  4. [Adapter] - iobroker.i2c
    6.7k
i2c
128 Beiträge 36 Kommentatoren 40.8k Aufrufe 26 Beobachtet
  • E Offline
    enricoh831
    schrieb am zuletzt editiert von enricoh831
    #61
    Ich habe mal nen MCP27031 an meinen Nanopi M4V2 angeschlossen.
    Hat auch komischerweise alles geklappt. In der Konsole mit i2ctools lauft alles.
    Im adapter hat er auch gleich an adresse 0x20 was gefunden. Nach dem Konfigurieren
    und speichern geht der Adapter nicht mehr auf grün (garnicht mehr).
    Im Log steht folgendes:
    host.Iobroker	2020-01-02 23:52:09.532	info	Restart adapter system.adapter.i2c.0 because enabled
    host.Iobroker	2020-01-02 23:52:09.532	info	instance system.adapter.i2c.0 terminated with code 0 (NO_ERROR)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5956:26)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5913:26)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5853:22)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at Adapter._processStatesSecondary (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5787:25)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at StateRedis.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:505:20)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5817:17)
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.i2c/i2c.js:129:14
    host.Iobroker	2020-01-02 23:52:09.531	error	Caught by controller[0]: at I2CAdapter.main (/opt/iobroker/node_modules/iobroker.i2c/i2c.js:43:20)
    host.Iobroker	2020-01-02 23:52:09.530	error	Caught by controller[0]: at Object.openSync (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:47:3)
    host.Iobroker	2020-01-02 23:52:09.530	error	Caught by controller[0]: at checkBusNumber (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:55:11)
    host.Iobroker	2020-01-02 23:52:09.530	error	Caught by controller[0]: Error: Invalid I2C bus number 2
    i2c.0	2020-01-02 23:52:09.015	info	(13771) Terminated (NO_ERROR): Without reason
    i2c.0	2020-01-02 23:52:09.014	info	(13771) terminating
    i2c.0	2020-01-02 23:52:08.964	error	at objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5956:26)
    i2c.0	2020-01-02 23:52:08.964	error	at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5913:26)
    i2c.0	2020-01-02 23:52:08.964	error	at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5853:22)
    i2c.0	2020-01-02 23:52:08.964	error	at Adapter._processStatesSecondary (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5787:25)
    i2c.0	2020-01-02 23:52:08.964	error	at StateRedis.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:505:20)
    i2c.0	2020-01-02 23:52:08.964	error	at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5817:17)
    i2c.0	2020-01-02 23:52:08.964	error	at /opt/iobroker/node_modules/iobroker.i2c/i2c.js:129:14
    i2c.0	2020-01-02 23:52:08.964	error	at I2CAdapter.main (/opt/iobroker/node_modules/iobroker.i2c/i2c.js:43:20)
    i2c.0	2020-01-02 23:52:08.964	error	at Object.openSync (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:47:3)
    i2c.0	2020-01-02 23:52:08.964	error	at checkBusNumber (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:55:11)
    i2c.0	2020-01-02 23:52:08.964	error	(13771) Error: Invalid I2C bus number 2
    i2c.0	2020-01-02 23:52:08.963	error	(13771) uncaught exception: Invalid I2C bus number 2
    i2c.0	2020-01-02 23:52:08.892	info	(13771) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.i2c, node: v10.18.0
    host.Iobroker	2020-01-02 23:52:07.721	info	instance system.adapter.i2c.0 started with pid 13771
    der Adapter erstellt auch keine Objekte
    hat einer ne idee.
    JS Controller ist 2.2.6
    schöne Grüße
      DrHouse03
      #62
      ich bin gerade dabei meine Pool-Steuerung zu planen.
      Jetzt bin ich auf das Tentacle T3 Board für den Raspberry Pi gestossen.
      Damit könnte ich die PH- und Redox-Werte über I2c auslesen.
      Leider bin ich noch nicht so versiert auf dem Gebiet.
      Wäre das mit diesem Adapter möglich oder müsste er noch erweitert werden?
