  3. Off Topic
  4. Raspberry Pi stürtzt ab mit Echarts
    6.0k
66 Beiträge 7 Kommentatoren 4.8k Aufrufe 5 Beobachtet
  • DuffyD Duffy
    Sagt:
    TestPi2@raspberrypi:~ $ sudo apt update && apt policy influxdb2*
    Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
    Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB]
    Fetched 694 kB in 2s (418 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    influxdb2-cli:
      Installed: 2.7.3-1
      Candidate: 2.7.3-1
      Version table:
     *** 2.7.3-1 500
            500 https://repos.influxdata.com/debian stable/main arm64 Packages
            100 /var/lib/dpkg/status
         2.7.1-2 500
         2.6.1 500
         2.6.0 500
         2.5.0 500
         2.4.0 500
         2.3.0 500
    influxdb2-client:
      Installed: (none)
      Candidate: 2.7.1-1
      Version table:
         2.7.1-1 500
    influxdb2:
      Installed: 2.7.1-1
      Candidate: 2.7.1-1
      Version table:
     *** 2.7.1-1 500
         2.7.0-1 500
         2.6.1-1 500
         2.6.0-1 500
         2.5.1-1 500
         2.4.0-1 500
         2.3.0-1 500
         2.2.0 500
    Damals hatte ich mir folgendes notiert:
    Installation von InfluxDB2
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    sudo apt update
    Sudo apt full-upgrade (optional)
    sudo apt install influxdb2
    sudo service influxdb start
    sudo service influxdb status
    Wird benötigt für Backitup Adapter:
    sudo apt update
    sudo apt install influxdb2-client
    Aufrufen der Oberfläche über: http://ip-des pi:8086
    z.B. http://192.168.178.25:8086
    War das auch schon wieder falsch 😕
    #41
    @duffy
    Passt.
    Auch wenn ich für mein System vermutlich das Paket
    influxdb2-client
    vorziehen würde, das passt von der Versionsnummer her besser zu influxdb2
    DuffyD 1 Antwort Letzte Antwort
      @duffy
      Passt.
      influxdb2-client
      DuffyD Offline
      DuffyD Offline
      Duffy
      #42
      @thomas-braun sagte in Raspberry Pi stürtzt ab mit Echarts:
      Passt.
      Aber es kommt ja trotzdem ein Fehler.
      wie würde das dan korrekt aussehen:
      sudo apt update
      sudo apt update
      Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
      Node.js: v22.23.2
      NPM: 10.9.4
      js-controller 7.1.2
      Linux: Trixie
      • DuffyD Duffy
        Passt.
        sudo apt update
        sudo apt update
        #43
        @duffy sagte in Raspberry Pi stürtzt ab mit Echarts:
        Nein, das ist kein Fehler.
        In beiden Paketen ist das von Backitup benötigte Programm enthalten.
        Kannst dir eins aussuchen.
        sudo apt remove influxdb2-cli
        wenn du influxdb2-client haben willst. Ansonsten lass es einfach so.
        • DuffyD Duffy
          Sagt:
          influxdb2-cli:
            Installed: 2.7.3-1
            Candidate: 2.7.3-1
            Version table:
           *** 2.7.3-1 500
               2.7.1-2 500
               2.6.1 500
               2.6.0 500
               2.5.0 500
               2.4.0 500
               2.3.0 500
          influxdb2-client:
            Installed: (none)
            Candidate: 2.7.1-1
            Version table:
               2.7.1-1 500
          influxdb2:
            Installed: 2.7.1-1
            Candidate: 2.7.1-1
            Version table:
           *** 2.7.1-1 500
               2.7.0-1 500
               2.6.1-1 500
               2.6.0-1 500
               2.5.1-1 500
               2.4.0-1 500
               2.3.0-1 500
               2.2.0 500
          sudo apt update
          sudo apt update
          #44
          Sagt:
          Moin,
          Was wird das hier? Ich dachte, es geht hier um Absturz bei eCharts Nutzung, jetzt sind wir über orphaned Inodes hin zu wie installiere ich influxDB, alles sehr verwirrend.
          Da ich hier nicht mehr mit komme, bin ja auch nicht mehr der jüngste ;) Hier mal mein letzter Kommentar.
