  5. [gelöst] Payload Daten in Objekte schreiben
78 Beiträge 4 Kommentatoren 9.7k Aufrufe 2 Beobachtet
    @gregors sagte: Alle anderen Scripte laufen einwandfrei.
    Auf welche Protokoll-Stufe ist die Javascript-Instanz eingestellt?
    GregorSG Offline
    GregorSG Offline
    GregorS
    #61
    Logstufe "Error"
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    GregorSG HomoranH 2 Antworten Letzte Antwort
    • GregorSG GregorS
      Logstufe "Error"
      GregorSG Offline
      GregorSG Offline
      GregorS
      #62
      Hab auf Debug umgestellt.
      Jetzt kommt was.
      javascript.0
      	2023-07-22 18:34:43.750	info	script.js.LoRAWAN_DEV_1: undefined
      javascript.0
      	2023-07-22 18:34:43.749	info	script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z784WHCPR9CKQMD6YA61PJ","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z784NZ778FHQVN8ATABV4B","ns:uplink:01H5Z784P0FCGCHDWHMB7EZSAR","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z784P0MKF1ZWAFJ9K7394H","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z784WGE4FZ7ETJHPJJQ9DV"],"received_at":"2023-07-22T16:34:43.728419808Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4350,"frm_payload":"NgUAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.829", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:34:42.898Z","timestamp":3874550100,"rssi":-113,"channel_rssi":-113,"snr":-9.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPENTiw7cOGgwIo4rwpQYQluzr9wEgoOC66eH+JSoMCKKK8KUGEIDJmawD","channel_index":1,"gps_time":"2023-07-22T16:34:42.898Z","received_at":"2023-07-22T16:34:42.235671618Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867300000", "timestamp":3874550100, "time":"2023-07-22T16:34:42.898Z"},"received_at":"2023-07-22T16:34:43.520848844Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
      • GregorSG GregorS
        Jetzt kommt was.
        javascript.0
        javascript.0
        #63
        @gregors sagte: Hab auf Debug umgestellt.
        Stell auf "info".
        @gregors sagte in Payload Daten in Objekte schreiben:
        Jetzt kommt was.
        Auch alle 2 Minuten aus dem Trigger?
        GregorSG 1 Antwort Letzte Antwort
          Stell auf "info".
          Jetzt kommt was.
          GregorSG Offline
          GregorSG Offline
          GregorS
          #64
          18:43:37.493	info	javascript.0 (652027) Start javascript script.js.LoRAWAN_DEV_1
          18:43:37.496	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z7MYH48PRXF13SW1RS6HD4","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z7MYARW1Q74HXA0T7D5T4S","ns:uplink:01H5Z7MYAR2XJWHT5VS9XVHEZZ","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z7MYARMWPFGXW00K1X3WSV","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z7MYH4FKD5VX7EZXWGJKHZ"],"received_at":"2023-07-22T16:41:43.204341812Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4357,"frm_payload":"NgMAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.827", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:41:42.891Z","timestamp":4294543004,"rssi":-118,"channel_rssi":-118,"snr":-12.2,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEJyN5v8PGgwIxo3wpQYQiODg3AMg4KLXtf6KJioMCMaN8KUGEMCp7qgD","channel_index":3,"gps_time":"2023-07-22T16:41:42.891Z","received_at":"2023-07-22T16:41:42.692566999Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867700000", "timestamp":4294543004, "time":"2023-07-22T16:41:42.891Z"},"received_at":"2023-07-22T16:41:43.000778353Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
          18:43:37.496	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          18:43:43.227	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z7RKQ7EM4GPTNH3A4ZZQRM","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z7RKGRA8VCCA5GDJDAJ32G","ns:uplink:01H5Z7RKGSHDHETYPCFKHZ4WB8","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z7RKGSTVXAW22XNQWVCPYS","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z7RKQ7Q4ASFM7XB599YRYK"],"received_at":"2023-07-22T16:43:43.207301529Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4359,"frm_payload":"NicAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.863", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:43:42.882Z","timestamp":119566764,"rssi":-117,"channel_rssi":-117,"snr":-14.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEKzjgTkaCgi/jvClBhCVjhYg4I/wtb2OJioMCL6O8KUGEICByaQD","channel_index":7,"gps_time":"2023-07-22T16:43:42.882Z","received_at":"2023-07-22T16:43:42.693099748Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"868500000", "timestamp":119566764, "time":"2023-07-22T16:43:42.882Z"},"received_at":"2023-07-22T16:43:43.001729646Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
          18:43:43.228	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: undefined
          • GregorSG GregorS
            #65
            @gregors
            log(payload);
            zeigt offenbar undefined, da "decoded_payload" falsch geschrieben ist (Zeile 5).
