  3. Off Topic
  4. Proxmox
  5. Proxmox LXC mit Frigate
    6.3k
Geplant Angeheftet Gesperrt Verschoben Proxmox
176 Beiträge 16 Kommentatoren 67.1k Aufrufe 21 Beobachtet
  • R Radi
    @Wal Da steht letztenendes dasselbe wie im Portainerlogfile drin. Ursächlich scheint wohl dies zu sein:
    2023-05-07 14:44:51.033075103  *************************************************************
    2023-05-07 14:44:51.033078419  *************************************************************
    2023-05-07 14:44:51.033079955  ***    Your config file is not valid!                     ***
    2023-05-07 14:44:51.033081414  ***    Please check the docs at                           ***
    2023-05-07 14:44:51.033082613  ***    https://docs.frigate.video/configuration/index     ***
    2023-05-07 14:44:51.033083997  *************************************************************
    2023-05-07 14:44:51.033085013  *************************************************************
    2023-05-07 14:44:51.033092726  ***    Config Validation Errors                           ***
    2023-05-07 14:44:51.033093828  *************************************************************
    2023-05-07 14:44:51.033094705  [Errno 21] Is a directory: '/config/config.yml'
    2023-05-07 14:44:51.033656750  Traceback (most recent call last):
    2023-05-07 14:44:51.033658821    File "/opt/frigate/frigate/app.py", line 351, in start
    2023-05-07 14:44:51.033659876      self.init_config()
    2023-05-07 14:44:51.033660984    File "/opt/frigate/frigate/app.py", line 80, in init_config
    2023-05-07 14:44:51.033661995      user_config = FrigateConfig.parse_file(config_file)
    2023-05-07 14:44:51.033662995    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
    2023-05-07 14:44:51.033663850      with open(config_file) as f:
    2023-05-07 14:44:51.033664794  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
    2023-05-07 14:44:51.033665538
    2023-05-07 14:44:51.033666509  *************************************************************
    2023-05-07 14:44:51.033667457  ***    End Config Validation Errors                       ***
    2023-05-07 14:44:51.033668354  **********************************************************
    Nur weiß ich nicht, wie man diesen "IsADirectoryError" korrigiert. Findet Frigate in dem angegebenen Pfad nichts? Oder hat dies eine andere Ursache? Den Screenshot aus dem Filezilla habe ich ja schon weiter oben gepostet. Mit meinem bescheidenen oder nicht vorhandenen Wissen würde ich annehmen, dass der Pfad zur config.yaml so passt.
    WalW Offline
    WalW Offline
    Wal
    schrieb am zuletzt editiert von Wal
    @radi ,
    mach mal im Container diesen Befehl:
    cat /config/config.yml
    Walter
    DoorIO-Adapter
    R 1 Antwort Letzte Antwort
    • WalW Wal
      @radi ,
      Radi
      schrieb am zuletzt editiert von Radi
      @wal sagte in Proxmox LXC mit Frigate:
      Hallo Walter,
      das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
      cat: /config/config.yml: No such file or directory
      will ich das Verzeichnis erzeugen, kommt das:
      mkdir config
      mkdir: cannot create directory 'config': File exists
      Will ich mit nano eine neue config erzeugen kommt:
        GNU nano 6.4                        /config/config.yml
                               [ Directory '/config' does not exist ]
      ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
      ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
      Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
      ~/config# cat config.yml
      detectors:
        cpu1:
          type: cpu
      mqtt:
        host: 192.168.69.159
        user: user
        password: xxx
      cameras:
        back:
          ffmpeg:
            hwaccel_args: preset-vaapi
            inputs:
              - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                roles:
                  - detect
              - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                roles:
                  - record
          detect:
            width: 640
            height: 360
          mqtt:
            enabled: False
         objects:
            track:
              - person
              - car
              - truck
              - bicycle
              - motorcycle
              - dog
              - cat
      snapshots:
        enabled: True
        timestamp: False
        bounding_box: False
        crop: False
        height: 175
        required_zones: []
        retain:
          default: 10
          objects:
                person: 15
      record:
        enabled: True
        retain:
          days: 7
          mode: motion
        events:
          retain:
            default: 14
            mode: active_objects
            objects:
              person: 14
              dog: 2
              car: 7
      WalW holzapfelaugeH 2 Antworten Letzte Antwort
      • R Radi
        Hallo Walter,
        mkdir config
        detectors:
          cpu1:
            type: cpu
        mqtt:
          user: user
          password: xxx
        cameras:
          back:
            ffmpeg:
              inputs:
                  roles:
                    - detect
                  roles:
                    - record
            detect:
              width: 640
              height: 360
            mqtt:
              enabled: False
           objects:
              track:
                - person
                - car
                - truck
                - bicycle
                - motorcycle
                - dog
                - cat
        snapshots:
          enabled: True
          timestamp: False
          bounding_box: False
          crop: False
          height: 175
          required_zones: []
          retain:
            default: 10
            objects:
                  person: 15
        record:
          enabled: True
          retain:
            days: 7
            mode: motion
          events:
            retain:
              default: 14
              objects:
                person: 14
                dog: 2
                car: 7
        WalW Offline
        WalW Offline
        Wal
        @radi ,
        du musst da aufpassen.
