  4. Raspberry "friert ein" nach Aufruf von ioBroker
106 Beiträge 9 Kommentatoren 13.2k Aufrufe 7 Beobachtet
  • G Greenhorn
    @meister-mopper said in Raspberry "friert ein" nach Aufruf von ioBroker:
    iob diag
    Hoffe, das ist richtig:
    Copy text starting here:
    			v.2023-10-10
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/London (GMT, +0000)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		multi-user.target
    Pending OS-Updates: 	3
    Pending iob updates: 	14
    Nodejs-Installation: 	/usr/bin/nodejs 	v12.22.12
    			/usr/bin/node 		v12.22.12
    /home/iobroker/.diag.sh: line 488: npm: command not found
    /home/iobroker/.diag.sh: line 489: npx: command not found
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"! and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        2.0G        947M        1.0M        885M        2.0G
    Swap:            99M          0B         99M
    Total:          3.9G        2.0G        1.0G
    Active iob-Instances: 	9
    Active repo(s): stable
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.8.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		3908
    States: 		3264
    Size of iob-Database:
    244M	/opt/iobroker/iobroker-data/objects.jsonl
    2.5M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    simon@iobroker:~ $
    wendy2702W Offline
    wendy2702W Offline
    wendy2702
    #41
    @greenhorn ist zwar nur die Kurzfassung aber:
    Altes OS mit uralter NodeJs Version.
    Hast du Backups?
    Dein Admin läuft nicht wenn ich das richtig sehe:
       iob start admin.0
    G 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      Hast du Backups?
         iob start admin.0
      Greenhorn
      #42
      @wendy2702 Nein, leider kein richtiges Backup...
      • G Greenhorn
        wendy2702W Offline
        wendy2702W Offline
        wendy2702
        #43
        @greenhorn
        Du hast ein log vom fix Befehl gepostet.
        Da steht am Ende drin das Iob noch läuft und zuerst gestoppt werden soll.
        Hast du das gelesen und gemacht?
        Das mit dem NodeJS was du gepostet hast, ist das was vollständiges?
        G 2 Antworten Letzte Antwort
          @greenhorn
          Greenhorn
          #44
          @wendy2702 Sorry, ich komme da leider nicht ganz mit. Wie kann ich das mit dem NodeJS vollständig erhalten?
            @greenhorn
            Greenhorn
            #45
            @wendy2702
            simon@iobroker:~ $ iob stop
            simon@iobroker:~ $ iob fix
            library: loaded
            Library version=2024-01-04
            Welcome to the ioBroker installation fixer!
            Script version: 2024-01-04
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:7 https://apt.grafana.com stable InRelease
            Err:5 https://repos.influxdata.com/debian bullseye InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            Reading package lists... Done
            W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            Checking ioBroker user and directory permissions (2/5)
            Created /etc/sudoers.d/iobroker
            Check and cleanup npm temporary directories (3/5)
            Done.
            Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            usage: sudo -h | -K | -k | -V
            usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
            usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
            usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>]
            usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
            main: line 14: [: -lt: unary operator expected
            sudo: npm: command not found
            Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
            simon@iobroker:~ $ iobroker start
            simon@iobroker:~ $
            • wendy2702W Offline
              wendy2702W Offline
              wendy2702
              #46
              Diese Reihenfolge
              iob stop
              iob fix
              Dann die komplette Ausgabe davon hier als Text posten.
              Dann schauen wir mal weiter
              Edit: ht sich überschnitten mit deinem post
                wendy2702W Offline
                wendy2702
                #47
                Dann jetzt mal
                iob diag
                Davon dann auch die Langfassung Ausgabe mal zeigen
                  Dann jetzt mal
                  iob diag
                  Greenhorn
                  #48
                  @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
                  iob diag
                  ======== Start marking the full check here =========
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Model		: Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   19:47:29 up 32 min,  1 user,  load average: 0.31, 0.55, 0.47
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Sun 2024-02-25 19:47:30 GMT
                             Universal time: Sun 2024-02-25 19:47:30 UTC
                                   RTC time: n/a
                                  Time zone: Europe/London (GMT, +0000)
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  simon
                  /home/simon
                  simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Mem:            3.8G        1.8G        955M        1.0M        1.0G        2.2G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.8G        1.1G
                           3794 M total memory
                           1830 M used memory
                           1700 M active memory
                            921 M inactive memory
                            955 M free memory
                             75 M buffer memory
                            932 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  lifetime oom required: 0 Mbytes
                  total time in oom handler: 0 ms
                  max time spent in oom handler: 0 ms
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G  4.7G   24G  17% /
                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                  tmpfs          tmpfs     759M  1.2M  758M   1% /run
                  /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  Show mounted filesystems \(real ones only\):
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.4G	/var/
                  859M	/var/log
                  841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
                  302M	/var/cache
                  Archived and active journals take up 840.1M in the file system.
