  4. SayIT probleme mit der Wiedergabe
54 Beiträge 8 Kommentatoren 7.7k Aufrufe 7 Beobachtet
    A1uca2d
    Hi Leute,
    meine Google Assistant Lautsprecher (JBL Link Portable & Google-Mini) geben meine Eingaben nicht mehr ab.
    Hier derAuszug aus dem Log:
    sayit.2
    2023-08-24 09:53:24.478	error	Cannot play file: Timeout by checking of announcement finished playing
    sayit.2
    2023-08-24 09:53:24.477	error	Error while checking if chromecast.0.b02a432175c1.player.announcement finished playing announcement: {"url":"http://192.168.1.149:8082/sayit.2/tts.mp3?ts=1692863593968","volume":70}: TIMEOUT
    chromecast.0
    2023-08-24 09:53:23.749	info	Büro-Mini - Detached player
    chromecast.0
    2023-08-24 09:53:23.705	info	{"appId":"CC1AD845","appType":"WEB","displayName":"Default Media Receiver","iconUrl":"","isIdleScreen":false,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.media"}],"sessionId":"42427740-9806-4a4b-938c-253e12ccec41","statusText":"Default Media Receiver","transportId":"42427740-9806-4a4b-938c-253e12ccec41","universalAppId":"CC1AD845"}
    chromecast.0
    2023-08-24 09:53:17.025	error	Büro-Mini - Could not play announcement: Error: Error: connect EHOSTUNREACH 192.168.1.149:8082
    chromecast.0
    2023-08-24 09:53:17.025	error	Büro-Mini - Error playing playlist - Error: Error: connect EHOSTUNREACH 192.168.1.149:8082 at ClientRequest.<anonymous> (/opt/iobroker/node_modules/castv2-player/lib/mediaInfo.js:81:98) at ClientRequest.emit (node:events:514:28) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:514:28) at emitErrorNT (node:internal/streams/destroy:151:8) at emitErrorCloseNT (node:internal/streams/destroy:116:3) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
    chromecast.0
    2023-08-24 09:53:17.024	info	Büro-Mini - Closing mediaInfo
    chromecast.0
    2023-08-24 09:53:13.970	info	Büro-Mini - Try to play url - http://192.168.1.149:8082/sayit.2/tts.mp3?ts=1692863593968
    chromecast.0
    2023-08-24 09:53:13.970	info	Büro-Mini - setting volume to same value 70 - ignored
    chromecast.0
    2023-08-24 09:53:13.969	info	Büro-Mini - Try to play announcement - "http://192.168.1.149:8082/sayit.2/tts.mp3?ts=1692863593968"
    Meister MopperM Horst BöttcherH 2 Antworten Letzte Antwort
    • A A1uca2d
      Hi Leute,
      sayit.2
      sayit.2
      chromecast.0
      chromecast.0
      chromecast.0
      chromecast.0
      chromecast.0
      chromecast.0
      chromecast.0
      chromecast.0
      Meister MopperM Online
      Meister Mopper
      @a1uca2d
      Hatte ich kürzlich auch. Halt mal den chromecast Adapter an, lösche alle Chromecast Objekte und starte den Adapter wieder.
      Sollten die Geräte dann noch immer stumm sein, solltest du die Sprachbefehle nicht mit sayit absetzen, sondern die entsprechenden Datenpunkte befüllen.
      i. e.
      Proxmox und HA ...
      A 1 Antwort Letzte Antwort
        @a1uca2d
        i. e.
        A1uca2d
        @meister-mopper
        Danke dir für die schnelle Hilfe.
        ich habe jetzt versucht SayIT zu umgehen.
        Aber wie bekomme ich das mit einer individuellen Sprachausgabe trotzdem hin? Bei meinen Chromecast Objekten finde ich kein "Text to Speech" oder so?
        Zum Testen habe ich jetzt eine mp3 URL aus dem Internet genommen und die im Json für Ansagen (chromecast.0.b02a432175c1.player.announcement) eingefügt. Dann spielt er den Ton auch ab. Also Chromecast läuft!
        • A A1uca2d
          @meister-mopper
          Meister Mopper
          @a1uca2d
          Das Objekt findest du in der jeweiligen sayit Instanz.
          Proxmox und HA ...
            @a1uca2d
            A1uca2d
            @meister-mopper
            OK. Das läuft bei mir irgendwie nicht. Egal welchen tts Anbieter ich wähle.
            Da kommt auch mein erster log Auszug her.
            • A A1uca2d
              @meister-mopper
              Meister Mopper
              @a1uca2d sagte in SayIT probleme mit der Wiedergabe:
              Was für ein Anbieter?
              Da musst du es reinschreiben
              Proxmox und HA ...
                A1uca2d
                @meister-mopper
                Ich habe es über die Cloud und Google probiert. Bei beiden das gleiche Problem.
                Ich nutzte bereits von Anfang an die Möglichkeit das Text to speech Objekt zu adressieren, da ich in Javascript arbeite und nicht mit blocky.
