  4. Sayit Adapter- Probleme nach Update
51 Beiträge 10 Kommentatoren 9.9k Aufrufe 6 Beobachtet
  • DJMarc75D DJMarc75
    @do5tj80 sagte in Sayit Adapter- Probleme nach Update:
    ich habe das Ankündigungston Problem leider auch
    ob Du gewillt bist die Ausgabe von
    iob diag
    hier zu posten ?
    Bitte in Codetags und die Langfassung
    do5tj80
    @djmarc75 said in Sayit Adapter- Probleme nach Update:
    iob diag
    v.2023-10-10
    Static hostname: iobroker
    Icon name: computer-vm
    Chassis: vm
    Virtualization: kvm
    Operating System: Debian GNU/Linux 11 (bullseye)
    Kernel: Linux 5.10.0-16-amd64
    Architecture: x86-64
    Installation: kvm
    Kernel: x86_64
    Userland: amd64
    Timezone: Europe/Berlin (CET, +0100)
    User-ID: 1000
    X-Server: false
    Boot Target: graphical.target
    Pending OS-Updates: 0
    Pending iob updates: 2
    This system needs to be REBOOTED NOW!
    ./diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
    /usr/bin/node v16.20.2
    /usr/bin/npm 8.19.4
    /usr/bin/npx 8.19.4
    /usr/bin/corepack 0.17.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    for more information on how to fix these errors.
    MEMORY:
    total used free shared buff/cache available
    Mem: 4.9G 4.2G 276M 0.0K 485M 513M
    Swap: 11G 1.7G 9.5G
    Total: 16G 5.9G 9.8G
    Active iob-Instances: 58
    Active repo(s): stable
    ioBroker Core: js-controller 5.0.16
    admin 6.12.0
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: jsonl
    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 54381
    States: 44373
    Size of iob-Database:
    63M /opt/iobroker/iobroker-data/objects.jsonl
    12M /opt/iobroker/iobroker-data/states.jsonl
      iob diag
      hier zu posten ?
      do5tj80
      @djmarc75
      Wie komme ich an die Langfassung?
      DJMarc75D bahnuhrB 2 Antworten Letzte Antwort
      • D do5tj80
        @djmarc75
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        indem Du nach der Ausgabe der Langfassung keine Taste drückst und Du dann auch, wie geschrieben, die Langfassung hier in CODETAGS einfügst
        Siehe hier:
        Lehrling seit 1975 !!!
        • D do5tj80
          @djmarc75
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @do5tj80
          das was vorher kam kopieren.
          @Thomas-Braun
          Vielleicht solltest du das wirklich mal umstellen.
          Danke.
          gute Forenbeiträge: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
            do5tj80
            schrieb am zuletzt editiert von do5tj80
            ======== Start marking the full check here =========
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             18:29:23 up 7 days,  3:46,  1 user,  load average: 0.75, 0.84, 0.89
            CPU threads: 4
            This system needs to be REBOOTED!
            *** Time and Time Zones ***
                           Local time: Sun 2023-11-26 18:29:23 CET
                       Universal time: Sun 2023-11-26 17:29:23 UTC
                             RTC time: Sun 2023-11-26 17:29:24
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            thuebner
            /home/thuebner
            thuebner cdrom floppy audio dip video plugdev netdev
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            4.9G        4.1G        357M        0.0K        492M        601M
            Swap:            11G        1.7G        9.5G
            Total:           16G        5.8G        9.8G
                     4933 M total memory
                     4082 M used memory
                     2900 M active memory
                     1305 M inactive memory
                      357 M free memory
                      102 M buffer memory
                      390 M swap cache
                    11215 M total swap
                     1727 M used swap
                     9488 M free swap
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            Filesystem                    Type      Size  Used Avail Use% Mounted on
            udev                          devtmpfs  2.4G     0  2.4G   0% /dev
            tmpfs                         tmpfs     494M  572K  493M   1% /run
            /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
            tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
            tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
            /dev/vda1                     ext2      470M   86M  360M  20% /boot
            tmpfs                         tmpfs     494M     0  494M   0% /run/user/0
            [sudo] password for thuebner:
            Sorry, user thuebner is not allowed to execute '/usr/bin/dmesg -T' as root on iobroker.huebner.local.