      Danke schon mal für eure Hilfe
      Schöne Grüße
      • Christin-Michelle FremgenC Offline
        #63
        Hi
        Ich habe eine RaspiZero und daran einen Servo-Treiber (https://smile.amazon.de/AZDelivery-PCA9685-Servotreiber-Arduino-Raspberry/dp/B072N8G7Y9/ref=pd_sbs_328_1/257-1480378-7596562?_encoding=UTF8&pd_rd_i=B072N8G7Y9&pd_rd_r=fa0715ab-30dc-4c9f-a613-ebb99265e6a0&pd_rd_w=PPyA1&pd_rd_wg=Vbn4i&pf_rd_p=c8718c55-fb13-473f-a41c-592a17ad3468&pf_rd_r=50ZCEETZNTBTFYH6WE43&psc=1&refRID=50ZCEETZNTBTFYH6WE43). Damit möchte ich die Luftklappen meiner Heizung die eben mit Heißluft anstelle von Heißwasser funktioniert steuern. Es wäre super wenn es möglich wäre die Unterstützung für dieses Modul zu implementieren.
        LG
        • M mike1976
          bezüglich i2c.
          Wäre es denkbar diesen Druckensor mittels i2c einzubinden?
          https://docs.rs-online.com/021c/0900766b81568892.pdf
          LG Mike
          Der sensor:
          :~ $ i2cdetect -l
          i2c-1 i2c bcm2835 I2C adapter I2C adapter
          UncleSamU Offline
          UncleSamU Offline
          UncleSam
          schrieb am zuletzt editiert von UncleSam
          #64
          @mike1976 sagte in [Adapter] - iobroker.i2c:
          Hallo Mike, bist du immer noch an diesem Sensor interessiert? Der Sensor ist nicht gerade günstig für mich zum kaufen, aber ich könnte es mal ohne ihn zu kaufen versuchen.
          /UncleSam
          • O oHa510
            Hallo zusammen, ich bin erst seit kurzem in der Smarthome Welt unterwegs, aber da ich ioBroker super finde, möchte ich nun auch mal etwas zurückgeben. Es geht um das Digital Input Modul von Horter, auch ich hatte nun das Problem wie @mike1976 und @strago, dass sobald man das Modul im Adapter als "Eingänge" definitert, alle LED's auf dem Board leuchten und man daher nichts einlesen kann...
            Nun habe ich in der "PCF8574.js" gesehen, dass dort in der "start" Funktion eine "initial value" in den 8574 geschrieben wird. Im Falle des Input Moduls wird der Wert 0x00 geschrieben, was wohl auch normalerweise so passen würde, aber die Horter Module haben eine negative Logik, heißt für Horter ist 0x00 = alle Eingänge High, daher gehen auch alle LEDs auf dem Board an. Es müsste der Wert 0xFF geschrieben werden, danach kann man auch einwandfrei die Inputs einlesen (getestet!).
            @UncleSam Kannst du das entsprechend einprogrammieren? Man könnte z.B. berücksichtigen, ob der Eingang im Adapter als "invertiert" gekennzeichnet ist und dann entsprechend die initial value erzeugen?!
            Viele Grüße
            oHa
            UncleSamU Offline
            UncleSamU Offline
            UncleSam
            #65
            @oHa510 sagte in [Adapter] - iobroker.i2c:
            Hallo oHa, habe ein Issue in GitHub erfasst und werde mich möglichst bald darum kümmern:
            https://github.com/UncleSamSwiss/ioBroker.i2c/issues/40
            • Дмитрий КошлаковД Дмитрий Кошлаков
              @UncleSam
              Vielen Dank für den I2C Adapter. Ich baue den Controller auf Rasberry 3 zusammen. Ich möchte dem Treiber einen Temperatur- und Feuchtigkeitssensor SHT20 hinzufügen. Datenblatt
              Vielen Dank im Voraus!
