  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • WalW Wal
    @skb ,
    habe den Adapter deinstalliert und die Alpha 16 installiert.
    Der Adapter startet ohne Probleme, danach ein Backup eingespielt und er stürtzt ab.
        "basic": {
            "enable_grid": true,
            "enable_animation": false,
            "enable_area_catch": true,
            "enable_config_icon": true,
            "enable_last_id": false,
            "enable_icon_proxy": false,
            "height": 540,
            "width": 600,
            "styles": "",
            "font": {
                "family": "\"Arial\", sans-serif",
                "size": "20",
                "color": "",
                "fill": "",
                "align": "middle"
            "rect": {
                "height": 100,
                "width": 100,
                "corners": 10
            "circle": {
                "radius": 50
            "elm": {
                "stroke_width": 5,
                "color": "",
                "fill": "",
                "pos_x": 50,
                "pos_y": 50
            "icon": {
                "height": 24,
                "width": 24,
                "color": ""
        "calculation": {
            "battery": {
                "dod": 0,
                "capacity": 0,
                "percent": -1,
                "charge": -1,
                "charge_prop": false,
                "charge_kw": false,
                "discharge": -1,
                "discharge_prop": false,
                "discharge_kw": false
            "consumption": {
                "production": [
                    -1
                "production_kw": false,
                "gridFeed": -1,
                "gridFeed_kw": false,
                "gridFeed_prop": false,
                "gridConsume": -1,
                "gridConsume_kw": false,
                "gridConsume_prop": false,
                "batteryCharge": -1,
                "batteryCharge_kw": false,
                "batteryCharge_prop": false,
                "batteryDischarge": -1,
                "batteryDischarge_kw": false,
                "batteryDischarge_prop": false
        "animation": {
            "stroke": "#ffce4a",
            "stroke_dasharray": "10 17 10 17 10  72",
            "stroke_width": "6",
            "animation_duration": "2000",
            "stroke_linecap": "round",
            "animation_timing_function": "linear"
        "animation_configuration": {
            "dots": "3",
            "distance": "17",
            "length": "10"
        "line": {
            "stroke_width": "8",
            "stroke": "#000000"
        "elements": {
            "2": {
                "position": 0,
                "type": "text",
                "subType": "datasource",
                "id": 2,
                "pos_x": 49,
                "pos_y": 41,
                "color": "none",
                "fill": "rgb(195, 255, 81)",
                "font_family": "Arial, sans-serif",
                "font_size": 18,
                "align": "middle",
                "text": "ID 2",
                "unit": "kW",
                "source": 2,
                "source_option": -1,
                "source_display": "value",
                "shadow": "",
                "threshold": 0,
                "calculate_kw": true,
                "convert": false,
                "decimal_places": 2,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "5": {
                "position": 0,
                "type": "rect",
                "id": 5,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 1,
                "pos_y": 1,
                "fill": "none",
                "color": "rgb(195, 255, 81)",
                "stroke": 2,
                "shadow": "rgba(0,0,0,0.7)",
                "frame": "_overlay",
                "fill_value": null,
                "fill_type": "percent",
                "fill_direction": 90,
                "fill_max": null,
                "border_value": null,
                "border_type": -1,
                "border_direction": "cw",
                "border_style": "round",
                "border_max": null,
                "border_reverse_value": null,
                "border_reverse": false,
                "border_start": 180,
                "source": 2,
                "threshold": 0
            "6": {
                "position": 0,
                "type": "icon",
                "id": "6",
                "icon": "mdi:solar-panel",
                "width": 24,
                "height": 24,
                "pos_x": "39",
                "pos_y": "5",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "7": {
                "position": 1,
                "type": "rect",
                "id": 7,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 221,
                "pos_y": 221,
                "fill": "none",
                "color": "rgb(0, 209, 255)",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": 1,
                "threshold": 0
            "9": {
                "position": 1,
                "type": "text",
                "id": 9,
                "pos_x": 271,
                "pos_y": 263,
                "color": "none",
                "fill": "rgb(0, 209, 255)",
