  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    #68
    Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
      @greenhorn
      iob diag
      Greenhorn
      #69
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-02-25 21:51:48 CET
                 Universal time: Sun 2024-02-25 20:51:48 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      simon
      /home/simon
      simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
      Swap:            99M          0B         99M
      Total:          3.9G        2.1G        594M
               3794 M total memory
               2118 M used memory
               2335 M active memory
                732 M inactive memory
                494 M free memory
                 84 M buffer memory
               1097 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  5.0G   23G  19% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.5G	/var/
      859M	/var/log
      841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
      356M	/var/cache
      Archived and active journals take up 840.1M in the file system.
      /opt/iobroker/backups:
      55M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      318M	/opt/iobroker/iobroker-data/
      163M	/opt/iobroker/iobroker-data/files
      57M	/opt/iobroker/iobroker-data/files/javascript.admin
      40M	/opt/iobroker/iobroker-data/backup-objects
      38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      115M	/opt/iobroker/iobroker-data/objects.jsonl
      22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
      7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.1
      /usr/bin/node 		v18.19.1
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.19
      admin: 		6.13.16
      javascript: 	7.8.0
      Adapters from github: 	0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
        system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
      + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
        system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "hmip"         : 1.21.0   , installed 1.21.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "link"         : 0.5.12   , installed 0.5.12
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
      Objects and States
      Objects: 	3913
      States: 	3266
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
      udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
      udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
      2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
      2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
      2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
      2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
      2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
      2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
      Copy text starting here:
      v.2023-10-10
      Icon name: computer
      Architecture: arm64
      Installation: native
      Kernel: aarch64
      Userland: arm64
      Timezone: Europe/Berlin (CET, +0100)
      User-ID: 1000
      X-Server: false
      Pending OS-Updates: 0
      Pending iob updates: 0
      Nodejs-Installation: /usr/bin/nodejs v18.19.1
      /usr/bin/npm 10.2.4
      /usr/bin/npx 10.2.4
      Recommended versions are nodejs and npm
      MEMORY:
      total used free shared buff/cache available
      Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
      Swap: 99M 0B 99M
      Total: 3.9G 1.7G 994M
      Active iob-Instances: 9
      ioBroker Core: js-controller 5.0.19
      admin 6.13.16
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 3913
      States: 3266
      Size of iob-Database:
      116M /opt/iobroker/iobroker-data/objects.jsonl
      1.3M /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      simon@iobroker:~ $
      • wendy2702W wendy2702
        HomoranH Offline
        HomoranH Offline
        #70
        @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
        so ist es!
        @Greenhorn
        iob start admin
        G 1 Antwort Letzte Antwort
          so ist es!
          @Greenhorn
          iob start admin
          Greenhorn
          #71
          Ja, stimmt.
          kann den ioBroker aber immer noch nicht öffnen...
          wendy2702W HomoranH 2 Antworten Letzte Antwort
          • G Greenhorn
            Ja, stimmt.
            wendy2702W Offline
            wendy2702W Offline
            #72
            @greenhorn zeige uns ein/Ausgabe des Befehls
            Mach mal so
            iob start admin.0
            • G Greenhorn
              Ja, stimmt.
              HomoranH Offline
              HomoranH Offline
              #73
              @greenhorn ist der admin jetzt aktiv?
              wenn nein, was hindert ihn daran? =was steht im log?
              • G Offline
                Greenhorn
                #74
                @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
                iob start admin.0
                👍🙏😀 Es geht wieder, ich fass´es nicht !
                Ihr seid die Besten !!! Allerherzlichsten Dank !!!
                • G Offline
                  Greenhorn
                  #75
                  Gleich ab morgen werde ich mich mit dem Thema Backup beschäftigen...
                  Mann oh Mann, was ein Schock 😬 Ich bin soo froh dass das wieder geht.
                  Nochmal allerherzlichsten Dank an euch 👍
                  • G Greenhorn
                    wendy2702W Offline
                    wendy2702W Offline
                    #76
                    @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                    Tippe schnell in die Konsole
                    iob backup
                    Dann hast du wenigsten schonmal eins
                      iob backup
                      Greenhorn
                      #77
                      @wendy2702
                      Das habe ich gestern leider nicht mehr gemacht, hatte es nicht mehr gesehen.
