  4. Backitup und Grafana
62 Beiträge 7 Kommentatoren 10.8k Aufrufe 6 Beobachtet
  • K kratan75
    @thomas-braun Geht trotzdem nicht.
    Hier die Ausgabe:
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v18.16.0
    v18.16.0
    9.5.1
    npm ERR! could not determine executable to run
    npm ERR!     /home/pi/.npm/_logs/2023-04-14T16_44_18_966Z-debug-0.log
    Copy text starting here:
                         v.2023-04-02
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/node           v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           3.8G        668M        1.7G         16M        1.5G        3.1G
    Swap:           99M          0B         99M
    Total:         3.9G        668M        1.8G
    Active iob-Instances:   13
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                3685
    States:                 3269
    Size of iob-Database:
    6.7M    /opt/iobroker/iobroker-data/objects.jsonl
    1.3M    /opt/iobroker/iobroker-data/states.jsonl
    Selbes Ergebnis:
    BackItUp:
    Your backup was not completely created. Please check the errors!!
    grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:1898:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2950:11)\n at IncomingMessage.emit (node:events:525:35)\n at endReadableNT (node:internal/streams/readable:1359:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","Authorization":"Bearer ****","User-Agent":"axios/1.3.5","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.3.162:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":false,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
    Irgendwie treibt mich das Teil noch zum Wahnsinn 👿
    Noch eine Idee ?
    Gruß Andi
    #41
    @kratan75 sagte in Backitup und Grafana:
    Da ist nodejs auch bestimmt 'krumm' installiert, denn npx wird natülich in einer gesunden Installation gefunden.
    iob diag
    sagt? Ist natürlich nur sinnvoll in einem aktuellen System, also nicht 'buster'.
    K 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      habe ich noch Buster drauf. Das möchte ich vorerst auch nicht ändern
      Grund ?
      kratan75
      #42
      @djmarc75 Weil ich damit meinen PV-Eigenverbrauch von 2 Anlagen optimiere und steuere und gerade wenig bis keine Zeit habe hier rum zu experimentieren. Der Rechner muss jetzt erst mal laufen. Wenn ich Zeit finde mach ich das Update.
      Gruß Andreas
        iob diag
        kratan75
        schrieb am zuletzt editiert von kratan75
        #43
        @thomas-braun Node JS19 lief ohne Probleme und keinen Fehler. Der tritt erst jetzt auf.
        Skript v.2023-04-02
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         19:02:24 up  4:02,  1 user,  load average: 0.01, 0.19, 0.34
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Fri 2023-04-14 19:02:24 CEST
                   Universal time: Fri 2023-04-14 17:02:24 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        709M        1.6G         16M        1.5G        3.0G
        Swap:           99M          0B         99M
        Total:         3.9G        709M        1.7G
                 3838 M total memory
                  710 M used memory
                  505 M active memory
                 1514 M inactive memory
                 1635 M free memory
                  158 M buffer memory
                 1335 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4       30G  5.2G   23G  19% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/loop1     squashfs   99M   99M     0 100% /snap/core/14788
        /dev/loop0     squashfs   99M   99M     0 100% /snap/core/14950
        /dev/loop2     squashfs  384K  384K     0 100% /snap/minicom/1
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Fri Apr 14 14:59:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:BC:F7:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Apr 14 14:59:31 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Apr 14 14:59:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Apr 14 14:59:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems (real ones only):
        TARGET             SOURCE         FSTYPE   OPTIONS
        /                  /dev/mmcblk0p2 ext4     rw,noatime
        |-/sys/fs/bpf      none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
        |-/snap/core/14788 /dev/loop1     squashfs ro,nodev,relatime
        |-/snap/core/14950 /dev/loop0     squashfs ro,nodev,relatime
        |-/snap/minicom/1  /dev/loop2     squashfs ro,nodev,relatime
        `-/boot            /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.1G    /var/
        508M    /var/lib
        294M    /var/lib/snapd
        253M    /var/log
        197M    /var/lib/snapd/snaps
        /opt/iobroker/backups:
        533M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        295M    /opt/iobroker/iobroker-data/
        252M    /opt/iobroker/iobroker-data/files
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        35M     /opt/iobroker/iobroker-data/backup-objects
        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
        6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
         *** 18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.23
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          system.adapter.fronius.0                : fronius               : iobroker                                 - disabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
        + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.kecontact.0              : kecontact             : iobroker                                 - disabled
          system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
          system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
          system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
