  3. Off Topic
  4. Proxmox
  5. Proxmox: Fehlermeldung bei backup - vzdump ?
    1.0k
    3.2k
Geplant Angeheftet Gesperrt Verschoben Proxmox
228 Beiträge 8 Kommentatoren 48.3k Aufrufe 6 Beobachtet
  • G GOETSCHHOFER
    @crunchip
    Anfangs bei Abfrage iob dag kommt folgende Meldung:
    *** iob diag is starting up, please wait ***
    The state system.host.IOBROKER.versions.nodeNewestNext was not found!
    The state system.host.IOBROKER.versions.npmNewestNext was not found!
    The state system.host.IOBROKER.versions.nodeCurrent was not found!
    Jetzt aber Ergebnis Gesamtabfrage:
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: IOBROKER
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 10 (buster)
                Kernel: Linux 4.19.0-25-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     07:27:35 up 18 min,  1 user,  load average: 0.15, 0.03, 0.01
    CPU threads: 6
    *** Time and Time Zones ***
                   Local time: Sat 2023-12-30 07:27:35 CET
               Universal time: Sat 2023-12-30 06:27:35 UTC
                     RTC time: Sat 2023-12-30 06:27:36
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    karl
    /home/karl
    karl cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           5.5G        235M        4.8G        7.0M        467M        5.0G
    Swap:          974M          0B        974M
    Total:         6.4G        235M        5.7G
             5458 M total memory
              235 M used memory
              316 M active memory
              266 M inactive memory
             4755 M free memory
               78 M buffer memory
              388 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    udev           devtmpfs  2.7G     0  2.7G   0% /dev
    tmpfs          tmpfs     546M  7.3M  539M   2% /run
    /dev/sda1      ext4       19G  4.4G   14G  25% /
    tmpfs          tmpfs     2.7G     0  2.7G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.7G     0  2.7G   0% /sys/fs/cgroup
    tmpfs          tmpfs     546M     0  546M   0% /run/user/1000
    [Sat Dec 30 07:09:18 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Dec 30 07:09:18 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems \(real ones only\):
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
    `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    /var:
    665M    /var/
    457M    /var/cache
    451M    /var/cache/apt
    388M    /var/cache/apt/archives
    186M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    285M    /opt/iobroker/iobroker-data/
    230M    /opt/iobroker/iobroker-data/files
    53M     /opt/iobroker/iobroker-data/backup-objects
    42M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
    11M     /opt/iobroker/iobroker-data/files/echarts/static/js/2.0a6dd638.chunk.js.map
    11M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.0a6dd638.chunk.js.map
    9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
    6.8M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.0aad1268.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/2.261c158c.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: tough-cookie@2.5.0 /opt/iobroker/node_modules/tough-cookie
    npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-30T06_27_37_794Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
     Cannot read system.config: null (OK when migrating or restoring)
     Cannot find view "system" for search "host"
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  3.2.16
    admin:          5.1.23
    javascript:     5.1.3
    Adapters from github:   14
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Cannot get list: undefined
    Installed ioBroker-Instances
    Error: Object "system.config" not found
    crunchipC Abwesend
    crunchipC Abwesend
    #121
    @goetschhofer sehr seltsam
    wie sieht es da aktuell aus?
    ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
    G 1 Antwort Letzte Antwort
      GOETSCHHOFER
      schrieb am zuletzt editiert von GOETSCHHOFER
      #122
      @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
      Dies habe ich soeben durchgeführt und wollte dir gleich psten: ☺
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 19:33 2023-12-28_19-33_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.g
      Bei den objects ist mir nichts aufgefallen.
      Bei den states schaut es so aus:
      Objects type: file
      States  type: file
      karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objec        ts
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 07:17 2023-12-28_07-17_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 10:33 2023-12-28_10-33_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 12:55 2023-12-28_12-55_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 07:38 2023-12-29_07-38_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 07:53 2023-12-29_07-53_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:01 2023-12-29_08-01_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:54 2023-12-29_08-54_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:05 2023-12-29_09-05_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:38 2023-12-29_09-38_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:42 2023-12-29_09-42_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:43 2023-12-29_09-43_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:53 2023-12-29_11-53_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:58 2023-12-29_11-58_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 12:02 2023-12-29_12-02_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:04 2023-12-29_13-04_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:27 2023-12-29_13-27_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:29 2023-12-29_13-29_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:40 2023-12-29_13-40_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:56 2023-12-29_13-56_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 14:07 2023-12-29_14-07_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:08 2023-12-29_15-08_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:46 2023-12-29_15-46_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M Dez 29 15:49 2023-12-29_15-49_objects.json.        gz
      -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 15:59 2023-12-29_15-59_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:05 2023-12-29_16-05_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:12 2023-12-29_16-12_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:14 2023-12-29_16-14_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:18 2023-12-29_16-18_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 06:41 2023-12-30_06-41_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 07:03 2023-12-30_07-03_objects.json.        gz
      -rw-rw-r--+ 1 iobroker iobroker 3,5K Dez 30 07:09 2023-12-30_07-09_objects.json.        gz
      karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep state        s
