  4. Raspberry Absturz alle 3 Tage
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • CodierknechtC Codierknecht
    @shellyrulestheworld
    Mach mal Deine Credentials für den Google-Kalender unkenntlich - sonst hagelt's womöglich bald Termine 😁
    shellyrulestheworld
    #41
    @codierknecht 😨 🤣
    • S shellyrulestheworld
      @codierknecht 😨 🤣
      shellyrulestheworld
      #42
      Zeile 10 --> da hab ich wohl einen Adapter installiert... Da ging es gut
      2023-01-23 06:20:09.729 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 06:20:59.603 - info: jarvis.0 (1493) Client with IP 192.168.178.37 connected.
      2023-01-23 06:21:55.238 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2023-01-23 06:22:09.760 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
      2023-01-23 06:22:13.959 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2023-01-23 06:22:19.926 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
      2023-01-23 06:22:32.239 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2023-01-23 06:24:08.833 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2023-01-23 06:24:45.302 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2023-01-23 06:24:49.474 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-01-23 06:25:02.363 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 37640
      2023-01-23 06:25:07.766 - info: dwd.0 (37640) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
      2023-01-23 06:25:10.465 - info: dwd.0 (37640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-23 06:25:11.019 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 06:25:44.430 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37
      2023-01-23 06:27:53.204 - info: host.raspberrypi iobroker add pollenflug --host raspberrypi
      2023-01-23 06:27:58.536 - info: host.raspberrypi iobroker NPM version: 8.19.3Installing iobroker.pollenflug@1.0.6... (System call)
        shellyrulestheworld
        #43
        Es scheint, wenn der admin.1 das anfordert zu krachen. Wie oft macht der admin das denn?
          CodierknechtC Online
          Codierknecht
          #44
          @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
          admin.1
          Wieso eigentlich admin.1. Hast Du mehr als eine Admin-Instanz laufen?
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            admin.1
            shellyrulestheworld
            #45
            @codierknecht nein, nur eine Admin Instanz. Am Anfang wollte mal die 8081 nicht mehr, dann habe ich eine admin.1 aufgemacht, Port 8089 und die als admin.1 gelassen.
            admin.0 gibt es nicht mehr.
            Kann das ein Problem sein?
            S CodierknechtC 2 Antworten Letzte Antwort
              shellyrulestheworld
              #46
                shellyrulestheworld
                #47
                  Heute leider das gleiche Spiel:
                  2023-01-23 18:30:14.828 - warn: trashschedule.0 (1627) no events matches type "Altpapier" with match "Altpapier"
                  2023-01-23 18:30:19.839 - info: ical.0 (64838) Terminated (NO_ERROR): Without reason
                  2023-01-23 18:30:20.382 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-01-23 18:30:32.846 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
                  2023-01-23 18:30:40.606 - info: daswetter.0 (64819) still wrong data structure from server received! repaired...
                  2023-01-23 18:30:47.585 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
                  2023-01-23 18:30:49.031 - info: daswetter.0 (64819) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2023-01-23 18:30:49.555 - info: daswetter.0 (64819) cleaned everything up...
                  2023-01-23 18:30:49.584 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-01-23 18:32:30.483 - info: javascript.0 (806) Stop script script.js.Test.Test
                  2023-01-23 18:33:38.234 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
                  2023-01-23 18:33:59.666 - info: javascript.0 (806) Start javascript script.js.Test.Test
                  2023-01-23 18:33:59.686 - info: javascript.0 (806) script.js.Test.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 18:34:46.007 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
                  2023-01-23 18:35:00.238 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 64966
                  2023-01-23 18:35:04.018 - info: dwd.0 (64966) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 18:35:09.773 - info: dwd.0 (64966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-01-23 18:35:10.322 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-01-23 18:35:50.683 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
                  2023-01-23 18:40:00.242 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65118
                  2023-01-23 18:40:04.203 - info: dwd.0 (65118) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 18:40:10.272 - info: dwd.0 (65118) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-01-23 18:40:10.807 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-01-23 18:45:00.041 - info: javascript.0 (806) script.js.PV.VerbrauchsberechnungShellys: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 28
                  2023-01-23 18:45:00.292 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65289
                  2023-01-23 18:45:04.381 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 65300
                  2023-01-23 18:45:06.108 - info: dwd.0 (65289) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 18:45:08.637 - info: daswetter.0 (65300) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 18:45:09.580 - error: pvforecast.0 (1536) [updateActualWeatherData] failed to update weather data: TypeError: data.filter is not a function
                  2023-01-23 18:45:11.322 - info: dwd.0 (65289) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-01-23 18:45:11.946 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-01-23 18:45:38.150 - info: daswetter.0 (65300) still wrong data structure from server received! repaired...