                  /opt/iobroker/backups:
                  55M	/opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  463M	/opt/iobroker/iobroker-data/
                  135M	/opt/iobroker/iobroker-data/files
                  52M	/opt/iobroker/iobroker-data/files/javascript.admin
                  40M	/opt/iobroker/iobroker-data/backup-objects
                  34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                  285M	/opt/iobroker/iobroker-data/objects.jsonl
                  7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                  6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                  4.6M	/opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                  find: '/dev/serial/by-id/': No such file or directory
                  *** NodeJS-Installation ***
                  /home/iobroker/.diag.sh: line 279: npm: command not found
                  /home/iobroker/.diag.sh: line 280: npx: command not found
                  /home/iobroker/.diag.sh: line 281: corepack: command not found
                  /home/iobroker/.diag.sh: line 290: npm: command not found
                  /home/iobroker/.diag.sh: line 291: npx: command not found
                  nodejs:
                    Installed: 12.22.12~dfsg-1~deb11u4
                    Candidate: 18.19.1-1nodesource1
                    Version table:
                       18.19.1-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                       18.19.0-1nodesource1 500
                       18.18.2-1nodesource1 500
                       18.18.1-1nodesource1 500
                       18.18.0-1nodesource1 500
                       18.17.1-1nodesource1 500
                       18.17.0-1nodesource1 500
                       18.16.1-1nodesource1 500
                       18.16.0-1nodesource1 500
                       18.15.0-1nodesource1 500
                       18.14.2-1nodesource1 500
                       18.14.1-1nodesource1 500
                       18.14.0-1nodesource1 500
                       18.13.0-1nodesource1 500
                       18.12.0-1nodesource1 500
                       18.11.0-1nodesource1 500
                       18.10.0-1nodesource1 500
                       18.9.1-1nodesource1 500
                       18.9.0-1nodesource1 500
                       18.8.0-1nodesource1 500
                       18.7.0-1nodesource1 500
                       18.6.0-1nodesource1 500
                       18.5.0-1nodesource1 500
                       18.4.0-1nodesource1 500
                       18.3.0-1nodesource1 500
                       18.2.0-1nodesource1 500
                       18.1.0-1nodesource1 500
                       18.0.0-1nodesource1 500
                   *** 12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                          100 /var/lib/dpkg/status
                  No problems detected
                  Errors in npm tree:
                  /home/iobroker/.diag.sh: line 360: npm: command not found
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller: 	4.0.24
                  admin: 		6.8.0
                  javascript: 	7.1.4
                  /home/iobroker/.diag.sh: line 375: npm: command not found
                  Adapters from github: 	0
                  Adapter State
                    system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                    system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
                  + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                    system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                    system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                  + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
                  + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
                    system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                    system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                    system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
                  + instance is alive
                  ioBroker-Repositories
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
                  Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
                  Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
                  Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
                  Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
                  Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
                  Adapter    "link"         : 0.5.12   , installed 0.5.12
                  Adapter    "midea"        : 0.0.7    , installed 0.0.7
                  Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
                  Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
                  Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
                  Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                  Adapter    "vis"          : 1.5.4    , installed 1.5.4
                  Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                  Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
                  Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
                  Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
                  Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
                  Objects and States
                  Objects: 	3908
                  States: 	3264
                  Pending Updates: 3
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14428      512/influxd
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28796      4257/io.sonoff.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13142      553/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27223      4238/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28486      4238/iobroker.js-co
                  tcp6       0      0 :::8086                 :::*                    LISTEN      110        14037      512/influxd
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27330      4313/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13153      553/sshd: /usr/sbin
                  tcp6       0      0 :::3000                 :::*                    LISTEN      111        14178      692/grafana
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12258      400/avahi-daemon: r
                  udp        0      0 0.0.0.0:42522           0.0.0.0:*                           108        12260      400/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      691/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        12259      400/avahi-daemon: r
                  udp6       0      0 :::57185                :::*                                108        12261      400/avahi-daemon: r
                  2024-02-25 19:41:36.839  - info: iqontrol.0 (4359) Creating Popup States...
                  2024-02-25 19:41:37.570  - info: iqontrol.0 (4359) Creating Widget States...
                  2024-02-25 19:41:37.571  - info: iqontrol.0 (4359) Lists deactivated.