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 07:31 2023-12-28_07-31_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 09:31 2023-12-28_09-31_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 11:31 2023-12-28_11-31_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 13:32 2023-12-28_13-32_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 15:32 2023-12-28_15-32_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 17:33 2023-12-28_17-33_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 07:53 2023-12-29_07-53_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:02 2023-12-29_08-02_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:54 2023-12-29_08-54_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:05 2023-12-29_09-05_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:39 2023-12-29_09-39_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:42 2023-12-29_09-42_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:44 2023-12-29_09-44_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 10:22 2023-12-29_10-22_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:27 2023-12-29_10-27_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:28 2023-12-29_10-28_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:53 2023-12-29_11-53_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:54 2023-12-29_11-54_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:58 2023-12-29_11-58_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 12:03 2023-12-29_12-03_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:05 2023-12-29_13-05_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:27 2023-12-29_13-27_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:30 2023-12-29_13-30_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:40 2023-12-29_13-40_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:57 2023-12-29_13-57_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 14:08 2023-12-29_14-08_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 15:08 2023-12-29_15-08_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 15:46 2023-12-29_15-46_states.json.g        z
      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 16:00 2023-12-29_16-00_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:06 2023-12-29_16-06_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:13 2023-12-29_16-13_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:15 2023-12-29_16-15_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:19 2023-12-29_16-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 18:19 2023-12-29_18-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 20:19 2023-12-29_20-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 22:19 2023-12-29_22-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 00:19 2023-12-30_00-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 02:19 2023-12-30_02-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 04:19 2023-12-30_04-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:19 2023-12-30_06-19_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:42 2023-12-30_06-42_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:04 2023-12-30_07-04_states.json.g        z
      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:09 2023-12-30_07-09_states.json.g        z
      karl@IOBROKER:/$ ^C
      karl@IOBROKER:/$ ^C
      karl@IOBROKER:/$
      • G GOETSCHHOFER
        Objects type: file
        States  type: file
        karl@IOBROKER:/$ ^C
        karl@IOBROKER:/$ ^C
        karl@IOBROKER:/$
        crunchipC Abwesend
        crunchipC Abwesend
        #123
        @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
        2023-12-30_07-03_objects.json.gz
        2023-12-30_07-09_states.json.gz
        dann führst du obiges erneut aus, mit diesen ersetzen, und dann mal nichts machen
          GOETSCHHOFER
          #124
          Führe ich so aus:
          iobroker stop
          cd /opt/iobroker/iobroker-data/
          mv objects.json objects.json.old
          mv states.json states.json.old
          cd backup-objects/
          gunzip -ck 2023-12-29_07-38_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
          gunzip -ck 2023-12-28_19-33_states.json.gz > /opt/iobroker/iobroker-data/states.json
          iobroker start
          • G GOETSCHHOFER
            Führe ich so aus:
            iobroker stop
            cd backup-objects/
            iobroker start
            GOETSCHHOFER
            #125
            @goetschhofer said in Proxmox: Fehlermeldung bei backup - vzdump ?:
            iobroker start
            Habe ich nun so ausgeführt:
            Ich sehe gerade bei den Dateien, welche ich reinkopiert habe, zeigt er unten nicht alles an, aber ich habe es wie oben dokumentiert hineinkopiert.
            login as: karl
            karl@192.168.1.176's password:
            Linux IOBROKER 4.19.0-25-amd64 #1 SMP Debian 4.19.289-2 (2023-08-08) x86_64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Sat Dec 30 07:47:27 2023 from 192.168.1.3
            karl@IOBROKER:~$ iobroker stop
            karl@IOBROKER:~$ cd /opt/iobroker/iobroker-data/
            karl@IOBROKER:/opt/iobroker/iobroker-data$ mv objects.json objects.json.old
            karl@IOBROKER:/opt/iobroker/iobroker-data$ mv states.json states.json.old
            karl@IOBROKER:/opt/iobroker/iobroker-data$ cd backup-objects/
            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-29_        07-38_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-28_        19-33_states.json.gz > /opt/iobroker/iobroker-data/states.json
            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ iobroker start
            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ cd ..
            karl@IOBROKER:/opt/iobroker/iobroker-data$ cd ..
            karl@IOBROKER:/opt/iobroker$ cd ..
            karl@IOBROKER:/opt$ cd ..
            karl@IOBROKER:/$ iobroker start
            karl@IOBROKER:/$
            • G GOETSCHHOFER
              iobroker start
              login as: karl
              karl@IOBROKER:/$
              crunchipC Abwesend
              crunchipC Abwesend
              #126
              aber falsch, ich habe dir doch beide genannt
              du solltest diese nehmen
              und
              iobroker stop
              cd backup-objects/
              gunzip -ck 2023-12-30_07-03_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
              gunzip -ck 2023-12-30_07-09_states.json.gz > /opt/iobroker/iobroker-data/states.json
              iobroker start
                und
                iobroker stop
                cd backup-objects/
                iobroker start
                GOETSCHHOFER
                #127
                iobroker start
                Sorry, die files kennt er nicht.
                login as: karl
                Last login: Sat Dec 30 10:24:46 2023 from 192.168.1.3
                karl@IOBROKER:/opt/iobroker/iobroker-data$ gunzip -ck 2023-12-30_07-03_objects.json.gz > /opt/iobroker/iobroker-data/objects.json                       gzip: 2023-12-30_07-03_objects.json.gz: No such file or directory
                karl@IOBROKER:/opt/iobroker/iobroker-data$ gunzip -ck 2023-12-30_07-09_states.json.gz > /opt/iobroker/iobroker-data/states.json
                gzip: 2023-12-30_07-09_states.json.gz: No such file or directory
                Anbei die aktuelle Abfrage zu den OBJECTS mit:
                karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 10:33 2023-12-28_10-33_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 12:55 2023-12-28_12-55_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 07:38 2023-12-29_07-38_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 07:53 2023-12-29_07-53_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:01 2023-12-29_08-01_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:54 2023-12-29_08-54_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:05 2023-12-29_09-05_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:38 2023-12-29_09-38_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:42 2023-12-29_09-42_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:43 2023-12-29_09-43_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:53 2023-12-29_11-53_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:58 2023-12-29_11-58_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 12:02 2023-12-29_12-02_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:04 2023-12-29_13-04_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:27 2023-12-29_13-27_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:29 2023-12-29_13-29_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:40 2023-12-29_13-40_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:56 2023-12-29_13-56_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 14:07 2023-12-29_14-07_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:08 2023-12-29_15-08_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:46 2023-12-29_15-46_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 1,8M Dez 29 15:49 2023-12-29_15-49_objects.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 15:59 2023-12-29_15-59_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:05 2023-12-29_16-05_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:12 2023-12-29_16-12_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:14 2023-12-29_16-14_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:18 2023-12-29_16-18_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 06:41 2023-12-30_06-41_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 07:03 2023-12-30_07-03_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,5K Dez 30 07:09 2023-12-30_07-09_objects.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 10:10 2023-12-30_10-10_objects.json.gz
                karl@IOBROKER:/$
                Anbei die aktuelle Abfrage zu den STATES mit:
                ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
                karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 11:31 2023-12-28_11-31_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 13:32 2023-12-28_13-32_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 15:32 2023-12-28_15-32_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 17:33 2023-12-28_17-33_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 19:33 2023-12-28_19-33_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 07:53 2023-12-29_07-53_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:02 2023-12-29_08-02_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:54 2023-12-29_08-54_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:05 2023-12-29_09-05_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:39 2023-12-29_09-39_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:42 2023-12-29_09-42_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:44 2023-12-29_09-44_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 10:22 2023-12-29_10-22_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:27 2023-12-29_10-27_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:28 2023-12-29_10-28_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:53 2023-12-29_11-53_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:54 2023-12-29_11-54_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:58 2023-12-29_11-58_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 12:03 2023-12-29_12-03_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:05 2023-12-29_13-05_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:27 2023-12-29_13-27_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:30 2023-12-29_13-30_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:40 2023-12-29_13-40_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:57 2023-12-29_13-57_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 14:08 2023-12-29_14-08_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 15:08 2023-12-29_15-08_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 15:46 2023-12-29_15-46_states.json.gz
                -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 16:00 2023-12-29_16-00_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:06 2023-12-29_16-06_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:13 2023-12-29_16-13_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:15 2023-12-29_16-15_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:19 2023-12-29_16-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 18:19 2023-12-29_18-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 20:19 2023-12-29_20-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 22:19 2023-12-29_22-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 00:19 2023-12-30_00-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 02:19 2023-12-30_02-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 04:19 2023-12-30_04-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:19 2023-12-30_06-19_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:42 2023-12-30_06-42_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:04 2023-12-30_07-04_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:09 2023-12-30_07-09_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 09:10 2023-12-30_09-10_states.json.gz
                -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 10:11 2023-12-30_10-11_states.json.gz
                karl@IOBROKER:/$
                • G GOETSCHHOFER
                  iobroker start
                  login as: karl
                  karl@IOBROKER:/$
                  karl@IOBROKER:/$
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #128
                  komisch, ist doch eigentlich da, aber egal
                  dann wäre der nächste Schritt deine Adapter auf Stand zu bringen, damit du anschließend den controller updaten kannst und anschließend hoffen, das die Datenbank bestehen bleibt😁
                  du hast noch einige Adapter aus Git installiert
                  Ausgabe von
                  iob update
                    Ausgabe von
                    iob update
                    GOETSCHHOFER
                    #129
                    iob update
                    Wie soll ich die adapter auf Stand bringen, ich kann ja über die WEBUI nicht auf den iobroker ?
                    Soll ich in proxmox ein backup machen ?
                    karl@IOBROKER:/$ iob update
                    Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                    Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                    hash changed or no sources cached => force download of new sources