          system.adapter.modbus.3                 : modbus                : iobroker                                 - disabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "backitup"     : 2.6.16   , installed 2.6.16
        Adapter    "countdown"    : 1.2.5    , installed 1.2.5
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "email"        : 1.1.4    , installed 1.1.4
        Adapter    "fronius"      : 1.1.3    , installed 1.1.3
        Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
        Adapter    "kecontact"    : 1.5.2    , installed 1.5.2
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "openweathermap": 0.3.3   , installed 0.3.3
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
        Objects and States
        Objects:        3685
        States:         3269
        Hit:1 http://archive.raspbian.org/raspbian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18691      633/sshd
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16738      626/influxd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       161446     21811/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       161439     21811/iobroker.js-c
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       160745     21832/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       162720     22068/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        16177      626/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18693      633/sshd
        tcp6       0      0 :::3000                 :::*                    LISTEN      109        16764      620/grafana
        udp        0      0 0.0.0.0:51197           0.0.0.0:*                           108        16508      372/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16663      618/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16506      372/avahi-daemon: r
        udp6       0      0 :::37553                :::*                                108        16509      372/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        16507      372/avahi-daemon: r
        2023-04-14 19:01:20.070  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:25.078  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:30.099  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:35.093  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:40.079  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:45.066  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:50.068  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:01:55.085  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:00.095  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:05.080  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:10.069  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:15.121  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:20.080  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:25.048  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:30.071  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:35.054  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:40.050  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:45.165  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:50.038  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:02:55.053  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:03:00.063  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:03:05.063  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:03:10.044  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:03:15.130  - error: rpi2.0 (22163) GPIO is not initialized!
        2023-04-14 19:03:20.060  - error: rpi2.0 (22163) GPIO is not initialized!
        iob diag has finished.
        • K kratan75
          Skript v.2023-04-02
          *** BASE SYSTEM ***
          Docker          : false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   3838 M total memory
                    710 M used memory
                    505 M active memory
                   1635 M free memory
                    158 M buffer memory
                   1335 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          508M    /var/lib
          294M    /var/lib/snapd
          253M    /var/log
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        3685
          States:         3269
          Pending Updates: 0
          #44
          @kratan75 Auf meiner Experimental-Kiste läuft nodejs19 auch. Aber du willst ja keine aktuellste Software laufen haben, sonst würdest du nicht am längst abgekündigten Buster festhalten.
          • K kratan75
            Skript v.2023-04-02
            *** BASE SYSTEM ***
            Docker          : false
            Release:        10
            Codename:       buster
            VERSION_ID="10"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           99M          0B         99M
                     3838 M total memory
                      710 M used memory
                      505 M active memory
                     1635 M free memory
                      158 M buffer memory
                     1335 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /var:
            1.1G    /var/
            508M    /var/lib
            294M    /var/lib/snapd
            253M    /var/log
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        3685
            States:         3269
            Pending Updates: 0
            #45
            Was ist das?
              kratan75
              #46
              Wie gesagt, im Moment habe ich keine Zeit und erst nach dem Update gibt es diese Probleme. Ich werde mal mein SD- Kartenbackup auf einer Experimintal Kiste installieren wenn Zeit ist. Da bestätigt sich mal wieder die Aussage (never touch a running system).
              Gibt es eine Anleitung für das Update ?
