2024-02-25 19:41:37.570  - info: iqontrol.0 (4359) Creating Widget States...
            2024-02-25 19:41:37.571  - info: iqontrol.0 (4359) Lists deactivated.
            2024-02-25 19:41:37.572  - info: iqontrol.0 (4359) Deleting unused Objects...
            2024-02-25 19:41:37.574  - info: iqontrol.0 (4359) Subscribing to states...
            2024-02-25 19:41:37.575  - info: iqontrol.0 (4359) iQontrol ready.
            2024-02-25 19:41:43.883  - info: hmip.0 (4272) ws connection opened
            2024-02-25 19:41:44.152  - info: hmip.0 (4272) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"14":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":14,"groupIndex":7,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}},"15":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":15,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_PRIMARY_ACTION_CHANNEL","groups":[],"channelRole":null,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"16":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
            2024-02-25 19:41:54.684  - info: hmip.0 (4272) hmip adapter connected and ready
            Copy text starting here:
            			v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
            Installation: 		native
            Kernel: 		aarch64
            Userland: 		arm64
            Timezone: 		Europe/London (GMT, +0000)
            User-ID: 		1000
            X-Server: 		false
            Pending OS-Updates: 	3
            Pending iob updates: 	14
            Nodejs-Installation: 	/usr/bin/nodejs 	v12.22.12
            /home/iobroker/.diag.sh: line 488: npm: command not found
            /home/iobroker/.diag.sh: line 489: npx: command not found
            /home/iobroker/.diag.sh: line 490: corepack: command not found
            Recommended versions are nodejs  and npm
            Wrong installation path detected. This needs to be fixed.
            Please check
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            for more information on how to fix these errors.
            MEMORY:
            Mem:            3.8G        1.9G        909M        1.0M        998M        2.1G
            Swap:            99M          0B         99M
            Total:          3.9G        1.9G        1.0G
            Active iob-Instances: 	9
            ioBroker Core: 		js-controller 		4.0.24
            			admin 			6.8.0
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            Objects: 		3908
            States: 		3264
            Size of iob-Database:
            4.2M	/opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
            • G Offline
              Greenhorn
              Musste zwischendrin etwas ausschneiden, weil der Eintrag sonst zu lang geworden wäre...
              • G Greenhorn
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                simon
                /home/simon
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3794 M total memory
                         1830 M used memory
                          955 M free memory
                           75 M buffer memory
                          932 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.4G	/var/
                859M	/var/log
                302M	/var/cache
                USB-Devices by-id:
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		6.8.0
                javascript: 	7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	3908
                States: 	3264
                Pending Updates: 3
                			v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                Kernel: 		aarch64
                Userland: 		arm64
                User-ID: 		1000
                X-Server: 		false
                Please check
                MEMORY:
                Swap:            99M          0B         99M
                			admin 			6.8.0
                Objects type: jsonl
                States  type: jsonl
                Objects: 		3908
                States: 		3264
                wendy2702W Offline
                wendy2702W Offline
                @greenhorn
                Jetzt
                iob nodejs-update
                Dauert wahrscheinlich was länger.
                  @greenhorn
                  Jetzt
                  iob nodejs-update
                  Greenhorn
                  iob nodejs-update
                  ioBroker nodejs updater 2023-10-13
                  No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                  Your current setup is:
                  /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                  /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                  /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                  /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                  We found these nodejs versions available for installation:
                  nodejs:
                  Version table:
                  Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                  Press <y> to continue or any other key to quit
                  Fixing your nodejs setup
                  *** Deleting ***
                  rm: cannot remove '': No such file or directory
                  *** Deleting ***
                  Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                  You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
                  Update der Installation läuft gerade noch...
                  • G Offline
                    Greenhorn
                    *** Deleting ***
                    *** Deleting ***
                    Trying to update your installation now. Please be patient.
                    Waiting for ioBroker to shut down - Give me a minute...
                    *** These repos are active on your system:
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://apt.grafana.com stable InRelease
                    Get:6 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                    Err:6 https://repos.influxdata.com/debian bullseye InRelease
                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                    Package: nodejs
                    Pin: origin deb.nodesource.com
                    Pin-Priority: 1001
                    *** These repos are active after the adjustments:
                    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                    Hit:6 https://apt.grafana.com stable InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Installing the recommended nodejs version now!
                    Exact recommended version unknown, installing a fallback!
                    (Reading database ... 55472 files and directories currently installed.)
                    Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                    dpkg: libnode72:arm64: dependency problems, but removing anyway as you requested:
                    nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
                    Removing libnode72:arm64 (12.22.12~dfsg-1~deb11u4) ...
                    (Reading database ... 55284 files and directories currently installed.)
                    Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
                    Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
                    Setting up nodejs (18.0.0-1nodesource1) ...
                    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
                    Processing triggers for man-db (2.9.4-2) ...