                "font_size": 18,
                "align": "middle",
                "text": "ID 9",
                "unit": "kW",
                "source": 1,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "10": {
                "position": 2,
                "type": "text",
                "id": 10,
                "pos_x": 51,
                "pos_y": 74,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Produktion",
                "shadow": "",
                "frame": "_overlay"
            "11": {
                "position": 3,
                "type": "text",
                "id": 11,
                "pos_x": 271,
                "pos_y": 297,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Gesamt",
                "shadow": "",
                "frame": "_overlay"
            "12": {
                "position": 1,
                "type": "icon",
                "id": "12",
                "icon": "mdi:house-city",
                "width": 24,
                "height": 24,
                "pos_x": "259",
                "pos_y": "227",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "14": {
                "position": 2,
                "type": "rect",
                "id": 14,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 1,
                "pos_y": 301,
                "fill": "none",
                "color": "rgb(255, 0, 0)",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": 0,
                "threshold": 0
            "19": {
                "position": 4,
                "type": "text",
                "id": 19,
                "pos_x": 50,
                "pos_y": 343,
                "color": "none",
                "fill": "rgb(255, 0, 0)",
                "font_size": 18,
                "align": "middle",
                "text": "ID 19",
                "unit": "kW",
                "source": 0,
                "shadow": "",
                "threshold": 0,
                "convert": true,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "20": {
                "position": 2,
                "type": "icon",
                "id": "20",
                "icon": "mdi:electricity-from-grid",
                "width": 24,
                "height": 24,
                "pos_x": "38",
                "pos_y": "307",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "21": {
                "position": 5,
                "type": "text",
                "id": 21,
                "pos_x": 50,
                "pos_y": 377,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Netz",
                "shadow": "",
                "frame": "_overlay"
            "22": {
                "position": 3,
                "type": "rect",
                "id": 22,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 121,
                "pos_y": 1,
                "fill": "none",
                "color": "rgb(255, 206, 74)",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": -1,
                "threshold": 0
            "24": {
                "position": 6,
                "type": "text",
                "id": 24,
                "pos_x": 171,
                "pos_y": 77,
                "color": "none",
                "fill": "rgb(255, 206, 74)",
                "font_size": 14,
                "align": "middle",
                "text": "Proxmox",
                "shadow": "",
                "frame": "_overlay"
            "26": {
                "position": 7,
                "type": "text",
                "id": 26,
                "pos_x": 171,
                "pos_y": 43,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "ID 26",
                "unit": "W",
                "source": 3,
                "shadow": "",
                "threshold": 0,
                "calculate_kw": false,
                "convert": false,
                "decimal_places": 0,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "27": {
                "position": 4,
                "type": "rect",
                "id": 27,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 241,
                "pos_y": 1,
                "fill": "none",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": -1,
                "threshold": 0
            "28": {
                "position": 8,
                "type": "text",
                "id": 28,
                "pos_x": 291,
                "pos_y": 77,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Tiefkühltruhe",
                "shadow": "",
                "frame": "_overlay"
            "29": {
                "position": 9,
                "type": "text",
                "id": 29,
                "pos_x": 291,
                "pos_y": 43,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "ID 29",
                "unit": "W",
                "source": 4,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "31": {
                "position": 5,
                "type": "rect",
                "id": 31,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 363,
                "pos_y": 1,
                "fill": "none",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": -1,
                "threshold": 0
            "32": {
                "position": 10,
                "type": "text",
                "id": 32,