              Gruß Andi
                Was ist das?
                kratan75
                #47
                Keine Ahnung. Wo hast das gesehen ?
                Gruß Andi
                • K kratan75
                  Gruß Andi
                  #48
                  Im Gegenteil. Wenn es irgendwas bestätigt dann: Halte die Kiste auf aktuellem Stand.
                  Ja, ich hatte da vor Urzeiten, als das Thema aktuell war was zu geschrieben.
                  • K kratan75
                    Gruß Andi
                    #49
                    Im Output von iob diag
                      kratan75
                      #50
                      @thomas-braun Das scheint irgendwas im Filesystem zu sein. Hängt das eventuell damit zusammen weil ich mal eine 64 GB Karte auf eine 128 GB Karte geklont habe ?
                      • K kratan75
                        #51
                        @kratan75
                        Das sieht eher wie eine Installation von minicom als snap aus. Fragt sich aber mal wieder warum... Gibt es nämlich auch über das Debian-Repo:
                        echad@chet:~ $ apt policy minicom
                        minicom:
                          Installed: (none)
                          Candidate: 2.8-2
                          Version table:
                             2.8-2 500
                          @kratan75
                          minicom:
                            Installed: (none)
                            Candidate: 2.8-2
                            Version table:
                               2.8-2 500
                          kratan75
                          #52
                          @thomas-braun Auf dem System läuft ein Volkszähler welcher seriell über USB kommuniziert. Ausserdem ein USB-> Modbus Converter.
                          Das hängt eventuell damit zusammen.
                          Hast du einen Link zum upgraden von Buster auf Bullseye ?
                          Wenn es am Wochenende weiter so schifft, kann ichs mal probieren. Vorher muß ich aber nochmal die SD-Karte Klonen damit nicht alles zerschossen wird.
                          • K kratan75
                            #53
                            @kratan75
                            https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                              @kratan75
                              kratan75
                              #54
                              @thomas-braun Okay Danke für den Link. Ich schau es mir die Tage mal an.
                              Nur noch eine Frage zur IP Adresse bzw. DHCP was hier angesprochen wird.
                              Kann ich unter
                              /etc/systemd/system/dhcpcd.service.d/wait.conf
                              folgenden Code für eine feste IP Adresse verwenden ?
                              interface eth0
                              static ip_address=192.168.3.162/24
                              static routers=192.168.3.1
                              static domain_name_servers=192.168.3.1 8.8.8.8 fd51:42f8:caae:d92e::1
                              Ich kann keine DHCP Adresse gebrauchen, weil dieses System direkt mit anderen Systemen Kommunizieren muss. Daher möchte ich dort auf jeden Fall eine feste IP drinnen haben.
                              Im Buster war das ja unter
                              /etc/dhcpcd.conf
                              hinterlegt.
                              • K kratan75
                                Kann ich unter
                                interface eth0
                                /etc/dhcpcd.conf
                                hinterlegt.
                                #55
                                @kratan75
                                Kann ich dir nicht sagen, ich werkel hier mit hostnames und DHCP.
                                  kratan75
                                  #56
                                  @thomas-braun Guten Morgen
                                  Also ich habe mich gestern tatsächlich spät Abends noch durchgerungen einen experimentier-Pi aufzusetzen und das Update von Buster auf Bullseye dort zu installieren.
                                  Resultat ist, das dies wohl anscheinend tatsächlich des Rätsels Lösung war. Das BackitUp läuft nun ohne Probleme durch. Danke nochmal für den Tipp. Trotzdem habe ich festgestellt das immer noch Fehlermeldungen in der NPM Liste stehen welche ich mir nicht erklären kann, weil alle Erweiterungen exakt auf diesen Stand sind welche im Log stehen.
                                  Mit dazu habe ich nochmal einen neuen API Key für Grafana erstellt, der hatte auch noch Probleme gemacht.
