  4. Neuer Adapter ecoflow-mqtt
    6.3k
804 Beiträge 62 Kommentatoren 308.1k Aufrufe 56 Beobachtet
  • S sirdir
    @foxthefox ist das wohl die Info?
    pstation: {"addr":0,"cmdFunc":0,"cmdId":0,"id":1584733429925413247,"version":"1.0","timestamp":1699223252,"moduleType":"4","params":{"bms_slave_bmsSlaveStatus_1.vol":50995,"bms_slave_bmsSlaveStatus_1.cellVol":[3226,3227],"bms_slave_bmsSlaveStatus_1.remainCap":12229,"bms_slave_bmsSlaveStatus_1.f32ShowSoc":31.4,"bms_slave_bmsSlaveStatus_1.cellTemp":[]}}
    foxthefox
    #41
    @sirdir sagte in Neuer Adapter ecoflow-mqtt:
    genau, das.
    muß "bms_slave_bmsSlaveStatus_1" erkennen und auswerten
    Adapterüberblick: Profil Github;
    Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
    Ein Aufruf: video
    • S sirdir
      @foxthefox hab den installiert. Hier noch 4 die ich grad gesehen habe:
      State value to set for "ecoflow-mqtt.0.xx.pd.dsgPowerAC" has value "5135.8" greater than max "4000"
      State value to set for "ecoflow-mqtt.0.xx.pd.chgPowerAC" has value "45061.3" greater than max "4000"
      State value to set for "ecoflow-mqtt.0.xx. inv.acChgRatedPower" has value "2400" greater than max "1800"
      State value to set for "ecoflow-mqtt.0.xx. inv.FastChgWatts" has value "2400" greater than max “2200”
      foxthefox
      #42
      061
      2400W ist eingebaut.
      bei dsgPowerAC/chgPowerAC scheint mir der Faktor zu groß, habe jetzt um 100 kleiner, also mal beobachten ob es mit den Erwartungen korreliert.
      Ein Aufruf: video
      • Norbert GöpelN Norbert Göpel
        @foxthefox - I currently implemented direct in javascript (own script) the possibility to set min / max chgwatts for my Delta2. I set 50 Watt as minimum and this works fine. My Delta 2 accepts down to 50. The app has only 200 as minimum but if I set 50 with my script, this also shown in the app and delta2 loads only with that value.
        foxthefox
        #43
        @norbert-göpel
        @sirdir
        changes are in the upcomming version 0.0.8
        to install it already use in user defined settings:
        https://github.com/foxthefox/ioBroker.ecoflow-mqtt/tree/0.0.8
        important, the changes to datapoints get only effective when deleting them before update.
        Ein Aufruf: video
        • F foxthefox
          genau, das.
          sirdir
          schrieb am zuletzt editiert von sirdir
          #44
          @foxthefox Jetzt klappt es mit dem Zusatzakku.
          Von den Warnmeldungen hab ich gerade auch keine mehr gesehen.
          F 1 Antwort Letzte Antwort
          • S sirdir
            foxthefox
            #45
            Sehr gut, dann hat es geklappt.
            Ein Aufruf: video
            • F foxthefox
              foxthefox
              #46
              @foxthefox
              dann hab ich mal 0.0.8 finalisiert.
              0.0.8
              • (foxthefox) Delta2Max mppt.outVol mult=0.001 instead 0.1
              • (foxthefox) handling additional battery for Delta2Max
              • (foxthefox) pd.dsgPowerAC -> mult 0.001 Delta2Max
              • (foxthefox) pd.chgPowerAC -> mult 0.001 Delta2Max
              • (foxthefox) inv.acChgRatedPower -> max 4000W
              • (foxthefox) inv.FastChgWatts -> max 2400W
              • (foxthefox) chgwatts Delta 2 -> min 50W
              Ein Aufruf: video
              • F foxthefox
                @foxthefox
                0.0.8
                foxthefox
                #47
                @foxthefox
                nur mal so zur Info, bin die nächste Zeit offline
                Ein Aufruf: video
                • F foxthefox
                  @foxthefox
                  foxthefox
                  schrieb am zuletzt editiert von foxthefox
                  #48
                  neue Version verfügbar.