              UncleSamU Offline
              UncleSamU Offline
              UncleSam
              #66
              @Дмитрий-Кошлаков Hallo, kannst du nicht den BME280 verwenden? Der wird schon unterstützt. /UncleSam
              • E enricoh831
                ich bin da gerade an einem neuen Projekt dran und möchte einen Arduino Mega direkt per I2C mit IO Broker ansteuern um Gpio zu schalten.
                Zur zeit geht das bei mir über 4 MCP27031 über I2C an einen Wemos D1 und dann per Mqtt an iobroker.
                Alternative wäre mir zwar Can Bus am liebsten aber da wir hier ja schon nen Adapter haben probiere ich erstmal I2C.
                Es gibt schon Python Skripte die über den Raspi einen Arduino steuern.
                Ich würde mir ja gerne selber den Adapter anpassen aber ich habe noch keine Berührungen mit adapter programmierung gehabt.
                Vielleicht habt ihr ja eine Idee.
                Schöne Grüße
                Enrico
                UncleSamU Offline
                UncleSamU Offline
                UncleSam
                #67
                @enricoh831 sagte in [Adapter] - iobroker.i2c:
                Hallo Enrico,
                wenn du per I2C zwischen RasPi (Master) und Arduino (Slave) kommunizieren willst, musst du wohl dein eigenes Protokoll machen. Falls du ganz einfach ein paar IOs schalten willst, dann benutze doch das MCP23017 Protokoll im Arduino, dann kannst du im ioBroker einfach MCP23017 einstellen.
                Proprietäre Protokolle, wie du eben möglicherweise machen willst, kann ich leider nicht unterstützen, da jeder ja eben sein eigenes Protokoll hat. Ich unterstütze nur "fixfertige" Silikon-Lösungen (I2C-Chips, die man so einkaufen kann).
                Falls ich etwas falsch verstanden habe, schick mir doch eine PM.
                /UncleSam
                • E enricoh831
                  hat einer ne idee.
                  schöne Grüße
                  UncleSamU Offline
                  UncleSamU Offline
                  UncleSam
                  #68
                  Hast du das Problem lösen können?
                  Meine Vermutungen: Bus Nummer 2 ist falsch (war das immer schon Nummer 2?) oder der Adapter respektive ioBroker läuft nicht mit den richtigen Berechtigungen (siehe: https://github.com/UncleSamSwiss/ioBroker.i2c#access-right-issue)
                  • D DrHouse03
                    Schöne Grüße
                    UncleSamU Offline
                    UncleSamU Offline
                    UncleSam
                    #69
                    @DrHouse03 sagte in [Adapter] - iobroker.i2c:
                    Das müsste noch implementiert werden. Gewisse Informationen finde ich hier: https://www.whiteboxes.ch/docs/tentacle/t3/#/code
                    Allerdings ist Implementieren ohne Hardware etwas schwierig und das Board ist doch etwas über meinem Budget nur um das zu implementieren.
                    Wenn du programmieren kannst, würde ich wohl eher das erwähnte i2c.py Skript erweitern und zum Beispiel per MQTT die Werte an den MQTT Adapter in ioBroker weiter schicken.
                    Wenn du nicht programmieren kannst, müssten wir bilateral (per PM) schauen, wie wwir das hinkriegen - es würde allerdings bedingen, dass du die Hardware bereits besitzt.
                    /UncleSam
                    • Christin-Michelle FremgenC Christin-Michelle Fremgen
                      Hi
                      LG
                      UncleSamU Offline
                      UncleSamU Offline
                      UncleSam
                      #70
                      @Christin-Michelle-Fremgen sagte in [Adapter] - iobroker.i2c:
                      GitHub Issue ist eröffnet: https://github.com/UncleSamSwiss/ioBroker.i2c/issues/41
                      Lieferung in 30-50 Tagen - sofern das Corona-Virus uns keinen Strich durch die Rechnung macht.
                        Telefisch
                        #71
                        Hallo UncleSam.
                        ich habe den Adapter "installiert" aber sehe nichts in den Instanzen.
                        Ich hab ein Multihost-System, falls das eine Rolle spielt.