        Im Docker-Container muss man diese Datei nicht erzeugen, die zeigt nur auf die Datei im LXC.
              - /home/frigate/frigate/config.yml:/config/config.yml
        also die Datei im LXC "/home/frigate/frigate/config.yml" wird im Docker auf "/config/config.yml" gemappt.
        das geht automatisch. Du musst nur die Datei wie hier im LXC "/home/frigate/frigate/config.yml" oder wie in deiner Docker-Config angegeben erzeugen.
        edit: oder mappst du die Datei in der Docker-Config gar nicht auf "/config/config.yml"
        editedit: der Docker Container ist fertig eingerichtet, da muss nichts verändert werden.
        Walter
        DoorIO-Adapter
        • WalW Wal
          Nachdem ich mir eine CORAL M.2 ACCELERATOR MIT DUAL EDGE TPU und ein Dual Edge TPU Adapter bestellt habe, wurde Frigate auf Proxmox installiert.
          Skript von TTeck
          Proxmox-Console Ubuntu Lunar installieren:
          bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/ct/ubuntu.sh)"
          • Use Default Settings? -> Advanced
          • Choose Distribution: -> ubuntu
          • Choose Version -> 23.04 Lunar
          • Choose Type -> 1 Unprivileged
          • Set Disk Size in GB -> 4GB, wenn Videos lokal abgelegt werden sollen erhöhen.
          • Allocate CPU Cores -> min. 2, je mehr Kameras desto mehr Cores
          • Allocate Ram in MiB -> min. 2048, je mehr Kameras desto mehr Speicher
          • Set a Static IPv4 -> besser ist es
          • Disable IPv6? -> besser ist es
          • Enable Root SSH Access? -> nein
          FrigateLXC als root:
          adduser frigate
          adduser frigate sudo
          exit
          FrigateLXC als User frigate:
          sudo apt-get install ca-certificates curl gnupg
          sudo install -m 0755 -d /etc/apt/keyrings
          curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
          sudo chmod a+r /etc/apt/keyrings/docker.gpg
          echo "deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu "$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
          sudo apt update
          sudo apt install docker-ce docker-ce-cli containerd.io docker-compose-plugin
          sudo adduser frigate docker
          exit
          FrigateLXC als User frigate neu anmelden:
          docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce
          sudo systemctl status docker
          sudo /lib/systemd/systemd-sysv-install enable docker
          mkdir frigate
          cd frigate
          nano docker-compose.yml
          docker-compose.yml:
          version: "3.9"
          services:
            frigate:
              container_name: frigate
              privileged: true # this may not be necessary for all setups
              restart: unless-stopped
              image: ghcr.io/blakeblackshear/frigate:stable
              shm_size: "64mb" # update for your cameras based on calculation above
              cap_add:
                - CAP_PERFMON
              devices:
                - /dev/apex_0:/dev/apex_0
                - /dev/apex_1:/dev/apex_1
                - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
              volumes:
                - /etc/localtime:/etc/localtime:ro
                - /media/frigate:/media/frigate
                - type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
                  target: /tmp/cache
                  tmpfs:
              ports:
                - "5000:5000"
                - "1935:1935" # RTMP feeds
          Achtung ab Frigate 13 muss der komplette Frigate-Pfad angegeben werden nicht die config.yml:
          - /home/frigate/frigate:/config
          nano config.yml
          die minimale config.yml:
          mqtt:
            enabled: False
          cameras:
            back:
              ffmpeg:
                inputs:
                  - path: rtsp://User:PW@192.168.69.162:554/h264Preview_01_main
                    roles:
                      - detect
              detect:
                enabled: False
                width: 640
                height: 480
          docker starten:
          docker compose up -d
          exit
          http://deineIP:5000
          exitus
          schrieb am zuletzt editiert von exitus
          danke euch allen
          mit viel grübeln habe ich frigate am laufen aber nur minimal.