                                  BackItUp:
                                  Eine neue iobroker Sicherung wurde am 15. April 2023 um 02:40 Uhr erstellt, und nach 85.214.205.194/ via FTP kopiert/verschoben.
                                  Hier mal die Logeintrage von npm (/home/iobroker/.npm/_logs/2023-04-15T07_49_11_023Z-debug-0.log)
                                   verbose cli /usr/bin/node /usr/bin/npm
                                  1 info using npm@9.5.1
                                  2 info using node@v18.16.0
                                  3 timing npm:load:whichnode Completed in 3ms
                                  4 timing config:load:defaults Completed in 6ms
                                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 16ms
                                  6 timing config:load:builtin Completed in 17ms
                                  7 timing config:load:cli Completed in 25ms
                                  8 timing config:load:env Completed in 1ms
                                  9 timing config:load:file:/opt/iobroker/node_modules/iobroker.backitup/.npmrc Completed in 1ms
                                  10 timing config:load:project Completed in 10ms
                                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                  12 timing config:load:user Completed in 0ms
                                  13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                  14 timing config:load:global Completed in 1ms
                                  15 timing config:load:setEnvs Completed in 3ms
                                  16 timing config:load Completed in 66ms
                                  17 timing npm:load:configload Completed in 66ms
                                  18 timing npm:load:mkdirpcache Completed in 1ms
                                  19 timing npm:load:mkdirplogs Completed in 1ms
                                  20 verbose title npm list
                                  21 verbose argv "list"
                                  22 timing npm:load:setTitle Completed in 4ms
                                  23 timing config:load:flatten Completed in 11ms
                                  24 timing npm:load:display Completed in 13ms
                                  25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-04-14T22_34_18_626Z-
                                  26 verbose logfile /home/iobroker/.npm/_logs/2023-04-14T22_34_18_626Z-debug-0.log
                                  27 timing npm:load:logFile Completed in 18ms
                                  28 timing npm:load:timers Completed in 0ms
                                  29 timing npm:load:configScope Completed in 0ms
                                  30 timing npm:load Completed in 108ms
                                  31 timing arborist:ctor Completed in 2ms
                                  32 silly logfile start cleaning logs, removing 1 files
                                  33 silly logfile done cleaning log files
                                  34 timing command:list Completed in 102ms
                                  35 verbose stack Error: missing: @alcalzone/release-script-plugin-iobroker@^3.5.9, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: @alcalzone/release-script-plugin-license@^3.5.9, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: @alcalzone/release-script@^3.5.9, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: @googleapis/drive@^4.0.2, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: @iobroker/adapter-core@^2.6.7, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: @iobroker/testing@^4.1.0, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: chai@^4.3.7, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: dropbox-v2-api@^2.5.10, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: express@^4.18.2, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: ftp@^0.3.10, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: google-auth-library@^8.7.0, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: gulp@^4.0.2, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: mocha@^10.2.0, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: node-wol@^0.1.1, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: onedrive-api@^1.0.7, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: request@^2.88.2, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: tar-fs@^2.1.1, required by iobroker.backitup@2.6.16
                                  35 verbose stack missing: webdav@^4.11.2, required by iobroker.backitup@2.6.16
                                  35 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:203:9)
                                  35 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:134:5)
                                  36 verbose cwd /opt/iobroker/node_modules/iobroker.backitup
                                  37 verbose Linux 6.1.21-v8+
                                  38 verbose node v18.16.0
                                  39 verbose npm  v9.5.1
                                  40 error code ELSPROBLEMS
                                  Hier der Stand seit heute Morgen (iob diag):
                                  Skript v.2023-04-02
                                  *** BASE SYSTEM ***
                                  Architecture    : aarch64
                                  Docker          : false
                                  Description:    Raspbian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                  VERSION_ID="11"
                                  VERSION="11 (bullseye)"
                                  VERSION_CODENAME=bullseye
                                  ID=raspbian
                                  ID_LIKE=debian
                                   09:45:53 up  8:06,  1 user,  load average: 0.85, 0.67, 0.63
                                  CPU threads: 4
                                                 Local time: Sat 2023-04-15 09:45:53 CEST
                                             Universal time: Sat 2023-04-15 07:45:53 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        1.1G        1.7G        0.0K        924M        2.7G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        1.1G        1.8G
                                           3794 M total memory
                                           1124 M used memory
                                           1232 M active memory