            • GregorSG GregorS
              Logstufe "Error"
              #66
              Logstufe "Error"
              nee, nich?
                @gregors
                log(payload);
                GregorSG Offline
                GregorSG Offline
                GregorS
                #67
                Habe ich korrigiert. Der Teufel steckt im Detail
                19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z8SJDEQ23SXYZE51TC07BD","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z8SJ70D6PACPHB0R2GHN04","ns:uplink:01H5Z8SJ712X5TEW0CWDE4CXQM","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z8SJ715Z75WJ51BS6ZWF31","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z8SJDDM0YCG82TXN5P6Q2T"],"received_at":"2023-07-22T17:01:43.213639158Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4377,"frm_payload":"NiwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.868", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T17:01:42.871Z","timestamp":1199555188,"rssi":-118,"channel_rssi":-118,"snr":-13.8,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEPSE/7sEGgsI95bwpQYQ0Mb0AyCgqr7Y9K0mKgwI9pbwpQYQwM+pnwM=","channel_index":4,"gps_time":"2023-07-22T17:01:42.871Z","received_at":"2023-07-22T17:01:42.714662309Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867900000", "timestamp":1199555188, "time":"2023-07-22T17:01:42.871Z"},"received_at":"2023-07-22T17:01:43.009292984Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
                19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {'ACI1_mA':'0.000','ACI2_mA':'0.000','AVI1_V':'13.868','AVI2_V':'0.000','Acount_times':null,'Count1_times':null,'Count2_times':null,'DI1_status':'L','DI2_status':'H','DI3_status':null,'DO1_status':'H','DO2_status':'H','DO3_status':null,'First_status':null,'Hardware_mode':'LT22222','RO1_status':'OFF','RO2_status':'OFF','Work_mode':'2ACI+2AVI'}
                paul53P GregorSG 2 Antworten Letzte Antwort
                • GregorSG GregorS
                  #68
                  @gregors sagte: Der Teufel steckt im Detail
                  ... und nun wurde auch der Datenpunkt "AVI1_V" mit dem Wert 13.87 gefüllt?
                  • GregorSG GregorS
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    #69
                    @Homoran
                    @marc-berg
                    Danke für Eure Geduld und die Hilfe.
                    Jetzt funktioniert es.
                    • GregorSG GregorS
                      @Homoran
                      @marc-berg
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      #70
                      Wie kann ich denn
                      "rssi" und "time"
                      extrahieren?
                      Alle anderen Infos haben funktioniert.
                      • GregorSG GregorS
                        Wie kann ich denn
                        "rssi" und "time"
                        extrahieren?
                        #71
                        @gregors sagte: "rssi" und "time"
                            const msg = JSON.parse(dp.state.val).uplink_message;
                            const payload = msg.decoded_payload;
                            const rx0 = msg.rx_metadata[0];
                            log(rx0.time);
                            log(rx0.rssi);
                        • GregorSG Offline
                          GregorSG Offline
                          GregorS
                          #72
                          Nachdem ich jetzt die Daten in ioBroker habe, ist mir die Nacht eine
                          zusätzliche Anwendung durch den Kopf gegangen.
                          Dazu muss ich allerdings RO1 schalten.
                          Über das Gateway habe ich bereits Erfolg gehabt, und die Rückmeldung im ioBroker aufgenommen.
                          Messaging / Downlink --> 03 00 11 Relais öffnen
                          --> 03 01 11 Relais schliessen
                          Wie kann ich das RO1 aus ioBroker schalten?
                          • GregorSG GregorS
                            Marc BergM Online
                            Marc BergM Online
                            Marc Berg
                            #73
                            @gregors sagte in [gelöst] Payload Daten in Objekte schreiben:
                            Ich habe das über Node Red umgesetzt, aber den entscheidenden Teil kannst du vielleicht adaptieren.
