  4. Zigbee Adapter startet nicht mehr
    5.1k
51 Beiträge 6 Kommentatoren 7.0k Aufrufe 6 Beobachtet
    @anselra
    fuser -mv /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00
    fuser -mv `readlink -f /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00`
    anselra
    #41
    pi@iobroker:~ $ fuser -mv /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00
                         USER        PID ACCESS COMMAND
    /dev/ttyACM0:        root     kernel mount /dev
    pi@iobroker:~ $ fuser -mv `readlink -f /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00`
    zigbee.0
    2023-10-28 17:03:25.648	error	Error herdsman start
    zigbee.0
    2023-10-28 17:03:25.647	error	Failed to start Zigbee
    zigbee.0
    2023-10-28 17:03:25.645	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2023-10-28 17:03:25.306	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
    zigbee.0
    2023-10-28 17:03:25.278	info	Starting Zigbee npm ...
    zigbee.0
    2023-10-28 17:03:25.276	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-10-28 17:03:15.274	error	Error herdsman start
    zigbee.0
    2023-10-28 17:03:15.273	error	Failed to start Zigbee
    zigbee.0
    2023-10-28 17:03:15.272	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2023-10-28 17:02:54.320	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
    zigbee.0
    2023-10-28 17:02:53.826	info	Starting Zigbee npm ...
    zigbee.0
    2023-10-28 17:02:53.819	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-10-28 17:02:53.634	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
    zigbee.0
    2023-10-28 17:02:50.476	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    BETRIEBSSYSTEM: LINUX
    ARCHITEKTUR: ARM
    CPUS: 4
    GESCHWINDIGKEIT: 1500 MHZ
    MODELL: ARMV7 PROCESSOR REV 3 (V7L)
    RAM: 3.7 GB
      @anselra sagte in Zigbee Adapter startet nicht mehr:
      Ich habe es mit Bookworm lite und:
      Ich hatte dasselbe Problem auch.
      thomas@rpizigbee:~ $ apt policy udev
      udev:
        Installiert:           252.17-1~deb12u1
        Installationskandidat: 252.17-1~deb12u1
        Versionstabelle:
       *** 252.17-1~deb12u1 500
              100 /var/lib/dpkg/status
      So habe ich es gestern auch eingerichtet, und der Zigbee wurde partout nicht grün.
      Also habe ich direkt in der Konsole den entsprechenden Wert rauskopiert:
      thomas@rpizigbee:~ $ ls -lah /dev/serial/by-id
      insgesamt 0
      drwxr-xr-x 2 root root 100 27. Okt 17:56 .
      drwxr-xr-x 4 root root  80 27. Okt 17:56 ..
      lrwxrwxrwx 1 root root  13 27. Okt 17:56 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
      lrwxrwxrwx 1 root root  13 27. Okt 17:56 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00 -> ../../ttyACM0
      lrwxrwxrwx 1 root root  13 27. Okt 17:56 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03 -> ../../ttyACM1
      , als
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
      in die Einstellungen der Instanz eingefügt, und die Verbindung ist geglückt.
      Ich war mir sicher, dass exakt diese Bezeichnung vorher auch drin stand, aber wie war das nochmal mit Teufel und Eichhörnchen. :man-shrugging:
      anselra
      #42
      @meister-mopper said in Zigbee Adapter startet nicht mehr:
      udev:
        Versionstabelle:
      insgesamt 0
      , als
      Hat bei mir leider nichts gebracht, ich kopiere alles immer aus meiner Install doku
      ARCHITEKTUR: ARM
      CPUS: 4
      RAM: 3.7 GB
      • A anselra
        udev:
          Versionstabelle:
        insgesamt 0
        , als
        #43
        Kopier es lieber aus der Konsole.
        Wo bei die Meldung bei einem falschen Dateinamen eine andere wäre.
        A 1 Antwort Letzte Antwort
          anselra
          schrieb am zuletzt editiert von anselra
          #44
          habs nochmal alles neu raus kopiert
          zigbee.0
          2023-10-28 17:14:15.866	error	Error herdsman start
          zigbee.0
          2023-10-28 17:14:15.865	error	Failed to start Zigbee
          zigbee.0
          2023-10-28 17:14:15.863	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          zigbee.0
          2023-10-28 17:14:15.445	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
          zigbee.0
          2023-10-28 17:14:15.372	info	Starting Zigbee npm ...
          zigbee.0
          2023-10-28 17:14:15.370	info	Try to reconnect. 1 attempts left
          zigbee.0
          2023-10-28 17:14:05.368	error	Error herdsman start
          zigbee.0
          2023-10-28 17:14:05.367	error	Failed to start Zigbee
          zigbee.0
          2023-10-28 17:14:05.366	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          zigbee.0
          2023-10-28 17:13:44.744	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
          zigbee.0
          2023-10-28 17:13:44.178	info	Starting Zigbee npm ...