          habe ein camera eingebunden mit minimal config rest mache ich weiter wenn mein tpu da ist.
          • E Offline
            exitus
            ich habe kamera eingebunden habe aber ein greenscreen nur
            woran kann es liegen???
            erledigt
            • E Offline
              exitus
              Hallo was ist an diesem config falsch
              detectors:
                cpu1:
                  type: cpu
              database:
                  path: /db/frigate.db
              mqtt:
                host: 172.16.0.10
                port: 1689
                user: admin
                password: passwort
              cameras:
                Parkplatz:
                  ffmpeg:
                    output_args:
                      record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
                      rtmp: -c:v copy -c:a aac -f flv
                    inputs:
              	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                        roles:
                          - detect
                          - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                        roles:
                          - record
                  rtmp:
                    enabled: False
              detect:
                    width: 640
                    height: 480
              objects:
                    track:
                      - person
                      - car
                      - dog
              snapshots:
                    enabled: true
              	  timestamp: true
                    bounding_box: true
                    retain:
                      default: 2
              record:
                    enabled: true
                    retain:
                      days: 10
              was sind das für errors
              [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
              [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              [cont-finish.d] executing container finish scripts...
              [cont-finish.d] done.
              [s6-finish] waiting for services.
              [s6-finish] sending all processes the TERM signal.
              [s6-finish] sending all processes the KILL signal and exiting.
              [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
              [s6-init] ensuring user provided files have correct perms...exited 0.
              [fix-attrs.d] applying ownership & permissions fixes...
              [fix-attrs.d] done.
              [cont-init.d] executing container initialization scripts...
              [cont-init.d] done.
              [services.d] starting services
              [services.d] done.
              [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
              Starting migrations
              [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
              There is nothing to migrate
              [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
              [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
              [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
              [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
              [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
              [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
              [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
              [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
              [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
              [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
              [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
              [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
              [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
              [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
              snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
              WalW 1 Antwort Letzte Antwort
              • E exitus
                detectors:
                  cpu1:
                    type: cpu
                database:
                mqtt:
                  host: 172.16.0.10
                  port: 1689
                  user: admin
                  password: passwort
                cameras:
                  Parkplatz:
                    ffmpeg:
                      output_args:
                      inputs:
                          roles:
                            - detect
                          roles:
                            - record
                    rtmp:
                      enabled: False
                detect:
                      width: 640
                      height: 480
                objects:
                      track:
                        - person
                        - car
                        - dog
                snapshots:
                      enabled: true
                	  timestamp: true
                      bounding_box: true
                      retain:
                        default: 2
                record:
                      enabled: true
                      retain:
                        days: 10
                [fix-attrs.d] done.
                [cont-init.d] done.
                [services.d] done.
                Starting migrations
                WalW Offline
                WalW Offline
                Wal
                @exitus sagte in Proxmox LXC mit Frigate:
                output_args:
                Was möchtest du damit erreichen ?
                Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
                Walter
                DoorIO-Adapter
                E 1 Antwort Letzte Antwort
                • WalW Wal
                  output_args:
                  exitus
                  @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
                  haben annke nc400 möchte das es erkennt und aufnimmt.
                  Bei mir werden bilder gemach aber keine clips.
                  Mein kamera sendet h264
                  WalW 2 Antworten Letzte Antwort
                  • E exitus
                    WalW Offline
                    WalW Offline
                    Wal
                    @exitus ,
                    meine reolink auch und habe keinen Greenscreen.
                      camera1:
                        ffmpeg:
                          inputs:
                            - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                              roles:
                                - detect
                            - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                              roles:
                                - record
                        detect:
                          width: 640
                          height: 360
                        mqtt:
                          enabled: False
                    Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
                    Walter
                    DoorIO-Adapter
                    • E exitus
                      WalW Offline
                      WalW Offline
                      Wal
                      @exitus ,
                      lese gerade das die Kamera auch h265 kann.
                      Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                      Walter
                      DoorIO-Adapter
                      • E Offline
                        exitus
                        wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                        wäre nett wenn jemand schritt für schritt erklärt.
                        gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
                        • E exitus
                          WalW Offline
                          WalW Offline
                          Wal
                          @exitus ,
                          du machst das Laufwerk unter dem Proxmox Host verfügbar z.B. unter '/media/synology' so als wäre es ein normales Laufwerk.
                          Danach gibst du in der lxc.conf den Ordner für den Frigate LXC frei.
                          arch: amd64
                          cores: 4
                          features: keyctl=1,nesting=1
                          hostname: testfrigate
                          memory: 8192
                          mp0: /media/synology,mp=/media/frigate
                          danach ist der Ordner im LXC unter '/media/frigate' verfügbar und du kannst ihn im Docker hinzufügen.
                              volumes:
                                - /home/frigate/config/config.yml:/config/config.yml
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @exitus ,
                            arch: amd64
                            cores: 4
                            memory: 8192
                                volumes:
                            exitus
                            @wal das habe ich gemacht, ich kann auch über die Konsole vom lxc kann ich die freigabe sehen aber habe kein schreib zugriff.
                            Ich habe über den Host in fstab die freigabe eingetragen , über den Host habe ich die schreib und leserechte von der nas aber über die lxc container vo docker und frigate läuft nicht
                            • E exitus
                              WalW Offline
                              WalW Offline
                              Wal
                              @exitus,
                              ok da kann ich jetzt nicht helfen.
                              Ich mache es anders rum, habe eine USB Festplatte als LXC-Backup und Datenspeicher eingerichtet und gebe diese über einen Samba LXC im Netzwerk frei. Damit habe ich Zugriff auf alle Dateien die ich im Proxmox speichere.
                              Walter
                              DoorIO-Adapter
                              • E exitus
                                WalW Offline
                                WalW Offline
                                Wal
                                @exitus ,
                                schau dir das mal an, könnte helfen.
