  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
Geplant Angeheftet Gesperrt Verschoben Installation
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.7k Aufrufe 52 Beobachtet
    tony63526
    #441
    hab jetzt Iob mal alles neu installiert.
    Der Hosts Adapter möchte gern noch das ich etwas aktualisiere.
    libgssapi-krb5-2/stable-security 1.20.1-2+deb12u2 arm64 [upgradable from: 1.20.1-2+deb12u1]
    libk5crypto3/stable-security 1.20.1-2+deb12u2 arm64 [upgradable from: 1.20.1-2+deb12u1]
    libkrb5-3/stable-security 1.20.1-2+deb12u2 arm64 [upgradable from: 1.20.1-2+deb12u1]
    libkrb5support0/stable-security 1.20.1-2+deb12u2 arm64 [upgradable from: 1.20.1-2+deb12u1]
    libssl3/stable 3.0.13-1~deb12u1+rpt1 arm64 [upgradable from: 3.0.13-1~deb12u1]
    openssl/stable 3.0.13-1~deb12u1+rpt1 arm64 [upgradable from: 3.0.13-1~deb12u1]
    raspberrypi-sys-mods/stable 20240807 arm64 [upgradable from: 20240624]
    raspi-config/stable,stable 20240708 all [upgradable from: 20240625]
    wpasupplicant/stable-security 2:2.10-12+deb12u2 arm64 [upgradable from: 2:2.10-12+deb12u1]
    2024-08-07 18:32:49.912
    Mit welchen Befehl mache ich das? Damit ging es nicht weg.
    sudo apt update && sudo apt full-upgrade
    sudo reboot
    • T tony63526
      sudo reboot
      #442
      @tony63526 sagte in Troubleshooting NodeJS update:
      sudo apt update
      sudo reboot
      Zeig mal die Ausgaben dazu. Ohne Rückmeldungen kann ich dazu auch nix sagen.
        tony63526
        #443
        pi@raspberrypi:~ $ sudo apt update
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        pi@raspberrypi:~ $ sudo apt full-upgrade
        Calculating upgrade... Done
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        pi@raspberrypi:~ $
        • T tony63526
          pi@raspberrypi:~ $
          #444
          Alles prima, so soll es sein.
          Und GUIs lügen. Sag ich ja immer wieder. Klick die Meldung weg.
            tony63526
            #445
            Alles klar, danke
              sol21
              #446
              Habe Versucht NodeJS upzudaten.
              Gemäss: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
              Seither wird mein IOBroker im Browser nicht mehr gefunden. Fehlermeldung"Fehler: Verbindung fehlgeschlagen"
              iobroker diag:
                                      v.2024-05-22
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7l+
                    Architecture: arm
              Installation:           native
              Kernel:                 armv7l
              Userland:               32 bit
              Timezone:               Europe/Zurich (CEST, +0200)
              User-ID:                1000
              Display-Server:         false
              Pending OS-Updates:     0
              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
              Pending iob updates:    0
              Nodejs-Installation:
              nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              /usr/bin/corepack
              Recommended versions are nodejs  and npm
              MEMORY:
              Mem:           3.8G         65M        3.2G         15M        539M        3.6G
              Swap:           99M          0B         99M
              Total:         3.9G         65M        3.3G
              Active iob-Instances:   0
              ioBroker Core:          js-controller
                                      admin
              ioBroker Status:
              Objects:                0
              States:                 0
              Size of iob-Database:
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              8.4M    /opt/iobroker/iobroker-data/objects.json.migrated
              8.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
              8.9M    /opt/iobroker/iobroker-data/states.jsonl
              800K    /opt/iobroker/iobroker-data/states.json.migrated
              800K    /opt/iobroker/iobroker-data/states.json.bak.migrated
              0       /opt/iobroker/iobroker-data/states.json.broken
              Ich vermute nun mal das hat was mit der fehlenden "GLIBCXX_3.4.26" zu tun?
              Wie kann ich die manuell nachinstallieren?
              Ro75R Thomas BraunT 2 Antworten Letzte Antwort
              • S sol21
                iobroker diag:
                                        v.2024-05-22
                         Icon name: computer
                      Architecture: arm
                Kernel:                 armv7l
                Userland:               32 bit
                User-ID:                1000
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                /usr/bin/corepack
                MEMORY:
                Swap:           99M          0B         99M
                                        admin
                ioBroker Status:
                Objects:                0
                States:                 0
                Ro75R Offline
                Ro75R Offline
                Ro75
                #447
                @sol21 Debian12 installieren (Bookworm)! Unter Buster (Debian10) geht das nicht!
                Ro75.
