  3. Off Topic
  4. Proxmox
  5. Proxmox LXC mit Frigate
    6.3k
Geplant Angeheftet Gesperrt Verschoben Proxmox
176 Beiträge 16 Kommentatoren 67.1k Aufrufe 21 Beobachtet
  • R Radi
    @wal Dankeschön, ich schau mal, ob noch etwas mehr drin steht.
    Radi
    schrieb am zuletzt editiert von Radi
    #41
    @Wal Da steht letztenendes dasselbe wie im Portainerlogfile drin. Ursächlich scheint wohl dies zu sein:
    2023-05-07 14:44:51.033075103  *************************************************************
    2023-05-07 14:44:51.033078419  *************************************************************
    2023-05-07 14:44:51.033079955  ***    Your config file is not valid!                     ***
    2023-05-07 14:44:51.033081414  ***    Please check the docs at                           ***
    2023-05-07 14:44:51.033082613  ***    https://docs.frigate.video/configuration/index     ***
    2023-05-07 14:44:51.033083997  *************************************************************
    2023-05-07 14:44:51.033085013  *************************************************************
    2023-05-07 14:44:51.033092726  ***    Config Validation Errors                           ***
    2023-05-07 14:44:51.033093828  *************************************************************
    2023-05-07 14:44:51.033094705  [Errno 21] Is a directory: '/config/config.yml'
    2023-05-07 14:44:51.033656750  Traceback (most recent call last):
    2023-05-07 14:44:51.033658821    File "/opt/frigate/frigate/app.py", line 351, in start
    2023-05-07 14:44:51.033659876      self.init_config()
    2023-05-07 14:44:51.033660984    File "/opt/frigate/frigate/app.py", line 80, in init_config
    2023-05-07 14:44:51.033661995      user_config = FrigateConfig.parse_file(config_file)
    2023-05-07 14:44:51.033662995    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
    2023-05-07 14:44:51.033663850      with open(config_file) as f:
    2023-05-07 14:44:51.033664794  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
    2023-05-07 14:44:51.033665538
    2023-05-07 14:44:51.033666509  *************************************************************
    2023-05-07 14:44:51.033667457  ***    End Config Validation Errors                       ***
    2023-05-07 14:44:51.033668354  **********************************************************
    Nur weiß ich nicht, wie man diesen "IsADirectoryError" korrigiert. Findet Frigate in dem angegebenen Pfad nichts? Oder hat dies eine andere Ursache? Den Screenshot aus dem Filezilla habe ich ja schon weiter oben gepostet. Mit meinem bescheidenen oder nicht vorhandenen Wissen würde ich annehmen, dass der Pfad zur config.yaml so passt.
    WalW 2 Antworten Letzte Antwort
    • R Radi
      WalW Offline
      WalW Offline
      Wal
      #42
      @radi ,
      wie erstellst du die config.yml ? mit nano ?
      Walter
      DoorIO-Adapter
      • R Radi
        WalW Offline
        WalW Offline
        Wal
        schrieb am zuletzt editiert von Wal
        #43
        @radi ,
        mach mal im Container diesen Befehl:
        cat /config/config.yml
        Walter
        DoorIO-Adapter
        R 1 Antwort Letzte Antwort
        • WalW Wal
          @radi ,
          Radi
          #44
          @wal sagte in Proxmox LXC mit Frigate:
          Hallo Walter,
          das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
          cat: /config/config.yml: No such file or directory
          will ich das Verzeichnis erzeugen, kommt das:
          mkdir config
          mkdir: cannot create directory 'config': File exists
          Will ich mit nano eine neue config erzeugen kommt:
            GNU nano 6.4                        /config/config.yml
                                   [ Directory '/config' does not exist ]
          ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
          ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
          Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
          ~/config# cat config.yml
          detectors:
            cpu1:
              type: cpu
          mqtt:
            host: 192.168.69.159
            user: user
            password: xxx
          cameras:
            back:
              ffmpeg:
                hwaccel_args: preset-vaapi
                inputs:
                  - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                    roles:
                      - detect
                  - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                    roles:
                      - record
              detect:
                width: 640
                height: 360
              mqtt:
                enabled: False
             objects:
                track:
                  - person
                  - car
                  - truck
                  - bicycle
                  - motorcycle
                  - dog
                  - cat
          snapshots:
            enabled: True
            timestamp: False
            bounding_box: False
            crop: False
            height: 175
            required_zones: []
            retain:
              default: 10
              objects:
                    person: 15
          record:
            enabled: True
            retain:
              days: 7
              mode: motion
            events:
              retain:
                default: 14
                mode: active_objects
                objects:
                  person: 14
                  dog: 2
                  car: 7
          WalW holzapfelaugeH 2 Antworten Letzte Antwort
          • R Radi
            Hallo Walter,
            mkdir config
            detectors:
              cpu1:
                type: cpu
            mqtt:
              user: user
              password: xxx
            cameras:
              back:
                ffmpeg:
                  inputs:
                      roles:
                        - detect
                      roles:
                        - record
                detect:
                  width: 640
                  height: 360
                mqtt:
                  enabled: False
               objects:
                  track:
                    - person
                    - car
                    - truck
                    - bicycle
                    - motorcycle
                    - dog
                    - cat
            snapshots:
              enabled: True
              timestamp: False
              bounding_box: False
              crop: False
              height: 175
              required_zones: []
              retain:
                default: 10
                objects:
                      person: 15
            record:
              enabled: True
              retain:
                days: 7
                mode: motion
              events:
                retain:
                  default: 14
                  objects:
                    person: 14
                    dog: 2
                    car: 7
            WalW Offline
            WalW Offline
            Wal
            #45
            @radi ,
            du musst da aufpassen.
