  3. Off Topic
  4. Proxmox
  5. Proxmox LXC mit Frigate
    6.3k
Geplant Angeheftet Gesperrt Verschoben Proxmox
176 Beiträge 16 Kommentatoren 67.1k Aufrufe 21 Beobachtet
  • R Radi
    @Wal Da steht letztenendes dasselbe wie im Portainerlogfile drin. Ursächlich scheint wohl dies zu sein:
    2023-05-07 14:44:51.033075103  *************************************************************
    2023-05-07 14:44:51.033078419  *************************************************************
    2023-05-07 14:44:51.033079955  ***    Your config file is not valid!                     ***
    2023-05-07 14:44:51.033081414  ***    Please check the docs at                           ***
    2023-05-07 14:44:51.033082613  ***    https://docs.frigate.video/configuration/index     ***
    2023-05-07 14:44:51.033083997  *************************************************************
    2023-05-07 14:44:51.033085013  *************************************************************
    2023-05-07 14:44:51.033092726  ***    Config Validation Errors                           ***
    2023-05-07 14:44:51.033093828  *************************************************************
    2023-05-07 14:44:51.033094705  [Errno 21] Is a directory: '/config/config.yml'
    2023-05-07 14:44:51.033656750  Traceback (most recent call last):
    2023-05-07 14:44:51.033658821    File "/opt/frigate/frigate/app.py", line 351, in start
    2023-05-07 14:44:51.033659876      self.init_config()
    2023-05-07 14:44:51.033660984    File "/opt/frigate/frigate/app.py", line 80, in init_config
    2023-05-07 14:44:51.033661995      user_config = FrigateConfig.parse_file(config_file)
    2023-05-07 14:44:51.033662995    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
    2023-05-07 14:44:51.033663850      with open(config_file) as f:
    2023-05-07 14:44:51.033664794  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
    2023-05-07 14:44:51.033665538
    2023-05-07 14:44:51.033666509  *************************************************************
    2023-05-07 14:44:51.033667457  ***    End Config Validation Errors                       ***
    2023-05-07 14:44:51.033668354  **********************************************************
    Nur weiß ich nicht, wie man diesen "IsADirectoryError" korrigiert. Findet Frigate in dem angegebenen Pfad nichts? Oder hat dies eine andere Ursache? Den Screenshot aus dem Filezilla habe ich ja schon weiter oben gepostet. Mit meinem bescheidenen oder nicht vorhandenen Wissen würde ich annehmen, dass der Pfad zur config.yaml so passt.
    WalW Offline
    WalW Offline
    Wal
    @radi ,
    wie erstellst du die config.yml ? mit nano ?
    Walter
    DoorIO-Adapter
    • R Radi
      WalW Offline
      WalW Offline
      Wal
      schrieb am zuletzt editiert von Wal
      @radi ,
      mach mal im Container diesen Befehl:
      cat /config/config.yml
      Walter
      DoorIO-Adapter
      R 1 Antwort Letzte Antwort
      • WalW Wal
        @radi ,
        Radi
        schrieb am zuletzt editiert von Radi
        @wal sagte in Proxmox LXC mit Frigate:
        Hallo Walter,
        das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
        cat: /config/config.yml: No such file or directory
        will ich das Verzeichnis erzeugen, kommt das:
        mkdir config
        mkdir: cannot create directory 'config': File exists
        Will ich mit nano eine neue config erzeugen kommt:
          GNU nano 6.4                        /config/config.yml
                                 [ Directory '/config' does not exist ]
        ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
        ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
        Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
        ~/config# cat config.yml
        detectors:
          cpu1:
            type: cpu
        mqtt:
          host: 192.168.69.159
          user: user
          password: xxx
        cameras:
          back:
            ffmpeg:
              hwaccel_args: preset-vaapi
              inputs:
                - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                  roles:
                    - detect
                - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                  roles:
                    - record
            detect:
              width: 640
              height: 360
            mqtt:
              enabled: False
           objects:
              track:
                - person
                - car
                - truck
                - bicycle
                - motorcycle
                - dog
                - cat
        snapshots:
          enabled: True
          timestamp: False
          bounding_box: False
          crop: False
          height: 175
          required_zones: []
          retain:
            default: 10
            objects:
                  person: 15
        record:
          enabled: True
          retain:
            days: 7
            mode: motion
          events:
            retain:
              default: 14
              mode: active_objects
              objects:
                person: 14
                dog: 2
                car: 7
        WalW holzapfelaugeH 2 Antworten Letzte Antwort
        • R Radi
          Hallo Walter,
          mkdir config
          detectors:
            cpu1:
              type: cpu
          mqtt:
            user: user
            password: xxx
          cameras:
            back:
              ffmpeg:
                inputs:
                    roles:
                      - detect
                    roles:
                      - record
              detect:
                width: 640
                height: 360
              mqtt:
                enabled: False
             objects:
                track:
                  - person
                  - car
                  - truck
                  - bicycle
                  - motorcycle
                  - dog
                  - cat
          snapshots:
            enabled: True
            timestamp: False
            bounding_box: False
            crop: False
            height: 175
            required_zones: []
            retain:
              default: 10
              objects:
                    person: 15
          record:
            enabled: True
            retain:
              days: 7
              mode: motion
            events:
              retain:
                default: 14
                objects:
                  person: 14
                  dog: 2
                  car: 7
          WalW Offline
          WalW Offline
          Wal
          @radi ,
          du musst da aufpassen.
