  4. Zigbee Adapter startet nicht mehr
    5.1k
51 Beiträge 6 Kommentatoren 7.0k Aufrufe 6 Beobachtet
    @anselra sagte in Zigbee Adapter startet nicht mehr:
    Pending Updates: 11
    Zieh die mal rein.
    Und dann zeig nochmal einen kompletten Kaltstart des zigbee-Adapters.
    Und die Einstellungen des Adapters.
    anselra
    schrieb am zuletzt editiert von anselra
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.1.0-rpi4-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:40:33 up 2 min,  2 users,  load average: 0.26, 0.22, 0.09
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2023-10-28 16:40:33 CEST
               Universal time: Sat 2023-10-28 14:40:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        498M        3.3G        1.2M        242M        3.5G
    Swap:           104M          0B        104M
    Total:          4.1G        498M        3.4G
             3793 M total memory
              476 M used memory
              475 M active memory
               68 M inactive memory
             3155 M free memory
               21 M buffer memory
              209 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       57G  2.8G   52G   6% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Oct 28 16:38:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8D:C3:A3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5aa7add2-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Oct 28 16:38:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Oct 28 16:38:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    533M    /var/
    209M    /var/cache
    203M    /var/cache/apt
    159M    /var/lib
    130M    /var/lib/apt/lists
    Archived and active journals take up 64.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    30M     /opt/iobroker/iobroker-data/
    22M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    7.6M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.10.1 [Updatable]
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        172
    States:         126
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14691      689/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14751      680/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14758      680/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14693      689/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16541      724/io.admin.0
    udp        0      0 0.0.0.0:36003           0.0.0.0:*                           104        14643      535/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14641      535/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        14642      535/avahi-daemon: r
    udp6       0      0 :::55452                :::*                                104        14644      535/avahi-daemon: r
    2023-10-28 16:38:08.012  - info: admin.0 (724) ==> Connected system.user.admin from ::ffff:192.168.0.134
    2023-10-28 16:38:09.611  - info: host.iobroker instance system.adapter.discovery.0 started with pid 806
    2023-10-28 16:38:12.001  - info: zigbee.0 (787) starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
    2023-10-28 16:38:12.162  - info: zigbee.0 (787) Starting Zigbee  npm ...
    2023-10-28 16:38:12.245  - info: discovery.0 (806) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.12
    2023-10-28 16:38:12.668  - info: zigbee.0 (787) Installed Version: iobroker.zigbee@1.8.23
    2023-10-28 16:38:13.276  - error: zigbee.0 (787) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
    2023-10-28 16:38:13.277  - error: zigbee.0 (787) Failed to start Zigbee
    2023-10-28 16:38:13.278  - error: zigbee.0 (787) Error herdsman start
    2023-10-28 16:38:13.621  - info: host.iobroker instance system.adapter.backitup.0 started with pid 830
    2023-10-28 16:38:15.999  - info: backitup.0 (830) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
    2023-10-28 16:38:16.097  - info: backitup.0 (830) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-10-28 16:38:23.282  - info: zigbee.0 (787) Try to reconnect. 1 attempts left
    2023-10-28 16:38:23.284  - info: zigbee.0 (787) Starting Zigbee  npm ...