            Show mounted filesystems \(real ones only\):
            TARGET  SOURCE                        FSTYPE OPTIONS
            /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
            `-/boot /dev/vda1                     ext2   rw,relatime
            /var:
            Sorry, user thuebner is not allowed to execute '/usr/bin/du -h /var/' as root on iobroker.huebner.local.
            Archived and active journals take up 16.0M in the file system.
            /opt/iobroker/backups:
            101M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            772M    /opt/iobroker/iobroker-data/
            557M    /opt/iobroker/iobroker-data/files
            133M    /opt/iobroker/iobroker-data/backup-objects
            89M     /opt/iobroker/iobroker-data/files/vis-2-beta
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            65M     /opt/iobroker/iobroker-data/objects.jsonl
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
            USB-Devices by-id:
            USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
            *** NodeJS-Installation ***
            ./diag.sh: line 277: nodejs: command not found
            /usr/bin/npm            8.19.4
            /usr/bin/npx            8.19.4
            ./diag.sh: line 288: nodejs: command not found
            nodejs:
              Installed: 16.20.2-deb-1nodesource1
              Candidate: 16.20.2-deb-1nodesource1
              Version table:
             *** 16.20.2-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                 10.24.0~dfsg-1~deb10u1 500
                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
            No problems detected
            Errors in npm tree:
            npm ERR! code ELSPROBLEMS
            npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.6
            npm ERR!     /home/thuebner/.npm/_logs/2023-11-26T17_29_31_386Z-debug-0.log
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.16
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   5
            Adapter State
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
              system.adapter.devices.0                : devices               : iobroker                                 -  enabled
            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
            + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
            + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
            + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
            + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
            + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
            + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
            + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
              system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
            + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
              system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
            + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
              system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
            + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
            + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
            + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
            + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
            + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
            + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
            + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
            + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "bring"        : 1.8.4    , installed 1.8.4
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "device-reminder": 3.0.0  , installed 3.0.0
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
            Adapter    "evcc"         : 0.0.10   , installed 0.0.10
            Adapter    "fronius"      : 2.0.2    , installed 2.0.2
            Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "ical"         : 1.13.3   , installed 1.13.3
            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
            Adapter    "icons-material-png": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "info"         : 2.0.0    , installed 2.0.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.16   , installed 5.0.16
            Adapter    "km200"        : 2.0.3    , installed 2.0.3
            Adapter    "knx"          : 2.0.23   , installed 2.0.23
            Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
            Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "owfs"         : 0.7.0    , installed 0.7.0
            Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
            Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
            Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
            Adapter    "roomba"       : 1.2.2    , installed 1.2.2
            Adapter    "s7"           : 1.3.15   , installed 1.3.15
            Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
            Adapter    "samsung"      : 0.5.11   , installed 0.5.11
            Adapter    "sayit"        : 3.0.5    , installed 3.0.5
            Adapter    "scenes"       : 2.3.9    , installed 2.3.9
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
            Adapter    "sql"          : 2.2.0    , installed 2.2.0
            Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
            Adapter    "synology"     : 3.0.1    , installed 3.0.1
            Adapter    "telegram"     : 2.0.1    , installed 2.0.1
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
            Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
            Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
            Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
            Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "wled"         : 0.7.1    , installed 0.7.1
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
            Objects and States
            Objects:        54381
            States:         44373
            Sorry, user thuebner is not allowed to execute '/usr/bin/apt-get update' as root on iobroker.huebner.local.
            Pending Updates: 0
            *** Listening Ports ***
            Sorry, user thuebner is not allowed to execute '/usr/bin/netstat -tulpen' as root on iobroker.huebner.local.