                  2023-01-23 18:45:47.366 - info: daswetter.0 (65300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2023-01-23 18:45:47.883 - info: daswetter.0 (65300) cleaned everything up...
                  2023-01-23 18:45:47.907 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-01-23 18:47:24.927 - info: admin.1 (739) Request actual repository...
                  2023-01-23 18:47:25.659 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2023-01-23 18:47:35.629 - info: hs100.0 (1413) cleaned everything up...
                  2023-01-23 18:47:35.642 - error: pvforecast.0 (1536) States database error: read ECONNRESET
                  2023-01-23 18:47:35.823 - error: trashschedule.0 (1627) States database error: read ECONNRESET
                  2023-01-23 18:47:35.679 - info: zigbee.0 (1204) cleaned everything up...
                  2023-01-23 18:47:35.676 - info: pollenflug.0 (37919) Closing Adapter
                  2023-01-23 18:47:35.896 - info: trashschedule.0 (1627) cleaned everything up...
                  2023-01-23 18:47:35.694 - info: javascript.0 (806) Stop script script.js.Heizungssteuerung.HeizungssteuerungBenno
                  2023-01-23 18:47:35.682 - info: info.0 (1428) cleaned everything up...
                  Zeile 47 und 48, wie auch schon davor..
                  #48
                  @shellyrulestheworld meine Frage nach /var/log/syslog und was da zeitlich passend steht ist noch nicht beantwortet gewesen oder?!
                    Codierknecht
                    #49
                    Nö - in dem Fall eher nicht.
                    • apollon77A apollon77
                      shellyrulestheworld
                      #50
                      @apollon77 jetzt kommt ne doofe Frage: was möchtest du haben und wie lade ich es am besten herunter? 0c6581bb-4470-4462-ba9d-43db91f99eb3-grafik.png
                        #51
                        CodeTags verwenden, keine Screenshots.
                        less -R /var/log/syslog
                          shellyrulestheworld
                          schrieb am zuletzt editiert von shellyrulestheworld
                          #52
                          @thomas-braun da steht zu viel drin ... das hier in Codetags würde den Rahmen sprengen...
                          Beispiel:
                          videodevice /dev/video0 and input -1
                          Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                          Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                          Jan 22 00:01:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                          Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                          Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                          Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                          Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                          Jan 22 00:01:40 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying unti:
                            Beispiel:
                            #53
                            Deswegen sollst du ja auch den zeitlich passenden Bereich posten.
                            S 2 Antworten Letzte Antwort
                              shellyrulestheworld
                              #54
                              Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                              Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                              Jan 23 18:47:20 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                              Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                              Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                              Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                              Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                              Jan 23 18:47:25 raspberrypi bash[712]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript
                              /Node.js","type":"linux"}],"node":"v16.19.0","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":
                              "Javascript/Node.js"},"backitup":{"version":"2.5.10","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Ja
                              vascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascr
                              ipt/Node.js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.2.4","platform":"Javascript
                              /Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/No
                              de.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node
                              .js"},"jarvis":{"version":"3.1.2","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Nod
                              e.js"},"philips-air":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platform":"Javascript/No
                              de.js"},"shelly":{"version":"6.2.4","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},"synology":{"version":"2.1.13","platform":"Javascript/
                              Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javasc
                              ript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.0.3","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javasc
                              ript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7
                              .2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"zigbee":{"version":"
                              1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"ver
                              sion":"3.3.6","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"}
                              ,"vis-2-widgets-energy":{"version":"0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
                              "Javascript/Node.js"},"daswetter":{"version":"3.1.4","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"alarm":{"version":"3.3.9","platform":
                              "Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":50,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux"
                              ,"city":"Mössingen","vis":20}
                              Jan 23 18:47:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                              Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                              Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                              Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                              Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                              Jan 23 18:47:34 raspberrypi kernel: [84968.088992] io.text2command invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089018] CPU: 2 PID: 1593 Comm: io.text2command Tainted: G         C        5.15.84-v8+ #1613
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089025] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089028] Call trace:
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089030]  dump_backtrace+0x0/0x1b8
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089045]  show_stack+0x20/0x30
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089051]  dump_stack_lvl+0x8c/0xb8
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089057]  dump_stack+0x18/0x34
                              Jan 23 18:47:34 raspberrypi kernel: [84968.089061]  dump_header+0x4c/0x204
                                shellyrulestheworld
                                #55
                                @thomas-braun reicht die Zeit oder noch mehr davor / danach ?
                                • GaspodeG Offline
                                  GaspodeG Offline
                                  Gaspode
                                  #56
                                  Dazu hat @apollon77 schon vor längerer Zeit in einem anderen Thread was geschrieben:
                                  @apollon77 said in Iobroker stuerzt immer wieder mal ab:
                                  Wenn oom_reaper bzw oom_killer im
                                  Syslog stehen dann geht dir der Speicher aus und der Kernel schießt Prozesse ab. Also ramnutzung wird dein Problem sein. Es läuft mehr als du ram hast.