                                            650 M inactive memory
                                           1745 M free memory
                                            100 M buffer memory
                                            824 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     759M 1008K  758M   1% /run
                                  /dev/loop0     squashfs  384K  384K     0 100% /snap/minicom/1
                                  /dev/loop2     squashfs   99M   99M     0 100% /snap/core/14950
                                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                  tmpfs          tmpfs     380M  4.0K  380M   1% /run/user/1000
                                  [Sat Apr 15 01:38:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1  smsc95xx.macaddr=E4:5F:01:A9:73:27 vc_mem.mem_base=0x3ec00000 vc_mem        .mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a62f624d-0        2 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Sat Apr 15 01:38:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                  [Sat Apr 15 01:38:57 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                                  [Sat Apr 15 01:38:59 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  |-/snap/minicom/1  /dev/loop0     squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core/14950 /dev/loop2     squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core/14788 /dev/loop1     squashfs ro,nodev,relatime,errors=continue
                                  `-/boot            /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,cod        epage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                  /var:
                                  1.2G    /var/
                                  535M    /var/lib
                                  318M    /var/log
                                  294M    /var/lib/snapd
                                  200M    /var/cache
                                  209M    /opt/iobroker/backups/
                                  299M    /opt/iobroker/iobroker-data/
                                  9.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                  6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c        9.chunk.js.map
                                  6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.j        s.map
                                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
                                  4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922        d.chunk.js.map
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
                                  nodejs:
                                    Version table:
                                          500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                       12.22.12~dfsg-1~deb11u3 500
                                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapter State
                                  + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
                                  + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                                  + system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
                                  + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                  + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                                  + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                                  + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
                                  + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                                  + instance is alive
                                  Objects and States
                                  Objects:        3685
                                  States:         3195
                                  Hit:1 http://archive.raspbian.org/raspbian bullseye InRelease
                                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:3 https://apt.grafana.com stable InRelease
                                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                  Hit:6 https://repos.influxdata.com/debian stable InRelease
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16452      759/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16459      759/iobroker.js-con
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1984       539/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13037      664/influxd
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14798      784/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15159      1040/io.web.0
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        14717      664/influxd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1986       539/sshd: /usr/sbin
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      109        16490      659/grafana
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12772      390/avahi-daemon: r
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14214      658/dhcpcd
                                  udp        0      0 0.0.0.0:39039           0.0.0.0:*                           1001       30278      2683/io.kecontact.0
                                  udp        0      0 0.0.0.0:55611           0.0.0.0:*                           108        12774      390/avahi-daemon: r
                                  udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       27137      2683/io.kecontact.0
                                  udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       27138      2683/io.kecontact.0
                                  udp6       0      0 :::5353                 :::*                                108        12773      390/avahi-daemon: r
                                  udp6       0      0 :::34479                :::*                                108        12775      390/avahi-daemon: r
                                  2023-04-15 09:44:33.791  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:44:39.750  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:44:45.639  - info: smartmeter.0 (2608) Received 13 values, 5 updated
                                  2023-04-15 09:44:51.506  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:44:57.331  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:45:03.117  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:45:08.899  - info: smartmeter.0 (2608) Received 13 values, 4 updated