                "pos_x": 413,
                "pos_y": 77,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Fernseher",
                "shadow": "",
                "frame": "_overlay"
            "33": {
                "position": 11,
                "type": "text",
                "id": 33,
                "pos_x": 413,
                "pos_y": 43,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "ID 33",
                "unit": "W",
                "source": 5,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "35": {
                "position": 3,
                "type": "icon",
                "id": "35",
                "width": 24,
                "height": 24,
                "pos_x": "158",
                "pos_y": "6",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "36": {
                "position": 4,
                "type": "icon",
                "id": "36",
                "width": 24,
                "height": 24,
                "pos_x": "278",
                "pos_y": "7",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "37": {
                "position": 5,
                "type": "icon",
                "id": "37",
                "width": 24,
                "height": 24,
                "pos_x": "401",
                "pos_y": "6",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
        "defs": {
            "path_5_7": {
                "type": "def",
                "id": "path_5_7",
                "d": "M31 102  V 131.8   V 236 A 15 15 0 0 0 46 251  H 220",
                "startSlot": "bottom_left",
                "endSlot": "left_top"
            "path_7_22": {
                "type": "def",
                "id": "path_7_22",
                "d": "M251 220  V 196.4 A 15 15 0 0 0 236 181.4  H 166 A 15 15 0 0 1 151 166.4   V 102",
                "startSlot": "top_left",
                "endSlot": "bottom_left"
            "path_7_27": {
                "type": "def",
                "id": "path_7_27",
                "d": "M271 220  V 102",
                "startSlot": "top",
            "path_7_31": {
                "type": "def",
                "id": "path_7_31",
                "d": "M291 220  V 196.4 A 15 15 0 0 1 306 181.4  H 378 A 15 15 0 0 0 393 166.4  V 102",
                "startSlot": "top_right",
            "path_14_7": {
                "type": "def",
                "id": "path_14_7",
                "d": "M71 300  V 294.2   V 285 A 14 14 0 0 1 85 271  H 220",
                "endSlot": "left"
        "lines": {
            "line_path_5_7": {
                "type": "line",
                "id": "line_path_5_7",
                "href": "#path_5_7",
                "color": "rgb(0, 0, 0)",
                "shadow": ""
            "line_path_7_22": {
                "type": "line",
                "id": "line_path_7_22",
                "href": "#path_7_22",
                "shadow": ""
            "line_path_7_27": {
                "type": "line",
                "id": "line_path_7_27",
                "href": "#path_7_27",
                "shadow": ""
            "line_path_7_31": {
                "type": "line",
                "id": "line_path_7_31",
                "href": "#path_7_31",
                "shadow": ""
            "line_path_14_7": {
                "type": "line",
                "id": "line_path_14_7",
                "href": "#path_14_7",
                "shadow": ""
        "animations": {
            "anim_path_5_7": {
                "type": "animation",
                "id": "anim_path_5_7",
                "source": 2,
                "threshold": 0,
                "animation_properties": "positive",
                "animation_option": false,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "animation_type": -1
            "anim_path_7_22": {
                "id": "anim_path_7_22",
                "source": 3,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_27": {
                "id": "anim_path_7_27",
                "source": 4,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_31": {
                "id": "anim_path_7_31",
                "source": 5,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_14_7": {
                "id": "anim_path_14_7",
                "color": "rgb(255, 15, 67)",
                "source": 0,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
        "datasources": {
            "0": {
                "source": "sonoff.0.Haus.Stromzähler.MT175_P",
                "alias": "Netzverbrauch"
            "1": {
                "source": "0_userdata.0.Stromverbrauch_aktuell",
                "alias": "Gesamtverbrauch"
            "2": {
                "source": "sonoff.0.Haus.Balkonkraftwerk.ENERGY_Power",
                "alias": "Balkonkraftwerk"
            "3": {
                "source": "sonoff.0.Test.Steckdose3.ENERGY_Power",
                "alias": "Proxmox"
            "4": {
                "source": "sonoff.0.Test.Steckdose.ENERGY_Power",
                "alias": "Tiefkühltruhe"
            "5": {
                "source": "sonoff.0.Test.Steckdose2.ENERGY_Power",
                "alias": "Fernseher"
    SKBS Offline
    SKBS Offline
    SKB
    #1341
    @wal Welche Fehlermeldung kommt beim Absturz?
    WalW 1 Antwort Letzte Antwort
    • SKBS SKB