                                  Es ist also wohl so, wie er oben bereits vermutet hat:
                                  @apollon77 said in Raspberry Absturz alle 3 Tage:
                                  Ich tippe auf Zuviele Instanzen bei zu wenig RAM.
                                  • GaspodeG Gaspode
                                    shellyrulestheworld
                                    #57
                                    @gaspode
                                    aktuelle Werte (ich finde die nicht abnormal und RAM --> 11% aktuell)
                                    CPU: 25,85 %
                                    RAM: 11,6 %
                                    Betriebszeit: 14h
                                    Verfügbar: 4.0.24
                                    Installiert: 4.0.24
                                    Ereignisse: ⇥38 / ↦15
                                    Plattform: linux
                                    Betriebssystem: linux
                                    Architektur: arm64
                                    CPUs: 4
                                    Geschwindigkeit: 1800 MHz
                                    Modell: Cortex-A72
                                    RAM: 3.6 GB
                                    System-Betriebszeit: 1 T. 11:21:29
                                    Node.js: v16.19.0
                                    time: 1674538375851
                                    timeOffset: -60
                                    Adapter-Anzahl: 456
                                    NPM: 8.19.3
                                    Datenträgergröße: 58.3 GB
                                    Freier Festplattenspeicher: 47.7 GB
                                    Betriebszeit: 11:45:00
                                    Aktive Instanzen: 38
                                    Pfad: /opt/iobroker/
                                    aktiv: true
                                    _nodeCurrent: 16.19.0
                                    _nodeNewest: 16.19.0
                                    _nodeNewestNext: 16.19.0
                                    _npmCurrent: 8.19.3
                                    _npmNewest: 8.19.3
                                    _npmNewestNext: 8.19.3
                                    Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
                                      @gaspode
                                      CPU: 25,85 %
                                      RAM: 11,6 %
                                      Betriebszeit: 14h
                                      Verfügbar: 4.0.24
                                      Installiert: 4.0.24
                                      Plattform: linux
                                      Architektur: arm64
                                      CPUs: 4
                                      Modell: Cortex-A72
                                      RAM: 3.6 GB
                                      Node.js: v16.19.0
                                      time: 1674538375851
                                      timeOffset: -60
                                      Adapter-Anzahl: 456
                                      NPM: 8.19.3
                                      aktiv: true
                                      _npmCurrent: 8.19.3
                                      _npmNewest: 8.19.3
                                      #58
                                      Könnte Grenzwertig sein.
                                        @gaspode
                                        CPU: 25,85 %
                                        RAM: 11,6 %
                                        Betriebszeit: 14h
                                        Verfügbar: 4.0.24
                                        Installiert: 4.0.24
                                        Plattform: linux
                                        Architektur: arm64
                                        CPUs: 4
                                        Modell: Cortex-A72
                                        RAM: 3.6 GB
                                        Node.js: v16.19.0
                                        time: 1674538375851
                                        timeOffset: -60
                                        Adapter-Anzahl: 456
                                        NPM: 8.19.3
                                        aktiv: true
                                        _npmCurrent: 8.19.3
                                        _npmNewest: 8.19.3
                                        GaspodeG Offline
                                        GaspodeG Offline
                                        Gaspode
                                        schrieb am zuletzt editiert von Gaspode
                                        #59
                                        @shellyrulestheworld said in Raspberry Absturz alle 3 Tage:
                                        Er läuft jetzt ja auch erst 14 Stunden, und nach drei Tagen kommt es zu dem Problem. In der Zischenzeit kann viel passieren, die RAM Auslastung ist ja nur eine Momentaufnahme. Evtl. hast du auch einen Prozess, der allokierten Speicher nicht mehr sauber freigibt.
                                        Ich würde mir an deiner Stelle mal regelmäßig die RAM Auslastung ansehen, so etwa alle 4 bis 6 Stunden, ob ein Trend erkennbar ist.
                                        Hier zur Hintergrundinfo (was passenderes habe ich auf die Schnelle nicht gefunden, aber das Prinzip wird verständlich erklärt):
                                        https://neo4j.com/developer/kb/linux-out-of-memory-killer/
                                        • GaspodeG Gaspode
                                          #60
                                          @gaspode
                                          https://www.linuxatemyram.com/
                                          Prüf mal ob der v4l2 Kram da erforderlich ist. Kamera im Einsatz? Die scheint jedenfalls nicht korrekt installiert zu sein.
                                          S GaspodeG 3 Antworten Letzte Antwort