                                Walter
                                DoorIO-Adapter
                                • WalW Wal
                                  @exitus ,
                                  exitus
                                  @wal habe es geschafft jetz anderes problem habe 2 cameras beide machen screenshots dedection klappt bei einen habe ich clips bei den anderen nur bilder ohne clips wo kein clips sind ist die kamera mit der bezeichnung back
                                  ier mein config
                                  database:
                                    path: /media/frigate/db/frigate.db
                                  detectors:
                                    cpu1:
                                      type: cpu
                                  ui:
                                    use_experimental: false
                                    live_mode: mse
                                  mqtt:
                                    host: 172.16.0.10
                                    port: 12345
                                    user: xxxxxxx
                                    password: exxxxx
                                  cameras:
                                    back1:
                                      ffmpeg:
                                        inputs:
                                          - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=2
                                            roles:
                                              - detect
                                              - rtmp
                                          - path: rtsp://admin:xxxxxxx@172.16.0.177:554/channel=1
                                            roles:
                                              - record
                                    back:
                                      ffmpeg:
                                        inputs:
                                          - path: rtsp://admin:xxxxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                            roles:
                                              - detect
                                              - rtmp
                                            roles:
                                              - record
                                  detect:
                                        width: 640
                                        height: 480
                                        fps: 5
                                  objects:
                                        track:
                                          - person
                                          - dog
                                          - bicycle
                                          - cat
                                        filters:
                                          person:
                                            min_score: 0.7
                                            threshold: 0.5
                                            min_area: 700
                                  snapshots:
                                        enabled: true
                                        timestamp: true
                                        bounding_box: true
                                        crop: True
                                        height: 500
                                        retain:
                                          default: 1
                                  record:
                                    enabled: True
                                    events:
                                      retain:
                                        default: 10
                                  birdseye:
                                    enabled: True
                                    mode: continuous
                                  • E exitus
                                    ier mein config
                                    database:
                                    detectors:
                                      cpu1:
                                        type: cpu
                                    ui:
                                      live_mode: mse
                                    mqtt:
                                      host: 172.16.0.10
                                      port: 12345
                                      user: xxxxxxx
                                      password: exxxxx
                                    cameras:
                                      back1:
                                        ffmpeg:
                                          inputs:
                                              roles:
                                                - detect
                                                - rtmp
                                              roles:
                                                - record
                                      back:
                                        ffmpeg:
                                          inputs:
                                              roles:
                                                - detect
                                                - rtmp
                                              roles:
                                                - record
                                    detect:
                                          width: 640
                                          height: 480
                                          fps: 5
                                    objects:
                                          track:
                                            - person
                                            - dog
                                            - bicycle
                                            - cat
                                          filters:
                                            person:
                                              min_score: 0.7
                                              threshold: 0.5
                                              min_area: 700
                                    snapshots:
                                          enabled: true
                                          timestamp: true
                                          bounding_box: true
                                          crop: True
                                          height: 500
                                          retain:
                                            default: 1
                                    record:
                                      enabled: True
                                      events:
                                        retain:
                                          default: 10
                                    birdseye:
                                      enabled: True
                                      mode: continuous
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    @exitus ,
                                    schau mal im Adapter ob das dort eingeschaltet ist.
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @exitus ,
                                      exitus
                                      @wal bei mir steht OFF wo kann man es den einschalten im config ist ja true,
                                      warum ist der eine on und der andere off
                                      • E exitus
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        @exitus ,
                                        state ist nur der Status und mit Set kann man an und ausschalten.
                                        Walter
                                        DoorIO-Adapter
                                        • E Offline
                                          exitus
                                          mein coral cpu ist das was habe ich gemacht habe unter proxmox wie auf der seite von coral installiert
                                          ausgabe lsusb
                                          Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                          Bus 003 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
                                          Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                          Bus 002 Device 002: ID 1a6e:089a Global Unichip Corp.
                                          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                          Bus 001 Device 003: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                          Bus 001 Device 002: ID 0451:16c8 Texas Instruments, Inc. CC2538 USB CDC
                                          ls -l /dev/bus/usb/002/002
                                          crw-rw-r-- 1 root plugdev 189, 129 May 24 16:13 /dev/bus/usb/002/002
                                          lxc 117.conf
                                          arch: amd64
                                          cores: 6
                                          hostname: frigate
                                          memory: 8096