          zigbee.0
          2023-10-28 17:13:44.173	info	delete old Backup files. keep only last 10
          zigbee.0
          2023-10-28 17:13:43.935	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
          zigbee.0
          2023-10-28 17:13:43.564	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          zigbee.0
          2023-10-28 17:13:34.018	info	debug devices set to []
          zigbee.0
          2023-10-28 17:13:33.927	info	terminating
          zigbee.0
          2023-10-28 17:13:33.926	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0
          2023-10-28 17:13:33.923	info	terminating
          zigbee.0
          2023-10-28 17:13:33.922	warn	Failed to stop zigbee during startup
          zigbee.0
          2023-10-28 17:13:33.872	info	Zigbee: disabling joining new devices.
          zigbee.0
          2023-10-28 17:13:33.129	info	cleaned everything up...
          zigbee.0
          2023-10-28 17:13:33.126	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.0
          2023-10-28 17:13:23.941	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100GZZ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100GZZ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03","vendorId":"0451","productId":"bef3"}]
          zigbee.0
          2023-10-28 17:13:23.559	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
          ARCHITEKTUR: ARM
          CPUS: 4
          RAM: 3.7 GB
          • A anselra
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            #45
            Das ist gerne was aus der Firmware-Ecke.
            A 2 Antworten Letzte Antwort
              anselra
              #46
              möchte ungern jetzt was an der Firmware machen, hab noch Sticks die versuche ich mal.
              melde mich :-)
              ARCHITEKTUR: ARM
              CPUS: 4
              RAM: 3.7 GB
                anselra
                #47
                na was soll ich sagen, mit dem Zigbee CC2531 USB Dongle geht es mit dem dev Board CC26X2R1 nicht.
                Mal schauen was für Firmware wo drauf ist falls man das findet
                ARCHITEKTUR: ARM
                CPUS: 4
                RAM: 3.7 GB
                • A anselra
                  #48
                  CC26X2R1
                  https://www.zigbee2mqtt.io/guide/adapters/flashing/flashing_via_uniflash.html
                    CC26X2R1
                    anselra
                    #49
                    update gemacht dev Board CC26X2R1 auf Z-Stack_3.x.0 coordinator 20230507
                    zigbee.0
                    2023-10-28 19:10:12.178	error	Error herdsman start
                    zigbee.0
                    2023-10-28 19:10:12.178	error	Failed to start Zigbee
                    zigbee.0
                    2023-10-28 19:10:12.177	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    zigbee.0
                    2023-10-28 19:10:11.815	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                    zigbee.0
                    2023-10-28 19:10:11.785	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-10-28 19:10:11.783	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    2023-10-28 19:10:01.781	error	Error herdsman start
                    zigbee.0
                    2023-10-28 19:10:01.780	error	Failed to start Zigbee
                    zigbee.0
                    2023-10-28 19:10:01.779	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                    zigbee.0
                    2023-10-28 19:09:41.317	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                    zigbee.0
                    2023-10-28 19:09:40.896	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-10-28 19:09:40.893	info	delete old Backup files. keep only last 10
                    zigbee.0
                    2023-10-28 19:09:40.708	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                    zigbee.0
                    2023-10-28 19:09:40.385	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    zigbee.0
                    2023-10-28 19:09:31.457	info	terminating
                    zigbee.0
                    2023-10-28 19:09:31.431	info	debug devices set to []
                    zigbee.0
                    2023-10-28 19:09:31.351	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    2023-10-28 19:09:31.350	info	terminating
                    zigbee.0
                    2023-10-28 19:09:31.349	warn	Failed to stop zigbee during startup
                    zigbee.0
                    2023-10-28 19:09:31.285	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    2023-10-28 19:09:30.951	info	cleaned everything up...
                    zigbee.0
                    2023-10-28 19:09:30.949	info	Got terminate signal TERMINATE_YOURSELF
                    leider das gleiche Ergebnis
                    Bezeichnung wurde angepasst im Adapter
                    usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GZZ-if00 -> ../../ttyACM0
                    ARCHITEKTUR: ARM
                    CPUS: 4
                    RAM: 3.7 GB
                    • A anselra
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      Meister MopperM Online
                      Meister Mopper
                      #50
                      Dann solltest du aber diesen Teil -> ../../ttyACM0 abschneiden.
                      Proxmox und HA ...
                        anselra
                        #51
                        @meister-mopper
                        sorry mein kopierfehler, ist natürlich nicht mit dabei
                        ARCHITEKTUR: ARM
                        CPUS: 4
                        RAM: 3.7 GB
