  5. [gelöst] Skriptfehler nach iobroker Update
18 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    mwolle
    schrieb am zuletzt editiert von mwolle
    Hallo zusammen, ich habe mein iobroker mal auf den neusten Stand gebracht:
    js-controller = 5.0.8
    npm = 9.5.1
    node 18.6.1
    javaskript Adapter = 7.1.1
    Seit dem bekomme ich aber diese Fehlermeldung, obwohl die States mit Values da sind:
    2023-07-24 23:00:00.025 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc2.activeSwitchProgram" not found
    2023-07-24 23:00:00.027 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
    2023-07-24 23:00:00.028 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:43:6)
    2023-07-24 23:00:00.028 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
    2023-07-24 23:00:00.029 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
    2023-07-24 23:00:00.029 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc1.activeSwitchProgram" not found
    2023-07-24 23:00:00.030 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
    2023-07-24 23:00:00.031 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:44:6)
    2023-07-24 23:00:00.031 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
    2023-07-24 23:00:00.032 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
    2023-07-24 23:00:00.032 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc2.temperatureLevels.high" not found
    2023-07-24 23:00:00.033 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
    2023-07-24 23:00:00.034 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:57:11)
    2023-07-24 23:00:00.034 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
    2023-07-24 23:00:00.035 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
    2023-07-24 23:00:00.035 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc1.temperatureLevels.high" not found
    2023-07-24 23:00:00.038 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
    2023-07-24 23:00:00.038 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:58:11)
    2023-07-24 23:00:00.039 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
    2023-07-24 23:00:00.039 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
    2023-07-24 23:00:00.040 - info: javascript.0 (2968) script.js.common.Heizprogram_dyn: 24
    2023-07-24 23:00:00.041 - warn: javascript.0 (2968) getState "km200:heatingCircuits.hc2.activeSwitchProgram" not found (3)
    2023-07-24 23:00:00.043 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:65:15)
    2023-07-24 23:00:00.043 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
    2023-07-24 23:00:00.044 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
    ich kann nicht so das Problem nachvollziehen...es hat ja auch vorher alles funktioniert.
    HomoranH arteckA 2 Antworten Letzte Antwort
    • M mwolle
      npm = 9.5.1
      node 18.6.1
      @mwolle sagte in Skriptfehler nach iobroker Update:
      ist eine Version für Beta-Tester
      bitte in den entsprechenden Beta-Tester Threads melden
      und sollte es Windows sein, bitte solche Informationen in den Eröffnungspost oder in den Threadtitel
      • M mwolle
        npm = 9.5.1
        node 18.6.1
        arteckA Offline
        arteckA Offline
        arteck
        zeigmal im screenshot diesen Datenpunkt
        @Homoran hat nix mit js-controller zu tun
        • arteckA arteck
          mwolle
          @arteck
          • M mwolle
            @arteck
            ticaki
            @mwolle
            im Screenshot fehlt "km200:heatingCircuits." und das wohl fehlende "0." oder "javascript.0."
            Spenden
            • T ticaki
              @mwolle
              mwolle
              @ticaki hier noch mal von hc1, der Pfad sieht für mich vollständig aus:
              javascript.0 ist die Instanz
              • M mwolle
                arteckA Offline
                arteckA Offline
                arteck
                @mwolle wo ist der knoten davor ??
                km200: heatingCircuits.hc2.activeSwitchProgram
                zeigmal das getState von dem Datenpunkt im Script.. oder zeig das Script mal
                • arteckA arteck
                  mwolle
                  @arteck der ganze Pfad sieht so aus. Der Adapter liest zwei Geräte aus, die dann in separaten Pfaden da gestellt werden, EMS-ESP und km200
                  • M mwolle
                    arteckA Offline
                    arteckA Offline
                    arteck
                    zeigmal das Script
                    • arteckA arteck
                      zeigmal das Script
                      mwolle
                      @arteck ist etwas unaufgeräumt...