          Was auch immer Du auf dem TestPi wie neu eingerichtet hast, da waren die Quellen für influxDB schon korrekt gesetzt und warum auch immer, das kannst nur Du Wissen, war da auch schon ein Paket influxDB2-cli installiert, daher kann er das andere Paket influxDB-Client nicht installieren, da im Pfad schon ein Programm, mit demselben Namen liegt, ist wie bei Reise nach Jerusalem, wenn da schon einer auf dem Stuhl sitzt, kann da kein zweiter sitzen :)
          Wenn Du einmal das Repository eingerichtet hast, musst Du das nicht immer wieder machen, es sei denn, influxDB ändert seinen Key, dann muss man da was anpassen.
          Also das ist nur einmalig auszuführen:
          Ja der BackitUp Adapter braucht eins der Pakete, entweder influxDB2-cli oder influxDB2-Client beide gehen nicht siehe oben mit Reise nach Jerusalem.
          VG
          Bernd
            Sagt:
            Moin,
            VG
            Bernd
            DuffyD Offline
            DuffyD Offline
            Duffy
            #45
            @dp20eic @thomas-braun
            Fehler gefunden.
            Ich habe wie schon so oft wieder alles von vorne Installiert.
            Dabei habe ich gesehen das bei der Installation von Influxdb auch schon der influxdb2-cli mit installiert wurde.
            Dann ist klar, wenn man weis das der influxDB-Client was ähnliches ist, das nicht geht. Werde wohl meine Anleitung entsprechend modifizieren müssen.
            Hoffe das ich bei der Grafana installation nicht auch noch auf für mich unüberwindbare Hürden treffe.
            So weit erst mal vielen Dank.
            Node.js: v22.23.2
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
            • DuffyD Duffy
              Fehler gefunden.
              #46
              die eine hast du doch auch überwunden!
              dann ist das aber sehr wahrscheinlich influxdb v2
                DuffyD Offline
                DuffyD Offline
                Duffy
                #47
                @homoran sagte in Raspberry Pi stürtzt ab mit Echarts:
                Ja, 👍
                Node.js: v22.23.2
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
                  Aber hätte ich eine andere Möglichkeit gehabt ausser Stromlos machen?
                  Den 'Linux-Affengriff'. Gibt u. a. eine Wikipedia-Eintrag dazu.
                  DuffyD Offline
                  DuffyD Offline
                  Duffy
                  #48
                  So, habe nun mein Kabel bekommen und eine Taststur angesteckt.
                  Auf dem Bildschirm erscheint auch was 👍
                  Jetzt vorab meine Frage um auf den Erststfall vorbereitet zu sein.
                  Wenn der Pi hängt, strg Alt Entf drücken und er düst wieder los?
                  Habe es mal so verucht und er hat es auch gemacht., aber ist das fachlich korrekt?
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  • ? Offline
                    #49
                    Moin,
                    hier mal das, was das WWW dazu sagt → https://de.wikipedia.org/wiki/Klammergriff
                    Ich hätte mir, anstatt eine Tastatur, an den RasPI zu hängen, lieber einen Button/Taster an die GPIO geklemmt, und dann damit entweder einen Hard Reset ausgelöst, ist dann nichts anderes als wenn man den Stecker zieht, oder besser einen Soft Reset, das entspricht dem Klammergriff <-> Affengriff, hier mal eine Beschreibung → https://pi-buch.info/die-fehlende-reset-taste/
                    VG
                    Bernd
                    P.S.: Wenn Dein RasPI sich so aufgehängt hat, dass auch der Kernel nicht mehr reagiert, dann hilft Dir die Tastatur nicht mehr, denn dann werden die Tastendrücke nicht mehr empfangen, dann hilft doch wieder nur ein Hard Reset!
                      Moin,
                      VG
                      Bernd
                      DuffyD Offline
                      DuffyD Offline
                      Duffy
                      #50
                      @dp20eic
                      Hallo Bernd,
                      ich habe hier schon genug Probleme da muss ich mir nicht noch zusätzliche einhandeln indem ich am Raspberry rummfummle 😖
                      Werde es nach dem nächsten Absturz sehen was passiert.
                      Wobei Knopf in so fern schön wäre, das ich nicht erst dem Monitor zum Pi schleppen muss
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                      • DuffyD Duffy
                        #51
                        Nein, der 'Klammergriff' geht anders (hängt auch von der Tastatur ab). Steht aber im Wikipedia-Eintrag glaube ich alles drin.