                                          net0: name=eth0,bridge=vmbr0,firewall=1,gw=172.16.0.1,hwaddr=22:88:33:2D:28:77,ip=172.1>
                                          ostype: debian
                                          rootfs: local-lvm:vm-117-disk-1,size=30G
                                          swap: 512
                                          lxc.cgroup.devices.allow: c 226:0 rwm
                                          lxc.cgroup.devices.allow: c 226:128 rwm
                                          lxc.cgroup.devices.allow: c 29:0 rwm
                                          lxc.cgroup.devices.allow: c 189:* rwm
                                          lxc.apparmor.profile: unconfined
                                          lxc.cgroup.devices.allow: a
                                          lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file >
                                          lxc.mount.entry: /dev/bus/usb/002/ dev/bus/usb/002/ none bind,optional,create=dir 0, 0
                                          lxc.cap.drop:
                                          lxc.mount.auto: cgroup:rw
                                          frigate conf
                                          database:
                                          detectors:
                                            coral:
                                              type: edgetpu
                                              device: usb
                                          ui:
                                            live_mode: mse
                                          mqtt:
                                            host: 172.16.0.10
                                            port: 1689
                                            user: so
                                            password: xxxxx
                                          record:
                                            enabled: True
                                            retain:
                                              days: 7
                                              mode: all
                                            events:
                                              retain:
                                                default: 30
                                          snapshots:
                                            enabled: True
                                            timestamp: False
                                            bounding_box: true
                                            retain:
                                              default: 90
                                          detect:
                                            stationary:
                                              max_frames:
                                                objects:
                                                  person: 1200
                                          cameras:
                                            back1:
                                              ffmpeg:
                                                inputs:
                                                  - path: rtsp://admin:xxxxxx@172.16.0.177:554/channel=2
                                                    roles:
                                                      - detect
                                                      - rtmp
                                                  - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=1
                                                    roles:
                                                      - record
                                                output_args:
                                                  record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v copy -c:a aac
                                              detect:
                                                width: 1280
                                                height: 720
                                              objects:
                                                track:
                                                  - person
                                                  - car
                                              record:
                                                events:
                                                  required_zones:
                                                    - street
                                                    - all
                                              zones:
                                                street:
                                                  coordinates: 352,544,416,519,476,513,502,334,472,199,391,107,325,127,261,136,62,162,45,347,59,430,207,535
                                                  objects:
                                                    - car
                                                all:
                                                  objects:
                                                    - person
                                              motion:
                                                mask:
                                                  - 254,79,503,44,848,24,1113,43,1111,0,439,0,291,0,226,0,0,0,0,159
                                            back:
                                              ffmpeg:
                                                inputs:
                                                  - path: rtsp://admin:xxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                                    roles:
                                                      - detect
                                                      - rtmp
                                                    roles:
                                                      - record
                                              detect:
                                                width: 1280
                                                height: 720
                                              objects:
                                                track:
                                                  - person
                                                  - car
                                              record:
                                                events:
                                                  required_zones:
                                                    - street
                                                    - all
                                              zones:
                                                street:
                                                  coordinates: 470,676,592,583,1051,569,1257,341,1147,254,1063,247,779,299,536,378,476,471,389,399,332,473,241,427,293,647
                                                  objects:
                                                    - person
                                                #all:
                                                  #coordinates: 472,57,526,64,1031,129,1060,95,941,30,504,26,376,0,175,0,0,0,33,169,191,143,360,110
                                                  #objects:
                                                   # - person
                                          ohne edge tpu ging es , habe detector auf edgetpu geänder seit dem habe ich kein bild kommt so für 1 sekunde und wider alles schwarz wie auf dem bild
                                          mein log vom docker
                                          2023-05-24 16:34:48.086320180
                                          2023-05-24 16:34:53.211082426  [2023-05-24 16:34:53] frigate.watchdog               INFO    : Detection appears to have stopped. Exiting Frigate...
                                          s6-rc: info: service legacy-services: stopping
                                          s6-rc: info: service legacy-services successfully stopped
                                          s6-rc: info: service nginx: stopping
                                          s6-rc: info: service go2rtc-healthcheck: stopping
                                          2023-05-24 16:34:53.227039323  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
                                          s6-rc: info: service go2rtc-healthcheck successfully stopped
                                          2023-05-24 16:34:53.305962172  [INFO] Service NGINX exited with code 0 (by signal 0)
                                          s6-rc: info: service nginx successfully stopped
                                          s6-rc: info: service nginx-log: stopping
                                          s6-rc: info: service frigate: stopping
                                          2023-05-24 16:34:53.309352767  [2023-05-24 16:34:53] frigate.app                    INFO    : Stopping...
                                          s6-rc: info: service nginx-log successfully stopped
                                          2023-05-24 16:34:53.311354844  [2023-05-24 16:34:53] frigate.watchdog               INFO    : Exiting watchdog...
