  4. Test Adapter telegram-menu v.1.6.x
1.9k Beiträge 65 Kommentatoren 987.0k Aufrufe 63 Beobachtet
  • Michael RolingM Michael Roling
    @michael-roling so ich habe das gefixt, bitte einmal von Github laden und testen
    liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    #701
    @michael-roling
    leider geht wieder etwas nicht mehr, was schon mal funktionierte
    telegram-menu.0
    2023-11-13 19:52:49.532	debug	Sent Value to ["{}"] users!
    telegram.3
    2023-11-13 19:52:49.531	error	Failed sending [user - undefined]: Error: ETELEGRAM: 400 Bad Request: message text is empty
    telegram-menu.0
    2023-11-13 19:52:49.506	debug	userListWithChatID : [{"name":"liv-in-sky","chatID":"98xxxxxxx"}]
    telegram-menu.0
    2023-11-13 19:52:49.506	debug	Instance : "telegram.3"
    telegram-menu.0
    2023-11-13 19:52:49.506	debug	Send this to : "liv-in-sky"
    telegram-menu.0
    2023-11-13 19:52:49.506	debug	Send this Value : undefined
    telegram-menu.0
    2023-11-13 19:52:49.506	error	"TypeError: Cannot read properties of undefined (reading 'split')\n at Object.checkStatusInfo (/opt/iobroker/node_modules/iobroker.telegram-menu/lib/js/utilities.js:19:32)\n at processData (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:334:38)\n at TelegramMenu.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:193:17)"
    telegram-menu.0
    2023-11-13 19:52:49.506	error	Error checkStatusInfo: "Cannot read properties of undefined (reading 'split')"
    telegram-menu.0
    2023-11-13 19:52:49.505	debug	Send Nav to Telegram
    beim drücken des button's kommt die fehlermeldung - hier die definition
    Michael RolingM 2 Antworten Letzte Antwort
    • liv-in-skyL liv-in-sky
      @michael-roling
      telegram-menu.0
      telegram.3
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      Michael RolingM Offline
      Michael Roling
      #702
      @liv-in-sky Ich schaue mal gerade drüber
        @michael-roling
        telegram-menu.0
        telegram.3
        telegram-menu.0
        telegram-menu.0
        telegram-menu.0
        telegram-menu.0
        telegram-menu.0
        telegram-menu.0
        telegram-menu.0
        Michael Roling
        #703
        @liv-in-sky update ist online
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          #704
          @michael-roling danke - läuft wieder 🥸
          • Q Offline
            Q Offline
            quorle
            #705
            Habe mal versucht eine Struktur in den Adapter zu bekommen. Ich baue aktuell mein Menü so auf:
            Natürlich kommt dann dieser Fehler:
            Kann man diesen Fehler irgendwie umgehen? Ich habe es gerne aufgeräumt und sortiert. Wenn ich alles in eine Menü packe, wird es bei mir sehr schnell unübersichtlich.
            Zudem habe ich ein Problem mit der Rückmeldung. Ich habe es einmal so versucht:
            Leider klappt das nicht. Es wird immer mit "true" oder "false" geantwortet.
            Die ID ist der Statuskanal, der mir wirklich sagt, ob true/false. Aber irgendwie, egal was ich mache, es kommt nur immer: Küchenlicht ist "true", oder Küchenlicht ist "false".
            Ich hätte es aber gerne, dass true=an und false=aus geschrieben wird.
            Wie kann ich das umsetzen?
            • Q quorle
              Michael Roling
              #706
              @quorle schaue ich mir heute Abend mal an.
              • Q quorle
                Michael Roling
                #707
                @quorle Problem nr kann ich nicht nachvollziehen, welche Version hast du denn installiert? Ich habe die 0.8.5 und da kann ich ohne weiters mehrere Menus anlegen als untermenu
                Jetzt schaue ich mal nach Problem 2
                Q 1 Antwort Letzte Antwort
                  Q Offline
                  Q Offline
                  quorle
                  #708
                  @michael-roling
                  Habe auch die aktuelle 0.8.5 Version. Die Menüs an und für sich funktionieren. Nur der Fehler mit den „Strichen“ kommt.
