  3. Off Topic
  4. Proxmox
  5. Proxmox LXC mit Frigate
    6.3k
Geplant Angeheftet Gesperrt Verschoben Proxmox
176 Beiträge 16 Kommentatoren 67.1k Aufrufe 21 Beobachtet
  • E exitus
    @wal hallo welche lxc hast du genommen bei mir gibt es fehler mit pfad findet config nicht frigate geht in bootschleife .
    habe ubuntu 22.1
        detectors:
    expected <block end>, but found '<block mapping start>'
      in "<unicode string>", line 9, column 2:
         cameras:
    2023-05-07 12:39:35.229716379  [INFO] The go2rtc service exited with code 1 (by signal 0)
    2023-05-07 12:39:36.234223582  [INFO] Preparing go2rtc config...
    Traceback (most recent call last):
      File "/usr/local/go2rtc/create_config.py", line 27, in <module>
        config: dict[str, any] = yaml.safe_load(raw_config)
      File "/usr/local/lib/python3.9/dist-packages/yaml/__init__.py", line 125, in safe_load
        return load(stream, SafeLoader)
      File "/usr/local/lib/python3.9/dist-packages/yaml/__init__.py", line 81, in load
        return loader.get_single_data()
      File "/usr/local/lib/python3.9/dist-packages/yaml/constructor.py", line 49, in get_single_data
        node = self.get_single_node()
      File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 36, in get_single_node
        document = self.compose_document()
      File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 55, in compose_document
        node = self.compose_node(None, None)
      File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 84, in compose_node
        node = self.compose_mapping_node(anchor)
      File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 127, in compose_mapping_node
        while not self.check_event(MappingEndEvent):
      File "/usr/local/lib/python3.9/dist-packages/yaml/parser.py", line 98, in check_event
        self.current_event = self.state()
      File "/usr/local/lib/python3.9/dist-packages/yaml/parser.py", line 438, in parse_block_mapping_key
        raise ParserError("while parsing a block mapping", self.marks[-1],
    yaml.parser.ParserError: while parsing a block mapping
      in "<unicode string>", line 1, column 1:
        detectors:
         cameras:
    2023-05-07 12:39:36.459721903  [INFO] The go2rtc service exited with code 1 (by signal 0)
    2023-05-07 12:39:37.463508621  [INFO] Preparing go2rtc config...
        detectors:
         cameras:
    2023-05-07 12:39:37.661047849  [INFO] The go2rtc service exited with code 1 (by signal 0)
    2023-05-07 12:39:38.665754030  [INFO] Preparing go2rtc config...
        detectors:
         cameras:
    2023-05-07 12:39:38.884406556  [INFO] The go2rtc service exited with code 1 (by signal 0)
    version: "3.9"
    services:
      frigate:
        container_name: frigate
        privileged: true # this may not be necessary for all setups
        restart: unless-stopped
        image: ghcr.io/blakeblackshear/frigate:stable
        shm_size: "64mb" # update for your cameras based on calculation above
        devices:
          - /dev/bus/usb:/dev/bus/usb # passes the USB Coral, needs to be modified for other versions
          - /dev/apex_0:/dev/apex_0 # passes a PCIe Coral, follow driver instructions here https://cora>
          - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
        volumes:
          - /etc/localtime:/etc/localtime:ro
          - /frigate/config.yml:/config/config.yml:ro
          - /frigate:/media/frigate
          - type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
            target: /tmp/cache
            tmpfs:
        ports:
          - "5000:5000"
          - "1935:1935" # RTMP feeds
     volumes:
            - /root/config/config.yml:/config/config.yml:ro
            - /root/frigate:/media/frigate
    das klappte auch nicht
    WalW Offline
    WalW Offline
    Wal
    schrieb am zuletzt editiert von Wal
    @exitus,
    ich nutze das docker script von TTeck .
    Konnte da man Ubuntu auswählen ?
    Ich nutze Debian.
    /frigate/config.yml
    das kann nur funktionieren wenn im Ordner /frigate eine config.yml liegt.
    Mittlerweile habe ich einen User frigate erstellt und im Userordner einen Ordner frigate, dort liegt meine config.yml.
    - /home/frigate/frigate/config.yml:/config/config.yml
    Walter
    DoorIO-Adapter
    R 1 Antwort Letzte Antwort
    • WalW Wal
      @exitus,
      Ich nutze Debian.