                      Heute morgen habe ich festgestellt, dass einige Instanzen nicht aktiv waren. Habe sie dann nacheinander aktiviert, mit dem Ergebnis, dass der Raspi so rödelt, dass er keinen Befehl mehr annimmt. Diesmal lasse ich ihn aber laufen bis ich heute nachmittag nachhause komme. Vielleicht hat er sich bis dahin beruhigt…
                      • G Greenhorn
                        @wendy2702
                        CodierknechtC Offline
                        Codierknecht
                        #78
                        @greenhorn
                        Weiß Du noch welche?
                        Mir scheint auch die objects.json etwas groß.
                        Ich habe z.B. fast doppelt so viele Objekte, die Datei ist aber nur 1/4 so groß.
                        @Thomas-Braun
                        Kann man im diag-Script an die Liste der aktiven Instanzen auch deren Speicherverbrauch prömpeln?
                        Mir fällt immer wieder auf, dass die Anwender häufig Probleme mit dem RAM haben.
                        Wäre doch praktisch, wenn man in der Ausgabe auch gleich sehen könnte, wo die "dicken Hunde" stecken.
                        Zumindest was die ioBroker-Instanzen betrifft.
                        HmIP|ZigBee|Tasmota|Unifi
                        Zabbix Certified Specialist
                        Thomas BraunT G 2 Antworten Letzte Antwort
                        • CodierknechtC Codierknecht
                          @greenhorn
                          @Thomas-Braun
                          #79
                          @codierknecht sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                          In einer Beta-Version ist ein Snapshot von 'top' drin.
                          Das ganze ist aber halt nur ein Snapshot und damit nur bedingt Aussage kräftig.
                            @greenhorn
                            @Thomas-Braun
                            Greenhorn
                            #80
                            @codierknecht
                            Nicht genau, aber ca. die Hälfte war nicht aktiv. U.a. die Influx, die habe ich aber vorsichtshalber gar nicht aktiviert, weil ich die am meisten in Verdacht hatte, alles zu blockieren…
                            • G Greenhorn
                              @codierknecht
                              Codierknecht
                              #81
                              Hätte ich auch.
                              Ich befürchte, der kleine Pi hat ein Speicherproblem.
                              Mit 4 GB RAM darf man von dem halt keine Wunderdinge erwarten.
                              Ich habe keine Ahnung, wie Speicherhungrig Influx so ist.
                              Könnte mir aber gut vorstellen, dass der arme kleine Pi damit überfordert ist.
                                Hätte ich auch.
                                Greenhorn
                                #82
                                @codierknecht
                                Wenn ich es richtig verstanden habe, könnte ich den iobroker auch auf der NAS laufen lassen? Das wäre dann eine Alternative, einen richtigen Rechner will ich nicht auch noch extra laufen laufen lassen.
                                • G Greenhorn
                                  @codierknecht
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  #83
                                  @greenhorn NAS geht, ob du dir als "Greenhorn" damit aber einen gefallen tust weiss ich ehrlich gesagt nicht.
                                    Codierknecht
                                    #84
                                    @wendy2702
                                    Und potent genug sollte die Kiste dann auch sein.
                                    Also ordentliche CPU und genügend RAM.
                                    Ist das gegeben, hätte das den Vorteil dass man ioBroker und Influx in getrennten Containern laufen lassen könnte (so man denn Docker verwendet).
                                    Aber Du hast natürlich Recht: Einfacher wird das nicht wirklich.
                                    Und @Thomas-Braun würde sich dann ausklinken 😁 😁 😁
                                      @wendy2702
                                      Greenhorn
                                      #85
                                      @codierknecht
                                      Synology 216dj oder so…
                                      • G Greenhorn
                                        @codierknecht
                                        Codierknecht
                                        #86
                                        @greenhorn
                                        Vergiss es.
                                          @greenhorn
                                          Vergiss es.
                                          Greenhorn
                                          schrieb am zuletzt editiert von Greenhorn
                                          #87
                                          @codierknecht
                                          OK, ich bleib beim Raspi ;-)
                                          Der Raspi hat immerhin 4GB.