            2023-11-26 18:30:06.044  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:00:00.000Z","datetype":"date-time","end":"2023-10-24T16:00:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"do5tj80@gmail.com"},"val":"mailto:do5tj80@gmail.com"},"uid":"f79t37oti7bdm0js41njjjgbic@google.com","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.ann@googlemail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.ann@googlemail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/xyu-para-npo","created":"2023-10-23T04:49:38.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/xyu-para-npo\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-23T04:49:40.000Z","location":"Festplatz Gelenau, Ernst-Grohmann-Straße, 09423 Gelenau/Erzgeb., Deutschland","sequence":"0","status":"CONFIRMED","summary":"Altpapiersammlung","transparency":"OPAQUE","method":"PUBLISH"}
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Altpapiersammlung; start:Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Altpapiersammlung at Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:30:00.000Z","datetype":"date-time","end":"2023-10-24T16:30:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"huebner.justus.paul@gmail.com"},"val":"mailto:huebner.justus.paul@gmail.com"},"uid":"A1E9AD76-8D6D-45B2-A4B7-D22ABDCB3D61","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/cdk-spjy-ptp","created":"2023-09-26T14:47:05.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/cdk-spjy-ptp\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-24T01:42:18.000Z","sequence":"1","status":"CONFIRMED","summary":"Bibo Gelenau","transparency":"OPAQUE","APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","method":"PUBLISH"}
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Bibo Gelenau; start:Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit)
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Bibo Gelenau at Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
            2023-11-26 18:30:06.045  - debug: ical.4 (291961) displaying dates because of callback
            2023-11-26 18:30:06.046  - debug: ical.4 (291961) Dates array (data.table): [{"date":"Day After Tomorrow 15:15-16:45","event":"Pippisport","_class":"ical_Tischdienst Justus ical_dayafter","_date":"2023-11-28T14:15:00.000Z","_end":"2023-11-28T15:45:00.000Z","_IDID":"1spa6nra1auon528393aj0gk9n@google.com","_allDay":false,"_private":false,"_rule":" ","location":"Ringerhalle","_calName":"Tischdienst Justus","_calColor":"#186804","_object":{"type":"VEVENT","params":[],"start":"2023-11-28T14:15:00.000Z","datetype":"date-time","end":"2023-11-28T15:45:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","uid":"1spa6nra1auon528393aj0gk9n@google.com","created":"2023-09-28T15:35:00.000Z","lastmodified":"2023-09-28T15:35:00.000Z","location":"Ringerhalle","sequence":"0","status":"CONFIRMED","summary":"Pippisport","transparency":"OPAQUE","method":"PUBLISH"}},{"date":"In 4 days 16:30-17:30","event":"Reiten","_class":"ical_Tischdienst Clara ical_4days","_date":"2023-11-30T15:30:00.000Z","_end":"2023-11-30T16:30:00.000Z","_IDID":"1uksojk6m1bp444avbrev14dgg@google.com","_allDay":false,"_private":false,"_rule":" rrule ","location":"Scharfensteiner Str. 24, 09430 Drebach","_calName":"Tischdienst Clara","_calColor":"#e307ff","_object":{"type":"VEVENT","params":[],"start":"2023-11-30T15:30:00.000Z","datetype":"date-time","end":"2023-11-30T16:30:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"Europe/Berlin","dtstart":"2023-09-07T14:30:00.000Z","freq":2,"byweekday":[{"weekday":3}]},"options":{"freq":2,"dtstart":"2023-09-07T14:30:00.000Z","interval":1,"wkst":0,"count":null,"until":null,"tzid":"Europe/Berlin","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[3],"bynweekday":null,"byhour":[14],"byminute":[30],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-11-26T17:30:05.000Z","uid":"1uksojk6m1bp444avbrev14dgg@google.com","created":"2023-09-08T09:18:39.000Z","lastmodified":"2023-09-08T09:18:39.000Z","location":"Scharfensteiner Str. 24, 09430 Drebach","sequence":"0","status":"CONFIRMED","summary":"Reiten","transparency":"OPAQUE","method":"PUBLISH"}}]
            2023-11-26 18:30:06.137  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
            2023-11-26 18:30:06.138  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
            2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
            2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
            2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 today Tischdienst = false, state = false
            2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 now Tischdienst = false, state = false
            2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 later Tischdienst = false, state = false
            2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 1 null Tischdienst = false, state = false
            2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 2 null Tischdienst = false, state = false
            2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 3 null Tischdienst = false, state = false
            2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 4 null Tischdienst = false, state = false
            2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 5 null Tischdienst = false, state = false
            2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 6 null Tischdienst = false, state = false
            2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 7 null Tischdienst = false, state = false
            2023-11-26 18:30:09.348  - info: ical.3 (291984) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            iob diag has finished.