                                          2023-05-24 16:34:53.312088389  [2023-05-24 16:34:53] frigate.storage                INFO    : Exiting storage maintainer...
                                          2023-05-24 16:34:53.312100611  [2023-05-24 16:34:53] frigate.stats                  INFO    : Exiting stats emitter...
                                          2023-05-24 16:34:53.312107805  [2023-05-24 16:34:53] frigate.record                 INFO    : Exiting recording maintenance...
                                          2023-05-24 16:34:53.320612754  [2023-05-24 16:34:53] frigate.record                 INFO    : Exiting recording cleanup...
                                          2023-05-24 16:34:53.321374794  [2023-05-24 16:34:53] frigate.events                 INFO    : Exiting event cleanup...
                                          2023-05-24 16:34:53.321393162  [2023-05-24 16:34:53] frigate.object_processing      INFO    : Exiting object processor...
                                          2023-05-24 16:34:53.571418465  [2023-05-24 16:34:53] frigate.comms.ws               INFO    : Exiting websocket client...
                                          2023-05-24 16:34:54.249977376  [2023-05-24 16:34:54] frigate.events                 INFO    : Exiting event processor...
                                          2023-05-24 16:34:54.250550076  [2023-05-24 16:34:54] peewee.sqliteq                 INFO    : writer received shutdown request, exiting.
                                          2023-05-24 16:34:54.259106288  [2023-05-24 16:34:54] watchdog.back                  INFO    : Terminating the existing ffmpeg process...
                                          2023-05-24 16:34:54.259777814  [2023-05-24 16:34:54] watchdog.back                  INFO    : Waiting for ffmpeg to exit gracefully...
                                          2023-05-24 16:34:54.266624376  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Terminating the existing ffmpeg process...
                                          2023-05-24 16:34:54.266775374  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Waiting for ffmpeg to exit gracefully...
                                          2023-05-24 16:34:54.383145698  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Terminating the existing ffmpeg process...
                                          2023-05-24 16:34:54.383311572  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Waiting for ffmpeg to exit gracefully...
                                          2023-05-24 16:34:54.415749456  [2023-05-24 16:34:54] watchdog.back                  INFO    : Terminating the existing ffmpeg process...
                                          2023-05-24 16:34:54.415853799  [2023-05-24 16:34:54] watchdog.back                  INFO    : Waiting for ffmpeg to exit gracefully...
                                          2023-05-24 16:34:54.637141769  [2023-05-24 16:34:54] frigate.output                 INFO    : exiting output process...
                                          2023-05-24 16:34:58.559268884  /usr/lib/python3.9/multiprocessing/resource_tracker.py:216: UserWarning: resource_tracker: There appear to be 13 leaked shared_memory objects to clean up at shutdown
                                          2023-05-24 16:34:58.559280338    warnings.warn('resource_tracker: There appear to be %d '
                                          2023-05-24 16:34:58.560386418  [INFO] Service Frigate exited with code 0 (by signal 0)
                                          s6-rc: info: service frigate successfully stopped
                                          s6-rc: info: service go2rtc: stopping
                                          s6-rc: info: service frigate-log: stopping
                                          2023-05-24 16:34:58.563280091  exit OK
                                          s6-rc: info: service frigate-log successfully stopped
                                          2023-05-24 16:34:58.570563372  [INFO] The go2rtc service exited with code 0 (by signal 0)
                                          s6-rc: info: service go2rtc successfully stopped
                                          s6-rc: info: service go2rtc-log: stopping
                                          s6-rc: info: service go2rtc-log successfully stopped
                                          s6-rc: info: service log-prepare: stopping
                                          s6-rc: info: service s6rc-fdholder: stopping
                                          s6-rc: info: service log-prepare successfully stopped
                                          s6-rc: info: service legacy-cont-init: stopping
                                          s6-rc: info: service s6rc-fdholder successfully stopped
                                          s6-rc: info: service legacy-cont-init successfully stopped
                                          s6-rc: info: service fix-attrs: stopping
                                          s6-rc: info: service fix-attrs successfully stopped