    2023-10-28 16:38:23.334  - info: zigbee.0 (787) Installed Version: iobroker.zigbee@1.8.23
    2023-10-28 16:38:23.667  - error: zigbee.0 (787) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
    2023-10-28 16:38:23.668  - error: zigbee.0 (787) Failed to start Zigbee
    2023-10-28 16:38:23.670  - error: zigbee.0 (787) Error herdsman start
    2023-10-28 16:39:09.804  - info: admin.0 (724) <== Disconnect system.user.admin from ::ffff:192.168.0.134
    2023-10-28 16:39:09.820  - info: admin.0 (724) ==> Connected system.user.admin from ::ffff:192.168.0.134
    2023-10-28 16:39:09.826  - info: admin.0 (724) <== Disconnect system.user.admin from ::ffff:192.168.0.134 admin
    2023-10-28 16:39:09.879  - info: admin.0 (724) ==> Connected system.user.admin from ::ffff:192.168.0.134
    2023-10-28 16:39:11.223  - info: admin.0 (724) <== Disconnect system.user.admin from ::ffff:192.168.0.134 admin
    2023-10-28 16:39:11.359  - info: admin.0 (724) ==> Connected system.user.admin from ::ffff:192.168.0.134
    2023-10-28 16:39:18.894  - info: admin.0 (724) <== Disconnect system.user.admin from ::ffff:192.168.0.134
    Update ist durch und nach Reboot folgende Zigbee Meldungen
    zigbee.0
    2023-10-28 16:38:23.670	error	Error herdsman start
    zigbee.0
    2023-10-28 16:38:23.668	error	Failed to start Zigbee
    zigbee.0
    2023-10-28 16:38:23.667	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
    zigbee.0
    2023-10-28 16:38:23.334	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-10-28 16:38:23.284	info	Starting Zigbee npm ...
    zigbee.0
    2023-10-28 16:38:23.282	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-10-28 16:38:13.278	error	Error herdsman start
    zigbee.0
    2023-10-28 16:38:13.277	error	Failed to start Zigbee
    zigbee.0
    2023-10-28 16:38:13.276	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
    zigbee.0
    2023-10-28 16:38:12.668	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-10-28 16:38:12.162	info	Starting Zigbee npm ...
    zigbee.0
    2023-10-28 16:38:12.001	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
    zigbee.0
    2023-10-28 16:37:47.901	warn	Failed to stop zigbee during startup
    zigbee.0
    2023-10-28 16:37:41.769	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-10-28 16:37:41.763	info	cleaned everything up.
    und noch die Einstellungen
    BETRIEBSSYSTEM: LINUX
    ARCHITEKTUR: ARM
    CPUS: 4
    GESCHWINDIGKEIT: 1500 MHZ
    MODELL: ARMV7 PROCESSOR REV 3 (V7L)
    RAM: 3.7 GB
    • A anselra
      kurze Info,
      Ich habe es mit Bookworm lite und:
      pi@iobroker:~ $ apt policy udev
      udev:
        Installed: 252.17-1~deb12u1
        Candidate: 252.17-1~deb12u1
        Version table:
       *** 252.17-1~deb12u1 500
      nicht zum laufen gebracht.
      Bin zurück auf Bullseye lite und mit der https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev läuft jetzt wieder alles.
      Nicht ganz das gewünschte Ergebnis.
      Meister MopperM Online
      Meister Mopper
      Ich hatte dasselbe Problem auch.
      thomas@rpizigbee:~ $ apt policy udev
      udev:
        Installiert:           252.17-1~deb12u1
        Installationskandidat: 252.17-1~deb12u1
        Versionstabelle:
      So habe ich es gestern auch eingerichtet, und der Zigbee wurde partout nicht grün.
      Also habe ich direkt in der Konsole den entsprechenden Wert rauskopiert:
      thomas@rpizigbee:~ $ ls -lah /dev/serial/by-id
      insgesamt 0
      drwxr-xr-x 2 root root 100 27. Okt 17:56 .
      drwxr-xr-x 4 root root  80 27. Okt 17:56 ..
      lrwxrwxrwx 1 root root  13 27. Okt 17:56 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
      lrwxrwxrwx 1 root root  13 27. Okt 17:56 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00 -> ../../ttyACM0
      lrwxrwxrwx 1 root root  13 27. Okt 17:56 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03 -> ../../ttyACM1
      , als
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
      in die Einstellungen der Instanz eingefügt, und die Verbindung ist geglückt.
      Ich war mir sicher, dass exakt diese Bezeichnung vorher auch drin stand, aber wie war das nochmal mit Teufel und Eichhörnchen. :man-shrugging:
      Proxmox und HA ...