            Im Docker-Container muss man diese Datei nicht erzeugen, die zeigt nur auf die Datei im LXC.
                  - /home/frigate/frigate/config.yml:/config/config.yml
            also die Datei im LXC "/home/frigate/frigate/config.yml" wird im Docker auf "/config/config.yml" gemappt.
            das geht automatisch. Du musst nur die Datei wie hier im LXC "/home/frigate/frigate/config.yml" oder wie in deiner Docker-Config angegeben erzeugen.
            edit: oder mappst du die Datei in der Docker-Config gar nicht auf "/config/config.yml"
            editedit: der Docker Container ist fertig eingerichtet, da muss nichts verändert werden.
            Walter
            DoorIO-Adapter
            • WalW Wal
              Nachdem ich mir eine CORAL M.2 ACCELERATOR MIT DUAL EDGE TPU und ein Dual Edge TPU Adapter bestellt habe, wurde Frigate auf Proxmox installiert.
              Skript von TTeck
              Proxmox-Console Ubuntu Lunar installieren:
              bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/ct/ubuntu.sh)"
              • Use Default Settings? -> Advanced
              • Choose Distribution: -> ubuntu
              • Choose Version -> 23.04 Lunar
              • Choose Type -> 1 Unprivileged
              • Set Disk Size in GB -> 4GB, wenn Videos lokal abgelegt werden sollen erhöhen.
              • Allocate CPU Cores -> min. 2, je mehr Kameras desto mehr Cores
              • Allocate Ram in MiB -> min. 2048, je mehr Kameras desto mehr Speicher
              • Set a Static IPv4 -> besser ist es
              • Disable IPv6? -> besser ist es
              • Enable Root SSH Access? -> nein
              FrigateLXC als root:
              adduser frigate
              adduser frigate sudo
              exit
              FrigateLXC als User frigate:
              sudo apt-get install ca-certificates curl gnupg
              sudo install -m 0755 -d /etc/apt/keyrings
              curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
              sudo chmod a+r /etc/apt/keyrings/docker.gpg
              echo "deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu "$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
              sudo apt update
              sudo apt install docker-ce docker-ce-cli containerd.io docker-compose-plugin
              sudo adduser frigate docker
              exit
              FrigateLXC als User frigate neu anmelden:
              docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce
              sudo systemctl status docker
              sudo /lib/systemd/systemd-sysv-install enable docker
              mkdir frigate
              cd frigate
              nano docker-compose.yml
              docker-compose.yml:
              version: "3.9"
              services:
                frigate:
                  container_name: frigate
                  privileged: true # this may not be necessary for all setups
                  restart: unless-stopped
                  image: ghcr.io/blakeblackshear/frigate:stable
                  shm_size: "64mb" # update for your cameras based on calculation above
                  cap_add:
                    - CAP_PERFMON
                  devices:
                    - /dev/apex_0:/dev/apex_0
                    - /dev/apex_1:/dev/apex_1
                    - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
                  volumes:
                    - /etc/localtime:/etc/localtime:ro
                    - /media/frigate:/media/frigate
                    - type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
                      target: /tmp/cache
                      tmpfs:
                  ports:
                    - "5000:5000"
                    - "1935:1935" # RTMP feeds
              Achtung ab Frigate 13 muss der komplette Frigate-Pfad angegeben werden nicht die config.yml:
              - /home/frigate/frigate:/config
              nano config.yml
              die minimale config.yml:
              mqtt:
                enabled: False
              cameras:
                back:
                  ffmpeg:
                    inputs:
                      - path: rtsp://User:PW@192.168.69.162:554/h264Preview_01_main
                        roles:
                          - detect
                  detect:
                    enabled: False
                    width: 640
                    height: 480
              docker starten:
              docker compose up -d
              exit
              http://deineIP:5000
              exitus
              schrieb am zuletzt editiert von exitus
              #46
              danke euch allen
              mit viel grübeln habe ich frigate am laufen aber nur minimal.
              habe ein camera eingebunden mit minimal config rest mache ich weiter wenn mein tpu da ist.
