  3. Einsteigerfragen
  4. Installation
  5. History Adapter läßt sich nicht installieren
Geplant Angeheftet Gesperrt Verschoben Installation
45 Beiträge 6 Kommentatoren 4.6k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @bastel2021 sagte in History Adapter läßt sich nicht installieren:
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobr oker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
    nochmal:
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    Bastel2021
    @glasfaser
    Siehe Terminal
    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm                         -rf ${i%%/}; done
    pi@raspberrypi:~ $ ^C
    pi@raspberrypi:~ $ iob upgrade javascript --debug
    This upgrade of "javascript" will introduce the following changes:
    -> 6.1.4:
    Corrected small error in rules
    Tried to fix debug mode
    -> 6.1.3:
    Prevent adapter crash when script could not be compiled
    -> 6.1.2:
    Added ukrainian translation
    -> 6.1.0:
    Add a configurable check for number of setStates per Minute to prevent scripts from taking down ioBroker. Default are 1000 set                        State per minute. Only stops if the number is reached 2 minutes in a row!
    Add createAlias method to create aliases for states
    Add setStateDelayed to selector
    Add options to exec command
    Fix issues with cancelling schedules when stopping scripts
    Corrected debug mode
    Would you like to upgrade javascript from @6.0.3 to @6.1.4 now? [(y)es, (n)o]: y
    Update javascript from @6.0.3 to @6.1.4
    NPM version: 8.19.3
    Installing iobroker.javascript@6.1.4... (System call)
    ^C
    pi@raspberrypi:~ $
    GlasfaserG crunchipC 2 Antworten Letzte Antwort
    • B Bastel2021
      @glasfaser
      Siehe Terminal
      -> 6.1.4:
      -> 6.1.3:
      -> 6.1.2:
      -> 6.1.0:
      NPM version: 8.19.3
      ^C
      pi@raspberrypi:~ $
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @bastel2021
      sehe kein Fehler .. sollte jetzt die aktuelle 6.1.4 sein
      B 1 Antwort Letzte Antwort
        @bastel2021
        Bastel2021
        @glasfaser
        pi@raspberrypi:/opt/iobroker $ npm ls
        iobroker.inst@3.0.0 /opt/iobroker
        ├── iobroker.admin@6.3.5
        ├── iobroker.backitup@2.5.10
        ├── iobroker.discovery@3.1.0
        ├── iobroker.flot@1.11.0
        ├── iobroker.history@2.2.4
        ├── iobroker.javascript@6.0.3
        ├── iobroker.js-controller@4.0.23
        ├── iobroker.mqtt@4.0.7
        ├── iobroker.node-red@4.0.0
        ├── iobroker.pushover@3.0.3
        ├── iobroker.sonoff@2.5.1
        ├── iobroker.web@4.3.0
        └── iobroker.zigbee@1.8.10
        • B Bastel2021
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @bastel2021
          iob list adapters
          sagt
            @bastel2021
            iob list adapters
            sagt
            Bastel2021
            @glasfaser
            pi@raspberrypi:/opt/iobroker $ iob list adapters
            system.adapter.admin                   : admin          - v6.3.5
            system.adapter.backitup                : backitup       - v2.5.10
            system.adapter.discovery               : discovery      - v3.1.0
            system.adapter.flot                    : flot           - v1.11.0
            system.adapter.history                 : history        - v2.2.4
            system.adapter.javascript              : javascript     - v6.0.3
            system.adapter.mqtt                    : mqtt           - v4.0.7
            system.adapter.node-red                : node-red       - v4.0.0
            system.adapter.pushover                : pushover       - v3.0.3
            system.adapter.sonoff                  : sonoff         - v2.5.1
            system.adapter.web                     : web            - v4.3.0
            system.adapter.zigbee                  : zigbee         - v1.8.10
            • B Bastel2021
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @bastel2021
              Mache mal ein
              sudo reboot
                @bastel2021
                Mache mal ein
                sudo reboot
                Bastel2021
                @glasfaser
                nach Reboot
                pi@raspberrypi:~ $ iob list adapters
                pi@raspberrypi:~ $
                • B Bastel2021
                  @glasfaser
                  nach Reboot
                  pi@raspberrypi:~ $
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  @bastel2021
                  iobroker stop
                  rm /opt/iobroker/package*
                  iobroker start
                  iob list adapters
                    @bastel2021
                    iobroker stop
                    iobroker start
                    iob list adapters
                    Bastel2021
                    @glasfaser
                    pi@raspberrypi:~ $ iobroker stop
                    pi@raspberrypi:~ $ rm /opt/iobroker/package*
                    pi@raspberrypi:~ $ iobroker start
                    pi@raspberrypi:~ $
                    • B Bastel2021
                      @glasfaser
                      Siehe Terminal
                      -> 6.1.4:
                      -> 6.1.3:
                      -> 6.1.2:
                      -> 6.1.0:
                      NPM version: 8.19.3
                      ^C
                      pi@raspberrypi:~ $
                      crunchipC Abwesend
                      crunchipC Abwesend
                      ^C
                      ist das überhaupt durchgelaufen?
                      • B Bastel2021
                        @glasfaser
                        pi@raspberrypi:~ $
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        @bastel2021
                        iob list instances
                        EDIT :
                        iob list adapters
                          ^C
                          Bastel2021
                          @crunchip
                          erst hatte ich gedacht das das System sich aufgehangen hat.
                          Nach "Installing iobroker.javascript@6.1.4... (System call)" kam lange Zeit nichts mehr.
                          Was das ^C zu bedeuten hat...?
                          • B Bastel2021
                            @crunchip
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            @bastel2021
                            Bitte nochmal die Befehle oben .....
                            B 2 Antworten Letzte Antwort
                              @bastel2021
                              Bastel2021
                              @glasfaser
                              habe ich gemacht!
                              System hat sich aufgehangen (Terminal Fenster ohne Reaktion)
                              IOBroker über Admin nicht mehr erreichbar
                              Werde den RPI neustarten
                                @bastel2021 bitte immer alle Konsolen Einý und Ausgaben als Text in code-tags posten!
                                  @bastel2021
                                  Bastel2021
                                  @glasfaser
                                  nach Neustart
                                  node:internal/modules/cjs/loader:998
                                    throw err;
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                      at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                      at node:internal/main/run_main_module:22:47 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                  pi@raspberrypi:~ $
                                  GlasfaserG HomoranH 2 Antworten Letzte Antwort
                                  • B Bastel2021
                                    @glasfaser
                                    nach Neustart
                                      throw err;
                                      requireStack: []
                                    pi@raspberrypi:~ $
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    @bastel2021
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.js-controller
                                    iobroker restart
                                    • B Bastel2021
                                      @glasfaser
                                      nach Neustart
                                        throw err;
                                        requireStack: []
                                      pi@raspberrypi:~ $
                                      @bastel2021 hast du den Stecker gezogen gehabt?
                                      War der Server nur schwer am arbeiten? und nicht wirklich tot?
                                      was ist das eigentlich für ein Pi?
                                        Bastel2021
                                        @homoran RPi 3B
                                        • B Bastel2021
                                          @homoran RPi 3B
                                          @bastel2021 was sagt top?
                                          da bist du wahrscheinlich schon am Ende der Möglichkeiten mit nur 1GB RAM.