      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
      • A anselra
        Skript v.2023-10-10
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           104M          0B        104M
                 3793 M total memory
                  476 M used memory
                  475 M active memory
                 3155 M free memory
                   21 M buffer memory
                  209 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        533M    /var/
        209M    /var/cache
        203M    /var/cache/apt
        159M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        172
        States:         126
        Pending Updates: 0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        @anselra
        fuser -mv /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00
        fuser -mv `readlink -f /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00`
          @anselra
          anselra
          pi@iobroker:~ $ fuser -mv /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00
                               USER        PID ACCESS COMMAND
          /dev/ttyACM0:        root     kernel mount /dev
          pi@iobroker:~ $ fuser -mv `readlink -f /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00`
          zigbee.0
          2023-10-28 17:03:25.648	error	Error herdsman start
          zigbee.0
          2023-10-28 17:03:25.647	error	Failed to start Zigbee
          zigbee.0
          2023-10-28 17:03:25.645	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          zigbee.0
          2023-10-28 17:03:25.306	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
          zigbee.0
          2023-10-28 17:03:25.278	info	Starting Zigbee npm ...
          zigbee.0
          2023-10-28 17:03:25.276	info	Try to reconnect. 1 attempts left
          zigbee.0
          2023-10-28 17:03:15.274	error	Error herdsman start
          zigbee.0
          2023-10-28 17:03:15.273	error	Failed to start Zigbee
          zigbee.0
          2023-10-28 17:03:15.272	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          zigbee.0
          2023-10-28 17:02:54.320	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
          zigbee.0
          2023-10-28 17:02:53.826	info	Starting Zigbee npm ...
          zigbee.0
          2023-10-28 17:02:53.819	info	delete old Backup files. keep only last 10
          zigbee.0
          2023-10-28 17:02:53.634	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
          zigbee.0
          2023-10-28 17:02:50.476	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          ARCHITEKTUR: ARM
          CPUS: 4
          RAM: 3.7 GB
            udev:
              Versionstabelle:
            insgesamt 0
            , als
            anselra
            @meister-mopper said in Zigbee Adapter startet nicht mehr:
            udev:
              Versionstabelle:
            insgesamt 0
            , als
            Hat bei mir leider nichts gebracht, ich kopiere alles immer aus meiner Install doku
            ARCHITEKTUR: ARM
            CPUS: 4
            RAM: 3.7 GB
            • A anselra
              udev:
                Versionstabelle:
              insgesamt 0
              , als
              Kopier es lieber aus der Konsole.
              Wo bei die Meldung bei einem falschen Dateinamen eine andere wäre.
                anselra
                habs nochmal alles neu raus kopiert
                zigbee.0
                2023-10-28 17:14:15.866	error	Error herdsman start
                zigbee.0
                2023-10-28 17:14:15.865	error	Failed to start Zigbee
                zigbee.0
                2023-10-28 17:14:15.863	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                zigbee.0
                2023-10-28 17:14:15.445	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                zigbee.0
                2023-10-28 17:14:15.372	info	Starting Zigbee npm ...
                zigbee.0
                2023-10-28 17:14:15.370	info	Try to reconnect. 1 attempts left
                zigbee.0
                2023-10-28 17:14:05.368	error	Error herdsman start
                zigbee.0
                2023-10-28 17:14:05.367	error	Failed to start Zigbee
                zigbee.0
                2023-10-28 17:14:05.366	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                zigbee.0
                2023-10-28 17:13:44.744	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                zigbee.0
                2023-10-28 17:13:44.178	info	Starting Zigbee npm ...
                zigbee.0
                2023-10-28 17:13:44.173	info	delete old Backup files. keep only last 10
                zigbee.0
                2023-10-28 17:13:43.935	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                zigbee.0
                2023-10-28 17:13:43.564	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                zigbee.0
                2023-10-28 17:13:34.018	info	debug devices set to []
                zigbee.0
                2023-10-28 17:13:33.927	info	terminating
                zigbee.0
                2023-10-28 17:13:33.926	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                zigbee.0
                2023-10-28 17:13:33.923	info	terminating
                zigbee.0
                2023-10-28 17:13:33.922	warn	Failed to stop zigbee during startup
                zigbee.0
                2023-10-28 17:13:33.872	info	Zigbee: disabling joining new devices.
                zigbee.0
                2023-10-28 17:13:33.129	info	cleaned everything up...
                zigbee.0
                2023-10-28 17:13:33.126	info	Got terminate signal TERMINATE_YOURSELF
                zigbee.0
                2023-10-28 17:13:23.941	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100GZZ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100GZZ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03","vendorId":"0451","productId":"bef3"}]
                zigbee.0
                2023-10-28 17:13:23.559	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                ARCHITEKTUR: ARM
                CPUS: 4
                RAM: 3.7 GB
                • A anselra
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  Das ist gerne was aus der Firmware-Ecke.