      WalW Offline
      WalW Offline
      Wal
      #1342
      @skb ,
      siehe Log den ich gepostet habe.
      Walter
      DoorIO-Adapter
      ArmilarA SKBS 2 Antworten Letzte Antwort
      • WalW Wal
        @skb ,
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        #1343
        @wal
        @SKB
        energiefluss-erweitert.0
        2023-09-01 10:49:56.407	info	Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.PV.Terrassendach.total.P_AC,sonoff.0.DZG_DWSB20_2H.DZG_Leistung_Aktuell,0_userdata.0.PV_Akku_Emulation.Akkustand,0_userdata.0.PV_Akku_Emulation.Leistung,shelly.0.shellypro3em#shellypro3em#1.EM0.TotalActivePower,0_userdata.0.Energiebilanz.Leistung.Verbrauch,sonoff.0.Kuehlschrank_Kueche.ENERGY_Power,sonoff.0.Waschmaschine.ENERGY_Power,sonoff.0.Geschirrspuelmaschine.ENERGY_Power,tuya.0.581550838caab5731891.5,sonoff.0.Mikrowelle.ENERGY_Power,sonoff.0.Kuehlschrank_HW.ENERGY_Power,sonoff.0.HW_LED_Unterbau.ENERGY_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_HW,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Kueche,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Buero,sonoff.0.Airbowl_Buero.ENERGY_Power,sonoff.0.Buero_Schreibtisch.ENERGY_Power,sonoff.0.Buero_Server.ENERGY_Power,sonoff.0.Pool.ENERGY_Power,sonoff.0.Kaffemaschine.ENERGY_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Rest,sonoff.0.Fritteuse.ENERGY_Power,pvforecast.0.summary.power.now,0_userdata.0.Stromzaehler.Aktuell.Bezug,0_userdata.0.Stromzaehler.Aktuell.EinspeisungWh,0_userdata.0.Stromzaehler.Aktuell.Bedarf,mqtt.0.PV.Terrassendach.total.YieldDay,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Esszimmer,shelly.0.SHDM-1#F3C218#1.lights.Power,sonoff.0.Esszimmer_Schreibtisch.ENERGY_Power,mqtt.0.PV.Terrassendach.Terrassendach.ch0.P_AC,mqtt.0.PV.Terrassendach.Terassendach2.ch0.P_AC,followthesun.0.current.altitude,followthesun.0.current.azimuth,0_userdata.0.Waermepumpe.Tag.Verbrauch_Total,0_userdata.0.Astro.01 - sunrise,0_userdata.0.Astro.07 - sunset,0_userdata.0.Zeit.Aktuell,mqtt.0.PV.Terrassendach.Terrassendach.ch0.active_PowerLimit,mqtt.0.PV.Terrassendach.Terassendach2.ch0.active_PowerLimit,sonoff.0.Pool.ENERGY_Today,sonoff.0.Kuehlschrank_Kueche.ENERGY_Today,sonoff.0.Kaffemaschine.ENERGY_Today,sonoff.0.Buero_Server.ENERGY_Today,sonoff.0.Buero_Schreibtisch.ENERGY_Today,sonoff.0.Esszimmer_Schreibtisch.ENERGY_Today,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Flur,sonoff.0.Treppenbeleuchtung_EG.Virtual_Energy_Power,shelly.0.SHSW-L#3C6105E43DD2#1.Relay0.Virtual_Energy_Power,sonoff.0.Licht_Flur_Vorne_EG.Virtual_Energy_Power,shelly.0.SHSW-L#84CCA8AE12A1#1.Relay0.Virtual_Energy_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Naehzimmer,0_userdata.0.Energiebilanz.Leistung.Verbrauch_GaesteWC,sonoff.0.Geschirrspuelmaschine.ENERGY_Today,sonoff.0.Waschmaschine.ENERGY_Today,sonoff.0.Kuehlschrank_HW.ENERGY_Today,sonoff.0.HW_LED_Unterbau.ENERGY_Today
        2023-09-01 10:49:56.406	info	Configuration loaded!
        2023-09-01 10:49:56.271	info	Adapter started. Loading config!
        2023-09-01 10:49:56.231	info	starting. Version 0.0.2-alpha.16 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#b7d0fd6df1e7181a917b26c4e162aa1fe8c54078) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
        2023-09-01 10:49:24.528	info	terminating
        2023-09-01 10:49:24.026	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-09-01 10:49:24.025	info	terminating
        2023-09-01 10:49:24.025	info	Cleared interval for relative values!
        2023-09-01 10:49:24.023	error	Cannot read properties of undefined (reading 'log')
        2023-09-01 10:49:24.023	error	TypeError: Cannot read properties of undefined (reading 'log') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1148:19)
        2023-09-01 10:49:24.022	error	unhandled promise rejection: Cannot read properties of undefined (reading 'log')
        2023-09-01 10:49:24.022	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-01 10:49:23.961	warn	The adapter could not find the state 'shelly.0.SHSW-L#84CCA8AE12A1#1.Relay0.Virtual_Energy_Power'! Please review your configuration of the adapter!
        2023-09-01 10:49:23.959	warn	The adapter could not find the state 'shelly.0.SHSW-L#3C6105E43DD2#1.Relay0.Virtual_Energy_Power'! Please review your configuration of the adapter!
        2023-09-01 10:49:23.893	info	Adapter started. Loading config!
        2023-09-01 10:49:23.857	info	starting. Version 0.0.2-alpha.16 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#b7d0fd6df1e7181a917b26c4e162aa1fe8c54078) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
        habe den ioBroker auch mal neu gestartet. Folgendes steht im log - Habe auch den Eindruck, dass sich nicht alle Datasources sauber aktualisieren...
        SKBS 1 Antwort Letzte Antwort
        • ArmilarA Armilar
          @wal
          @SKB
          SKBS Offline
          SKBS Offline
          SKB
          schrieb am zuletzt editiert von SKB
          #1344
          @armilar sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
          @wal
          @SKB
          Ist ja auch so, da die States nicht gefunden werden.
          EDIT: Habe den Fehler mit dem "Log" beseitigt. Bitte nochmal drüber installieren und schauen, was passiert.