              • E Offline
                exitus
                #47
                ich habe kamera eingebunden habe aber ein greenscreen nur
                woran kann es liegen???
                erledigt
                • E Offline
                  exitus
                  #48
                  Hallo was ist an diesem config falsch
                  detectors:
                    cpu1:
                      type: cpu
                  database:
                      path: /db/frigate.db
                  mqtt:
                    host: 172.16.0.10
                    port: 1689
                    user: admin
                    password: passwort
                  cameras:
                    Parkplatz:
                      ffmpeg:
                        output_args:
                          record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
                          rtmp: -c:v copy -c:a aac -f flv
                        inputs:
                  	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                            roles:
                              - detect
                              - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                            roles:
                              - record
                      rtmp:
                        enabled: False
                  detect:
                        width: 640
                        height: 480
                  objects:
                        track:
                          - person
                          - car
                          - dog
                  snapshots:
                        enabled: true
                  	  timestamp: true
                        bounding_box: true
                        retain:
                          default: 2
                  record:
                        enabled: true
                        retain:
                          days: 10
                  was sind das für errors
                  [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
                  [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  [cont-finish.d] executing container finish scripts...
                  [cont-finish.d] done.
                  [s6-finish] waiting for services.
                  [s6-finish] sending all processes the TERM signal.
                  [s6-finish] sending all processes the KILL signal and exiting.
                  [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
                  [s6-init] ensuring user provided files have correct perms...exited 0.
                  [fix-attrs.d] applying ownership & permissions fixes...
                  [fix-attrs.d] done.
                  [cont-init.d] executing container initialization scripts...
                  [cont-init.d] done.
                  [services.d] starting services
                  [services.d] done.
                  [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
                  Starting migrations
                  [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
                  There is nothing to migrate
                  [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
                  [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
                  [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
                  [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
                  [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
                  [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
                  [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
                  [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                  [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                  [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                  [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                  [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                  [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                  [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                  snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
                  WalW 1 Antwort Letzte Antwort
                  • E exitus
                    detectors:
                      cpu1:
                        type: cpu
                    database:
                    mqtt:
                      host: 172.16.0.10
                      port: 1689
                      user: admin
                      password: passwort
                    cameras:
                      Parkplatz:
                        ffmpeg:
                          output_args:
                          inputs:
                              roles:
                                - detect
                              roles:
                                - record
                        rtmp:
                          enabled: False
                    detect:
                          width: 640
                          height: 480
                    objects:
                          track:
                            - person
                            - car
                            - dog
                    snapshots:
                          enabled: true
                    	  timestamp: true
                          bounding_box: true
                          retain:
                            default: 2
                    record:
                          enabled: true
                          retain:
                            days: 10
                    [fix-attrs.d] done.
                    [cont-init.d] done.
                    [services.d] done.
                    Starting migrations
                    WalW Offline
                    WalW Offline
                    Wal
                    #49
                    @exitus sagte in Proxmox LXC mit Frigate:
                    output_args:
                    Was möchtest du damit erreichen ?
                    Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
                    Walter
                    DoorIO-Adapter
                    E 1 Antwort Letzte Antwort
                    • WalW Wal
                      output_args:
                      exitus
                      #50
                      @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
                      haben annke nc400 möchte das es erkennt und aufnimmt.
                      Bei mir werden bilder gemach aber keine clips.
                      Mein kamera sendet h264
                      • E exitus
                        WalW Offline
                        WalW Offline
                        Wal
                        #51
                        @exitus ,
                        meine reolink auch und habe keinen Greenscreen.
                          camera1:
                            ffmpeg:
                              inputs:
                                - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                                  roles:
                                    - detect
                                - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                                  roles:
                                    - record
                            detect:
                              width: 640
                              height: 360
                            mqtt:
                              enabled: False
                        Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
                        Walter
                        DoorIO-Adapter
                        • E exitus
                          WalW Offline
                          WalW Offline
                          Wal
                          #52
                          @exitus ,
                          lese gerade das die Kamera auch h265 kann.
                          Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                          Walter
                          DoorIO-Adapter
                          • E Offline
                            exitus
                            #53
                            wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                            wäre nett wenn jemand schritt für schritt erklärt.
                            gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
                            • E exitus
                              WalW Offline
                              WalW Offline
                              Wal
                              #54
                              @exitus ,
                              du machst das Laufwerk unter dem Proxmox Host verfügbar z.B. unter '/media/synology' so als wäre es ein normales Laufwerk.
                              Danach gibst du in der lxc.conf den Ordner für den Frigate LXC frei.
