  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
Geplant Angeheftet Gesperrt Verschoben Installation
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.8k Aufrufe 52 Beobachtet
  • bfelizardoB bfelizardo
    @homoran @thomas-braun
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID:	Raspbian
    Description:	Raspbian GNU/Linux 10 (buster)
    Release:	10
    Codename:	buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     11:33:00 up 22 min,  1 user,  load average: 1.25, 1.44, 1.36
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=54.5'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Wed 2023-07-05 11:33:00 CEST
               Universal time: Wed 2023-07-05 09:33:00 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           7.9G        1.5G        5.7G        8.0M        679M        6.1G
    Swap:           99M          0B         99M
    Total:         8.0G        1.5G        5.8G
             7875 M total memory
             1477 M used memory
              266 M active memory
             1770 M inactive memory
             5717 M free memory
              103 M buffer memory
              576 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.2G   22G  23% /
    devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
    [Wed Jul  5 11:10:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:2E:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=634d01a8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Wed Jul  5 11:10:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Jul  5 11:10:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Jul  5 11:10:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems (real ones only):
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    562M	/var/
    367M	/var/cache
    362M	/var/cache/apt
    303M	/var/cache/apt/archives
    92M	/var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    358M	/opt/iobroker/backups/
    1.5M	/opt/iobroker/backups/old
    /opt/iobroker/iobroker-data:
    1.3G	/opt/iobroker/iobroker-data/
    342M	/opt/iobroker/iobroker-data/history
    248M	/opt/iobroker/iobroker-data/backup-objects
    231M	/opt/iobroker/iobroker-data/files
    210M	/opt/iobroker/iobroker-data/sonosCache
    149M	/opt/iobroker/iobroker-data/states.jsonl
    31M	/opt/iobroker/iobroker-data/objects.jsonl
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    15M	/opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.16.1
    /usr/bin/node 		v18.16.1
    /usr/bin/npm 		9.7.2
    /usr/bin/npx 		9.7.2
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	6.1.4
    Adapters from github: 	1
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
      system.adapter.apple-find-me.1          : apple-find-me         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0, run as: ????
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: ????
      system.adapter.nightscout.0             : nightscout            : iobroker                                 - disabled, port: ????, bind: 0.0.0.0
      system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: ????, bind: 192.168.?.?
      system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
      system.adapter.pushover.1               : pushover              : iobroker                                 - disabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
      system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0, run as: ????
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
    + system.adapter.withings.0               : withings              : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: ????
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "synochat"     : 1.2.1    , installed 1.2.1
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects: 	38519
    States: 	35458
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    Pending Updates: 186
    *** Listening Ports ***
    tcp        0      0 192.168.?.?:????   0.0.0.0:*               LISTEN      1001       18478      741/io.hm-rpc.1
    tcp        0      0 0.0.0.0:????            0.0.0.0:*               LISTEN      1001       17969      781/io.sonoff.0
    tcp        0      0 127.0.0.1:????          0.0.0.0:*               LISTEN      1001       17664      572/iobroker.js-con
    tcp        0      0 127.0.0.1:????          0.0.0.0:*               LISTEN      1001       16178      572/iobroker.js-con
    tcp        0      0 192.168.?.?:????   0.0.0.0:*               LISTEN      1001       17223      734/io.hm-rpc.0
    tcp        0      0 0.0.0.0:????              0.0.0.0:*               LISTEN      0          17652      578/sshd
    tcp6       0      0 :::????                 :::*                    LISTEN      1001       19609      1040/io.simple-api.
    tcp6       0      0 :::????                 :::*                    LISTEN      1001       18324      1029/io.lovelace.0
    tcp6       0      0 :::????                 :::*                    LISTEN      1001       17996      809/io.sonos.0
    tcp6       0      0 :::????                 :::*                    LISTEN      1001       16255      604/io.admin.0
    tcp6       0      0 :::????                 :::*                    LISTEN      1001       19745      1081/io.web.0
    tcp6       0      0 :::????                 :::*                    LISTEN      1001       20529      1051/io.socketio.0
    tcp6       0      0 :::????                   :::*                    LISTEN      0          17654      578/sshd
    udp        0      0 0.0.0.0:????            0.0.0.0:*                           108        14581      365/avahi-daemon: r
    udp        0      0 0.0.0.0:????           0.0.0.0:*                           108        14583      365/avahi-daemon: r
    udp        0      0 0.0.0.0:????              0.0.0.0:*                           0          15820      569/dhcpcd
    udp        0      0 0.0.0.0:????           0.0.0.0:*                           1001       18510      771/io.mihome-vacuu
    udp6       0      0 :::????                :::*                                108        14584      365/avahi-daemon: r
    udp6       0      0 :::????                 :::*                                108        14582      365/avahi-daemon: r
    2023-07-05 11:16:06.395  - info: alexa2.0 (708) Subscribing to states...