                • A A1uca2d
                  @meister-mopper
                  maxpd
                  @a1uca2d Ich habe exakt das gleiche Problem. Hast du eine Lösung gefunden?
                  maxpd
                  Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
                  • A A1uca2d
                    Hi Leute,
                    sayit.2
                    sayit.2
                    chromecast.0
                    chromecast.0
                    chromecast.0
                    chromecast.0
                    chromecast.0
                    chromecast.0
                    chromecast.0
                    chromecast.0
                    Horst BöttcherH Offline
                    Horst Böttcher
                    schrieb am zuletzt editiert von Horst Böttcher
                    Ich schliesse mich mal an
                    Wenn ich im Sayit adpter auf Test klicke kommt ton an
                    Es über Blockly kommt nicht bei Goolge an .-(
                    Es steht leider nix im log
                    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                    • crunchipC Offline
                      crunchipC Offline
                      ich hab generell nach wie vor da Problem das der google hin und wieder stumm bleibt
                      daher starte ich die chromecast Instanz regelmäßig (alle 3 Std) neu
                      sollte es dennoch mal dazu komme, das keine Ausgabe mehr erfolgt, schafft bei mir nur Abhilfe, in den Objekten den google home zu löschen und Instanz neu zu starten, danach funktioniert wieder alles wie gewohnt für ne Zeitlang
                      H 1 Antwort Letzte Antwort
                        maxpd
                        @crunchip ok, der neustart vom chromecast scheint das timeoutpoblem zu lösen. Wenn 1x Nachts nicht ausreicht, werde ich per JS dann neu starten, wenn aktuell nichts auf einem Chromecast läuft.
                        maxpd
                        • M maxpd
                          crunchipC Offline
                          crunchipC Offline
                          @maxpd bei mir trat das Problem des Öfteren innerhalb von 6 Stunden auf, daher starte ich alle 3 Stunden aktuell
                          Meister MopperM M 2 Antworten Letzte Antwort
                            Meister Mopper
                            schrieb am zuletzt editiert von Meister Mopper
                            @crunchip sagte in SayIT probleme mit der Wiedergabe:
                            Das mache ich mittlerweile auch.
                            Nach Aussage meiner Frau gilt diese Lösung als Beispiel für das fünfte (Not)rad der Informatiker. :man-shrugging:
                            Proxmox und HA ...
                              crunchipC Offline
                              crunchipC Offline
                              @meister-mopper ja mei, wenns aktuell nicht anders geht, was will man machen
                                Meister Mopper
                                was will man machen
                                Da machste nüscht 😊
                                Proxmox und HA ...
                                  maxpd
                                  @crunchip ok, habe mir dann einen reboot gebaut, der alle 3h stattfindet, sofern kein chromecast etwas am abspielen ist.
                                  maxpd
                                    maxpd
                                    @maxpd Theoretisch könnte man mit einem JS auch Nachts einmal alle Datenpunkte des Chromecast löschen, Sekunden bevor ein Neustart des Adapters stattfindet und diese dann neu gebaut werden, oder?
                                    Löscht ihr dann komplett den Order "0"?
                                    Also bislang kamen Ansagen, aber manchmal mit einem Versatz von bis zu mehreren Minuten nach dem Ankündigungs-Dong. Warum die Ausgabe nicht direkt kommt, sagt mir aber auch das Log nicht.
                                    Und die Lautstärke ändert sich während der Sprachausgabe bei einer Gruppe von 100 auf .
                                    maxpd
                                    • M maxpd
                                      maxpd
                                      Das Löschen der Datenpunkte und Neustarten des Adapters löst zudem folgendes Problem nicht, welches am meisten nervt.
                                      Doppelte Sprachausgabe, bzw. Abspielen eines alten Files, obwohl auf dem iobroker schon eine neue MP3 liegt. Mein Test hierzu, der auch Queues löscht und alte Files aktiv löscht. Auch größere Abstände von 30 Sekunden helfen nicht. Es wird immer "Test 1" ausgegeben. Debug Ausgaben geben Test 2 und Test 3 währenddessen aus.
                                      Was kann ich noch versuchen?
                                      Leider kann Sayit keinen Pause Befehl, sodass wenn ich alles in eine Sprachausgabe packe, diese halt runterrasselt ohne kurze Pausen einzulegen. Bei längeren Ansagen am Morgen für die Tagesplanung unpraktisch.
                                      maxpd
                                      crunchipC 2 Antworten Letzte Antwort
                                      • M maxpd
                                        crunchipC Offline
                                        crunchipC Offline
                                        @maxpd mach mal den Haken rein bei mit Ergebnissen
                                        Dann wir der darunterliegende Befehl erst abgearbeitet wenn der exec Befehl ausgeführt wurde
                                          maxpd
                                          schrieb am zuletzt editiert von maxpd
                                          @crunchip Du meinst ich soll Text to Speech in die neue Klammer des exec Befehls einsetzen?
                                          Ich bin mir nicht sicher, ob das der richtige Weg ist.
                                          Also die Datei wird nach obigem Aufbau wirklich gelöscht, das habe ich geprüft. Und der darunterliegende Text to speech Befehl auch ausgeführt. Denn es befindet sich auf dem iobroker Server nach dem Löschvorgang eine neue mp3, die Test 2 spricht. Hierzu habe ich großzügige Pausen zwischen die einzelnen Schritte gebaut, um deren Abarbeitung zu prüfen. Die neue mp3, wird auch als Abspielpfad dem Chromecast übergeben.
                                          Trotzdem ist die Ausgabe über den Chromecast Test 1. Sodass irgendwas irgendwo gecacht werden muss.
                                          maxpd