                  2024-02-25 19:41:37.572  - info: iqontrol.0 (4359) Deleting unused Objects...
                  2024-02-25 19:41:37.574  - info: iqontrol.0 (4359) Subscribing to states...
                  2024-02-25 19:41:37.575  - info: iqontrol.0 (4359) iQontrol ready.
                  2024-02-25 19:41:43.883  - info: hmip.0 (4272) ws connection opened
                  2024-02-25 19:41:44.152  - info: hmip.0 (4272) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"14":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":14,"groupIndex":7,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}},"15":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":15,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_PRIMARY_ACTION_CHANNEL","groups":[],"channelRole":null,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"16":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
                  2024-02-25 19:41:54.684  - info: hmip.0 (4272) hmip adapter connected and ready
                  			v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		arm64
                  User-ID: 		1000
                  X-Server: 		false
                  Recommended versions are nodejs  and npm
                  Please check
                  MEMORY:
                  Mem:            3.8G        1.9G        909M        1.0M        998M        2.1G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.9G        1.0G
                  			admin 			6.8.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		3908
                  States: 		3264
                  4.2M	/opt/iobroker/iobroker-data/states.jsonl
                  wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                  • G Offline
                    Greenhorn
                    #49
                    Musste zwischendrin etwas ausschneiden, weil der Eintrag sonst zu lang geworden wäre...
                    • G Greenhorn
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      simon
                      /home/simon
                      X-Server: 	false
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               3794 M total memory
                               1830 M used memory
                                955 M free memory
                                 75 M buffer memory
                                932 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.4G	/var/
                      859M	/var/log
                      302M	/var/cache
                      USB-Devices by-id:
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin: 		6.8.0
                      javascript: 	7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects: 	3908
                      States: 	3264
                      Pending Updates: 3
                      			v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		arm64
                      User-ID: 		1000
                      X-Server: 		false
                      Please check
                      MEMORY:
                      Swap:            99M          0B         99M
                      			admin 			6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		3908
                      States: 		3264
                      wendy2702W Offline
                      wendy2702W Offline
                      wendy2702
                      #50
                      @greenhorn
                      Jetzt
                      iob nodejs-update
                      Dauert wahrscheinlich was länger.
                        @greenhorn
                        Jetzt
                        iob nodejs-update
                        Greenhorn
                        #51
                        iob nodejs-update
                        ioBroker nodejs updater 2023-10-13
                        No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                        Your current setup is:
                        /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                        /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                        /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                        /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                        We found these nodejs versions available for installation:
                        nodejs:
                        Version table:
                        Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                        Press <y> to continue or any other key to quit
                        Fixing your nodejs setup
                        *** Deleting ***
                        rm: cannot remove '': No such file or directory
                        *** Deleting ***
                        Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                        You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
                        Update der Installation läuft gerade noch...
                        • G Offline
                          Greenhorn
                          #52
                          *** Deleting ***
                          *** Deleting ***
                          Trying to update your installation now. Please be patient.
                          Waiting for ioBroker to shut down - Give me a minute...
                          *** These repos are active on your system:
                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:5 https://apt.grafana.com stable InRelease
                          Get:6 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                          Err:6 https://repos.influxdata.com/debian bullseye InRelease
                          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                          Package: nodejs
                          Pin: origin deb.nodesource.com
                          Pin-Priority: 1001
                          *** These repos are active after the adjustments:
                          Get:5 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                          Hit:6 https://apt.grafana.com stable InRelease
                          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Installing the recommended nodejs version now!
                          Exact recommended version unknown, installing a fallback!
                          (Reading database ... 55472 files and directories currently installed.)
                          Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                          dpkg: libnode72:arm64: dependency problems, but removing anyway as you requested:
                          nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
                          Removing libnode72:arm64 (12.22.12~dfsg-1~deb11u4) ...
                          (Reading database ... 55284 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
                          Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
                          Setting up nodejs (18.0.0-1nodesource1) ...
                          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
                          Processing triggers for man-db (2.9.4-2) ...
                          Updating fallback to latest nodejs v18 release
                          Preconfiguring packages ...
                          (Reading database ... 60946 files and directories currently installed.)
                          Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
                          Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
                          Setting up tar (1.34+dfsg-1+deb11u1) ...
                          Preparing to unpack .../tzdata_2024a-0+deb11u1_all.deb ...
                          Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u11) ...
                          Preparing to unpack .../distro-info-data_0.51+deb11u5_all.deb ...
                          Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
                          Preparing to unpack .../nodejs_18.19.1-1nodesource1_arm64.deb ...
                          Detected old npm client, removing...