    2023-07-05 11:16:06.648  - error: daswetter.0 (1720) exception in await insertIntoList [Error: DB closed]
    2023-07-05 11:16:06.666  - error: daswetter.0 (1720) exception in await insertIntoList [Error: DB closed]
    2023-07-05 11:16:06.671  - error: daswetter.0 (1720) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value": Connection is closed.
    2023-07-05 11:16:06.680  - error: daswetter.0 (1720) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value": Connection is closed.]
    2023-07-05 11:16:06.683  - error: daswetter.0 (1720) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.uv_index_value": Connection is closed.
    2023-07-05 11:16:06.706  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    2023-07-05 11:16:08.594  - info: alexa2.0 (708) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-07-05 11:16:31.896  - info: fb-checkpresence.0 (1107) createFbDeviceObjects finished successfully
    2023-07-05 11:16:31.900  - info: fb-checkpresence.0 (1107) states successfully subscribed
    2023-07-05 11:16:31.903  - info: fb-checkpresence.0 (1107) loop successfully started
    2023-07-05 11:16:41.826  - info: alexa2.0 (708) Initialization Done ...
    2023-07-05 11:28:24.018  - info: sonoff.0 (781) Client [XXXX] connection closed: Error: read ECONNRESET
    2023-07-05 11:28:31.614  - info: sonoff.0 (781) Client [XXXX] connected with secret ????
    2023-07-05 11:30:00.129  - info: host.iobroker instance system.adapter.daswetter.0 started with pid ????
    2023-07-05 11:30:03.763  - info: daswetter.0 (3111) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-07-05 11:30:04.120  - info: daswetter.0 (3111) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
    2023-07-05 11:30:27.051  - info: daswetter.0 (3111) still wrong data structure from server received! repaired...
    2023-07-05 11:30:33.154  - info: daswetter.0 (3111) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-07-05 11:30:33.678  - info: daswetter.0 (3111) cleaned everything up...
    2023-07-05 11:30:33.705  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-05 11:33:50.597  - info: sonoff.0 (781) Client [XXXX] connection closed: closed
    2023-07-05 11:34:07.677  - info: admin.0 (604) ==> Connected system.user.???? from ::ffff:192.168.?.?
    2023-07-05 11:34:36.056  - info: host.iobroker iobroker upgrade javascript@7.0.3 --debug
    2023-07-05 11:34:38.784  - info: sonoff.0 (781) Client [XXXX] connected with secret ????
    iob diag has finished.
    Press any key for a summary
    crunchipC Offline
    crunchipC Offline
    #201
    @bfelizardo was stimmt da mit deinen Ports nicht?
    außerdem ist buster überfällig
    bfelizardoB 1 Antwort Letzte Antwort
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:	10
      Codename:	buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=54.5'C
      volt=0.8500V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               7875 M total memory
               1477 M used memory
                266 M active memory
               5717 M free memory
                103 M buffer memory
                576 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      562M	/var/
      367M	/var/cache
      362M	/var/cache/apt
      92M	/var/lib
      /usr/bin/npm 		9.7.2
      /usr/bin/npx 		9.7.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	38519
      States: 	35458
      #202
      @crunchip sagte in Troubleshooting NodeJS update:
      und das auch noch ungepflegt
      @bfelizardo sagte in Troubleshooting NodeJS update:
        bfelizardoB Offline
        bfelizardoB Offline
        bfelizardo
        #203
        @crunchip
        habe die Port "geschwärzt".
        @crunchip + @Homoran
        Danke für eure Rückmeldung. Da mit dem Update von Buster etc. verstehe ich, aber ist das die Ursache für mein Problem?
        HomoranH crunchipC 3 Antworten Letzte Antwort
          @crunchip
          #204
          und wie sollen wir dann z.B. doppelt belegte oder falsche ports erkennen?
            @crunchip
            crunchipC Offline
            crunchipC Offline
            #205
            wie kommt man denn auf so eine Idee, die Ausgabe ist doch dafür da um Fehler zu finden
            möglicherweise ja
              @crunchip
              #206
              hast du tatsächlich von
              node.js 12.x
              direkt auf 18 hochgezogen?
                node.js 12.x
                bfelizardoB Offline
                bfelizardoB Offline
                bfelizardo
                #207
                @homoran @crunchip
                sorry mit den Ports, war mir unsicher was ich hier alles öffentlich machen soll.
