  3. Einsteigerfragen
  4. Installation
  5. History Adapter läßt sich nicht installieren
45 Beiträge 6 Kommentatoren 4.6k Aufrufe 5 Beobachtet
  • B Bastel2021
    @glasfaser
    pi@raspberrypi:/opt/iobroker $ npm ls
    iobroker.inst@3.0.0 /opt/iobroker
    ├── iobroker.admin@6.3.5
    ├── iobroker.backitup@2.5.10
    ├── iobroker.discovery@3.1.0
    ├── iobroker.flot@1.11.0
    ├── iobroker.history@2.2.4
    ├── iobroker.javascript@6.0.3
    ├── iobroker.js-controller@4.0.23
    ├── iobroker.mqtt@4.0.7
    ├── iobroker.node-red@4.0.0
    ├── iobroker.pushover@3.0.3
    ├── iobroker.sonoff@2.5.1
    ├── iobroker.web@4.3.0
    └── iobroker.zigbee@1.8.10
    GlasfaserG Offline
    GlasfaserG Offline
    @bastel2021
    iob list adapters
    sagt
    • GlasfaserG Glasfaser
      @bastel2021
      iob list adapters
      sagt
      Bastel2021
      @glasfaser
      pi@raspberrypi:/opt/iobroker $ iob list adapters
      system.adapter.admin                   : admin          - v6.3.5
      system.adapter.backitup                : backitup       - v2.5.10
      system.adapter.discovery               : discovery      - v3.1.0
      system.adapter.flot                    : flot           - v1.11.0
      system.adapter.history                 : history        - v2.2.4
      system.adapter.javascript              : javascript     - v6.0.3
      system.adapter.mqtt                    : mqtt           - v4.0.7
      system.adapter.node-red                : node-red       - v4.0.0
      system.adapter.pushover                : pushover       - v3.0.3
      system.adapter.sonoff                  : sonoff         - v2.5.1
      system.adapter.web                     : web            - v4.3.0
      system.adapter.zigbee                  : zigbee         - v1.8.10
      • B Bastel2021
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @bastel2021
        Mache mal ein
        sudo reboot
          @bastel2021
          Mache mal ein
          sudo reboot
          Bastel2021
          @glasfaser
          nach Reboot
          pi@raspberrypi:~ $ iob list adapters
          pi@raspberrypi:~ $
          • B Bastel2021
            @glasfaser
            nach Reboot
            pi@raspberrypi:~ $
            GlasfaserG Offline
            GlasfaserG Offline
            @bastel2021
            iobroker stop
            rm /opt/iobroker/package*
            iobroker start
            iob list adapters
              @bastel2021
              iobroker stop
              iobroker start
              iob list adapters
              Bastel2021
              @glasfaser
              pi@raspberrypi:~ $ iobroker stop
              pi@raspberrypi:~ $ rm /opt/iobroker/package*
              pi@raspberrypi:~ $ iobroker start
              pi@raspberrypi:~ $
              • B Bastel2021
                @glasfaser
                Siehe Terminal
                pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm                         -rf ${i%%/}; done
                pi@raspberrypi:~ $ ^C
                pi@raspberrypi:~ $ iob upgrade javascript --debug
                This upgrade of "javascript" will introduce the following changes:
                -> 6.1.4:
                Corrected small error in rules
                Tried to fix debug mode
                -> 6.1.3:
                Prevent adapter crash when script could not be compiled
                -> 6.1.2:
                Added ukrainian translation
                -> 6.1.0:
                Add a configurable check for number of setStates per Minute to prevent scripts from taking down ioBroker. Default are 1000 set                        State per minute. Only stops if the number is reached 2 minutes in a row!
                Add createAlias method to create aliases for states
                Add setStateDelayed to selector
                Add options to exec command
                Fix issues with cancelling schedules when stopping scripts
                Corrected debug mode
                Would you like to upgrade javascript from @6.0.3 to @6.1.4 now? [(y)es, (n)o]: y
                Update javascript from @6.0.3 to @6.1.4
                NPM version: 8.19.3
                Installing iobroker.javascript@6.1.4... (System call)
                ^C
                pi@raspberrypi:~ $
                crunchipC Abwesend
                crunchipC Abwesend
                @bastel2021 sagte in History Adapter läßt sich nicht installieren:
                ^C
                ist das überhaupt durchgelaufen?
                • B Bastel2021
                  @glasfaser
                  pi@raspberrypi:~ $
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @bastel2021
                  iob list instances
                  EDIT :
                  iob list adapters
                    ^C
                    Bastel2021
                    @crunchip
                    erst hatte ich gedacht das das System sich aufgehangen hat.
                    Nach "Installing iobroker.javascript@6.1.4... (System call)" kam lange Zeit nichts mehr.
                    Was das ^C zu bedeuten hat...?
                    • B Bastel2021
                      @crunchip
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @bastel2021
                      Bitte nochmal die Befehle oben .....
                      B 2 Antworten Letzte Antwort
                        @bastel2021
                        Bastel2021
                        @glasfaser
                        habe ich gemacht!
                        System hat sich aufgehangen (Terminal Fenster ohne Reaktion)
                        IOBroker über Admin nicht mehr erreichbar
                        Werde den RPI neustarten
                          @bastel2021 bitte immer alle Konsolen Einý und Ausgaben als Text in code-tags posten!
                            @bastel2021
                            Bastel2021
                            @glasfaser
                            nach Neustart
                            node:internal/modules/cjs/loader:998
                              throw err;
                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                at node:internal/main/run_main_module:22:47 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                            pi@raspberrypi:~ $
                            GlasfaserG HomoranH 2 Antworten Letzte Antwort
                            • B Bastel2021
                              @glasfaser
                              nach Neustart
                                throw err;
                                requireStack: []
                              pi@raspberrypi:~ $
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @bastel2021
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                              iobroker restart
                              • B Bastel2021
                                @glasfaser
                                nach Neustart
                                  throw err;
                                  requireStack: []
                                pi@raspberrypi:~ $
                                @bastel2021 hast du den Stecker gezogen gehabt?
                                War der Server nur schwer am arbeiten? und nicht wirklich tot?
                                was ist das eigentlich für ein Pi?
                                  Bastel2021
                                  @homoran RPi 3B
                                  • B Bastel2021
                                    @homoran RPi 3B
                                    @bastel2021 was sagt top?
                                    da bist du wahrscheinlich schon am Ende der Möglichkeiten mit nur 1GB RAM.
                                      @bastel2021
                                      cd /opt/iobroker
                                      iobroker restart
                                      Bastel2021
                                      @glasfaser
                                      pi@raspberrypi:~ $ cd /opt/iobroker
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-contr                                            oller
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rename
                                      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                                      npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-02-05T19_59_12_122Z-debug-0.log
                                      • B Bastel2021
                                        @glasfaser
                                        npm ERR! errno -39
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        cd /opt/iobroker
                                        iobroker restart
                                          cd /opt/iobroker
                                          iobroker restart
                                          Bastel2021
                                          @glasfaser
                                            throw err;
                                            requireStack: []