                            So sieht ein einfacher Beispiel-Flow aus:
                            Der Payload (hier "0501100200") wird in einem Function-Node verarbeitet (Base64 Kodierung + Erzeugung des Downlinks) und dann per MQTT an TTN gesendet.
                            Der Code im Function-Node sieht so aus (in 'msg.hex' steckt "0501100200"):
                            var s=msg.hex;
                            var b=Buffer.from(s, 'hex');            //Buffer erzeugen
                            s=b.toString("base64");                 //to base64
                            msg.payload=
                                "downlinks": [{
                                  "f_port": 2,
                                  "frm_payload": s,
                                  "priority": "NORMAL"
                            return msg;
                            Dieser so aufbereitete Payload wird dann per MQTT an folgendes Topic gesendet:
                            v3/<APPLICATION-ID>@ttn/devices/<DEVICE_ID>/down/replace
                            • Marc BergM Marc Berg
                              var s=msg.hex;
                              msg.payload=
                                  "downlinks": [{
                                    "f_port": 2,
                                    "frm_payload": s,
                              return msg;
                              GregorSG Offline
                              GregorSG Offline
                              GregorS
                              #74
                              @marc-berg
                              Danke für den Denkanstoss.
                              Habe aber bisher noch keinen Erfolg gehabt.
                              Bekomme das Payload nicht gesendet.
                              Bleibe dran
                              • GregorSG GregorS
                                @marc-berg
                                Bleibe dran
                                Marc BergM Online
                                Marc BergM Online
                                Marc Berg
                                #75
                                Bleibe dran
                                Das müsste ja dann bei dir zum Einschalten so aussehen:
                                    "downlinks": [{
                                      "f_port": 2,
                                      "frm_payload": "AwER",
                                und zum Ausschalten so:
                                    "downlinks": [{
                                      "f_port": 2,
                                      "frm_payload": "AwAR",
                                Auf welche Weise sendest du den Downlink?
                                  Bleibe dran
                                      "downlinks": [{
                                        "f_port": 2,
                                      "downlinks": [{
                                        "f_port": 2,
                                  GregorSG Offline
                                  GregorSG Offline
                                  GregorS
                                  schrieb am zuletzt editiert von GregorS
                                  #76
                                  @marc-berg said in [gelöst] Payload Daten in Objekte schreiben:
                                  Was meinst du damit?
                                  Ich habe mehrer Versionen probiert, aber es hakt immer am "Doppelpunkt" hinter downlinks.
                                  Ich galube, da fehlt was entscheidendes.
                                  //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down.sent'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/sent*/
                                  on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down', function (dp)
                                    "downlinks": [{
                                      "f_port": 2,
                                      "frm_payload": "130011=",
                                  18:26:04.002	error	javascript.0 (681137) script.js.LoRAWAN_DEV_1_senden compile failed: at script.js.LoRAWAN_DEV_1_senden:4
                                  paul53P Marc BergM 2 Antworten Letzte Antwort
                                  • GregorSG GregorS
                                      "downlinks": [{
                                        "f_port": 2,
                                    #77
                                    @gregors
                                    Du willst doch keine Daten erhalten (triggern), sondern Daten senden. Das macht man mit sendTo() oder mit setState() auf den Datenpunkt, der an das Topic "v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/replace" sendet.
                                    • GregorSG GregorS
                                        "downlinks": [{
                                          "f_port": 2,
                                      Marc BergM Online
                                      Marc BergM Online
                                      Marc Berg
                                      #78
                                      Nun ja, man kann ja die Daten per MQTT oder per API senden. Wie ich jetzt gesehen habe, versuchst du es per MQTT. Das heißt, du hast eine MQTT Instanz erstellt und dich damit an TTN angemeldet? Funktioniert denn die Anmeldung?
                                      Zum Scripting kann ich nicht viel sagen, dazu hat sich ja @paul53 schon geäußert.
                                      Aber das hier:
                                      ist auf jeden Fall falsch Base64 kodiert. Ein guter Konverter ist z.B. der hier https://base64.guru/converter/encode/hex
                                      Wenn Du deinen Hexadezimal-Payload "03 01 11" durch den Konverter schickst, kommt "AwER" raus.