                    Cannot get any information of "_repoInfo". Ignored.
                    update done
                    Adapter    "accuweather"   : 1.3.2
                    Adapter    "acme"          : 0.1.2
                    Adapter    "adb"           : 0.0.7
                    Adapter    "adguard"       : 0.0.8
                    Adapter    "admin"         : 6.12.0   , installed 5.1.23 [Updateable]
                    Adapter    "aio"           : 0.1.1
                    Adapter    "airconwithme"  : 0.0.4
                    Adapter    "airzone"       : 2.0.3
                    Adapter    "alarm"         : 3.4.3
                    Adapter    "alexa-shoppinglist": 0.1.5
                    Adapter    "alexa-timer-vis": 0.2.0
                    Adapter    "alexa2"        : 3.26.3
                    Adapter    "alias-manager" : 1.2.6
                    Adapter    "alpha-ess"     : 2.0.0
                    Adapter    "alpha2"        : 1.0.0
                    Adapter    "amazon-dash"   : 1.2.0
                    Adapter    "anelhut"       : 1.0.15
                    Adapter    "apcups"        : 1.0.15
                    Adapter    "apg-info"      : 0.1.0
                    Adapter    "artnet"        : 1.2.2
                    Adapter    "asterisk"      : 1.0.6
                    Adapter    "asuswrt"       : 1.0.1
                    Adapter    "atlas-scientific-ezo-i2c": 2.3.0
                    Adapter    "awattar"       : 1.0.6    , installed 1.0.6
                    Adapter    "awtrix-light"  : 0.10.0
                    Adapter    "b-control-em"  : 0.3.1    , installed 0.2.1 [Updateable]
                    Adapter    "backitup"      : 2.9.8    , installed 2.1.17 [Updateable]
                    Adapter    "beckhoff"      : 1.5.3
                    Adapter    "benchmark"     : 1.1.4
                    Adapter    "benq"          : 0.2.5
                    Adapter    "bestway"       : 0.0.4
                    Adapter    "bidirectional-counter": 2.1.3
                    Adapter    "birthdays"     : 2.4.1
                    Adapter    "ble"           : 0.13.4
                    Adapter    "blebox"        : 2.1.0
                    Adapter    "bluelink"      : 2.3.6
                    Adapter    "bmw"           : 2.5.7
                    Adapter    "bosch-ebike"   : 0.0.3
                    Adapter    "bosesoundtouch": 0.10.3
                    Adapter    "botslab360"    : 0.0.2
                    Adapter    "botvac"        : 2.0.1
                    Adapter    "bring"         : 1.8.4
                    Adapter    "broadlink2"    : 2.1.5
                    Adapter    "bsblan"        : 0.3.1
                    Adapter    "bshb"          : 0.2.6
                    Adapter    "bwt"           : 0.0.5
                    Adapter    "bydbatt"       : 1.1.0
                    Adapter    "bydhvs"        : 1.5.0
                    Adapter    "canbus"        : 1.3.1    , installed 1.3.1
                    Adapter    "cec2"          : 0.1.1
                    Adapter    "chromecast"    : 3.0.3    , installed 2.3.1 [Updateable]
                    Adapter    "cleveron"      : 0.0.6
                    Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                    Adapter    "cloudflare"    : 1.1.1
                    Adapter    "comfoair"      : 1.1.8
                    Adapter    "contactid"     : 1.0.2
                    Adapter    "coronavirus-statistics": 0.9.0
                    Adapter    "countdown"     : 2.2.0
                    Adapter    "cul"           : 2.2.0
                    Adapter    "daikin"        : 1.4.2
                    Adapter    "daikin-cloud"  : 0.3.0
                    Adapter    "daswetter"     : 3.1.11   , installed 3.0.7 [Updateable]
                    Adapter    "deconz"        : 1.3.23
                    Adapter    "denon"         : 1.15.4
                    Adapter    "device-reminder": 3.0.0
                    Adapter    "device-watcher": 2.9.6
                    Adapter    "devices"       : 1.1.5
                    Adapter    "deyeidc"       : 0.0.14
                    Adapter    "digitalstrom"  : 2.3.0
                    Adapter    "discord"       : 2.2.0
                    Adapter    "discovergy"    : 0.5.13
                    Adapter    "discovery"     : 4.2.0    , installed 2.6.2 [Updateable]
                    Adapter    "divera247"     : 0.2.0
                    Adapter    "doorbird"      : 1.3.0
                    Adapter    "doorio"        : 2.1.4
                    Adapter    "drag-indicator": 2.1.4
                    Adapter    "ds18b20"       : 2.0.5
                    Adapter    "dwd"           : 2.8.5    , installed 2.7.5 [Updateable]
                    Adapter    "dysonairpurifier": 2.5.9
                    Adapter    "e3dc-rscp"     : 1.2.5
                    Adapter    "easee"         : 1.0.10
                    Adapter    "ebus"          : 3.2.4
                    Adapter    "echarts"       : 1.5.4    , installed 0.4.13 [Updateable]
                    Adapter    "ecovacs-deebot": 1.4.13
                    Adapter    "egigeozone"    : 0.1.2
                    Adapter    "ekey"          : 1.2.3
                    Adapter    "elero-usb-transmitter": 0.5.2
                    Adapter    "email"         : 1.2.1    , installed 1.0.10 [Updateable]
                    Adapter    "emby"          : 1.1.1
                    Adapter    "emporia"       : 0.0.12
                    Adapter    "ems-esp"       : 2.6.2
                    Adapter    "energymanager" : 1.4.2
                    Adapter    "enet"          : 1.0.1
                    Adapter    "enigma2"       : 2.0.5
                    Adapter    "envertech-pv"  : 1.1.0
                    Adapter    "epson_ecotank_et_2750": 0.0.12
                    Adapter    "epson_stylus_px830": 0.2.1
                    Adapter    "epson_xp540"   : 1.0.6
                    Adapter    "eusec"         : 1.2.1
                    Adapter    "evcc"          : 0.0.10
                    Adapter    "eventlist"     : 2.0.0
                    Adapter    "exchangerates" : 0.0.14
                    Adapter    "fahrplan"      : 1.2.3
                    Adapter    "fakeroku"      : 0.2.2
                    Adapter    "fb-checkpresence": 1.2.2
                    Adapter    "feiertage"     : 1.1.4
                    Adapter    "fhem"          : 2.0.5    , installed 1.6.0 [Updateable]
                    Adapter    "fiat"          : 0.0.8
                    Adapter    "firetv"        : 2.0.2
                    Adapter    "fitbit-fitness": 0.5.0
                    Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                    Adapter    "followthesun"  : 0.5.0    , installed 0.3.4 [Updateable]
                    Adapter    "foobar2000"    : 2.1.0
                    Adapter    "ford"          : 0.0.14
                    Adapter    "frigate"       : 0.2.7
                    Adapter    "fritzbox"      : 0.5.0
                    Adapter    "fritzdect"     : 2.5.9    , installed 2.1.15 [Updateable]
                    Adapter    "froeling"      : 0.0.8
                    Adapter    "fronius"       : 2.0.2    , installed 1.1.6 [Updateable]