                  Michael RolingM 1 Antwort Letzte Antwort
                  • Q quorle
                    @michael-roling
                    Michael Roling
                    #709
                    @quorle Hast du evtl ein Leerzeichen da drin??
                      Q Offline
                      Q Offline
                      quorle
                      #710
                      @michael-roling sagte in Test Adapter telegram-menu v.0.8.x:
                      Meinst du vor, oder hinter den Strichen?
                      Oder das 2. Problem, Leerzeichen zwischen den beiden Aktionen?
                      • Q quorle
                        Michael Roling
                        #711
                        @quorle Auch das habe ich gerade getestet, das funktioniert alles wunderbar
                          Q Offline
                          Q Offline
                          quorle
                          #712
                          @michael-roling
                          Komisch, habe gestern mal etliche Variationen durchprobiert. Aber keine Funktion das er den Wert von einem anderen Datenpunkt holt und aus True = an macht.
                          Michael RolingM 3 Antworten Letzte Antwort
                          • Q quorle
                            @michael-roling
                            Michael Roling
                            #713
                            @quorle da muss ich erst nachschauen ob das überhaupt so geht im Moment. Aber mit dem - macht mich stutzig
                            • Q quorle
                              @michael-roling
                              Michael Roling
                              #714
                              @quorle ich habe jetzt gerade mal richtig gelesen was da drin steht, das funktioniert ja so auch nicht, als rückgabetext muss das stehen
                              Wert wurde auch && gesetzt change{"true":"an","false":"aus"}
                              Den text kann man anpassen und auch die werte in change
                              • Q quorle
                                @michael-roling
                                Michael Roling
                                #715
                                @quorle der Bindestrich darf nur in der ersten, der grünen Zeile verwendet werden
                                  Q Offline
                                  Q Offline
                                  quorle
                                  #716
                                  Ja hier habe ich jeweils in jedem Untermenü in die grüne Zeile einen Bindestrich im Feld "Call Text" und "Navigation"
                                  Zu Problem 2:
                                  Also kann man unter "Aktion" -> SetState keine zwei Sachen als Rückgabetext machen? Beispiel:
                                  {'id':'ID','text':'Your Text'} change{"true":"an","false":"aus"}
                                  W Michael RolingM 2 Antworten Letzte Antwort
                                  • Q quorle
                                    Zu Problem 2:
                                    W Offline
                                    W Offline
                                    Willi-Wunder
                                    schrieb am zuletzt editiert von Willi-Wunder
                                    #717
                                    @Michael Roling
                                    Hallo Michael,
                                    bräuchte auch mal deine Hilfe. Ich frage mit Telegram den Status von verschiedenen Geräten ab. Bei Geräten wo der Wert ein Boolean ist klappt das auch. Bei einem String Wert wird der Wert nicht umgewandelt. Könnte es daher am String liegen?
                                    Vielen Dank.
                                    Gruß Willi
                                    • W Willi-Wunder
                                      @Michael Roling
                                      Hallo Michael,
                                      Vielen Dank.
                                      Gruß Willi
                                      Michael Roling
                                      #718
                                      @willi-wunder was steht denn in dem datenpunkt? nur true oder false als string?
                                      W 1 Antwort Letzte Antwort
                                      • Q quorle
                                        Zu Problem 2:
                                        Michael Roling
                                        schrieb am zuletzt editiert von Michael Roling
                                        #719
                                        @quorle was genau möchtest du denn bei Problem 2 machen?
                                        Es kommt eh bald eine komplett neue UI. Bitte daher noch etwas geduld. Aber wie gesagt eigentlich funkktioniert Problem 1. du könntest mal deine daten exportieren und mir per mail an michael.roling@gmx.de schicken. dann schaue ich da mal rein
                                          W Offline
                                          W Offline
                                          Willi-Wunder
                                          #720
                                          @michael-roling
                                          Beim ESP steht als String "Connected" oder "Disconnected" drin. Bei einem Somfy Produkt geht es auch nicht, Datenpunkt als string mit "available" oder "unavailable", hier das gleiche Problem das es nicht umgewandelt wird.