                      //createState("javascript.0.Merker_Heizleistung", 0, {
                      //    name: "Merker_Heizleistung",
                      //    type: 'int'
                      on({
                          change: "ne"
                      }, async function (obj) {
                          var Element2 = (getState("javascript.0.Merker_Heizleistung").val);
                          // var Element3;
                          var Counterschleife = 0;
                          var Leistungswert2 = 41; // (getState("km200.0.heatSources.actualModulation").val);
                          var Heat_on = (getState("km200:heatSources.hs1.flameStatus").val);
                          var WWtemperatur = (getState("ems-esp.0.dhwCircuits.dhw1.wwcurtemp").val);
                          var Leistungswert = (getState("km200:heatSources.hs1.burnerModulationSetpoint").val);
                          var Brennerstarts = (getState("javascript.0.minutenZwischenBrennerStarts").val);
                          var actualPower = (getState("km200:heatSources.hs1.actualPower").val);
                          // var Raumtemperatur = (getState("fritzdect.0.DECT_116300132384.celsius").val);
                          // Weitere Prüfung auf Heizprogramm, Programm soll nur laufen, wenn Heizung aktiv ist
                             var Zeit = new Date();
                              var Stunden = Zeit.getHours();
                              var Minuten = Zeit.getMinutes();
                              var Minuten_Tag = (Stunden * 60) + Minuten;
                              var temp = 360; //Heizprogramm_E[703]; // 300 Minuten ab Mitternacht -> 5 Uhr
                              var temp_2 = 1200; //Heizprogramm_E[45]; // 1200 Minuten ab Mitternacht -> 20 Uhr geht Heizung aus
                      console.log(WWtemperatur);
                      console.log(Leistungswert);
                      console.log(actualPower);
                      console.log(Leistungswert2);
                          if (actualPower <= Leistungswert && actualPower <= Leistungswert2 && WWtemperatur < 41){ // Prüfen ob Leistung für Warmwasser ist
                              //if (Heat_on == 0) { //Prüfen ob Heizung an ist
                              //Counterschleife = 1;
                                 if (Minuten_Tag > temp && Minuten_Tag < temp_2) {
                              // Prüfung, ob Heizung Taktet, wenn ja, Heizleistung um 2 verringern.
                                    if (Brennerstarts <= 30) {
                                  Element2 += 1;
                                  setState("javascript.0.Merker_Heizleistung", (Element2),true);
                                  Counterschleife = 2;
                                    } else {
                                  Element2 = 0;
                                  Counterschleife = 3;
                              if (Element2 >= 2){
                                  //setState("ems-esp.0.heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 5, true);
                                       setState("km200:heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 1, true);
                                       setState("km200:heatingCircuits.hc1.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 1, true);
                                  Element2 = 0;
                                  setState("javascript.0.Merker_Heizleistung", (Element2),);
                              Counterschleife = 4;
                                  sendTo("whatsapp-cmb", "send", {
                                   text: 'Heizung ausgeschaltet. Folgende Parameter:' + (Brennerstarts) +' Minuten Brennerstarts und ' + (actualPower) + ' Heizung an'
                         // console.log(Heat_on);
                         // console.log(Minuten_Tag);
                         // console.log(Leistungswert);
                         // console.log(actualPower);
                         // console.log(Brennerstarts);
                          // console.log(Raumtemperatur);
                         // console.log(Element2);
                          // console.log(Element3);
                         console.log(Counterschleife);
                      // Wenn Raumtemperatur aber unter 20 Grad ist, Heizleistung erhöhen,
                      // wenn Heizung taktet wird Heizleistung dennoch niedriger da Thermostate ausgedreht
                      on({
                          change: "ne"
                      //    on({
                      //        id: "fritzdect.0.DECT_116300132384.celsius",
                      //        change: "ne"
                      //    }, async function (obj) {
                              // var Element2 = 1;
                              var Heat_on = (getState("km200.0.heatSources.hs1.flameStatus").val);
                              // var Leistungswert = (getState("km200.0.heatSources.powerSetpoint").val);
                              //var Brennerstarts = (getState("javascript.0.minutenZwischenBrennerStarts").val);
                              var Raumtemperatur_Mila = (getState("fritzdect.0.DECT_116300142272.celsius").val);
                              var Raumtemperatur2_Wohnz = (getState("km200:heatingCircuits.hc2.roomtemperature").val);
                              var Aussentemp = (getState("km200:system.sensors.temperatures.outdoor_t1").val)
                              //var Heizprogramm_E = (getState("km200.0.heatingCircuits.hc2.switchPrograms.E").val);
                              // getState("von allen Heizprogrammen") -> später, erst mal das Programm nehmen, welches durchgängig an ist.