      /frigate/config.yml
      Radi
      schrieb am zuletzt editiert von Radi
      @wal Ja, man kann da, zumindest bei mir, aus drei verschiedenen Versionen Ubuntu oder eben Debian auswählen.
      @exitus Wo findet man das Logfile. Ich komme nur über Portainer an ein nicht sonderlich aussagekräftiges Logfile, dass mir alle paar Sekunden ein "Container frigate exited with status code 1" ausspuckt.
      Manchmal ist es wie verhext. Ich suche ja schon eine ganze Weile, warum das bei mir nicht funktioniert.
      Jetzt habe ich im Portainer auch das Logfile für den Container Frigate gefunden. Da steht:
      s6-rc: info: service log-prepare successfully stopped
      s6-rc: info: service legacy-cont-init: stopping
      s6-rc: info: service s6rc-fdholder successfully stopped
      s6-rc: info: service legacy-cont-init successfully stopped
      s6-rc: info: service fix-attrs: stopping
      s6-rc: info: service fix-attrs successfully stopped
      s6-rc: info: service s6rc-oneshot-runner: stopping
      s6-rc: info: service s6rc-oneshot-runner successfully stopped
      s6-rc: info: service s6rc-fdholder: starting
      s6-rc: info: service s6rc-oneshot-runner: starting
      s6-rc: info: service s6rc-oneshot-runner successfully started
      s6-rc: info: service fix-attrs: starting
      s6-rc: info: service s6rc-fdholder successfully started
      s6-rc: info: service fix-attrs successfully started
      s6-rc: info: service legacy-cont-init: starting
      s6-rc: info: service legacy-cont-init successfully started
      s6-rc: info: service log-prepare: starting
      s6-rc: info: service log-prepare successfully started
      s6-rc: info: service nginx-log: starting
      s6-rc: info: service go2rtc-log: starting
      s6-rc: info: service frigate-log: starting
      s6-rc: info: service nginx-log successfully started
      s6-rc: info: service go2rtc-log successfully started
      s6-rc: info: service go2rtc: starting
      s6-rc: info: service frigate-log successfully started
      s6-rc: info: service go2rtc successfully started
      s6-rc: info: service go2rtc-healthcheck: starting
      s6-rc: info: service frigate: starting
      s6-rc: info: service go2rtc-healthcheck successfully started
      s6-rc: info: service frigate successfully started
      s6-rc: info: service nginx: starting
      2023-05-07 13:43:21.141928870  [INFO] Preparing go2rtc config...
      s6-rc: info: service nginx successfully started
      s6-rc: info: service legacy-services: starting
      2023-05-07 13:43:21.143878913  [INFO] Starting NGINX...
      s6-rc: info: service legacy-services successfully started
      2023-05-07 13:43:21.151714209  [INFO] Starting Frigate...
        File "/usr/local/go2rtc/create_config.py", line 23, in <module>
          with open(config_file) as f:
      IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
      2023-05-07 13:43:21.323364168  [INFO] The go2rtc service exited with code 1 (by signal 0)
      2023-05-07 13:43:21.841745413  *************************************************************
      2023-05-07 13:43:21.841749020  *************************************************************
      2023-05-07 13:43:21.841750573  ***    Your config file is not valid!                     ***
      2023-05-07 13:43:21.841752110  ***    Please check the docs at                           ***
      2023-05-07 13:43:21.841753273  ***    https://docs.frigate.video/configuration/index     ***
      2023-05-07 13:43:21.841754729  *************************************************************
      2023-05-07 13:43:21.841755781  *************************************************************
      2023-05-07 13:43:21.841763459  ***    Config Validation Errors                           ***
      2023-05-07 13:43:21.841764598  *************************************************************
      2023-05-07 13:43:21.841765506  [Errno 21] Is a directory: '/config/config.yml'
      2023-05-07 13:43:21.842565222  Traceback (most recent call last):
      2023-05-07 13:43:21.842567276    File "/opt/frigate/frigate/app.py", line 351, in start
      2023-05-07 13:43:21.842568370      self.init_config()
      2023-05-07 13:43:21.842569532    File "/opt/frigate/frigate/app.py", line 80, in init_config
      2023-05-07 13:43:21.842570616      user_config = FrigateConfig.parse_file(config_file)
      2023-05-07 13:43:21.842571677    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
      2023-05-07 13:43:21.842572588      with open(config_file) as f:
      2023-05-07 13:43:21.842573621  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
      2023-05-07 13:43:21.842574440
      2023-05-07 13:43:21.842575493  *************************************************************
      2023-05-07 13:43:21.842576482  ***    End Config Validation Errors                       ***
      2023-05-07 13:43:21.842577477  *************************************************************
      2023-05-07 13:43:21.842645337  [2023-05-07 13:43:21] frigate.app                    INFO    : Starting Frigate (0.12.0-da3e197)
      2023-05-07 13:43:22.326572470  [INFO] Preparing go2rtc config...