                @Homoran ich habe von 14.x auf 18.x hochgezogen.
                crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                  @homoran @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  #208
                  @bfelizardo ok, sollte an und für sich funktionieren von 14 auf 18
                  allerdings aufgrund deiner ungepflegten updates wohl nicht
                  aktuelles OS neu installieren und backup vom iobroker zurückspielen würde ich vorschlagen
                    bfelizardoB Offline
                    bfelizardoB Offline
                    bfelizardo
                    #209
                    @crunchip said in Troubleshooting NodeJS update:
                    ok danke. Werde ich ausprobieren!
                      @homoran @crunchip
                      Thomas BraunT Offline
                      #210
                      Alles.
                      Zumindest bei npm hast du aber noch händisch herumgefummelt. Die Version passt nicht zum nodejs.
                      iob stop
                      sudo install --reinstall nodejs
                      iob start
                      ausführen.
                      Besser aber das System kompett neu aufsetzen, auf 'Bullseye' 64bit 'Lite'.
                        @apollon77 Danke für die Antwort! Ne, ich nutzte kein Daikin Adapter.
                        Ich habe versucht den javascript Adapter von v6.1.4 auf v7.0.3 upzudaten. Hier die vollständige Logausgabe, wenn ich versuche den Apdapbter im iobroker unter Adapter upzudaten. Gleiche Fehler bekomme ich auch beim update vom HomeMatic RPC Adpater. Denke das passiert egal welchen Adpater ich updaten will.
                        $ iobroker upgrade javascript@7.0.3 --debug
                        Update javascript from @6.1.4 to @7.0.3
                        NPM version: 9.7.2
                        Installing iobroker.javascript@7.0.3... (System call)
                        npm WARN old lockfile
                        npm WARN old lockfile The package-lock.json file was created with an old version of npm,npm WARN old lockfile so supplemental metadata must be fetched from the registry.npm WARN old lockfile
                        npm WARN old lockfile This is a one-time fix-up, please be patient...npm WARN old lockfile
                        npm ERR! code EBADENGINE
                        npm ERR! engine Unsupported engine
                        npm ERR! notsup Required: {"node":"^12.16.1 || ^10.15.2 || ^8.15.1","npm":"^6.4.1"}npm ERR! notsup Actual: {"npm":"9.7.2","node":"v18.16.1"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-05T08_46_11_943Z-debug-0.log
                        upload [261] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                        upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                        upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/uk.js google-blockly/own/msg/uk.js application/javascript
                        upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Amplifier.6f5d18048328386033f8.svg static/media/Amplifier.6f5d18048328386033f8.svg image/svg+xml
                        upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Heater.b53bccc334bbb9238a36.svg static/media/Heater.b53bccc334bbb9238a36.svg image/svg+xml
                        upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Light.21f1a5dfcc93f8ba1214.svg static/media/Light.21f1a5dfcc93f8ba1214.svg image/svg+xml
                        upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Office.7e6a38218390b655e270.svg static/media/Office.7e6a38218390b655e270.svg image/svg+xml
                        upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
                        upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.db548379676317470c4f.svg static/media/Speaker.db548379676317470c4f.svg image/svg+xml
                        upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                        upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                        upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                        upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                        upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                        upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                        upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                        upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                        upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                        upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                        upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                        upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                        upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                        upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                        upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                        upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                        upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                        upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                        upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                        upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                        upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                        Process exited with code 0
                        #211
                        liess ggf mal in dem genannten Logfile - vllt steht da welches paket es bei dir auslöst
                          Stadtschloss
                          schrieb am zuletzt editiert von Stadtschloss
                          #212
                          ich kann leider kein apt-get update machen. Ich erhalte folgenden Fehler:
                          apt-get update
                          Err:1 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Could not connect to deb.nodesource.com:443 (0.0.0.0). - connect (111: Connection refused) Could not connect to deb.nodesource.com:443 (::). - connect (111: Connection refused)
                          Hit:2 http://ftp.debian.org/debian bullseye InRelease
                          Hit:3 http://security.debian.org bullseye-security InRelease
                          Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
                          Reading package lists... Done
                          W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/bullseye/InRelease  Could not connect to deb.nodesource.com:443 (0.0.0.0). - connect (111: Connection refused) Could not connect to deb.nodesource.com:443 (::). - connect (111: Connection refused)
                          W: Some index files failed to download. They have been ignored, or old ones used instead.
                          node --version
                          v18.15.0
                          Was kann ich hier tun?
                          Danke!
                          EDIT:
                          Mein Adblocker blockiert die URL. Problem gelöst :)
                          • C Offline
                            centrofly
                            schrieb am zuletzt editiert von centrofly
                            #213
                            Post gelöscht, hat sich auf wundersame Weise selbst geheilt...
                            • C Offline
                              Creatorhs
                              schrieb am zuletzt editiert von Creatorhs
                              #214
                              ich habe leider Probleme nodejs upzudaten.