          Im Docker-Container muss man diese Datei nicht erzeugen, die zeigt nur auf die Datei im LXC.
                - /home/frigate/frigate/config.yml:/config/config.yml
          also die Datei im LXC "/home/frigate/frigate/config.yml" wird im Docker auf "/config/config.yml" gemappt.
          das geht automatisch. Du musst nur die Datei wie hier im LXC "/home/frigate/frigate/config.yml" oder wie in deiner Docker-Config angegeben erzeugen.
          edit: oder mappst du die Datei in der Docker-Config gar nicht auf "/config/config.yml"
          editedit: der Docker Container ist fertig eingerichtet, da muss nichts verändert werden.
          Walter
          DoorIO-Adapter
          • WalW Wal
            Nachdem ich mir eine CORAL M.2 ACCELERATOR MIT DUAL EDGE TPU und ein Dual Edge TPU Adapter bestellt habe, wurde Frigate auf Proxmox installiert.
            Skript von TTeck
            Proxmox-Console Ubuntu Lunar installieren:
            bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/ct/ubuntu.sh)"
            • Use Default Settings? -> Advanced
            • Choose Distribution: -> ubuntu
            • Choose Version -> 23.04 Lunar
            • Choose Type -> 1 Unprivileged
            • Set Disk Size in GB -> 4GB, wenn Videos lokal abgelegt werden sollen erhöhen.
            • Allocate CPU Cores -> min. 2, je mehr Kameras desto mehr Cores
            • Allocate Ram in MiB -> min. 2048, je mehr Kameras desto mehr Speicher
            • Set a Static IPv4 -> besser ist es
            • Disable IPv6? -> besser ist es
            • Enable Root SSH Access? -> nein
            FrigateLXC als root:
            adduser frigate
            adduser frigate sudo
            exit
            FrigateLXC als User frigate:
            sudo apt-get install ca-certificates curl gnupg
            sudo install -m 0755 -d /etc/apt/keyrings
            curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
            sudo chmod a+r /etc/apt/keyrings/docker.gpg
            echo "deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu "$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
            sudo apt update
            sudo apt install docker-ce docker-ce-cli containerd.io docker-compose-plugin
            sudo adduser frigate docker
            exit
            FrigateLXC als User frigate neu anmelden:
            docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce
            sudo systemctl status docker
            sudo /lib/systemd/systemd-sysv-install enable docker
            mkdir frigate
            cd frigate
            nano docker-compose.yml
            docker-compose.yml:
            version: "3.9"
            services:
              frigate:
                container_name: frigate
                privileged: true # this may not be necessary for all setups
                restart: unless-stopped
                image: ghcr.io/blakeblackshear/frigate:stable
                shm_size: "64mb" # update for your cameras based on calculation above
                cap_add:
                  - CAP_PERFMON
                devices:
                  - /dev/apex_0:/dev/apex_0
                  - /dev/apex_1:/dev/apex_1
                  - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
                volumes:
                  - /etc/localtime:/etc/localtime:ro
                  - /media/frigate:/media/frigate
                  - type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
                    target: /tmp/cache
                    tmpfs:
                ports:
                  - "5000:5000"
                  - "1935:1935" # RTMP feeds
            Achtung ab Frigate 13 muss der komplette Frigate-Pfad angegeben werden nicht die config.yml:
            - /home/frigate/frigate:/config
            nano config.yml
            die minimale config.yml:
            mqtt:
              enabled: False
            cameras:
              back:
                ffmpeg:
                  inputs:
                    - path: rtsp://User:PW@192.168.69.162:554/h264Preview_01_main
                      roles:
                        - detect
                detect:
                  enabled: False
                  width: 640
                  height: 480
            docker starten:
            docker compose up -d
            exit
            http://deineIP:5000
            exitus
            schrieb am zuletzt editiert von exitus
            danke euch allen
            mit viel grübeln habe ich frigate am laufen aber nur minimal.
            habe ein camera eingebunden mit minimal config rest mache ich weiter wenn mein tpu da ist.