                  A 2 Antworten Letzte Antwort
                    anselra
                    möchte ungern jetzt was an der Firmware machen, hab noch Sticks die versuche ich mal.
                    melde mich :-)
                    ARCHITEKTUR: ARM
                    CPUS: 4
                    RAM: 3.7 GB
                      anselra
                      na was soll ich sagen, mit dem Zigbee CC2531 USB Dongle geht es mit dem dev Board CC26X2R1 nicht.
                      Mal schauen was für Firmware wo drauf ist falls man das findet
                      ARCHITEKTUR: ARM
                      CPUS: 4
                      RAM: 3.7 GB
                      • A anselra
                        CC26X2R1
                        https://www.zigbee2mqtt.io/guide/adapters/flashing/flashing_via_uniflash.html
                          CC26X2R1
                          anselra
                          update gemacht dev Board CC26X2R1 auf Z-Stack_3.x.0 coordinator 20230507
                          zigbee.0
                          2023-10-28 19:10:12.178	error	Error herdsman start
                          zigbee.0
                          2023-10-28 19:10:12.178	error	Failed to start Zigbee
                          zigbee.0
                          2023-10-28 19:10:12.177	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                          zigbee.0
                          2023-10-28 19:10:11.815	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                          zigbee.0
                          2023-10-28 19:10:11.785	info	Starting Zigbee npm ...
                          zigbee.0
                          2023-10-28 19:10:11.783	info	Try to reconnect. 1 attempts left
                          zigbee.0
                          2023-10-28 19:10:01.781	error	Error herdsman start
                          zigbee.0
                          2023-10-28 19:10:01.780	error	Failed to start Zigbee
                          zigbee.0
                          2023-10-28 19:10:01.779	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                          zigbee.0
                          2023-10-28 19:09:41.317	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                          zigbee.0
                          2023-10-28 19:09:40.896	info	Starting Zigbee npm ...
                          zigbee.0
                          2023-10-28 19:09:40.893	info	delete old Backup files. keep only last 10
                          zigbee.0
                          2023-10-28 19:09:40.708	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                          zigbee.0
                          2023-10-28 19:09:40.385	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                          zigbee.0
                          2023-10-28 19:09:31.457	info	terminating
                          zigbee.0
                          2023-10-28 19:09:31.431	info	debug devices set to []
                          zigbee.0
                          2023-10-28 19:09:31.351	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zigbee.0
                          2023-10-28 19:09:31.350	info	terminating
                          zigbee.0
                          2023-10-28 19:09:31.349	warn	Failed to stop zigbee during startup
                          zigbee.0
                          2023-10-28 19:09:31.285	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2023-10-28 19:09:30.951	info	cleaned everything up...
                          zigbee.0
                          2023-10-28 19:09:30.949	info	Got terminate signal TERMINATE_YOURSELF
                          leider das gleiche Ergebnis
                          Bezeichnung wurde angepasst im Adapter
                          usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GZZ-if00 -> ../../ttyACM0
                          ARCHITEKTUR: ARM
                          CPUS: 4
                          RAM: 3.7 GB
                          • A anselra
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            Meister Mopper
                            Dann solltest du aber diesen Teil -> ../../ttyACM0 abschneiden.
                            Proxmox und HA ...
                              anselra
                              @meister-mopper
                              sorry mein kopierfehler, ist natürlich nicht mit dabei
                              ARCHITEKTUR: ARM
                              CPUS: 4
                              RAM: 3.7 GB