                        Die Grundtechnik ist aber
                        AltGr + R
                        AltGr + E
                        AltGr + I
                        AltGr + S
                        AltGr + U
                        AltGr + B
                        Merksatz: Raising Elephants Is So Utterly Boring
                          AltGr + R
                          AltGr + E
                          AltGr + I
                          AltGr + S
                          AltGr + U
                          AltGr + B
                          DuffyD Offline
                          DuffyD Offline
                          Duffy
                          schrieb am zuletzt editiert von Duffy
                          #52
                          Hintereinander?
                          In Wiki steht halt auch strg alt entf oder ist die Methode zu hart?
                          Node.js: v22.23.2
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
                          • DuffyD Duffy
                            Hintereinander?
                            #53
                            @duffy
                            Die 6 Tastenkombinationen hintereinander mit ein paar Sekunden Abstand eingeben. Dann werden die einzelnen Dinge, die für einen sauberen Rebott erforderlich sind (inkl. Schreiben der offenen Dateien) durchgeführt.
                            S = Sync
                            U = Umount
                            B = Boot
                            Was die ersten drei Kombinationen machen weiß ich aus dem Kopf aber nicht.
                              @duffy
                              S = Sync
                              U = Umount
                              B = Boot
                              DuffyD Offline
                              DuffyD Offline
                              Duffy
                              #54
                              @Thomas-Braun
                              Es hat sich etwas getan zum Thema Raspberry Pi stürzt ab mit Echarts"
                              Ich habe inzwischen die Fehlerquelle ausmachen können. Es ist der Datenpunkten von InfluxDB denn es kam im Protokoll folgender Fehler:
                              influxdb.0
                              	2023-11-19 12:51:54.321	warn	Error in query "from(bucket: "iobroker-data") |> range(start: 2022-11-12T12:00:00.000Z, stop: 2023-11-12T11:59:59.999Z) |> filter(fn: (r) => r["_measurement"] == "Luftentfeuchter") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns: ["_time"], desc: true) |> limit(n: 1)": RequestTimedOutError: Request timed out
                              influxdb.0
                              	2023-11-19 12:51:54.318	warn	Error in query "from(bucket: "iobroker-data") |> range(start: 2022-11-12T12:00:00.000Z, stop: 2023-11-12T11:59:59.999Z) |> filter(fn: (r) => r["_measurement"] == "Luftentfeuchter") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns: ["_time"], desc: true) |> limit(n: 1)": RequestTimedOutError: Request timed out
                              influxdb.0
                              Nachdem ich den Datenpunkt gelöscht und neu angelegt habe funktioniert auch wieder Echarts ohne Abstürze.
                              Jetzt habe ich in dem Bucket noch weitere Datenpunkte die ich nur ungerne löschen würde und deshalb die Frage an die Experten ob man bei den fehlerhaften Datenpunkten etwas korrigieren kann?
                              Bei Grafana machen die Datenpunkte übrigens keine Probleme.
                              VG Duffy
                              Node.js: v22.23.2
                              NPM: 10.9.4
                              js-controller 7.1.2
                              Linux: Trixie
                              ? Marc BergM 2 Antworten Letzte Antwort
                              • DuffyD Duffy
                                @Thomas-Braun
                                influxdb.0
                                influxdb.0
                                influxdb.0
                                VG Duffy
                                #55
                                Moin,
                                ich sehe da keinen Fehler, dass was Dir da gemeldet wird ist ein Warning also eine Warnung, und das es zu einem Timeout beim Request = der Abfrage gekommen ist.
                                Das kann aber mehrere Ursachen haben, zu viele Daten für den gewählten Zeitraum
                                Oder einfach die Netzwerkverbindung ioBroker <-> influxDB war/ist schlecht, wenn es lokal auf der Maschine läuft, kann auch ein anderer I/O schuld sein.
                                Wenn Du diese Abfrage mal in Grafana machst, was kommt denn da für eine Zahl an Datensätzen raus?
                                  |> group()
                                  |> limit(n: 1)
                                VG
                                Bernd
                                  Moin,
                                    |> group()
                                    |> limit(n: 1)
                                  VG
                                  Bernd
                                  DuffyD Offline
                                  DuffyD Offline
                                  Duffy
                                  #56
                                  @dp20eic sagte in Raspberry Pi stürtzt ab mit Echarts:
                                  Guten Abend,
                                  ich bring das leider nicht mit grafana und der Abfrage.
                                  Bin ich hier richtig?
                                  Ich vermute mal nicht.