                          Unpacking nodejs (18.19.1-1nodesource1) over (18.0.0-1nodesource1) ...
                          Setting up distro-info-data (0.51+deb11u5) ...
                          Setting up nodejs (18.19.1-1nodesource1) ...
                          Setting up tzdata (2024a-0+deb11u1) ...
                          Current default time zone: 'Europe/London'
                          Local time is now: Sun Feb 25 20:02:26 GMT 2024.
                          Universal Time is now: Sun Feb 25 20:02:26 UTC 2024.
                          Run 'dpkg-reconfigure tzdata' if you wish to change it.
                          Processing triggers for mailcap (3.69) ...
                          v18.19.1 has been installed! You are using the latest version now!
                          Installing the recommended nodejs version!
                          We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                          *** RESTARTING ioBroker NOW! ***
                          Please refresh or restart your browser in a few moments.
                          simon@iobroker:~ $
                          • G Greenhorn
                            iob diag
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            simon
                            /home/simon
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                     3794 M total memory
                                     1830 M used memory
                                      955 M free memory
                                       75 M buffer memory
                                      932 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.4G	/var/
                            859M	/var/log
                            302M	/var/cache
                            USB-Devices by-id:
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.8.0
                            javascript: 	7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	3908
                            States: 	3264
                            Pending Updates: 3
                            			v.2023-10-10
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel: 		aarch64
                            Userland: 		arm64
                            User-ID: 		1000
                            X-Server: 		false
                            Please check
                            MEMORY:
                            Swap:            99M          0B         99M
                            			admin 			6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		3908
                            States: 		3264
                            #53
                            @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                            Stell das richtig ein. Geht in
                            sudo raspi-config
                            Dann
                            sudo rm /etc/apt/sources.list.d/influ*
                            wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                            echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                            echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                            rm influxdata-archive_compat.key
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                            Dann
                            iob update
                            iob upgrade all -y
                            iob stop
                            iob upgrade self
                            iob restart
                            • G Offline
                              Greenhorn
                              #54
                              OK, grad mal noch neues iob.diag
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                               20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
                              CPU threads: 4
                              Current issues:
                                             Local time: Sun 2024-02-25 20:05:04 GMT
                                         Universal time: Sun 2024-02-25 20:05:04 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              simon
                              /home/simon
                              X-Server: 	false
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
                              Swap:            99M          0B         99M
                              Total:          3.9G        1.7G        840M
                                       3794 M total memory
                                       1680 M used memory
                                       1813 M active memory
                                        990 M inactive memory
                                        740 M free memory
                                        124 M buffer memory
                                       1247 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4       29G  4.9G   23G  18% /
                              /var:
                              1.5G	/var/
                              859M	/var/log
                              356M	/var/cache
                              505M	/opt/iobroker/iobroker-data/
                              325M	/opt/iobroker/iobroker-data/objects.jsonl
                              5.1M	/opt/iobroker/iobroker-data/states.jsonl
                              USB-Devices by-id:
                              /usr/bin/nodejs 	v18.19.1
                              /usr/bin/node 		v18.19.1
                              /usr/bin/npm 		10.2.4
                              /usr/bin/npx 		10.2.4
                              /usr/bin/corepack 	0.22.0
                              nodejs:
                                Installed: 18.19.1-1nodesource1
                                Version table:
                               *** 18.19.1-1nodesource1 1001
                                   18.19.0-1nodesource1 1001
                                   18.18.2-1nodesource1 1001
                                   18.18.1-1nodesource1 1001
                                   18.18.0-1nodesource1 1001
                                   18.17.1-1nodesource1 1001
                                   18.17.0-1nodesource1 1001
                                   18.16.1-1nodesource1 1001
                                   18.16.0-1nodesource1 1001
                                   18.15.0-1nodesource1 1001
                                   18.14.2-1nodesource1 1001
                                   18.14.1-1nodesource1 1001
                                   18.14.0-1nodesource1 1001
                                   18.13.0-1nodesource1 1001
                                   18.12.0-1nodesource1 1001
                                   18.11.0-1nodesource1 1001
                                   18.10.0-1nodesource1 1001
                                   18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                   18.8.0-1nodesource1 1001
                                   18.7.0-1nodesource1 1001
                                   18.6.0-1nodesource1 1001
                                   18.5.0-1nodesource1 1001
                                   18.4.0-1nodesource1 1001
                                   18.3.0-1nodesource1 1001
                                   18.2.0-1nodesource1 1001
                                   18.1.0-1nodesource1 1001
                                   18.0.0-1nodesource1 1001
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin: 		6.8.0
                              javascript: 	7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              • G Greenhorn
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                simon
                                /home/simon
                                X-Server: 	false
                                Desktop:
                                Terminal: 	tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                         1680 M used memory
                                          740 M free memory
                                          124 M buffer memory
                                         1247 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                1.5G	/var/
                                859M	/var/log
                                356M	/var/cache
                                USB-Devices by-id:
                                /usr/bin/npm 		10.2.4
                                /usr/bin/npx 		10.2.4
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin: 		6.8.0
                                javascript: 	7.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                #55
                                @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
                                • G Greenhorn
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  simon
                                  /home/simon
                                  X-Server: 	false
                                  Desktop:
                                  Terminal: 	tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           3794 M total memory
                                           1680 M used memory
                                            740 M free memory
                                            124 M buffer memory
                                           1247 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  1.5G	/var/
                                  859M	/var/log
                                  356M	/var/cache
                                  USB-Devices by-id:
                                  /usr/bin/npm 		10.2.4
                                  /usr/bin/npx 		10.2.4
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin: 		6.8.0
                                  javascript: 	7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  #56
                                  • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
                                  • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
                                  Die liegen nauf dem gleichen Port.