            • E Offline
              exitus
              ich habe kamera eingebunden habe aber ein greenscreen nur
              woran kann es liegen???
              erledigt
              • E Offline
                exitus
                Hallo was ist an diesem config falsch
                detectors:
                  cpu1:
                    type: cpu
                database:
                    path: /db/frigate.db
                mqtt:
                  host: 172.16.0.10
                  port: 1689
                  user: admin
                  password: passwort
                cameras:
                  Parkplatz:
                    ffmpeg:
                      output_args:
                        record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
                        rtmp: -c:v copy -c:a aac -f flv
                      inputs:
                	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                          roles:
                            - detect
                            - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                          roles:
                            - record
                    rtmp:
                      enabled: False
                detect:
                      width: 640
                      height: 480
                objects:
                      track:
                        - person
                        - car
                        - dog
                snapshots:
                      enabled: true
                	  timestamp: true
                      bounding_box: true
                      retain:
                        default: 2
                record:
                      enabled: true
                      retain:
                        days: 10
                was sind das für errors
                [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
                [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                [cont-finish.d] executing container finish scripts...
                [cont-finish.d] done.
                [s6-finish] waiting for services.
                [s6-finish] sending all processes the TERM signal.
                [s6-finish] sending all processes the KILL signal and exiting.
                [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
                [s6-init] ensuring user provided files have correct perms...exited 0.
                [fix-attrs.d] applying ownership & permissions fixes...
                [fix-attrs.d] done.
                [cont-init.d] executing container initialization scripts...
                [cont-init.d] done.
                [services.d] starting services
                [services.d] done.
                [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
                Starting migrations
                [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
                There is nothing to migrate
                [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
                [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
                [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
                [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
                [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
                [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
                [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
                [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
                WalW 1 Antwort Letzte Antwort
                • E exitus
                  detectors:
                    cpu1:
                      type: cpu
                  database:
                  mqtt:
                    host: 172.16.0.10
                    port: 1689
                    user: admin
                    password: passwort
                  cameras:
                    Parkplatz:
                      ffmpeg:
                        output_args:
                        inputs:
                            roles:
                              - detect
                            roles:
                              - record
                      rtmp:
                        enabled: False
                  detect:
                        width: 640
                        height: 480
                  objects:
                        track:
                          - person
                          - car
                          - dog
                  snapshots:
                        enabled: true
                  	  timestamp: true
                        bounding_box: true
                        retain:
                          default: 2
                  record:
                        enabled: true
                        retain:
                          days: 10
                  [fix-attrs.d] done.
                  [cont-init.d] done.
                  [services.d] done.
                  Starting migrations
                  WalW Offline
                  WalW Offline
                  Wal
                  @exitus sagte in Proxmox LXC mit Frigate:
                  output_args:
                  Was möchtest du damit erreichen ?
                  Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
                  Walter
                  DoorIO-Adapter
                  E 1 Antwort Letzte Antwort
                  • WalW Wal
                    output_args:
                    exitus
                    @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
                    haben annke nc400 möchte das es erkennt und aufnimmt.
                    Bei mir werden bilder gemach aber keine clips.
                    Mein kamera sendet h264
                    WalW 2 Antworten Letzte Antwort
                    • E exitus
                      WalW Offline
                      WalW Offline
                      Wal
                      @exitus ,
                      meine reolink auch und habe keinen Greenscreen.
                        camera1:
                          ffmpeg:
                            inputs:
                              - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                                roles:
                                  - detect
                              - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                                roles:
                                  - record
                          detect:
                            width: 640
                            height: 360
                          mqtt:
                            enabled: False
                      Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
                      Walter
                      DoorIO-Adapter
                      • E exitus
                        WalW Offline
                        WalW Offline
                        Wal
                        @exitus ,
                        lese gerade das die Kamera auch h265 kann.
                        Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                        Walter
                        DoorIO-Adapter
                        • E Offline
                          exitus
                          wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                          wäre nett wenn jemand schritt für schritt erklärt.
                          gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
                          • E exitus
                            WalW Offline
                            WalW Offline
                            Wal
                            @exitus ,
                            du machst das Laufwerk unter dem Proxmox Host verfügbar z.B. unter '/media/synology' so als wäre es ein normales Laufwerk.
                            Danach gibst du in der lxc.conf den Ordner für den Frigate LXC frei.
                            arch: amd64
                            cores: 4
                            features: keyctl=1,nesting=1
                            hostname: testfrigate
                            memory: 8192
                            mp0: /media/synology,mp=/media/frigate
                            danach ist der Ordner im LXC unter '/media/frigate' verfügbar und du kannst ihn im Docker hinzufügen.