                    Adapter    "fronius-solarweb": 0.0.3
                    Adapter    "fronius-wattpilot": 4.6.2
                    Adapter    "frontier_silicon": 0.1.1
                    Adapter    "fuelpricemonitor": 0.4.0
                    Adapter    "fullcalendar"  : 2.2.6
                    Adapter    "fullybrowser"  : 3.0.6
                    Adapter    "g-homa"        : 0.5.3
                    Adapter    "garmin"        : 0.0.3
                    Adapter    "geofency"      : 1.2.4
                    Adapter    "gigaset-elements": 0.4.3
                    Adapter    "gira-iot"      : 0.4.0
                    Adapter    "go-e"          : 1.0.29
                    Adapter    "govee-local"   : 0.1.2
                    Adapter    "growatt"       : 3.2.1
                    Adapter    "gruenbeck"     : 0.0.42
                    Adapter    "gsmsms"        : 0.0.6
                    Adapter    "haassohn"      : 1.0.9
                    Adapter    "habpanel"      : 0.5.0    , installed 0.4.3 [Updateable]
                    Adapter    "haier"         : 1.0.4
                    Adapter    "ham"           : 5.3.1
                    Adapter    "ham-wemo"      : 3.0.2
                    Adapter    "harmony"       : 1.3.0
                    Adapter    "hass"          : 1.4.0
                    Adapter    "hausbus_de"    : 1.2.12
                    Adapter    "heatingcontrol": 2.11.1
                    Adapter    "heizoel"       : 1.0.3
                    Adapter    "heizungssteuerung": 1.7.0
                    Adapter    "hekr"          : 0.0.6
                    Adapter    "helios"        : 0.0.3
                    Adapter    "heos"          : 2.1.0
                    Adapter    "heytech"       : 1.0.6
                    Adapter    "hid-community" : 0.3.0
                    Adapter    "hikvision-alarmserver": 0.1.0
                    Adapter    "history"       : 3.0.1
                    Adapter    "hm-rega"       : 4.0.0
                    Adapter    "hm-rpc"        : 1.15.19
                    Adapter    "hmip"          : 1.20.0
                    Adapter    "homeconnect"   : 1.1.1
                    Adapter    "homee"         : 1.2.0
                    Adapter    "homekit-controller": 0.5.8   , installed 0.3.3 [Updateable]
                    Adapter    "homenet"       : 0.0.2
                    Adapter    "homepilot"     : 1.1.6
                    Adapter    "hoover"        : 0.0.7
                    Adapter    "hp-ilo"        : 1.0.6
                    Adapter    "hs100"         : 2.2.0    , installed 2.0.3 [Updateable]
                    Adapter    "hue"           : 3.10.1
                    Adapter    "huum-sauna"    : 0.4.5
                    Adapter    "i2c"           : 1.2.1
                    Adapter    "ical"          : 1.13.3
                    Adapter    "iceroad"       : 1.2.1
                    Adapter    "ico-cloud"     : 1.1.0
                    Adapter    "icons-addictive-flavour-png": 0.1.0
                    Adapter    "icons-eclipse-smarthome-classic": 1.0.0
                    Adapter    "icons-fatcow-hosting": 0.1.0
                    Adapter    "icons-freepic" : 1.0.0
                    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                    Adapter    "icons-material-png": 0.1.0
                    Adapter    "icons-material-svg": 0.1.0
                    Adapter    "icons-mfd-png" : 1.2.1
                    Adapter    "icons-mfd-svg" : 1.1.0
                    Adapter    "icons-open-icon-library-png": 0.1.2
                    Adapter    "icons-smarthome": 1.0.0
                    Adapter    "icons-ultimate-png": 1.0.1
                    Adapter    "ikettle2"      : 1.0.1
                    Adapter    "imap"          : 0.1.1
                    Adapter    "imow"          : 0.0.2
                    Adapter    "influxdb"      : 3.2.0    , installed 1.9.5 [Updateable]
                    Adapter    "info"          : 2.0.0    , installed 1.9.8 [Updateable]
                    Adapter    "innogy-smarthome": 1.2.6
                    Adapter    "innoxel"       : 0.3.1
                    Adapter    "intex"         : 0.1.5
                    Adapter    "iot"           : 2.0.11   , installed 1.8.22 [Updateable]
                    Adapter    "iqontrol"      : 2.3.0    , installed 1.6.4 [Updateable]
                    Adapter    "iwg-vpn"       : 2.0.5
                    Adapter    "janitza-gridvis": 3.1.8
                    Adapter    "jarvis"        : 3.1.8
                    Adapter    "javascript"    : 7.1.6    , installed 5.1.3 [Updateable]
                    Adapter    "jeelink"       : 1.2.3
                    Controller "js-controller" : 5.0.17   , installed 3.2.16 [Updateable]
                    Adapter    "judoisoft"     : 1.1.0
                    Adapter    "kecontact"     : 2.0.2
                    Adapter    "klf200"        : 1.1.2
                    Adapter    "km200"         : 2.0.3
                    Adapter    "knmi-weather"  : 1.0.2
                    Adapter    "knx"           : 2.0.24
                    Adapter    "kodi"          : 3.0.0
                    Adapter    "kostal-piko-ba": 3.0.9
                    Adapter    "lametric"      : 3.1.1
                    Adapter    "landroid"      : 1.0.3
                    Adapter    "lcn"           : 1.1.1
                    Adapter    "legrand-ecocompteur": 1.0.0
                    Adapter    "letrika_comgw" : 0.0.6
                    Adapter    "lg-ess-home"   : 0.2.3
                    Adapter    "lg-thinq"      : 0.1.4
                    Adapter    "lgtv"          : 2.1.2
                    Adapter    "lgtv-rs"       : 0.1.1
                    Adapter    "lgtv11"        : 1.0.5
                    Adapter    "libre"         : 0.0.4
                    Adapter    "lifx"          : 1.0.4
                    Adapter    "lightcontrol"  : 0.4.0
                    Adapter    "lightify"      : 0.2.16
                    Adapter    "link"          : 0.5.12
                    Adapter    "link2home"     : 0.0.1
                    Adapter    "linkeddevices" : 1.5.5
                    Adapter    "linktap"       : 0.3.0
                    Adapter    "linux-control" : 1.1.5
                    Adapter    "logparser"     : 2.2.0    , installed 1.1.0 [Updateable]
                    Adapter    "loqed"         : 0.3.1
                    Adapter    "lovelace"      : 3.0.1
                    Adapter    "lowpass-filter": 2.2.3
                    Adapter    "loxone"        : 3.0.1
                    Adapter    "luftdaten"     : 3.1.0
                    Adapter    "lupusec"       : 1.3.6
                    Adapter    "luxtronik1"    : 0.3.5
                    Adapter    "material"      : 1.3.1
                    Adapter    "matrix-org"    : 1.0.0
                    Adapter    "maveo"         : 0.0.5
                    Adapter    "maxcube"       : 1.0.4
                    Adapter    "maxcul"        : 1.3.1
                    Adapter    "mbus"          : 2.6.1    , installed 2.4.0 [Updateable]
                    Adapter    "mclighting"    : 0.1.2
                    Adapter    "meater"        : 1.0.2