                    Updating fallback to latest nodejs v18 release
                    Preconfiguring packages ...
                    (Reading database ... 60946 files and directories currently installed.)
                    Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
                    Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
                    Setting up tar (1.34+dfsg-1+deb11u1) ...
                    Preparing to unpack .../tzdata_2024a-0+deb11u1_all.deb ...
                    Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u11) ...
                    Preparing to unpack .../distro-info-data_0.51+deb11u5_all.deb ...
                    Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
                    Preparing to unpack .../nodejs_18.19.1-1nodesource1_arm64.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (18.19.1-1nodesource1) over (18.0.0-1nodesource1) ...
                    Setting up distro-info-data (0.51+deb11u5) ...
                    Setting up nodejs (18.19.1-1nodesource1) ...
                    Setting up tzdata (2024a-0+deb11u1) ...
                    Current default time zone: 'Europe/London'
                    Local time is now: Sun Feb 25 20:02:26 GMT 2024.
                    Universal Time is now: Sun Feb 25 20:02:26 UTC 2024.
                    Run 'dpkg-reconfigure tzdata' if you wish to change it.
                    Processing triggers for mailcap (3.69) ...
                    v18.19.1 has been installed! You are using the latest version now!
                    Installing the recommended nodejs version!
                    We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                    *** RESTARTING ioBroker NOW! ***
                    Please refresh or restart your browser in a few moments.
                    simon@iobroker:~ $
                    • G Greenhorn
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      simon
                      /home/simon
                      X-Server: 	false
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               3794 M total memory
                               1830 M used memory
                                955 M free memory
                                 75 M buffer memory
                                932 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.4G	/var/
                      859M	/var/log
                      302M	/var/cache
                      USB-Devices by-id:
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin: 		6.8.0
                      javascript: 	7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects: 	3908
                      States: 	3264
                      Pending Updates: 3
                      			v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		arm64
                      User-ID: 		1000
                      X-Server: 		false
                      Please check
                      MEMORY:
                      Swap:            99M          0B         99M
                      			admin 			6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		3908
                      States: 		3264
                      @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                      Stell das richtig ein. Geht in
                      sudo raspi-config
                      Dann
                      sudo rm /etc/apt/sources.list.d/influ*
                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                      rm influxdata-archive_compat.key
                      sudo apt update
                      sudo apt full-upgrade
                      sudo reboot
                      Dann
                      iob update
                      iob upgrade all -y
                      iob stop
                      iob upgrade self
                      iob restart
                      G 2 Antworten Letzte Antwort
                      • G Offline
                        Greenhorn
                        OK, grad mal noch neues iob.diag
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
                        CPU threads: 4
                        Current issues:
                                       Local time: Sun 2024-02-25 20:05:04 GMT
                                   Universal time: Sun 2024-02-25 20:05:04 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        simon
                        /home/simon
                        X-Server: 	false
                        Desktop:
                        Terminal: 	tty
                        *** MEMORY ***
                        Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.7G        840M
                                 3794 M total memory
                                 1680 M used memory
                                 1813 M active memory
                                  990 M inactive memory
                                  740 M free memory
                                  124 M buffer memory
                                 1247 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  4.9G   23G  18% /
                        /var:
                        1.5G	/var/
                        859M	/var/log
                        356M	/var/cache
                        505M	/opt/iobroker/iobroker-data/
                        325M	/opt/iobroker/iobroker-data/objects.jsonl
                        5.1M	/opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        /usr/bin/nodejs 	v18.19.1
                        /usr/bin/node 		v18.19.1
                        /usr/bin/npm 		10.2.4
                        /usr/bin/npx 		10.2.4
                        /usr/bin/corepack 	0.22.0
                        nodejs:
                          Installed: 18.19.1-1nodesource1
                          Version table:
                         *** 18.19.1-1nodesource1 1001
                             18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin: 		6.8.0
                        javascript: 	7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        • G Greenhorn
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          simon
                          /home/simon
                          X-Server: 	false
                          Desktop:
                          Terminal: 	tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   3794 M total memory
                                   1680 M used memory
                                    740 M free memory
                                    124 M buffer memory
                                   1247 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.5G	/var/
                          859M	/var/log
                          356M	/var/cache
                          USB-Devices by-id:
                          /usr/bin/npm 		10.2.4
                          /usr/bin/npx 		10.2.4
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin: 		6.8.0
                          javascript: 	7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          wendy2702W Offline
                          wendy2702W Offline
                          @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
                          • G Greenhorn
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            simon
                            /home/simon
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                     3794 M total memory
                                     1680 M used memory
                                      740 M free memory
                                      124 M buffer memory
                                     1247 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.5G	/var/
                            859M	/var/log
                            356M	/var/cache
                            USB-Devices by-id:
                            /usr/bin/npm 		10.2.4
                            /usr/bin/npx 		10.2.4
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.8.0
                            javascript: 	7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
                            • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
                            Die liegen nauf dem gleichen Port.