                                volumes:
                                  - /home/frigate/config/config.yml:/config/config.yml
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @exitus ,
                              arch: amd64
                              cores: 4
                              memory: 8192
                                  volumes:
                              exitus
                              @wal das habe ich gemacht, ich kann auch über die Konsole vom lxc kann ich die freigabe sehen aber habe kein schreib zugriff.
                              Ich habe über den Host in fstab die freigabe eingetragen , über den Host habe ich die schreib und leserechte von der nas aber über die lxc container vo docker und frigate läuft nicht
                              • E exitus
                                WalW Offline
                                WalW Offline
                                Wal
                                @exitus,
                                ok da kann ich jetzt nicht helfen.
                                Ich mache es anders rum, habe eine USB Festplatte als LXC-Backup und Datenspeicher eingerichtet und gebe diese über einen Samba LXC im Netzwerk frei. Damit habe ich Zugriff auf alle Dateien die ich im Proxmox speichere.
                                Walter
                                DoorIO-Adapter
                                • E exitus
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  @exitus ,
                                  schau dir das mal an, könnte helfen.
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @exitus ,
                                    exitus
                                    @wal habe es geschafft jetz anderes problem habe 2 cameras beide machen screenshots dedection klappt bei einen habe ich clips bei den anderen nur bilder ohne clips wo kein clips sind ist die kamera mit der bezeichnung back
                                    ier mein config
                                    database:
                                      path: /media/frigate/db/frigate.db
                                    detectors:
                                      cpu1:
                                        type: cpu
                                    ui:
                                      use_experimental: false
                                      live_mode: mse
                                    mqtt:
                                      host: 172.16.0.10
                                      port: 12345
                                      user: xxxxxxx
                                      password: exxxxx
                                    cameras:
                                      back1:
                                        ffmpeg:
                                          inputs:
                                            - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=2
                                              roles:
                                                - detect
                                                - rtmp
                                            - path: rtsp://admin:xxxxxxx@172.16.0.177:554/channel=1
                                              roles:
                                                - record
                                      back:
                                        ffmpeg:
                                          inputs:
                                            - path: rtsp://admin:xxxxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                              roles:
                                                - detect
                                                - rtmp
                                              roles:
                                                - record
                                    detect:
                                          width: 640
                                          height: 480
                                          fps: 5
                                    objects:
                                          track:
                                            - person
                                            - dog
                                            - bicycle
                                            - cat
                                          filters:
                                            person:
                                              min_score: 0.7
                                              threshold: 0.5
                                              min_area: 700
                                    snapshots:
                                          enabled: true
                                          timestamp: true
                                          bounding_box: true
                                          crop: True
                                          height: 500
                                          retain:
                                            default: 1
                                    record:
                                      enabled: True
                                      events:
                                        retain:
                                          default: 10
                                    birdseye:
                                      enabled: True
                                      mode: continuous
                                    • E exitus
                                      ier mein config
                                      database:
                                      detectors:
                                        cpu1:
                                          type: cpu
                                      ui:
                                        live_mode: mse
                                      mqtt:
                                        host: 172.16.0.10
                                        port: 12345
                                        user: xxxxxxx
                                        password: exxxxx
                                      cameras:
                                        back1:
                                          ffmpeg:
                                            inputs:
                                                roles:
                                                  - detect
                                                  - rtmp
                                                roles:
                                                  - record
                                        back:
                                          ffmpeg:
                                            inputs:
                                                roles:
                                                  - detect
                                                  - rtmp
                                                roles:
                                                  - record
                                      detect:
                                            width: 640
                                            height: 480
                                            fps: 5
                                      objects:
                                            track:
                                              - person
                                              - dog
                                              - bicycle
                                              - cat
                                            filters:
                                              person:
                                                min_score: 0.7
                                                threshold: 0.5
                                                min_area: 700
                                      snapshots:
                                            enabled: true
                                            timestamp: true
                                            bounding_box: true
                                            crop: True
                                            height: 500
                                            retain:
                                              default: 1
                                      record:
                                        enabled: True
                                        events:
                                          retain:
                                            default: 10
                                      birdseye:
                                        enabled: True
                                        mode: continuous
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      @exitus ,
                                      schau mal im Adapter ob das dort eingeschaltet ist.
                                      Walter
                                      DoorIO-Adapter
                                      • WalW Wal
                                        @exitus ,
                                        exitus
                                        @wal bei mir steht OFF wo kann man es den einschalten im config ist ja true,
                                        warum ist der eine on und der andere off
                                        • E exitus
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          @exitus ,
                                          state ist nur der Status und mit Set kann man an und ausschalten.
                                          Walter
                                          DoorIO-Adapter