      2023-05-07 13:43:22.445020382  [INFO] The go2rtc service exited with code 1 (by signal 0)
      2023-05-07 13:43:22.932425363  [INFO] Service Frigate exited with code 1 (by signal 0)
      s6-rc: info: service legacy-services: stopping
      s6-rc: info: service legacy-services successfully stopped
      s6-rc: info: service nginx: stopping
      s6-rc: info: service go2rtc-healthcheck: stopping
      2023-05-07 13:43:22.937461001  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
      s6-rc: info: service go2rtc-healthcheck successfully stopped
      2023-05-07 13:43:23.051822574  [INFO] Service NGINX exited with code 0 (by signal 0)
      s6-rc: info: service nginx successfully stopped
      s6-rc: info: service nginx-log: stopping
      s6-rc: info: service frigate: stopping
      s6-rc: info: service frigate successfully stopped
      s6-rc: info: service go2rtc: stopping
      s6-rc: info: service frigate-log: stopping
      s6-rc: info: service nginx-log successfully stopped
      s6-rc: info: service go2rtc successfully stopped
      s6-rc: info: service go2rtc-log: stopping
      s6-rc: info: service frigate-log successfully stopped
      s6-rc: info: service go2rtc-log successfully stopped
      s6-rc: info: service log-prepare: stopping
      s6-rc: info: service s6rc-fdholder: stopping
      Das deutet meiner Meinung nach darauf hin, das er das config.File nicht findet.
      Da muss ich nochmal Hausaufgaben machen, wieso das so ist.
      WalW E 2 Antworten Letzte Antwort
      • R Radi
        WalW Offline
        WalW Offline
        Wal
        @radi sagte in Proxmox LXC mit Frigate:
        Ok, ist ja auch schon 4 Wochen her. ;-)
        Logfiles sind was für Memmen. ;-)
        @exitus ,
        der erste Teil der FileUrl ist der Pfad der config.yml im LXC und der zweite im Docker Container der immer gleich bleibt.
        Und nutze erst die minimal Config, ich habe Tage für die endgültige config.yml gebraucht.
        Walter
        DoorIO-Adapter
        • R Radi
          exitus
          @radi ist aus portainer die logfile
          @Wal ich habe das lxc container nicht mit script installiert sondern den container selber erstellt danach habe ich docker compose mit portainer und dann mit stack frigate
          • E exitus
            Radi
            @exitus Wie ich oben ergänzt habe, habe ich das gerade gefunden. Ich habe es inzwischen mit allen Ubuntu-Versionen wie auch mit Debian über das TTeck Script probiert und war nicht in der Lage eine lauffähige Installation hinzubekommen.
            Ich bin mir sicher, ich mache da etwas Grundsätzliches, das für Containernutzer selbstverständlich ist, falsch. Leider bin ich noch nicht dahinter gekommen, was das ist.
            Die Odnerstruktur ist allerdings so, wie ich das erwarten würde:
            [Link Text](777f87af-7e4c-4b2b-b8bf-7e875c7f55c1-grafik.png Link Adresse)
            WalW 1 Antwort Letzte Antwort
            • R Radi
              WalW Offline
              WalW Offline
              Wal
              @radi ,
              eben getestet.
              docker logs -f frigate
              auf dem LXC oder normalen Installation zeigt den log an
              Walter
              DoorIO-Adapter
              • WalW Wal
                @radi ,
                eben getestet.
                Radi
                @wal Dankeschön, ich schau mal, ob noch etwas mehr drin steht.