                • S sol21
                  iobroker diag:
                                          v.2024-05-22
                           Icon name: computer
                        Architecture: arm
                  Kernel:                 armv7l
                  Userland:               32 bit
                  User-ID:                1000
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  /usr/bin/corepack
                  MEMORY:
                  Swap:           99M          0B         99M
                                          admin
                  ioBroker Status:
                  Objects:                0
                  States:                 0
                  #448
                  @sol21 sagte in Troubleshooting NodeJS update:
                  Gar nicht.
                  Aktuelles Raspberry OS 12 komplett neu installieren.
                  Künftig dann nicht auf abgesoffenen Releases verharren sondern zeitnah den Absprung auf das aktuelle Stable-Release planen. Dann rennt man nämlich nicht in solche Situationen.
                    sol21
                    #449
                    O.k. Danke Euch beiden.
                    Das war ich mir nicht bewusst. Hatte IOBroker immer die Stabel Version nachgeführt. Das Raspberry OS habe ich dabei nicht mehr bedacht...
                    Dann muss ich mich da mal durcharbeiten.
                    • S sol21
                      #450
                      @sol21
                      Ich hab mal dazu was geschrieben. Such meinen 'Raspberry installieren - Einfacher geht's nicht' Thread.
                      • E Offline
                        eviltrooper
                        #451
                        Hi leute.
                        ich hab aktuell "leider" noch debian Bullseye und will eigentlich ein Upgrade machen.
                        Allerdings sind meine ganzen Adapter jetzt auch veraltet und ich kann die nicht mehr updaten da ich node >=18 benötige aber noch 16 installiert habe.
                        dazu hab ich auch noch den JS-Controller auf 4.0.24
                        ja ich weiß.. hätte ich mal updaten sollen..
                        Ich denke ich sollte auf dem alten System erstmal alles "updaten" um dann von dort ein Update zu machen.
                        wie kann ich denn die nodesjs updaten?
                        sollte doch bei Bullseye mit "iob nodejs-update 18" funktionieren oder?
                        dann update ich alles, kauf mir den neuen Raspi5 mit 8GB und zieh alles auf den neuen Um inkl. natürlich das neuste RaspiOS.
                        so die Frage ist jetzt wie gesagt, wie bekomme ich nodesjs 18 auf das Bullseye System?
                        reicht da
                        • E eviltrooper
                          Hi leute.
                          reicht da
                          #452
                          @eviltrooper
                          Hier hat jemand die fast gleiche Konstellation:
                          https://forum.iobroker.net/topic/70370/passwort-iobroker-über-mac-terminal-anders/91?_=1729889757239
                          Lies dich da ein.
                          E 1 Antwort Letzte Antwort
                            @eviltrooper
                            Lies dich da ein.
                            eviltrooper
                            #453
                            @thomas-braun ahh danke :)
                            • E Offline
                              el-lutschi
                              #454
                              ich versuch gerade node.js in meinem Proxmox LXC auf Version 20 zu updaten. Leider klappt das einfach nicht. Führe ich den Befehl
                              iob nodejs-update
                              als normaler User aus erhalte ich
                              bash: /home/iobroker/.nodejs-update.sh: Permission denied
                              Versuche ich es als root erhalte ich
                              This script must not be run as root! Please use your standard user!"
                              Dann habe ich
                              su iobroker -s /bin/bash -c 'iob nodejs-update'
                              versucht. Dann läuft das Skript zwar an aber ich erhalte die folgenden Fehler:
                              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                              sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
                              sudo: a password is required
                              *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                              Ich steh grad irgendwie auf dem Schlauch und verstehe nicht warum es nicht klappt. Kann mir jemand helfen?
                              • E el-lutschi
                                iob nodejs-update
                                Dann habe ich
                                #455
                                @el-lutschi sagte in Troubleshooting NodeJS update:
                                Wo und wie führst du das denn aus? Du musst da schon mit einem gescheiten Terminal anrücken.
                                Dann funktioniert das auch ohne diese Verrenkungen, die du da fabrizierst.
                                  el-lutschi
                                  #456
                                  In einer SSH Session über Putty. Was ist für dich ein gescheiter Terminal?
                                  • E el-lutschi
                                    #457
                                    PuTTY muss funktionieren. Auch wenn es nicht mein bevorzugtes Terminal ist.
                                      el-lutschi
                                      #458
                                      Danke für deine Hilfe. Mit welchem Befehl und als was für ein User muss es denn gehen?
                                      • E el-lutschi
                                        #459
                                        Als Standard-User, der in der Gruppe 'iobroker' enthalten ist muss es gehen.
                                        • E Offline
                                          el-lutschi
                                          #460
                                          Danke!! Das war der Fehler. Der User war nicht in der Gruppe. Vielen Dank für den richtigen Tipp.