            • D do5tj80
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              thuebner
              /home/thuebner
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            11G        1.7G        9.5G
                       4933 M total memory
                       4082 M used memory
                        357 M free memory
                        102 M buffer memory
                        390 M swap cache
                      11215 M total swap
                       1727 M used swap
                       9488 M free swap
              *** FILESYSTEM ***
              /var:
              USB-Devices by-id:
              /usr/bin/npm            8.19.4
              /usr/bin/npx            8.19.4
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        54381
              States:         44373
              Pending Updates: 0
              Mach das...
              Zuvor
              iob nodejs-update
                Mach das...
                Zuvor
                iob nodejs-update
                do5tj80
                thuebner@iobroker:~$ iob nodejs-update
                iobroker nodejs-update [<major-version>]
                Upgrade the Node.JS installation to the current LTS
                Options:
                  --help  Show help  [boolean]
                mehr kommt da nicht.
                • D do5tj80
                  Options:
                  @do5tj80
                  iob stop
                  iob fix
                  iob nodejs-update
                  Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
                    @do5tj80
                    iob stop
                    iob fix
                    iob nodejs-update
                    do5tj80
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: vm
                        Virtualization: kvm
                                Kernel: Linux 5.10.0-26-amd64
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
                    CPU threads: 4
                                   Local time: Sun 2023-11-26 18:49:14 CET
                               Universal time: Sun 2023-11-26 17:49:14 UTC
                                     RTC time: Sun 2023-11-26 17:49:15
                                  NTP service: active
                              RTC in local TZ: no
                    thuebner
                    /home/thuebner
                    thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
                    Swap:            11G          0B         11G
                    Total:           16G        3.7G         12G
                             4921 M total memory
                             3693 M used memory
                              159 M active memory
                             3645 M inactive memory
                              816 M free memory
                               50 M buffer memory
                              359 M swap cache
                            11215 M total swap
                                0 M used swap
                            11215 M free swap
                    *** FILESYSTEM ***
                    tmpfs                         tmpfs     493M  540K  492M   1% /run
                    tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
                    [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
                    [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
                    [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
                    [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
                    /var:
                    2.8G    /var/
                    2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
                    2.2G    /var/log
                    382M    /var/cache
                    Archived and active journals take up 32.0M in the file system.
                    754M    /opt/iobroker/iobroker-data/
                    46M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/nodejs         v18.18.2
                    /usr/bin/node           v18.18.2
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    nodejs:
                      Installed: 18.18.2-1nodesource1
                      Candidate: 18.18.2-1nodesource1
                      Version table:
                     *** 18.18.2-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        54381
                    States:         44412
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 https://repos.influxdata.com/debian stable InRelease
                    Hit:3 http://ftp.de.debian.org/debian buster InRelease
                    Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                    Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists... Done
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
                    tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
                    tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
                    tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
                    tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
                    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
                    tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
                    udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
                    udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
                    udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
                    udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
                    udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
                    udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
                    udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
                    udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
                    udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
                    udp6       0      0 :::111                  :::*                                0          11448      1/init
                    2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
                    2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                    2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
                    2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
                    2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                    2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
                    2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
                    2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                    2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
                    2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
                    2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                    2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
                    2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                    • D do5tj80
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: vm
                          Virtualization: kvm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 4
                                    NTP service: active
                                RTC in local TZ: no
                      thuebner
                      /home/thuebner
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            11G          0B         11G
                      Total:           16G        3.7G         12G
                               4921 M total memory
                               3693 M used memory
                                159 M active memory
                                816 M free memory
                                 50 M buffer memory
                                359 M swap cache
                              11215 M total swap
                                  0 M used swap
                              11215 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.8G    /var/
                      2.2G    /var/log
                      382M    /var/cache
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        54381
                      States:         44412
                      Pending Updates: 0
                      @do5tj80
                      Der Eintrag
                      muss raus.
                      Und setz den User auch noch in die Gruppe 'adm'.
                        @do5tj80
                        Der Eintrag
                        muss raus.