                • R Radi
                  Radi
                  @Wal Da steht letztenendes dasselbe wie im Portainerlogfile drin. Ursächlich scheint wohl dies zu sein:
                  2023-05-07 14:44:51.033075103  *************************************************************
                  2023-05-07 14:44:51.033078419  *************************************************************
                  2023-05-07 14:44:51.033079955  ***    Your config file is not valid!                     ***
                  2023-05-07 14:44:51.033081414  ***    Please check the docs at                           ***
                  2023-05-07 14:44:51.033082613  ***    https://docs.frigate.video/configuration/index     ***
                  2023-05-07 14:44:51.033083997  *************************************************************
                  2023-05-07 14:44:51.033085013  *************************************************************
                  2023-05-07 14:44:51.033092726  ***    Config Validation Errors                           ***
                  2023-05-07 14:44:51.033093828  *************************************************************
                  2023-05-07 14:44:51.033094705  [Errno 21] Is a directory: '/config/config.yml'
                  2023-05-07 14:44:51.033656750  Traceback (most recent call last):
                  2023-05-07 14:44:51.033658821    File "/opt/frigate/frigate/app.py", line 351, in start
                  2023-05-07 14:44:51.033659876      self.init_config()
                  2023-05-07 14:44:51.033660984    File "/opt/frigate/frigate/app.py", line 80, in init_config
                  2023-05-07 14:44:51.033661995      user_config = FrigateConfig.parse_file(config_file)
                  2023-05-07 14:44:51.033662995    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
                  2023-05-07 14:44:51.033663850      with open(config_file) as f:
                  2023-05-07 14:44:51.033664794  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
                  2023-05-07 14:44:51.033665538
                  2023-05-07 14:44:51.033666509  *************************************************************
                  2023-05-07 14:44:51.033667457  ***    End Config Validation Errors                       ***
                  2023-05-07 14:44:51.033668354  **********************************************************
                  Nur weiß ich nicht, wie man diesen "IsADirectoryError" korrigiert. Findet Frigate in dem angegebenen Pfad nichts? Oder hat dies eine andere Ursache? Den Screenshot aus dem Filezilla habe ich ja schon weiter oben gepostet. Mit meinem bescheidenen oder nicht vorhandenen Wissen würde ich annehmen, dass der Pfad zur config.yaml so passt.
                  WalW 2 Antworten Letzte Antwort
                  • R Radi
                    WalW Offline
                    WalW Offline
                    Wal
                    @radi ,
                    wie erstellst du die config.yml ? mit nano ?
                    Walter
                    DoorIO-Adapter
                    • R Radi
                      WalW Offline
                      WalW Offline
                      Wal
                      @radi ,
                      mach mal im Container diesen Befehl:
                      cat /config/config.yml
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        @radi ,
                        Radi
                        @wal sagte in Proxmox LXC mit Frigate:
                        Hallo Walter,
                        das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
                        cat: /config/config.yml: No such file or directory
                        will ich das Verzeichnis erzeugen, kommt das:
                        mkdir config
                        mkdir: cannot create directory 'config': File exists
                        Will ich mit nano eine neue config erzeugen kommt:
                          GNU nano 6.4                        /config/config.yml
                                                 [ Directory '/config' does not exist ]
                        ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
                        ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
                        Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
                        ~/config# cat config.yml
                        detectors:
                          cpu1:
                            type: cpu
                        mqtt:
                          host: 192.168.69.159
                          user: user
                          password: xxx
                        cameras:
                          back:
                            ffmpeg:
                              hwaccel_args: preset-vaapi
                              inputs:
                                - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                                  roles:
                                    - detect
                                - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                                  roles:
                                    - record
                            detect:
                              width: 640
                              height: 360
                            mqtt:
                              enabled: False
                           objects:
                              track:
                                - person
                                - car
                                - truck
                                - bicycle
                                - motorcycle
                                - dog
                                - cat
                        snapshots:
                          enabled: True
                          timestamp: False
                          bounding_box: False
                          crop: False
                          height: 175
                          required_zones: []
                          retain:
                            default: 10
                            objects:
                                  person: 15
                        record:
                          enabled: True
                          retain:
                            days: 7
                            mode: motion
                          events:
                            retain:
                              default: 14
                              mode: active_objects
                              objects:
                                person: 14
                                dog: 2
                                car: 7
                        WalW holzapfelaugeH 2 Antworten Letzte Antwort
                        • R Radi
                          Hallo Walter,
                          mkdir config
                          detectors:
                            cpu1:
                              type: cpu
                          mqtt:
                            user: user
                            password: xxx
                          cameras:
                            back:
                              ffmpeg:
                                inputs:
                                    roles:
                                      - detect
                                    roles:
                                      - record
                              detect:
                                width: 640
                                height: 360
                              mqtt:
                                enabled: False
                             objects:
                                track:
                                  - person
                                  - car
                                  - truck
                                  - bicycle
                                  - motorcycle
                                  - dog
                                  - cat
                          snapshots:
                            enabled: True
                            timestamp: False
                            bounding_box: False
                            crop: False
                            height: 175
                            required_zones: []
                            retain:
                              default: 10
                              objects:
                                    person: 15
                          record:
                            enabled: True
                            retain:
                              days: 7
                              mode: motion
                            events:
                              retain:
                                default: 14
                                objects:
                                  person: 14
                                  dog: 2
                                  car: 7
                          WalW Offline
                          WalW Offline
                          Wal
                          @radi ,
                          du musst da aufpassen.