                  wichtigste Änderung mit admin 6.12.3 funktioniert nun auch das automatische befüllen der MQTT credentials
                  0.0.9
                  • (foxthefox) final version of credential creation, at least 6.12.3 for admin required
                  • (foxthefox) pd.wattsInSum max=4000W, pd.wattsOutSum max=4000W
                  • (foxthefox) unknwon59 -> batChargingTime, battMin -> batDischargingTime
                  • (foxthefox) processing multiple messages in one datagram
                  Ein Aufruf: video
                  • F foxthefox
                    0.0.9
                    foxthefox
                    #49
                    @foxthefox
                    nun werden auch die SmartPlugs unterstützt.
                    Da ich keine besitze, ist eine Rückmeldung zur Plausibilität der Werte wichtig. Es kann sein, daß man noch an der ein oder anderen Stelle ein Komma verschieben muß.
                    0.0.10
                    • (foxthefox) unknown pstream message debug possibility
                    • (foxthefox) inv.outTemp max=90°C, inverter_heartbeat.pv1/2inputWatts max=600W
                    • (foxthefox) new function -> smart plugs
                    Ein Aufruf: video
                    • F foxthefox
                      @foxthefox
                      0.0.10
                      foxthefox
                      #50
                      @foxthefox
                      neue Version war notwendig, da ich nicht an allen Stellen plug+stream berücksichtigt hatte
                      0.0.11
                      • (foxthefox) correction this.pstreamStatesDict to cope with pstream and plug
                      Ein Aufruf: video
                      A 1 Antwort Letzte Antwort
                      • F foxthefox
                        @foxthefox
                        0.0.11
                        ApolloSK
                        #51
                        @foxthefox
                        Hallo foxthefox, ich habe die Version des Adapter installiert.
                        Powerstream und Deltas werden erkannt und die Werte angezeigt.
                        Die Plugs werden grundsätzlich auch erkannt - zumindest wird der Objektbaum "plus_heartbeat" mit den entsprechenden Unterobjekten angelegt. Leider werden dieser aber nicht mit Daten befüllt. Im Adapter habe ich daraufhin die Protokollstufe auf "silly" gestellt. Die einzige Fehlermeldung die ausgegeben wird, ist folgende:
                        ecoflow-mqtt.0
                        2023-12-13 09:14:07.796 warn State "ecoflow-mqtt.0.HW52ZDH4xxxxxxxx2.energy.watth6" has no existing object, this might lead to an error in future versions
                        Wenn ich die Helligkeit des PLUGS über die App ändere, wird folgendes Ergebnis protokolliert:
                        ecoflow-mqtt.0
                        2023-12-13 09:13:57.025 debug store payload TypeError: Cannot read properties of undefined (reading 'brightness')
                        Kannst du da bitte mal prüfen? DANKE!
                        F 2 Antworten Letzte Antwort
                        • A ApolloSK
                          @foxthefox
                          ecoflow-mqtt.0
                          ecoflow-mqtt.0
                          foxthefox
                          #52
                          @apollosk
                          Danke für die Rückmeldung, ich habe ja keine Plugs und somit ist die Rückmeldung sehr wichtig.
                          Kommt da wirklich Objektbaum "plus_heartbeat" und nicht "plug_heartbeat" ?
                          Das wäre zumindest ein Grund, warum dort keine Daten hereinkommen.
                          Es war eigentlich nicht vorgesehen, daß bei Plugs auch Energie ausgelesen wird, da konnte ich bisher zu wenig analysieren.
                          Wenn ich soweit bin, wird es auch dort den energy Baum geben.
                          brightness sollte eigentlich noch nicht änderbar sein, habe heute erst Daten dazu analysiert, kommt aber im nächsten Update
                          Ein Aufruf: video
                          • A ApolloSK
                            @foxthefox
                            ecoflow-mqtt.0
                            ecoflow-mqtt.0
                            foxthefox
                            #53
                            @apollosk
                            Du könntest den Adapter auch mal in den debug modus schalten, damit ein paar mehr Meldungen herauskommen.