                              Ich konnte noch iob stop eingeben und - vermutlich - die alte nodejs Version löschen. Wobei auch schon hier nicht genau die Ausgabe kam, wie im best practice Artikel.
                              Ich habe dann noch versucht das Repository herunterzuladen und erscheint dann folgende Fehlermeldung:
                              + apt-get update
                              Ign:3 https://packages.grafana.com/oss/deb stable InRelease
                              OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                              Fehl:5 https://packages.grafana.com/oss/deb stable Release
                                Certificate verification failed: The certificate is NOT trusted. The certifica        te chain uses expired certificate.  Could not handshake: Error in the certificat        e verification. [IP: 2a04:4e42:6f::729 443]
                              E: Das Depot »https://packages.grafana.com/oss/deb stable Release« enthält keine        Release-Datei mehr.
                              N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur        chgeführt werden, daher ist es standardmäßig deaktiviert.
                              N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur        ation finden Sie in der Handbuchseite apt-secure(8).
                              Error executing command, exiting
                              Danach geht nichts mehr mit der bisher aufgespielten Version 14, da diese ja weg ich.
                              Ich habe dann noch versucht "irgendeine" Nodejs zu installieren, was vermutlich der Fehler war:
                              sudo apt install -y nodejs
                              jetzt ist die ganz alte Version 12 drauf und zB Javaskript startet nicht mehr.
                              Kann mir jemand helfen? Ich hab keine Ahnung, wie ich weitermachen soll. Backups sind auf googledrive vorhanden. Wenn ich ganz ehrlich bin bräuchte ich hier auch Hilfe um die wieder einzuspielen.
                              edit: auch weitere Instanzen, wie zB shelly, tankerkönig, fb-checkpresence, gehen nicht mehr. Ich vermute, da die V12 zu alt ist?!
                              Creator
                              • C Creatorhs
                                + apt-get update
                                Creator
                                crunchipC Offline
                                crunchipC Offline
                                #215
                                @creatorhs sagte in Troubleshooting NodeJS update:
                                und wie hast du die da rein gebracht, denn in deinem repo steht noch
                                grafana korrigieren
                                debian buster
                                https://www.debian.org/releases/
                                um deine probleme zu beseitigen, findest du die Lösungen hier https://forum.iobroker.net/user/thomas-braun
                                C 1 Antwort Letzte Antwort
                                  grafana korrigieren
                                  debian buster
                                  Creatorhs
                                  #216
                                  grafana korrigieren
                                  debian buster
                                  Danke für deine schnelle Antwort!
                                  Wie ich die reingebracht habe?! Durch das letzte Update, habe mich an die Artikel hier gehalten. Hatte nur vorhin unter "Hosts" die V14 gesehen, daher meine Aussage. Weiß nicht mehr sicher, welches das letzte Update war, ist schon etwas her...
                                  Grafana korrigieren: Wie?
                                  mit dem letzten Link, den du geschrieben hattest: Was möchtest du mir dort zeigen?
                                  Danke für die Hilfe.
                                  EDIT: Danke, lese mir die links durch...
                                  • C Creatorhs
                                    grafana korrigieren
                                    debian buster
                                    crunchipC Offline
                                    crunchipC Offline
                                    #217
                                    da stehn alle Threads( die oberen) zu deinen Problemen
                                    an welche? dann würde ja keine v12 drin stehen
                                    • C Creatorhs
                                      grafana korrigieren
                                      debian buster
                                      #218
                                      @creatorhs
                                      Bzgl. nodejs kannst du auch probieren mit der aktuellen Beta vom iob_diag-Skript das gerade ziehen zu lassen.
                                      Nutzt dir aber nix bei den anderen Dingen, die da bei dir im Argen liegen.
                                      • C Offline
                                        Chu
                                        schrieb am zuletzt editiert von Chu
                                        #219
                                        ich hab eben das Update von nodeJS 14 auf 18 gemacht. Nach dieser Anleitung: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                                        type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        v18.17.1
                                        v18.17.1
                                        9.6.7
                                        9.6.7
                                        Jedoch erkennt der ioBroker die Version nicht:
                                        und das update für den Admin Adapter kann ebenfalls nicht durchgeführt werden wegen zu geringer nodeJS Version.
                                        Hat jemand eine Idee wie ich den ioBroker die neue Version nutzen lasse?
                                        Thomas BraunT C 2 Antworten Letzte Antwort
                                        • C Chu
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v18.17.1
                                          v18.17.1
                                          9.6.7
                                          9.6.7
                                          #220
                                          @chu sagte in Troubleshooting NodeJS update:
                                          Starte den neu.