                          Im Docker-Container muss man diese Datei nicht erzeugen, die zeigt nur auf die Datei im LXC.
                          also die Datei im LXC "/home/frigate/frigate/config.yml" wird im Docker auf "/config/config.yml" gemappt.
                          das geht automatisch. Du musst nur die Datei wie hier im LXC "/home/frigate/frigate/config.yml" oder wie in deiner Docker-Config angegeben erzeugen.
                          edit: oder mappst du die Datei in der Docker-Config gar nicht auf "/config/config.yml"
                          editedit: der Docker Container ist fertig eingerichtet, da muss nichts verändert werden.
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            Nachdem ich mir eine CORAL M.2 ACCELERATOR MIT DUAL EDGE TPU und ein Dual Edge TPU Adapter bestellt habe, wurde Frigate auf Proxmox installiert.
                            Skript von TTeck
                            Proxmox-Console Ubuntu Lunar installieren:
                            bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/ct/ubuntu.sh)"
                            • Use Default Settings? -> Advanced
                            • Choose Distribution: -> ubuntu
                            • Choose Version -> 23.04 Lunar
                            • Choose Type -> 1 Unprivileged
                            • Set Disk Size in GB -> 4GB, wenn Videos lokal abgelegt werden sollen erhöhen.
                            • Allocate CPU Cores -> min. 2, je mehr Kameras desto mehr Cores
                            • Allocate Ram in MiB -> min. 2048, je mehr Kameras desto mehr Speicher
                            • Set a Static IPv4 -> besser ist es
                            • Disable IPv6? -> besser ist es
                            • Enable Root SSH Access? -> nein
                            FrigateLXC als root:
                            adduser frigate
                            adduser frigate sudo
                            exit
                            FrigateLXC als User frigate:
                            sudo apt-get install ca-certificates curl gnupg
                            sudo install -m 0755 -d /etc/apt/keyrings
                            curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
                            sudo chmod a+r /etc/apt/keyrings/docker.gpg
                            echo "deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu "$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
                            sudo apt update
                            sudo apt install docker-ce docker-ce-cli containerd.io docker-compose-plugin
                            sudo adduser frigate docker
                            exit
                            FrigateLXC als User frigate neu anmelden:
                            docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce
                            sudo systemctl status docker
                            sudo /lib/systemd/systemd-sysv-install enable docker
                            mkdir frigate
                            cd frigate
                            nano docker-compose.yml
                            docker-compose.yml:
                            version: "3.9"
                            services:
                              frigate:
                                cap_add:
                                  - CAP_PERFMON
                                devices:
                                  - /dev/apex_1:/dev/apex_1
                                volumes:
                                  - /media/frigate:/media/frigate
                                    target: /tmp/cache
                                    tmpfs:
                                ports:
                                  - "5000:5000"
                            Achtung ab Frigate 13 muss der komplette Frigate-Pfad angegeben werden nicht die config.yml:
                            - /home/frigate/frigate:/config
                            nano config.yml
                            die minimale config.yml:
                            mqtt:
                              enabled: False
                            cameras:
                              back:
                                ffmpeg:
                                  inputs:
                                    - path: rtsp://User:PW@192.168.69.162:554/h264Preview_01_main
                                      roles:
                                        - detect
                                detect:
                                  enabled: False
                                  width: 640
                                  height: 480
                            docker starten:
                            docker compose up -d
                            exit
                            http://deineIP:5000
                            exitus
                            schrieb am zuletzt editiert von exitus
                            danke euch allen
                            mit viel grübeln habe ich frigate am laufen aber nur minimal.