                                          s6-rc: info: service s6rc-oneshot-runner: stopping
                                          s6-rc: info: service s6rc-oneshot-runner successfully stopped
                                          s6-rc: info: service s6rc-fdholder: starting
                                          s6-rc: info: service s6rc-oneshot-runner: starting
                                          s6-rc: info: service s6rc-oneshot-runner successfully started
                                          s6-rc: info: service fix-attrs: starting
                                          s6-rc: info: service s6rc-fdholder successfully started
                                          s6-rc: info: service fix-attrs successfully started
                                          s6-rc: info: service legacy-cont-init: starting
                                          s6-rc: info: service legacy-cont-init successfully started
                                          s6-rc: info: service log-prepare: starting
                                          s6-rc: info: service log-prepare successfully started
                                          s6-rc: info: service nginx-log: starting
                                          s6-rc: info: service go2rtc-log: starting
                                          s6-rc: info: service frigate-log: starting
                                          s6-rc: info: service nginx-log successfully started
                                          s6-rc: info: service go2rtc-log successfully started
                                          s6-rc: info: service go2rtc: starting
                                          s6-rc: info: service frigate-log successfully started
                                          s6-rc: info: service go2rtc successfully started
                                          s6-rc: info: service go2rtc-healthcheck: starting
                                          s6-rc: info: service frigate: starting
                                          s6-rc: info: service go2rtc-healthcheck successfully started
                                          s6-rc: info: service frigate successfully started
                                          s6-rc: info: service nginx: starting
                                          2023-05-24 16:35:03.269511637  [INFO] Preparing go2rtc config...
                                          s6-rc: info: service nginx successfully started
                                          s6-rc: info: service legacy-services: starting
                                          2023-05-24 16:35:03.274350536  [INFO] Starting Frigate...
                                          2023-05-24 16:35:03.274655883  [INFO] Starting NGINX...
                                          s6-rc: info: service legacy-services successfully started
                                          2023-05-24 16:35:03.544117376  [INFO] Starting go2rtc...
                                          2023-05-24 16:35:03.635953359  16:35:03.635 INF go2rtc version 1.2.0 linux/amd64
                                          2023-05-24 16:35:03.636486320  16:35:03.636 INF [api] listen addr=:1984
                                          2023-05-24 16:35:03.636814435  16:35:03.636 INF [rtsp] listen addr=:8554
                                          2023-05-24 16:35:03.637127674  16:35:03.637 INF [srtp] listen addr=:8443
                                          2023-05-24 16:35:03.637534711  16:35:03.637 INF [webrtc] listen addr=:8555
                                          2023-05-24 16:35:04.485742533  [2023-05-24 16:35:04] frigate.app                    INFO    : Starting Frigate (0.12.0-da3e197)
                                          2023-05-24 16:35:04.527219793  [2023-05-24 16:35:04] peewee_migrate                 INFO    : Starting migrations
                                          2023-05-24 16:35:04.531970132  [2023-05-24 16:35:04] peewee_migrate                 INFO    : There is nothing to migrate
                                          2023-05-24 16:35:04.549606158  [2023-05-24 16:35:04] detector.coral                 INFO    : Starting detection process: 429
                                          2023-05-24 16:35:04.554122319  [2023-05-24 16:35:04] frigate.app                    INFO    : Output process started: 431
                                          2023-05-24 16:35:04.561305867  [2023-05-24 16:35:04] frigate.app                    INFO    : Camera processor started for back1: 437
                                          2023-05-24 16:35:04.570196340  [2023-05-24 16:35:04] frigate.app                    INFO    : Camera processor started for back: 439
                                          2023-05-24 16:35:04.576351891  [2023-05-24 16:35:04] frigate.app                    INFO    : Capture process started for back1: 440
                                          2023-05-24 16:35:04.582484533  [2023-05-24 16:35:04] frigate.app                    INFO    : Capture process started for back: 444
                                          2023-05-24 16:35:13.274499111  [INFO] Starting go2rtc healthcheck service...