                            Zusätzlich wäre dann noch ein Häckchen bei msgUpdatePlug und msgUpdateValuePlug notwendig um sich auf den Plug zu konzentrieren
                            Ein Aufruf: video
                            • F foxthefox
                              @apollosk
                              ApolloSK
                              #54
                              @foxthefox
                              Mein Fehler - es wird der Objektbaum "plug_heartbeat" angezeigt
                              Brigthness habe ich in der App nur mal geändert um zu prüfen ob was im Adapter ankommt.
                              • A ApolloSK
                                @foxthefox
                                foxthefox
                                #55
                                @apollosk
                                OK, dann muß es etwas anderes sein, warum es die Werte nicht schreibt.
                                Schonmal debug angeschaut?
                                Ein Aufruf: video
                                • F foxthefox
                                  @apollosk
                                  ApolloSK
                                  #56
                                  @foxthefox
                                  Adapter läuft jetzt im Debug-Modus, mit den entsprechenden Häckchen bei den o.g. Punkten:
                                  ecoflow-mqtt.0
                                  2023-12-13 18:17:09.935	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:16:09.746	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:15:30.121	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:15:28.150	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:15:09.660	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:14:09.528	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:13:25.023	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:13:22.999	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:13:09.294	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:12:48.122	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:12:46.087	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:12:09.239	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:12:01.010	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:11:58.937	debug	store payload TypeError: Cannot read properties of undefined (reading 'volt')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:11:09.119	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:10:09.107	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:09:08.928	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:08:08.801	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:07:08.674	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:06:33.187	debug	store payload TypeError: Cannot read properties of undefined (reading 'brightness')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:06:28.327	debug	store payload TypeError: Cannot read properties of undefined (reading 'errCode')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:06:26.370	debug	store payload TypeError: Cannot read properties of undefined (reading 'errCode')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:06:08.520	warn	State "ecoflow-mqtt.0.HW52ZDH4XXXXXXXX.energy.watth6" has no existing object, this might lead to an error in future versions
                                  ecoflow-mqtt.0
                                  2023-12-13 18:05:58.235	debug	store payload TypeError: Cannot read properties of undefined (reading 'heartbeatFrequency')
                                  ecoflow-mqtt.0
                                  2023-12-13 18:05:56.769	debug	subscribed the topics
                                  ecoflow-mqtt.0
                                  2023-12-13 18:05:56.674	debug	connected
                                  Der Rest betrifft die Powerstations bzw den Powerstream.
                                  • A ApolloSK
                                    @foxthefox
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    ecoflow-mqtt.0
                                    foxthefox
                                    #57
                                    @apollosk
                                    danke derweil, es gibt ein wenig mehr Einblick
                                    EDIT:
                                    Kann es sein, daß noch ein Häckchen bei msgUpdatePlug nicht gesetzt ist?
                                    Ein Aufruf: video
                                    • F foxthefox
                                      @apollosk
                                      EDIT:
                                      ApolloSK
                                      #58
                                      @foxthefox
                                      msgUpdatePlug und msgUpdateValuePlug, beide sind aktiviert.
                                      • A ApolloSK
                                        @foxthefox
                                        foxthefox
                                        #59
                                        @apollosk sagte in Neuer Adapter ecoflow-mqtt:
                                        @foxthefox
                                        ich hatte es oben schon gelesen, aber eigentlich hätte es damit noch eine andere Meldung geben müssen.
                                        nunja, ich schau weiter.
                                        Ein Aufruf: video
                                        • F foxthefox
                                          @foxthefox
                                          foxthefox
                                          #60
                                          @ApolloSK
                                          Eine neue Version ist auf github verfügbar.
                                          Plug sollte mindestens das watth6 jetzt gehen und das andere vom plug könnte funktionieren.
                                          0.0.12
                                          • (foxthefox) new command brightness for plugs
                                          • (foxthefox) correction of factors for plugs
                                          • (foxthefox) powerstream bpType with value as texts
                                          • (foxthefox) DELTA 2 factors corrected (mppt.inVol, mppt.inAmp,mppt.carOutAmp, mppt.carOutVol)
                                          • (foxthefox) naming of watth1...8 (except 5)
                                          Ein Aufruf: video
                                          F A 2 Antworten Letzte Antwort