                    Adapter    "mediola-gateway": 1.0.1
                    Adapter    "megad"         : 1.2.1
                    Adapter    "megadd"        : 0.2.0
                    Adapter    "megaesp"       : 0.1.0
                    Adapter    "melcloud"      : 1.3.6
                    Adapter    "mercedesme"    : 0.1.1
                    Adapter    "mercury"       : 0.1.6
                    Adapter    "meross"        : 1.16.1
                    Adapter    "meteoalarm"    : 2.3.7
                    Adapter    "micronova"     : 0.0.2
                    Adapter    "midea"         : 0.0.7
                    Adapter    "miele"         : 0.1.5
                    Adapter    "mielecloudservice": 6.5.4
                    Adapter    "mihome"        : 1.4.0
                    Adapter    "mihome-cloud"  : 0.1.0
                    Adapter    "mihome-lamp"   : 1.1.0
                    Adapter    "mihome-plug"   : 0.2.1
                    Adapter    "mihome-vacuum" : 4.1.0
                    Adapter    "mikrotik"      : 1.1.1
                    Adapter    "milight"       : 0.4.0
                    Adapter    "milight-smart-light": 1.2.2
                    Adapter    "minuvis"       : 2.3.3
                    Adapter    "mobile"        : 1.0.1
                    Adapter    "modbus"        : 6.0.1    , installed 3.4.14 [Updateable]
                    Adapter    "moma"          : 1.2.9
                    Adapter    "mpd"           : 1.1.1
                    Adapter    "mqtt"          : 5.1.0    , installed 2.4.0 [Updateable]
                    Adapter    "mqtt-client"   : 1.7.0    , installed 1.4.0 [Updateable]
                    Adapter    "musiccast"     : 1.1.3
                    Adapter    "mydlink"       : 1.3.5
                    Adapter    "myenergi"      : 0.0.3
                    Adapter    "mysensors"     : 3.0.0
                    Adapter    "mystrom"       : 0.0.14
                    Adapter    "myvbus"        : 0.2.5
                    Adapter    "nanoleaf-lightpanels": 1.4.0
                    Adapter    "net-tools"     : 0.2.0
                    Adapter    "netatmo"       : 3.1.0
                    Adapter    "netatmo-crawler": 0.8.1
                    Adapter    "netatmo-energy": 2.7.0
                    Adapter    "nibeuplink"    : 1.3.0
                    Adapter    "nina"          : 0.0.25
                    Adapter    "nissan"        : 0.0.12
                    Adapter    "niu"           : 0.0.3
                    Adapter    "node-red"      : 4.0.3    , installed 2.4.0 [Updateable]
                    Adapter    "notification-manager": 1.0.0
                    Adapter    "nsclient"      : 0.2.2
                    Adapter    "nuki"          : 1.6.0
                    Adapter    "nuki-extended" : 2.6.5
                    Adapter    "nut"           : 1.6.0
                    Adapter    "ocpp"          : 0.12.5
                    Adapter    "octoprint"     : 5.1.0
                    Adapter    "odl"           : 3.0.1
                    Adapter    "oekofen-json"  : 1.0.5
                    Adapter    "oilfox"        : 4.2.0
                    Adapter    "omnicomm-lls"  : 0.0.7
                    Adapter    "onkyo"         : 2.1.2
                    Adapter    "onvif"         : 1.1.1
                    Adapter    "opendtu"       : 1.0.1
                    Adapter    "openhab"       : 1.1.0
                    Adapter    "openknx"       : 0.6.3
                    Adapter    "openligadb"    : 1.2.4
                    Adapter    "openweathermap": 0.4.5    , installed 0.1.0 [Updateable]
                    Adapter    "operating-hours": 1.0.6
                    Adapter    "opi"           : 0.1.2
                    Adapter    "oppoplayer"    : 0.2.4
                    Adapter    "owfs"          : 0.7.0
                    Adapter    "owntracks"     : 1.0.5
                    Adapter    "panasonic-comfort-cloud": 2.2.4
                    Adapter    "panasonic-viera": 2.0.0
                    Adapter    "parcel"        : 0.0.27
                    Adapter    "parser"        : 2.0.7    , installed 1.0.7 [Updateable]
                    Adapter    "paw"           : 0.3.2
                    Adapter    "pegelalarm"    : 1.3.2
                    Adapter    "ph803w"        : 1.1.1
                    Adapter    "phantomjs"     : 1.1.3
                    Adapter    "philips-air"   : 1.0.3
                    Adapter    "philips-tv"    : 0.5.3
                    Adapter    "pi-hole"       : 1.3.6
                    Adapter    "piface"        : 1.0.0
                    Adapter    "pimatic"       : 0.3.2
                    Adapter    "ping"          : 1.6.2    , installed 1.4.12 [Updateable]
                    Adapter    "pixelit"       : 1.1.3
                    Adapter    "places"        : 1.1.2
                    Adapter    "plenticore"    : 2.2.0
                    Adapter    "plex"          : 1.1.4
                    Adapter    "plexconnect"   : 0.0.7
                    Adapter    "pollenflug"    : 1.0.6
                    Adapter    "porsche"       : 0.0.3
                    Adapter    "powerfox2"     : 0.0.14
                    Adapter    "procon-ip"     : 1.5.1
                    Adapter    "proxmox"       : 2.2.2    , installed 1.3.3 [Updateable]
                    Adapter    "proxy"         : 1.3.2
                    Adapter    "psa"           : 0.0.11
                    Adapter    "puppeteer"     : 0.2.7
                    Adapter    "pushbullet"    : 2.0.1
                    Adapter    "pushover"      : 3.0.6
                    Adapter    "pushsafer"     : 1.0.3
                    Adapter    "pvforecast"    : 2.9.0
                    Adapter    "pvoutputorg"   : 1.8.10
                    Adapter    "pylontech"     : 0.0.7
                    Adapter    "radar2"        : 2.1.0
                    Adapter    "radiohead"     : 1.3.0
                    Adapter    "rct"           : 1.2.2
                    Adapter    "renacidc"      : 0.0.6
                    Adapter    "renault"       : 0.0.15
                    Adapter    "reolink"       : 1.0.2
                    Adapter    "residents"     : 0.1.1
                    Adapter    "resol"         : 1.3.0
                    Adapter    "rest-api"      : 1.1.0
                    Adapter    "rflink"        : 2.1.6
                    Adapter    "rickshaw"      : 1.0.0
                    Adapter    "ring"          : 5.0.10
                    Adapter    "robonect"      : 1.3.4
                    Adapter    "roborock"      : 0.4.4
                    Adapter    "roomba"        : 1.2.2
                    Adapter    "rpi2"          : 1.3.2
                    Adapter    "rssfeed"       : 2.6.1
                    Adapter    "s7"            : 1.3.15
                    Adapter    "sainlogic"     : 0.10.5
                    Adapter    "samsung"       : 0.5.11
                    Adapter    "samsung_tizen" : 1.0.0
                    Adapter    "sanext"        : 0.0.5
                    Adapter    "sayit"         : 3.0.5
                    Adapter    "sbfspot"       : 4.1.7
                    Adapter    "scenes"        : 2.3.9