                              sudo raspi-config
                              Dann
                              sudo apt update
                              sudo reboot
                              Dann
                              iob update
                              iob upgrade all -y
                              iob stop
                              iob upgrade self
                              iob restart
                              Greenhorn
                              @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
                              iob upgrade all -y
                              Läuft noch...melde mich wenn fertig.
                                sudo raspi-config
                                Dann
                                sudo apt update
                                sudo reboot
                                Dann
                                iob update
                                iob upgrade all -y
                                iob stop
                                iob upgrade self
                                iob restart
                                Greenhorn
                                iob restart
                                Alles einwandfrei durchgelaufen bis auf:
                                simon@iobroker:~ $ iob upgrade self
                                No connection to databases possible ...
                                • G Greenhorn
                                  iob restart
                                  @greenhorn
                                  iob restart
                                  iob diag
                                    @greenhorn
                                    iob restart
                                    iob diag
                                    Greenhorn
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Sun 2024-02-25 21:25:58 CET
                                               Universal time: Sun 2024-02-25 20:25:58 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    simon
                                    /home/simon
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                    Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.6G        1.0G
                                             3794 M total memory
                                             1639 M used memory
                                              913 M inactive memory
                                              905 M free memory
                                               42 M buffer memory
                                             1206 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  5.3G   23G  19% /
                                    [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    /var:
                                    1.5G	/var/
                                    859M	/var/log
                                    356M	/var/cache
                                    657M	/opt/iobroker/iobroker-data/
                                    163M	/opt/iobroker/iobroker-data/files
                                    57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                    38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                    447M	/opt/iobroker/iobroker-data/objects.jsonl
                                    22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                                    7.0M	/opt/iobroker/iobroker-data/states.jsonl
                                    7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                                    USB-Devices by-id:
                                    /usr/bin/npm 		10.2.4
                                    /usr/bin/npx 		10.2.4
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin: 		6.13.16
                                    javascript: 	7.8.0
                                    Adapter State
                                    + instance is alive
                                    Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                    Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                                    Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                    bjects and States
                                    Objects: 	3913
                                    States: 	3266
                                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                                    udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                                    udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                                    2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                                    2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                                    2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                                    2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                                    2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                                    2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                                    2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                                    2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                                    2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                                    iob diag has finished.
                                    			v.2023-10-10
                                             Icon name: computer
                                          Architecture: arm64
                                    Kernel: 		aarch64
                                    Userland: 		arm64
                                    Timezone: 		Europe/Berlin (CET, +0100)
                                    User-ID: 		1000
                                    X-Server: 		false
                                    Pending OS-Updates: 	0
                                    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                                    			/usr/bin/npm 		10.2.4
                                    			/usr/bin/npx 		10.2.4
                                    MEMORY:
                                    Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.8G        757M
                                    			admin 			6.13.16
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		3913
                                    States: 		3266
                                    7.2M	/opt/iobroker/iobroker-data/states.jsonl
                                    simon@iobroker:~ $
                                    • G Greenhorn
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      simon
                                      /home/simon
                                      X-Server: 	false
                                      Desktop:
                                      Terminal: 	tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3794 M total memory
                                               1639 M used memory
                                                905 M free memory
                                                 42 M buffer memory
                                               1206 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.5G	/var/
                                      859M	/var/log
                                      356M	/var/cache
                                      USB-Devices by-id:
                                      /usr/bin/npm 		10.2.4
                                      /usr/bin/npx 		10.2.4
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin: 		6.13.16
                                      javascript: 	7.8.0
                                      Adapter State
                                      + instance is alive
                                      bjects and States
                                      Objects: 	3913
                                      States: 	3266
                                      Pending Updates: 0
                                      			v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm64
                                      Kernel: 		aarch64
                                      Userland: 		arm64
                                      User-ID: 		1000
                                      X-Server: 		false
                                      			/usr/bin/npm 		10.2.4
                                      			/usr/bin/npx 		10.2.4
                                      MEMORY:
                                      Swap:            99M          0B         99M
                                      			admin 			6.13.16
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects: 		3913
                                      States: 		3266
                                      simon@iobroker:~ $
                                      @greenhorn
                                      iob stop
                                      iob upgrade self
                                      iob start
                                        @greenhorn
                                        iob stop
                                        iob upgrade self
                                        iob start
                                        Greenhorn
                                        iob start
                                        simon@iobroker:~ $ iob start
                                        simon@iobroker:~ $
                                        • G Greenhorn
                                          iob start
                                          simon@iobroker:~ $
                                          @greenhorn
                                          Kein Wunder. Die ist ja auch RIESIG:
                                          Versuch mal ein
                                          iob stop
                                          iob fix
                                          iob upgade self