                              arch: amd64
                              cores: 4
                              features: keyctl=1,nesting=1
                              hostname: testfrigate
                              memory: 8192
                              mp0: /media/synology,mp=/media/frigate
                              danach ist der Ordner im LXC unter '/media/frigate' verfügbar und du kannst ihn im Docker hinzufügen.
                                  volumes:
                                    - /home/frigate/config/config.yml:/config/config.yml
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                @exitus ,
                                arch: amd64
                                cores: 4
                                memory: 8192
                                    volumes:
                                exitus
                                #55
                                @wal das habe ich gemacht, ich kann auch über die Konsole vom lxc kann ich die freigabe sehen aber habe kein schreib zugriff.
                                Ich habe über den Host in fstab die freigabe eingetragen , über den Host habe ich die schreib und leserechte von der nas aber über die lxc container vo docker und frigate läuft nicht
                                • E exitus
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #56
                                  @exitus,
                                  ok da kann ich jetzt nicht helfen.
                                  Ich mache es anders rum, habe eine USB Festplatte als LXC-Backup und Datenspeicher eingerichtet und gebe diese über einen Samba LXC im Netzwerk frei. Damit habe ich Zugriff auf alle Dateien die ich im Proxmox speichere.
                                  Walter
                                  DoorIO-Adapter
                                  • E exitus
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    #57
                                    @exitus ,
                                    schau dir das mal an, könnte helfen.
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @exitus ,
                                      exitus
                                      #58
                                      @wal habe es geschafft jetz anderes problem habe 2 cameras beide machen screenshots dedection klappt bei einen habe ich clips bei den anderen nur bilder ohne clips wo kein clips sind ist die kamera mit der bezeichnung back
                                      ier mein config
                                      database:
                                        path: /media/frigate/db/frigate.db
                                      detectors:
                                        cpu1:
                                          type: cpu
                                      ui:
                                        use_experimental: false
                                        live_mode: mse
                                      mqtt:
                                        host: 172.16.0.10
                                        port: 12345
                                        user: xxxxxxx
                                        password: exxxxx
                                      cameras:
                                        back1:
                                          ffmpeg:
                                            inputs:
                                              - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=2
                                                roles:
                                                  - detect
                                                  - rtmp
                                              - path: rtsp://admin:xxxxxxx@172.16.0.177:554/channel=1
                                                roles:
                                                  - record
                                        back:
                                          ffmpeg:
                                            inputs:
                                              - path: rtsp://admin:xxxxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                                roles:
                                                  - detect
                                                  - rtmp
                                                roles:
                                                  - record
                                      detect:
                                            width: 640
                                            height: 480
                                            fps: 5
                                      objects:
                                            track:
                                              - person
                                              - dog
                                              - bicycle
                                              - cat
                                            filters:
                                              person:
                                                min_score: 0.7
                                                threshold: 0.5
                                                min_area: 700
                                      snapshots:
                                            enabled: true
                                            timestamp: true
                                            bounding_box: true
                                            crop: True
                                            height: 500
                                            retain:
                                              default: 1
                                      record:
                                        enabled: True
                                        events:
                                          retain:
                                            default: 10
                                      birdseye:
                                        enabled: True
                                        mode: continuous
                                      • E exitus
                                        ier mein config
                                        database:
                                        detectors:
                                          cpu1:
                                            type: cpu
                                        ui:
                                          live_mode: mse
                                        mqtt:
                                          host: 172.16.0.10
                                          port: 12345
                                          user: xxxxxxx
                                          password: exxxxx
                                        cameras:
                                          back1:
                                            ffmpeg:
                                              inputs:
                                                  roles:
                                                    - detect
                                                    - rtmp
                                                  roles:
                                                    - record
                                          back:
                                            ffmpeg:
                                              inputs:
                                                  roles:
                                                    - detect
                                                    - rtmp
                                                  roles:
                                                    - record
                                        detect:
                                              width: 640
                                              height: 480
                                              fps: 5
                                        objects:
                                              track:
                                                - person
                                                - dog
                                                - bicycle
                                                - cat
                                              filters:
                                                person:
                                                  min_score: 0.7
                                                  threshold: 0.5
                                                  min_area: 700
                                        snapshots:
                                              enabled: true
                                              timestamp: true
                                              bounding_box: true
                                              crop: True
                                              height: 500
                                              retain:
                                                default: 1
                                        record:
                                          enabled: True
                                          events:
                                            retain:
                                              default: 10
                                        birdseye:
                                          enabled: True
                                          mode: continuous
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        #59
                                        @exitus ,
                                        schau mal im Adapter ob das dort eingeschaltet ist.
                                        Walter
                                        DoorIO-Adapter
                                        • WalW Wal
                                          @exitus ,
                                          exitus
                                          #60
                                          @wal bei mir steht OFF wo kann man es den einschalten im config ist ja true,
                                          warum ist der eine on und der andere off