                    Adapter    "scheduler"     : 1.1.9
                    Adapter    "schoolfree"    : 1.1.3
                    Adapter    "schwoerer-ventcube": 1.4.2
                    Adapter    "seko"          : 0.0.1
                    Adapter    "selverf"       : 0.6.3
                    Adapter    "semp"          : 1.3.13
                    Adapter    "seq"           : 0.3.0
                    Adapter    "shelly"        : 6.6.1    , installed 4.0.7 [Updateable]
                    Adapter    "shuttercontrol": 1.6.3
                    Adapter    "sia"           : 1.0.4
                    Adapter    "siegenia"      : 1.1.1
                    Adapter    "signal-cmb"    : 0.3.0
                    Adapter    "signifylights" : 0.3.1
                    Adapter    "simple-api"    : 2.7.2    , installed 2.6.1 [Updateable]
                    Adapter    "sma-em"        : 1.0.0
                    Adapter    "smappee"       : 0.2.6
                    Adapter    "smart-eq"      : 0.0.4    , installed 0.0.2 [Updateable]
                    Adapter    "smartcontrol"  : 2.0.1
                    Adapter    "smartgarden"   : 2.0.0
                    Adapter    "smartmeter"    : 3.4.0    , installed 3.2.1 [Updateable]
                    Adapter    "smartthings"   : 0.0.4
                    Adapter    "snips"         : 1.5.1
                    Adapter    "snmp"          : 3.1.0
                    Adapter    "socketio"      : 6.6.0    , installed 3.1.4 [Updateable]
                    Adapter    "solarlog"      : 2.2.8
                    Adapter    "solarmanpv"    : 0.5.1
                    Adapter    "solarviewdatareader": 1.0.7
                    Adapter    "solarwetter"   : 1.1.5
                    Adapter    "solax"         : 0.8.0
                    Adapter    "sonnen"        : 1.16.0
                    Adapter    "sonoff"        : 3.0.3    , installed 2.5.1 [Updateable]
                    Adapter    "sonos"         : 3.0.0
                    Adapter    "sony-bravia"   : 1.0.9
                    Adapter    "spotify-premium": 1.3.1
                    Adapter    "sprinklecontrol": 0.2.13
                    Adapter    "sql"           : 2.2.0
                    Adapter    "squeezeboxrpc" : 1.3.9
                    Adapter    "starline"      : 1.1.3
                    Adapter    "statistics"    : 2.4.0
                    Adapter    "stiebel-isg"   : 1.7.7
                    Adapter    "sureflap"      : 1.2.1
                    Adapter    "swiss-weather-api": 2.0.3
                    Adapter    "synochat"      : 1.3.1
                    Adapter    "synology"      : 3.0.1
                    Adapter    "systeminfo"    : 1.1.0
                    Adapter    "tado"          : 0.4.12
                    Adapter    "tahoma"        : 0.10.2
                    Adapter    "tankerkoenig"  : 3.3.7
                    Adapter    "tapo"          : 0.0.8
                    Adapter    "telegram"      : 3.0.1
                    Adapter    "telegram-menu" : 1.5.1
                    Adapter    "terminal"      : 1.0.0
                    Adapter    "tesla-motors"  : 1.3.2
                    Adapter    "text2command"  : 3.0.2
                    Adapter    "tibberlink"    : 2.0.0
                    Adapter    "tinker"        : 1.2.1
                    Adapter    "tinymqttbroker": 0.1.0
                    Adapter    "toyota"        : 0.0.3
                    Adapter    "tr-064"        : 4.2.18
                    Adapter    "traccar"       : 1.1.4
                    Adapter    "tractive-gps"  : 1.1.0
                    Adapter    "tradfri"       : 3.1.3
                    Adapter    "trashschedule" : 2.3.0
                    Adapter    "trivum"        : 0.0.5
                    Adapter    "tronity"       : 1.1.1
                    Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                    Adapter    "tuya"          : 3.15.0
                    Adapter    "tvprogram"     : 1.1.2
                    Adapter    "tvspielfilm"   : 2.0.5
                    Adapter    "twinkly"       : 1.0.14
                    Adapter    "unifi"         : 0.6.7
                    Adapter    "upnp"          : 1.0.21
                    Adapter    "uv-protect"    : 0.5.1
                    Adapter    "vaillant"      : 0.1.2
                    Adapter    "valloxmv"      : 1.2.0
                    Adapter    "valuetrackerovertime": 1.0.1
                    Adapter    "vcard"         : 0.0.9
                    Adapter    "vds2465-server": 0.1.10
                    Adapter    "velux"         : 0.0.7
                    Adapter    "vesync"        : 0.0.3
                    Adapter    "viessmann"     : 1.4.6
                    Adapter    "viessmannapi"  : 2.3.0
                    Adapter    "virtualpowermeter": 1.4.6   , installed 1.4.2 [Updateable]
                    Adapter    "vis"           : 1.5.4    , installed 1.4.3 [Updateable]
                    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                    Adapter    "vis-canvas-gauges": 1.0.1
                    Adapter    "vis-colorpicker": 2.0.3
                    Adapter    "vis-fancyswitch": 1.1.0
                    Adapter    "vis-google-fonts": 1.0.4
                    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                    Adapter    "vis-hqwidgets" : 1.4.0
                    Adapter    "vis-icontwo"   : 1.0.0
                    Adapter    "vis-inventwo"  : 3.3.3
                    Adapter    "vis-jqui-mfd"  : 1.0.12
                    Adapter    "vis-justgage"  : 2.1.0
                    Adapter    "vis-keyboard"  : 0.0.2
                    Adapter    "vis-lcars"     : 1.1.1
                    Adapter    "vis-map"       : 1.0.4
                    Adapter    "vis-material"  : 0.1.3
                    Adapter    "vis-material-advanced": 1.7.4
                    Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.1-beta [Updateable]
                    Adapter    "vis-metro"     : 1.2.0
                    Adapter    "vis-players"   : 0.1.6
                    Adapter    "vis-plumb"     : 1.0.2
                    Adapter    "vis-rgraph"    : 0.0.2
                    Adapter    "vis-timeandweather": 1.2.2
                    Adapter    "vis-weather"   : 2.5.6
                    Adapter    "voltoplus"     : 0.1.3
                    Adapter    "volumio"       : 0.1.2
                    Adapter    "volvo"         : 0.1.0
                    Adapter    "vr200"         : 1.0.0
                    Adapter    "vw-connect"    : 0.0.67
                    Adapter    "wallpanel"     : 0.3.11
                    Adapter    "warp"          : 1.2.2
                    Adapter    "weather-warnings": 0.6.4
                    Adapter    "weatherflow_udp": 0.1.3
                    Adapter    "weatherunderground": 3.6.0
                    Adapter    "web"           : 6.1.10   , installed 3.4.7 [Updateable]
                    Adapter    "webcal"        : 1.3.0
                    Adapter    "webui"         : 0.20.7
                    Adapter    "webuntis"      : 0.3.4
                    Adapter    "weishaupt-wem" : 0.0.15
                    Adapter    "welcome"       : 0.1.0