                        Wie geht's jetzt weiter? Das sind die letzten Zeilen der Installationsausgabe:
                        upload [10] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/words.js words.js application/javascript
                        upload [9] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/lib/js/jsviews.min.js lib/js/jsviews.min.js application/javascript
                        upload [8] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/lib/js/jsviews-jqueryui-widgets.min.js lib/js/jsviews-jqueryui-widgets.min.js application/javascript
                        upload [7] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/index.html index.html text/html
                        upload [6] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/i2c.png i2c.png image/png
                        upload [5] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/devices/PCF8574.js devices/PCF8574.js application/javascript
                        upload [4] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/devices/MCP23017.js devices/MCP23017.js application/javascript
                        upload [3] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/devices/MCP23008.js devices/MCP23008.js application/javascript
                        upload [2] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/devices/DeviceBase.js devices/DeviceBase.js application/javascript
                        upload [1] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/devices/BME280.js devices/BME280.js application/javascript
                        upload [0] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/devices/ADS1x15.js devices/ADS1x15.js application/javascript
                        process exited with code 0
                        Sieht also nach meinem Empfinden gut aus. Hab ich was falsch gemacht? Ich müsste ihn ja mit I2C im Filter finden.
                        Gruß Carsten
                        Synology DS916+ (Docker), 2x Echo, 2x Dot, 2x Show
                        • UncleSamU UncleSam
                          /UncleSam
                          DrHouse03
                          #72
                          @UncleSam Danke für die Rückmeldung. Es hat sich erledigt. Ich löse das ganze über einen Arduino der die Daten an eine Siemens Logo sendet. Die Kommunikation mit iobroker erfolgt dann über den S7 Adapter.
                            Telefisch
                            schrieb am zuletzt editiert von Telefisch
                            #73
                            @UncleSam
                            Mittlerweile scheint der Adapter zu laufen.
                            Ich möchte einen APDS-9960 am RPI auslesen.
                            Wie fange ich das an? Der Sensor wird am Bus gefunden.
                            • F Offline
                              flubb
                              #74
                              @UncleSam
                              Bist du hier eigentlich noch dran?
                              https://github.com/UncleSamSwiss/ioBroker.i2c/issues/21
                              Falls ja, schon mal Danke!
                              • PizzaProgramP Offline
                                PizzaProgram
                                #75
                                Grüßgott,
                                1.) Habe vor 2 Tagen iobroker auf mein Raspberry Pi 4 installiert. (Minimal image von 2019.11)
                                2.) Alles upgraded
                                4.) I2C enabled (raspi-config), RPi restarted, installed:
                                sudo apt-get update
                                sudo apt-get install i2c-tools libi2c-dev python-smbus
                                • i2cdetect -l << kann die Busse schön listen:
                                pi@hv:~ $ sudo i2cdetect -l
                                i2c-7   i2c             i2c-tiny-usb at bus 001 device 014      I2C adapter
                                3.) Gab kommand:
                                sudo usermod -G i2c iobroker
                                Trozdem, findet dieses Adapter nicht mal den Bus: :(
                                host.hv 2020-03-30 17:31:56.944 info instance system.adapter.i2c.0 terminated with code 0 (NO_ERROR)
                                host.hv 2020-03-30 17:31:56.943 error Caught by controller[0]: at objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6061:26)
                                host.hv 2020-03-30 17:31:56.943 error Caught by controller[0]: at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6018:26)
                                host.hv 2020-03-30 17:31:56.943 error Caught by controller[0]: at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5958:22)
                                host.hv 2020-03-30 17:31:56.943 error Caught by controller[0]: at Adapter._processStatesSecondary (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5892:25)
                                host.hv 2020-03-30 17:31:56.943 error Caught by controller[0]: at StateRedis.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:594:20)
                                host.hv 2020-03-30 17:31:56.943 error Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
                                host.hv 2020-03-30 17:31:56.942 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.i2c/i2c.js:129:14