                            habe ein camera eingebunden mit minimal config rest mache ich weiter wenn mein tpu da ist.
                            • E Offline
                              exitus
                              ich habe kamera eingebunden habe aber ein greenscreen nur
                              woran kann es liegen???
                              erledigt
                              • E Offline
                                exitus
                                Hallo was ist an diesem config falsch
                                detectors:
                                  cpu1:
                                    type: cpu
                                database:
                                    path: /db/frigate.db
                                mqtt:
                                  host: 172.16.0.10
                                  port: 1689
                                  user: admin
                                  password: passwort
                                cameras:
                                  Parkplatz:
                                    ffmpeg:
                                      output_args:
                                        record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
                                        rtmp: -c:v copy -c:a aac -f flv
                                      inputs:
                                	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                                          roles:
                                            - detect
                                            - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                                          roles:
                                            - record
                                    rtmp:
                                      enabled: False
                                detect:
                                      width: 640
                                      height: 480
                                objects:
                                      track:
                                        - person
                                        - car
                                        - dog
                                snapshots:
                                      enabled: true
                                	  timestamp: true
                                      bounding_box: true
                                      retain:
                                        default: 2
                                record:
                                      enabled: true
                                      retain:
                                        days: 10
                                was sind das für errors
                                [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
                                [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                [cont-finish.d] executing container finish scripts...
                                [cont-finish.d] done.
                                [s6-finish] waiting for services.
                                [s6-finish] sending all processes the TERM signal.
                                [s6-finish] sending all processes the KILL signal and exiting.
                                [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
                                [s6-init] ensuring user provided files have correct perms...exited 0.
                                [fix-attrs.d] applying ownership & permissions fixes...
                                [fix-attrs.d] done.
                                [cont-init.d] executing container initialization scripts...
                                [cont-init.d] done.
                                [services.d] starting services
                                [services.d] done.
                                [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
                                Starting migrations
                                [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
                                There is nothing to migrate
                                [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
                                [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
                                [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
                                [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
                                [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
                                [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
                                [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
                                [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                                [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                                [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                                [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                                [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                                [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                                [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                                snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
                                • E exitus
                                  detectors:
                                    cpu1:
                                      type: cpu
                                  database:
                                  mqtt:
                                    host: 172.16.0.10
                                    port: 1689
                                    user: admin
                                    password: passwort
                                  cameras:
                                    Parkplatz:
                                      ffmpeg:
                                        output_args:
                                        inputs:
                                            roles:
                                              - detect
                                            roles:
                                              - record
                                      rtmp:
                                        enabled: False
                                  detect:
                                        width: 640
                                        height: 480
                                  objects:
                                        track:
                                          - person
                                          - car
                                          - dog
                                  snapshots:
                                        enabled: true
                                  	  timestamp: true
                                        bounding_box: true
                                        retain:
                                          default: 2
                                  record:
                                        enabled: true
                                        retain:
                                          days: 10
                                  [fix-attrs.d] done.
                                  [cont-init.d] done.
                                  [services.d] done.
                                  Starting migrations
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  @exitus sagte in Proxmox LXC mit Frigate:
                                  output_args:
                                  Was möchtest du damit erreichen ?
                                  Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
                                  Walter
                                  DoorIO-Adapter
                                  E 1 Antwort Letzte Antwort
                                  • WalW Wal
                                    output_args:
                                    exitus
                                    @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
                                    haben annke nc400 möchte das es erkennt und aufnimmt.
                                    Bei mir werden bilder gemach aber keine clips.
                                    Mein kamera sendet h264
                                    • E exitus
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      @exitus ,
                                      meine reolink auch und habe keinen Greenscreen.
                                        camera1:
                                          ffmpeg:
                                            inputs:
                                              - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                                                roles:
                                                  - detect
                                              - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                                                roles:
                                                  - record
                                          detect:
                                            width: 640
                                            height: 360
                                          mqtt:
                                            enabled: False
                                      Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
                                      Walter
                                      DoorIO-Adapter
                                      • E exitus
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        @exitus ,
                                        lese gerade das die Kamera auch h265 kann.
                                        Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                                        Walter
                                        DoorIO-Adapter
                                        • E Offline
                                          exitus
                                          wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                                          wäre nett wenn jemand schritt für schritt erklärt.
                                          gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