                                  Wenn ich es in influxDB eintrage kommt auch nichts. vermutlich auch falsch.
                                  Das mit der Datenmenge hatte ich mir auch schon mal überlegt aber der Raspberry bzw Echarts hat auch bei einer Abfrage von 1 Tag den Dienst eingestellt.
                                  Gruß Duffy
                                  Node.js: v22.23.2
                                  NPM: 10.9.4
                                  js-controller 7.1.2
                                  Linux: Trixie
                                  ? 2 Antworten Letzte Antwort
                                  • DuffyD Duffy
                                    Guten Abend,
                                    Gruß Duffy
                                    #57
                                    Moin,
                                    Ja, ist aber wohl mein Fehler, denn Du hast ja gesagt, dass Du da irgendwas gelöscht hast, daher kann es sein, dass dann natürlich mit dem _measurement -> Luftfeuchte nichts mehr kommt.
                                    Zumal ich gerade geschaut habe, das mit limit(1) beschränkt das Ergebnis auf 1 also das letzte Ergebnis
                                    Description:
                                    Limits each output table to the first `n` records, excluding the offset.
                                    Arguments
                                               n:Integer
                                               The maximum number of records to output.
                                               offset:Integer
                                               The number of records to skip at the beginning of a table before limiting to `n`. Defaults to `0`.
                                    Example
                                    |> limit(n:10, offset: 0)
                                    Nein, aber das gleiche Problem, Du hast ja Luftfeuchte gelöscht.
                                    • DuffyD Duffy
                                      Guten Abend,
                                      Gruß Duffy
                                      #58
                                      Moin,
                                      schau mal auf Github -> https://github.com/ioBroker/ioBroker.echarts/issues nach, es scheint, sieht so aus, als ob es Probleme mit eChart gibt.
                                      Wie viel RAM hast Du denn noch frei auf dem RasPI, während Du da was her herumspielst, lass mal parallel ein Terminal mit top mitlaufen, und schau mal wie sich der RAM verhält.
                                      VG
                                      Bernd
                                        Moin,
                                        Description:
                                        Arguments
                                                   n:Integer
                                                   offset:Integer
                                        Example
                                        DuffyD Offline
                                        DuffyD Offline
                                        Duffy
                                        #59
                                        @dp20eic
                                        Also bei Luftfeuchte konnte er nichts mehr finden in dem genanten Zeitraum weil da nichts mehr war.
                                        Aber es sit ja auch abgestürzt bei meiner mini PV.
                                        Da hat die Abfrage das ergeben, es hab aber nur ein ERgebnis vermutlich wegen dem limit(1) wie du ja schon geschreiben hattest.
                                        MIt |> limit(n:10, offset: 0) schauts so aus.
                                        Node.js: v22.23.2
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                          Moin,
                                          VG
                                          Bernd
                                          DuffyD Offline
                                          DuffyD Offline
                                          Duffy
                                          #60
                                          @dp20eic
                                          "schau mal auf Github -> https://github.com/ioBroker/ioBroker.echarts/issues nach, es scheint, sieht so aus, als ob es Probleme mit eChart gibt."
                                          Aktuell hat mein Pi 8 GB Ram. Die Anzeige des verwendeten Ram war ja mal, ich glaube bei Informationen oder Übersicht im IOB.
                                          Da ist es aber nicht mehr.
                                          Ich kann ja ohnehin den Ram beim Pi nicht aufrüsten.
                                          Ich denke ich verwende einfach Grafana und lasse es mit Echarts. (Bzw. nutze es halt hier und da wo es funktioniert. Ist eh eher eine Spielerrei weil ich mir über ein Blockly immer Bilder meiner PV Produktion und der Temperatur/Feuchtigkeit Keller schicken lasse.
                                          "Wie viel RAM hast Du denn noch frei auf dem RasPI, während Du da was her herumspielst, lass mal parallel ein Terminal mit top mitlaufen, und schau mal wie sich der RAM verhält."
                                          Da weis ich doch auch schon wieder nicht wie das geht und will auch keinen mehr nerven wegen eher unwichtigen Dingen die ich auch alternativ lösen kann.
                                          Danke dennoch für die viele Mühe.
                                          Viele Grüße Duffy
                                          Node.js: v22.23.2
                                          NPM: 10.9.4
                                          js-controller 7.1.2
                                          Linux: Trixie
                                          ? 1 Antwort Letzte Antwort