                        do5tj80
                        @thomas-braun said in Sayit Adapter- Probleme nach Update:
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                   Chassis: vm
                            Virtualization: kvm
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                         19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
                        CPU threads: 4
                                       Local time: Sun 2023-11-26 19:08:23 CET
                                   Universal time: Sun 2023-11-26 18:08:23 UTC
                                         RTC time: Sun 2023-11-26 18:08:24
                                      NTP service: active
                                  RTC in local TZ: no
                        thuebner
                        /home/thuebner
                        thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.9G        4.0G        502M        0.0K        464M        746M
                        Swap:            11G        308M         10G
                        Total:           16G        4.3G         11G
                                 4921 M total memory
                                 3954 M used memory
                                  475 M active memory
                                 3651 M inactive memory
                                  502 M free memory
                                   29 M buffer memory
                                  434 M swap cache
                                11215 M total swap
                                  308 M used swap
                                10907 M free swap
                        *** FILESYSTEM ***
                        tmpfs                         tmpfs     493M  560K  492M   1% /run
                        /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
                        /var:
                        2.8G    /var/
                        2.2G    /var/log
                        382M    /var/cache
                        Archived and active journals take up 2.1G in the file system.
                        767M    /opt/iobroker/iobroker-data/
                        59M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        54381
                        States:         44373
                        Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                        Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Pending Updates: 0
                        2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
                        2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
                        2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                        2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
                        2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
                        2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
                        2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
                        2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
                        2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
                        2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                        2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
                        2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
                        2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
                        2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                        2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
                        2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
                        2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
                        2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                        2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                        2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                        2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                        in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
                        • D do5tj80
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                     Chassis: vm
                              Virtualization: kvm
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                        NTP service: active
                                    RTC in local TZ: no
                          thuebner
                          /home/thuebner
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            11G        308M         10G
                          Total:           16G        4.3G         11G
                                   4921 M total memory
                                   3954 M used memory
                                    475 M active memory
                                    502 M free memory
                                     29 M buffer memory
                                    434 M swap cache
                                  11215 M total swap
                                    308 M used swap
                                  10907 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.8G    /var/
                          2.2G    /var/log
                          382M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        54381
                          States:         44373
                          Pending Updates: 0
                          @do5tj80
                          Dann würde ich den Arbeitsspeicher anders verteilen.
                          11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
                            @do5tj80
                            do5tj80
                            Ok das schaue ich mir an.
                            Aber generel erst mal Danke , das du so viele Tip's gibst.
                            F 1 Antwort Letzte Antwort
                            • D do5tj80
                              fvp
                              Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
                              Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
                              sayit.0
                              	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              sayit.0
                              	2023-12-12 12:02:29.016	info	Upload announce mp3 files
                              sayit.0
                              	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
                              Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
                              • F fvp
                                sayit.0
                                sayit.0
                                sayit.0
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @fvp
                                Sende erst das mp3
                                und nach x Sek. dann den Text.
                                Dies funktioniert.
                                Danke.
                                • F Offline
                                  fvp
                                  @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                                  • F fvp
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @fvp sagte in Sayit Adapter- Probleme nach Update:
                                    Man muss halt auch mal die Hilfe der Adapter lesen.
                                    Bringt manchmal Erleuchtung.
                                    Denn da steht alles was du gerade suchst.
                                    Danke.
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      per js so:
                                      setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                                      setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                                      Danke.
                                      F D 3 Antworten Letzte Antwort
                                      • bahnuhrB bahnuhr
                                        per js so:
                                        fvp
                                        @bahnuhr
                                        Erstmal vielen Dank für den Code.
                                        Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                                        In der Hilfe steht hier
                                        sayit.N.tts.text: Phrase to be spoken.
                                        Hast du den Ankündigungston im Adapter abgeschaltet ?
                                        Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                                        • bahnuhrB bahnuhr
                                          per js so:
                                          fvp
                                          @bahnuhr
                                          Ich habe deinen Tipp gerade ausprobiert.
                                          Als Workaround kann man das so machen.
                                          Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                                                  // place as first the announcement mp3
                                                  tasks.push({
                                                      text: announce,
                                                      language,
                                                      volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                                      ts: task.ts,
                                                      testOptions
                                                  // and then text
                                                  tasks.push(task);
