  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
    @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                Time zone: Europe/London (GMT, +0000)
    Stell das richtig ein. Geht in
    sudo raspi-config
    Dann
    sudo rm /etc/apt/sources.list.d/influ*
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive_compat.key
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Dann
    iob update
    iob upgrade all -y
    iob stop
    iob upgrade self
    iob restart
    Greenhorn
    @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
    iob upgrade all -y
    Läuft noch...melde mich wenn fertig.
      sudo raspi-config
      Dann
      sudo apt update
      sudo reboot
      Dann
      iob update
      iob upgrade all -y
      iob stop
      iob upgrade self
      iob restart
      Greenhorn
      iob restart
      Alles einwandfrei durchgelaufen bis auf:
      simon@iobroker:~ $ iob upgrade self
      No connection to databases possible ...
      • G Greenhorn
        iob restart
        @greenhorn
        iob restart
        iob diag
        G 1 Antwort Letzte Antwort
          @greenhorn
          iob restart
          iob diag
          Greenhorn
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-02-25 21:25:58 CET
                     Universal time: Sun 2024-02-25 20:25:58 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          simon
          /home/simon
          simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	multi-user.target
          *** MEMORY ***
          Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
          Swap:            99M          0B         99M
          Total:          3.9G        1.6G        1.0G
                   3794 M total memory
                   1639 M used memory
                   1813 M active memory
                    913 M inactive memory
                    905 M free memory
                     42 M buffer memory
                   1206 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  5.3G   23G  19% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.5G	/var/
          859M	/var/log
          841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
          356M	/var/cache
          Archived and active journals take up 840.1M in the file system.
          /opt/iobroker/backups:
          55M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          657M	/opt/iobroker/iobroker-data/
          163M	/opt/iobroker/iobroker-data/files
          57M	/opt/iobroker/iobroker-data/files/javascript.admin
          40M	/opt/iobroker/iobroker-data/backup-objects
          38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          447M	/opt/iobroker/iobroker-data/objects.jsonl
          22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
          7.0M	/opt/iobroker/iobroker-data/states.jsonl
          7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
          USB-Devices by-id:
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.19.1
          /usr/bin/node 		v18.19.1
          /usr/bin/npm 		10.2.4
          /usr/bin/npx 		10.2.4
          /usr/bin/corepack 	0.22.0
          nodejs:
            Installed: 18.19.1-1nodesource1
            Candidate: 18.19.1-1nodesource1
            Version table:
           *** 18.19.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	4.0.24
          admin: 		6.13.16
          javascript: 	7.8.0
          Adapters from github: 	0
          Adapter State
            system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
            system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
            system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
          + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
          + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
            system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 6.13.16
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
          Adapter    "hmip"         : 1.21.0   , installed 1.21.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
          Adapter    "link"         : 0.5.12   , installed 0.5.12
          Adapter    "midea"        : 0.0.7    , installed 0.0.7
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "vis"          : 1.5.4    , installed 1.5.4
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
          bjects and States
          Objects: 	3913
          States: 	3266
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://repos.influxdata.com/debian stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
          tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
          udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
          udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
          2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
          2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
          2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
          2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
          2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
          2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
          l":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
          2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
          2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
          2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
          iob diag has finished.
          Copy text starting here:
          			v.2023-10-10
                   Icon name: computer
                Architecture: arm64
          Installation: 		native
          Kernel: 		aarch64
          Userland: 		arm64
          Timezone: 		Europe/Berlin (CET, +0100)
          User-ID: 		1000
          X-Server: 		false
          Pending OS-Updates: 	0
          Pending iob updates: 	1
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
          			/usr/bin/npm 		10.2.4
          			/usr/bin/npx 		10.2.4
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
          Swap:            99M          0B         99M
          Total:          3.9G        1.8G        757M
          Active iob-Instances: 	9
          ioBroker Core: 		js-controller 		4.0.24
          			admin 			6.13.16
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		3913
          States: 		3266
          Size of iob-Database:
          7.2M	/opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          simon@iobroker:~ $
          • G Greenhorn
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            simon
            /home/simon
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                     1639 M used memory
                      905 M free memory
                       42 M buffer memory
                     1206 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            1.5G	/var/
            859M	/var/log
            356M	/var/cache
            USB-Devices by-id:
            /usr/bin/npm 		10.2.4
            /usr/bin/npx 		10.2.4
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.13.16
            javascript: 	7.8.0
            Adapter State
            + instance is alive
            bjects and States
            Objects: 	3913
            States: 	3266
            Pending Updates: 0
            			v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
            Kernel: 		aarch64
            Userland: 		arm64
            User-ID: 		1000
            X-Server: 		false
            			/usr/bin/npm 		10.2.4
            			/usr/bin/npx 		10.2.4
            MEMORY:
            Swap:            99M          0B         99M
            			admin 			6.13.16
            Objects type: jsonl
            States  type: jsonl
            Objects: 		3913
            States: 		3266
            simon@iobroker:~ $
            @greenhorn
            iob stop
            iob upgrade self
            iob start
              @greenhorn
              iob stop
              iob upgrade self
              iob start
              Greenhorn
              iob start
              simon@iobroker:~ $ iob stop
              simon@iobroker:~ $ iob start
              simon@iobroker:~ $
              • G Greenhorn
                iob start
                simon@iobroker:~ $
                @greenhorn
                Kein Wunder. Die ist ja auch RIESIG:
                Versuch mal ein
                iob stop
                iob fix
                iob upgade self
                  @greenhorn
                  Versuch mal ein
                  iob stop
                  iob fix
                  iob upgade self
                  Greenhorn
                  Update js-controller from @4.0.24 to @5.0.19
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.2.4
                  Installing iobroker.js-controller@5.0.19... (System call)
                  added 2 packages, removed 12 packages, and changed 29 packages in 1m
                  136 packages are looking for funding
                    run `npm fund` for details
                  simon@iobroker:~ $
                  • G Greenhorn
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.2.4
                    simon@iobroker:~ $
                    @greenhorn
                    Dann sollte es das nun gewesen sein.