                              // getState("km200.0.heatingCircuits.hc2.activeSwitchProgram") wir später benötigt, wenn andere Heizprogramme auch aktiviert sind
                              var temp = 420; //Heizprogramm_E[703]; // 300 Minuten ab Mitternacht -> 5 Uhr
                              //if (Heat_on == 1) {
                              //    Counterschleife = 7;
                                      Counterschleife = 5;
                                      if (Raumtemperatur_Mila <= 20 && Raumtemperatur2_Wohnz <= 18.5 || Raumtemperatur2_Wohnz <= 18.3 && Aussentemp <= 9 || Raumtemperatur2_Wohnz < 19.0 && Aussentemp > 9.1) {
                                          //setState("ems-esp.0.heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 4, true);
                                               setState("km200:heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 0,true );
                                               setState("km200:heatingCircuits.hc1.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 0,true );
                                          Counterschleife = 6;
                                              text: 'Heizung eingeschaltet.' + (Raumtemperatur_Mila)+ ' Raumtemperatur Mila und' + (Raumtemperatur2_Wohnz) +'Raumtemperatur Wohnzimmer'
                              console.log(temp);
                              console.log(temp_2);
                              //console.log(actualPower);
                              //console.log(Leitungswert);
                              console.log(Raumtemperatur_Mila);
                              console.log(Raumtemperatur2_Wohnz);
                      • M mwolle
                        //    type: 'int'
                        on({
                            change: "ne"
                            // var Element3;
                                    Element2 += 1;
                                      } else {
                                    Element2 = 0;
                                if (Element2 >= 2){
                                    Element2 = 0;
                        on({
                            change: "ne"
                        //    on({
                        //        change: "ne"
                                console.log(temp);
                        seh nur ich den nicht?
                        edit: ist ja nicht aufgeklappt, sorry
                        • M mwolle
                          //    type: 'int'
                          on({
                              change: "ne"
                              // var Element3;
                                      Element2 += 1;
                                        } else {
                                      Element2 = 0;
                                  if (Element2 >= 2){
                                      Element2 = 0;
                          on({
                              change: "ne"
                          //    on({
                          //        change: "ne"
                                  console.log(temp);
                          arteckA Offline
                          arteckA Offline
                          arteck
                          km200:
                          nicht km200: <-- doppelpunkt
                          sondern km200. <-- da muss ein Punkt hin
                          in Zeile 14, 16, 18, 54, 55,80, 93, 94,121, 122
                          und die insanznummer fehlt da auch
                          also alle km200: auf km200.0. ersetzen... wie in Zeile 13 steht
                          wenn du schon was Editierst dann achte drauf das du es richtig machst
                            mwolle
                            @homoran das ist der hier:
                            die ID heißt so: ems-esp.0.dhwCircuits.dhw1.wwcurtemp
                              ticaki
                              Ich bin echt gerade verwirrt...
                              lese bildet :)
                              Spenden
                              • arteckA arteck
                                km200:
                                mwolle
                                @arteck ich habe die IDs einfach kopiert...der hat den Doppelpunkt im Bauch. Ich hatte den Datenbaum gelöscht und noch mal neu aufbauen lassen, da ich den Heizungsregler neu getauscht hatte.
                                T arteckA 2 Antworten Letzte Antwort
                                • M mwolle
                                  ticaki
                                  @mwolle
                                  Du hast noch kein Bild gezeigt wo der gesamte Pfad über km200: bis zum Enddatenpunkt zu sehen ist :)
                                  Edit: da könnt ich mal all die ungenutzen States löschen
                                  Spenden
                                  • M mwolle
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    never... es gibt keinen Datenbaum mit : im object..dann bist du auf caps lock gekommen.. und so ist der : reingekommen anstatt .
                                    ist der gleiche knopp
                                    • arteckA arteck
                                      mwolle
                                      @arteck ja du hast absolut recht...ich habe den Namen kopiert und nicht die ID...der Name der ID ist dann km200:XXX, die ID ist dann richtigerweise ems-esp.0.XXX...