          • WalW Wal
            @skb ,
            SKBS Offline
            SKBS Offline
            SKB
            #1345
            @wal Kannst Du nochmal drüber installieren und schauen, ob der Fehler noch auftritt?
            WalW 2 Antworten Letzte Antwort
            • SKBS SKB
              WalW Offline
              WalW Offline
              Wal
              #1346
              @skb ,
              ja ist weg. 👍
              Walter
              DoorIO-Adapter
              • WalW Wal
                @skb ,
                ja ist weg. 👍
                SKBS Offline
                SKBS Offline
                SKB
                #1347
                @wal Danke für den Hinweis und die Rückmeldung :)
                • SKBS SKB
                  WalW Offline
                  WalW Offline
                  Wal
                  #1348
                  @skb ,
                  die Animation ist nicht mehr flüssig, die stockt alle 3sec. ist aber i. M. nicht wichtig. ;-)
                  Walter
                  DoorIO-Adapter
                  • WalW Wal
                    @skb ,
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #1349
                    @wal Dann wird dies vorher schon gewesen sein - an den Animationen habe ich seit einigen Versionen nichts geändert.
                    WalW 3 Antworten Letzte Antwort
                    • SKBS SKB
                      WalW Offline
                      WalW Offline
                      Wal
                      #1350
                      @skb ,
                      leider nein, das stocken ist erst seit alpha 16.
                      Ich mache nochmal den recheck.
                      Walter
                      DoorIO-Adapter
                      • SKBS SKB
                        WalW Offline
                        WalW Offline
                        Wal
                        #1351
                        @skb sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                        Bin zurück gegangen und kein stocken, mach dir aber erst mal kein Stress.
                        Walter
                        DoorIO-Adapter
                        • WalW Wal
                          SKBS Offline
                          SKBS Offline
                          SKB
                          #1352
                          @wal Kannst du mal ein Beispiel aufnehmen?
                          • SKBS SKB
                            WalW Offline
                            WalW Offline
                            Wal
                            #1353
                            @skb ,
                            da legst dich nieder, wieder zurück auf die Neuste und auch kein stocken. ;-)
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @skb ,
                              SKBS Offline
                              SKBS Offline
                              SKB
                              #1354
                              @wal vielleicht der Upload unvollständig. Aber gut, wenn es geht ;)
                              • SKBS SKB
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #1355
                                @skb
                                Merkwürdig... Habe 2 Datenpunkte auf 0_userdate.0... vom Typ state/number. Damit errechne ich den Gesamtverbrauch und den Restverbrauch per JS. Wenn ich die GUI speicher und verlasse, dann stimmen die beiden Werte, jedoch werden sie in der GUI danach nicht mehr aktualisiert.
                                Bei allen anderen ID's aktualisieren sich die Werte.
                                Ist in der vorherigen Version nicht so...
                                EDIT: im ioBroker ändern sich die Werte sekündlich...
                                • ArmilarA Armilar
                                  @skb
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  #1356
                                  @armilar Danke für den Hinweis. Gemäß den Bestimmungen von ioBroker sollen Adapter bei fremden Datenpunkten nur reagieren, wenn "ACK" true gesetzt wird.
                                  Du kannst in deinen Javascripts, die die Punkte bearbeiten, einfach ein "ACK" true mitgeben:
                                  setState(Datenpunkt, Wert, true); // true am Ende
                                  ArmilarA F 2 Antworten Letzte Antwort
                                  • SKBS SKB
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #1357
                                    @skb
                                    okay... das wars... aktualisieren sich wieder
                                    • ArmilarA Armilar
                                      @skb
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #1358
                                      @armilar na perfekt :)
                                      • ArmilarA Armilar
                                        @skb
                                        Hier der versprochene Screenshot
                                        Die Tapete wächst aber noch ;-) Sind noch lange nicht alle drin und der Akku (aktuell fake) ist auch erst in ein paar Tagen aktiv...
                                        Pascal
                                        #1359
                                        @armilar Wie stellst Du die Linien Animation für "Verbrauch Büro" ein? Dass diese läuft, wenn 1 oder mehrer Verbraucher an sind.
                                        Lob für den Screenshot. Schaut Cool aus.
                                        Pascal
                                        • P Pascal
                                          Pascal
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #1360
                                          @pascal
                                          Ich habe jeden Raum separat auf je einem Datenpunkt und Trigger jeden Verbraucher des Raumes auf Veränderungen. Dann erfolgt ein Update auf den jeweiligen Raum-DP in Addition aller Verbraucher. Würde es dir gerne posten, habe allerdings mobil aktuell nur sehr begrenzte Möglichkeiten.