                                  2023-04-15 09:45:14.601  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:45:20.353  - info: smartmeter.0 (2608) Received 13 values, 5 updated
                                  2023-04-15 09:45:26.075  - info: smartmeter.0 (2608) Received 13 values, 5 updated
                                  2023-04-15 09:45:31.800  - info: smartmeter.0 (2608) Received 13 values, 5 updated
                                  2023-04-15 09:45:37.652  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:45:43.530  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:45:49.296  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:45:55.025  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:00.782  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:06.467  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:12.207  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:17.941  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:23.605  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:29.256  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:34.946  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:40.701  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:46.529  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  2023-04-15 09:46:52.261  - info: smartmeter.0 (2608) Received 13 values, 6 updated
                                  Und hier die npm ls Ausgabe:
                                  pi@iobroker:~ $ cd /opt/iobroker/node_modules/iobroker.backitup
                                  pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ npm ls
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! missing: @alcalzone/release-script-plugin-iobroker@^3.5.9, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: @alcalzone/release-script-plugin-license@^3.5.9, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: @alcalzone/release-script@^3.5.9, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: @googleapis/drive@^4.0.2, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: @iobroker/adapter-core@^2.6.7, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: @iobroker/testing@^4.1.0, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: chai@^4.3.7, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: dropbox-v2-api@^2.5.10, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: express@^4.18.2, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: ftp@^0.3.10, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: google-auth-library@^8.7.0, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: gulp@^4.0.2, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: mocha@^10.2.0, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: node-wol@^0.1.1, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: onedrive-api@^1.0.7, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: request@^2.88.2, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: tar-fs@^2.1.1, required by iobroker.backitup@2.6.16
                                  npm ERR! missing: webdav@^4.11.2, required by iobroker.backitup@2.6.16
                                  iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                                  ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-iobroker@^3.5.9
                                  ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-license@^3.5.9
                                  ├── UNMET DEPENDENCY @alcalzone/release-script@^3.5.9
                                  ├── UNMET DEPENDENCY @googleapis/drive@^4.0.2
                                  ├── UNMET DEPENDENCY @iobroker/adapter-core@^2.6.7
                                  ├── UNMET DEPENDENCY @iobroker/testing@^4.1.0
                                  ├── axios@1.3.5
                                  ├── UNMET DEPENDENCY chai@^4.3.7
                                  ├── UNMET DEPENDENCY dropbox-v2-api@^2.5.10
                                  ├── UNMET DEPENDENCY express@^4.18.2
                                  ├── fs-extra@11.1.1
                                  ├── UNMET DEPENDENCY ftp@^0.3.10
                                  ├── UNMET DEPENDENCY google-auth-library@^8.7.0
                                  ├── UNMET DEPENDENCY gulp@^4.0.2
                                  ├── UNMET DEPENDENCY mocha@^10.2.0
                                  ├── node-schedule@2.1.1
                                  ├── UNMET DEPENDENCY node-wol@^0.1.1
                                  ├── UNMET DEPENDENCY onedrive-api@^1.0.7
                                  ├── UNMET DEPENDENCY request@^2.88.2
                                  ├── UNMET DEPENDENCY tar-fs@^2.1.1
                                  └── UNMET DEPENDENCY webdav@^4.11.2
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-04-15T07_49_11_023Z-debug-0.log
                                  Es läuft so jetzt alles wieder problemlos.
                                  Ich hätte aber gerne ein sauberes System. Was kann das noch sein ?
                                  Gruß Andi
                                  • K kratan75
                                    BackItUp:
                                    Skript v.2023-04-02
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    CPU threads: 4
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             3794 M total memory
                                             1124 M used memory
                                             1745 M free memory
                                              100 M buffer memory
                                              824 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.2G    /var/
                                    535M    /var/lib
                                    318M    /var/log
                                    294M    /var/lib/snapd
                                    200M    /var/cache
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    javascript:     6.1.4
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        3685
                                    States:         3195
                                    Pending Updates: 0
                                    ├── axios@1.3.5
                                    ├── fs-extra@11.1.1
                                    Gruß Andi
                                    #57
                                    @kratan75
                                    Du stehst im falschen Verzeichnis.