                    Adapter    "whatsapp-cmb"  : 0.2.3
                    Adapter    "wiegand-tcpip" : 0.4.6
                    Adapter    "wiffi-wz"      : 2.2.1
                    Adapter    "wifilight"     : 1.1.4
                    Adapter    "windows-control": 0.1.5
                    Adapter    "wiobrowser"    : 2.0.2
                    Adapter    "wireguard"     : 1.6.1
                    Adapter    "wireless-mbus" : 0.9.1
                    Adapter    "withings"      : 0.0.13
                    Adapter    "wlanthermo-nano": 0.2.1
                    Adapter    "wled"          : 0.7.2
                    Adapter    "wmswebcontrol" : 0.0.5
                    Adapter    "wolf"          : 1.7.0
                    Adapter    "wolf-smartset" : 1.1.1
                    Adapter    "worx"          : 2.3.4
                    Adapter    "ws"            : 2.5.8
                    Adapter    "xbox"          : 1.1.0
                    Adapter    "xs1"           : 1.0.2
                    Adapter    "xterm"         : 2.0.1
                    Adapter    "yahka"         : 1.0.3
                    Adapter    "yahoo-stock-market": 0.0.5
                    Adapter    "yamaha"        : 0.5.3
                    Adapter    "yeelight-2"    : 1.2.1
                    Adapter    "youtube"       : 4.4.0
                    Adapter    "yr"            : 5.3.0
                    Adapter    "zehnder-cloud" : 0.0.7
                    Adapter    "zigbee"        : 1.9.5
                    Adapter    "zigbee2mqtt"   : 2.13.3
                    Adapter    "zont"          : 0.5.4
                    Adapter    "zwave2"        : 3.1.0
                    karl@IOBROKER:/$
                    • G GOETSCHHOFER
                      iob update
                      update done
                      karl@IOBROKER:/$
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #130
                      @goetschhofer deine Datenbank stimmt nicht
                        GOETSCHHOFER
                        #131
                        Wie darf ich dies verstehen ?
                        G crunchipC 2 Antworten Letzte Antwort
                        • G GOETSCHHOFER
                          GOETSCHHOFER
                          #132
                          @crunchip
                          Sollten wir vorher das Problem mit den Dateien versuchen zu lösen ?
                          Bei den states sehe ich eine 0 u. bei den objects sehe ich auch eine große Veränderung ?
                          -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 10:54 2023-12-30_10-54_objects.json.gz
                          -rw-rw-r--+ 1 iobroker iobroker 138K Dez 30 10:54 2023-12-30_10-54_states.json.gz
                          karl@IOBROKER:/$
                          • G GOETSCHHOFER
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #133
                            @goetschhofer dein Fehler von oben
                            dir fehlt wohl jetzt die DB für states
                            führe das nochmal aus
                            iobroker stop
                            cd backup-objects/
                            gunzip -ck 2023-12-30_10-11_states.json.gz > /opt/iobroker/iobroker-data/states.json
                            iobroker start
                            und dann noch mal
                            iob update
                              iobroker stop
                              cd backup-objects/
                              iobroker start
                              und dann noch mal
                              iob update
                              GOETSCHHOFER
                              #134
                              iobroker start
                              Ich glaube jetzt schaut es gut aus, super danke ! 👍
                              Jetzt kann ich auch wieder auf den iobroker.
                              Ist hier etwas zu aktualisieren ?
                              Soll ich sicherheitshalber mal gleich eine Datensicherung in proxmox machen ?
                              login as: karl
                              Last login: Sat Dec 30 10:27:16 2023 from 192.168.1.3
                              karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-30_07-03_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                              karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-30_10-11_states.json.gz > /opt/iobroker/iobroker-data/states.json
                              karl@IOBROKER:/$
                              update done
                              karl@IOBROKER:/$
                              • G GOETSCHHOFER
                                iobroker start
                                login as: karl
                                karl@IOBROKER:/$
                                update done
                                karl@IOBROKER:/$
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #135
                                kannst du mal, dann ist zumindest dieser Stand vorerst gesichert
                                anschließend deine Adapter updaten
                                iobroker upgrade
                                • G GOETSCHHOFER
                                  iobroker start
                                  login as: karl
                                  karl@IOBROKER:/$
                                  update done
                                  karl@IOBROKER:/$
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #136
                                  zeig mal die Ausgabe von
                                  iob repo list
                                    iob repo list
                                    GOETSCHHOFER
                                    #137
                                    iob repo list
                                    karl@IOBROKER:~$ iob repo list
                                    Stable (default): http://download.iobroker.net/sources-dist.json
                                    Beta (latest): http://download.iobroker.net/sources-dist-latest.json
                                    live        : http://iobroker.live/repo/sources-dist-latest.json
                                    Active repo: Stable (default)
                                    karl@IOBROKER:~$
                                    • G GOETSCHHOFER
                                      iob repo list
                                      karl@IOBROKER:~$
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #138
                                      @goetschhofer ok das passt
                                        GOETSCHHOFER
                                        #139
                                        Super !!!👍
                                        • G GOETSCHHOFER
                                          Super !!!👍
                                          #140
                                          @goetschhofer
                                          Dann schaufel jetzt die Upgrades rein. Und künftig regelmäßig und häufiger aktuell halten.
                                          cd
                                          iob upgrade all -y