                                    sudo raspi-config
                                    Dann
                                    sudo apt update
                                    sudo reboot
                                    Dann
                                    iob update
                                    iob upgrade all -y
                                    iob stop
                                    iob upgrade self
                                    iob restart
                                    Greenhorn
                                    #57
                                    @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
                                    iob upgrade all -y
                                    Läuft noch...melde mich wenn fertig.
                                      sudo raspi-config
                                      Dann
                                      sudo apt update
                                      sudo reboot
                                      Dann
                                      iob update
                                      iob upgrade all -y
                                      iob stop
                                      iob upgrade self
                                      iob restart
                                      Greenhorn
                                      #58
                                      iob restart
                                      Alles einwandfrei durchgelaufen bis auf:
                                      simon@iobroker:~ $ iob upgrade self
                                      No connection to databases possible ...
                                      • G Greenhorn
                                        iob restart
                                        #59
                                        @greenhorn
                                        iob restart
                                        iob diag
                                          @greenhorn
                                          iob restart
                                          iob diag
                                          Greenhorn
                                          #60
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                           21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Sun 2024-02-25 21:25:58 CET
                                                     Universal time: Sun 2024-02-25 20:25:58 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          simon
                                          /home/simon
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          *** MEMORY ***
                                          Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        1.6G        1.0G
                                                   3794 M total memory
                                                   1639 M used memory
                                                    913 M inactive memory
                                                    905 M free memory
                                                     42 M buffer memory
                                                   1206 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       29G  5.3G   23G  19% /
                                          [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          /var:
                                          1.5G	/var/
                                          859M	/var/log
                                          356M	/var/cache
                                          657M	/opt/iobroker/iobroker-data/
                                          163M	/opt/iobroker/iobroker-data/files
                                          57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                          38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                          447M	/opt/iobroker/iobroker-data/objects.jsonl
                                          22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                          8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                                          7.0M	/opt/iobroker/iobroker-data/states.jsonl
                                          7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                                          USB-Devices by-id:
                                          /usr/bin/npm 		10.2.4
                                          /usr/bin/npx 		10.2.4
                                          nodejs:
                                            Version table:
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.13.16
                                          javascript: 	7.8.0
                                          Adapter State
                                          + instance is alive
                                          Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                          Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                          Adapter    "web"          : 6.2.3    , installed 6.2.3
                                          Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                          bjects and States
                                          Objects: 	3913
                                          States: 	3266
                                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:6 https://repos.influxdata.com/debian stable InRelease
                                          Pending Updates: 0
                                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                                          udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                                          udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                                          2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                                          2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                                          2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                                          2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                                          2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                                          2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                                          2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                                          2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                                          2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                                          iob diag has finished.
                                          			v.2023-10-10
                                                   Icon name: computer
                                                Architecture: arm64
                                          Kernel: 		aarch64
                                          Userland: 		arm64
                                          Timezone: 		Europe/Berlin (CET, +0100)
                                          User-ID: 		1000
                                          X-Server: 		false
                                          Pending OS-Updates: 	0
                                          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                                          			/usr/bin/npm 		10.2.4
                                          			/usr/bin/npx 		10.2.4
                                          MEMORY:
                                          Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        1.8G        757M
                                          			admin 			6.13.16
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects: 		3913
                                          States: 		3266
                                          7.2M	/opt/iobroker/iobroker-data/states.jsonl
                                          simon@iobroker:~ $