                                host.hv 2020-03-30 17:31:56.942 error Caught by controller[0]: at I2CAdapter.main (/opt/iobroker/node_modules/iobroker.i2c/i2c.js:43:20)
                                host.hv 2020-03-30 17:31:56.942 error Caught by controller[0]: at Object.openSync (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:47:3)
                                host.hv 2020-03-30 17:31:56.942 error Caught by controller[0]: at checkBusNumber (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:55:11)
                                host.hv 2020-03-30 17:31:56.941 error Caught by controller[0]: Error: Invalid I2C bus number 7
                                i2c.0 2020-03-30 17:31:56.430 info (7112) Terminated (NO_ERROR): Without reason
                                i2c.0 2020-03-30 17:31:56.429 info (7112) terminating
                                i2c.0 2020-03-30 17:31:56.424 error at objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6061:26)
                                i2c.0 2020-03-30 17:31:56.424 error at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6018:26)
                                i2c.0 2020-03-30 17:31:56.424 error at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5958:22)
                                i2c.0 2020-03-30 17:31:56.424 error at Adapter._processStatesSecondary (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5892:25)
                                i2c.0 2020-03-30 17:31:56.424 error at StateRedis.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:594:20)
                                i2c.0 2020-03-30 17:31:56.424 error at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
                                i2c.0 2020-03-30 17:31:56.424 error at /opt/iobroker/node_modules/iobroker.i2c/i2c.js:129:14
                                i2c.0 2020-03-30 17:31:56.424 error at I2CAdapter.main (/opt/iobroker/node_modules/iobroker.i2c/i2c.js:43:20)
                                i2c.0 2020-03-30 17:31:56.424 error at Object.openSync (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:47:3)
                                i2c.0 2020-03-30 17:31:56.424 error at checkBusNumber (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:55:11)
                                i2c.0 2020-03-30 17:31:56.424 error (7112) Error: Invalid I2C bus number 7
                                i2c.0 2020-03-30 17:31:56.423 error (7112) uncaught exception: Invalid I2C bus number 7
                                i2c.0 2020-03-30 17:31:56.313 info (7112) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.i2c, node: v10.19.0
                                Ich verstehe Deutsch gut, nur is it easier to type in English.
                                HBH 1 Antwort Letzte Antwort
                                  Abry
                                  #76
                                  Ich habe gelesen, dass es eine Anfrage für den INA219 gibt. Dies würde mich auch sehr interessieren. Ist der INA 219 schon implementiert?
                                  Viele Grüße
                                    Abry
                                    #77
                                    Keine eine Idee?
                                    • PizzaProgramP PizzaProgram
                                      Grüßgott,
                                      2.) Alles upgraded
                                      sudo apt-get update
                                      3.) Gab kommand:
                                      HBH Offline
                                      HBH Offline
                                      HB
                                      schrieb am zuletzt editiert von HB
                                      #78
                                      @PizzaProgram Ich habe das gleiche probiert, auf der RaspberryPi4 findet er den ADS1115:
                                      Allerdings findet er den über I2C verbunden ADS1115 nicht in IObroker:
                                      Ich kriege den über I2C am Pi4 (habs auch an einem Zero versucht) verbundenen ADS1115 somit leider auch nicht zum laufen, machen wir was falsch?
                                        strago
                                        #79
                                        @PizzaProgram @HB Ich hatte ein ähnliches Probleme wenn man den Iobroker mit einem fertigen Image aufgesetzt hat. Gelöst hab ich das mit folgenden Befehlen:
                                        adduser iobroker i2c
                                        adduser www-data i2c
                                        Vielleicht mal versuchen ob das hilft.
                                        sg
                                        Strago
                                        • S strago
                                          sg
                                          Strago
                                          HBH Offline
                                          HBH Offline
                                          HB
                                          #80
                                          @strago Hallo Strago,
                                          Danke zuerst mal;
                                          leider hat sich allerdings bei mir nichts geändert..
                                          Ich habe ein Reboot gemacht und auf dem Pi4 als auch Zero aber die Fehler Meldung, dass I2C Bus umber 1 nicht stimmt bleibt.