                    • G Offline
                      Greenhorn
                      #66
                      Kann den iobroker aber leider immer noch nicht wieder aufrufen :-(
                      • G Greenhorn
                        #67
                        @greenhorn
                        iob diag
                        • wendy2702W Offline
                          wendy2702W Offline
                          #68
                          Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
                            @greenhorn
                            iob diag
                            Greenhorn
                            #69
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2024-02-25 21:51:48 CET
                                       Universal time: Sun 2024-02-25 20:51:48 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            simon
                            /home/simon
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
                            Swap:            99M          0B         99M
                            Total:          3.9G        2.1G        594M
                                     3794 M total memory
                                     2118 M used memory
                                     2335 M active memory
                                      732 M inactive memory
                                      494 M free memory
                                       84 M buffer memory
                                     1097 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G  5.0G   23G  19% /
                            /var:
                            1.5G	/var/
                            859M	/var/log
                            356M	/var/cache
                            318M	/opt/iobroker/iobroker-data/
                            115M	/opt/iobroker/iobroker-data/objects.jsonl
                            6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                            USB-Devices by-id:
                            /usr/bin/npm 		10.2.4
                            /usr/bin/npx 		10.2.4
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            js-controller: 	5.0.19
                            admin: 		6.13.16
                            javascript: 	7.8.0
                            Adapter State
                            + instance is alive
                            Controller "js-controller": 5.0.19   , installed 5.0.19
                            Objects and States
                            Objects: 	3913
                            States: 	3266
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
                            2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
                            2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
                            2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
                            2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
                            2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
                            2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
                            v.2023-10-10
                            Icon name: computer
                            Architecture: arm64
                            Kernel: aarch64
                            Userland: arm64
                            User-ID: 1000
                            X-Server: false
                            Pending iob updates: 0
                            /usr/bin/npm 10.2.4
                            /usr/bin/npx 10.2.4
                            MEMORY:
                            total used free shared buff/cache available
                            Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
                            Swap: 99M 0B 99M
                            Total: 3.9G 1.7G 994M
                            ioBroker Core: js-controller 5.0.19
                            admin 6.13.16
                            Objects type: jsonl
                            States type: jsonl
                            • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects: 3913
                            States: 3266
                            116M /opt/iobroker/iobroker-data/objects.jsonl
                            1.3M /opt/iobroker/iobroker-data/states.jsonl
                            simon@iobroker:~ $
                            • wendy2702W wendy2702
                              HomoranH Offline
                              HomoranH Offline
                              #70
                              @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                              so ist es!
                              @Greenhorn
                              iob start admin
                                so ist es!
                                @Greenhorn
                                iob start admin
                                Greenhorn
                                #71
                                Ja, stimmt.
                                kann den ioBroker aber immer noch nicht öffnen...
                                wendy2702W HomoranH 2 Antworten Letzte Antwort
                                • G Greenhorn
                                  Ja, stimmt.
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  #72
                                  @greenhorn zeige uns ein/Ausgabe des Befehls
                                  Mach mal so
                                  iob start admin.0
                                  • G Greenhorn
                                    Ja, stimmt.
                                    HomoranH Offline
                                    HomoranH Offline
                                    #73
                                    @greenhorn ist der admin jetzt aktiv?
                                    wenn nein, was hindert ihn daran? =was steht im log?
                                    • G Offline
                                      Greenhorn
                                      #74
                                      @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
                                      iob start admin.0
                                      👍🙏😀 Es geht wieder, ich fass´es nicht !
                                      Ihr seid die Besten !!! Allerherzlichsten Dank !!!
                                      • G Offline
                                        Greenhorn
                                        #75
                                        Gleich ab morgen werde ich mich mit dem Thema Backup beschäftigen...
                                        Mann oh Mann, was ein Schock 😬 Ich bin soo froh dass das wieder geht.
                                        Nochmal allerherzlichsten Dank an euch 👍
                                        • G Greenhorn
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          #76
                                          Tippe schnell in die Konsole
                                          iob backup
                                          Dann hast du wenigsten schonmal eins