                                    cd /opt/iobroker
                                    npm ls
                                    simatecS K 2 Antworten Letzte Antwort
                                    • K kratan75
                                      BackItUp:
                                      Skript v.2023-04-02
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3794 M total memory
                                               1124 M used memory
                                               1745 M free memory
                                                100 M buffer memory
                                                824 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.2G    /var/
                                      535M    /var/lib
                                      318M    /var/log
                                      294M    /var/lib/snapd
                                      200M    /var/cache
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        3685
                                      States:         3195
                                      Pending Updates: 0
                                      ├── axios@1.3.5
                                      ├── fs-extra@11.1.1
                                      Gruß Andi
                                      #58
                                      @kratan75
                                      Zieh den js-controller noch auf die aktuelle Version und installier den Backitup-Adapter nochmal neu.
                                        @kratan75
                                        cd /opt/iobroker
                                        npm ls
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #59
                                        @kratan75 Aber bitte dann Backitup nicht nur in den Instanzen, sondern auch im Tab Adapter vorher löschen
                                        • Besuche meine Github Seite
                                        • HowTo Restore ioBroker
                                          @kratan75
                                          cd /opt/iobroker
                                          npm ls
                                          kratan75
                                          #60
                                          @thomas-braun Hallo Thomas, also wenn ich in dieses Verzeichiss wechsel sieht alles gut aus.
                                          pi@iobroker:/opt/iobroker $ npm ls
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├── iobroker.admin@6.3.5
                                          ├── iobroker.backitup@2.6.16
                                          ├── iobroker.countdown@1.2.5
                                          ├── iobroker.discovery@3.1.0
                                          ├── iobroker.email@1.1.4
                                          ├── iobroker.fronius@1.1.3
                                          ├── iobroker.icons-addictive-flavour-png@0.1.0
                                          ├── iobroker.icons-icons8@0.0.1
                                          ├── iobroker.icons-material-png@0.1.0
                                          ├── iobroker.icons-mfd-png@1.1.0
                                          ├── iobroker.icons-mfd-svg@1.1.0
                                          ├── iobroker.icons-open-icon-library-png@0.1.2
                                          ├── iobroker.icons-ultimate-png@1.0.1
                                          ├── iobroker.influxdb@3.2.0
                                          ├── iobroker.javascript@6.1.4
                                          ├── iobroker.js-controller@4.0.23
                                          ├── iobroker.kecontact@1.5.2
                                          ├── iobroker.modbus@5.0.11
                                          ├── iobroker.openweathermap@0.3.3
                                          ├── iobroker.ping@1.5.3
                                          ├── iobroker.pvforecast@2.3.0
                                          ├── iobroker.rpi2@1.3.2
                                          ├── iobroker.smartmeter@3.3.4
                                          ├── iobroker.vis-icontwo@0.93.0
                                          ├── iobroker.vis-inventwo@3.3.1
                                          ├── iobroker.vis-timeandweather@1.2.2
                                          ├── iobroker.vis@1.4.16
                                          ├── iobroker.weatherunderground@3.4.2
                                          └── iobroker.web@4.3.0
                                          Die BackitUp Instanz habe ich gestern schon neu installiert und die alte gelöscht, weil ich den Adapter sonst nicht ans laufen bekommen habe. Ich hatte den Gedanken mit der Neuinstallation auch, weil trotz upgrade mit der alten Installation gar nichts mehr ging, Es kam immer dieselbe Fehlermeldung.
                                          Jetzt steht halt Backitup1. Aber das ist nur ein Schönheitsfehler. Die "1" dahinter wird scheinbar vom System vergeben und kann nicht geändert werden.
                                          Ich denke jetzt läuft wieder alles so wie es soll.
                                          Gibt es noch was, wo ich noch reinschauen sollte ?
                                          Danke nochmal an alle, wo hier mit geholfen haben den Fehler zu finden :-)
                                          Gruß Andi
